- 07-Comware 7 Web-based configuration examples (AC+fit AP deployment)
- 01-Telnet Access Control Configuration Example
- 02-IPv6 Telnet Access Control Configuration Example
- 03-Web Access Control Configuration Example
- 04-User Role Assignment for Local Web Authentication Users Configuration Example
- 05-SSH Local Authentication Configuration Example
- 06-SSH User Remote Password Authentication Configuration Example
- 07-IPv6 SSH User Remote Password Authentication Configuration Example
- 08-Password Control Configuration Example
- 09-Licensing Configuration Example
- 10-Automatic License Installation Configuration Example
- 11-Layer 2 Static Link Aggregation Configuration Example
- 12-Layer 2 Dynamic Link Aggregation Configuration Example
- 13-PPPoE Client Configuration Example
- 14-Static IPv6 Address Configuration Example
- 15-IPv6 Static Routing Configuration Example
- 16-Static IPv4 DNS Configuration Example
- 17-Static IPv6 DNS Configuration Example
- 18-IGMP Snooping Configuration Example
- 19-MLD Snooping Configuration Example
- 20-IPv4 DNS Proxy Configuration Example
- 21-IPv6 DNS Proxy Configuration Example
- 22-Static NAT Configuration Example
- 23-Dynamic NAT Configuration Example
- 24-IPv4 ACL-Based Packet Filter Configuration Example
- 25-IPv6 ACL-Based Packet Filter Configuration Example
- 26-ARP Attack Protection Configuration Example
- 27-ARP Proxy Configuration Example
- 28-Dynamic IPv4 DNS Configuration Example
- 29-Dynamic IPv6 DNS Configuration Example
- 30-WLAN Access Configuration Example
- 31-Different Wireless Services on Different Radios Configuration Example
- 32-CAPWAP Tunnel Establishment Through DHCP Configuration Example
- 33-CAPWAP Tunnel Establishment Through DHCPv6 Configuration Example
- 34-CAPWAP Tunnel Establishment Through DNS Configuration Example
- 35-CAPWAP Tunnel Establishment Through DNSv6 Configuration Example
- 36-Auto AP Configuration Example
- 37-AP Group Configuration Example
- 38-Radio Management Configuration Example
- 39-Load Balancing Group-Based Session-Mode Load Balancing Configuration Example
- 40-Radio-Based Session-Mode Load Balancing Configuration Example
- 41-A-MPDU and A-MSDU Configuration Example
- 42-Device Classification and Countermeasure Configuration Example
- 43-Malformed Packet Detection and Flood Attack Detection Configuration Example
- 44-Signature-Based Attack Detection Configuration Example
- 45-802.1X RADIUS-Based AAA Configuration Example
- 46-VLAN Interface-Based Direct Portal Authentication Configuration Example
- 47-Service Template-Based Direct Portal Authentication Configuration Example
- 48-Wireless Spectrum Analysis Configuration Example
- 49-Auto DFS Configuration Examples
- 50-Auto TPC Configuration Examples
- 51-Whitelist-Based Client Access Control Configuration Example
- 52-Blacklist-Based Client Access Control Configuration Example
- 53-CAC Configuration Example
- 54-WLAN Probe Configuration Example
- 55-Intra-AC Roaming Configuration Example
- 56-Bonjour Gateway Configuration Example
- 57-IPv4 Multicast Optimization Configuration Examples
- 58-IPv6 Multicast Optimization Configuration Examples
- 59-Ping Configuration Example
- 60-Local Packet Capture Configuration Example
- 61-Remote Packet Capture Configuration Example
| 21-IPv6 DNS Proxy Configuration Example | 104.83 KB |
H3C Access Controllers |
Comware 7 IPv6 DNS Proxy |
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for configuring IPv6 DNS proxy to allow users to access a host through the DNS proxy. When the DNS server address is changed, you can change the configuration only on the DNS proxy instead of on each DNS client.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of DNS proxy.
Example: Configuring IPv6 DNS proxy
As shown in Figure 1, the AC acts as the DNS proxy to relay DNS packets between wireless client and the DNS server. The wireless client accesses the host with domain name host.com through the DNS proxy.
Configure static routes or a dynamic routing protocol on all devices to make sure the network connections are available.
Procedures
Configuring the DNS server
On the DNS server, configure the mapping between the host's domain name host.com and IPv6 address 3000::1/64. (Details not shown.)
Configuring the AC
1. Configure basic wireless features on the AC. (Details not shown.)
2. Specify the DNS server IPv6 address on the AC:
a. Click the System View tab at the bottom of the page.
b. From the navigation pane, select Network Configuration > Network Services > DHCP/DNS.
c. Click the IPv6 DNS tab.
d. Specify 4000::1 as the DNS server IPv6 address.
Figure 2 Specifying the DNS server IPv6 address
e. Click the Add icon
3. Configure the AC as the DNS proxy:
a. On the IPv6 DNS tab, click the Advanced settings button
b. Enable DNS proxy.
Figure 3 Enabling DNS proxy
Configuring the DNS client
On the DNS client, specify 2000::2 as the DNS server IPv6 address. (Details not shown.)
# Execute the ping host.com command on the client and verify that the client can resolve domain name host.com into IP address 3000::1.
C:\Users\aa>ping ipv6 host.com
Ping6(56 data bytes) 2000::1 --> 3000::1
56 bytes from 3000::1: icmp_seq=0 ttl=128 time=0.671 ms
56 bytes from 3000::1: icmp_seq=1 ttl=128 time=0.571 ms
56 bytes from 3000::1: icmp_seq=2 ttl=128 time=0.373 ms
56 bytes from 3000::1: icmp_seq=3 ttl=128 time=0.538 ms
56 bytes from 3000::1: icmp_seq=4 ttl=128 time=0.750 ms
--- 3000::1 ping6 statistics ---
round-trip min/avg/max = 0.373/0.581/0.750 ms
Related documentation
H3C Access Controllers Web-Based Configuration Guide
