19-FC and FCoE
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 6715-6W10019-FC and FCoE
16-T11-FC-ROUTE-MIB
16-T11-FC-ROUTE-MIB 78.84 KB
T11-FC-ROUTE-MIB
About this MIB
Use this MIB to implement the functions supported by RFC 4625. A switch does not support this MIB when it is operating is NPV mode.
MIB file name
rfc4625-t11-fc-route.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).t11FcRouteMIB(144)
Tabular objects
t11FcRouteFabricTable
About this table
This table obtains routing information in a VSAN.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are fcmInstanceIndex, fcmSwitchIndex, and t11FcRouteFabricIndex.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.144.1.1.1.1)
not-accessible
T11FabricIndex
Unsigned32
(0..4095)
VSAN ID.
As per the MIB.
t11FcRouteFabricLastChange (1.3.6.1.2.1.144.1.1.1.2)
read-only
TimeStamp
TimeTicks
(0.. 4294967295)
Route update time.
As per the MIB.
t11FcRouteTable
About this table
This table obtains information about a specific route.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are fcmInstanceIndex , fcmSwitchIndex, t11FcRouteFabricIndex, t11FcRouteDestAddrId, t11FcRouteDestMask, t11FcRouteSrcAddrId, t11FcRouteSrcMask, t11FcRouteInInterface, t11FcRouteProto, and t11FcRouteOutInterface.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.144.1.2.1.1)
not-accessible
FcAddressIdOrZero
OCTET STRING (3)
Destination FC address.
As per the MIB.
t11FcRouteDestMask
(1.3.6.1.2.1.144.1.2.1.2)
not-accessible
FcAddressIdOrZero
OCTET STRING (0 | 3)
Mask for the destination FC address.
As per the MIB.
t11FcRouteSrcAddrId
(1.3.6.1.2.1.144.1.2.1.3)
not-accessible
FcAddressIdOrZero
Source FC address.
As per the MIB.
t11FcRouteSrcMask
(1.3.6.1.2.1.144.1.2.1.4)
not-accessible
FcAddressIdOrZero
Mask for the source FC address.
As per the MIB.
(1.3.6.1.2.1.144.1.2.1.5)
not-accessible
InterfaceIndexOrZero
Integer32
(0.. 2147483647)
Input interface index.
As per the MIB.
t11FcRouteProto
(1.3.6.1.2.1.144.1.2.1.6)
not-accessible
INTEGER
INTEGER
1:other(1)
2:local(2)
3:netmgmt(3)
4:fspf(4)
Mechanism via which the route was learned.
As per the MIB.
(1.3.6.1.2.1.144.1.2.1.7)
not-accessible
Integer32
(0.. 2147483647)
Output interface index.
As per the MIB.
t11FcRouteDomainId
(1.3.6.1.2.1.144.1.2.1.8)
read-create
FcDomainIdOrZero
Integer32
(0.. 239)
Domain ID of next hop switch..
Supports only the read operation.
t11FcRouteMetric
(1.3.6.1.2.1.144.1.2.1.9)
read-create
Unsigned32
 Unsigned32
(0.. 65536)
Routing metric for the route..
t11FcRouteType
(1.3.6.1.2.1.144.1.2.1.10)
read-create
INTEGER
INTEGER
1:local(1)
2:remote(2)
Route type.
t11FcRouteIfDown
(1.3.6.1.2.1.144.1.2.1.11)
read-create
INTEGER
INTEGER
1:remove(1)
2:retain(2)
Indicates what happens to the route when the output interface is operationally down.
t11FcRouteStorageType
(1.3.6.1.2.1.144.1.2.1.12)
read-create
StorageType
INTEGER
other(1)
volatile(2)
nonVolatile(3)                     permanent(4)                     readOnly(5)
Storage type.
Supports only the read operation. When read, this object always returns Volatile (2).
t11FcRouteRowStatus
(1.3.6.1.2.1.144.1.2.1.13)
read-create
RowStatus
INTEGER
active(1)
notInService(2)
notReady(3)
createAndGo(4)
createAndWait(5)
destroty(6)
Row status.
