- 07-Comware 7 Web-based configuration examples (AC+fit AP deployment)
- 01-Telnet Access Control Configuration Example
- 02-IPv6 Telnet Access Control Configuration Example
- 03-Web Access Control Configuration Example
- 04-User Role Assignment for Local Web Authentication Users Configuration Example
- 05-SSH Local Authentication Configuration Example
- 06-SSH User Remote Password Authentication Configuration Example
- 07-IPv6 SSH User Remote Password Authentication Configuration Example
- 08-Password Control Configuration Example
- 09-Licensing Configuration Example
- 10-Automatic License Installation Configuration Example
- 11-Layer 2 Static Link Aggregation Configuration Example
- 12-Layer 2 Dynamic Link Aggregation Configuration Example
- 13-PPPoE Client Configuration Example
- 14-Static IPv6 Address Configuration Example
- 15-IPv6 Static Routing Configuration Example
- 16-Static IPv4 DNS Configuration Example
- 17-Static IPv6 DNS Configuration Example
- 18-IGMP Snooping Configuration Example
- 19-MLD Snooping Configuration Example
- 20-IPv4 DNS Proxy Configuration Example
- 21-IPv6 DNS Proxy Configuration Example
- 22-Static NAT Configuration Example
- 23-Dynamic NAT Configuration Example
- 24-IPv4 ACL-Based Packet Filter Configuration Example
- 25-IPv6 ACL-Based Packet Filter Configuration Example
- 26-ARP Attack Protection Configuration Example
- 27-ARP Proxy Configuration Example
- 28-Dynamic IPv4 DNS Configuration Example
- 29-Dynamic IPv6 DNS Configuration Example
- 30-WLAN Access Configuration Example
- 31-Different Wireless Services on Different Radios Configuration Example
- 32-CAPWAP Tunnel Establishment Through DHCP Configuration Example
- 33-CAPWAP Tunnel Establishment Through DHCPv6 Configuration Example
- 34-CAPWAP Tunnel Establishment Through DNS Configuration Example
- 35-CAPWAP Tunnel Establishment Through DNSv6 Configuration Example
- 36-Auto AP Configuration Example
- 37-AP Group Configuration Example
- 38-Radio Management Configuration Example
- 39-Load Balancing Group-Based Session-Mode Load Balancing Configuration Example
- 40-Radio-Based Session-Mode Load Balancing Configuration Example
- 41-A-MPDU and A-MSDU Configuration Example
- 42-Device Classification and Countermeasure Configuration Example
- 43-Malformed Packet Detection and Flood Attack Detection Configuration Example
- 44-Signature-Based Attack Detection Configuration Example
- 45-802.1X RADIUS-Based AAA Configuration Example
- 46-VLAN Interface-Based Direct Portal Authentication Configuration Example
- 47-Service Template-Based Direct Portal Authentication Configuration Example
- 48-Wireless Spectrum Analysis Configuration Example
- 49-Auto DFS Configuration Examples
- 50-Auto TPC Configuration Examples
- 51-Whitelist-Based Client Access Control Configuration Example
- 52-Blacklist-Based Client Access Control Configuration Example
- 53-CAC Configuration Example
- 54-WLAN Probe Configuration Example
- 55-Intra-AC Roaming Configuration Example
- 56-Bonjour Gateway Configuration Example
- 57-IPv4 Multicast Optimization Configuration Examples
- 58-IPv6 Multicast Optimization Configuration Examples
- 59-Ping Configuration Example
- 60-Local Packet Capture Configuration Example
- 61-Remote Packet Capture Configuration Example
| 26-ARP Attack Protection Configuration Example | 241.76 KB |
H3C Access Controllers |
Comware 7 ARP Attack Protection |
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for configuring ARP attack protection.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of ARP attack protection.
Example: Configuring ARP attack protection
As shown in Figure 1, configure ARP attack protection for VLAN 10 on the AC so the AC can perform ARP packet validity check and user validity check on Client 1 and Client 2.
Make sure the AC, the switch, and the clients can reach other. (Details not shown.)
Procedures
Configuring the DHCP server
Details not shown.
Configuring the AC
Configuring IP addresses
# Add all interfaces on the AC to VLAN 10. (Details not shown.)
Configuring DHCP snooping
1. Click the System View tab at the bottom of the page.
2. From the navigation pane, select Network Configuration > Network Services > DHCP/DNS.
3. Click the DHCP Snooping tab.
4. Click the Enable DHCP Snooping button.
Figure 2 Enabling DHCP snooping
5. Enable the binding record feature on GigabitEthernet 1/0/1 and configure GigabitEthernet 1/0/3 as a trusted port.
Figure 3 Configuring DHCP snooping
6. Click Apply.
1. From the navigation pane, select Network Configuration > Network Services > ARP.
2. Click the Advanced settings
button
to
configure advanced ARP settings.
3. In the Attack protection area, click the
right angle bracket button
in
the ARP attack protection row.
Figure 4 Configuring advanced ARP settings
4. Enable ARP detection on VLAN 10.
Figure 5 Enabling ARP detection
5. In the Settings area, click the right chevron
button
in
the Advanced settings row to configure advanced ARP attack protection.
a. In the ARP packet validity check area, enable source MAC address check, destination MAC address check, and IP address check.
b. In the Trusted interfaces area, configure GigabitEthernet 1/0/3 as a trusted interface.
Figure 6 Configuring advanced ARP attack protection
2. From the navigation pane, select Network Configuration > Network Services > ARP.
3. Verify that the AC has the ARP entry for Client 1 but it does not have the ARP entry for Client 2.
Related documentation
H3C Access Controllers Web-Based Configuration Guide
