- 04-IP Multicast Volume
- 00-IP Multicast Volume Organization
- 01-Multicast Routing and Forwarding Commands
- 02-IGMP Commands
- 03-PIM Commands
- 04-MSDP Commands
- 05-MBGP Commands
- 06-Multicast VPN Commands
- 07-IGMP Snooping Commands
- 08-Multicast VLAN Commands
- 09-IPv6 Multicast Routing and Forwarding Commands
- 10-MLD Commands
- 11-IPv6 PIM Commands
- 12-IPv6 MBGP Commands
- 13-MLD Snooping Commands
- 14-IPv6 Multicast VLAN Commands
| 06-Multicast VPN Commands | 26.73 KB |
1 Multicast VPN Configuration Commands
display multicast-domain vpn-instance share-group
display multicast-domain vpn-instance vpn-instance-name share-group
View
Default Level
1: Monitor level
vpn-instance-name: VPN instance name, a case sensitive string of up to 31 characters. A VPN instance name must not contain any space.
Use the display multicast-domain vpn-instance share-group command to view the share-group information of the specified VPN instance in the MD.
# View the share-group information of VPN instance mvpn in the MD.
<Sysname> display multicast-domain vpn-instance mvpn share-group
MD local share-group information for VPN-Instance: mvpn
Share-group: 225.2.2.2
MTunnel address: 1.1.1.1
Table 1-1 display multicast-domain vpn-instance share-group command output description
MD local share-group information for VPN-Instance: mvpn |
Share-group information of VPN instance mvpn |
Share-group |
Share-group address |
MTunnel address |
MTI address associated with the share-group address |
multicast-domain share-group
multicast-domain share-group group-address binding mtunnel mtunnel-number
undo multicast-domain share-group
View
VPN instance view
Default Level
2: System level
group-address: Multicast group address, in the range of 224.0.1.0 to 239.255.255.255.
mtunnel-number: Number of the MTI interface to be created, in the range of 0 to 127.
Use the multicast-domain share-group command to configure a share-group address and associate an MTI with the current VPN instance.
Use the undo multicast-domain share-group command to restore the system default.
By default, no share-group address is configured and no MTI is associated with a VPN instance.
Note that:
l Do not specify a multicast group address in the public network SSM group range as a share-group address; otherwise a share-MDT cannot be established.
l This command must not be used repeatedly in the same VPN instance view. To configure a new group address and MTI for a VPN instance, you must remove the existing configuration.
l IP multicast routing must be enabled in the VPN instance before this command can take effect.
Related commands: multicast routing-enable in Multicast Routing and Forwarding Commands in the IP Multicast Volume.
# Specify 224.1.1.1 as the share-group address in VPN instance mvpn and associate MTI 0 with the VPN instance.
[Sysname] ip vpn-instance mvpn
[Sysname-vpn-instance-mvpn] multicast-domain share-group 224.1.1.1 binding mtunnel 0
