- 19-FC and FCoE
- 01-FC-MGMT-MIB
- 02-HH3C-FDMI-MIB
- 03-HH3C-FC-FLOGIN-MIB
- 04-HH3C-FC-NAME-SERVER-MIB
- 05-HH3C-FC-PING-MIB
- 06-HH3C-FC-PSM-MIB
- 07-HH3C-NPV-MIB
- 08-HH3C-SAN-AGG-MIB
- 09-HH3C-VSAN-MIB
- 10-HH3C-FC-TRACE-ROUTE-MIB
- 11-HH3C-FC-ZONE-SERVER-MIB
- 12-HH3C-FCOE-MODE-MIB
- 13-HH3C-FCOE-MIB
- 14-T11-FC-FABRIC-CONFIG-SERVER-MIB
- 15-T11-FC-NAME-SERVER-MIB
- 16-T11-FC-ROUTE-MIB
- 17-T11-FC-VIRTUAL-FABRIC-MIB
- 18-T11-FC-ZONE-SERVER-MIB
08-HH3C-SAN-AGG-MIB | 99.34 KB |
HH3C-SAN-AGG-MIB
About this MIB
Use this MIB to configure SAN aggregation.
MIB file name
hh3c-san-agg.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSan(127).hh3cSanAgg(2)
Scalar objects
hh3cSanAggMaxMemberNumber
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSanAggMaxMemberNumber (1.3.6.1.4.1.25506.2.127.2.1.1) |
read-only |
Integer32 |
Integer32 |
Maximum number of member ports allowed in an FC aggregate interface. |
As per the MIB. |
hh3cSanAggGroupPreviousSpeed
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSanAggGroupPreviousSpeed (1.3.6.1.4.1.25506.2.127.2.3.1) |
accessible-for-notify |
Integer32 |
Integer32 |
Speed of the FC aggregate interface before speed change. |
As per the MIB. |
hh3cSanAggGroupCurrentSpeed
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSanAggGroupCurrentSpeed (1.3.6.1.4.1.25506.2.127.2.3.2) |
Integer32 |
Integer32 |
Speed of the FC aggregate interface after speed change. |
As per the MIB. |
Tabular objects
hh3cSanAggGroupTable
About this table
This table configures or obtains FC aggregate interface information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Not supported |
Supported |
Columns
The table index is hh3cSanAggGroupNumber.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSanAggGroupNumber (1.3.6.1.4.1.25506.2.127.2.2.1.1) |
Integer32 |
Integer (32 bit) |
FC aggregate interface number. |
As per the MIB. |
hh3cSanAggGroupIndex (1.3.6.1.4.1.25506.2.127.2.2.1.2) |
read-only |
Integer32 |
Integer (32 bit) |
FC aggregate interface index. |
As per the MIB. |
hh3cSanAggMemberList (1.3.6.1.4.1.25506.2.127.2.2.1.3) |
read-create |
OCTET STRING |
Octets |
List of member port indexes. |
As per the MIB. |
hh3cSanAggMemberStateList (1.3.6.1.4.1.25506.2.127.2.2.1.4) |
read-only |
OCTET STRING |
Octets |
List of member port states. |
As per the MIB. |
hh3cSanAggGroupRowStatus (1.3.6.1.4.1.25506.2.127.2.2.1.5) |
read-create |
INTEGER |
Integer (32 bit) |
Row status. |
Supports the following values: · active(1). · createAndGo(4). · destroy(6). |
Notifications
hh3cSanAggGroupSpeedChange
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.127.2.4.0.1 |
FC aggregate interface speed changed |
Informational |
Warning |
N/A |
ON |
Notification triggers
This notification is generated when the speed of an FC aggregate interface changes because a link error occurs or the network topology changes.
System impact
Services on the FC aggregate interface are affected.
Status control
The notification cannot be disabled.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.127.2.2.1.1 (hh3cSanAggGroupNumber) |
Aggregation group number for the aggregate interface. |
hh3cSanAggGroupNumber |
Integer32 |
1..65535 |
1.3.6.1.4.1.25506.2.127.2.3.1 (hh3cSanAggGroupPreviousSpeed) |
Speed of the FC aggregate interface before speed change |
N/A |
Integer32 |
Standard MIB values. |
1.3.6.1.4.1.25506.2.127.2.3.2 (hh3cSanAggGroupCurrentSpeed) |
Speed of the FC aggregate interface after speed change |
N/A |
Integer32 |
Recommended action
To resolve the issue:
1. Verify that no link error or network topology change occurs.
2. If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cSanAggMemberInactive
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.127.2.4.0.2 |
Member port becoming Unselected |
Error |
Major |
1.3.6.1.4.1.25506.2.127.2.4.0.3(hh3cSanAggMemberActive) |
ON |
This notification is generated when a member port becomes Unselected.
System impact
None.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Integer32 |
1..65535 |
1.3.6.1.2.1.2.2.1.1 (ifIndex) |
Index of the member port. |
ifIndex |
InterfaceIndex |
Integer32(1..2147483647) |
1.3.6.1.2.1.2.2.1.2 (ifDescr) |
Description of the member port. |
ifIndex |
DisplayString |
OCTET STRING (SIZE (0..255)) |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.127.2.4.0.3 |
Member port becoming Selected |
Recovery |
Warning |
N/A |
ON |
This notification is generated when a member port becomes Selected.
System impact
None.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Integer32 |
1..65535 |
ifIndex |
InterfaceIndex |
ifIndex |
DisplayString |
Recommended action
