- 04-IP Multicast Volume
- 00-IP Multicast Volume Organization
- 01-Multicast Routing and Forwarding Commands
- 02-IGMP Commands
- 03-PIM Commands
- 04-MSDP Commands
- 05-MBGP Commands
- 06-Multicast VPN Commands
- 07-IGMP Snooping Commands
- 08-Multicast VLAN Commands
- 09-IPv6 Multicast Routing and Forwarding Commands
- 10-MLD Commands
- 11-IPv6 PIM Commands
- 12-IPv6 MBGP Commands
- 13-MLD Snooping Commands
- 14-IPv6 Multicast VLAN Commands
| 10-MLD Commands | 148.34 KB |
Table of Contents
last-listener-query-interval (MLD view)
mld last-listener-query-interval
mld timer other-querier-present
require-router-alert (MLD view)
startup-query-count (MLD view)
startup-query-interval (MLD view)
timer other-querier-present (MLD view)
The term “router” in this document refers to a router in a generic sense or a Layer 3 switch running MLD.
MLD Configuration Commands
display mld group
display mld group [ ipv6-group-address | interface interface-type interface-number ] [ static | verbose ]
View
Default Level
1: Monitor level
ipv6-group-address: MLD multicast group address, in the range of FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16, and FF0y::), where x and y represent any hexadecimal number ranging from 0 to F.
interface interface-type interface-number: Displays the information of MLD multicast groups on the specified interface.
static: Displays the information of statically joined MLD multicast groups.
verbose: Displays detailed information of MLD multicast groups.
Use the display mld group command to view information of MLD multicast groups.
Note that:
l If you do not specify an IPv6 mutlicast group address, this command will display the MLD information of all the multicast groups.
l If you do not specify interface-type interface-number, this command will display the MLD multicast group information on all the interfaces.
l If you do not specify the static keyword, the information of only dynamically joined MLD groups will be displayed.
# View the detailed information of dynamically joined MLD multicast groups on all interfaces.
<Sysname> display mld group verbose
Interface group report information
Vlan-interface1(FE80::101)
Total 1 MLD Groups reported
Group: FF03::101
Uptime: 00:01:46
Expires: 00:01:30
Last reporter: FE80::10
Last-listener-query-counter: 0
Last-listener-query-timer-expiry: off
Group mode: include
Version1-host-present-timer-expiry: off
Table 1-1 display mld group command output description
Interface group report information |
MLD multicast group information on the interface |
Total 1 MLD Groups reported |
One MLD multicast group was reported. |
Group |
IPv6 multicast group address |
Uptime |
Length of time since the IPV6 multicast group was joined |
Expires |
Remaining time of the IPv6 multicast group , where “off" means that the multicast group never times out |
Last reporter |
IPv6 address of the host that last reported membership for this group |
Last-listener-query-counter |
Number of MLD multicast-address-specific queries sent |
Last-listener-query-timer-expiry |
Remaining time of the MLD last listener query timer , where “off" means that the timer never times out |
Group mode |
Filtering mode of multicast sources |
Version1-host-present-timer-expiry |
Remaining time of the MLDv1 host present timer , where “off" means that the timer never times out |
display mld group port-info
display mld group port-info [ vlan vlan-id ] [ slot slot-number ] [ verbose ]
View
Default Level
1: Monitor level
vlan-id: VLAN ID, in the range of 1 to 4094. If you do not specify a VLAN, this command will display the Layer 2 port information of MLD multicast groups in all VLANs.
slot slot-number: Displays the Layer 2 port information about MLD multicast groups on the specified card. If you do not specify a slot number, this command will display the Layer 2 port information about MLD multicast groups on the main processing unit.
verbose: Displays the detailed information about Layer 2 ports of MLD multicast groups.
Use the display mld group port-info command to view Layer 2 port information of MLD multicast groups.
# View detailed Layer 2 port information of MLD multicast groups.
<Sysname> display mld group port-info verbose
Total 1 IP Group(s).
Total 1 IP Source(s).
Total 1 MAC Group(s).
Port flags: D-Dynamic port, S-Static port, C-Copy port
Subvlan flags: R-Real VLAN, C-Copy VLAN
Vlan(id):2.
Router port(s):total 1 port.
Vlan1 (D) ( 00:01:30 )
IP group(s):the following ip group(s) match to one mac group.
IP group address: FF03::101
(FE80::1, FF03::101):
Attribute: Host Port
Host port(s):total 1 port.
Vlan2 (D) ( 00:03:23 )
MAC group(s):
MAC group address:3333-0000-0101
Vlan2
Table 1-2 display mld group port-info command output description
Total 1 IP Group(s). |
Total number of IPv6 multicast groups |
Total 1 IP Source(s). |
Total number of IPv6 multicast sources |
Total 1 MAC Group(s). |
Total number of MAC multicast groups |
Port flags: D-Dynamic port, S-Static port, C-Copy port |
Port flag: D stands for dynamic port, S for static port, and C for port copied from a (*, G) entry to an (S, G) entry. |
Subvlan flags: R-Real VLAN, C-Copy VLAN |
Sub-VLAN flag: R stands for real egress sub-VLAN under the current entry, and C for sub-VLAN copied from a (*, G) entry to an (S, G) entry. |
Router port(s) |
Number of router ports |
( 00:01:30 ) |
Remaining time of dynamic member port or router port aging timer. On a distributed device, to get this time value of a non-aggregation port on a board other than the main processing unit, you must specify the number of the slot where the corresponding board resides by using slot slot-number. This is not required for an aggregation port. |
IP group address |
Address of an IPv6 multicast group |
MAC group address |
Address of a MAC multicast group |
Attribute |
Attribute of an IPv6 multicast group |
Host port(s) |
Number of member ports |
display mld interface
display mld interface [ interface-type interface-number ] [ verbose ]
View
Default Level
1: Monitor level
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command will display the information of all interfaces running MLD.
verbose: Displays detailed MLD configuration and operation information.
Use the display mld interface command to view MLD configuration and operation information on the specified interface or all MLD-enabled interfaces.
# View the detailed MLD configuration and operation information on Vlan-interface 1.
<Sysname> display mld interface vlan-interface 1 verbose
Vlan-interface1(FE80::200:AFF:FE01:101):
MLD is enabled
Current MLD version is 2
Value of query interval for MLD(in seconds): 125
Value of other querier present interval for MLD(in seconds): 255
Value of maximum query response time for MLD(in seconds): 10
Value of last listener query interval(in seconds): 1
Value of startup query interval(in seconds): 31
Value of startup query count: 2
General query timer expiry (hours:minutes:seconds): 00:00:23
Querier for MLD: FE80::200:AFF:FE01:101 (this router)
MLD activity: 1 joins, 0 leaves
Multicast ipv6 routing on this interface: enabled
Robustness: 2
Require-router-alert: disabled
Fast-leave: disabled
Ssm-mapping: disabled
Startup-query-timer-expiry: off
Other-querier-present-timer-expiry: off
Total 1 MLD Group reported
Table 1-3 display mld group port-info command output description
Ethernet1/1(FE80::200:AFF:FE01:101) |
Interface name (IPv6 link-local address) |
Current MLD version |
MLD version running on the interface |
MLD group policy |
MLD group policy |
Value of query interval for MLD (in seconds) |
MLD query interval, in seconds |
Value of other querier present interval for MLD (in seconds) |
MLD other querier present interval, in seconds |
Value of maximum query response time for MLD (in seconds) |
Maximum response delay for general query messages (in seconds) |
Value of last listener query interval (in seconds) |
MLD last listener query interval, in seconds |
Value of startup query interval(in seconds) |
MLD startup query interval, in seconds |
Value of startup query count |
Number of MLD general queries sent on startup |
General query timer expiry |
Remaining time of the MLD general query timer , where “off" means that the timer never times out |
Querier for MLD |
IPv6 link-local address of the MLD querier |
MLD activity |
MLD activity statistics (number of join and done messages) |
Robustness |
MLD querier robustness variable |
Require-router-alert |
Dropping MLD messages without Router-Alert (enabled/disabled) |
Fast-leave |
MLD fast leave processing status (enabled/disabled) |
Ssm-mapping |
MLD SSM mapping status (enabled/disabled) |
Startup-query-timer-expiry |
Remaining time of MLD startup query timer , where “off" means that the timer never times out |
Other-querier-present-timer-expiry |
Remaining time of MLD other querier present timer , where “off" means that the timer never times out |
Total 1 MLD Group reported |
Total number of MLD groups the interface has dynamically joined |
display mld routing-table
display mld routing-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] ] *
View
Default Level
1: Monitor level
ipv6-source-address: Specifies a multicast source by its IPv6 address.
ipv6-group-address: Specifies an IPv6 multicast group by its IPv6 address, in the form of FFxy::/16, where x and y represent any hexadecimal number ranging from 0 to F.
prefix-length: Prefix length of the multicast source or multicast group address. For a multicast source address, this argument has an effective value range of 0 to 128; for a multicast group address, it has an effective value range of 8 to 128. The system default is 128 in both cases.
Use the display mld routing-table command to view the information of the MLD routing table.
# View the information of the MLD routing table.
<Sysname> display mld routing-table
Routing table
Total 1 entry
00001. (*, FF1E::101)
List of 1 downstream interface
Vlan-interface1 (FE80::200:5EFF:FE71:3800),
Protocol: MLD
Table 1-4 display mld routing-table command output description
Routing table |
MLD routing table |
00001 |
Sequence number of this (*, G) entry |
(*, FF1E::101) |
An (*, G) entry in the MLD routing table |
List of 1 downstream interface |
List of downstream interfaces: namely the interfaces to which multicast data for this group will be forwarded |
Protocol |
Protocol type |
display mld ssm-mapping
display mld ssm-mapping ipv6-group-address
View
Default Level
1: Monitor level
ipv6-group-address: Specifies an IPv6 multicast group by its address, in the range of FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16, and FF0y::), where x and y represent any hexadecimal number ranging from 0 to F.
Use the display mld ssm-mapping command to view the configured MLD SSM mappings for the specified IPv6 multicast group.
Related commands: ssm-mapping.
# View the MLD SSM mappings for multicast group FF1E::101.
<Sysname> display mld ssm-mapping ff1e::101
Group: FF1E::101
Source list:
1::1
1::2
10::1
100::10
Table 1-5 display mld ssm-mapping command output description
Group |
Source list |
List of IPv6 multicast source addresses |
display mld ssm-mapping group
display mld ssm-mapping group [ ipv6-group-address | interface interface-type interface-number ] [ verbose ]
View
Default Level
1: Monitor level
ipv6-group-address: Specifies a multicast group by its IPv6 address, in the range of FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16, and FF0y::), where x and y represent any hexadecimal number ranging from 0 to F.
verbose: Displays the detailed multicast group information created based on the configured MLD SSM mappings.
Use the display mld ssm-mapping group command to view the multicast group information created based on the configured MLD SSM mappings.
Note that:
l If you do not specify an IPv6 multicast group, this command will display the information of all IPv6 multicast groups created based on the configured MLD SSM mappings.
l If you do not specify an interface, this command will display the multicast group information created based on the configured MLD SSM mappings on all interfaces.
# View the detailed information of IPv6 multicast group FF3E::101 created based on the configured MLD SSM mappings on all interfaces.
<Sysname> display mld ssm-mapping group ff3e::101 verbose
Vlan-interface1(FE80::101):
Total 1 MLD SSM-mapping Group reported
Group: FF3E::101
Uptime: 00:01:46
Expires: off
Group mode: include
Source list(Total 1 source):
Source: 30::1
Uptime: 00:01:46
Expires: 00:02:34
Table 1-6 display mld ssm-mapping group command output description
IPv6 multicast group information created based on MLD SSM mappings on the interface |
Total 1 MLD SSM-mapping Group reported |
One MLD SSM mapping multicast group was reported. |
Group |
Uptime |
Length of time since the IPv6 multicast group was reported |
Expires |
Remaining time of the IPv6 multicast group , where “off” means that the group never times out |
Last reporter |
Group mode |
IPv6 multicast sources filter mode |
Source list(Total 1 source) |
IPv6 multicast source list (one IPv6 multicast source) |
Source |
IPv6 multicast source address |
Remaining time of the MLD last listener query timer , where “off” means that the timer never expires |
undo last-listener-query-interval
View
MLD view
Default Level
2: System level
interval: MLD last listener query interval in seconds, namely the length of time the device waits between sending MLD multicast-address-specific queries. The effective range is 1 to 5.
Use the last-listener-query-interval command to configure the MLD last listener query interval globally.
Use the undo last-listener-query-interval command to restore the system default.
By default, the MLD last listener query interval is 1 second.
Related commands: mld last-listener-query-interval, robust-count, display mld interface.
# Set the MLD last listener query interval to 3 seconds globally.
[Sysname] mld
[Sysname-mld] last-listener-query-interval 3
max-response-time (MLD view)
max-response-time interval
undo max-response-time
View
MLD view
Default Level
2: System level
interval: Maximum response delay for MLD general query messages in seconds, in the range of 1 to 25.
Use the max-response-time command to configure the maximum response delay for MLD general queries globally.
Use the undo max-response-time command to restore the system default.
By default, the maximum response delay for MLD general queries is 10 seconds.
Related commands: mld max-response-time, timer other-querier-present, display mld interface.
# Set the maximum response delay for MLD general queries to 8 seconds globally.
[Sysname] mld
[Sysname-mld] max-response-time 8
mld
mld
undo mld
View
Default Level
2: System level
None
Use the mld command to enter MLD view.
Use the undo mld command to remove the configurations made in MLD view.
Note that this command can take effect only after IPv6 multicast routing is enabled on the device.
Related commands: mld enable; multicast ipv6 routing-enable in IPv6 Multicast Routing and Forwarding Commands in the IP Multicast Volume.
# Enable IPv6 multicast routing and enter MLD view.
[Sysname] multicast ipv6 routing-enable
[Sysname] mld
[Sysname-mld]
mld enable
undo mld enable
View
Interface view
Default Level
2: System level
None
Use the mld enable command to enable MLD on the current interface.
Use the undo mld enable command to disable MLD on the current interface.
By default, MLD is disabled on the current interface.
Note that:
l This command can take effect only after IPv6 multicast routing is enabled on the device.
l Other MLD configurations performed on the interface can take effect only after MLD is enabled on the interface.
Related commands: mld; multicast ipv6 routing-table in IPv6 Multicast Routing and Forwarding Commands in the IP Multicast Volume.
# Enable IPv6 multicast routing and enable MLD on VLAN-interface 100.
[Sysname-Vlan-interface100] mld enable
mld group-policy
mld group-policy acl6-number [ version-number ]
undo mld group-policy
View
Interface view
Default Level
2: System level
acl6-number: Number of a basic or advanced IPv6 ACL, in the range of 2000 to 3999. The source address or address range specified in the advanced IPv6 ACL rule is the IPv6 multicast source address(es) specified in MLDv2 reports, rather than the source address in the IPv6 packets. The system assumes that an MLDv1 report or an MLDv2 IS_EX or TO_EX report that does not carry an IPv6 multicast source address carries a IPv6 multicast source address of 0::0.
version-number: MLD version number, 1 or 2. If you do not specify an MLD version, the configured group filter will be effective for MLD reports of both version 1 and version 2.
Use the mld group-policy command to configure an IPv6 multicast group filter on the current interface to limit access to the IPv6 multicast group.
Use the undo mld group-policy command to remove the configured IPv6 multicast group filter.
By default, no IPv6 multicast group filter is configured by default, that is, a host can join any valid IPv6 multicast group.
# Configure an IPv6 ACL so that hosts on the subnet attached to Vlan-interface1 can join the IPv6 multicast group FF03::101 only.
[Sysname] acl ipv6 number 2005
[Sysname-acl6-basic-2005] rule permit source ff03::101 128
[Sysname-acl6-basic-2005] quit
[Sysname] interface Vlan-interface 1
[Sysname-Vlan-interface1] mld group-policy 2005
mld last-listener-query-interval interval
undo mld last-listener-query-interval
View
Interface view
Default Level
2: System level
interval: MLD last listener query interval in seconds, in the range of 1 to 5.
Use the mld last-listener-query-interval command to configure the MLD last listener query interval on the current interface.
Use the undo mld last-listener-query-interval command to restore the system default.
Related commands: last-listener-query-interval, mld robust-count, display mld interface.
# Set the MLD last listener query interval to 3 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] mld last-listener-query-interval 3
mld max-response-time interval
undo mld max-response-time
View
Interface view
Default Level
2: System level
Use the mld max-response-time command to configure the maximum response delay for MLD general query messages on the interface.
Use the undo mld max-response-time command to restore the default configuration.
By default, the maximum response delay for MLD general query messages is 10 seconds.
The maximum response delay determines the time which the device takes to detect directly attached group members in the LAN.
Related commands: max-response-time, mld timer other-querier-present, display mld interface.
# Set the maximum response delay for MLD general query messages to 8 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] mld max-response-time 8
mld require-router-alert
undo mld require-router-alert
View
Interface view
Default Level
2: System level
None
Use the mld require-router-alert command to configure the interface to discard MLD messages without the Router-Alert option.
Use the undo mld require-router-alert command to restore the default configuration.
By default, the device does not check the Router-Alert option, that is, it forwards all received MLD messages to the upper layer protocol for processing.
Related commands: require-router-alert, mld send-router-alert.
# Configure VLAN-interface 100 to discard MLD messages without the Router-Alert option.
[Sysname-Vlan-interface100] mld require-router-alert
mld robust-count
mld robust-count robust-value
undo mld robust-count
View
Interface view
Default Level
2: System level
robust-value: MLD querier robustness variable, with an effective range of 2 to 5.
Use the mld robust-count command to configure the MLD querier robustness variable on the current interface.
Use the undo mld robust-count command to restore the system default.
By default, the MLD querier robustness variable is 2.
Related commands: robust-count, mld timer query, mld last-listener-query-interval, mld timer other-querier-present, display mld interface.
# Set the MLD querier robustness variable to 3 on VLAN-interface 100.
[Sysname-Vlan-interface100] mld robust-count 3
undo mld send-router-alert
View
Interface view
Default Level
2: System level
None
Use the mld send-router-alert command to enable insertion of the Router-Alert option into MLD messages to be sent from the current interface.
Use the undo mld send-router-alert command to disable insertion of the Router-Alert option into MLD messages to be sent from the current interface.
By default, MLD messages carry the Router-Alert option.
Related commands: send-router-alert, mld require-router-alert.
# Disable insertion of the Router-Alert option into MLD messages to be sent from VLAN-interface 100.
[Sysname-Vlan-interface100] undo mld send-router-alert
mld ssm-mapping enable
undo mld ssm-mapping enable
View
Interface view
Default Level
2: System level
None
Use the mld ssm-mapping enable command to enable the MLD SSM mapping feature on the current interface.
Use the undo mld ssm-mapping enable command to disable the MLD SSM mapping feature on the current interface.
By default, the MLD SSM mapping feature is disabled on all interfaces.
# Enable the MLD SSM mapping feature on VLAN-interface 100.
[Sysname-Vlan-interface100] mld ssm-mapping enable
mld startup-query-count
mld startup-query-count value
undo mld startup-query-count
View
Interface view
Default Level
2: System level
value: Startup query count, namely, the number of queries the MLD querier sends on startup, with an effective range of 2 to 5.
Use the mld startup-query-count command to configure the startup query count on the current interface.
Use the undo mld startup-query-count command to restore the system default.
By default, the startup query count is set to the MLD querier robustness variable.
By default, the MLD querier robustness variable is 2, so the startup query count is also 2.
Related commands: startup-query-count, mld robust-count.
# Set the startup query count to 3 on VLAN-interface 100.
[Sysname-Vlan-interface100] mld startup-query-count 3
mld startup-query-interval
mld startup-query-interval interval
undo mld startup-query-interval
View
Interface view
Default Level
2: System level
interval: Startup query interval in seconds, namely, the interval between general queries the MLD querier sends on startup, with an effective range of 1 to 18000.
Use the mld startup-query-interval command to configure the startup query interval on the current interface.
Use the undo mld startup-query-interval command to restore the system default.
By default, the startup query interval is 1/4 of the MLD query interval.
By default, the MLD query interval is 125 seconds, so the startup query interval = 125 / 4 = 31.25 (seconds).
Related commands: startup-query-interval, mld timer query.
# Set the startup query interval to 5 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] mld startup-query-interval 5
mld static-group
mld static-group ipv6-group-address [ source ipv6-source-address ]
undo mld static-group { all | ipv6-group-address [ source ipv6-source-address ] }
View
Interface view
Default Level
2: System level
all: Removes all static IPv6 multicast groups that the current interface has joined.
ipv6-group-address: IPv6 multicast group address, in the range of FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16, and FF0y::), where x and y represent any hexadecimal number ranging from 0 to F. .
ipv6-source-address: IPv6 address of the specified multicast source.
Use the mld static-group command to configure the current interface to be a statically-connected member of the specified IPv6 multicast group or IPv6 multicast source and group.
Use the undo mld static-group command to remove the configuration.
By default, an interface is not a statically-connected member of any IPv6 multicast group or IPv6 multicast source and group.
If the IPv6 multicast address is in the SSM multicast address range, you must specify an IPv6 multicast source address at the same time; otherwise MLD routing table entries cannot be established. There is no such a restriction if the specified IPv6 multicast group address is not in the SSM multicast address range.
# Configure Vlan-interface1 to be a statically-connected member of the IPv6 multicast group FF03::101.
[Sysname] interface Vlan-interface1
[Sysname-Ethernet1/1] mld static-group ff03::101
# Configure Vlan-interface1 as a static member to forward multicast data of the multicast source 2001::101 to the multicast group FF3E::202.
[Sysname-Vlan-interface1] mld static-group ff3e::202 source 2001::101
mld timer other-querier-present interval
undo mld timer other-querier-present
View
Interface view
Default Level
2: System level
interval: MLD other querier present interval in seconds, in the range of 60 to 300.
Use the mld timer other-querier-present command to configure the MLD other querier present interval on the current interface.
Use the undo mld timer other-querier-present command to restore the system default.
By default, MLD other querier present interval = [ MLD query interval ] times [ MLD querier robustness variable ] plus [ maximum response delay for MLD general queries ] divided by two.
By default, the values of the three parameters in the above-mentioned formula are 125, 2, and 10, respectively, so the MLD other querier present interval is 125 x 2 + 10 / 2 = 255 (seconds).
Related commands: timer other-querier-present, mld timer query, mld robust-count, mld max-response-time, display mld interface.
# Set the MLD other querier present interval to 200 seconds on VLAN-interface 100.
[Sysname] interface vlan-interface100
[Sysname-Vlan-interface100] mld timer other-querier-present 200
mld timer query
mld timer query interval
undo mld timer query
View
Interface view
Default Level
2: System level
interval: MLD query interval, namely the amount of time in seconds between MLD general query messages, in the range of 1 to 18,000.
Use the mld timer query command to configure the MLD query interval on the current interface.
Use the undo mld timer query command to restore the system default.
By default, the MLD query interval is 125 seconds.
Related commands: timer query, mld timer other-querier-present, display mld interface.
# Set the MLD query interval to 200 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] mld timer query 200
mld version
mld version version-number
undo mld version
View
Interface view
Default Level
2: System level
version-number: MLD version, 1 or 2.
Use the mld version command to configure the MLD version on the current interface.
Use the undo mld version command to restore the default MLD version.
By default, the MLD version is MLDv1.
Related commands: version.
# Set the MLD version to MLDv2 on VLAN-interface 100.
[Sysname-Vlan-interface100] mld version 2
undo require-router-alert
View
MLD view
Default Level
2: System level
None
Use the require-router-alert command to globally configure the device to discard MLD messages without the Router-Alert option.
Use the undo require-router-alert command to restore the default configuration.
Related commands: mld require-router-alert, send-router-alert.
# Globally configure the device to discard MLD messages without the Router-Alert option.
[Sysname] mld
[Sysname-mld] require-router-alert
reset mld group
reset mld group { all | interface interface-type interface-number { all | ipv6-group-address [ prefix-length ] [ ipv6-source-address [ prefix-length ] ] } }
View
Default Level
2: System level
all: The first all specifies to clear MLD multicast group information on all interfaces, while the second all specifies to clear the information of all MLD multicast groups.
interface interface-type interface-number: Clears the MLD multicast group information on the specified interface.
ipv6-group-address: IPv6 multicast group address, in the range of FFxy::/16, where x and y represent any hexadecimal number ranging from 0 to F.
ipv6-source-address: IPv6 multicast source address.
prefix-length: Prefix length of the specified multicast source or multicast group. For a multicast source address, this argument has an effective value range of 0 to 128; for a multicast group address, it has an effective value range of 8 to 128. The system default is 128 in both cases.
Use the reset mld group command to clear MLD multicast group information.
Note that this command cannot clear MLD multicast group information of static joins.
Related commands: display mld group.
# Clear all MLD multicast group information on all interfaces.
<Sysname> reset mld group all
# Clear all MLD multicast group information for VLAN-interface 100.
<Sysname> reset mld group interface vlan-interface 100 all
# Clear the information about MLD multicast group FF03::101:10 on VLAN-interface 100.
<Sysname> reset mld group interface vlan-interface 100 ff03::101:10
reset mld group port-info
reset mld group port-info { all | ipv6-group-address } [ vlan vlan-id ]
View
Default Level
2: System level
all: Clears Layer 2 port information of all the MLD multicast groups.
Ipv6-group-address: Clears Layer 2 port information of the specified MLD multicast group. The effective range of group-address is FFxy::/16, where x and y represent any hexadecimal number between 0 and F, inclusive.
vlan-id: Clear Layer 2 port information of MLD multicast groups in the specified VLAN. The effective range of vlan-id is 1 to 4094.
Use the reset mld group port-info command to clear Layer 2 port information of MLD multicast groups.
Note that:
l Layer 2 ports for MLD multicast groups include member ports and router ports.
l This command cannot clear Layer 2 port information about MLD multicast groups of static joins.
Related commands: display mld group port-info.
# Clear Layer 2 port information of all MLD multicast groups in all VLANs.
<Sysname> reset mld group port-info all
# Clear Layer 2 port information of all MLD multicast groups in VLAN 100.
<Sysname> reset mld group port-info all vlan 100
# Clear Layer 2 port information about multicast group FF03::101:10 in VLAN 100.
<Sysname> reset mld group port-info ff03::101:10 vlan 100
reset mld ssm-mapping group
reset mld ssm-mapping group { all | interface interface-type interface-number { all | ipv6-group-address [ prefix-length ] [ ipv6-source-address [ prefix-length ] ] } }
View
Default Level
2: System level
all: The first all specifies to clear IPv6 multicast group information created based on the configured MLD SSM mappings on all interfaces, while the second all specifies to clear all IPv6 multicast group information created based on the configured MLD SSM mappings..
Use the reset mld ssm-mapping group command to clear IPv6 multicast group information created based on the configured MLD SSM mappings.
Related commands: display mld ssm-mapping group.
# Clear all IPv6 multicast group information created based on the configured MLD SSM mappings on all interfaces.
<Sysname> reset mld ssm-mapping group all
robust-count (MLD view)
undo robust-count
View
MLD view
Default Level
2: System level
Use the robust-count command to configure the MLD querier robustness variable globally.
Use the undo robust-count command to restore the system default.
Related commands: mld robust-count, last-listener-query-interval, timer other-querier-present, display mld interface.
# Set the MLD querier robustness variable to 3 globally.
[Sysname] mld
[Sysname-mld] robust-count 3
send-router-alert (MLD view)
send-router-alert
undo send-router-alert
View
MLD view
Default Level
2: System level
None
Use the send-router-alert command to globally enable the insertion of the Router-Alert option into MLD messages to be sent.
Use the undo send-router-alert command to globally disable the insertion of the Router-Alert option into MLD messages to be sent.
Related commands: mld send-router-alert, require-router-alert.
# Globally disable insertion of the Router-Alert option into MLD messages to be sent.
[Sysname] mld
[Sysname-mld] undo send-router-alert
ssm-mapping (MLD view)
ssm-mapping ipv6-group-address prefix-length ipv6-source-address
undo ssm-mapping { ipv6-group-address prefix-length ipv6-source-address | all }
View
MLD view
Default level
2: System level
prefix-length: Prefix length of the IPv6 multicast group address, in the range of 8 to 128.
all: Removes all MLD SSM mappings.
Use the ssm-mapping command to configure an MLD SSM mapping.
Use the undo ssm-mapping command to remove one or all MLD SSM mappings.
By default, no MLD SSM mappings are configured.
Related commands: mld ssm-mapping enable, display mld ssm-mapping.
# Configure an MLD SSM mapping for multicast group FF1E::101/64 and multicast source 1::1.
[Sysname] mld
[Sysname-mld] ssm-mapping ff1e::101 64 1::1
undo startup-query-count
View
MLD view
Default Level
2: System level
Use the startup-query-count command to configure the startup query count globally.
Use the undo startup-query-count command to restore the system default.
Related commands: mld startup-query-count, robust-count.
# Set the startup query count to 3 globally.
[Sysname] mld
[Sysname-mld] startup-query-count 3
undo startup-query-interval
View
MLD view
Default Level
2: System level
Use the startup-query-interval command to configure the startup query interval globally.
Use the undo startup-query-interval command to restore the system default.
By default, the startup query interval is 1/4 of the “MLD query interval”.
Related commands: mld startup-query-interval, timer query.
# Set the startup query interval to 5 seconds globally.
[Sysname] mld
[Sysname-mld] startup-query-interval 5
undo timer other-querier-present
View
MLD view
Default Level
2: System level
Use the timer other-querier-present command to configure the MLD other querier present interval globally.
Use the undo timer other-querier-present command to restore the default configuration.
Related commands: mld timer other-querier-present, timer query, robust-count, max-response-time, display mld interface.
# Set the MLD other querier present interval to 200 seconds globally.
[Sysname] mld
[Sysname-mld] timer other-querier-present 200
timer query (MLD view)
undo timer query
View
MLD view
Default Level
2: System level
interval: MLD query interval, namely, amount of time in seconds between MLD general queries, in the range of 1 to 18,000.
Use the timer query command to configure the MLD query interval globally.
Use the undo timer query command to restore the system default.
Related commands: mld timer query, timer other-querier-present, display mld interface.
# Set the MLD query interval to 200 seconds globally.
[Sysname] mld
[Sysname-mld] timer query 200
version (MLD view)
undo version
View
MLD view
Default Level
2: System level
Use the version command to configure the MLD version globally.
Use the undo version command to restore the default MLD version.
Related commands: mld version.
# Globally set the MLD version to MLDv2.
[Sysname] mld
[Sysname-mld] version 2
