- 07-Wireless authentication
- 01-Local Portal Authentication Configuration Examples
- 02-HTTPS-Based Local Portal Authentication Configuration Examples
- 03-Remote Portal Authentication Configuration Examples
- 04-Local Portal Authentication through LDAP Server Configuration Examples
- 05-Local Portal Auth and SSID-based Auth Page Pushing Configuration Examples
- 06-Local Portal MAC-Trigger Authentication Configuration Examples
- 07-Portal MAC-Trigger Authentication Configuration Examples
- 08-Local Forwarding Mode and Local Portal MAC-Trigger Auth Configuration Examples
- 09-Local Portal Authentication (IPv6) Configuration Examples
- 10-Local Portal Authentication through LDAP Server (IPv6) Configuration Examples
- 11-Remote Portal Authentication (IPv6) Configuration Examples
- 12-Portal MAC-Trigger Authentication (IPv6) Configuration Example
- 13-Remote Portal Authentication with User Profile Authorization Configuration Examples
- 14-WiFiDog Portal Authentication Configuration Examples
- 15-Portal Fail-Permit Configuration Examples
- 16-Local MAC Authentication Configuration Examples
- 17-Remote MAC Authentication Configuration Examples
- 18-Transparent Auth Through Remote MAC and Portal Auth Configuration Examples
- 19-Remote AP, Remote Portal, and MAC-Trigger Authentication Configuration Examples
- 20-MAC Authentication with Guest VLAN Assignment Configuration Examples
- 21-MAC Authentication with Guest VLAN Assignment (IPv6) Configuration Examples
- 22-Local MAC-And-802.1X Authentication Configuration Examples
- 23-Local 802.1X Authentication Configuration Examples
- 24-Local RADIUS-Based 802.1X Authentication in EAP Relay Mode Configuration Examples
- 25-Remote 802.1X Authentication Configuration Examples
- 26-Remote 802.1X Authentication (IPv6) Configuration Examples
- 27-Remote 802.1X Authentication in WPA3-Enterprise Mode Configuration Examples
- 28-802.1X Auth with ACL Assignment Through IMC Server Configuration Examples
- 29-802.1X Auth with User Profile Assignment Through IMC Server Configuration Examples
- 30-EAD Authentication Configuration Examples
- 31-EAD Authentication (IPv6) Configuration Examples
| 03-Remote Portal Authentication Configuration Examples | 367.36 KB |
H3C Access Controllers |
Remote Portal Authentication |
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example of configuring remote portal authentication.
The following information applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of AAA, portal, and WLAN.
Example: Configuring remote portal authentication
As shown in Figure 1, the AP and the client obtain IP addresses from the DHCP server.
To implement remote portal authentication, perform the following tasks:
· Configure direct portal authentication.
· Configure a portal authentication server and a portal Web server on IMC.
· Configure a RADIUS server as the authentication server and accounting server.
Analysis
To allow an authenticated user to access network resources on any Layer 2 ports in its access VLAN without re-authentication, enable portal roaming.
To avoid possible authentication failure caused by frequent logins and logouts of portal clients in a short time, disable the Rule ARP entry feature for portal clients.
For the RADIUS server to dynamically change user authorization information or forcibly disconnect users, enable the RADIUS session-control feature.
Use the serial ID labeled on the AP's rear panel to specify an AP.
Make sure the types of the portal authentication server and portal Web server specified on the AC are the same as those actually used. (This example uses CMCC servers.)
By default, the portal Web server URL redirected to users does not carry parameters. You can configure the parameters to be carried in the redirection URL as needed.
Procedures
Configuring IMC
In this example, the IMC server runs IMC PLAT 7.1 (E0303p13), IMC EIA 7.1 (F0302p08), and IMC EIP 7.1 (F0302p08).
Configuring the RADIUS server
1. Add an access device.
a. Log in to IMC and click the User tab.
b. From the navigation tree, select User Access Policy > Access Device Management > Access Device.
c. Click Add to open the page as shown in Figure 2.
d. In the Device List area, click Add Manually to open the Add Access Device Manually page. Enter 2.2.2.1 in the Start IP field and then click OK.
e. In the Access Configuration area, set the shared key to radius, which must be the same as that configured on the AC.
f. Use the default settings for other parameters.
g. Click OK.
Figure 2 Adding an access device
2. Add an access policy.
a. From the navigation tree, select User Access Policy > Access Policy.
b. Click Add to open the page as shown in Figure 3.
c. Enter the access policy name.
d. Select a service group. This example uses the default setting (Ungrouped).
e. Use the default settings for other parameters.
f. Click OK.
Figure 3 Adding an access policy
3. Add an access service.
a. From the navigation tree, select User Access Policy > Access Service.
b. Click Add to open the page as shown in Figure 4.
c. Enter the service name.
d. Use the default settings for other parameters.
e. Click OK.
Figure 4 Adding an access service
4. Add an access user.
a. From the navigation tree, select Access User > All Access Users.
b. Click Add to open the page as shown in Figure 5.
c. Select an existing access user or click Add User to add a new access user.
d. Set the password.
e. In the Access Service area, select the configured access service.
g. Click OK.
Figure 5 Adding an access user
Configuring the portal server
1. Configure the portal authentication service:
a. From the navigation tree, select User Access Policy > Portal Service > Server to open the portal server configuration page, as shown in Figure 6.
b. Configure the portal server parameters as needed.
This example uses the default settings.
c. Click OK.
Figure 6 Configuring the portal server
2. Configure the IP address group:
a. From the navigation tree, select User Access Policy > Portal Service > IP Group.
b. Click Add to open the page as shown in Figure 7.
c. Enter the IP group name.
d. Enter the start IP address and end IP address of the IP group.
Make sure the client IP address is in the IP group.
e. Select a service group.
This example uses the default group Ungrouped.
f. Select Normal from the Action list.
g. Click OK.
Figure 7 Adding an IP address group
3. Add a portal device:
a. From the navigation tree, select User Access Policy > Portal Service > Device.
b. Click Add to open the page as shown in Figure 8.
c. Enter the device name.
d. Select CMCC 1.0 from the Version list.
e. Enter the IP address of the AC's interface connected to the client.
f. Set whether to support the portal server heartbeat and user heartbeat functions.
In this example, select No for both Support Server Heartbeat and Support User Heartbeat.
g. Enter the key, which must be the same as that configured on the AC.
h. Select Directly Connected for Access Method.
i. Use the default settings for other parameters.
j. Click OK.
Figure 8 Adding a portal device
4. Associate the portal device with the IP address group:
a. Click the Port Group icon in the Operation field of device NAS, as shown in Figure 9.
b. Click Add to open the page as shown in Figure 10.
c. Enter the port group name.
d. Select the configured IP address group.
The IP address used by the user to access the network must be within this IP address group.
f. Click OK.
Configuring the AC
1. Configure interfaces on the AC:
# Create VLAN 100 and VLAN-interface 100. Assign an IP address to the VLAN interface. The AC will use this IP address to establish CAPWAP data and control tunnels with the AP.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 2.2.1.1 24
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200. Assign an IP address to the VLAN interface. The AC will use VLAN 200 for client access.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 2.2.2.1 24
[AC-Vlan-interface200] quit
# Configure the interface that is connected to the switch as a trunk port, and assign the port to VLAN 100 and VLAN 200.
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
2. Configure a static route to reach the IMC server:
[AC] ip route-static 192.168.0.0 255.255.0.0 2.2.2.100
3. Configure a wireless service:
# Create a service template named st1 and enter its view.
[AC] wlan service-template st1
# Set the SSID of service template st1 to service.
[AC-wlan-st-st1] ssid service
# Assign clients coming online through service template st1 to VLAN 200.
[AC-wlan-st-service] vlan 200
# Specify the AKM mode as PSK, and configure the preshared key as 12345678 in plain text.
[AC-wlan-st-st1] akm mode psk
[AC-wlan-st-st1] preshared-key pass-phrase simple 12345678
# Specify the cipher suite as CCMP and the security IE as RSN.
[AC-wlan-st-st1] cipher-suite ccmp
[AC-wlan-st-st1] security-ie rsn
# Configure the AC to forward client data traffic. (Skip this step if the client data traffic forwarder is the AC by default.)
[AC-wlan-st-st1] client forwarding-location ac
# Specify ISP domain dm1 as the authentication domain for portal users on service template st1.
[AC-wlan-st-st1] portal domain dm1
# Enable service template st1.
[AC–wlan-st-st1] service-template enable
[AC-wlan-st-st1] quit
4. Configure the AP:
NOTE: In large-scale networks, configure AP groups instead of single APs as a best practice. |
# Create an AP named office with model WA6320 and set its serial ID to 219801A28N819CE0002T.
[AC] wlan ap office model WA6320
[AC-wlan-ap-office] serial-id 219801A28N819CE0002T
[AC-wlan-ap-office] quit
# Create AP group group1 and add AP office to AP group group1.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap office
# Bind service template st1 to radio 2 in AP group group1.
[AC-wlan-ap-group-group1] ap-model WA6320
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 2
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] service-template st1
# Enable radio 2.
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] quit
[AC-wlan-ap-group-group1-ap-model-WA6320] quit
[AC-wlan-ap-group-group1] quit
5. Configure a RADIUS scheme:
# Create a RADIUS scheme named rs1 and enter its view.
[AC] radius scheme rs1
# Specify the primary authentication server and primary accounting server, and configure the keys for communication with the servers.
[AC-radius-rs1] primary authentication 192.168.0.111
[AC-radius-rs1] primary accounting 192.168.0.111
[AC-radius-rs1] key authentication simple radius
[AC-radius-rs1] key accounting simple radius
# Configure the AC to remove the domain name from the usernames sent to the RADIUS servers.
[AC-radius-rs1] user-name-format without-domain
# Specify 2.2.2.1 as the source IP address for outgoing RADIUS packets sent to the RADIUS servers.
[AC-radius-rs1] nas-ip 2.2.2.1
[AC-radius-rs1] quit
# Enable the RADIUS session-control feature.
[Router] radius session-control enable
6. Configure an authentication domain:
# Create an ISP domain named dm1 and enter its view.
[AC] domain dm1
# Configure the authentication, authorization, and authorization methods as RADIUS for portal users in the ISP domain.
[AC-isp-dm1] authentication portal radius-scheme rs1
[AC-isp-dm1] authorization portal radius-scheme rs1
[AC-isp-dm1] accounting portal radius-scheme rs1
# Configure the idle cut feature for users in the ISP domain. Log out a user if the user's traffic is less than 1024 bytes in 15 minutes.
[AC-isp-dm1] authorization-attribute idle-cut 15 1024
[AC-isp-dm1] quit
7. Configure portal authentication:
# Create a portal authentication server named newpt, specify IP address 192.168.0.111 as the IP address of the authentication server, and specify 50100 as the portal service port number.
[AC] portal server newpt
[AC-portal-server-newpt] ip 192.168.0.111 key simple radius
[AC-portal-server-newpt] port 50100
# Specify CMCC as the type of portal authentication server newpt.
[AC-portal-server-newpt] server-type cmcc
[AC-portal-server-newpt] quit
# Create a portal Web server named newpt and specify http://192.168.0.111:8080/portal as the URL of the server.
[AC] portal web-server newpt
[AC-portal-websvr-newpt] url http://192.168.0.111:8080/portal
# Add parameters ssid, wlanuserip, and wlanacname to the URL of portal Web server newpt. Specify the AP's SSID, the IP address of the client, and the AC's name as the values for the parameters, respectively. (The parameters are required to be carried in the URL of a portal Web server of the CMCC type.)
[AC-portal-websvr-newpt] url-parameter ssid ssid
[AC-portal-websvr-newpt] url-parameter wlanuserip source-address
[AC-portal-websvr-newpt] url-parameter wlanacname value AC
# Specify CMCC as the type of portal Web server newpt.
[AC-portal-websvr-newpt] server-type cmcc
[AC-portal-websvr-newpt] quit
# Configure a destination-based portal-free rule numbered 0 to permit traffic destined for IP address 192.168.0.111 (the portal Web server).
[AC] portal free-rule 0 destination ip 192.168.0.111 24
# Configure two destination-based portal-free rules to permit the traffic destined for the DNS server.
[AC] portal free-rule 1 destination ip any udp 53
[AC] portal free-rule 2 destination ip any tcp 53
# Enable portal roaming.
[AC] portal roaming enable
# Enable validity check on wireless portal clients.
[AC] portal host-check enable
# Disable the Rule ARP entry feature for portal clients.
[AC] undo portal refresh arp enable
# Enable direct portal authentication on service template st1.
[AC-wlan-st-st1] portal enable method direct
# Specify ISP domain dm1 as the portal authentication domain.
# Specify portal Web server newpt on service template st1 for portal authentication.
[AC-wlan-st-st1] portal apply web-server newpt
# Configure the BAS-IP attribute as 2.2.2.2 for portal packets sent to portal authentication server newpt.
[AC-wlan-st-st1] portal bas-ip 2.2.2.1
Configuring the switch
# Create VLAN 100. The switch will use this VLAN to forward traffic on the CAPWAP tunnel between the AC and the AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
# Create VLAN 200. The switch will use this VLAN to forward client traffic.
[Switch] vlan 200
[Switch-vlan200] quit
# Create VLAN 2.
[Switch] vlan 2
[Switch-vlan2] quit
# Configure GigabitEthernet 1/0/1 (the port connected to the AC) as a trunk port and assign the trunk port to VLAN 100 and VLAN 200.
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Configure GigabitEthernet 1/0/2 (the port connected to the AP) as an access port and assign the access port to VLAN 100.
# Enable PoE on the access port.
# Configure GigabitEthernet 1/0/3 (the port connected to the IMC) as an access port. Assign the access port to VLAN 2.
[Switch] interface gigabitethernet 1/0/3
[Switch-GigabitEthernet1/0/3] port link-type access
[Switch-GigabitEthernet1/0/3] port access vlan 2
[Switch-GigabitEthernet1/0/3] quit
# Create VLAN-interface 200 and assign an IP address to the VLAN interface.
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 2.2.2.100 255.255.255.0
[Switch-Vlan-interface200] quit
# Create VLAN-interface 2 and assign an IP address to the VLAN interface.
[Switch-Vlan-interface2] ip address 192.168.0.100 255.255.255.0
[Switch-Vlan-interface2] quit
# Use the configured username and password to perform portal authentication through a Web browser on the client. Before passing portal authentication, the user can access only the authentication page http://192.168.0.111:8080/portal. All Web requests from the user will be redirected to the authentication page. After passing portal authentication, the user can access other network resources.
# Display information about all portal users.
[AC] display portal user all
Total portal users: 1
Username: Client
AP name: office
Radio ID: 2
SSID: service
Portal server: newpt
State: Online
VPN instance: N/A
MAC IP VLAN Interface
0021-6330-0933 2.2.2.2 200 WLAN-BSS1/0/2
Authorization information:
DHCP IP pool: N/A
User profile: N/A
Session group profile: N/A
ACL number: N/A
Inbound CAR: N/A
Outbound CAR: N/A
Configuration files
· AC:
vlan 100
vlan 200
ssid service
vlan 200
akm mode psk
preshared-key pass-phrase cipher $c$3$9tIUHSkAUVqCH9/EPrL26ldkcEQnngexUEFj
cipher-suite ccmp
security-ie rsn
portal domain dm1
interface Vlan-interface100
ip address 2.2.1.1 255.255.255.0
interface Vlan-interface200
ip address 2.2.2.1 255.255.255.0
port trunk permit vlan 1 100 200
ip route-static 192.168.0.0 16 2.2.2.100
radius scheme rs1
key authentication cipher $c$3$Sqgqz7lDs4XPnethmAgyAKVlke7qwEkYbQ==
key accounting cipher $c$3$4J/JBRGwqB4F213furJMkB6JWYXBFjWE6g==
nas-ip 2.2.2.1
domain dm1
portal free-rule 0 destination ip 192.168.0.0 255.255.255.0
server-type cmcc
portal server newpt
ip 192.168.0.111 key cipher $c$3$Q82T/9AHq5HT7uFX7nho8K0Y6jziycoJTw==
server-type cmcc
ap office
ap-model WA6320
radio 1
radio 2
radio enable
· Switch:
vlan 100
vlan 200
poe enable
port access vlan 2
Related documentation
· User Access and Authentication Command Reference in H3C Access Controllers Command References
· User Access and Authentication Configuration Guide in H3C Access Controllers Configuration Guides
· WLAN Access Command Reference in H3C Access Controllers Command References
· WLAN Access Configuration Guide in H3C Access Controllers Configuration Guides
