- 07-Comware 7 Web-based configuration examples (AC+fit AP deployment)
- 01-Telnet Access Control Configuration Example
- 02-IPv6 Telnet Access Control Configuration Example
- 03-Web Access Control Configuration Example
- 04-User Role Assignment for Local Web Authentication Users Configuration Example
- 05-SSH Local Authentication Configuration Example
- 06-SSH User Remote Password Authentication Configuration Example
- 07-IPv6 SSH User Remote Password Authentication Configuration Example
- 08-Password Control Configuration Example
- 09-Licensing Configuration Example
- 10-Automatic License Installation Configuration Example
- 11-Layer 2 Static Link Aggregation Configuration Example
- 12-Layer 2 Dynamic Link Aggregation Configuration Example
- 13-PPPoE Client Configuration Example
- 14-Static IPv6 Address Configuration Example
- 15-IPv6 Static Routing Configuration Example
- 16-Static IPv4 DNS Configuration Example
- 17-Static IPv6 DNS Configuration Example
- 18-IGMP Snooping Configuration Example
- 19-MLD Snooping Configuration Example
- 20-IPv4 DNS Proxy Configuration Example
- 21-IPv6 DNS Proxy Configuration Example
- 22-Static NAT Configuration Example
- 23-Dynamic NAT Configuration Example
- 24-IPv4 ACL-Based Packet Filter Configuration Example
- 25-IPv6 ACL-Based Packet Filter Configuration Example
- 26-ARP Attack Protection Configuration Example
- 27-ARP Proxy Configuration Example
- 28-Dynamic IPv4 DNS Configuration Example
- 29-Dynamic IPv6 DNS Configuration Example
- 30-WLAN Access Configuration Example
- 31-Different Wireless Services on Different Radios Configuration Example
- 32-CAPWAP Tunnel Establishment Through DHCP Configuration Example
- 33-CAPWAP Tunnel Establishment Through DHCPv6 Configuration Example
- 34-CAPWAP Tunnel Establishment Through DNS Configuration Example
- 35-CAPWAP Tunnel Establishment Through DNSv6 Configuration Example
- 36-Auto AP Configuration Example
- 37-AP Group Configuration Example
- 38-Radio Management Configuration Example
- 39-Load Balancing Group-Based Session-Mode Load Balancing Configuration Example
- 40-Radio-Based Session-Mode Load Balancing Configuration Example
- 41-A-MPDU and A-MSDU Configuration Example
- 42-Device Classification and Countermeasure Configuration Example
- 43-Malformed Packet Detection and Flood Attack Detection Configuration Example
- 44-Signature-Based Attack Detection Configuration Example
- 45-802.1X RADIUS-Based AAA Configuration Example
- 46-VLAN Interface-Based Direct Portal Authentication Configuration Example
- 47-Service Template-Based Direct Portal Authentication Configuration Example
- 48-Wireless Spectrum Analysis Configuration Example
- 49-Auto DFS Configuration Examples
- 50-Auto TPC Configuration Examples
- 51-Whitelist-Based Client Access Control Configuration Example
- 52-Blacklist-Based Client Access Control Configuration Example
- 53-CAC Configuration Example
- 54-WLAN Probe Configuration Example
- 55-Intra-AC Roaming Configuration Example
- 56-Bonjour Gateway Configuration Example
- 57-IPv4 Multicast Optimization Configuration Examples
- 58-IPv6 Multicast Optimization Configuration Examples
- 59-Ping Configuration Example
- 60-Local Packet Capture Configuration Example
- 61-Remote Packet Capture Configuration Example
| 61-Remote Packet Capture Configuration Example | 360.39 KB |
H3C Access Controllers |
Comware 7 Remote Packet Capture |
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for configuring remote packet capture and analyzing the captured packets.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of remote packet capture.
Example: Configuring remote packet capture
As shown in Figure 1, configure remote packet capture on Radio 1 of the AP to capture packets. Send the captured packets to the PC. Start Wireshark on the PC to analyze the packets.
Make sure the AP can access the AC.
Install Wireshark V2.6.4 on the PC and make sure the PC and the AP can communicate with each other.
Procedures
Configuring the AC
1. Click the Network View tab at the bottom of the page.
2. From the navigation pane, select Tools > Wireless Capture.
3. Select the wa5320 AP entry with radio 5GHz(1) and click Start.
Figure 2 Selecting an AP
4. Configure the following packet capture parameters:
¡ Select the remote capture mode.
¡ Set the RPCAP service port number to 2014.
Figure 3 Configuring remote packet capture parameters
5. Click Start.
Figure 4 Starting remote packet capture
Configuring Wireshark on the PC
1. Start Wireshark.
2. Select Capture > Options.
Figure 5 Wireshark menu
3. On the Input tab, click Manage Interfaces.
Figure 6 Entering the interface management page
4. Click the Remote Interface tab and complete the following tasks:
¡ Enter the IP address of the AP 192.168.0.2.
¡ Set the port number to 2014.
¡ Select Null authentication.
¡ Click OK.
Figure 7 Adding a remote interface
5. Click OK.
Figure 8 Completing the remote interface configuration
6. Select the remote interface and click Start.
Figure 9 Starting remote packet capture
1. Verify that captured packets are displayed on Wireshark. (Details not shown.)
2. Verify that you can use Wireshark to analyze the packets. (Details not shown.)
Related documentation
H3C Access Controllers Web-Based Configuration Guide
