- 07-Comware 7 Web-based configuration examples (AC+fit AP deployment)
- 01-Telnet Access Control Configuration Example
- 02-IPv6 Telnet Access Control Configuration Example
- 03-Web Access Control Configuration Example
- 04-User Role Assignment for Local Web Authentication Users Configuration Example
- 05-SSH Local Authentication Configuration Example
- 06-SSH User Remote Password Authentication Configuration Example
- 07-IPv6 SSH User Remote Password Authentication Configuration Example
- 08-Password Control Configuration Example
- 09-Licensing Configuration Example
- 10-Automatic License Installation Configuration Example
- 11-Layer 2 Static Link Aggregation Configuration Example
- 12-Layer 2 Dynamic Link Aggregation Configuration Example
- 13-PPPoE Client Configuration Example
- 14-Static IPv6 Address Configuration Example
- 15-IPv6 Static Routing Configuration Example
- 16-Static IPv4 DNS Configuration Example
- 17-Static IPv6 DNS Configuration Example
- 18-IGMP Snooping Configuration Example
- 19-MLD Snooping Configuration Example
- 20-IPv4 DNS Proxy Configuration Example
- 21-IPv6 DNS Proxy Configuration Example
- 22-Static NAT Configuration Example
- 23-Dynamic NAT Configuration Example
- 24-IPv4 ACL-Based Packet Filter Configuration Example
- 25-IPv6 ACL-Based Packet Filter Configuration Example
- 26-ARP Attack Protection Configuration Example
- 27-ARP Proxy Configuration Example
- 28-Dynamic IPv4 DNS Configuration Example
- 29-Dynamic IPv6 DNS Configuration Example
- 30-WLAN Access Configuration Example
- 31-Different Wireless Services on Different Radios Configuration Example
- 32-CAPWAP Tunnel Establishment Through DHCP Configuration Example
- 33-CAPWAP Tunnel Establishment Through DHCPv6 Configuration Example
- 34-CAPWAP Tunnel Establishment Through DNS Configuration Example
- 35-CAPWAP Tunnel Establishment Through DNSv6 Configuration Example
- 36-Auto AP Configuration Example
- 37-AP Group Configuration Example
- 38-Radio Management Configuration Example
- 39-Load Balancing Group-Based Session-Mode Load Balancing Configuration Example
- 40-Radio-Based Session-Mode Load Balancing Configuration Example
- 41-A-MPDU and A-MSDU Configuration Example
- 42-Device Classification and Countermeasure Configuration Example
- 43-Malformed Packet Detection and Flood Attack Detection Configuration Example
- 44-Signature-Based Attack Detection Configuration Example
- 45-802.1X RADIUS-Based AAA Configuration Example
- 46-VLAN Interface-Based Direct Portal Authentication Configuration Example
- 47-Service Template-Based Direct Portal Authentication Configuration Example
- 48-Wireless Spectrum Analysis Configuration Example
- 49-Auto DFS Configuration Examples
- 50-Auto TPC Configuration Examples
- 51-Whitelist-Based Client Access Control Configuration Example
- 52-Blacklist-Based Client Access Control Configuration Example
- 53-CAC Configuration Example
- 54-WLAN Probe Configuration Example
- 55-Intra-AC Roaming Configuration Example
- 56-Bonjour Gateway Configuration Example
- 57-IPv4 Multicast Optimization Configuration Examples
- 58-IPv6 Multicast Optimization Configuration Examples
- 59-Ping Configuration Example
- 60-Local Packet Capture Configuration Example
- 61-Remote Packet Capture Configuration Example
| 15-IPv6 Static Routing Configuration Example | 104.78 KB |
H3C Access Controllers |
Comware 7 IPv6 Static Routing |
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring IPv6 static routing
Assigning IP addresses to interfaces
Configuring an IPv6 static route on AC 1
Configuring IPv6 static routes on AC 2
Configuring an IPv6 static route on AC 3
Overview
The following information provides an example for configuring IPv6 static routes on ACs to allow clients to communicate with each other.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of IPv6 basics and static routing.
As shown in Figure 1, configure IPv6 static routes on ACs to enable the clients to communicate with each other.
Procedures
Assign IPv6 addresses to VLAN interfaces on ACs. (Details not shown.)
1. Click the System View tab at the bottom of the page.
2. From the navigation pane, select Network Configuration > Network Routing.
3. Click the Static Routing tab.
4. Click the Expand icon
for
IPv6 static routing.
5. Click the Add button
to
add an IPv6 static route to match routes with all destination IPv6 addresses.
a. Set the destination IPv6 address to ::.
b. Set the prefix length to 0.
c. Set the next hop address to 4::2.
Figure 2 Configuring a static route on AC 1
6. Click Apply.
On AC 2, configure IPv6 static routes to reach network segments of Client 3 and Client 1 in the same way you configure the IPv6 static route on AC 1.
1. Configure the IPv6 static route to reach the network segment of Client 3 as follows:
a. Set the destination IPv6 address to 3::2.
b. Set the prefix length to 64.
c. Set the next hop address to 5::1.
2. Configure the IPv6 static route to reach the network segment of Client 1 as follows:
a. Set the destination IPv6 address to 1::2.
c. Set the next hop address to 4::1.
On AC 3, configure an IPv6 static route to match routes with all destination IPv6 addresses in the same way you configure the IPv6 static route on AC 1. Configure the following route information on AC 3:
1. Set the destination IPv6 address to ::.
2. Set the prefix length to 0.
3. Set the next hop address to 5::2.
Verify that the clients can ping each other. (Details not shown.)
Related documentation
H3C Access Controllers Web-Based Configuration Guide
