- 07-Comware 7 Web-based configuration examples (AC+fit AP deployment)
- 01-Telnet Access Control Configuration Example
- 02-IPv6 Telnet Access Control Configuration Example
- 03-Web Access Control Configuration Example
- 04-User Role Assignment for Local Web Authentication Users Configuration Example
- 05-SSH Local Authentication Configuration Example
- 06-SSH User Remote Password Authentication Configuration Example
- 07-IPv6 SSH User Remote Password Authentication Configuration Example
- 08-Password Control Configuration Example
- 09-Licensing Configuration Example
- 10-Automatic License Installation Configuration Example
- 11-Layer 2 Static Link Aggregation Configuration Example
- 12-Layer 2 Dynamic Link Aggregation Configuration Example
- 13-PPPoE Client Configuration Example
- 14-Static IPv6 Address Configuration Example
- 15-IPv6 Static Routing Configuration Example
- 16-Static IPv4 DNS Configuration Example
- 17-Static IPv6 DNS Configuration Example
- 18-IGMP Snooping Configuration Example
- 19-MLD Snooping Configuration Example
- 20-IPv4 DNS Proxy Configuration Example
- 21-IPv6 DNS Proxy Configuration Example
- 22-Static NAT Configuration Example
- 23-Dynamic NAT Configuration Example
- 24-IPv4 ACL-Based Packet Filter Configuration Example
- 25-IPv6 ACL-Based Packet Filter Configuration Example
- 26-ARP Attack Protection Configuration Example
- 27-ARP Proxy Configuration Example
- 28-Dynamic IPv4 DNS Configuration Example
- 29-Dynamic IPv6 DNS Configuration Example
- 30-WLAN Access Configuration Example
- 31-Different Wireless Services on Different Radios Configuration Example
- 32-CAPWAP Tunnel Establishment Through DHCP Configuration Example
- 33-CAPWAP Tunnel Establishment Through DHCPv6 Configuration Example
- 34-CAPWAP Tunnel Establishment Through DNS Configuration Example
- 35-CAPWAP Tunnel Establishment Through DNSv6 Configuration Example
- 36-Auto AP Configuration Example
- 37-AP Group Configuration Example
- 38-Radio Management Configuration Example
- 39-Load Balancing Group-Based Session-Mode Load Balancing Configuration Example
- 40-Radio-Based Session-Mode Load Balancing Configuration Example
- 41-A-MPDU and A-MSDU Configuration Example
- 42-Device Classification and Countermeasure Configuration Example
- 43-Malformed Packet Detection and Flood Attack Detection Configuration Example
- 44-Signature-Based Attack Detection Configuration Example
- 45-802.1X RADIUS-Based AAA Configuration Example
- 46-VLAN Interface-Based Direct Portal Authentication Configuration Example
- 47-Service Template-Based Direct Portal Authentication Configuration Example
- 48-Wireless Spectrum Analysis Configuration Example
- 49-Auto DFS Configuration Examples
- 50-Auto TPC Configuration Examples
- 51-Whitelist-Based Client Access Control Configuration Example
- 52-Blacklist-Based Client Access Control Configuration Example
- 53-CAC Configuration Example
- 54-WLAN Probe Configuration Example
- 55-Intra-AC Roaming Configuration Example
- 56-Bonjour Gateway Configuration Example
- 57-IPv4 Multicast Optimization Configuration Examples
- 58-IPv6 Multicast Optimization Configuration Examples
- 59-Ping Configuration Example
- 60-Local Packet Capture Configuration Example
- 61-Remote Packet Capture Configuration Example
| 13-PPPoE Client Configuration Example | 136.25 KB |
H3C Access Controllers |
Comware 7 PPPoE Client |
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring the PPPoE client
Configuring the PPPoE server to assign the username and password to the AC
Overview
Point-to-Point Protocol over Ethernet (PPPoE) extends PPP by transporting PPP frames encapsulated in Ethernet over point-to-point links. PPPoE specifies the methods for establishing PPPoE sessions and encapsulating PPP frames over Ethernet. PPPoE requires a point-to-point relationship between peers instead of a point-to-multipoint relationship as in multi-access environments such as Ethernet. PPPoE provides Internet access for the hosts in an Ethernet through a remote access device and implement access control, authentication, and accounting on a per-host basis.
Integrating the low cost of Ethernet and scalability and management functions of PPP, PPPoE gained popularity in various application environments, such as residential access networks.
The following information is provided based on the assumption that you have basic knowledge of the PPPoE client.
As shown in Figure 1, the AC connects to the Internet as a PPPoE client through Layer 3 physical interface GigabitEthernet 1/0/1. Configure the PPPoE client to meet the following requirements:
· The PPPoE server and the AC can reach each other at Layer 3.
· Host can access the Internet through Telnetting to the IP address of GigabitEthernet 1/0/2 of the AC.
When you configure the PPPoE client, follow these restrictions and guidelines:
· Only outgoing packets can reset the link-idle timeout timer.
· When configuring the PPPoE client, you must select the Remove existing interface address option. Select a proper Layer 3 physical interface as needed.
· After configuring PPPoE for an interface, do not assign an IP address to the interface manually or through DHCP.
Procedures
Details not shown.
1. Click the System View tab at the bottom of the page.
2. From the navigation pane, select Network Configuration > Network Interfaces.
3. Click the PPPoE tab to enter the PPPoE configuration page, as shown in Figure 2.
4. Click the Add button
to
enter the page for adding PPPoE configuration, as shown in Figure 3.
Figure 2 PPPoE configuration page
5. On the page as shown in Figure 3, perform the following tasks:
a. Select the Layer 3 physical interface to be configured (GigabitEthernet 1/0/1 in this example).
b. Enter the username and password.
c. Select an online mode.
d. Select the Open the NAT function and the Remove existing interface address options.
e. Click Apply.
Figure 3 Adding PPPoE configuration
Configure a static route and send packets on the AC. View the traffic information to verify the configuration.
Related documentation
H3C Access Controllers Web-Based Configuration Guide
