- H3C S7500E Switch Series Installation Guide-6W108
- 01-Chapter 1 Preparing for Installation
- 02-Chapter 2 Installing the Switch
- 03-Chapter 3 Installing FRUs
- 04-Chapter 4 Connecting Your Switch to the Network
- 05-Chapter 5 Replacement Procedures
- 06-Chapter 6 Troubleshooting
- 07-Appendix A Chassis Views and Technical Specifications
- 08-Appendix B FRUs and Compatibility Matrixes
- 09-Appendix C LEDs
- 10-Appendix D Cables
- 11-Appendix E Engineering Labels for Cables
- 12-Appendix F Cable Management
| 07-Appendix A Chassis Views and Technical Specifications | 7.86 MB |
7 Appendix A Chassis views and technical specifications
Chassis views
The figures in this chapter are for illustration only.
S7502E
Figure 7-1 S7502E front and rear panels
(2) MPU section |
(3) Service module section |
(4) Fan tray section |
(5) PoE power input port |
S7503E-S
Figure 7-2 S7503E-S front and rear panels
(1) Power module section |
(2) MPU section |
S7503E-M
Figure 7-3 S7503E-M front panel
(2) MPU section |
(3) MPU/service module section |
S7503E
Figure 7-4 S7503E front panel
(1) MPU section |
(2) Service module section |
(3) Power module section |
S7506E-S
Figure 7-5 S7506E-S front panel
(1) MPU section |
S7506E
Figure 7-6 S7506E front panel
(1) MPU section |
S7506E (non-PoE)
Figure 7-7 S7506E (non-PoE) front panel
(1) MPU section |
S7506E-MF
Figure 7-8 S7506E-MF front panel
(1) MPU section |
S7506E-MF (non-PoE)
Figure 7-9 S7506E-MF (non-PoE) front panel
(1) MPU section |
S7506E-V
Figure 7-10 S7506E-V front panel
(1) MPU section |
(2) Power module section |
S7510E
Figure 7-11 S7510E front panel
(1) Service module section |
(2) MPU section |
Technical specifications
Weights and dimensions
Table 7-1 Chassis weights and dimensions
Model |
Weight (fully configured) |
Height |
Width |
Depth |
S7502E |
< 30 kg (66.14 lb) |
175 mm (6.89 in) (4 RU) |
436 mm (17.17 in) |
420 mm (16.54 in) |
S7503E-S |
436 mm (17.17 in) |
420 mm (16.54 in) |
S7503E-M |
436 mm (17.17 in) |
420 mm (16.54 in) |
S7503E |
< 60 kg (132.28 lb) |
441 mm (17.36 in) (10 RU) |
436 mm (17.17 in) |
420 mm (16.54 in) |
S7506E-S |
< 75 kg (165.34 lb) |
575 mm (22.64 in) (13 RU) |
436 mm (17.17 in) |
420 mm (16.54 in) |
S7506E (non-PoE) |
436 mm (17.17 in) |
420 mm (16.54 in) |
S7506E |
436 mm (17.17 in) |
420 mm (16.54 in) |
S7506E-MF (non-PoE) |
436 mm (17.17 in) |
420 mm (16.54 in) |
S7506E-MF |
436 mm (17.17 in) |
420 mm (16.54 in) |
S7506E-V |
< 85 kg (187.39 lb) |
930 mm (36.61 in) (21 RU) |
436 mm (17.17 in) |
420 mm (16.54 in) |
S7510E |
< 95 kg (209.44 lb) |
708 mm (27.87 in) (16 RU) |
436 mm (17.17 in) |
420 mm (16.54 in) |
NOTE: · Rack height is measured in RUs. One RU is 44.45 mm (1.75 in). · The dimensions listed in Table 7-1 are for switch chassis, excluding mounting brackets, cable management brackets, cards, and power modules. |
Table 7-2 Card weights and dimensions
Model |
Weight |
Height |
Width |
Depth |
LSQ1MPUA0 |
1.35 kg (2.98 lb) |
45 mm (1.77 in) |
199 mm (7.83 in) |
355 mm (13.98 in) |
LSQ1CGV24PSC0 |
2.80 kg (6.17 lb) |
45 mm (1.77 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1CGP24TSC0 |
2.86 kg (6.31 lb) |
45 mm (1.77 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1CTGS16SC0 |
3.34 kg (7.36 lb) |
45 mm (1.77 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1MPUB0 (Salience VI-Lite) |
3.60 kg (7.94 lb) |
45 mm (1.77 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1SRPA0 (Salience VI-Smart) |
2.61 kg (5.75 lb) |
45 mm (1.77 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1SRPB0 (Salience VI) |
3.60 kg (7.94 lb) |
45 mm (1.77 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1SRPD0 (Salience VI-Plus) |
3.56 kg (7.85 lb) |
45 mm (1.77 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1SRP1CB0 (Salience VI-Turbo) |
3.60 kg (7.94 lb) |
45 mm (1.77 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1SRP12GB0 (Salience VI-GE) |
3.59 kg (7.91 lb) |
45 mm (1.77 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1SRP2XB0 (Salience VI-10GE) |
3.60 kg (7.94 lb) |
45 mm (1.77 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM3MPUA0 |
1.41 kg (3.11 lb) |
45 mm (1.77 in) |
199 mm (7.83 in) |
355 mm (13.98 in) |
LSQM3MPUB0 |
2.95 kg (6.50 lb) |
45 mm (1.77 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2MPUC0 |
4.00 kg (8.82 lb) |
45 mm (1.77 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2MPUD0 |
4.10 kg (9.04 lb) |
45 mm (1.77 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2MPUDS0 |
4.05 kg (8.93 lb) |
45 mm (1.77 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1SRP8X2QE0 |
4.40 kg (9.70 lb) |
45 mm (1.77 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1CGP24TSSC0 |
3.00 kg (6.61 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1CGT24TSSC0 |
2.85 kg (6.28 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1CTGS24QSFD0 |
3.15 kg (6.94 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1TGS24QSFD0 |
3.00 kg (6.61 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1CQGS12SG0 |
3.20 kg (7.05 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1CGS2FE0 |
2.82 kg (6.22 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1QGS24RSG0 |
3.39 kg (7.47 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1QGS4SC0 |
3.12 kg (6.88 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1QGC4SC0 |
3.46 kg (7.62 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1GP24TXSD0 |
3.08 kg (6.79 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1P24XGSC0 |
2.95 kg (6.50 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1T24XGSC0 |
2.92 kg (6.43 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1TGX8SD0 |
3.23 kg (7.12 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1TGX4SD0 |
2.93 kg (6.46 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1TGX4EB0 |
2.93 kg (6.46 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1TGX2SC0 |
2.95 kg (6.50 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1TGX2SD0 |
2.93 kg (6.46 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1TGX2EB0 |
2.93 kg (6.46 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1TGX1EA0 |
2.80 kg (6.17 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2GT24PTSSC0 |
3.21 kg (7.08 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2GT24TSSC0 |
2.95 kg (6.50 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM3GP44TSSC0 |
3.00 kg (6.61lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2GP44TSSC0 |
3.00 kg (6.61lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1GP40TS8FD0 |
3.20 kg (7.05 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2GP40TS8FD0 |
3.10 kg (6.83 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1TGS48RSG0 |
3.50 kg (7.72 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2TGS48SG0 |
3.30 kg (7.28 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1TGS48RFE0 |
3.60 kg (7.94 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1TGS16GPSA0 |
3.50 kg (7.72 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1TGS24FD0 |
3.00 kg (6.61lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1TGS16SC0 |
3.03 kg (6.68 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1TGS16FD0 |
2.91 kg (6.42 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2TGS16SF0 |
3.05 kg (6.72 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1TGS8SC0 |
3.11 kg (6.86 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1TGS4SC0 |
2.86 kg (6.31 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2GP24TSSA0 |
2.85 kg (6.28 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1TGS12EC0 |
3.30 kg (7.28 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1XPT12TSFD0 |
3.45 kg (7.61 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2XPT12TSFD0 |
3.45 kg (7.61 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1PT24TSSC0 |
2.90 kg (6.39 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1PT8TSSC0 |
2.75 kg (6.06 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ4PT16PSC0 |
2.82 kg (6.22 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1PT16PSC0 |
2.82 kg (6.22 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1PT8PSC0 |
2.70 kg (5.95 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ4PT8PSC0 |
2.70 kg (5.95 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1PT4PSC0 |
2.64 kg (5.82 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ4PT4PSC0 |
2.64 kg (5.82 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1GV40PSC0 |
3.02 kg (6.66 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1GV24PSC0 |
2.80 kg (6.17 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1GV24PSA0 |
2.80 kg (6.17 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1GP24TSA0 |
2.77 kg (6.11 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1GP24TSC0 |
2.77 kg (6.11 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1GP24TEB0 |
3.04 kg (6.70 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1GP24TSD0 |
3.01 kg (6.64 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1GP48SC0 |
3.04 kg (6.70 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1GP48SD0 |
3.25 kg (7.16 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1GP48EB0 |
3.25 kg (7.16 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2GP48SA0 |
3.00 kg (6.61 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1GP48FD0 |
3.10 kg (6.83 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1GP24SC0 |
2.78 kg (6.13 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2GP24SA0 |
2.81 kg (6.19 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1GP12SC0 |
2.66 kg (5.86 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1GP12EA0 |
2.88 kg (6.35 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1FP48SA0 |
3.05 kg (6.72 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ2FP48SA0 |
2.93 kg (6.46 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1TGT24FD0 |
3.40 kg (7.50 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1GV48SA0 |
3.09 kg (6.81 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1GV48SC0 |
3.09 kg (6.81 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2GT48SA0 |
3.18 kg (7.01 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1GV48SD0 |
3.31 kg (7.30 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ3GV48SC0 |
3.31 kg (7.30 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2GT48SC0 |
3.18 kg (7.01 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1GT48FD0 |
3.40 kg (7.50 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM4GV48SA0 |
3.05 kg (6.72 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM4GV48SC0 |
3.05 kg (6.72 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1GT24SC0 |
2.72 kg (6.00 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ2FT48SA0 |
2.74 kg (6.04 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1FV48SA0 |
2.89 kg (6.37 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSU1WCME0 |
4.00 kg (8.82 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSU3WCMD0 |
3.62 kg (7.98 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1WCMD0 |
3.40 kg (7.50 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1WCMX20 |
4.00 kg (8.82 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1WCMX40 |
4.00 kg (8.82 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1FWDSC0 |
3.80 kg (8.38 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSU1FWCEA0 |
3.90 kg (8.60 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSU3FWCEA0 |
3.90 kg (8.60 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSUM1FWCEAB0 |
3.90 kg (8.60 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ2FWBSC0 |
3.23 kg (7.12 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1FWBSC0 |
3.23 kg (7.12 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSU1NSCEA0 |
3.90 kg (8.60 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1NSMSC0 |
3.23 kg (7.12 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1NSDSC0 |
3.80 kg (8.38 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSU1IPSBEA0 |
3.90 kg (8.60 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1IPSSC0 |
3.23 kg (7.12 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1IPSDSC0 |
3.80 kg (8.38 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1SSLSC0 |
3.10 kg (6.83 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1ACGASC0 |
3.23 kg (7.12 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1ACGDSC0 |
3.80 kg (8.38 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSU1ADECEA0 |
3.90 kg (8.60 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1ADEDSC0 |
3.80 kg (8.38 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQ1LBSC0 |
3.23 kg (7.12 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2FWDSC0 |
3.30 kg (7.28 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1EPSB0 |
3.40 kg (7.50 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1SDNB0 |
3.40 kg (7.50 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1WBCZ720X |
3.50 kg (7.72 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
NOTE: · Card dimensions are expressed as follows: ¡ H—Height of the front panel of the card. ¡ W—Width of the front panel of the card. ¡ D—Depth from the front panel of the card to the connector. · The card models listed in Table 7-2 are marked on the card panels. They might be slightly different from the card models marked on the card packages. For example, LSQ1QGS4SC0 and LSQM1QGS4SC0 identify the same card. LSQ1QGS4SC0 is marked on the card panel. When you order the card, you refer to it as LSQM1QGS4SC0. |
Table 7-3 Power module adapter weights and dimensions
Model |
Weight |
Height |
Width |
Depth |
LSQM1PWRSPA |
4.42 kg (9.74 lb) |
128 mm (5.04 in) |
196 mm (7.72 in) |
380 mm (14.96 in) |
LSQM1PWRSPB |
4.95 kg (10.91 lb) |
128 mm (5.04 in) |
196 mm (7.72 in) |
380 mm (14.96 in) |
Table 7-4 Power module weights and dimensions
Model |
Weight |
Height |
Width |
Depth |
PSR320-A |
1.89 kg (4.17 lb) |
40 mm (1.57 in)/1 RU |
140 mm (5.51 in) |
350 mm (13.78 in) |
PSR320-D |
1.85 kg (4.08 lb) |
140 mm (5.51 in) |
350 mm (13.78 in) |
PSR650-A |
2.42 kg (5.34 lb) |
140 mm (5.51 in) |
350 mm (13.78 in) |
PSR650-D |
2.25 kg (4.96 lb) |
140 mm (5.51 in) |
350 mm (13.78 in) |
PSR650C-12A |
4.7 kg (10.36 lb) |
128 mm (5.04 in)/3 RU |
196 mm (7.72 in) |
380 mm (14.96 in) |
PSR650C-12D |
4.2 kg (9.26 lb) |
196 mm (7.72 in) |
380 mm (14.96 in) |
PSR1200-A |
2.56 kg (5.64 lb) |
140 mm (5.51 in) |
350 mm (13.78 in) |
PSR1200-D |
2.51 kg (5.53 lb) |
140 mm (5.51 in) |
350 mm (13.78 in) |
PSR1400-A |
6.35 kg (14.00 lb) |
196 mm (7.72 in) |
380 mm (14.96 in) |
PSR1400-D |
9.24 kg (20.37 lb) |
196 mm (7.72 in) |
380 mm (14.96 in) |
PSR1400-12D1 |
6.39 kg (14.09 lb) |
196 mm (7.72 in) |
380 mm (14.96 in) |
PSR2500-12AHD |
5.7 kg (12.57 lb) |
196 mm (7.72 in) |
380 mm (14.96 in) |
PSR2500-12D |
5.7 kg (12.57 lb) |
196 mm (7.72 in) |
380 mm (14.96 in) |
PSR2800-ACV |
9.87 kg (21.76 lb) |
196 mm (7.72 in) |
380 mm (14.96 in) |
PSR6000-ACV |
12.16 kg (26.81 lb) |
196 mm (7.72 in) |
380 mm (14.96 in) |
Table 7-5 Fan tray weights and dimensions
Model |
Weight |
Height |
Width |
Depth |
S7502E fan tray |
0.82 kg (1.81 lb) |
30 mm (1.18 in) |
127 mm (5 in) |
351 mm (13.82 in) |
S7503E-S fan tray |
0.82 kg (1.81 lb) |
30 mm (1.18 in) |
127 mm (5 in) |
351 mm (13.82 in) |
S7503E-M fan tray |
0.80 kg (1.76 lb) |
30 mm (1.18 in) |
127 mm (5 in) |
351 mm (13.82 in) |
S7503E fan tray |
1.58 kg (3.48 lb) |
29 mm (1.14 in) |
225 mm (8.86 in) |
367 mm (14.45 in) |
S7506E-S fan tray |
2.20 kg (4.85 lb) |
29 mm (1.14 in) |
347 mm (13.66 in) |
367 mm (14.45 in) |
S7506E fan tray |
2.20 kg (4.85 lb) |
29 mm (1.14 in) |
347 mm (13.66 in) |
367 mm (14.45 in) |
S7506E fan tray (non-PoE) |
2.20 kg (4.85 lb) |
29 mm (1.14 in) |
347 mm (13.66 in) |
367 mm (14.45 in) |
S7506E-MF fan tray |
0.70 kg (1.54 lb) |
27 mm (1.06 in) |
100 mm (3.94 in) |
347 mm (13.66 in) |
S7506E-MF fan tray (non-PoE) |
0.70 kg (1.54 lb) |
27 mm (1.06 in) |
100 mm (3.94 in) |
347 mm (13.66 in) |
S7506E-V fan tray |
3.14 kg (6.92 lb) |
45 mm (1.77 in) |
435 mm (17.13 in) |
377 mm (14.84 in) |
S7510E fan tray |
2.94 kg (6.48 lb) |
28 mm (1.10 in) |
497 mm (19.57 in) |
351 mm (13.82 in) |
Module power consumption
Card power consumption
The power consumption of the cards depends on the card model and state. Table 7-6 shows the power consumption for different card models.
· Static power consumption (min)—Power consumed by the card when the following conditions exist:
¡ The card is running but all ports on the card are down.
¡ No transceiver module is available on the optical interface of the card.
· Dynamic power consumption (max)—Power consumed by the card when all the ports on the card are link up and are sending broadcasts.
Table 7-6 Card power consumption
Model |
Static power consumption (min) |
Dynamic power consumption (max) |
LSQ1MPUA0 |
10 W |
15 W |
LSQ1CGV24PSC0 |
25 W |
45 W |
LSQ1CGP24TSC0 |
30 W |
60 W |
LSQ1CTGS16SC0 |
83 W |
110 W |
40 W |
45 W |
25 W |
30 W |
42 W |
50 W |
50 W |
60 W |
53 W |
60 W |
42 W |
60 W |
55 W |
65 W |
LSQM3MPUA0 |
17 W |
23 W |
LSQM3MPUB0 |
36 W |
60 W |
LSQM2MPUC0 |
38 W |
63 W |
LSQM2MPUD0 |
55 W |
96 W |
LSQM2MPUDS0 |
45 W |
86 W |
LSQM1SRP8X2QE0 |
60 W |
140 W |
LSQM1CGP24TSSC0 |
28 W |
55 W |
LSQM1CGT24TSSC0 |
30 W |
46 W |
LSQM1CTGS24QSFD0 |
60 W |
110 W |
LSQM1TGS24QSFD0 |
60 W |
107 W |
LSQM1CQGS12SG0 |
55 W |
147 W |
LSQM1CGS2FE0 |
55 W |
77 W |
LSQM1QGS24RSG0 |
65 W |
198 W |
LSQ1QGS4SC0 |
70 W |
90 W |
LSQ1QGC4SC0 |
52 W |
85 W |
LSQ1GP24TXSD0 |
54 W |
95 W |
LSQ1P24XGSC0 |
40 W |
55 W |
LSQ1T24XGSC0 |
50 W |
75 W |
LSQ1TGX8SD0 |
73 W |
120 W |
LSQ1TGX4SD0 |
53 W |
80 W |
LSQ1TGX4EB0 |
53 W |
80 W |
LSQ1TGX2SC0 |
30 W |
40 W |
LSQ1TGX2SD0 |
43 W |
55 W |
LSQ1TGX2EB0 |
46 W |
65 W |
LSQ1TGX1EA0 |
35 W |
45 W |
LSQM2GT24PTSSC0 |
36 W |
59 W |
LSQM2GT24TSSC0 |
32 W |
43 W |
LSQM3GP44TSSC0 |
34 W |
69 W |
LSQM2GP44TSSC0 |
31 W |
65 W |
LSQM1GP40TS8FD0 |
47 W |
96 W |
LSQM2GP40TS8FD0 |
42 W |
81 W |
LSQM1TGS48RSG0 |
60 W |
149 W |
LSQM2TGS48SG0 |
67 W |
152 W |
LSQM1TGS48RFE0 |
50 W |
122 W |
LSQM1TGS16GPSA0 |
28 W |
64 W |
LSQM1TGS24FD0 |
50 W |
104 W |
LSQ1TGS16SC0 |
84 W |
115 W |
LSQM1TGS16FD0 |
54 W |
90 W |
LSQM2TGS16SF0 |
52 W |
75 W |
LSQ1TGS8SC0 |
75 W |
95 W |
LSQ1TGS4SC0 |
52 W |
60 W |
LSQM2GP24TSSA0 |
25 W |
49 W |
LSQM1TGS12EC0 |
82 W |
130 W |
LSQM1XPT12TSFD0 |
100 W |
162 W |
LSQM2XPT12TSFD0 |
100 W |
162 W |
LSQM1PT24TSSC0 |
80 W |
115 W |
LSQM1PT8TSSC0 |
56 W |
80 W |
LSQ4PT16PSC0 |
55 W |
65 W |
LSQ1PT16PSC0 |
55 W |
65 W |
LSQ1PT8PSC0 |
38 W |
45 W |
LSQ4PT8PSC0 |
38 W |
45 W |
LSQ1PT4PSC0 |
33 W |
40 W |
LSQ4PT4PSC0 |
33 W |
40 W |
LSQ1GV40PSC0 |
41 W |
95 W |
LSQ1GV24PSC0 |
30 W |
60 W |
LSQ1GV24PSA0 |
30 W |
60 W |
LSQ1GP24TSA0 |
25 W |
45 W |
LSQ1GP24TSC0 |
25 W |
45 W |
LSQ1GP24TEB0 |
50 W |
90 W |
LSQ1GP24TSD0 |
47 W |
75 W |
LSQ1GP48SC0 |
43 W |
85 W |
LSQ1GP48SD0 |
44 W |
95 W |
LSQ1GP48EB0 |
43 W |
110 W |
LSQM2GP48SA0 |
28 W |
58 W |
LSQM1GP48FD0 |
49 W |
78 W |
LSQ1GP24SC0 |
38 W |
55 W |
LSQM2GP24SA0 |
24 W |
45 W |
LSQ1GP12SC0 |
26 W |
35 W |
LSQ1GP12EA0 |
40 W |
50 W |
LSQ1FP48SA0 |
34 W |
85 W |
LSQ2FP48SA0 |
30 W |
75 W |
LSQM1TGT24FD0 |
60 W |
112 W |
LSQ1GV48SA0 |
60 W |
80 W |
LSQ1GV48SC0 |
60 W |
90 W |
LSQM2GT48SA0 |
35 W |
45 W |
LSQ1GV48SD0 |
67 W |
95 W |
LSQ3GV48SC0 |
67 W |
95 W |
LSQM2GT48SC0 |
38 W |
48 W |
LSQM1GT48FD0 |
48 W |
65 W |
LSQM4GV48SA0 |
34 W |
44 W |
LSQM4GV48SC0 |
38 W |
48 W |
LSQ1GT24SC0 |
42 W |
50 W |
LSQ2FT48SA0 |
24 W |
30 W |
LSQ1FV48SA0 |
30 W |
35 W |
LSU1WCME0 |
125 W |
180 W |
LSU3WCMD0 |
118 W |
150 W |
LSQ1WCMD0 |
86 W |
117 W |
LSQM1WCMX20 |
125 W |
180 W |
LSQM1WCMX40 |
125 W |
180 W |
LSQM1FWDSC0 |
115 W |
123 W |
LSU1FWCEA0 |
109 W |
157 W |
LSU3FWCEA0 |
109 W |
157 W |
LSUM1FWCEAB0 |
109 W |
157 W |
LSQ2FWBSC0 |
80 W |
104 W |
LSQ1FWBSC0 |
80 W |
104 W |
LSU1NSCEA0 |
109 W |
157 W |
LSQ1NSMSC0 |
80 W |
104 W |
LSQM1NSDSC0 |
115 W |
123 W |
LSU1IPSBEA0 |
109 W |
157 W |
LSQ1IPSSC0 |
80 W |
104 W |
LSQM1IPSDSC0 |
116 W |
124 W |
LSQ1SSLSC0 |
80 W |
89 W |
LSQ1ACGASC0 |
80 W |
104 W |
LSQM1ACGDSC0 |
116 W |
124 W |
LSU1ADECEA0 |
109 W |
157 W |
LSQM1ADEDSC0 |
116 W |
124 W |
LSQ1LBSC0 |
80 W |
104 W |
LSQM2FWDSC0 |
60 W |
66 W |
LSQM1EPSB0 |
102 W |
124 W |
LSQM1SDNB0 |
102 W |
124 W |
LSQM1WBCZ720X |
160 W |
210 W |
Fan tray power consumption
The switch uses fan trays that can automatically adjust the fan speed based on the heat dissipation condition of the switch. The power consumed by a fan tray depends on the fan speed. Table 7-7 shows the power consumption of different fan trays.
Table 7-7 Fan tray power consumption
Model |
Minimum fan tray power consumption |
Maximum fan tray power consumption |
S7502E |
7.5 W |
14.5 W |
S7503E-S |
7.5 W |
14.5 W |
S7503E-M |
7.5 W |
14.5 W |
S7503E |
15.5 W |
27.5 W |
S7506E-S |
24.5 W |
42.5 W |
S7506E |
24.5 W |
42.5 W |
S7506E (non-PoE) |
24.5 W |
42.5 W |
S7506E-MF |
7.00 W |
14.00 W |
7.00 W |
14.00 W |
S7506E-V |
30 W |
45.5 W |
S7510E |
28 W |
48.5 W |
Total power consumption
For the S7506E-S, S7506E (non-PoE), or S7506E-MF (non-PoE), the total power consumption of the switch equals its system power consumption.
For the S7502E, S7503E-S, S7503E, S7506E, S7506E-MF, S7506E-V, or S7510E, the total power consumption of the switch equals its system power consumption plus its PoE power consumption.
System power consumption
The system power consumption of the switch depends on the type and number of the running cards and the fan tray power consumption.
· The minimum system power consumption is the total static power consumption of all cards plus the minimum fan tray power consumption. For example, an S7503E switch is installed with two LSQM2MPUC0 MPUs, three LSQ3GV48SC0 (LSQM3GV48SC0) service modules, and one fan tray. The minimum system power consumption of the switch is 2 × 38 + 3 × 67 + 15.5 = 292.5 W.
· The maximum system power consumption is the total dynamic power consumption of all cards plus the maximum fan tray power consumption. For example, an S7503E switch is installed with two LSQM2MPUC0 MPUs, three LSQ3GV48SC0 (LSQM3GV48SC0) service modules, and one fan tray. The maximum system power consumption of the switch is 2 × 63 + 3 × 95 +27.5 = 438.5 W.
Table 7-8 lists the max power consumption for each model of the S7500E in full and max configuration.
· Max system power consumption (full and max configuration)—Max system power consumption when the switch is fully configured with cards and fan trays that have the highest power consumptions.
· Max card and fan tray power consumption (full and max configuration)—Max card and fan tray power consumption when the switch is fully configured with cards and fan trays that have the highest power consumptions.
Table 7-8 Max system/Max card and fan tray power consumption in full and max configuration
Model |
Max system power consumption (full and max configuration) |
Max card and fan tray power consumption (full and max configuration) |
S7502E-AC |
450 W |
359 W |
S7502E-DC |
430 W |
359 W |
S7503E-S-AC |
380 W |
350 W |
S7503E-S-DC |
380 W |
350 W |
S7503E-M-AC |
530 W |
423 W |
S7503E-M-DC |
510 W |
423 W |
S7503E-AC |
940 W |
755 W |
S7503E-DC |
900 W |
755 W |
S7506E-S-AC |
1320 W |
1057 W |
S7506E-S-DC |
1260 W |
1057 W |
S7506E-AC |
1520 W |
1217 W |
S7506E-DC |
1450 W |
1217 W |
S7506E (non-PoE)-AC |
1320 W |
1057 W |
S7506E (non-PoE)-DC |
1260 W |
1057 W |
S7506E-MF-AC |
1520 W |
1217 W |
S7506E-MF-DC |
1450 W |
1217 W |
S7506E-MF (non-PoE)-AC |
1320 W |
1057 W |
S7506E-MF (non-PoE)-DC |
1260 W |
1057 W |
S7506E-V-AC |
1520 W |
1220 W |
S7506E-V-DC |
1450 W |
1220 W |
S7510E-AC |
2260 W |
1816 W |
S7510E-DC |
2160 W |
1816 W |
The power over Ethernet (PoE) power consumption refers to the sum of power consumptions of all powered devices (PDs) connected to the switch.
The maximum PoE power consumption refers to the sum of the power consumption of all PDs when all power interfaces (PIs) are connected to PDs and consume the maximum power. The maximum PoE power consumption is decided by the following items:
· Number of the PoE cards (PSEs) installed on the switch.
· Number of the PIs that each PoE card provides.
· Maximum power of each PoE card.
· Maximum PoE power that each slot of the switch provides.
Each slot of the switch can provide a maximum PoE power of 800 W.
Table 7-9 shows the specifications for each PoE card model.
For example, an S7503E switch is installed with three LSQ3GV48SC0 (LSQM3GV48SC0) PoE cards. The maximum PoE power consumption of the switch is 3 × 800 = 2400 W.
Table 7-9 PoE card specifications
Model |
PI quantity |
PI power |
Maximum PSE power |
Maximum number |
LSQ1GV48SD0 |
48 |
0 to 30 W |
800 W |
· S7502E: 2 · S7503E: 3 · S7506E: 6 · S7506E-MF: 6 · S7506E-V: 6 · S7510E: 10 |
LSQ3GV48SC0 |
48 |
0 to 30 W |
800 W |
LSQM4GV48SA0 |
48 |
0 to 30 W |
1440 W |
LSQM4GV48SC0 |
48 |
0 to 30 W |
1440 W |
LSQ1CGV24PSC0 |
24 |
0 to 15.4 W |
370 W |
LSQ1GV24PSC0 |
24 |
0 to 15.4 W |
370 W |
LSQ1GV24PSA0 |
24 |
0 to 15.4 W |
370 W |
LSQ1FV48SA0 |
48 |
0 to 15.4 W |
740 W |
LSQ1GV48SA0 |
48 |
0 to 15.4 W |
740 W |
LSQ1GV48SC0 |
48 |
0 to 15.4 W |
740 W |
LSQ1GV40PSC0 |
40 |
0 to 15.4 W |
616 W |
NOTE: · The PoE power consumption is 0 if the switch does not supply PoE. · The maximum PoE power consumption of the S7510E switch is 10000 W. · For more information about PoE power supply, see "(Optional) Setting up a PoE system." |
Heat dissipation
Heat dissipation is measured in BTU/h, and 1 W equals 3.4121BTU/h.
The heat dissipation of a switch depends on its power consumption. To calculate heat dissipation of the switch, assume 90% power consumption is converted to heat, and the efficiency of the power module is 90%. Heat dissipation/hour of the switch is 0.9 × (total power consumption of the cards plus power consumption of the fan tray)/0.9 × 3.4121.
Table 7-10 shows the heat dissipation for each switch model.
Model |
Heat dissipation (BTU/h) |
S7502E |
1223 |
S7503E-S |
1190 |
S7503E-M |
1441 |
S7503E |
2574 |
S7506E-S |
3605 |
S7506E |
4151 |
S7506E (non-PoE) |
3605 |
S7506E-MF |
4151 |
3605 |
S7506E-V |
4161 |
S7510E |
6195 |
For the power consumption of the cards and fan trays of the S7500E series switches, see "Module power consumption."
Noise
The switch uses fan trays that can adjust the fan speed automatically based on the device temperature. The sound pressure levels vary by fan speed. For more information, see Table 7-11.
Table 7-11 Sound pressure levels
Model |
Sound pressure level when the fan tray operates at low speed |
Sound pressure level when the fan tray operates at middle speed |
Sound pressure level when the fan tray operates at full speed |
S7502E |
49.8 dBA |
51.6 dBA |
56.7 dBA |
S7503E-S |
49.8 dBA |
51.6 dBA |
56.7 dBA |
S7503E-M |
49.8 dBA |
51.6 dBA |
56.7 dBA |
S7503E |
51.6 dBA |
54.6 dBA |
56.1 dBA |
S7506E-S |
53.6 dBA |
56.2 dBA |
57.7 dBA |
S7506E |
53.6 dBA |
56.2 dBA |
57.7 dBA |
S7506E (non-PoE) |
53.6 dBA |
56.2 dBA |
56.7 dBA |
S7506E-MF |
53.6 dBA |
56.2 dBA |
57.7 dBA |
53.6 dBA |
56.2 dBA |
56.7 dBA |
S7506E-V |
52.1 dBA |
55.1 dBA |
56.2 dBA |
S7510E |
53.5 dBA |
55.8 dBA |
56.7 dBA |
