- 19-FC and FCoE
- 01-FC-MGMT-MIB
- 02-HH3C-FDMI-MIB
- 03-HH3C-FC-FLOGIN-MIB
- 04-HH3C-FC-NAME-SERVER-MIB
- 05-HH3C-FC-PING-MIB
- 06-HH3C-FC-PSM-MIB
- 07-HH3C-NPV-MIB
- 08-HH3C-SAN-AGG-MIB
- 09-HH3C-VSAN-MIB
- 10-HH3C-FC-TRACE-ROUTE-MIB
- 11-HH3C-FC-ZONE-SERVER-MIB
- 12-HH3C-FCOE-MODE-MIB
- 13-HH3C-FCOE-MIB
- 14-T11-FC-FABRIC-CONFIG-SERVER-MIB
- 15-T11-FC-NAME-SERVER-MIB
- 16-T11-FC-ROUTE-MIB
- 17-T11-FC-VIRTUAL-FABRIC-MIB
- 18-T11-FC-ZONE-SERVER-MIB
09-HH3C-VSAN-MIB | 174.18 KB |
hh3cVsanDmFabricChangeNotifyEnable
hh3cVsanDmDomainIdChangeNotifyEnable
hh3cVsanDmDomainIdNotAssignedNotify
hh3cVsanDmNewPrincipalSwitchNotify
HH3C-VSAN-MIB
About this MIB
Use this MIB to configure or obtain VSAN settings.
MIB file name
hh3c-vsan.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSan(127).hh3cVsan(1)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsanDmFabricChangeNotifyEnable (1.3.6.1.4.1.25506.2.127.1.1.3.1.1) |
read-write |
TruthValue |
TruthValue |
Trap switch for hh3cVsanDmFabricChangeNotify |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsanDmDomainIdChangeNotifyEnable (1.3.6.1.4.1.25506.2.127.1.1.3.1.2) |
read-write |
TruthValue |
TruthValue |
Trap switch for hh3cVsanDmDomainIdChangeNotify |
As per the MIB. |
Tabular objects
hh3cVsanTable
About this table
This table creates or deletes a VSAN, and obtains the physical switch name.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table index is hh3cVsanIndex.
OID of this table is:1.3.6.1.4.1.25506.2.127.1.1.1.1
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsanIndex (1.3.6.1.4.1.25506.2.127.1.1.1.1.1.1) |
accessible-for-notify |
Unsigned32 |
Unsigned32 |
VSAN ID |
The value range is 2 to 3839 for creating, configuring, or deleting a VSAN. VSAN 1 is the default VSAN, and VSAN 4079 is the control VSAN. |
hh3cVsanCoreSwitchName (1.3.6.1.4.1.25506.2.127.1.1.1.1.1.2) |
read-only |
Hh3cFcNameIdOrZero |
OCTET STRING (8 | 16) |
Physical switch name. |
As per the MIB. |
hh3cVsanRowStatus (1.3.6.1.4.1.25506.2.127.1.1.1.1.1.3) |
read-create |
INTEGER |
1:active(1) |
Row status. |
VSANs 2 to 3839 support the following values: · active(1). · createAndGo(4). · destroy(6). VSAN 1 and VSAN 4079 support only active(1). |
hh3cVsanName (1.3.6.1.4.1.25506.2.127.1.1.1.1.1.4) |
read-create |
OCTET STRING |
OCTET STRING |
VSAN name. |
As per the MIB. |
hh3cVsanWorkingMode (1.3.6.1.4.1.25506.2.127.1.1.1.1.1.5) |
read-create |
Integer32 |
Integer32 |
Operating mode of the VSAN. |
As per the MIB. |
hh3cVsanDmTable
About this table
This table configures or obtains domain information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
OID of this table is: 1.3.6.1.4.1.25506.2.127.1.1.1.2
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsanDmDomainConfigureEnable (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.1) |
read-write |
TruthValue |
true(1), |
Fabric configuration status. |
As per the MIB. |
hh3cVsanDmFabricNameConfigured (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.2) |
read-write |
OCTET STRING (0 | 8 | 16) |
Configured fabric name. |
As per the MIB. |
hh3cVsanDmPriorityConfigured (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.3) |
read-write |
Unsigned32 |
noOperation(1) |
Configured switch priority. |
As per the MIB. |
hh3cVsanDmAllowedDomainIdList (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.4) |
read-write |
OCTET STRING |
disabledWithNoDomain(1), |
Allowed domain ID list. |
As per the MIB. |
hh3cVsanDmDomainIdConfigured (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.5) |
read-write |
Hh3cFcDomainIdOrZero |
Integer32 |
Configured domain ID. |
As per the MIB. |
hh3cVsanDmDomainIdTypeConfigured (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.6) |
read-write |
INTEGER |
static(1), |
Configured domain ID type. |
As per the MIB. |
hh3cVsanDmAutoReconfigureEnable (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.7) |
read-write |
TruthValue |
true(1), |
Automatic reconfiguration status. |
As per the MIB. |
hh3cVsanDmDomainRestart (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.8) |
read-write |
INTEGER |
noOperation(1), |
Fabric reconfiguration type. |
As per the MIB. |
hh3cVsanDmState (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.9) |
read-only |
Hh3cFcDmState |
Domain status. |
As per the MIB. |
hh3cVsanDmDomainIdAssigned (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.10) |
read-only |
Integer32 (0..239) |
Assigned domain ID. |
As per the MIB. |
hh3cVsanDmPrincipalSwitchWWN (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.11) |
read-only |
Hh3cFcNameId |
OCTET STRING (8) |
Principal switch WWN. |
As per the MIB. |
hh3cVsanDmLocalSwitchWWN (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.12) |
read-only |
Hh3cFcNameId |
OCTET STRING (8) |
Local switch WWN. |
As per the MIB. |
hh3cVsanDmPrincipalSwRunPriority (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.13) |
read-only |
Hh3cFcDomainPriority |
Unsigned32 (1..254) |
Principal switch runtime priority. |
As per the MIB. |
hh3cVsanDmLocalSwRunPriority (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.14) |
read-only |
Local switch runtime priority. |
As per the MIB. |
hh3cVsanDmPrincipalSwSlctCnt (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.15) |
read-only |
Counter32 |
Standard MIB values. |
Number of times the local switch participates in principal switch election is a VSAN. |
As per the MIB. |
hh3cVsanDmLocalPrincipalSwSlctCnt(1.3.6.1.4.1.25506.2.127.1.1.1.2.1.16) |
read-only |
Counter32 |
Number of times the local switch becomes the principal switch. |
As per the MIB. |
hh3cVsanDmBFCnt (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.17) |
read-only |
Counter32 |
Number of times the local switch participates in nondisruptive reconfiguration. |
As per the MIB. |
hh3cVsanDmRCFCnt (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.18) |
read-only |
Counter32 |
Number of times the local switch participates in disruptive reconfiguration. |
As per the MIB. |
hh3cVsanDmIfConfigTable
About this table
This table configures domain information for an interface in a VSAN.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Not supported |
Columns
The table indexes are ifIndex and hh3cVsanIndex.
OID of this table is:1.3.6.1.4.1.25506.2.127.1.1.1.3
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsanDmIfConfigRcfReject (1.3.6.1.4.1.25506.2.127.1.1.1.3.1.1) |
read-write |
TruthValue |
true(1), |
Indicates whether the interface rejects incoming RCF requests. |
As per the MIB. |
hh3cVsanDmDatabaseTable
About this table
This table obtains the physical switch name for a domain ID in a VSAN.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cVsanIndex and hh3cVsanDmDatabaseDomainId.
OID of this table is:1.3.6.1.4.1.25506.2.127.1.1.2.1
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsanDmDatabaseDomainId (1.3.6.1.4.1.25506.2.127.1.1.2.1.1.1) |
not-accessible |
Integer32 |
Integer32 |
Domain ID. |
As per the MIB. |
hh3cVsanDmDatabaseSwitchWWN (1.3.6.1.4.1.25506.2.127.1.1.2.1.1.2) |
read-only |
OCTET STRING |
octet string |
As per the MIB. |
hh3cVsanDmIfInfoTable
About this table
This table obtains interface status in a VSAN.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
OID of this table is:1.3.6.1.4.1.25506.2.127.1.1.2.2
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsanDmIfInfoRole (1.3.6.1.4.1.25506.2.127.1.1.2.2.1.1) |
read-only |
INTEGER |
nonPrincipal(1) |
Status of an interface in a VSAN. |
As per the MIB. |
hh3cVsanFcIdTable
About this table
This table configures or obtains the persistent FC ID feature information in a VSAN.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
OID of this table is:1.3.6.1.4.1.25506.2.127.1.1.1.4
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsanFreeFcIds(1.3.6.1.4.1.25506.2.127.1.1.1.4.1.1) |
read-only |
Counter32 |
Counter32 |
Free FC IDs. |
As per the MIB. |
hh3cVsanAssignedFcIds(1.3.6.1.4.1.25506.2.127.1.1.1.4.1.2) |
read-only |
Counter32 |
Counter32 |
Assigned FC IDs. |
As per the MIB. |
hh3cVsanFcIdPersistency(1.3.6.1.4.1.25506.2.127.1.1.1.4.1.3) |
read-write |
INTEGER |
TruthValue |
Persistent FC ID feature. |
As per the MIB. |
hh3cVsanFcIdPurge(1.3.6.1.4.1.25506.2.127.1.1.1.4.1.4) |
read-write |
INTEGER |
noOp(1) |
FC ID purging. |
As per the MIB. |
hh3cVsanFcIdPersistencyTable
About this table
This table manages the persistent FC ID database in a VSAN.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are hh3cVsanIndex and hh3cVsanFcIdPersistencyWwn.
OID of this table is:1.3.6.1.4.1.25506.2.127.1.1.1.5
Note: When creating a new instance of this table, the following objects should be set simultaneously
hh3cVsanFcIdPersistencyFcId, hh3cVsanFcIdPersistencyType, hh3cVsanFcIdPersistencyRowStatus.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsanFcIdPersistencyWwn(1.3.6.1.4.1.25506.2.127.1.1.1.5.1.1) |
not-accessible |
OCTET STRING |
Octets |
Persistent WWN. |
As per the MIB. |
hh3cVsanFcIdPersistencyFcId(1.3.6.1.4.1.25506.2.127.1.1.1.5.1.2) |
read-create |
OCTET STRING |
Octets |
Persistent FC ID. |
As per the MIB. |
hh3cVsanFcIdPersistencyUsed(1.3.6.1.4.1.25506.2.127.1.1.1.5.1.3) |
read-only |
INTEGER |
TruthValue |
Persistency. |
As per the MIB. |
hh3cVsanFcIdPersistencyType(1.3.6.1.4.1.25506.2.127.1.1.1.5.1.4) |
read-create |
INTEGER |
static(1) |
Persistency type. |
As per the MIB. |
hh3cVsanFcIdPersistencyRowStatus(1.3.6.1.4.1.25506.2.127.1.1.1.5.1.5) |
read-create |
INTEGER |
Integer (32 bit) |
Row status. |
As per the MIB. |
Notifications
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.127.1.1.3.0.1 |
Domain ID assignment failure |
Informational |
Major |
N/A |
ON |
Notification triggers
This notification might be generated when the following events occur:
· The switch's request to apply for a domain ID is rejected.
· The switch receives an assigned domain ID that is different from the statically configured domain ID.
· The switch receives an assigned domain ID that is not in its allowed domain ID list.
· On the switch, the fabric configuration feature is disabled and the configured domain ID is removed.
· On the switch, there is no configured domain ID when the fabric configuration feature is disabled.
System impact
Services that use domain IDs are affected.
Status control
The notification cannot be disabled.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.127.1.1.1.1.1.1 (hh3cVsanIndex) |
VSAN ID. |
hh3cVsanIndex |
Hh3cFcVsanIndex |
Unsigned32 (1..4095) |
1.3.6.1.4.1.25506.2.127.1.1.1.2.1.12 (hh3cVsanDmLocalSwitchWWN) |
Local switch WWN. |
hh3cVsanIndex |
Hh3cFcNameId |
OCTET STRING (SIZE (8)) |
Recommended action
To resolve this issue:
1. Verify that the configuration and network topology are correct.
2. If this issue persists, contact H3C Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.127.1.1.3.0.2 |
A switch selected as the principal switch in a VSAN |
Informational |
Warning |
N/A |
ON |
A switch is selected as the principal switch in a VSAN.
System impact
No negative impact on services.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
VSAN ID. |
hh3cVsanIndex |
Hh3cFcVsanIndex |
Unsigned32(1..4095) |
Local switch WWN. |
hh3cVsanIndex |
Hh3cFcNameId |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.127.1.1.3.0.3 |
BF or RCF frames received or sent in a VSAN |
Informational |
Warning |
N/A |
OFF |
The switch receives or sends BF or RCF frames in a VSAN.
System impact
Services that use the information carried in the BF or RCF frames will be affected.
Status control
ON
· CLI: Use the snmp-agent trap enable fc-fabric fabric-change command.
· MIB: Set hh3cVsanDmFabricChangeNotifyEnable to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable fc-fabric fabric-change command.
· MIB: Set hh3cVsanDmFabricChangeNotifyEnable to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
VSAN ID. |
hh3cVsanIndex |
Hh3cFcVsanIndex |
Recommended action
1. Verify whether the BF or RCF frames have negative impacts on services:
¡ If the BF or RCF frames have no negative impact on services, no action is required.
¡ If the BF or RCF frames have negative impacts on services, go to the next step.
2. Verify that the configuration and network topology are correct.
3. If this issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.127.1.1.3.0.4 |
Domain ID changed in a VSAN |
Informational |
Warning |
N/A |
OFF |
The domain ID changes in a VSAN.
System impact
If the domain ID change is normal, there is no negative impact on services. If the domain ID change is abnormal, services in the VSAN will be affected.
Status control
ON
· CLI: Use the snmp-agent trap enable fc-fabric domain-id-change command.
· MIB: Set hh3cVsanDmDomainIdChangeNotifyEnable to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable fc-fabric domain-id-change command.
· MIB: Set hh3cVsanDmDomainIdChangeNotifyEnable to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
VSAN ID. |
hh3cVsanIndex |
Hh3cFcVsanIndex |
1.3.6.1.4.1.25506.2.127.1.1.1.2.1.10 (hh3cVsanDmDomainIdAssigned) |
hh3cVsanIndex |
Integer32(0..239) |
Local switch WWN. |
hh3cVsanIndex |
Hh3cFcNameId |
Recommended action
1. Verify whether the domain ID change is normal:
¡ If the domain ID change is normal, no action is required.
¡ If the domain ID change is abnormal, go to the next step.
