- 19-FC and FCoE
- 01-FC-MGMT-MIB
- 02-HH3C-FDMI-MIB
- 03-HH3C-FC-FLOGIN-MIB
- 04-HH3C-FC-NAME-SERVER-MIB
- 05-HH3C-FC-PING-MIB
- 06-HH3C-FC-PSM-MIB
- 07-HH3C-NPV-MIB
- 08-HH3C-SAN-AGG-MIB
- 09-HH3C-VSAN-MIB
- 10-HH3C-FC-TRACE-ROUTE-MIB
- 11-HH3C-FC-ZONE-SERVER-MIB
- 12-HH3C-FCOE-MODE-MIB
- 13-HH3C-FCOE-MIB
- 14-T11-FC-FABRIC-CONFIG-SERVER-MIB
- 15-T11-FC-NAME-SERVER-MIB
- 16-T11-FC-ROUTE-MIB
- 17-T11-FC-VIRTUAL-FABRIC-MIB
- 18-T11-FC-ZONE-SERVER-MIB
10-HH3C-FC-TRACE-ROUTE-MIB | 85.89 KB |
About this MIB
Use this MIB to configure an FC traceroute operation.
MIB file name
hh3c-fc-trace-route.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSan(127).hh3cFcTraceRoute(4)
Tabular objects
hh3cFcTraceRouteTable
About this table
This table initiates an FC traceroute operation.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Not supported |
Columns
The table index is hh3cFcTraceRouteIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcTraceRouteIndex (1.3.6.1.4.1.25506.2.127.4.1.1.1.1.1) |
accessible-for-notify |
Unsigned32 |
Unsigned32(1..65535) |
FC traceroute entry index. |
As per the MIB. |
hh3cFcTraceRouteVsan (1.3.6.1.4.1.25506.2.127.4.1.1.1.1.2) |
read-create |
Hh3cFcVsanIndex |
Unsigned32(1..4095) |
VSAN for the FC traceroute operation. |
As per the MIB. |
hh3cFcTraceRouteAddressType (1.3.6.1.4.1.25506.2.127.4.1.1.1.1.3) |
read-create |
Hh3cFcAddressType |
wwn(1), fcid(2) |
FC traceroute destination type. |
As per the MIB. |
hh3cFcTraceRouteAddress (1.3.6.1.4.1.25506.2.127.4.1.1.1.1.4) |
read-create |
Hh3cFcAddress |
OCTET STRING (3 | 8) |
FC traceroute destination address. |
As per the MIB. |
hh3cFcTraceRouteTimeout (1.3.6.1.4.1.25506.2.127.4.1.1.1.1.5) |
read-create |
Unsigned32 |
Unsigned32 (1..10) |
Timeout time for the FC traceroute operation. |
As per the MIB. |
hh3cFcTraceRouteAdminStatus (1.3.6.1.4.1.25506.2.127.4.1.1.1.1.6) |
read-create |
Hh3cFcStartOper |
enable (1), disable (2) |
Administrative status for the FC traceroute entry. |
As per the MIB. |
hh3cFcTraceRouteOperStatus (1.3.6.1.4.1.25506.2.127.4.1.1.1.1.7) |
read-only |
INTEGER |
inProgress(1), success(2), partialSuccess(3), failure(4), disabled(5) |
Operational status for the FC traceroute entry. |
As per the MIB. |
hh3cFcTraceRouteAgeInterval (1.3.6.1.4.1.25506.2.127.4.1.1.1.1.8) |
read-create |
Unsigned32 |
Unsigned32(500..900) |
Aging time for the FC traceroute entry. |
As per the MIB. |
hh3cFcTraceRouteTrapOnCompletion (1.3.6.1.4.1.25506.2.127.4.1.1.1.1.9) |
read-create |
TruthValue |
true (1), false (2) |
Indicates whether to generate traps upon the completion of the FC traceroute operation.. |
As per the MIB. |
hh3cFcTraceRouteRowStatus (1.3.6.1.4.1.25506.2.127.4.1.1.1.1.10) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
As per the MIB. |
hh3cFcTraceRouteHopsTable
About this table
This table contains path information for an FC traceroute operation.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
The table indexes are hh3cFcTraceRouteIndex and hh3cFcTraceRouteHopsIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcTraceRouteHopsIndex (1.3.6.1.4.1.25506.2.127.4.1.2.1.1.1) |
not-accessible |
Unsigned32 |
Path entry index. |
As per the MIB. |
hh3cFcTraceRouteHopsAddr (1.3.6.1.4.1.25506.2.127.4.1.2.1.1.2) |
read-only |
Hh3cFcNameId |
OCTET STRING (8) |
WWN of a hop. |
As per the MIB. |
Notifications
hh3cFcTraceRouteCompletionNotify
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.127.4.1.3.0.1 |
FC traceroute operation completed |
Informational |
Warning |
N/A |
OFF |
Notification triggers
An FC traceroute operation is completed.
System impact
No negative impact on services.
Status control
ON
MIB: Set hh3cFcTraceRouteTrapOnCompletion to true(1).
OFF
MIB: Set hh3cFcTraceRouteTrapOnCompletion to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.127.4.1.1.1.1.1 (hh3cFcTraceRouteIndex) |
hh3cFcTraceRouteIndex |
Unsigned32 |
1.3.6.1.4.1.25506.2.127.4.1.1.1.1.2 (hh3cFcTraceRouteVsan) |
VSAN ID. |
Hh3cFcVsanIndex |
1.3.6.1.4.1.25506.2.127.4.1.1.1.1.3 (hh3cFcTraceRouteAddressType) |
Traceroute packet address type. |
Hh3cFcAddressType |
WWN(1), FCID(2) |
1.3.6.1.4.1.25506.2.127.4.1.1.1.1.4 (hh3cFcTraceRouteAddress) |
Traceroute packet address. |
Hh3cFcAddress |
OCTET STRING (3) |
1.3.6.1.4.1.25506.2.127.4.1.1.1.1.7 (hh3cFcTraceRouteOperStatus) |
Traceroute entry operational status. |
INTEGER |
Recommended action
No action is required.
