- 04-CLI configuration examples (AP standalone)
- 01-WPA2-PSK Encryption Configuration Examples
- 02-Client Rate Limiting Configuration Examples
- 03-NAT Configuration Examples
- 04-PPPoE Configuration Examples
- 05-Mesh WDS Configuration Examples
- 06-Local MAC Authentication (IPv6) Configuration Examples
- 07-IPv6 Configuration Examples
- 08-Layer 2 IPv6 Multicast Configuration Examples
- 09-Interoperation of Fat APs and Switch for WLAN Access and Roaming Configuration Examples
- 10-Remote 802.1X Authentication Configuration Examples
- 11-Remote MAC Authentication Configuration Examples
- 12-Anchor AC Mode Local Forwarding Configuration Examples
- 13-Anchor AC Mode Dual-Link Backup Configuration Examples
- 14-Anchor AC Mode Internal-to-External Access Through NAT Configuration Examples
- 15-Anchor AC Mode Remote Portal Auth in Local Forwarding Configuration Examples
- 16-Anchor AC Mode Remote Portal Auth in Centralized Forwarding Configuration Examples
- 17-Anchor AC Mode Remote 802.1X Auth in Local Forwarding Configuration Examples
- 18-Anchor AC Mode Remote 802.1X Auth in Centralized Forwarding Configuration Examples
- 19-Anchor AC Mode Remote AP Configuration Examples
| 14-Anchor AC Mode Internal-to-External Access Through NAT Configuration Examples | 79.08 KB |
H3C Anchor Access Points in AC Mode |
Internal-to-External Access Through NAT |
Copyright © 2022 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides examples for configuring NAT to allow internal users to access the external network.
This document applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
This document assumes that you have basic knowledge of NAT and WLAN.
Example: Configuring NAT to allow internal users to access the external network
The AC in this example is an anchor AP that operates as an AC.
As shown in Figure 1, the AP and the clients obtain IP addresses through DHCP. Configure dynamic NAT on the AC's interface that connects to the external network to allow only the clients at the 192.168.1.0/24 to access the Internet.
Device |
IP address |
Device |
IP address |
AC |
Vlan-int100 |
192.168.0.1/24 |
Switch |
Vlan-int100 |
192.168.0.2/24 |
Vlan-int200 |
192.168.1.1/24 |
Vlan-int200 |
192.168.1.2/24 |
Vlan-int300 |
202.38.1.1/24 |
When you configure NAT to allow internal users to access the external network, follow these restrictions and guidelines:
· If you configure NAT on VLAN interfaces, use the address group as a best practice for dynamic NAT.
· Do not add the public IP address of the VLAN interface to the NAT address group.
· If the AC uses only one public IP address of the VLAN interface for dynamic NAT, use the port-range command to specify a proper port range. As a best practice, use the port range from 10000 to 65535 to ensure that the service ports on the AC are not used by NAT.
· Make sure the devices can reach each other. In this example, the routing configuration is not shown.
Procedures
Configuring the AC
Configuring the interfaces on the AC
# Create VLAN 100 and configure VLAN-interface 100. The AC will use this IP address to establish a CAPWAP tunnel with the AP.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.168.0.1 24
[AC-Vlan-interface100] quit
# Create VLAN 200 and configure VLAN-interface 200. The clients will access the WLAN network through this VLAN.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 192.168.1.1 24
[AC-Vlan-interface200] quit
# Create VLAN 300 and configure VLAN-interface 300. The AC will use this VLAN for dynamic address translation.
[AC] vlan 300
[AC-vlan300] quit
[AC] interface vlan-interface 300
[AC-Vlan-interface300] ip address 202.38.1.1 24
[AC-Vlan-interface300] quit
# Configure XGE 1/0/1 on the AC that connects the AC to the switch, as a trunk port, and assign it to VLAN 100 and VLAN 200.
[AC] interface Ten-GigabitEthernet 1/0/1
[AC-Ten-GigabitEthernet1/0/1] port link-type trunk
[AC-Ten-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[AC-Ten-GigabitEthernet1/0/1] quit
Configuring WLAN services
# Create service template 1 and enter its view.
[AC] wlan service-template 1
# Set the SSID to service.
[AC-wlan-st-1] ssid service
# Assign clients coming online through service template service to VLAN 200.
[AC-wlan-st-1] vlan 200
# Configure the AC to forward client data traffic.
[AC-wlan-st-1] client forwarding-location ac
# Set the authentication and key management mode to PSK, and configure simple string 12345678 as the PSK.
[AC-wlan-st-1] akm mode psk
[AC-wlan-st-1] preshared-key pass-phrase simple 12345678
# Set the CCMP cipher suite and enable the RSN IE in the beacon and probe responses.
[AC-wlan-st-1] cipher-suite ccmp
[AC-wlan-st-1] security-ie rsn
# Enable the service template.
[AC-wlan-st-1] quit
# Create AP 6630x with model WA6630X-JP, and set the serial ID to 210235A1GQC152001076.
[AC] wlan ap 6630x model WA6630X-JP
[AC-wlan-ap-6630x] serial-id 210235A1GQC152001076
# Enter radio view.
[AC-wlan-ap-6630x] radio 2
# Bind service template 1 to radio 2, and enable the radio.
[AC-wlan-ap-6630x-radio-2] service-template 1
[AC-wlan-ap-6630x-radio-2] radio enable
[AC-wlan-ap-6630x-radio-2] quit
[AC-wlan-ap-6630x] quit
Configuring dynamic NAT
# Configure address group 0. Add two public IP addresses 202.38.1.2 and 202.38.1.3 to the address group.
[AC] nat address-group 0
[AC-address-group-0] address 202.38.1.2 202.38.1.3
[AC-address-group-0] quit
# Configure ACL 2000 to identify packets sourced from 192.168.1.0/24.
[AC] acl basic 2000
[AC-acl-ipv4-basic-2000] rule permit source 192.168.1.0 0.0.0.255
[AC-acl-ipv4-basic-2000] quit
# Configure a default route to change the VLAN to which the packets belong from VLAN 200 to VLAN 300.
[AC] ip route-static 0.0.0.0 0.0.0.0 Vlan-interface 300
# Configure outbound dynamic IP and port translation on VLAN-interface 300 to translate the source IP address of outgoing packets permitted by ACL 2000 into addresses in address group 0.
[AC-Vlan-interface300] nat outbound 2000 address-group 0
Configuring the switch
Configuring the interfaces on the switch
# Create VLAN 100, and assign an IP address to VLAN-interface 100. The switch will use this VLAN to forward traffic on the CAPWAP tunnel between the AC and AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
[Switch-Vlan-interface100] ip address 192.168.0.2 24
# Create VLAN 200, and assign an IP address to VLAN-interface 200. This VLAN is used to forward packets from the clients.
[Switch] vlan 200
[Switch-vlan200] quit
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 192.168.1.2 24
[Switch-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1, the interface that connects to the AC, as a trunk port, and assign it to VLAN 100 and VLAN 200.
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Configure GigabitEthernet 1/0/2, the interface that connects to the AP, as an access port, and assign it to VLAN 100.
# Enable PoE.
Configuring DHCP services
# Enable DHCP.
[Switch] dhcp enable
# Configure DHCP address pool vlan100 to dynamically assign IP addresses on subnet 192.168.0.0/16 to the AP. Specify 192.168.0.1 as the excluded IP address and gateway address.
[Switch] dhcp server ip-pool vlan100
[Switch-dhcp-pool-vlan100] network 192.168.0.0 mask 255.255.0.0
[Switch-dhcp-pool-vlan100] forbidden-ip 192.168.0.1
[Switch-dhcp-pool-vlan100] gateway-list 192.168.0.1
[Switch-dhcp-pool-vlan100] quit
# Configure DHCP address pool vlan200 to dynamically assign IP addresses on subnet 192.168.1.0/24 to the clients. Specify 192.168.1.1 as the gateway address and DNS server address. Configure the DNS server address for clients based on the network plan. In this example, the DNS server address is the same as the gateway address.
[Switch] dhcp server ip-pool vlan200
[Switch-dhcp-pool-vlan200] network 192.168.1.0 mask 255.255.255.0
[Switch-dhcp-pool-vlan200] gateway-list 192.168.1.1
[Switch-dhcp-pool-vlan200] dns-list 192.168.1.1
[Switch-dhcp-pool-vlan200] quit
# Verify that when a user on subnet 192.168.1.0/24 accesses the Internet, dynamic NAT is performed on the packets from the user. Execute the display nat session verbose command to display the NAT session information.
[AC] display nat session verbose
Slot 1:
Initiator:
Source IP/port: 192.168.1.10/1628
Destination IP/port: 202.38.1.100/21
DS-Lite tunnel peer: -
Protocol: TCP(6)
Inbound interface: Vlan-interface200
Responder:
Source IP/port: 202.38.1.100/21
Destination IP/port: 202.38.1.2/1024
Protocol: TCP(6)
Inbound interface: Vlan-interface300
State: TCP_ESTABLISHED
Application: FTP
Start time: 2015-11-28 16:54:35 TTL: 2699s
Initiator->Responder: 1 packets 84 bytes
Responder->Initiator: 1 packets 84 bytes
Total sessions found: 1 s
Configuration files
vlan 100
vlan 200
vlan 300
ssid service
vlan 200
akm mode psk
cipher-suite ccmp
security-ie rsn
interface Vlan-interface100
ip address 192.168.0.1 255.255.255.0
interface Vlan-interface200
interface Vlan-interface300
ip address 202.38.1.1 255.255.255.0
acl basic 2000
rule 0 permit source 192.168.1.0 0.0.0.255
nat address-group 0
radio 1
radio 2
radio enable
service-template 1
· Switch:
vlan 100
vlan 200
ip address 192.168.0.2 255.255.255.0
ip address 192.168.1.2 255.255.255.0
port trunk permit vlan 1 100 200
poe enable
dhcp enable
Related documentation
· Network Connectivity Command Reference in H3C Access Points Anchor AC Mode Command References
· Network Connectivity Configuration Guide in H3C Access Points Anchor AC Mode Configuration Guides
· WLAN Access Command Reference in H3C Access Points Anchor AC Mode Command References
· WLAN Access Configuration Guide in H3C Access Points Anchor AC Mode Configuration Guides
