- 04-CLI configuration examples (AP standalone)
- 01-WPA2-PSK Encryption Configuration Examples
- 02-Client Rate Limiting Configuration Examples
- 03-NAT Configuration Examples
- 04-PPPoE Configuration Examples
- 05-Mesh WDS Configuration Examples
- 06-Local MAC Authentication (IPv6) Configuration Examples
- 07-IPv6 Configuration Examples
- 08-Layer 2 IPv6 Multicast Configuration Examples
- 09-Interoperation of Fat APs and Switch for WLAN Access and Roaming Configuration Examples
- 10-Remote 802.1X Authentication Configuration Examples
- 11-Remote MAC Authentication Configuration Examples
- 12-Anchor AC Mode Local Forwarding Configuration Examples
- 13-Anchor AC Mode Dual-Link Backup Configuration Examples
- 14-Anchor AC Mode Internal-to-External Access Through NAT Configuration Examples
- 15-Anchor AC Mode Remote Portal Auth in Local Forwarding Configuration Examples
- 16-Anchor AC Mode Remote Portal Auth in Centralized Forwarding Configuration Examples
- 17-Anchor AC Mode Remote 802.1X Auth in Local Forwarding Configuration Examples
- 18-Anchor AC Mode Remote 802.1X Auth in Centralized Forwarding Configuration Examples
- 19-Anchor AC Mode Remote AP Configuration Examples
| 19-Anchor AC Mode Remote AP Configuration Examples | 152.56 KB |
H3C Anchor Access Points in AC Mode |
Copyright © 2022 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for configuring remote AP by an anchor AP that acts as an AC.
This document applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
This document assumes that you have basic knowledge of remote AP.
Example: Configuring remote AP
As shown in Figure 1, the AP connects to the AC through the switch, and the switch acts as a DHCP server to assign IP addresses to the AP and the clients. Configure remote AP on the AC so that the AP can still provide services for clients when the tunnel between the AP and the AC is disconnected.
When you configure remote AP, follow these restrictions and guidelines:
· Use the serial ID labeled on the AP's rear panel to specify an AP.
· For new clients to come online, make sure the clients are associated with and authenticated at APs. In this case, use simple text or PSK encryption as a best practice.
· Remote AP takes effect only on an AP that operates in local forwarding mode.
· For GigabitEthernet 1/0/1 on the AP to join VLAN 200, edit the AP configuration file, and upload it to the storage media of the AC.
Procedures
Configuring the AC
1. Configure interfaces on the AC:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish CAPWAP tunnels with APs.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.1.0.1 16
[AC-Vlan-interface100] quit
# Create VLAN 200. The AC will use VLAN 200 for client access.
[AC] vlan 200
[AC-vlan200] quit
# Configure GigabitEthernet 1/0/1 that connects the AC and the switch as a trunk port, and assign it to VLAN 100.
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100
2. Configure wireless services:
# Create service template named 1 and enter its view.
[AC] wlan service-template 1
# Configure the SSID of service template 1 as service.
[AC-wlan-st-1] ssid service
# Specify the AKM as PSK and specify plaintext pre-shared key 12345678.
[AC-wlan-st-1] akm mode psk
[AC-wlan-st-1] preshared-key pass-phrase simple 12345678
# Specify the cipher suite as CCMP and enable the RSN security IE.
[AC-wlan-st-1] cipher-suite ccmp
[AC-wlan-st-1] security-ie rsn
# Enable local forwarding.
[AC-wlan-st-1] client forwarding-location ap
# Configure clients to be associated with and authenticated at APs.
[AC-wlan-st-1] client-security authentication-location ap
[AC-wlan-st-1] client association-location ap
# Enable the service template.
[AC-wlan-st-1] quit
3. Configure the AP:
NOTE: In a large-scale network, configure AP groups instead of single APs as a best practice. |
# Create a manual AP named officeap, and specify the AP model and serial ID.
[AC] wlan ap officeap model WA6320
[AC-wlan-ap-officeap] serial-id 219801A28N819CE0002T
# Add the AP to AP group group1.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap officeap
# Bind service template 1 and VLAN 200 to radio 2.
[AC-wlan-ap-group-group1] ap-model WA6320
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 2
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] service-template 1 vlan 200
# Enable radio 2.
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] quit
# Deploy configuration file apcfg.txt to the AP.
[AC-wlan-ap-group-group1-ap-model-WA6320] map-configuration flash:/apcfg.txt
[AC-wlan-ap-group-group1-ap-model-WA6320] quit
# Enable remote AP.
[AC-wlan-ap-group-group1] hybrid-remote-ap enable
[AC-wlan-ap-group-group1] quit
Configuring the switch
1. Configure interfaces on the switch:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The switch will use VLAN 100 to forward the traffic on the CAPWAP tunnel between the AC and AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
[Switch-Vlan-interface100] ip address 192.1.0.2 16
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The switch will use VLAN 200 to forward client traffic.
[Switch] vlan 200
[Switch-vlan200] quit
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 192.2.0.2 16
[Switch-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the switch and the AC as a trunk port, and assign the trunk port to VLAN 100.
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100
# Configure GigabitEthernet 1/0/2 that connects the switch to the AP as a trunk port, remove the port from VLAN 1, assign the trunk port to VLANs 100 and 200, and set the PVID to VLAN 100.
[Switch-GigabitEthernet1/0/2] port link-type trunk
[Switch-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/2] port trunk permit vlan 100 200
[Switch-GigabitEthernet1/0/2] port trunk pvid vlan 100
2. Configure the DHCP service:
# Enable DHCP.
[Switch] dhcp enable
# Create DHCP address pool vlan100, specify subnet 192.1.0.0/16 for dynamic allocation, exclude 192.1.0.1 from dynamic allocation, and specify gateway IP address 192.1.0.2.
[Switch] dhcp server ip-pool vlan100
[Switch-dhcp-pool-vlan100] network 192.1.0.0 mask 255.255.0.0
[Switch-dhcp-pool-vlan100] forbidden-ip 192.1.0.1
[Switch-dhcp-pool-vlan100] gateway-list 192.1.0.2
[Switch-dhcp-pool-vlan100] quit
# Create DHCP address pool vlan200, specify subnet 192.2.0.0/16 for dynamic allocation, and exclude 192.2.0.1 from dynamic allocation. Specify gateway IP address 192.2.0.2, and specify the DNS server address. In this example, the gateway also acts as a DNS server.
[Switch] dhcp server ip-pool vlan200
[Switch-dhcp-pool-vlan200] network 192.2.0.0 mask 255.255.0.0
[Switch-dhcp-pool-vlan200] forbidden-ip 192.2.0.1
[Switch-dhcp-pool-vlan200] gateway-list 192.2.0.2
[Switch-dhcp-pool-vlan200] dns-list 192.2.0.2
[Switch-dhcp-pool-vlan200] quit
Configuring AP configuration file apcfg.txt
# Copy the following text to a text file and upload the file to the AC.
vlan 200
interface GigabitEthernet 1/0/1
port trunk permit vlan 200
# Verify that clients remain online and the AP can still forward client traffic when the tunnel between the AP and the AC is disconnected. (Details not shown.)
Configuration files
· AC (anchor AP):
vlan 100
vlan 200
ssid service
akm mode psk
preshared-key pass-phrase cipher $c$3$N//5BVbsOqdBTxi+7MJZKT6Zqh5MAmYs2ZzM
cipher-suite ccmp
security-ie rsn
interface Vlan-interface100
ip address 192.1.0.1 255.255.0.0
ap ap1
ap-model WA6320
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
· apcfg.txt:
vlan 200
· Switch:
dhcp enable
vlan 100
vlan 200
dns-list 192.2.0.2
ip address 192.1.0.2 255.255.0.0
interface Vlan-interface200
ip address 192.2.0.2 255.255.0.0
Related documentation
· AP Management Command Reference in H3C Access Points Anchor AC Mode Command References
· AP Management Configuration Guide in H3C Access Points Anchor AC Mode Configuration Guides
· Network Connectivity Command Reference in H3C Access Points Anchor AC Mode Command References
· Network Connectivity Configuration Guide in H3C Access Points Anchor AC Mode Configuration Guides
