- 04-IP Multicast Volume
- 00-IP Multicast Volume Organization
- 01-Multicast Routing and Forwarding Commands
- 02-IGMP Commands
- 03-PIM Commands
- 04-MSDP Commands
- 05-MBGP Commands
- 06-Multicast VPN Commands
- 07-IGMP Snooping Commands
- 08-Multicast VLAN Commands
- 09-IPv6 Multicast Routing and Forwarding Commands
- 10-MLD Commands
- 11-IPv6 PIM Commands
- 12-IPv6 MBGP Commands
- 13-MLD Snooping Commands
- 14-IPv6 Multicast VLAN Commands
| 14-IPv6 Multicast VLAN Commands | 32.56 KB |
1 IPv6 Multicast VLAN Configuration Commands
port (IPv6 multicast VLAN view)
subvlan (IPv6 multicast VLAN view)
display multicast-vlan ipv6
display multicast-vlan ipv6 [ vlan-id ]
View
Default Level
1: Monitor level
vlan-id: VLAN ID of an IPv6 multicast VLAN, in the range of 1 to 4094. If this argument is not provided, the information about all IPv6 multicast VLANs will be displayed.
Use the display multicast-vlan ipv6 command to view the information about the specified IPv6 multicast VLAN or all IPv6 multicast VLANs.
# View the information about all IPv6 multicast VLANs.
<Sysname> display multicast-vlan ipv6
Total 4 IPv6 multicast-vlan(s)
IPv6 Multicast vlan 100
subvlan list:
vlan 2 4-6
port list:
no port
IPv6 Multicast vlan 200
subvlan list:
no subvlan
port list:
GE2/0/1 GE2/0/2
IPv6 Multicast vlan 300
subvlan list:
vlan 3
port list:
GE2/0/3 GE2/0/4
IPv6 Multicast vlan 400
subvlan list:
no subvlan
port list:
no port
Table 1-1 display multicast-vlan ipv6 command output description
Total 4 IPv6 multicast-vlan(s) |
Total number of IPv6 multicast VLANs |
IPv6 Multicast vlan |
An IPv6 multicast VLAN |
subvlan list |
List of sub-VLANs of the IPv6 multicast VLAN |
port list |
Port list of the IPv6 multicast VLAN |
multicast-vlan ipv6
multicast-vlan ipv6 vlan-id
undo multicast-vlan ipv6 { all | vlan-id }
View
Default Level
2: System level
vlan-id: Specifies a VLAN by its ID, in the range of 1 to 4094.
all: Deletes all IPv6 multicast VLANs.
Use the multicast-vlan ipv6 command to configure the specified VLAN as an IPv6 multicast VLAN and enter IPv6 multicast VLAN view.
Use the undo multicast-vlan ipv6 command to remove the specified VLAN as an IPv6 multicast VLAN.
No VLAN is an IPv6 multicast VLAN by default.
Note that:
l The specified VLAN to be configured as an IPv6 multicast VLAN must exist.
l The IPv6 multicast VLAN feature cannot be enabled on a device with IPv6 multicast routing enabled.
l For a sub-VLAN-based IPv6 multicast VLAN, you need to enable MLD Snooping only in the IPv6 multicast VLAN; for a port-based IPv6 multicast VLAN, you need to enable MLD Snooping in both the IPv6 multicast VLAN and all the user VLANs.
Related commands: multicast ipv6 routing-table in the IPv6 Multicast Routing and Forwarding Commands in the IP Multicast Volume; mld-snooping enable in the MLD Snooping Commands in the IP Multicast Volume.
# Enable MLD Snooping in VLAN 100. Configure it as an IPv6 multicast VLAN and enter IPv6 multicast VLAN view.
[Sysname] mld-snooping
[Sysname-mld-snooping] quit
[Sysname] vlan 100
[Sysname-vlan100] mld-snooping enable
[Sysname-vlan100] quit
[Sysname] multicast-vlan ipv6 100
[Sysname-ipv6-mvlan-100]
port interface-list
undo port { all | interface-list }
View
Default Level
2: System level
interface-list: Specifies a port in the form of interface-type interface-number, or a port range in the form of interface-type start-interface-number to interface-type end-interface-number, where the end interface number must be greater than the start interface number.
all: Deletes all the ports in the current IPv6 multicast VLAN.
Use the port command to assign port(s) to the current IPv6 multicast VLAN.
Use the undo port command to delete port(s) from the current IPv6 multicast VLAN.
By default, an IPv6 multicast VLAN has no ports.
Note that:
l A port can belong to only one IPv6 multicast VLAN.
l Only the following types of interfaces can be configured as IPv6 multicast VLAN ports: Ethernet, and Layer 2 aggregate interfaces.
# Assign ports GigabitEthernet 2/0/1 through GigabitEthernet 2/0/5 to IPv6 multicast VLAN 100.
[Sysname-ipv6-mvlan-100] port gigabitethernet 2/0/1 to gigabitethernet 2/0/5
subvlan vlan-list
undo subvlan { all | vlan-list }
View
Default Level
2: System level
vlan-list: Specifies a VLAN in the form of vlan-id, or a VLAN range in the form of start-vlan-id to end-vlan-id, where the end VLAN ID must be greater than the start VLAN ID. The effective range of a VLAN ID is 1 to 4094.
all: Deletes all the sub-VLANs of the current IPv6 multicast VLAN.
Use the subvlan command to configure sub-VLAN(s) for the current IPv6 multicast VLAN.
Use the undo subvlan command to remove the specified sub-VLAN(s) or all sub-VLANs from the current IPv6 multicast VLAN.
An IPv6 multicast VLAN has no sub-VLANs by default.
Note that:
l The VLANs to be configured as the sub-VLANs of the IPv6 multicast VLAN must exist and must not be IPv6 multicast VLANs or sub-VLANs of another IPv6 multicast VLAN.
l The number of sub-VLANs of the IPv6 multicast VLAN must not exceed the system-defined limit (an S7500E series Ethernet switch supports up to five multicast VLANs, and supports up to 4000 sub-VLANs for each multicast VLAN. The total number of sub-VLANs for all multicast VLANs on the switch cannot exceed 4000.).
# Configure VLAN 10 through VLAN 15 as sub-VLANs of IPv6 multicast VLAN 100.
[Sysname-ipv6-mvlan-100] subvlan 10 to 15
