- 04-IP Multicast Volume
- 00-IP Multicast Volume Organization
- 01-Multicast Routing and Forwarding Commands
- 02-IGMP Commands
- 03-PIM Commands
- 04-MSDP Commands
- 05-MBGP Commands
- 06-Multicast VPN Commands
- 07-IGMP Snooping Commands
- 08-Multicast VLAN Commands
- 09-IPv6 Multicast Routing and Forwarding Commands
- 10-MLD Commands
- 11-IPv6 PIM Commands
- 12-IPv6 MBGP Commands
- 13-MLD Snooping Commands
- 14-IPv6 Multicast VLAN Commands
| 04-MSDP Commands | 96.27 KB |
Table of Contents
The term “router” in this document refers to a router in the generic sense or a Layer 3 switch running MSDP.
MSDP Configuration Commands
cache-sa-enable
cache-sa-enable
undo cache-sa-enable
View
Public instance MSDP view, VPN instance MSDP view
Default Level
2: System level
None
Use the cache-sa-enable command to enable the SA cache mechanism to cache the (S, G) entries contained in SA messages.
Use the undo cache-sa-enable command to disable the SA cache mechanism.
By default, the SA cache mechanism is enabled, that is, the device caches the (S, G) entries contained in SA messages received.
# Enable the SA message cache mechanism in the public instance so that the device caches the (S, G) entries contained in SA messages received.
[Sysname] msdp
[Sysname-msdp] cache-sa-enable
display msdp brief
display msdp [ all-instance | vpn-instance vpn-instance-name ] brief [ state { connect | down | listen | shutdown | up } ]
View
Default Level
1: Monitor level
all-instance: Specifies all instances.
vpn-instance vpn-instance-name: Specifies a VPN instance. A VPN instance name is a case sensitive string of up to 31 characters and must not contain any space.
state: Displays the information of MSDP peers in the specified state.
connect: Displays the information of MSDP peers in the connecting state.
down: Displays the information of MSDP peers in the down state.
listen: Displays the information of MSDP peers in the listening state.
shutdown: Displays the information of MSDP peers in the deactivated state.
up: Displays the information of MSDP peers in the in-session state.
Use the display msdp brief command to view the brief information of MSDP peers.
Note that if neither all-instance nor vpn-instance is specified, this command will display the information on the public instance.
# View the brief information of MSDP peers in all states in the public instance.
<Sysname> display msdp brief
MSDP Peer Brief Information of VPN-Instance: public net
Configured Up Listen Connect Shutdown Down
1 1 0 0 0 0
Peer's Address State Up/Down time AS SA Count Reset Count
20.20.20.20 Up 00:00:13 100 0 0
Table 1-1 display msdp brief command output description
MSDP Peer Brief Information of VPN-Instance: public net |
Brief information of MSDP peers of the public network |
Configured |
Number of MSDP peers configured |
Up |
Number of MSDP peers in the up state |
Listen |
Number of MSDP peers in the listen state |
Connect |
Number of MSDP peers in the connect state |
Shutdown |
Number of MSDP peers in the shutdown state |
Down |
Number of MSDP peers in the down state |
Peer's Address |
MSDP peer address |
State |
MSDP peer status: l Up: Session set up; MSDP peer in session l Listen: Session set up; local device as server, in listening state l Connect: Session not set up; local device as client, in connecting state l Shutdown: Deactivated l Down: Connection failed |
Up/Down time |
Length of time since MSDP peer connection was established/failed |
AS |
Number of the AS where the MSDP peer is located. “?” indicates that the system was unable to obtain the AS number. |
SA Count |
Number of (S, G) entries |
Reset Count |
MSDP peer connection reset times |
display msdp peer-status
display msdp [ all-instance | vpn-instance vpn-instance-name ] peer-status [ peer-address ]
View
Default Level
1: Monitor level
peer-address: Specifies an MSDP peer by its address. If you do not provide this argument, this command will display the detailed status information of all MSDP peers.
Use the display msdp peer-status command to view the detailed MSDP peer status information.
Related commands: peer connect-interface, peer description, peer mesh-group, peer minimum-ttl, peer request-sa-enable, peer sa-cache-maximum, peer sa-policy, peer sa-request-policy.
# View the detailed status information of the MSDP peer with the address of 10.110.11.11 in the public instance.
<Sysname> display msdp peer-status 10.110.11.11
MSDP Peer Information of VPN-Instance: public net
MSDP Peer 20.20.20.20, AS 100
Description:
Information about connection status:
State: Up
Up/down time: 14:41:08
Resets: 0
Connection interface: LoopBack0 (20.20.20.30)
Number of sent/received messages: 867/947
Number of discarded output messages: 0
Elapsed time since last connection or counters clear: 14:42:40
Information about (Source, Group)-based SA filtering policy:
Import policy: none
Export policy: none
Information about SA-Requests:
Policy to accept SA-Request messages: none
Sending SA-Requests status: disable
Minimum TTL to forward SA with encapsulated data: 0
SAs learned from this peer: 0, SA-cache maximum for the peer: none
Input queue size: 0, Output queue size: 0
Counters for MSDP message:
Count of RPF check failure: 0
Incoming/outgoing SA messages: 0/0
Incoming/outgoing SA requests: 0/0
Incoming/outgoing SA responses: 0/0
Incoming/outgoing data packets: 0/0
Table 1-2 display msdp peer-status command output description
MSDP Peer Information of VPN-Instance: public net |
Information of the MSDP peer of the public network |
MSDP Peer |
MSDP peer address |
AS |
State |
Resets |
Number of times the MSDP peer connection is reset |
Up/Down time |
Connection interface |
Interface and its IP address used for setting up a TCP connection with the remote MSDP peer |
Number of sent/received messages |
Number of SA messages sent and received through this connection |
Number of discarded output messages |
Number of discarded outgoing messages |
Elapsed time since last connection or counters clear |
Time passed since the information of the MSDP peer was last cleared |
Information about (Source, Group)-based SA filtering policy |
SA message filtering list information l Import policy: Filter list for receiving SA messages from the specified MSDP peer l Export policy: Filter list for forwarding SA messages from the specified MSDP peer |
Information about SA-Requests |
SA requests information l Policy to accept SA-Request messages: Filtering rule for receiving or forwarding SA messages from the specified MSDP peer l Sending SA-Requests status: Whether enabled to send an SA request message to the designated MSDP peer upon receiving a new Join message |
Minimum TTL to forward SA with encapsulated data |
Minimum TTL of multicast packet encapsulated in SA messages |
SAs learned from this peer |
Number of cached (S, G) entries learned from this MSDP peer |
SA-cache maximum for the peer |
Maximum number of (S, G) entries learned from this MSDP peer that the device can cache |
Input queue size |
Data size cached in the input queue |
Output queue size |
Data size cached in the output queue |
Counters for MSDP message |
MSDP peer statistics: l Count of RPF check failure: Number of SA messages discarded due to RPF check failure l Incoming/outgoing SA messages: Number of SA messages received and sent l Incoming/outgoing SA requests: Number of SA request received and sent l Incoming/outgoing SA responses: Number of SA responses received and sent l Incoming/outgoing data packets: Number of received and sent SA messages encapsulated with multicast data |
display msdp sa-cache
display msdp [ all-instance | vpn-instance vpn-instance-name ] sa-cache [ group-address | source-address | as-number ] *
View
Default Level
1: Monitor level
group-address: Multicast group address in the (S, G) entry, in the range of 224.0.1.0 to 239.255.255.255.
source-address: Multicast source address in the (S, G) entry.
as-number: AS number, in the range of 1 to 65535.
Use the display msdp sa-cache command to view the information of (S, G) entries in the SA cache.
Note that:
l If you do not specify all-instance nor vpn-instance, this command will display the information on the public instance.
l This command gives the corresponding output only after the cache-sa-enable command is executed.
l If you do not provide a group address, this command will display the (S, G) entry information for all multicast groups.
l If you do not provide a source address, this command will display the (S, G) entry information for all sources.
l If you provide neither a group address nor a source address, this command will display the information of all cached (S, G) entries.
l If you do not provide an AS number, this command will display the (S, G) entry information related to all ASs.
Related commands: cache-sa-enable.
# View the information of (S, G) entries in the SA cache in the public instance.
<Sysname> display msdp sa-cache
MSDP Source-Active Cache Information of VPN-Instance: public net
MSDP Total Source-Active Cache - 5 entries
MSDP matched 5 entries
(Source, Group) Origin RP Pro AS Uptime Expires
(10.10.1.2, 225.1.1.1) 10.10.10.10 BGP 100 00:00:11 00:05:49
(10.10.1.3, 225.1.1.1) 10.10.10.10 BGP 100 00:00:11 00:05:49
(10.10.1.2, 225.1.1.2) 10.10.10.10 BGP 100 00:00:11 00:05:49
(10.10.2.1, 225.1.1.2) 10.10.10.10 BGP 100 00:00:11 00:05:49
(10.10.1.2, 225.1.2.2) 10.10.10.10 BGP 100 00:00:11 00:05:49
Table 1-3 display msdp sa-cache command output description
MSDP Source-Active Cache Information of VPN-Instance: public net |
SA cache information of the public network |
MSDP Total Source-Active Cache - 5 entries |
Total number of (S, G) entries in the SA cache |
MSDP matched 5 entries |
Total number of (S, G) entries matched by MSDP |
(Source, Group) |
(S, G) entry: (source address, group address) |
Origin RP |
Address of the RP that generated the (S, G) entry |
Pro |
Type of protocol from which the AS number is originated. “?” indicates that the system was unable to obtain the protocol type. |
AS |
AS number of the origin RP. “?” indicates that the system was unable to obtain the AS number. |
Uptime |
Length of time for which the cached (S, G) entry has been existing, in hours:minutes:seconds |
Expires |
Length of time in which the cached (S, G) entry will expire, in hours:minutes:seconds |
display msdp sa-count
display msdp [ all-instance | vpn-instance vpn-instance-name ] sa-count [ as-number ]
View
Default Level
1: Monitor level
Use the display msdp sa-count command to view the number of (S, G) entries in the SA cache.
Note that:
l If neither all-instance nor vpn-instance is specified, this command will display the information on the public instance.
# View the number of (S, G) entries in the SA cache for the public instance.
<Sysname> display msdp sa-count
MSDP Source-Active Count Information of VPN-Instance: public net
Number of cached Source-Active entries, counted by Peer
Peer's Address Number of SA
10.10.10.10 5
Number of source and group, counted by AS
AS Number of source Number of group
? 3 3
Total 5 Source-Active entries
Table 1-4 display msdp sa-count command output description
MSDP Source-Active Count Information of VPN-Instance: public net |
Number of SA messages for the public network cache |
Number of cached Source-Active entries, counted by Peer |
Number of (S, G) entries counted by peer |
Peer's Address |
Address of the MSDP peer that sent SA messages |
Number of SA |
Number of (S, G) entries from this peer |
Number of source and group, counted by AS |
Number of cached (S, G) entries, counted by AS |
AS |
AS number. “?” indicates that the system was unable to obtain the AS number. |
Number of source |
Number of multicast sources from this AS |
Number of group |
Number of multicast groups from this AS |
encap-data-enable
encap-data-enable
undo encap-data-enable
View
Default Level
2: System level
Use the encap-data-enable command to enable register message encapsulation in SA messages.
Use the undo encap-data-enable command to disable register message encapsulation in SA messages.
By default, an SA message contains only an (S, G) entry. No register message is encapsulated in an SA message.
# Enable register message encapsulation in SA messages in the public instance.
[Sysname] msdp
[Sysname-msdp] encap-data-enable
import-source
import-source [ acl acl-number ]
undo import-source
View
Default Level
2: System level
acl-number: Basic or advanced ACL number, in the range of 2000 to 3999. A basic ACL is used to filter multicast sources, while an advanced ACL is used to filter multicast sources or multicast groups. If you do not provide this argument in your command, no multicast source information will be advertised.
During ACL matching, the protocol ID in the ACL rule is not checked.
Use the import-source command to configure a rule of creating (S, G) entries.
Use the undo import-source command to remove any rule of creating (S, G) entries.
By default, when an SA message is created, there are no restrictions on the (S, G) entries to be advertised in it, namely all the (S, G) entries within the domain are advertised in the SA message.
In addition to controlling SA message creation by using this command, you can also configure a filtering rule for forwarding and receiving SA messages by using the peer sa-policy command.
Related commands: peer sa-policy.
# Configure the MSDP peer in the public instance to advertise only the (S, G) entries of multicast sources on the 10.10.0.0/16 subnet and with multicast group address of 225.1.0.0/16 when creating an SA message.
[Sysname] acl number 3101
[Sysname-acl-adv-3101] rule permit ip source 10.10.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[Sysname-acl-adv-3101] quit
[Sysname] msdp
[Sysname-msdp] import-source acl 3101
msdp
msdp [ vpn-instance vpn-instance-name ]
undo msdp [ vpn-instance vpn-instance-name ]
View
Default Level
2: System level
Use the msdp command to enable MSDP in the public instance or the specified VPN instance and enter public instance or VPN instance MSDP view.
Use the undo msdp command to disable MSDP in the public instance or the specified VPN instance and remove the configurations performed in public instance or VPN instance MSDP view to free the resources occupied by MSDP.
By default, MSDP is disabled.
Note that:
l If you do not specify vpn-instance, this configuration will take effect only on the public instance
l IP multicast must be enabled in the corresponding instance before this command can take effect.
Related commands: multicast routing-enable in Multicast Routing and Forwarding Commands of the Multicast Volume.
# Enable IP multicast routing in the public instance, and enable MSDP in the public instance to enter public instance MSDP view.
[Sysname] multicast routing-enable
[Sysname] msdp
[Sysname-msdp]
# Enable IP multicast routing in VPN instance mvpn, and enable MSDP in VPN instance mvpn to enter MSDP view of VPN instance mvpn.
[Sysname] ip vpn-instance mvpn
[Sysname-vpn-instance-mvpn]route-distinguisher 100:1
[Sysname-vpn-instance-mvpn] multicast routing-enable
[Sysname-vpn-instance-mvpn] quit
[Sysname] msdp vpn-instance mvpn
[Sysname-msdp-mvpn]
originating-rp
originating-rp interface-type interface-number
undo originating-rp
View
Default Level
2: System level
Use the originating-rp command to configure the address of the specified interface as the RP address of SA messages.
Use the undo originating-rp command to restore the system default.
Be default, the PIM RP address is used as the RP address of SA messages.
# Specify the IP address of VLAN-interface 100 as the RP address of SA messages.
[Sysname] msdp
[Sysname-msdp] originating-rp vlan-interface 100
peer peer-address connect-interface interface-type interface-number
undo peer peer-address
View
Default Level
2: System level
peer-address: MSDP peer address.
interface-type interface-number: Specifies an interface by its type and number. The local device will use the IP address of the specified interface as the source IP address when setting up a TCP connection with the remote MSDP peer.
Use the peer connect-interface command to create an MSDP peer connection.
Use the undo peer connect-interface command to remove an MSDP peer connection.
No MSDP peer connection is created by default.
Be sure to carry out this command before you use any other peer command; otherwise the system will prompt that the peer does not exist.
Related commands: static-rpf-peer.
# Configure the router with the IP address of 125.10.7.6 as the MSDP peer of the local router, with interface VLAN-interface 100 as the local connection port.
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 connect-interface vlan-interface 100
peer description
peer peer-address description text
undo peer peer-address description
View
Default Level
2: System level
text: Descriptive string of 1 to 80 case sensitive characters including spaces.
Use the peer description command to configure the description information for the specified MSDP peer.
Use the undo peer description command to delete the configured description information of the specified MSDP peer.
By default, an MSDP peer has no description information.
Related commands: display msdp peer-status.
# In the public instance, add the descriptive text “Router CstmrA” for the router with the IP address of 125.10.7.6 to indicate that this router is Customer A.
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 description Router CstmrA
peer mesh-group
peer peer-address mesh-group name
undo peer peer-address mesh-group
View
Default Level
2: System level
name: Mesh group name, a case-sensitive string of 1 to 32 characters. A mesh group name must not contain any space.
Use the peer mesh-group command to configure an MSDP peer as a mesh group member.
Use the undo peer mesh-group command to remove an MSDP peer as a mesh group member.
By default, an MSDP peer does not belong to any mesh group.
# In the public instance, configure the MSDP peer with the IP address of 125.10.7.6 as a member of the mesh group “Grp1”.
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 mesh-group Grp1
peer minimum-ttl
peer peer-address minimum-ttl ttl-value
undo peer peer-address minimum-ttl
View
Default Level
2: System level
ttl-value: Time-to-Live (TTL) threshold, in the range of 0 to 255.
Use the peer minimum-ttl command to configure the TTL threshold for multicast data packet encapsulation in SA messages.
Use the undo peer minimum-ttl command to restore the system default.
By default, the TTL threshold for a multicast packet to be encapsulated in an SA message is 0.
# In the public instance, set the TTL threshold for multicast packets to be encapsulated in SA messages to 10 so that only multicast data packets whose TTL value is larger than or equal to 10 can be encapsulated in SA messages and forwarded to the MSDP peer 110.10.10.1.
[Sysname] msdp
[Sysname-msdp] peer 110.10.10.1 minimum-ttl 10
peer peer-address request-sa-enable
undo peer peer-address request-sa-enable
View
Default Level
2: System level
Use the peer request-sa-enable command to enable the device to send an SA request message to the specified MSDP peer upon receiving a new join message.
Use the undo peer request-sa-enable command to disable the device from sending an SA request message to the specified MSDP peer.
By default, upon receiving a new join message, the router does not send an SA request message to any MSDP peer; instead, it waits for the next SA message to come.
Note that before you can enable the device to send SA requests, you must disable the SA message cache mechanism.
# Disable the SA message cache mechanism in the public instance, and enable the router to send an SA request message to the MSDP peer 125.10.7.6 upon receiving a new Join message.
[Sysname] msdp
[Sysname-msdp] undo cache-sa-enable
[Sysname-msdp] peer 125.10.7.6 request-sa-enable
peer peer-address sa-cache-maximum sa-limit
undo peer peer-address sa-cache-maximum
View
Default Level
2: System level
sa-limit: Maximum number of (S, G) entries that the device can cache, in the range of 1 to 8,192.
Use the peer sa-cache-maximum command to configure the maximum number of (S, G) entries learned from the specified MSDP peer that the device can cache.
Use the undo peer sa-cache-maximum command to restore the system default.
By default, the device can cache a maximum of 8,192 (S, G) entries learned from any MSDP peer.
Related commands: display msdp sa-count, display msdp peer-status, display msdp brief.
# In the public instance allow the device to cache a maximum of 100 (S, G) entries learned from its MSDP peer 125.10.7.6.
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 sa-cache-maximum 100
peer sa-policy
peer peer-address sa-policy { import | export } [ acl acl-number ]
undo peer peer-address sa-policy { import | export }
View
Default Level
2: System level
import: Specifies to filter SA messages from the specified MSDP peer.
export: Specifies to filter SA messages forwarded to the specified MSDP peer.
acl-number: Advanced ACL number, in the range of 3000 to 3999. If you do not provide an ACL number, all SA messages carrying (S, G) entries will be filtered off.
Use the peer sa-policy command to configure a filtering rule for receiving or forwarding SA messages.
Use the undo peer sa-policy command to restore the default setting.
By default, SA messages received or to be forwarded are not filtered, namely, all SA messages are accepted or forwarded.
In addition to controlling SA message receiving and forwarding by using this command, you can also configure a filtering rule for creating SA messages using the import-source command.
Related commands: display msdp peer-status, import-source.
# Configure a filtering rule so that SA messages will be forwarded to the MSDP peer 125.10.7.6 only if they match ACL 3100.
[Sysname] acl number 3100
[Sysname-acl-adv-3100] rule permit ip source 170.15.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[Sysname-acl-adv-3100] quit
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 sa-policy export acl 3100
peer peer-address sa-request-policy [ acl acl-number ]
undo peer peer-address sa-request-policy
View
Default Level
2: System level
acl-number: Basic ACL number, in the range of 2000 to 2999. If you provide this argument, the SA requests of only the multicast groups that match the ACL will be accepted and other SA requests will be ignored; if you do not provide this argument, all SA requests will be ignored.
Use the peer sa-request-policy command to configure a filtering rule for SA request messages.
Use the undo peer sa-request-policy command to remove the configured SA request filtering rule.
Be default, SA request messages are not filtered.
# Configure an SA request filtering rule in the public instance so that SA messages from the MSDP peer 175.58.6.5 will be accepted only if the multicast group address in the SA messages is in the range of 225.1.1.0/24.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 225.1.1.0 0.0.0.255
[Sysname-acl-basic-2001] quit
[Sysname] msdp
[Sysname-msdp] peer 175.58.6.5 sa-request-policy acl 2001
reset msdp peer
reset msdp [ all-instance | vpn-instance vpn-instance-name ] peer [ peer-address ]
View
Default Level
2: System level
peer-address: Specifies an MSDP peer by its address. If you do not provide this argument, the TCP connections with all MSDP peers will be reset.
Use the reset msdp peer command to reset the TCP connection with the specified MSDP peer or the TCP connections with all MSDP peers and clear all the statistics information of the MSDP peer(s).
# Reset the TCP connection in the public instance with the MSDP peer 125.10.7.6 and clear all the statistics information of this MSDP peer.
<Sysname> reset msdp peer 125.10.7.6
reset msdp sa-cache
reset msdp [ all-instance | vpn-instance vpn-instance-name ] sa-cache [ group-address ]
View
Default Level
2: System level
group-address: Specifies a multicast group, in the range of 224.0.1.0 to 239.255.255.255. If you do not provide this argument, the command will clear the cached (S, G) entries for all multicast groups from the SA cache.
Use the reset msdp sa-cache command to clear (S, G) entries from the SA cache.
Note that if neither all-instance nor vpn-instance is specified, this command will clear the information on the public instance.
Related commands: cache-sa-enable, display msdp sa-cache.
# Clear the (S, G) entries for multicast group 225.5.4.3 from the SA cache of the public instance.
<Sysname> reset msdp sa-cache 225.5.4.3
reset msdp statistics
reset msdp [ all-instance | vpn-instance vpn-instance-name ] statistics [ peer-address ]
View
Default Level
2: System level
peer-address: Address of the MSDP peer of which the statistics information is to be cleared. If you do not provide this argument, the command will clear the statistics information of all MSDP peers.
Use the reset msdp statistics command to clear the statistics information of the specified MSDP peer or all MSDP peers without resetting the MSDP peer(s).
# Clear the statistics information of the MSDP peer 125.10.7.6 in the public instance.
<Sysname> reset msdp statistics 125.10.7.6
shutdown (MSDP View)
shutdown peer-address
undo shutdown peer-address
View
Default Level
2: System level
Use the shutdown command to deactivate manually the connection with the specified MSDP peer.
Use the undo shutdown command to reactivate the connection with the specified MSDP peer.
By default, the connections with all MSDP peers are active.
# Deactivate the connection with the MSDP peer 125.10.7.6 in the public instance.
[Sysname] msdp
[Sysname-msdp] shutdown 125.10.7.6
static-rpf-peer
static-rpf-peer peer-address [ rp-policy ip-prefix-name ]
undo static-rpf-peer peer-address
View
Default Level
2: System level
rp-policy ip-prefix-name: Specifies a filtering policy based on the RP address in SA messages, where ip-prefix-name is the filtering policy name, a case sensitive string of 1 to 19 characters. A policy name must not contain any space.
Use the static-rpf-peer command to configure a static RPF peer.
Use the undo static-rpf-peer command to remove a static RPF peer.
No static RPF peer is configured by default.
When you configure multiple static RPF peers, observe the follow rules:
1) If you use the rp-policy keyword for all the static RPF peers, all the static RPF peers take effect concurrently. SA messages will be filtered as per the configured prefix list and only those SA messages whose RP addresses pass the filtering will be accepted. If multiple static RPF peers use the same filtering policy at the same time, when a peer receives an SA message, it will forward the SA message to the other peers.
2) If you use the rp-policy keyword for none of the static RPF peers, according to the configuration sequence, only the first static RPF peer whose connection is in the UP state will be activated, and all SA messages from this peer will be accepted while the SA messages from other static RPF peers will be discarded. When this active static RPF peer fails (for example, when the configuration is removed or when the connection is torn down), still the first RPF peer whose connection is in UP state will be selected as the activated RPF peer according to the configuration sequence.
Related commands: display msdp peer-status, ip prefix-list.
[Sysname] ip ip-prefix list1 permit 130.10.0.0 16 great-equal 16 less-equal 32
[Sysname] msdp
[Sysname-msdp] peer 130.10.7.6 connect-interface vlan-interface 100
[Sysname-msdp] static-rpf-peer 130.10.7.6 rp-policy list1
timer retry
timer retry interval
undo timer retry
View
Default Level
2: System level
interval: Interval between MSDP peer connection retries, in seconds. The effective range is 1 to 60.
Use the timer retry command to configure the interval between MSDP peer connection retries.
Use the undo timer retry command to restore the default setting.
By default, the interval between MSDP peer connection retries is 30 seconds.
# Set the MSDP peer connection retry interval to 60 seconds in the public instance.
[Sysname] msdp
[Sysname-msdp] timer retry 60
