- 07-Comware 7 Web-based configuration examples (AC+fit AP deployment)
- 01-Telnet Access Control Configuration Example
- 02-IPv6 Telnet Access Control Configuration Example
- 03-Web Access Control Configuration Example
- 04-User Role Assignment for Local Web Authentication Users Configuration Example
- 05-SSH Local Authentication Configuration Example
- 06-SSH User Remote Password Authentication Configuration Example
- 07-IPv6 SSH User Remote Password Authentication Configuration Example
- 08-Password Control Configuration Example
- 09-Licensing Configuration Example
- 10-Automatic License Installation Configuration Example
- 11-Layer 2 Static Link Aggregation Configuration Example
- 12-Layer 2 Dynamic Link Aggregation Configuration Example
- 13-PPPoE Client Configuration Example
- 14-Static IPv6 Address Configuration Example
- 15-IPv6 Static Routing Configuration Example
- 16-Static IPv4 DNS Configuration Example
- 17-Static IPv6 DNS Configuration Example
- 18-IGMP Snooping Configuration Example
- 19-MLD Snooping Configuration Example
- 20-IPv4 DNS Proxy Configuration Example
- 21-IPv6 DNS Proxy Configuration Example
- 22-Static NAT Configuration Example
- 23-Dynamic NAT Configuration Example
- 24-IPv4 ACL-Based Packet Filter Configuration Example
- 25-IPv6 ACL-Based Packet Filter Configuration Example
- 26-ARP Attack Protection Configuration Example
- 27-ARP Proxy Configuration Example
- 28-Dynamic IPv4 DNS Configuration Example
- 29-Dynamic IPv6 DNS Configuration Example
- 30-WLAN Access Configuration Example
- 31-Different Wireless Services on Different Radios Configuration Example
- 32-CAPWAP Tunnel Establishment Through DHCP Configuration Example
- 33-CAPWAP Tunnel Establishment Through DHCPv6 Configuration Example
- 34-CAPWAP Tunnel Establishment Through DNS Configuration Example
- 35-CAPWAP Tunnel Establishment Through DNSv6 Configuration Example
- 36-Auto AP Configuration Example
- 37-AP Group Configuration Example
- 38-Radio Management Configuration Example
- 39-Load Balancing Group-Based Session-Mode Load Balancing Configuration Example
- 40-Radio-Based Session-Mode Load Balancing Configuration Example
- 41-A-MPDU and A-MSDU Configuration Example
- 42-Device Classification and Countermeasure Configuration Example
- 43-Malformed Packet Detection and Flood Attack Detection Configuration Example
- 44-Signature-Based Attack Detection Configuration Example
- 45-802.1X RADIUS-Based AAA Configuration Example
- 46-VLAN Interface-Based Direct Portal Authentication Configuration Example
- 47-Service Template-Based Direct Portal Authentication Configuration Example
- 48-Wireless Spectrum Analysis Configuration Example
- 49-Auto DFS Configuration Examples
- 50-Auto TPC Configuration Examples
- 51-Whitelist-Based Client Access Control Configuration Example
- 52-Blacklist-Based Client Access Control Configuration Example
- 53-CAC Configuration Example
- 54-WLAN Probe Configuration Example
- 55-Intra-AC Roaming Configuration Example
- 56-Bonjour Gateway Configuration Example
- 57-IPv4 Multicast Optimization Configuration Examples
- 58-IPv6 Multicast Optimization Configuration Examples
- 59-Ping Configuration Example
- 60-Local Packet Capture Configuration Example
- 61-Remote Packet Capture Configuration Example
| 35-CAPWAP Tunnel Establishment Through DNSv6 Configuration Example | 276.25 KB |
H3C Access Controllers |
Comware 7 CAPWAP Tunnel Establishment Through DNSv6 |
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring CAPWAP tunnel establishment through DNSv6 at Layer 3
Specifying an IPv6 address for the AC
Overview
The following information provides an example for configuring CAPWAP tunnel establishment through DNSv6.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of CAPWAP tunnel establishment.
As shown in Figure 1, the switch acts as a DHCPv6 server to assign the AC's domain name and AP's IPv6 address to the AP. Configure the AP to obtain the AC's IPv6 address from the DNSv6 server.
Procedures
1. Create VLAN 20. (Details not shown.)
2. Click the System View tab at the bottom of the page.
3. From the navigation pane, select Network Configuration > Network Services > IP Services.
4. On the IPv6 tab, set the IPv6 address of VLAN-interface 20 to 2::AA and set the prefix to 64.
Figure 2 Specifying an IP address for the AC
Configuring an AP
1. Click the Network View tab at the bottom of the page.
2. From the navigation pane, select Wireless Configuration > AP Management.
a. Click the Add
button
to
create an AP and specify its name as ap1.
b. Specify the AP model and serial ID.
Figure 3 Configuring an AP
Configuring a static route
1. Click the System View tab at the bottom of the page.
2. From the navigation pane, select Network Configuration > Network Routing.
3. On the Static Routing tab, create an IPv6 static route with destination IPv4 address 1:: /64 and next hop address 2::AB.
Figure 4 Configuring a static route
Configuring the switch
1. Set the IP address of VLAN-interface 1 to 1::1/64.
2. Create VLAN 20 and set the IP address of VLAN-interface 20 to 2::AB/64.
Configuring the DHCP server
1. Create DHCP address pool 1 and specify subnet 1::0/64 in the pool.
2. Specify the domain name suffix of the AC as aaa for APs to discover the AC through DNSv6.
3. Set the IP address of the DNSv6 server to 1::2D/64.
Configuring the DNSv6 server
# Create a mapping between AC domain name h3c.aaa and AC IP address 2::AA/64. (Details not shown.)
3. On the AP tab, verify that the AP has come online.
Figure 5 Verifying AP configuration
5. On the CAPWAP Tunnel tab, verify that the AP uses DNS to discovery the AC.
Figure 6 Verifying the AC discovery method
Related documentation
H3C Access Controllers Web-Based Configuration Guide
