IP Multicast Volume Organization
Manual Version
20091105-C-1.03
Product Version
Release 6300 series
Organization
The IP Multicast Volume
is organized as follows:
Features
Multicast Routing and Forwarding
Multicast routing and forwarding refer to
some policies that filter RPF routing information for IP multicast support.
This document introduces the commands for Multicast Routing and Forwarding
configuration.
IGMP
Internet Group Management Protocol (IGMP)
is a protocol in the TCP/IP suite responsible for management of IP multicast
members. This document introduces the commands for IGMP configuration.
PIM
PIM leverages the unicast routing table
created by any unicast routing protocol to provide routing information for IP
multicast. This document introduces the commands for PIM configuration.
MSDP
Multicast source discovery protocol
(MSDP) describes interconnection mechanism of multiple PIM-SM domains. It is
used is to discover multicast source information in other PIM-SM domains.
This document introduces the commands for MSDP configuration.
MBGP
As a multicast extension
of MP-BGP, MBGP enables BGP to provide routing information for multicast
applications. This document introduces the
commands for MBGP configuration.
Multicast VPN
Multicast VPN is a technique that
implements multicast delivery in MPLS L3VPN networks. This document
introduces the commands for Multicast VPN configuration.
IGMP Snooping
Running at the data link layer, IGMP
Snooping is a multicast control mechanism on the Layer 2 Ethernet switch and
it is used for multicast group management and control. This document
introduces the commands for IGMP Snooping configuration.
Multicast VLAN
Multicast VLAN configuration.
IPv6 Multicast Routing and Forwarding
IPv6 multicast routing and forwarding
refer to some policies that filter RPF routing information for IPv6 multicast
support. This document introduces the commands for IPv6 Multicast Routing and
Forwarding configuration.
MLD
MLD is used by an IPv6 router or a
Ethernet Switch to discover the presence of multicast listeners on
directly-attached subnets. This document introduces the commands for MLD
configuration.
IPv6 PIM
IPv6 PIM discovers multicast source and
delivers information to the receivers. This document introduces the commands
for IPv6 PIM configuration.
IPv6 MBGP
As an IPv6 multicast extension of MP-BGP,
IPv6 MBGP enables BGP to provide routing information for IPv6 multicast
commands for IPv6 MBGP configuration.
MLD Snooping
Multicast Listener Discovery Snooping
(MLD Snooping) is an IPv6 multicast constraining mechanism that runs on Layer
2 devices to manage and control IPv6 multicast groups. This document
introduces the commands for MLD Snooping configuration.
IPv6 Multicast VLAN
IPv6 Multicast VLAN configuration.
