- 04-IP Multicast Volume
- 00-IP Multicast Volume Organization
- 01-Multicast Routing and Forwarding Commands
- 02-IGMP Commands
- 03-PIM Commands
- 04-MSDP Commands
- 05-MBGP Commands
- 06-Multicast VPN Commands
- 07-IGMP Snooping Commands
- 08-Multicast VLAN Commands
- 09-IPv6 Multicast Routing and Forwarding Commands
- 10-MLD Commands
- 11-IPv6 PIM Commands
- 12-IPv6 MBGP Commands
- 13-MLD Snooping Commands
- 14-IPv6 Multicast VLAN Commands
| 02-IGMP Commands | 155.27 KB |
display igmp ssm-mapping group
igmp last-member-query-interval
igmp timer other-querier-present
last-member-query-interval (IGMP view)
require-router-alert (IGMP view)
startup-query-count (IGMP view)
startup-query-interval (IGMP view)
timer other-querier-present (IGMP view)
The term "router" in this document refers to a router in a generic sense or a Layer 3 switch running an IP routing protocol.
IGMP Configuration Commands
display igmp group
display igmp [ all-instance | vpn-instance vpn-instance-name ] group [ group-address | interface interface-type interface-number ] [ static | verbose ]
View
Default Level
1: Monitor level
all-instance: Specifies all nstances.
vpn-instance vpn-instance-name: Specifies a VPN instance. A VPN instance name is a case sensitive string of up to 31 characters and must not contain any space.
group-address: Multicast group address, in the range of 224.0.1.0 to 239.255.255.255.
interface interface-type interface-number: Displays the IGMP multicast group information about a particular interface.
static: Displays the information of statically joined IGMP multicast groups.
verbose: Displays the detailed information of IGMP multicast groups.
Use the display igmp group command to view IGMP multicast group information.
Note that:
l If neither all-instance nor vpn-instance is specified, this command will display the information on the public instance.
l If you do not specify group-address, this command will display the IGMP information of all the multicast groups.
l If you do not specify interface-type interface-number, this command will display the IGMP multicast group information on all the interfaces.
l If you do not specify the static keyword, this command will display the detailed information about the dynamically joined IGMP multicast groups.
# Display the information about dynamically joined IGMP multicast groups on all interfaces in the public instance.
<Sysname> display igmp group
Total 3 IGMP Group(s).
Interface group report information of VPN-Instance: public net
Vlan-interface1(20.20.20.20):
Total 3 IGMP Groups reported
Group Address Last Reporter Uptime Expires
225.1.1.1 20.20.20.20 00:02:04 00:01:15
225.1.1.3 20.20.20.20 00:02:04 00:01:15
225.1.1.2 20.20.20.20 00:02:04 00:01:17
# Display the detailed information of multicast group 225.1.1.1 in the public instance.
<Sysname> display igmp group 225.1.1.1 verbose
Vlan-interface1(10.10.1.20):
Total 1 IGMP Groups reported
Group: 225.1.1.1
Uptime: 00:00:34
Expires: 00:00:40
Last reporter: 10.10.1.10
Last-member-query-counter: 0
Last-member-query-timer-expiry: off
Version1-host-present-timer-expiry: off
Table 1-1 display igmp group command output description
Interface group report information of VPN-Instance: public net |
IGMP multicast group information on a public network interface |
Total 1 IGMP Groups reported |
One IGMP multicast group was reported. |
Group |
Multicast group address |
Uptime |
Length of time since the multicast group was reported |
Expires |
Remaining time of the multicast group, where “off” means that the multicast group never times out |
Last reporter |
Address of the last host that reported its membership for this multicast group |
Last-member-query-counter |
Number of group-specific queries sent |
Last-member-query-timer-expiry |
Remaining time of the last member query timer, where “off” means that the timer never expires |
Version1-host-present-timer-expiry |
Remaining time of the IGMPv1 host present timer, where “off” means that the timer never expires |
display igmp group port-info
display igmp group port-info [ vlan vlan-id ] [ slot slot-number ] [ verbose ]
View
Default Level
1: Monitor level
vlan-id: VLAN ID, in the range of 1 to 4094. If you do not specify a VLAN, this command will display the Layer 2 port information of IGMP multicast groups in all VLANs.
slot slot-number: Displays the Layer 2 port information about IGMP multicast groups on the specified card. If you do not specify a slot number, this command will display the Layer 2 port information about IGMP multicast groups on the SRPU.
verbose: Displays the detailed information about Layer 2 ports of IGMP multicast groups.
Use the display igmp group port-info command to view Layer 2 port information of IGMP multicast groups.
# View detailed Layer 2 ports information of IGMP multicast groups.
<Sysname> display igmp group port-info verbose
Total 1 IP Group(s).
Total 1 IP Source(s).
Total 1 MAC Group(s).
Port flags: D-Dynamic port, S-Static port, C-Copy port
Subvlan flags: R-Real VLAN, C-Copy VLAN
Vlan(id):2.
Router port unit board: Mask(0x8 3)
Router port(s):total 1 port.
GE2/0/1 (D)
IP group(s):the following ip group(s) match to one mac group.
IP group address:224.1.1.1
(1.1.1.1, 224.1.1.1):
Attribute: Host Port
Host port unit board: Mask(0x8 3)
Host port(s):total 1 port.
GE2/0/2 (D)
MAC group(s):
MAC group address:0100-5e01-0101
GE2/0/2
Table 1-2 display igmp group port-info command output description
Total 1 IP Group(s). |
Total number of IP multicast groups |
Total 1 IP Source(s). |
Total number of IP multicast sources |
Total 1 MAC Group(s). |
Total number of MAC multicast groups |
Port flags: D-Dynamic port, S-Static port, C-Copy port |
Port flags: D for a dynamic port, S for a static port, and C for a port copied from a (*, G) entry to an (S, G) entry |
Subvlan flags: R-Real VLAN, C-Copy VLAN |
Sub-VLAN flags: R for a real egress sub-VLAN under the current entry, and C for a sub-VLAN copied from a (*, G) entry to an (S, G) entry |
Router port(s) |
Number of router ports |
( 00:01:30 ) |
Remaining time of dynamic member port or router port aging timer. To get this time value of a non-aggregation port on a board other than the SRPU, you must specify the number of the slot where the corresponding board resides by using slot slot-number. This is not required for an aggregation port. |
IP group address |
Address of the IP multicast group |
MAC group address |
Address of the MAC multicast group |
Attribute |
Attribute of the IP multicast group |
Host port(s) |
Number of member ports |
display igmp interface
display igmp [ all-instance | vpn-instance vpn-instance-name ] interface [ interface-type interface-number ] [ verbose ]
View
Default Level
1: Monitor level
all-instance: Specifies all instances.
interface-type interface-number: Specifies an interface to display the IGMP configuration and operation information about. If no interface is specified, this command will display the related information of all IGMP-enabled interfaces.
verbose: Displays the detailed IGMP configuration and operation information.
Use the display igmp interface command to view IGMP configuration and operation information of the specified interface or all IGMP-enabled interfaces.
Note that if neither all-instance nor vpn-instance is specified, this command will display the information on the public instance.
# View the IGMP configuration and operation information on VLAN-interface 1 in the public instance.
<Sysname> display igmp interface Vlan-interface 1 verbose
IGMP is enabled
Current IGMP version is 2
Value of query interval for IGMP(in seconds): 60
Value of other querier present interval for IGMP(in seconds): 125
Value of maximum query response time for IGMP(in seconds): 10
Value of last member query interval(in seconds): 1
Value of startup query interval(in seconds): 15
Value of startup query count: 2
General query timer expiry (hours:minutes:seconds): 00:00:54
Querier for IGMP: 10.10.1.20 (this router)
IGMP activity: 1 joins, 0 leaves
Multicast routing on this interface: enabled
Robustness: 2
Require-router-alert: disabled
Fast-leave: disabled
Ssm-mapping: disabled
Startup-query-timer-expiry: off
Other-querier-present-timer-expiry: off
Total 1 IGMP Group reported
Table 1-3 display igmp interface command output description
Vlan-interface1(10.10.1.20) |
Interface name (IP address) |
Current IGMP version |
Version of IGMP currently running on the interface |
Value of query interval for IGMP(in seconds) |
IGMP query interval, in seconds |
Value of other querier present interval for IGMP(in seconds) |
Other querier present interval, in seconds |
Value of maximum query response time for IGMP(in seconds) |
Maximum response time for IGMP general queries, in seconds |
Value of last member query interval(in seconds) |
IGMP last member query interval, in seconds |
Value of startup query interval(in seconds) |
IGMP startup query interval, in seconds |
Value of startup query count |
Number of IGMP general queries the device sends on startup |
General query timer expiry |
Remaining time of the IGMP general query timer, where “off” means that the timer never expires |
Querier for IGMP |
IP address of the IGMP querier |
IGMP activity |
Statistics of IGMP activities (joins and leaves) |
Robustness |
Robustness variable of the IGMP querier |
Require-router-alert |
Dropping IGMP messages without Router-Alert (enabled/disabled) |
Fast-leave |
Fast leave processing status (enabled/disabled) |
Ssm-mapping |
IGMP SSM mapping status (enabled/disabled) |
Startup-query-timer-expiry |
Remaining time of the startup query timer, where “off” means that the timer never expires |
Other-querier-present-timer-expiry |
Remaining time of the other querier present timer, where “off” means that the timer never expires |
Total 1 IGMP Group reported |
Total number of reported groups on the interface |
display igmp routing-table
display igmp [ all-instance | vpn-instance vpn-instance-name ] routing-table [ source-address [ mask { mask | mask-length } ] | group-address [ mask { mask | mask-length } ] ] *
View
Default Level
1: Monitor level
source-address: Multicast source address.
mask: Subnet mask of the multicast group/source address, 255.255.255.255 by default.
mask-length: Subnet mask length of the multicast group/source address. For a multicast source address, this argument has an effective value range of 0 to 32; for a multicast group address, this argument has an effective value range of 4 to 32. The system default is 32 in both cases.
Use the display igmp routing-table command to view the IGMP routing table information.
# View IGMP routing table information in the public instance.
<Sysname> display igmp routing-table
Routing table of VPN-Instance: public net
Total 2 entries
00001. (*, 225.1.1.1)
List of 1 downstream interface
Vlan-interface1 (20.1.1.1),
Protocol: STATIC
00002. (*, 239.255.255.250)
Vlan-interface2 (40.20.20.20),
Protocol: IGMP
Table 1-4 display igmp routing-table command output description
Routing table of VPN-Instance: public net |
Public network IGMP routing table |
00001 |
Sequence number of this (*, G) entry |
(*, 225.1.1.1) |
A (*, G) entry of the IGMP routing table |
List of 1 downstream interface |
Downstream interface list, namely the interfaces to which multicast data for this group will be forwarded |
Protocol |
Protocol type |
display igmp [ all-instance | vpn-instance vpn-instance-name ] ssm-mapping group-address
View
Default Level
1: Monitor level
group-address: Specifies a multicast group by its IP address, in the range of 224.0.1.0 to 239.255.255.255.
Use the display igmp ssm-mapping command to view the configured IGMP SSM mappings for the specified multicast group.
Related commands: ssm-mapping.
# View the IGMP SSM mappings for multicast group 232.1.1.1 in the public instance.
<Sysname> display igmp ssm-mapping 232.1.1.1
Group: 232.1.1.1
Source list:
1.2.3.4
5.5.5.5
10.1.1.1
100.1.1.10
Table 1-5 display igmp ssm-mapping command output description
Public instance |
Group |
Source list |
List of multicast source addresses |
display igmp [ all-instance | vpn-instance vpn-instance-name ] ssm-mapping group [ group-address | interface interface-type interface-number ] [ verbose ]
View
Default Level
1: Monitor level
verbose: Displays the detailed multicast group information created based on the configured IGMP SSM mappings.
Use the display igmp ssm-mapping group command to view the multicast group information created based on the configured IGMP SSM mappings.
Note that:
l If you do not specify a multicast group, this command will display the information of all multicast groups created based on the configured IGMP SSM mappings.
l If you do not specify an interface, this command will display the multicast group information created based on the configured IGMP SSM mappings on all the interfaces.
# View the detailed information of multicast group 232.1.1.1 created based on the configured IGMP SSM mappings in the public instance.
<Sysname> display igmp ssm-mapping group 232.1.1.1 verbose
Vlan-interface1 (10.10.10.10):
Total 1 IGMP SSM-mapping Group reported
Group: 232.1.1.1
Uptime: 00:00:31
Expires: off
Last reporter: 1.1.1.1
Source list(Total 1 source):
Source: 1.1.1.1
Uptime: 00:00:31
Expires: 00:01:39
Table 1-6 display igmp ssm-mapping group command output description
Multicast group information created based on IGMP SSM mappings on a public network interface |
Total 1 IGMP SSM-mapping Group reported |
One IGMP SSM mapping multicast group was reported. |
Group |
Uptime |
Expires |
Last reporter |
Source list(Total 1 source) |
Multicast source list (one multicast source) |
Source |
Multicast source address |
igmp
igmp [ vpn-instance vpn-instance-name ]
undo igmp [ vpn-instance vpn-instance-name ]
View
Default Level
2: System level
Use the igmp command to enter public instance IGMP view or VPN instance IGMP view .
Use the undo igmp command to remove configurations performed in public instance IGMP view or VPN instance IGMP view.
Note that:
l If you do not specify vpn-instance, this configuration will take effect only on the public instance.
l IP multicast must be enabled in the corresponding instance before this command can take effect
Related commands: igmp enable; multicast routing-enable in Multicast Routing and Forwarding Commands in the IP Multicast Volume.
# Enable IP multicast routing in the public instance and enter public instance IGMP view.
[Sysname] multicast routing-enable
[Sysname] igmp
[Sysname-igmp]
# Enable IP multicast routing in VPN instance mvpn and enter IGMP view for VPN instance mvpn.
[Sysname] ip vpn-instance mvpn
[Sysname-vpn-instance-mvpn] route-distinguisher 100:1
[Sysname-vpn-instance-mvpn] multicast routing-enable
[Sysname-vpn-instance-mvpn] quit
[Sysname] igmp vpn-instance mvpn
[Sysname-igmp-mvpn]
igmp enable
undo igmp enable
View
Interface view
Default Level
2: System level
None
Use the igmp enable command to enable IGMP on the current interface.
Use the undo igmp enable command to disable IGMP on the current interface.
By default, IGMP is disabled on all interfaces.
Note that:
l IP multicast must be enabled in the corresponding instance before this command can take effect.
l IGMP must be enabled on an interface before any other IGMP feature configured on the interface can take effect.
Related commands: igmp; multicast routing-table in Multicast Routing and Forwarding Commands in the IP Multicast Volume.
# Enable IP multicast routing, and then enable IGMP on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp enable
igmp group-policy
igmp group-policy acl-number [ version-number ]
undo igmp group-policy
View
Interface view
Default Level
2: System level
acl-number: Basic or advanced ACL number, in the range of 2000 to 3999. The source address or address range specified in the advanced ACL rule is used to match the multicast source address(es) specified in IGMPv3 reports, rather than the source address in the IP packets. The system assumes that an IGMPv1 or IGMPv2 report or an IGMPv3 IS_EX and TO_EX report that does not carry a multicast source address carries a multicast source address of 0.0.0.0..
version-number: IGMP version, in the range of 1 to 3. If you do not specify an IGMP version, the configured group filter will apply to IGMP reports of all versions.
Use the igmp group-policy command to configure a multicast group filter on the current interface to control joins to specific multicast groups.
Use the undo igmp group-policy command to remove the configured multicast group filter.
By default, no multicast group filter is configured, namely a host can join any valid multicast group.
# Configure an ACL rule so that hosts on the subnet attached to VLAN-interface 1 can join multicast group 225.1.1.1 only.
[Sysname] acl number 2005
[Sysname-acl-basic-2005] rule permit source 225.1.1.1 0
[Sysname-acl-basic-2005] quit
[Sysname] interface Vlan-interface 1
[Sysname-Vlan-interface1] igmp group-policy 2005
igmp last-member-query-interval interval
undo igmp last-member-query-interval
View
Interface view
Default Level
2: System level
interval: IGMP last member query interval in seconds, with an effective range of 1 to 5.
Use the igmp last-member-query-interval command to configure the last member query interval, namely the length of time the device waits between sending IGMP group-specific queries, on the current interface.
Use the undo igmp last-member-query-interval command to restore the system default.
By default, the IGMP last member query interval is 1 second.
Related commands: last-member-query-interval, igmp robust-count, display igmp interface.
# Set the IGMP last member query interval to 3 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp last-member-query-interval 3
igmp max-response-time
igmp max-response-time interval
undo igmp max-response-time
View
Interface view
Default Level
2: System level
interval: Maximum response time in seconds for IGMP general queries, with an effective range of 1 to 25.
Use the igmp max-response-time command to configure the maximum response time for IGMP general queries on the current interface.
Use the undo igmp max-response-time command to restore the system default.
By default, the maximum response time for IGMP general queries is 10 seconds.
Related commands: max-response-time, igmp timer other-querier-present, display igmp interface.
# Set the maximum response time for IGMP general queries to 8 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp max-response-time 8
igmp require-router-alert
undo igmp require-router-alert
View
Interface view
Default Level
2: System level
None
Use the igmp require-router-alert command to configure the interface to discard IGMP messages that do not carry the Router-Alert option.
Use the undo igmp require-router-alert command to restore the default configuration.
By default, the device does not check the Router-Alert option, namely it passes all the IGMP messages it receives to the upper layer protocol for processing.
Related commands: require-router-alert, igmp send-router-alert.
# Configure VLAN-interface 100 to discard IGMP messages that do not carry the Router-Alert option.
[Sysname-Vlan-interface100] igmp require-router-alert
igmp robust-count
igmp robust-count robust-value
undo igmp robust-count
View
Interface view
Default Level
2: System level
robust-value: IGMP querier robustness variable, with an effective range of 2 to 5. The IGMP robustness variable determines the default number of general queries the IGMP querier sends on startup and the number of IGMP group-specific queries the IGMP querier sends upon receiving an IGMP leave message.
Use the igmp robust-count command to configure the IGMP querier robustness variable on the current interface.
Use the undo igmp robust-count command to restore the system default.
By default, the IGMP querier robustness variable is 2.
Related commands: robust-count, igmp timer query, igmp last-member-query-interval, igmp timer other-querier-present, display igmp interface.
# Set the IGMP querier robustness variable to 3 on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp robust-count 3
undo igmp send-router-alert
View
Interface view
Default Level
2: System level
None
Use the igmp send-router-alert command on the current interface to enable insertion of the Router-Alert option in IGMP messages to be sent.
Use the undo igmp send-router-alert command on the current interface to disable insertion of the Router-Alert option in IGMP messages to be sent.
By default, IGMP messages are sent with the Router-Alert option.
Related commands: send-router-alert, igmp require-router-alert.
# Disable insertion of the Router-Alert option into IGMP messages that leave VLAN-interface 100.
[Sysname-Vlan-interface100] undo igmp send-router-alert
igmp ssm-mapping enable
undo igmp ssm-mapping enable
View
Interface view
Default Level
2: System level
None
Use the igmp ssm-mapping enable command to enable the IGMP SSM mapping feature on the current interface.
Use the undo igmp ssm-mapping enable command to disable the IGMP SSM mapping feature on the current interface.
By default, the IGMP SSM mapping feature is disabled on all interfaces.
# Enable the IGMP SSM mapping feature on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp ssm-mapping enable
igmp startup-query-count
igmp startup-query-count value
undo igmp startup-query-count
View
Interface view
Default Level
2: System level
value: Startup query count, namely, the number of queries the IGMP querier sends on startup, with an effective range of 2 to 5.
Use the igmp startup-query-count command to configure the startup query count on the current interface.
Use the undo igmp startup-query-count command to restore the system default.
By default, the startup query count is set to the IGMP querier robustness variable.
By default, the IGMP querier robustness variable is 2, so the startup query count is also 2.
Related commands: startup-query-count, igmp robust-count.
# Set the startup query count to 3 on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp startup-query-count 3
igmp startup-query-interval
igmp startup-query-interval interval
undo igmp startup-query-interval
View
Interface view
Default Level
2: System level
interval: Startup query interval in seconds, namely, the interval between general queries the IGMP querier sends on startup, with an effective range of 1 to 18000.
Use the igmp startup-query-interval command to configure the startup query interval on the current interface.
Use the undo igmp startup-query-interval command to restore the system default.
By default, the startup query interval is 1/4 of the IGMP query interval.
By default, the IGMP query interval is 60 seconds, so the startup query interval = 60 / 4 = 15 (seconds).
Related commands: startup-query-interval, igmp timer query.
# Set the startup query interval to 5 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp startup-query-interval 5
igmp static-group
igmp static-group group-address [ source source-address ]
undo igmp static-group { all | group-address [ source source-address ] }
View
Interface view
Default Level
2: System level
all: Specifies to remove all static multicast groups that the current interface has joined.
Use the igmp static-group command to configure the current interface to be a statically connected member of the specified multicast group or multicast source and group.
Use the undo igmp static-group command to restore the system default.
By default, an interface is not a static member of any multicast group or multicast source and group.
If the specified multicast address is in the SSM multicast address range, you must specify a multicast source address at the same time; otherwise IGMP routing table entries cannot be established. There is no such a restriction if the specified multicast group address is not in the SSM multicast address range.
# Configure VLAN-interface 1 to be a statically connected member of multicast group 224.1.1.1.
[Sysname] interface Vlan-interface1
[Sysname-Vlan-interface1] igmp static-group 224.1.1.1
# Configure VLAN-interface 1 to be a statically connected member of multicast source and group (192.168.1.1, 232.1.1.1).
[Sysname-Vlan-interface1] igmp static-group 232.1.1.1 source 192.168.1.1
igmp timer other-querier-present interval
undo igmp timer other-querier-present
View
Interface view
Default Level
2: System level
interval: IGMP other querier present interval in seconds, in the range of 60 to 300.
Use the igmp timer other-querier-present command to configure the IGMP other querier present interval on the current interface.
Use the undo igmp timer other-querier-present command to restore the system default.
By default, the IGMP other querier present interval is [ IGMP query interval ] times [ IGMP querier robustness variable ] plus [ maximum response time for IGMP general queries ] divided by two.
By default, the three parameters in the above-mentioned formula are 60 (seconds), 2 and 10 (seconds) respectively, so the IGMP other querier present interval = 60 × 2 + 10 / 2 = 125 (seconds).
Related commands: timer other-querier-present, igmp timer query, igmp robust-count, igmp max-response-time, display igmp interface.
# Set the IGMP other querier present interval to 200 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp timer other-querier-present 200
igmp timer query
igmp timer query interval
undo igmp timer query
View
Interface view
Default Level
2: System level
interval: IGMP query interval in seconds, namely the interval between IGMP general queries, with an effective range of 1 to 18,000.
Use the igmp timer query command to configure the IGMP query interval on the current interface.
Use the undo igmp timer query command to restore the system default.
By default, the IGMP query interval is 60 seconds.
Related commands: timer query, igmp timer other-querier-present, display igmp interface.
# Set the IGMP query interval to 125 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp timer query 125
igmp version
igmp version version-number
undo igmp version
View
Interface view
Default Level
2: System level
Use the igmp version command to configure the IGMP version on the current interface.
Use the undo igmp version command to restore the default IGMP version.
The default IGMP version is version 2.
Related commands: version.
# Set the IGMP version to IGMPv1 on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp version 1
undo last-member-query-interval
View
Public instance IGMP view, VPN instance IGMP view
Default Level
2: System level
interval: Last-member query interval in seconds, with an effective range of 1 to 5.
Use the last-member-query-interval command to configure the global IGMP last-member query interval.
Use the undo last-member-query-interval command to restore the system default.
By default, the IGMP last-member query interval is 1 second.
Related commands: igmp last-member-query-interval, robust-count, display igmp interface.
# Set the global IGMP last-member interval to 3 seconds in the public instance.
[Sysname] igmp
[Sysname-igmp] last-member-query-interval 3
max-response-time (IGMP view)
undo max-response-time
View
Default Level
2: System level
interval: Maximum response time for IGMP general queries in seconds, with an effective range of 1 to 25.
Use the max-response-time command to configure the maximum response time for IGMP general queries globally.
Use the undo max-response-time command to restore the system default.
Related commands: igmp max-response-time, timer other-querier-present, display igmp interface.
# Set the maximum response time for IGMP general queries to 8 seconds globally in the public instance.
[Sysname] igmp
[Sysname-igmp] max-response-time 8
undo require-router-alert
View
Default Level
2: System level
None
Use the require-router-alert command to configure globally the router to discard IGMP messages that do not carry the Router-Alert option.
Use the undo require-router-alert command to restore the system default.
By default, the device does not check the Router-Alert option, namely it handles all the IGMP messages it received to the upper layer protocol for processing.
Related commands: igmp require-router-alert, send-router-alert.
# Globally configure the router to discard IGMP messages that do not carry the Router-Alert option in the public instance.
[Sysname] igmp
[Sysname-igmp] require-router-alert
reset igmp group
reset igmp [ all-instance | vpn-instance vpn-instance-name ] group { all | interface interface-type interface-number { all | group-address [ mask { mask | mask-length } ] [ source-address [ mask { mask | mask-length } ] ] } }
View
Default Level
2: System level
all: The first all specifies to clear IGMP multicast group information on all interfaces, while the second all specifies to clear the information of all IGMP multicast groups.
interface interface-type interface-number: Clears IGMP multicast information on the specified interface.
group-address: Multicast group address, in the range of 224.0.0.0 to 239.255.255.255.
mask-length: Subnet mask length of the multicast group/source address. For a multicast group address, this argument has an effective value range of 4 to 32; for a multicast source address, this argument has an effective value range of 0 to 32. The system default is 32 in both cases.
Use the reset igmp group command to clear IGMP multicast group information.
Note that:
l This command cannot clear IGMP multicast group information of static joins.
Related commands: display igmp group.
# Clear all IGMP multicast group information on all interfaces.
<Sysname> reset igmp group all
# Clear all IGMP multicast group information on VLAN-interface 100.
<Sysname> reset igmp group interface vlan-interface 100 all
# Clear IGMP multicast group information about multicast group 225.0.0.1 on VLAN-interface 100.
<Sysname> reset igmp group interface vlan-interface 100 225.0.0.1
reset igmp group port-info
reset igmp group port-info { all | group-address } [ vlan vlan-id ]
View
Default Level
2: System level
all: Clears Layer 2 port information of all the IGMP multicast groups.
group-address: Clears Layer 2 port information of the specified IGMP multicast group. The effective range of group-address is 224.0.1.0 to 239.255.255.255.
vlan-id: Clears Layer 2 port information of IGMP multicast groups in the specified VLAN. The effective range of vlan-id is 1 to 4094.
Use the reset igmp group port-info command to clear Layer 2 port information of IGMP multicast groups.
Note that:
l Layer 2 ports for IGMP multicast groups include member ports and router ports.
l This command cannot clear Layer 2 port information about IGMP multicast groups of static joins.
Related commands: display igmp group port-info.
# Clear Layer 2 port information of all IGMP multicast groups in all VLANs.
<Sysname> reset igmp group port-info all
# Clear Layer 2 port information of all IGMP multicast groups in VLAN 100.
<Sysname> reset igmp group port-info all vlan 100
# Clear Layer 2 port information about multicast group 225.0.0.1 in VLAN 100.
<Sysname> reset igmp group port-info 225.0.0.1 vlan 100
reset igmp ssm-mapping group
reset igmp [ all-instance | vpn-instance vpn-instance-name ] ssm-mapping group { all | interface interface-type interface-number { all | group-address [ mask { mask | mask-length } ] [ source-address [ mask { mask | mask-length } ] ] } }
View
Default Level
2: System level
all: The first all specifies to clear multicast group information created based on the configured IGMP SSM mappings on all interfaces, while the second all specifies to clear all multicast group information created based on the configured IGMP SSM mappings.
group-address: Specifies a multicast group by its IP address, in the range of 224.0.0.0 to 239.255.255.255.
source-address: Specifies a multicast source by its IP address.
mask-length: Subnet mask length of the multicast group/source address. For a multicast group address, this argument has an effective value range of 4 to 32; for a multicast source address, this argument has an effective value range of 0 to 32. For both cases, the default value is 32.
Use the reset igmp ssm-mapping group command to clear multicast group information created based on the configured IGMP SSM mappings.
Note that if neither all-instance nor vpn-instance is specified, this command will clear the information on the public instance.
Related commands: display igmp ssm-mapping group.
# Clear all multicast group information created based on the configured IGMP SSM mappings on all interfaces in the public instance.
<Sysname> reset igmp ssm-mapping group all
robust-count (IGMP view)
undo robust-count
View
Default Level
2: System level
Use the robust-count command to configure the IGMP querier robustness variable globally.
Use the undo robust-count command to restore the system default.
Related commands: igmp robust-count, timer query, last-member-query-interval, timer other-querier-present, display igmp interface.
# Set the IGMP querier robustness variable to 3 globally in the public instance.
[Sysname] igmp
[Sysname-igmp] robust-count 3
send-router-alert (IGMP view)
send-router-alert
undo send-router-alert
View
Default Level
2: System level
None
Use the send-router-alert command to globally enable insertion of the Router-Alert option into IGMP messages to be sent.
Use the undo send-router-alert command to globally disable insertion of the Router-Alert option into IGMP messages to be sent.
By default, an IGMP message carries the Router-Alert option.
Related commands: igmp send-router-alert, require-router-alert.
# Globally disable the insertion of the Router-Alert option in IGMP messages to be sent in the public instance.
[Sysname] igmp
[Sysname-igmp] undo send-router-alert
ssm-mapping (IGMP view)
ssm-mapping group-address { mask | mask-length } source-address
undo ssm-mapping { group-address { mask | mask-length } source-address | all }
View
Default Level
2: System level
mask: Subnet mask of the multicast group address.
mask-length: Subnet mask length of the multicast group address, in the range of 4 to 32.
all: Removes all IGMP SSM mappings.
Use the ssm-mapping command to configure an IGMP SSM mapping.
Use the undo ssm-mapping command to remove one or all IGMP SSM mappings.
By default, no IGMP SSM mappings are configured.
Related commands: igmp ssm-mapping enable, display igmp ssm-mapping.
# Configure an IGMP SSM mapping in the public instance for multicast groups in the range of 225.1.1.0/24 and multicast source 125.1.1.1.
[Sysname] igmp
[Sysname-igmp] ssm-mapping 225.1.1.0 24 125.1.1.1
undo startup-query-count
View
Default Level
2: System level
Use the startup-query-count command to configure the startup query count globally.
Use the undo startup-query-count command to restore the system default.
Related commands: igmp startup-query-count, robust-count.
# Set the startup query count to 3 globally in the public instance.
[Sysname] igmp
[Sysname-igmp] startup-query-count 3
undo startup-query-interval
View
Default Level
2: System level
Use the startup-query-interval command to configure the startup query interval globally.
Use the undo startup-query-interval command to restore the system default.
By default, the startup query interval is 1/4 of the “IGMP query interval”.
Related commands: igmp-startup-query-interval, timer query.
# Set the startup query interval to 5 seconds globally in the public instance.
[Sysname] igmp
[Sysname-igmp] startup-query-interval 5
undo timer other-querier-present
View
Default Level
2: System level
interval: IGMP other querier present interval, in the range of 60 to 300.
Use the timer other-querier-present command to configure the IGMP other querier present interval globally.
Use the undo timer other-querier-present command to restore the system default.
By default, the three parameters in the above-mentioned formula are 60 (seconds), 2 (times) and 10 (seconds) respectively, so the IGMP other querier present interval = 60 × 2 + 10 / 2 = 125 (seconds).
Related commands: igmp timer other-querier-present, timer query, robust-count, max-response-time, display igmp interface.
# Set the IGMP other querier present interval to 200 seconds globally in the public instance.
[Sysname] igmp
[Sysname-igmp] timer other-querier-present 200
timer query (IGMP view)
undo timer query
View
Default Level
2: System level
interval: IGMP query interval in seconds, namely interval between IGMP general queries, with an effective range of 1 to 18,000.
Use the timer query command to configure the IGMP query interval globally.
Use the undo timer query command to restore the default setting.
By default, IGMP query interval is 60 seconds.
Related commands: igmp timer query, timer other-querier-present, display igmp interface.
# Set the IGMP query interval to 125 seconds globally in the public instance.
[Sysname] igmp
[Sysname-igmp] timer query 125
version (IGMP view)
undo version
View
Default Level
2: System level
Use the version command to configure the IGMP version globally.
Use the undo version command to restore the system default.
Related commands: igmp version.
# Set the global IGMP version to IGMPv1 in the public instance.
[Sysname] igmp
[Sysname-igmp] version 1
