10-Segment Routing命令参考
05-SRv6 TE Policy命令
本章节下载: 05-SRv6 TE Policy命令  (708.94 KB)
05-SRv6 TE Policy命令
1 SRv6 TE Policy
1.1 SRv6 TE Policy配置命令
1.1.1 address-family ipv6 sr-policy
1.1.2 advertise ebgp enable
1.1.3 autoroute enable
1.1.4 autoroute metric
1.1.5 backup hot-standby
1.1.6 bestroute encap-type
1.1.7 bfd echo
1.1.8 bfd srv6-encapsulation-mode encap
1.1.9 bfd trigger path-down enable
1.1.10 binding-sid
1.1.11 bypass enable
1.1.12 candidate-paths
1.1.13 color end-point
1.1.14 color match dscp (DSCP forward type view)
1.1.15 color match dscp (SRv6 TE Policy group view)
1.1.16 default-color (VPN instance IPv4/IPv6 address family view)
1.1.17 default-color (Public instance IPv4/IPv6 address family view)
1.1.18 delete-delay
1.1.19 description
1.1.20 display bgp mirror remote-sid
1.1.21 display bgp routing-table ipv6 sr-policy
1.1.22 display evpn srv6 mirror remote-sid
1.1.23 display pce segment-routing ipv6 policy database
1.1.24 display pce segment-routing ipv6 policy initiate-cache
1.1.25 display segment-routing ipv6 te bfd
1.1.26 display segment-routing ipv6 te database
1.1.27 display segment-routing ipv6 te forwarding
1.1.28 display segment-routing ipv6 te policy
1.1.29 display segment-routing ipv6 te policy last-down-reason
1.1.30 display segment-routing ipv6 te policy statistics
1.1.31 display segment-routing ipv6 te policy status
1.1.32 display segment-routing ipv6 te policy-group
1.1.33 display segment-routing ipv6 te policy-group last-down-reason
1.1.34 display segment-routing ipv6 te policy-group statistics
1.1.35 display segment-routing ipv6 te sbfd
1.1.36 display segment-routing ipv6 te segment-list
1.1.37 display segment-routing ipv6 te source-sid
1.1.38 distribute bgp-ls
1.1.39 drop-upon-invalid enable
1.1.40 dynamic (SRv6 TE Policy Path Preference view)
1.1.41 dynamic (SRv6 TE-ODN view)
1.1.42 encapsulation-mode encaps include local-end.x
1.1.43 encapsulation-mode encaps reduced
1.1.44 end-point
1.1.45 explicit segment-list
1.1.46 fast-reroute mirror delete-delay
1.1.47 fast-reroute mirror enable
1.1.48 forwarding statistics
1.1.49 forward-type
1.1.50 group-color
1.1.51 import-route sr-policy
1.1.52 index
1.1.53 mirror remote-sid delete-delay
1.1.54 on-demand
1.1.55 on-demand-group
1.1.56 path verification
1.1.57 pce capability segment-routing ipv6
1.1.58 pce delegation
1.1.59 pce passive-delegate report-only
1.1.60 pcep (SRv6 TE Policy Path Preference dynamic view)
1.1.61 pcep (SRv6 TE-ODN dynamic view)
1.1.62 policy
1.1.63 policy-group
1.1.64 preference
1.1.65 rate-limit
1.1.66 reset segment-routing ipv6 te forwarding statistics
1.1.67 restrict
1.1.68 router-id filter
1.1.69 sbfd
1.1.70 segment-list
1.1.71 service-class
1.1.72 shutdown
1.1.73 snmp-agent trap enable srv6-policy
1.1.74 sr-policy steering
1.1.75 sr-te frr enable
1.1.76 srv6-policy alarm-threshold
1.1.77 srv6-policy autoroute enable
1.1.78 srv6-policy backup hot-standby enable
1.1.79 srv6-policy bfd echo
1.1.80 srv6-policy encapsulation-mode encaps include local-end.x
1.1.81 srv6-policy encapsulation-mode encaps reduced
1.1.82 srv6-policy forwarding statistics enable
1.1.83 srv6-policy forwarding statistics interval
1.1.84 srv6-policy locator
1.1.85 srv6-policy log enable
1.1.86 srv6-policy path verification enable
1.1.87 srv6-policy pce delegation enable
1.1.88 srv6-policy pce passive-delegate report-only enable
1.1.89 srv6-policy sbfd
1.1.90 srv6-policy switch-delay delete-delay
1.1.91 te ipv6-router-id
1.1.92 traffic-engineering
1.1.93 ttl-mode
1.1.94 validation-check enable
1 SRv6 TE Policy
address-family ipv6 sr-policy命令用来创建BGP IPv6 SR Policy地址族,并进入相应地址族视图。如果BGP IPv6 SR Policy地址族视图已经存在,则直接进入BGP IPv6 SR Policy地址族。
undo address-family ipv6 sr-policy命令用来删除BGP IPv6 SR Policy地址族,及相应地址族视图下的所有配置。
不存在BGP IPv6 SR Policy地址族。
BGP实例视图
BGP IPv6 SR Policy地址族视图下的配置,只对BGP IPv6 SR Policy地址族的路由和对等体生效。
# 在BGP实例视图下,创建BGP IPv6 SR Policy地址族,并进入BGP IPv6 SR Policy地址族视图。
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv6 sr-policy
[Sysname-bgp-default-srpolicy-ipv6]
advertise ebgp enable命令用来配置将BGP IPv6 SR Policy路由发布给EBGP邻居。
undo advertise ebgp enable命令用来恢复缺省情况。
BGP IPv6 SR Policy路由不发布给EBGP邻居。
缺省情况下,BGP IPv6 SR Policy路由只能在IBGP对等体之间发布。如果需要将BGP IPv6 SR Policy路由发布给EBGP对等体,则需要执行本命令。
# 配置将BGP IPv6 SR Policy路由发布给EBGP邻居。
[Sysname] bgp 100
[Sysname-bgp-default] address ipv6 sr-policy
[Sysname-bgp-default-srpolicy-ipv6] advertise ebgp enable
autoroute enable命令用来开启自动引流功能。
undo autoroute enable命令用来关闭自动引流功能。
autoroute enable [ isis | ospfv3 ]
自动引流功能处于关闭状态。
SRv6 TE Policy视图
isis:开启IPv6 IS-IS的自动引流功能。
ospfv3:开启OSPFv3的自动引流功能。
自动路由发布是指将SRv6 TE Policy隧道发布到IGP(OSPFv3或IS-IS)路由中,让SRv6 TE Policy隧道参与IGP路由的计算,使得流量可以通过SRv6 TE Policy隧道转发。
自动路由发布目前仅支持IGP Shortcut方式,也称为自动路由宣告(AutoRoute Announce),该功能将SRv6 TE Policy隧道当作一条直接连接隧道Ingress节点(头节点)和Egress节点(尾节点)的链路,在隧道的Ingress节点上进行IGP路由计算时考虑该SRv6 TE Policy隧道。
如果不指定isis和ospfv3参数,则在OSPFv3和IPv6 IS-IS协议的路由计算中都考虑SRv6 TE Policy隧道。
# 开启SRv6 TE Policy的自动引流功能。
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] traffic-engineering
[Sysname-srv6-te] policy srv6policy
[Sysname-srv6-te-policy-srv6policy] autoroute enable
·     autoroute metric
autoroute metric命令用来配置SRv6 TE Policy隧道的度量值。
undo autoroute metric命令用来恢复缺省情况。
autoroute metric { absolute value | relative value }
SRv6 TE Policy隧道的度量值等于其IGP度量值。
SRv6 TE Policy视图
absolute value:以绝对值的方式指定度量值,即实际度量值为配置的值value。value为正整数,取值范围为1~65535。
relative value:以相对值的方式指定度量值,即实际度量值为配置的值value+该隧道的IGP度量值。value可以是正整数、负整数或0,取值范围为-10~10。
开启自动引流功能后,SRv6 TE Policy隧道作为一条链路参与IGP路由的计算。SRv6 TE Policy隧道在路由计算过程中的度量值可以通过本命令来配置。
# 配置SRv6 TE Policy隧道的度量值为绝对值15。
[Sysname-srv6-te-policy-srv6policy] autoroute metric absolute 15
·     autoroute enable
backup hot-standby命令用来配置SRv6 TE Policy的热备份功能。
undo backup hot-standby命令用来恢复缺省情况。
backup hot-standby { disable | enable }
未配置SRv6 TE Policy的热备份功能,以SRv6 TE视图下的配置为准。
SRv6 TE Policy视图
disable:关闭SRv6 TE Policy的热备份功能。
enable:开启SRv6 TE Policy的热备份功能。
开启SRv6 TE Policy的热备份功能后,如果一个SRv6 TE Policy下面存在多条候选路径,则优先级最高的有效路径是主路径,优先级次高的有效路径是备份路径。如果主路径下所有Segment List都发生故障,则将流量切换到备路径转发,以减少对业务的影响。
SRv6 TE视图和SRv6 TE Policy视图下均可以配置SRv6 TE Policy的热备份功能。SRv6 TE视图的配置对所有SRv6 TE Policy都有效,而SRv6 TE Policy视图的配置只对当前SRv6 TE Policy有效。对于一个SRv6 TE Policy来说,优先采用该SRv6 TE Policy内的配置,只有该SRv6 TE Policy内未进行配置时,才采用SRv6 TE视图的配置。
# 开启SRv6 TE Policy 1的热备份功能。
[Sysname-srv6-te] policy 1
[Sysname-srv6-te-policy-1] backup hot-standby enable
·     srv6-policy backup hot-standby enable
bestroute encap-type命令用来配置根据报文封装进行路由优选。
undo bestroute encap-type命令用来恢复缺省情况。
bestroute encap-type { mpls | srv6 }
不根据报文封装进行路由优选。
BGP-VPN实例视图
mpls:优选MPLS封装的路由。
srv6:优选SRv6封装的路由。
配置本命令后,对指定VPN实例下的BGP路由进行选路时,依次完成路由属性NEXT_HOP、Preferred-value和LOCAL_PREF的选路过程后,根据bestroute encap-type命令选优SRv6封装或MPLS封装的路由,之后继续根据BGP原有的选路流程进行选路。关于BGP选路规则的详细介绍,请参见“三层技术-IP路由配置指导”中的“BGP概述”。
多次执行本命令,最后一次执行的命令生效。
# 配置优选SRv6封装的路由。
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] bestroute encap-type srv6
1.1.7  bfd echo
bfd echo命令用来配置SRv6 TE Policy的echo报文方式的BFD检测功能。
undo bfd echo命令用来恢复缺省情况。
bfd echo { disable | enable [ source-ipv6 ipv6-address ] [ template template-name ] [ backup-template backup-template-name ] [ oam-sid sid ] [ encaps | insert ] }
undo bfd echo
未配置SRv6 TE Policy的echo报文方式的BFD检测功能,以SRv6 TE视图下的配置为准。
SRv6 TE Policy视图
disable:关闭SRv6 TE Policy的echo报文方式的BFD检测功能。
enable:开启SRv6 TE Policy的echo报文方式的BFD检测功能。
source-ipv6 ipv6-address:指定BFD会话的源IPv6地址。如果未指定本参数,则以SRv6 TE视图下的配置为准。
template template-name:指定引用的BFD模板。template-name为BFD会话参数模板的名称,为1~63个字符的字符串,区分大小写。如果未指定本参数,则以SRv6 TE视图下配置的BFD模板为准。
backup-template backup-template-name:指定备份SID列表引用的BFD模板。backup-template-name为BFD会话参数模板的名称,为1~63个字符的字符串,区分大小写。如果未指定本参数,则以SRv6 TE视图下配置的备份BFD模板为准。
oam-sid sid:为BFD报文添加OAM SID,用于定位目的节点。sid为目的节点的SRv6 SID。如果未指定本参数,则不为BFD报文添加OAM SID。目前OAM SID需要配置为目的节点上的End.OP SID。
encaps:配置BFD报文采用普通封装模式。
insert:配置BFD报文采用插入封装模式。
通过echo报文方式的BFD检测SRv6 TE Policy时,需要为BFD报文封装SRv6 TE Policy的SID列表,封装模式包括:
·     Encaps方式:普通封装模式。在原始报文的基础上封装新的IPv6头和SRH,且SRv6 TE Policy的SID列表中的所有SID均封装在SRH中。
¡     新IPv6头的目的IPv6地址为SRv6 TE Policy的SID列表中的第一个IPv6地址,源IPv6地址为encapsulation source-address命令指定的IPv6地址。
¡     SRH包含SRv6 TE Policy的SID列表中所有SID信息。
·     Insert方式:插入封装模式。在原始IPv6报文头后插入SRH,且SRv6 TE Policy的SID列表中的所有SID均封装在SRH中。
¡     IPv6头的目的IPv6地址改为SRv6 TE Policy的SID列表中的第一个IPv6地址,源IPv6地址为encapsulation source-address命令指定的IPv6地址。
如果未指定encaps和insert参数,则采用bfd srv6-encapsulation-mode encap命令配置的封装模式。
通过echo报文方式的BFD检测SRv6 TE Policy,为BFD报文封装SRv6 TE Policy的SID列表时,不受SRv6 TE视图和SRv6 TE Policy视图下SRv6 TE Policy的封装模式命令的控制。
SRv6 TE视图和SRv6 TE Policy视图下均可以配置SRv6 TE Policy的echo报文方式的BFD检测功能。SRv6 TE视图的配置对所有SRv6 TE Policy都有效,而SRv6 TE Policy视图的配置只对当前SRv6 TE Policy有效。对于一个SRv6 TE Policy来说,优先采用该SRv6 TE Policy内的配置,只有该SRv6 TE Policy内未进行配置时,才采用SRv6 TE视图的配置。
目前,支持通过BFD echo报文和SBFD两种方式检测SRv6 TE Policy。在同一SRv6 TE Policy下同时配置以上两种检测方式时,SBFD检测生效。
# 开启SRv6 TE Policy 1的echo报文方式的BFD检测功能,并指定BFD会话的源IPv6地址为11::11。
[Sysname-srv6-te-policy-1] bfd echo enable source-ipv6 11::11
·     bfd srv6-encapsulation-mode encap
·     display segment-routing ipv6 te bfd
·     srv6-policy bfd echo
bfd srv6-encapsulation-mode encap命令用来配置使用BFD或SBFD对SRv6转发路径进行故障检测时,BFD或SBFD报文的封装模式为Encap模式。
undo bfd srv6-encapsulation-mode encap命令用来恢复缺省情况。
使用BFD或SBFD对SRv6转发路径进行故障检测时,BFD或SBFD报文的封装模式为Insert模式。
使用BFD或SBFD对SRv6 TE Policy进行故障检测时,不同封装模式下的封装内容不同,具体如下:
·     Insert模式下,在IPv6基本头和BFD/SBFD报文之间插入SRH,该SRH中包含SRv6 TE Policy的SID列表。如果SID列表长度为0,则不插入SRH。
·     Encap模式下,在IPv6报文基本头和BFD/SBFD报文之间插入SRH和一个新的IPv6基本头,添加的SRH中包含SRv6 TE Policy的SID列表。如果SID列表长度为0,则不添加SRH。
需要保证会话两端的BFD/SBFD报文封装模式相同,否则会导致BFD/SBFD会话建立失败。
# 配置使用BFD/SBFD对SRv6转发路径进行故障检测时,BFD/SBFD报文的封装模式为Encap模式。
[Sysname] bfd srv6-encapsulation-mode encap
·     bfd echo
·     sbfd
bfd trigger path-down enable命令用来开启BFD down联动SRv6 TE Policy路径切换功能。
undo bfd trigger path-down enable命令用来关闭BFD down联动SRv6 TE Policy路径切换功能。
BFD down联动SRv6 TE Policy路径切换功能处于关闭状态。
SRv6 TE Policy视图
缺省情况下,当SRv6 TE Policy存在多条有效候选路径时:
·     如果未开启热备份功能,则BFD/SBFD仅检测SRv6 TE Policy的最优有效候选路径中所有SID列表,设备为每个SID列表分别建立BFD/SBFD会话。当所有BFD/SBFD会话dwon时,SRv6 TE Policy不重新优选其他有效的候选路径,设备不再通过该SRv6 TE Policy转发报文。
·     如果开启热备份功能,则BFD/SBFD检测SRv6 TE Policy的主备路径中所有SID列表,设备为每个SID列表分别建立BFD/SBFD会话。
¡     当检测主路径的所有BFD/SBFD会话dwon时,SRv6 TE Policy将切换到备份路径转发报文,不重新优选其他有效的候选路径。
¡     当检测主备路径的所有BFD/SBFD会话dwon时,SRv6 TE Policy不重新优选其他有效的候选路径,设备不再通过该SRv6 TE Policy转发报文。
开启BFD down联动SRv6 TE Policy路径切换功能后,当SRv6 TE Policy存在多条有效候选路径时:
·     如果未开启热备份功能,则BFD/SBFD仅检测SRv6 TE Policy的最优有效候选路径中所有SID列表,设备为每个SID列表分别建立BFD/SBFD会话。当所有BFD/SBFD会话dwon时,SRv6 TE Policy重新优选其他有效的候选路径,使用该有效候选路径转发报文。重新优选时,如果SRv6 TE Policy中无有效的候选路径,则无法使用该SRv6 TE Policy转发报文。
¡     当检测主路径的所有BFD/SBFD会话dwon时,SRv6 TE Policy将切换到备份路径转发报文,并重新优选主备路径。
¡     当检测主备路径的所有BFD/SBFD会话dwon时,SRv6 TE Policy重新优选其他有效的候选路径作为主备路径,设备通过SRv6 TE Policy的新的主路径转发报文。
·     重新优选时,如果SRv6 TE Policy中无有效的候选路径,则无法使用该SRv6 TE Policy转发报文。
开启本功能前需要先创建检测SRv6 TE Policy的BFD或SBFD会话。
# 开启SRv6 TE Policy a1的BFD down联动SRv6 TE Policy路径切换功能。
[Sysname-srv6-te] policy a1
[Sysname-srv6-te-policy-a1] bfd trigger path-down enable
·     bfd echo
·     sbfd
·     srv6-policy sbfd
1.1.10  binding-sid
binding-sid命令用来配置BSID。
undo binding-sid命令用来删除BSID。
binding-sid ipv6 ipv6-address
undo binding-sid
不存在BSID。
SRv6 Policy视图
ipv6 ipv6-address:配置BSID为IPv6地址。ipv6-address为IPv6地址。
BSID(Binding SID,绑定SID)是指入节点的SID。通过BSID、Color和Endpoint可以唯一标识一个SRv6 TE Policy。
BSID获取方式如下:
·     手工配置:通过本命令手工配置BSID。
·     动态获取:SRv6 TE Policy下仅配置Color和Endpoint时,SRv6 TE Policy会自动申请一个BSID。
手工配置优先生效。
本命令配置的BSID必须在SRv6 TE视图下引用的Locator的静态段范围内。否则,BSID对应的SRv6 TE Policy不能用于报文转发。
# 为名称为srv6policy的SRv6 TE Policy配置BSID为1000::1。
[Sysname-segment-routing-ipv6] traffic engineering
[Sysname-srv6-te-policy-srv6policy] binding-sid ipv6 1000::1
bypass enable命令用来开启SRv6 TE Policy的备份路径功能。
undo bypass enable命令用来关闭SRv6 TE Policy的备份路径功能。
bypass enable
undo bypass enable
SRv6 TE Policy的备份路径功能处于关闭状态。
SRv6 TE Policy视图
当本节点作为SRv6 TE Policy的源节点时,如果SID列表中的第一个SID不可达,则源节点会将SRv6 TE Policy置为down状态,既无法通过该SRv6 TE Policy转发报文,也无法触发SRv6 TE FRR。
开启SRv6 TE Policy的备份路径功能,可以解决上述问题。开启本功能后,如果SRv6 TE Policy的SID列表中的第一个SID不可达,则设备生成一条目的地址为SID列表中第一个SID、出接口为NULL0的路由,保证该SRv6 TE Policy处于up状态,以触发SRv6 TE FRR。
# 开启SRv6 TE Policy的备份路径功能。
[Sysname-srv6–te] policy 1
[Sysname-srv6–te-policy-1] bypass enable
·     sr-te frr enable
candidate-paths命令用来创建SRv6 TE Policy候选路径,并进入SRv6 TE Policy候选路径视图。如果SRv6 TE Policy候选路径已经存在,则直接进入SRv6 TE Policy候选路径视图。
undo candidate-paths命令用来删除SRv6 TE Policy候选路径,及SRv6 TE Policy候选路径视图下的所有配置。
candidate-paths
不存在SRv6 TE Policy候选路径。
SRv6 TE Policy视图
# 创建SRv6 TE Policy候选路径,并进入SRv6 TE Policy候选路径视图。
[Sysname-srv6-te-policy-srv6policy] candidate-paths
[Sysname-srv6-te-policy-srv6policy-path]
color end-point命令用来配置SRv6 TE Policy的Color属性和目的节点地址。
undo color命令用来删除SRv6 TE Policy的Color属性和目的节点地址。
color color-value end-point ipv6 ipv6-address
undo color
未配置SRv6 TE Policy的Color属性和目的节点地址。
SRv6 TE Policy视图
color-value:SRv6 TE Policy的Color属性,取值范围为0~4294967295。
ipv6-address:SRv6 TE Policy目的节点的IPv6地址。
Color为转发路径的Color属性,用于在相同的源和目的节点之间区分不同的SRv6 TE Policy;Endpoint为SRv6 TE Policy目的节点的IPv6地址。通过BSID、Color和Endpoint可以唯一标识一个SRv6 TE Policy。
不同SRv6 TE Policy不能配置相同的Color和目的节点地址。
# 配置SRv6 TE Policy的Color属性为20、目的节点的IPv6地址为1000::1。
[Sysname-srv6-te-policy-srv6policy] color 20 end-point ipv6 1000::1
color match dscp命令用来配置SRv6 TE Policy组的ODN模板中Color和DSCP的映射关系。
undo color match dscp命令用来删除SRv6 TE Policy组的ODN模板中Color和DSCP的映射关系。
color color-value match dscp { ipv4 | ipv6 } dscp-value-list
undo color color-value match dscp { ipv4 | ipv6 } dscp-value-list
color color-value match dscp { ipv4 | ipv6 } default
undo color color-value match dscp { ipv4 | ipv6 } default
未配置SRv6 TE Policy组的ODN模板中Color和DSCP映射关系。
DSCP转发类型视图
color-value:指定SRv6 TE Policy的Color值,取值范围为0~4294967295。
ipv4:将IPv4报文引流到指定的SRv6 TE Policy。
ipv6:将IPv6报文引流到指定的SRv6 TE Policy。
dscp-value-list:DSCP列表,表示方式为dscp-value-list = { dscp-value1 [ to dscp-value2 ] } &<1-32>。其中,dscp-value表示DSCP值,取值范围为0~63。&<1-32>表示前面的参数最多可以输入32次。dscp-value2的值要大于等于dscp-value1的值。
default:配置缺省的Color和DSCP的映射关系,即未匹配DSCP值的报文均通过指定的SRv6 TE Policy转发。
通过ODN模板创建SRv6 TE Policy组后,可以根据本命令配置的Color和DSCP的映射关系,实现基于DSCP引流。
IPv4和IPv6地址族可以分别指定Color与DSCP的映射关系,但是对于同一个地址族的报文,每个DSCP值仅支持关联一个Color值。
只有SRv6 TE Policy有效时,才能将其Color值与DSCP关联。
可以通过default参数来指定某个SRv6 TE Policy作为指定地址族报文的缺省SRv6 TE Policy。当SRv6 TE Policy组内某个DSCP没有指定SRv6 TE Policy时,可以使用该缺省SRv6 TE Policy转发报文。一个SRv6 TE Policy组内,一个地址族只能有一个缺省SRv6 TE Policy。
当设备收到未匹配SRv6 TE Policy组ODN模板内Color和DSCP映射关系的IPv4/IPv6地址族报文时,依次按照如下原则选择报文转发方式:
(1)     如果本地址族已配置缺省的SRv6 TE Policy,且该SRv6 TE Policy有效,则采用该SRv6 TE Policy转发报文。
(2)     如果另一地址族已配置缺省的SRv6 TE Policy,且该SRv6 TE Policy有效,则采用该SRv6 TE Policy转发报文。
(3)     如果本地址族下配置了Color和DSCP映射关系,且最小DSCP对应的SRv6 TE Policy有效,则采用该SRv6 TE Policy转发。
(4)     如果另一地址族下配置了Color和DSCP映射关系,且最小DSCP对应的SRv6 TE Policy有效,则采用该SRv6 TE Policy转发。
(5)     均未匹配时,报文不通过SRv6 TE Policy转发,查找IPv6路由表转发。
# 配置SRv6 TE Policy组的ODN模板中Color和DSCP映射关系:将DSCP值为30的IPv4报文引流到Color 20对应的SRv6 TE Policy上。
[Sysname-srv6-te] on-demand-group color 1
[Sysname-srv6-te-odn-group-1] forward-type dscp
[Sysname-srv6-te-odn-group-1-dscp] color 20 match dscp ipv6 30
color match dscp命令用来配置SRv6 TE Policy组的Color和DSCP映射关系。
undo color match dscp命令用来删除SRv6 TE Policy组的Color和DSCP映射关系。
undo color color-value match dscp { ipv4 | ipv6 } [ default ]
未配置SRv6 TE Policy组的Color和DSCP映射关系,即不能通过该SRv6 TE Policy组转发流量。
SRv6 TE Policy组视图
ipv4:将IPv4报文引流到指定的SRv6 TE Policy的DSCP值。
ipv6:将IPv6报文引流到指定的SRv6 TE Policy的DSCP值。
default:配置缺省的Color和DSCP映射关系,即未匹配DSCP值的报文均通过的指定SRv6 TE Policy转发。
当设备收到未匹配SRv6 TE Policy组内Color和DSCP映射关系的IPv4/IPv6地址族报文时,依次按照如下原则选择报文转发方式:
# 配置SRv6 TE Policy组的Color和DSCP映射关系:将DSCP值为30的IPv4报文引流到Color 20对应的SRv6 TE Policy上。
[Sysname-srv6-te] policy-group 10
[Sysname-srv6-te-policy-group-10] color 20 match dscp ipv4 30
default-color命令用来配置L3VPN业务迭代SRv6 TE Policy隧道时使用指定的缺省Color值。
undo default-color命令用来恢复缺省情况。
default-color color-value [ evpn ]
undo default-color [ evpn ]
未配置缺省Color值。
VPN实例IPv4地址族视图
VPN实例IPv6地址族视图
color-value:缺省Color值,取值范围为0~4294967295。
evpn:表示EVPN L3VPN路由迭代SRv6 TE Policy隧道时使用指定的缺省Color值。不指定该参数时表示MPLS L3VPN路由迭代SRv6 TE Policy隧道时都使用指定缺省Color值。
本地PE从远端PE接收到VPNv4、VPNv6或EVPN IP prefix路由后,如果该路由未携带Color扩展团体属性,且没有通过路由策略为路由添加Color属性,则将该路由迭代到SRv6 TE Policy隧道时,会使用本命令配置的缺省Color值来查找匹配的SRv6 TE Policy,以实现SRv6 TE Policy引流。
本命令只对从远端PE学习到的VPN路由生效。
本命令配置的Color值仅在SRv6 TE Policy隧道引流时生效,路由向外发布时不生效。
# 在VPN实例vpn1的IPv4址族视图下,配置EVPN L3VPN业务迭代SRv6 TE Policy隧道时使用的缺省Color值为100。
[Sysname-vpn-instance-vpn1] address-family ipv4
[Sysname-vpn-ipv4-vpn1] default-color 100 evpn
default-color命令用来配置公网业务迭代SRv6 TE Policy隧道时使用指定的缺省Color值。
undo default-color
未配置缺省Color值。
公网实例IPv4地址族视图
公网实例IPv6地址族视图
本地PE从远端PE接收到公网实例的路由后,如果该路由未携带Color扩展团体属性,且没有通过路由策略为路由添加Color属性,则将该路由迭代到SRv6 TE Policy隧道时,会使用本命令配置的缺省Color值来查找匹配的SRv6 TE Policy,以实现SRv6 TE Policy引流。
本命令只对从远端PE学习到的公网实例路由生效。
# 在公网实例IPv4地址族视图下,配置公网业务迭代SRv6 TE Policy隧道时使用指定的缺省Color值为100。
[Sysname] ip public-instance
[Sysname-public-instance] address-family ipv4
[Sysname-public-instance-ipv4] default-color 100
1.1.18  delete-delay
delete-delay命令用来配置由ODN模板生成的SRv6 TE Policy的延迟删除时间。
undo delete-delay命令用来恢复缺省情况。
delete-delay delay-time
undo delete-delay
由ODN模板生成的SRv6 TE Policy的延迟删除时间为180000毫秒。
SRv6 TE-ODN视图
delay-time:由ODN模板生成的SRv6 TE Policy的延迟删除时间,取值范围为0~600000,单位为毫秒。
ODN基于指定BGP路由自动创建SRv6 TE Policy后,如果该BGP路由被删除,则自动创建的SRv6 TE Policy也会被立刻删除,这样将导致通过该BGP路由转发的报文被丢弃。在BGP路由被删除后,为了避免流量丢失,可以配置本命令延迟删除SRv6 TE Policy,待设备计算出新转发路径后,再将该SRv6 TE Policy删除。
# 配置由ODN模板生成的SRv6 TE Policy的延迟删除时间为300000毫秒。
[Sysname-srv6-te] on-demand color 1
[Sysname-srv6-te-odn-1] delete-delay 300000
1.1.19  description
description命令用来配置SRv6 TE Policy组ODN模板的描述信息。
undo description命令用来恢复缺省情况。
未配置SRv6 TE Policy组ODN模板的描述信息。
SRv6 TE-ODN Policy组视图
text:SRv6 TE Policy组ODN模板的描述信息,为1~242个字符的字符串,区分大小写。
为了方便记忆和管理,可以配置SRv6 TE Policy组ODN模板的描述信息。
# 配置SRv6 TE Policy组ODN模板的描述信息。
[Sysname-srv6-te-odn-group-1] description abc
display bgp mirror remote-sid命令用来显示通过Mirror SID保护的远端SRv6 SID。
display bgp [ instance instance-name ] mirror remote-sid [ end-dt4 | end-dt46 | end-dt6 ] [ sid ]
end-dt4:End.DT4类型的远端SRv6 SID。
end-dt46:End.DT46类型的远端SRv6 SID。
end-dt6:End.DT6类型的远端SRv6 SID。
sid:显示指定的远端SRv6 SID信息。
通过本命令可以显示IP L3VPN over SRv6、EVPN L3VPN over SRv6和公网IP over SRv6组网中通过Mirror SID保护的远端SRv6 SID。
如果未指定任何参数,则显示所有通过Mirror SID保护的远端SRv6 SID的信息。
# 显示所有通过Mirror SID保护的远端SRv6 SID的信息。
<Sysname> display bgp mirror remote-sid
Remote SID: 3001::1:0:0
Remote SID type: End.DT4
Mirror locator: 3001::1/64
VPN instance name: vrf1
Remote SID: 3001::1:0:1
Remote SID type: End.DT6
VPN instance name: vrf2
Remote SID: 1111:2222:3333:4444::1
Mirror locator: 1111:2222:3333:4444:5555:6666:7777:8888/64
Public instance
表1-1 display bgp mirror remote-sid命令简要显示信息描述表
Remote SID
远端SRv6 SID
Remote SID type
远端SRv6 SID的类型:
·     End.DT4
·     End.DT6
·     End.DT46
Mirror locator
远端SRv6 SID所属的Locator的IPv6前缀和前缀长度
VPN instance name
与远端SRv6 SID关联的VPN实例名称
Public instance
公网实例
display bgp routing-table ipv6 sr-policy命令用来显示BGP IPv6 SR Policy路由信息。
display bgp [ instance instance-name ] routing-table ipv6 sr-policy [ sr-policy-prefix [ advertise-info ] | { color color-value | end-point ipv6 ipv6-address } * | peer ipv6-address { advertised-routes | received-routes } [ statistics ] | statistics ]
sr-policy-prefix:显示指定BGP IPv6 SR Policy路由的详细信息。sr-policy-prefix组成格式为sr-policy-route/route-length,为1~512个字符的字符串,不区分大小写。其中,sr-policy-route表示BGP IPv6 SR Policy路由信息,route-length表示路由信息的长度。
color color-value:显示指定Color属性的BGP IPv6 SR Policy路由的详细信息。color-value表示Color属性值,取值范围为1~4294967295。
end-point ipv6 ipv6-address:显示指定目的地址的BGP IPv6 SR Policy路由的详细信息。ipv6-address表示目的节点的IPv6地址。
advertise-info:显示BGP IPv6 SR Policy路由的通告信息。
peer ipv6-address:显示向指定的对等体发布或者从指定的对等体收到的BGP IPv6 SR Policy路由信息。ipv6-address为对等体的IPv6地址。
advertised-routes:显示向指定的对等体发布的路由信息。
received-routes:显示从指定的对等体接收到的路由信息。
statistics:显示路由的统计信息。
如果没有指定任何参数,则显示所有BGP IPv6 SR Policy路由的简要信息。
# 显示所有BGP IPv6 SR Policy路由的简要信息。
<Sysname> display bgp routing-table ipv6 sr-policy
 Total number of routes: 1
 Status codes: * - valid, > - best, d - dampened, h - history
               a – additional-path
>i Network : [46][46][8::8]/192
   NextHop : 1::2                                  LocPrf    : 100
   PrefVal : 0                                     MED       : 0
   Path/Ogn: i
表1-2 display bgp routing-table ipv6 sr-policy命令简要显示信息描述表
路由总数
BGP local router ID
本地的路由器ID
Status codes
路由状态代码:
·     * – valid:合法路由
·     > – best:普通优选路由
·     d - dampened:震荡抑制路由
·     h – history:历史路由
·     s – suppressed:聚合抑制路由
·     S – stale:过期路由
·     i – internal:内部路由
·     e – external:外部路由
·     a – additional-path:Add-Path优选路由
Origin
路由信息的来源,取值包括:
·     i – IGP:表示路由产生于本AS内
·     e – EGP:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的
·     ? – incomplete:表示路由的来源无法确定
Network
BGP IPv6 SR Policy路由,由以下三部分组成:
·     SRv6 TE Policy候选路径的优先级
·     SRv6 TE Policy的Color属性值
·     目的节点IPv6地址
NextHop
下一跳IP地址
LocPrf
本地优先级
PrefVal
路由首选值
MED
MED(Multi-Exit Discriminator,多出口区分)属性值
Path/Ogn
路由的AS路径(AS_PATH)属性和路由信息的来源(ORIGIN)属性,其中:
·     AS_PATH属性记录了此路由经过的所有AS,可以避免路由环路的出现
·     ORIGIN属性标记了此BGP路由如何生成的
# 显示BGP IPv6 SR Policy路由[46][46][8::8]/192的详细信息。
<Sysname> display bgp routing-table ipv6 sr-policy [46][46][8::8]/192
BGP local router ID: 5.5.5.1
Local AS number: 100
Paths: 1 available, 1 best
 BGP routing table information of [46][46][8::8]/192
 Imported route.
 Original nexthop: ::
 Output interface: p1
 Route age       : 19h45m02s
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : (null)
 Origin          : igp
 Attribute value : MED 0, localpref 100, pref-val 32768
 State           : valid, local, best
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 Tunnel encapsulation info:
    Type: 15 (SR policy)
     Policy name: p1
     Binding SID: 2::6
     Preference: 100
     Path: 1
      Weight: 1
      SIDs: {2::2}
表1-3 display bgp routing-table ipv6 sr-policy命令详细显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Paths
路由数信息
·     available:有效路由数目
·     best:最佳路由数目
BGP IPv6 SR Policy路由[46][46][8::8]/192的路由表项信息
Imported route
引入的路由
From
发布该路由的BGP对等体的IP地址
Rely Nexthop
路由迭代后的下一跳IP地址,如果没有迭代出下一跳地址,则显示为“not resolved”
Original nexthop
路由的原始下一跳地址,如果是从BGP更新消息中获得的路由,则该地址为接收到的消息中的下一跳IP地址
Output interface
出接口信息,显示为转发隧道的SRv6 TE policy名称
Route age
路由最后一次更新到目前持续的时间
OutLabel
路由的出标签值
RxPathID
接收到的路由的Add-Path ID值
TxPathID
发送的路由的Add-Path ID值
AS-path
路由的AS路径(AS_PATH)属性,记录了此路由经过的所有AS,可以避免路由环路的出现
Origin
路由信息的来源,取值包括:
·     igp:表示路由产生于本AS内
·     egp:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的
Attribute value
BGP路由属性信息,包括:
·     MED:与目的网络关联的MED值
·     localpref:本地优先级
·     pref-val:路由首选值
·     pre:协议优先级
路由当前状态,取值包括:
·     valid:有效路由
·     internal:内部路由
·     external:外部路由
·     local:本地产生路由
·     synchronize:同步路由
·     best:最佳路由
·     delay:表示该路由优选时将被延迟(仅在显示路由详细信息时显示本字段)
·     not preferred for reason:路由未被优选的原因,reason的具体内容请参见表1-4
IP precedence
路由的IP优先级,取值范围为0~7,N/A表示无效值
QoS local ID
路由的QoS本地ID属性,取值范围为1~4095,N/A表示无效值
Traffic index
流量索引值,取值范围为1~64,N/A表示无效值
隧道封装信息
隧道封装类型,目前取值只能为15,表示SR policy
Policy name
SRv6 TE policy名称
Preference
候选路径优先级
Binding SID
SRv6 TE Policy的绑定SID
Path
候选路径的编号
Weight
权重
SIDs
SID列表
当SID为G-SID时,显示格式为{sid-value, coc32, prefix-length}。其中,sid-value为SID值;prefix-length为公共前缀长度
表1-4 路由未被优选的原因
原因
preferred-value
优选首选值最大的路由
local-preference
优选本地优先级最高的路由
as-path
优选AS路径最短的路由
origin
依次选择ORIGIN类型为IGP、EGP、Incomplete的路由
med
优选MED值最低的路由
remote-route
依次选择从EBGP、联盟EBGP、联盟IBGP、IBGP学来的路由
igp-cost
优选IGP Metric值最小的路由
relydepth
优选迭代深度值小的路由
rfc5004
rfc5004规则:如果当前的最优路由为EBGP路由,则BGP路由器收到来自不同的EBGP邻居的路由后,不会改变最优路由
router-id
优选Router ID最小的路由器发布的路由。如果路由包含RR属性,那么在路由选择过程中,就用ORIGINATOR_ID来替代Router ID
cluster-list
优选CLUSTER_LIST长度最短的路由
peer-address
优选IP地址最小的对等体发布的路由
received
优选最先学习到的路由
# 显示BGP IPv6 SR Policy路由[46][46][8::8]/192的通告信息。
<Sysname> display bgp routing-table ipv6 sr-policy [46][46][8::8]/192 advertise-info
 BGP local router ID: 2.2.2.2
 Local AS number: 1
 Paths:   1 best
 BGP routing table information of [46][46][8::8]/192(TxPathID:0):
 Advertised to peers (2 in total):
    1::1
    3::3
表1-5 display bgp routing-table ipv6 sr-policy advertise-info命令显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Paths
到达指定目的网络的优选路由数目
BGP routing table information of [102][2][5.6.7.8]/96(TxPathID:0)
BGP IPv6 SR Policy路由[46][46][8::8]的通告信息,TxPathID表示发送的路由的Add-Path ID值
该路由已经向哪些对等体发送,以及对等体的数目
# 显示向对等体2::2发布的BGP IPv6 SR Policy路由的统计信息。
<Sysname> display bgp routing-table ipv6 sr-policy peer 2::2 advertised-routes statistics
 Advertised routes total: 2
# 显示从对等体2::2收到的BGP IPv6 SR Policy路由的统计信息。
<Sysname> display bgp routing-table ipv6 sr-policy peer 2::2 received-routes statistics
 Received routes total: 1
表1-6 display bgp routing-table ipv6 sr-policy peer statistics命令显示信息描述表
向指定对等体发布的路由总数
从指定对等体收到的路由总数
# 显示BGP IPv6 SR Policy路由的统计信息。
<Sysname> display bgp routing-table ipv6 sr-policy statistics
 Total number of routes: 3
表1-7 display bgp routing-table ipv6 sr-policy statistics命令显示信息描述表
路由总数
display evpn srv6 mirror remote-sid命令用来显示EVPN VPWS/VPLS over SRv6组网中通过Mirror SID保护的远端SRv6 SID。
display evpn srv6 mirror remote-sid [ sid | type { end-dt2u | end-dx2 } ]
sid:显示指定远端SRv6 SID的信息。
type:显示通过Mirror SID保护的指定类型远端SRv6 SID的信息。
end-dt2u:End.DT2U类型的远端SRv6 SID。
end-dx2:End.DX2类型的远端SRv6 SID。
# 显示EVPN VPWS/VPLS over SRv6组网中所有通过Mirror SID保护的远端SID信息。
<Sysname> display evpn srv6 mirror remote-sid
Total number of SIDs: 2
End.DT2U SID        : 111::100
Mirror locator      : 111::/64
VSI name            : svpls
End.DX2 SID         : 111::200
Xconnect group name : svpws
Connection name     : pw1
表1-8 display evpn srv6 mirror remote-sid命令显示信息描述表
End.DT2U SID
远端End.DT2U SID
End.DX2 SID
远端End.DX2 SID
Mirror locator
VSI name
与远端SRv6 SID关联的VSI名称
Xconnect group name
与远端SRv6 SID关联的交叉连接组名称
Connection name
与远端SRv6 SID关联的交叉连接名称
display pce segment-routing ipv6 policy database命令用来显示PCE进程中的SRv6 TE Policy信息。
display pce segment-routing ipv6 policy database [ color color-value endpoint ipv6 ipv6-address | policyname policy-name] [ verbose ]
color color-value end-point ipv6 ipv6-address:显示PCE进程中指定Color属性和目的节点的SRv6 TE Policy信息。color-value取值范围为0~4294967295,ipv6-address表示目的节点的IPv6地址。
policyname policy-name:显示PCE进程中指定名称的SRv6 TE Policy信息。policy-name为SRv6 TE Policy名称,为1~59个字符的字符串,区分大小写。
verbose:显示PCE进程中的SRv6 TE Policy的详细信息。如果不指定本参数,则显示PCE进程中的SRv6 TE Policy的简要信息。
如果未指定color color-value end-point ipv6 ipv6-address和policyname policy-name参数,则显示PCE进程中所有SRv6 TE Policy信息。
# 显示PCE进程中的SRv6 TE Policy的简要信息。
<Sysname> display pce segment-routing ipv6 policy database
Color       Preference  Association  Delegated address  State  Endpoint
1           100         1            192.168.56.1       Up     4:4::4:4
2           10          2            192.168.56.2       Up     4:4::4:4
表1-9 display pce segment-routing ipv6 policy database命令显示信息描述表
Color
Preference
SRv6 TE Policy的候选路径优先级
Association ID
SRv6 TE Policy的候选路径所属组ID,通过组ID来标识一个SRv6 TE Policy
Delegated address
托管PCE的地址,如果候选路径没有托管或者托管失败则本字段显示为“-”
SRv6 TE Policy的候选路径状态,取值包括:
·     Up:表示候选路径建立成功
·     Down:表示候选路径未建立或者建立失败
Endpoint
SRv6 TE Policy的目的节点的IPv6地址
# 显示PCE进程中SRv6 TE Policy的详细信息。
<Sysname> display pce segment-routing ipv6 policy database verbose
PLSP ID: 1046537                           Policy name: p1
 Color: 10
 Endpoint: 4:4::4:4
 Preference: 10
 Protocol Original: 30
 BGP Instance: 0
 ASN: 0              Node address: 0.0.0.0
 Binding SID: 8::1
 Association ID: 1
 Protection type: Unprotected
 Path role: Primary
 SRP ID: 0                                  PCE initiated: No
 PCE-setup-type: SRv6 TE Policy
 Delegatable: Yes                           Delegated address: 192.168.56.1
 Operational state: Up                      Speaker address: 192.168.56.1
 PCEP status: -
 Candidate path/4:  path state: Up
  SRv6-EROs: 3
  SID type: SID without NAI           Strict
    SID: 6000::1                      NAI: N/A
    SID: 7000::1                      NAI: N/A
    SID: 8000::1                      NAI: N/A
  SRv6-RROs: 3
表1-10 display pce segment-routing ipv6 policy database命令显示信息描述表
PLSP ID
PLSP ID,唯一标识一条候选路径
Policy name
SRv6 TE Policy的名称
Color
Endpoint
Preference
Protocol Original
候选路径的来源,取值包括:
·     10:PCE创建
·     20:BGP创建
·     30:命令行创建
BGP Instance
如果候选路径是由BGP创建的,显示BGP所属的实例号,如果不是BGP创建的,则显示为“-”
ASN
自治系统号,0表示未从BGP对等体获取SRv6 TE Policy信息
Node address
BGP节点地址
从BGP对等体获取SRv6 TE Policy信息时,Node address为BGP对等体的Router ID;通过其他方式获取SRv6 TE Policy信息时,Node address为0.0.0.0
Binding SID
SRv6 TE Policy的BSID,如果未指定,则显示为“-”
Association ID
Protection type
候选路径保护类型,取值包括:
·     Unprotected:无保护
·     (Full)Rerouting:普通备份保护
·     Rerouting without Extra-Traffic:热备份保护
·     1:N Protection with Extra-Traffic:1:N保护
·     1+1 Unidirectional Protection:单向1+1保护
·     1+1 Bidirectional Protection:双向1+1保护
Path role
候选路径的类型,取值包括:
·     Primary:主路径
·     Backup:备路径
·     Other:其他路径
SRP ID
Stateful PCE请求参数的ID(Stateful PCE Request Parameters)
PCE initiated
候选路径是否由PCE创建,取值包括:
·     Yes:是由PCE创建
·     No:不是由PCE创建
PCE-setup-type
创建候选路径的协议类型,取值为SRv6 TE Policy,表示SRv6 TE Policy协议
Delegatable
候选路径是否可以托管,取值包括:
·     Yes:具有托管能力
·     No:不具有托管能力
Delegated address
托管PCE地址,如果候选路径没有托管或者托管失败则本字段显示为“-”
Operational state
候选路径状态,取值包括:
·     Up:表示候选路径建立成功
Speaker address
PCE地址
PCEP status
候选路径托管状态,取值包括:
·     Delegated:表示候选路径已经托管给PCE
·     Updated:表示PCE已经更新过候选路径
·     Redelegating:表示候选路径正在重新寻找可以托管的PCE
·     Report-only:表示已将候选路径信息上报给PCE,但候选路径不托管给PCE
·     State reverted:表示候选路径已经回退到托管给PCE之前的状态
Candidate path/path-id
候选路径引用的seglist信息,path-id为seglist编号
path state
候选路径下SID列表的状态,取值包括:
·     Up:表示SID列表建立成功
·     Down:表示SID列表未建立或者建立失败
SRv6-EROs
SRv6-ERO(Segment Routing IPv6 Explicit Route Object,段路由显式路由对象)的个数及其信息
SID Type
ERO和RRO中SID和NAI信息的类型,取值为SID without NAI,表示仅包含SID,不包含NAI
Strict
表示两个SID之间不存在其他的SRv6节点
SID
节点的SRv6 SID
NAI
(暂不支持)Node or Adjacency Identifier,节点或邻接标识
SRv6-RROs
SRv6-RRO(Segment Routing IPv6 Record Route Object,记录路由对象)的个数及其信息
display pce segment-routing ipv6 policy initiate-cache命令用来显示PCE进程中缓存的SRv6 TE Policy的Initiate消息。
PCE与PCC之间建立Active-Stateful PCEP会话后,PCE通过向PCC发送Initiate消息来创建候选路径。通过本命令可以查看设备缓存中还未处理的Initiate消息。
# 显示PCE进程中缓存的SRv6 TE Policy的Initiate消息。
<Sysname> display pce segment-routing ipv6 policy initiate-cache
Policy name: 111111
 Color: 17
 Endpoint: 3::3
 Preference: 17
 Originator: -
 Binding SID: 8::17
 Association ID: 17
 SRP ID: 1                                 PCE initiated: Yes
 Operational state: Down
 Candiate path/0:  path state: Down
  SRv6-EROs: 1
    SID: 2::2                         NAI: N/A
  SRv6-RROs: 0
表1-11 display pce segment-routing ipv6 policy initiate-cache命令显示信息描述表
Policy name
SRv6 TE Policy的名字,如果没有,则显示为“-”
Color
Endpoint
Preference
Originator
BGP节点地址
从BGP对等体获取SRv6 TE Policy信息时,显示为BGP对等体的Router ID;通过其他方式获取SRv6 TE Policy信息时,显示为0.0.0.0
Binding SID
Association ID
Protecttion type
候选路径保护类型,取值包括:
·     Unprotected:无保护
SRP ID
Stateful PCE请求的参数ID(Stateful PCE Request Parameters)
PCE initiated
候选路径是否由PCE创建,取值包括:
·     Yes:是由PCE创建
·     No:不是由PCE创建
Operational state
候选路径状态,取值包括:
·     Up:表示候选路径建立成功
path state
候选路径下SID列表的状态,取值包括:
·     Up:表示SID列表建立成功
SRv6-EROs
SID Type
Strict
SID
节点的SID,即IPv6地址
NAI
SRv6-RROs
display segment-routing ipv6 te bfd命令用来显示SRv6 TE Policy的BFD信息。
display segment-routing ipv6 te bfd [ down | policy { { color color-value | end-point ipv6 ipv6-address } * | name policy-name } | up ]
down:显示状态为down的SRv6 TE Policy的BFD信息。
policy:显示指定SRv6 TE Policy的BFD信息。
color color-value:指定Color属性,取值范围为0~4294967295。
end-point ipv6 ipv6-address:指定目的节点,ipv6-address表示目的节点的IPv6地址。
name policy-name:指定SRv6 TE Policy名称,为1~59个字符的字符串,区分大小写。
up:显示状态为up的SRv6 TE Policy的BFD信息。
如果未指定down、policy和up参数,则显示所有SRv6 TE Policy的BFD信息。
# 显示所有SRv6 TE Policy的BFD信息。
<Sysname> display segment-routing ipv6 te bfd
 Color: 10
 Endpoint: 4::4
 Policy name: p1
 State: Up
   Nid: 2149580801
   BFD type: ECHO
   Encapsulation mode: Encaps
   Source IPv6: 1::1
   State: Up
   Timer: 37
   VPN index: 1
   Template name: abc
表1-12 display segment-routing ipv6 te bfd命令显示信息描述表
Color
Endpoint
Policy name
SRv6 TE Policy的名称
BFD会话状态:
·     Up
·     Down
·     Delete
Nid
SID列表的转发表项索引
BFD type
BFD类型,目前仅支持BFD echo
Encapsulation mode
BFD报文封装模式:
·     Encaps:普通封装模式
·     Insert:插入封装模式
·     -:未配置BFD封装模式
Source IPv6
BFD会话的源IPv6地址
Timer
BFD会话定时器,单位为秒
VPN index
VPN实例索引
Template name
Echo方式BFD的模板名
display segment-routing ipv6 te database命令用来显示SRv6 TE Policy的数据库信息。
display segment-routing ipv6 te database [ link | node | prefix | srv6-sid ]
link:显示IGP协议上报到SRv6 TE Policy数据库的链路信息。
node:显示IGP协议上报到SRv6 TE Policy数据库的节点信息。
prefix:显示IGP协议上报到SRv6 TE Policy数据库的前缀信息。
srv6-sid:显示IGP协议上报到SRv6 TE Policy数据库的SRv6 SID信息。
如果未指定任何参数,显示IGP协议上报到SRv6 TE Policy数据库的所有信息。
# 显示IGP协议上报到SRv6 TE Policy数据库的链路信息。
<Sysname> display segment-routing ipv6 te database link
Link-state information: Link, count: 2
  Public instance, MT-ID: 2, IS-IS instance ID: 0, Link count: 2
    IS-IS p2p:
    Local node: System ID 0000.0000.0020.00, IS level: 1
    Remote node: System ID 0000.0000.0019.00, IS level: 1
    Topology ID: 2
      Link source: ProcID 100, TLV type: MT-IS-reach, FragID: 0x0
        TE local router ID: 2.2.2.2
        TE remote router ID: 1.2.3.4
        IPv6 remote router ID: 1::1
        IGP metric: 10
        SR/SRv6 link maximum SID depths:
          MPLS MSD    : 5
        SRv6 End.X SID
          SID            : 200::1:0:0
          Function type  : End.X (no PSP, no USP)
          Algorithm      : 0
          Weight         : 0
          Flags (B/S/P/C): 0/0/0/0
        SRv6 End.X SID
          SID            : 200::1:0:2
          Function type  : End.X with PSP
          Algorithm      : 0
          Weight         : 0
    IS-IS P2P:
    Local node: System ID 0000.0000.0019.00, IS level: 1
    Remote node: System ID 0000.0000.0020.00, IS level: 1
    IPv6 local address: 2001:1::2
    IPv6 remote address: 2001:1::16
    Topology ID: 2
        TE local router ID: 1.2.3.4
        TE remote router ID: 2.2.2.2
        IPv6 local router ID: 1::1
        TE administrative group: 0x10
        TE maximum bandwidth (kbits/sec): 0
        TE maximum reservable bandwidth (kbits/sec): 0
        TE class  0 unreserved bandwidth (kbits/sec): 0
        TE class  1 unreserved bandwidth (kbits/sec): 0
        TE class  2 unreserved bandwidth (kbits/sec): 0
        TE class  3 unreserved bandwidth (kbits/sec): 0
        TE class  4 unreserved bandwidth (kbits/sec): 0
        TE class  5 unreserved bandwidth (kbits/sec): 0
        TE class  6 unreserved bandwidth (kbits/sec): 0
        TE class  7 unreserved bandwidth (kbits/sec): 0
        TE class  8 unreserved bandwidth (kbits/sec): 0
        TE class  9 unreserved bandwidth (kbits/sec): 0
        TE class 10 unreserved bandwidth (kbits/sec): 0
        TE class 11 unreserved bandwidth (kbits/sec): 0
        TE class 12 unreserved bandwidth (kbits/sec): 0
        TE class 13 unreserved bandwidth (kbits/sec): 0
        TE class 14 unreserved bandwidth (kbits/sec): 0
        TE class 15 unreserved bandwidth (kbits/sec): 0
        TE metric: 10
        IGP metric: 10
          MPLS MSD    : 5
        SRv6 End.X SID
          SID            : 11::A
          Algorithm      : 0
          Weight         : 0
        SRv6 End.X SID
          SID            : 11::1:0:6
          Algorithm      : 0
          Weight         : 0
        SRv6 End.X SID
          SID            : 12:1:2:3:0:A::
          Algorithm      : 0
          Weight         : 0
          Flags (B/S/P/C): 0/0/0/1
          Common prefix length: 64
          Node length         : 26
          Function length     : 6
          Args length         : 0
        SRv6 End.X SID
          SID            : 12:1:2:3:0:6::
          Algorithm      : 0
          Weight         : 0
          Node length         : 26
          Function length     : 6
          Args length         : 0
表1-13 display segment-routing ipv6 te database link命令显示信息描述表
链路状态信息
count
IGP协议上报到SRv6 TE Policy数据库的链路信息的数量
Public instance
公网VPN实例
MT-ID
拓扑信息:
·     0:表示标准拓扑
·     2:表示IPv6单播拓扑
IS-IS instance ID
IS-IS的实例ID
Link count
本实例下的链路的数量
IS-IS P2P
IS-IS P2P类型的链路
IS-IS to DIS
IS-IS到伪节点的链路
IS-IS from DIS
IS-IS伪节点到非伪节点的链路
Local node
链路的本地节点信息
Remote node
链路的远端节点信息
System ID
节点的系统ID
IS level
节点的Level级别
IPv6 local address
本地IPv6地址
IPv6 remote address
远端IPv6地址
Topology ID
拓扑ID:
·     0:IPv4拓扑
·     2:IPv6拓扑
Link source
链路的发布源
ProcID
IS-IS进程号
TLV type
TLV类型:
·     none:无效TLV
·     nbr:邻居TLV
·     wide-nbr:wide的邻居TLV
·     ip-internal:IP内部可达地址TLV
·     ip-external:IP外部可达地址TLV
·     router-id:Router ID TLV
·     ip-extended:扩展的IP可达TLV
·     ipv6-reach:IPv6可达TLV
·     ipv6 router-id:IPv6 Router ID TLV
·     MT-IS-reach:多拓扑IS可达TLV
·     MT-IP-reach:多拓扑IP可达TLV
·     MT-ipv6-reach:多拓扑IPv6可达TLV
·     srlg:SRLG TLV
·     locator:Locator TLV
·     rtr-cap:路由能力TLV
·     unknown:未知TLV
FragID
报文分片号
TE local router ID
本地TE Router ID
TE remote router ID
Link对端的TE Router ID
本地IPv6 TE Router ID
Link对端的IPv6 TE Router ID
TE链路管理组属性
TE最大带宽
TE最大预留带宽
TE class  XX unreserved bandwidth (kbits/sec)
TE指定隧道转发类的可预留带宽
TE metric
TE度量值
IGP metric
IGP度量值
SR-MPLS/SRv6链路MSD(Maximum SID Depths,最大SID深度)子TLV相关信息
MPLS MSD
SR-MPLS能够封装到报文中的SID最大个数
SRv6 LAN End.X SID
LAN邻接链路的SRv6 End.X SID子TLV相关信息
SRv6 End.X SID
P2P邻接链路的SRv6 End.X SID子TLV相关信息
SID
SRv6 SID
Function type
SID的Function类型:
·     End.X (no PSP, no USP):End.X类型SID,且倒数第二跳不弹出、最后一跳不弹出
·     End.X with PSP:End.X类型SID,且倒数第二跳弹出
·     End.X with USP:End.X类型SID,且最后一跳跳弹出
·     End.X with PSP&USP:End.T类型SID,且倒数第二跳弹出、最后一跳弹出
·     End.X with COC (no PSP, no USP):End.X压缩类型SID,且倒数第二跳不弹出、最后一跳不弹出
·     End.X with PSP&COC:End.X压缩类型SID,且倒数第二跳弹出
·     End.X with PSP&USP&COC:End.X压缩类型SID,且倒数第二跳弹出、最后一跳弹出
Algorithm
算法值
Weight
链路的权重
Flags (B/S/P/C)
SRv6标志信息:
·     B:备份标志,置位时,表明可用于链路保护
·     S:集合标志,置位时,表明是一系列邻居设备的集合,表示该SID能分配给多个邻居
·     P:持久性标志,置位时,表明该SID永久分配给该邻居,即使邻居重建
·     C:SRv6压缩标记,置位时,表明SID为压缩格式
压缩类型SID的公共前缀长度
Node length
压缩类型SID的节点长度
Function length
压缩类型SID的Function长度
Args length
压缩类型SID的Args长度
# 显示IGP协议上报到SRv6 TE Policy数据库的节点信息。
Link-state information: Node, count: 2
  Public instance, MT-ID: 2, IS-IS instance ID: 0, Node count: 2
    IS-IS node: System ID 0000.0000.0020.00, IS level: 1
      Node source: ProcID 100, TLV type: none, FragID: 0x0
        Node topology ID: 0 2
        IS-IS area: 10
        SRv6 capability flag (O/C): 0/0
        SR/SRv6 node maximum SID depths:
          MPLS MSD    : 5
          Segment Left: 11
          End Pop MSD : 11
          H.Encaps MSD: 11
          End D MSD   : 11
    IS-IS node: System ID 0000.0000.0019.00, IS level: 1
        Node flag: 0x1
        IS-IS area: 10
        SRv6 capability flag (O/C): 0/1
          MPLS MSD    : 5
          Segment Left: 11
          End Pop MSD : 11
          H.Encaps MSD: 11
          End D MSD   : 11
表1-14 display segment-routing ipv6 te database node命令显示信息描述表
链路状态节点信息
count
IGP协议上报到SRv6 TE Policy数据库的节点信息的数量
Public instance
公网VPN实例
MT-ID
拓扑信息:
·     0:表示标准拓扑
·     2:表示IPv6单播拓扑
Public instance
公网VPN实例
MT-ID
拓扑信息
0表示标准拓扑,2表示IPv6单播拓扑
IS-IS instance ID
IS-IS的实例ID
Node count
本实例下的节点的数量
IS-IS node
节点信息
System ID
节点的系统ID
IS level
节点的Level级别
Node source
节点的发布源
ProcID
IS-IS进程号
TLV type
TLV类型:
·     none:无效TLV
·     nbr:邻居TLV
·     srlg:SRLG TLV
·     rtr-cap:路由能力TLV
·     unknown:未知TLV
FragID
报文分片号
Node topology ID
节点所在拓扑ID
Node flag
节点的标志位
0x01:表示根节点
IS-IS area
IS-IS区域地址
TE local router ID
本地TE Router ID
本地TE IPv6 Router ID
SRv6能力标记:
·     O表示SRH flag的O标志位,置位时,表示路由器支持OAM
·     C表示SRv6压缩标记,置位时,表示SID为压缩格式
SR-MPLS/SRv6节点MSD(Maximum SID Depths,最大SID深度)子TLV相关信息
MPLS MSD
Segment Left
SRH中Segment Left字段的最大值
End Pop MSD
支持PSP(Penultimate Segment Pop of the SRH,倒数第二跳弹出)或USP(Ultimate Segment Pop of the SRH,最后一跳弹出)的端点能够弹出的最大SID个数
对于目的地址为某设备上本地SID的报文,该设备为该报文的端点
H.Encaps MSD
头节点封装SRH时SRH中的SID的最大个数
End D MSD
Endpoint节点能够解封装的SID的最大个数
# 显示IGP协议上报到SRv6 TE Policy数据库的前缀信息。
<Sysname> display segment-routing ipv6 te database prefix
Link-state information: Prefix, count: 21
  Public instance, MT-ID: 2, IS-IS instance ID: 0, Prefix count: 7
    IS-IS IPv6 prefix:
    Local node: System ID 0000.0000.0001.00, IS level: 1
    Prefix: 100::1/128, Topology ID: 2
      Prefix source: ProcID 1, TLV type: ipv6-reach, FragID: 0x0
        Route tag: 100
        Prefix metric: 10
        Locator information
          Metric     : 0
          Algorithm  : 0
          Flags (D/A): 0/0
表1-15 display segment-routing ipv6 te database prefix命令显示信息描述表
链路状态前缀信息
count
IGP协议上报到SRv6 TE Policy数据库的前缀信息的数量
Public instance
公网VPN实例
MT-ID
拓扑信息:
·     0:表示标准拓扑
·     2:表示IPv6单播拓扑
IS-IS instance ID
IS-IS的实例ID
Prefix count
本实例下的前缀的数量
IS-IS IPv6 prefix
IS-IS IPv6前缀信息
Local node
链路的本地节点信息
System ID
节点的系统ID
IS level
节点的Level级别
Prefix
前缀地址
Topology ID
拓扑ID:
·     0:IPv4拓扑
·     2:IPv6拓扑
Prefix source
前缀地址的发布源
ProcID
IS-IS进程号
TLV type
TLV类型:
·     none:无效TLV
·     nbr:邻居TLV
·     srlg:SRLG TLV
·     rtr-cap:路由能力TLV
·     unknown:未知TLV
FragID
报文分片号
Route tag
前缀对应的接口的Tag值
Prefix metric
前缀的度量值
Locator information
前缀携带的Locator子TLV信息
Metric
度量值
Algorithm
Locator关联的算法ID:
·     0:表示SPF算法
·     128~288:表示Flex-Algo算法
Flags (D/A)
Locator的标志位:
·     渗透的标志信息(D标志),置位时,Locator TLV不能从Level-1渗透到Level-2
·     Anycast Locator标志信息(A标志),置位时,表示该Locator为Anycast Locator
# 显示IGP协议上报到SRv6 TE Policy数据库的SRv6 SID信息。
<Sysname> display segment-routing ipv6 te database srv6-sid
Link-state information: SRv6 SID, count: 20
  Public instance, MT-ID: 2, IS-IS instance ID: 0, SRv6 SID count: 1
    IS-IS SRv6 SID:
    Local node: System ID 0000.0000.0002.00, IS level: 1
    SID: 300::2, Topology ID: 2
      SID source: ProcID 1, TLV type: locator, FragID: 0x0
        SRv6 endpoint function
          Function type: End with PSP
          Algorithm    : 0
          Flags        : 0x01
表1-16 display segment-routing ipv6 te database srv6-sid命令显示信息描述表
链路状态SRv6 SID信息
count
IGP协议上报到SRv6 TE Policy数据库的SRv6 SID信息的数量
Public instance
公网VPN实例
MT-ID
拓扑信息:
·     0:表示标准拓扑
·     2:表示IPv6单播拓扑
IS-IS instance ID
IS-IS的实例ID
SRv6 SID count
本实例下的SRv6 SID的数量
IS-IS SRv6 SID
IS-IS发布的SRv6 SID
Local node
链路的本地节点信息
System ID
节点的系统ID
IS level
节点的Level级别
SID
SRv6 SID
Topology ID
拓扑ID
·     0:IPv4拓扑
·     2:IPv6拓扑
SID source
SID的发布源
ProcID
IS-IS进程号
TLV type
TLV类型:
·     none:无效TLV
·     nbr:邻居TLV
·     srlg:SRLG TLV
·     rtr-cap:路由能力TLV
·     unknown:未知TLV
FragID
报文分片号
SRv6 SID绑定的动作
SID
SRv6 SID
Function type
SID的Function类型:
·     End (no PSP, no USP):End类型SID,且倒数第二跳不弹出、最后一跳不弹出
·     End with PSP:End类型SID,且倒数第二跳弹出
·     End with USP:End类型SID,且最后一跳跳弹出
·     End with PSP&USP:End类型SID,且倒数第二跳弹出、最后一跳弹出
·     End.T (no PSP, no USP):End.T类型SID,且倒数第二跳不弹出、最后一跳不弹出
·     End.T with PSP:End.T类型SID,且倒数第二跳弹出
·     End.T with USP:End.T类型SID,且最后一跳跳弹出
·     End.T with PSP&USP:End.T类型SID,且倒数第二跳弹出、最后一跳弹出
·     End.DT6:End.DT6类型SID
·     End.DX6:End.DX6类型SID
·     End with COC (no PSP, no USP):End压缩类型SID,且倒数第二跳不弹出、最后一跳不弹出
·     End with PSP&COC:End压缩类型SID,且倒数第二跳弹出
·     End with PSP&USP&COC:End压缩类型SID,且倒数第二跳弹出、最后一跳弹出
Algorithm
算法值
Flags
压缩标记位:
·     0x01:End SID的压缩标记位
·     0x10:End.X SID的压缩标记位
display segment-routing ipv6 te forwarding命令用来显示SRv6 TE的转发信息。
display segment-routing ipv6 te forwarding [ policy { name policy-name | { color color-value | end-point ipv6 ipv6-address } * } ] [ verbose ]
policy:显示指定SRv6 TE Policy的转发信息。如果未指定本参数,则显示所有SRv6 TE Policy的转发信息。
name policy-name:显示指定名称的SRv6 TE Policy的转发信息。policy-name为SRv6 TE Policy名称,为1~59个字符的字符串,区分大小写。
color color-value:显示指定Color属性的SRv6 TE Policy的转发信息。color-value表示Color属性值,取值范围为0~4294967295。
end-point ipv6 ipv6-address:显示指定目的节点的SRv6 TE Policy的转发信息。ipv6-address表示目的节点的IPv6地址。
verbose:显示SRv6 TE Policy的详细转发信息。如果未指定本参数,则显示SRv6 TE Policy的简要转发信息。
# 显示所有SRv6 TE Policy的简要转发信息。
<Sysname> display segment-routing ipv6 te forwarding
Total forwarding entries: 1
Policy name/ID: p1/0
 Binding SID: 8000::1
 Forwarding index: 2150629377
 Main path:
   Seglist ID: 1
     Seglist forwarding index: 2149580801
     Weight: 1
     Outgoing forwarding index: 2148532225
       Interface: GE3/1/1
       Nexthop: FE80::6CCE:CBFF:FE91:206
 Backup path:
   Seglist ID: 2
     Seglist forwarding index: 2149580802
     Weight: 1
     Outgoing forwarding index: 2148532226
       Interface: GE3/1/2
       Nexthop: FE80::6CCE:CBFF:FE91:207
# 显示所有SRv6 TE Policy的详细转发信息。
<Sysname> display segment-routing ipv6 te forwarding verbose
 Inbound statistics:
   Total octets: 525
   Total packets: 1
   Erroneous packets: 0
   Dropped packets: 0
   Input rate in last 300 seconds:
     0 bits/sec, 0 pkts/sec
   Input rate in last statistical period (20 sec):
 Outbound statistics:
   Total octets: 750
   Total packets: 1
   Dropped packets: 0
   Output rate in last 300 seconds:
   Output rate in last statistical period (20 sec):
 Main path:
   Seglist ID: 1
     Weight: 1
       Total octets: 750
       Total packets: 1
       Dropped packets: 0
       Output service-class 4:
         416 octets, 4 packets,
         0 errors, 0 dropped packets
       Interface: GE3/1/1
         Path ID: 1
         SID list: {44::44, 45::45}
         Total octets: 750
         Total packets: 1
         Dropped packets: 0
 Backup path:
   Seglist ID: 2
     Weight: 1
         Interface: GE3/1/2
           Path ID: 2
           SID list: {44::44, 45::47}
表1-17 display segment-routing ipv6 te forwarding命令显示信息描述表
SRv6 TE转发表项总数
Policy name/ID
SRv6 TE Policy的名称/ID
Binding SID
入节点的SID
Forwarding index
SRv6 TE Policy的转发表项索引
Inbound statistics
入方向流量统计信息,记录了指定BSID收到的总流量
Total octets
转发的字节总数
Total packets
转发的总报文数
Erroneous packets
错误报文个数
Dropped packets
丢弃报文个数
最近300秒入方向流量速率统计信息,单位分别为比特/秒和数据包/秒
最近一次统计周期内入方向流量速率统计信息,单位分别为比特/秒和数据包/秒。统计周期通过srv6-policy forwarding statistics interval命令设置
Outbound statistics
出方向流量统计信息
最近300秒出方向流量速率统计信息,单位分别为比特/秒和数据包/秒
最近一次统计周期内出方向流量速率统计信息,单位分别为比特/秒和数据包/秒。统计周期通过srv6-policy forwarding statistics interval命令设置
指定Service-class的出方向流量的统计数据
转发类为255时,表示该SRv6 TE Policy未配置转发类,转发优先级最低
octets
字节数
packets
报文数
errors
错误包数
dropped packets
丢弃包数
Main path
流量转发的主路径
Backup path
流量转发的备份路径
Seglist ID
SID列表ID
SID列表的转发表项索引
Weight
SID列表的权重
SID列表中首地址的下一跳转发表项索引
携带ECMP-backup,表示等价路由的备份路径
出接口简称
出接口为NULL0时,表示开启并触发了SRv6 TE FRR功能
Nexthop
下一跳IPv6地址
Path ID
SRv6 TE Policy为SID列表分配的ID
SID list
SID列表
SID
节点的SID,即IPv6地址
G-SID的公共前缀长度
G-SID length
G-SID长度
display segment-routing ipv6 te policy命令用来显示SRv6 TE Policy信息。
display segment-routing ipv6 te policy [ odn | pce ] [ name policy-name | down | up | { color color-value | end-point ipv6 ipv6-address } * ]
odn:显示由ODN创建的SRv6 TE Policy的信息。
pce:显示由PCE计算SID列表的SRv6 TE Policy的信息。
name policy-name:显示指定SRv6 TE Policy的信息。policy-name为SRv6 TE Policy名称,为1~59个字符的字符串,区分大小写。
down:显示状态为down的SRv6 TE Policy信息。
up:显示状态为up的SRv6 TE Policy信息。
color color-value:显示指定Color属性的SRv6 TE Policy信息。color-value取值范围为0~4294967295。
end-point ipv6 ipv6-address:显示指定目的节点的SRv6 TE Policy信息。ipv6-address表示目的节点的IPv6地址。
如果未指定任何参数,则显示所有SRv6 TE Policy的信息。
# 显示所有SRv6 TE Policy的信息。
<Sysname> display segment-routing ipv6 te policy
Name/ID: p1/0
 Color: 10
 Endpoint: 1000::1
 Name from BGP:
 BSID:
  Mode: Dynamic              Type: Type 2              Request state: Succeeded
  Current BSID: 8000::1      Explicit BSID: -          Dynamic BSID: 8000::1
 Reference counts: 3
 Flags: A/BS/NC
 Status: Up
 AdminStatus: Not configured
 Up time: 2020-03-09 16:09:40
 Down time: 2020-03-09 16:09:13
 Hot backup: Enabled
 Statistics: Enabled
  Statistics by service class: Enabled
 Path verification: Enabled
 Drop-upon-invalid: Enabled
 BFD trigger path-down: Enabled
 SBFD: Enabled
  Remote: 1000
  SBFD template name: abc
  SBFD backup-template name: -
  OAM SID: -
 BFD Echo: Not configured
 Association ID: 1
 Service-class: -
 Rate-limit: 15000 kbps
 PCE delegation: Not configured
 PCE delegate report-only: Not configured
 Encaps reduced: Not configured
 Encaps include local End.X: Not configured
 Candidate paths state: Configured
 Candidate paths statistics:
  CLI paths: 1          BGP paths: 0          PCEP paths: 0       ODN paths: 0
 Candidate paths:
  Preference : 20
   CpathName:
   Instance ID: 0               ASN: 0              Node address: 0.0.0.0
   Peer address:  ::
   Optimal: Y                   Flags: V/A
   Dynamic: Not configured
     PCEP: Not configured
   Explicit SID list:
    ID: 1                      Name: Sl1
    Weight: 1                  Forwarding index: 2149580801
    State: Up                  State(-): -
    Verification State: -
    Path MTU: 1500               Path MTU Reserved: 0
表1-18 display segment-routing ipv6 te policy命令显示信息描述表
Name/ID
Color
Endpoint
SRv6 TE Policy的目的节点的IPv6地址,none表示未配置
Name from BGP
通过BGP获取到的SRv6 TE Policy的名称,未获取到时显示为空
BSID
入节点的SID
Mode
BSID的模式:
·     Explicit:手工指定的
·     Dynamic:动态获取的
·     None:未配置
BSID的类型:
·     None:未配置
·     Type 2:IPv6地址
Request state
BSID申请的状态:
·     Conflicted:BSID冲突
·     Failed:申请失败
·     Succeeded:申请成功
Current BSID
当前的BSID
Explicit BSID
静态的BSID
Dynamic BSID
动态的BSID
Reference counts
SRv6 TE Policy被引用的次数
Flags
SRv6 TE Policy的标志位:
·     A:激活SRv6 TE Policy
·     C:优选SRv6 TE Policy
·     N:正在进行SRv6 TE Policy优选
·     BA:正在申请BSID
·     BS:优选BSID
·     D:删除SRv6 TE Policy
·     CF:和已有BSID冲突
·     NC:手工配置的SRv6 TE Policy
·     NB:通过BGP路由获取到的SRv6 TE Policy
Status
SRv6 TE Policy的状态:
·     Up
·     Down
AdminStatus
SRv6 TE Policy的管理状态,即是否通过shutdown命令关闭SRv6 TE Policy:
·     Configured:已配置
·     Not configured:未配置
Up time
SRv6 TE Policy变为Up状态的时间
Down time
SRv6 TE Policy变为Down状态的时间
Hot backup
SRv6 TE Policy的热备份功能的配置状态:
·     Enabled:热备份功能处于开启状态
·     Disabled:热备份功能处于关闭状态
·     Not configured:未配置热备份功能
Statistics
SRv6 TE Policy的流量转发统计功能的配置状态:
·     Disabled:关闭
·     Enabled:开启
基于隧道转发类的SRv6 TE Policy流量转发统计功能的配置状态:
·     Enabled:开启
Path verification
SRv6 TE Policy路径连通性检查功能的配置状态:
·     Disabled:关闭
·     Enabled:开启
Drop-upon-invalid
SRv6 TE Policy失效时丢弃流量功能的配置状态:
·     Disabled:关闭
·     Enabled:开启
SRv6 TE Policy的BFD down触发Policy down功能的配置状态:
·     Disabled:关闭
·     Enabled:开启
SBFD
SRv6 TE Policy的SBFD功能的配置状态:
·     Enabled:SBFD功能处于开启状态
·     Disabled:SBFD功能处于关闭状态
·     Not configured:未配置SBFD功能
Remote
SBFD会话的远端标识符,采用缺省值时显示为“-”
SBFD template name
SBFD的模板名
备份SID列表的SBFD模板名
OAM SID
为SBFD报文或Echo BFD报文添加OAM SID
BFD Echo
SRv6 TE Policy的echo方式的BFD功能的配置状态:
·     Enable:echo方式的BFD功能处于开启状态
·     Disabled:echo方式的BFD功能处于关闭状态
·     Not configured:未配置echo方式的BFD功能
Source IPv6 address
Echo方式BFD会话的源IPv6地址
Echo template name
Echo方式BFD的模板名
Echo backup-template name
Echo方式备份SID列表的BFD模板名
Encapsulation mode
BFD和SBFD报文封装模式:
·     Encaps:普通封装模式
·     Insert:插入封装模式
·     -:未配置BFD或SBFD封装模式
Forwarding index
Association ID
Service-class
SRv6 TE Policy的转发类,采用缺省值时显示为“-”
Rate-limit
SRv6 TE Policy的限速值,未配置时显示为“-”
PCE delegation
SRv6 TE Policy的PCE托管功能的配置状态:
·     Disabled:关闭
·     Enabled:开启
SRv6 TE Policy的PCE不托管仅上报功能的配置状态:
·     Disabled:关闭
·     Enabled:开启
Encaps reduced
SRv6 TE Policy的Encaps.Red封装模式配置状态:
·     Disabled:采用Encaps封装模式
·     Enabled:采用Encaps.Red封装模式
SRv6 TE Policy封装报文时是否包含本地End.X SID:
·     Disabled:不包含
·     Enabled:包含
候选路径配置状态:
·     Configured:已配置
SRv6 TE Policy候选路径来源统计
CLI paths
手工配置的候选路径数量
BGP paths
通过BGP SRv6 Policy路由获取的候选路径数量
PCEP paths
(暂不支持)通过PCEP(Path Computation Element Protocol,路径计算单元通信协议)获取的候选路径数量
ODN paths
通过ODN创建的SRv6 TE Policy的候选路径数量
Candidate paths
SRv6 TE Policy候选路径信息
Preference
CPathName
通过BGP路由获取的候选路径名称,未获取时显示为N/A
Instance ID
BGP实例ID,0表示未从BGP对等体获取SRv6 TE Policy信息
ASN
Node address
BGP节点地址
Peer address
BGP对等体地址
手工配置SRv6 TE Policy时,Peer address为::;从BGP对等体获取SRv6 TE Policy信息时,Peer address为BGP对等体的地址
Optimal
是否为最优路径:
·     Y:表示是最优路径
·     N:表示不是最优路径
Flags
SRv6 TE Policy候选路径标志位:
·     V:有效的候选路径
·     A:激活的候选路径
·     NONE:无候选路径
Dynamic
动态计算SID列表:
·     Configured:已配置
PCEP
PCEP功能配置状态:
·     Configured:已配置
Explicit SID list
SRv6 TE Policy候选路径下的显式SID列表
ID
SID列表索引
Name
SID列表名称
Weight
SID列表在该候选路径中的权重值
Forwarding index
SID列表的转发表项索引
SID列表状态:
·     UP:SID列表处于UP状态
·     DOWN:SID列表处于DOWN状态
State(type)
SID列表的SBFD或Echo BFD会话状态:
·     Up:会话处于UP状态
·     Down:会话处于DOWN状态
·     Path Inactive:候选路径中无可用的SID列表
·     Unknown:SBFD或Echo BFD检测无结果
·     -:SBFD或Echo BFD未配置
Verification state
SID列表的故障感知校验结果:
·     Down:校验未通过
·     Up:校验通过
·     -:未配置故障感知功能
Path MTU
Path MTU值
Path MTU Reserved
Path MTU预留值
display segment-routing ipv6 te policy last-down-reason命令用来显示SRv6 TE Policy最近一次down的原因。
display segment-routing ipv6 te policy last-down-reason [ binding-sid bsid | color color-value endpoint ipv6 ipv6-address | policy-name policy-name ]
binding-sid bsid:指定BSID。bsid为IPv6地址。
color color-value endpoint ipv6 ipv6-address:指定Color属性和目的节点地址。color-value表示Color属性值,取值范围为0~4294967295。ipv6-address表示目的节点的IPv6地址。
policy-name policy-name:指定SRv6 TE Policy名称,为1~59个字符的字符串,区分大小写。
如果不指定任何参数,则显示所有SRv6 TE Policy最近一次down的原因。
# 显示名称为abc的SRv6 TE Policy最近一次down的原因。
<Sysname> display segment-routing ipv6 te policy last-down-reason policy-name abc
Name/ID: p1/1
  Color: 10
  Endpoint: 4::4
  BSID: 5000::2
  Up time: 2020-06-23 15:42:14
  Down time: 2020-06-23 15:41:15
  Down reason: Candidate path invalid segment list
  Candidate paths:
    Preference : 10
      CPathName:
      Explicit SID list:
        ID: 1                     Name: s1
        Down reason: No SRv6 SID Out
表1-19 display segment-routing ipv6 te policy last-down-reason命令显示信息描述表
Name/ID
Color
SRv6 TE Policy的Color属性,0表示未配置
Endpoint
SRv6 TE Policy的目的节点地址,None表示未配置
BSID
入节点的SID
Up time
SRv6 TE Policy UP的时间
Down time
SRv6 TE Policy DOWN的时间
Down reason
SRv6 TE Policy DOWN的原因
·     Admin down:表示该SRv6 TE Policy已经通过shutdown命令被关闭,即管理状态为关闭
·     No Endpoint:目的地址不存在
·     No candidate path:候选路径不存在
·     No valid candidate path:候选路径下未指定Segment list
·     Candidate path invalid segment list:候选路径下所有SID列表处于Down状态
·     Policy unconfigured:SRv6 TE Policy正在被删除
·     Internal error:内部错误
Candidate paths
Preference
候选路径的优先级
CPathName
候选路径的名称,未从BGP获取到时显示为空
Explicit SID List
SRv6 TE Policy候选路径下的SID列表
ID
SID列表索引
Name
SID列表名称
Up time
SID列表UP的时间
Down time
SID列表DOWN的时间
Down reason
SID列表DOWN的原因
·     No SID list:SID列表不存在
·     No SRv6 SID Out:SID列表中首个SID无对应出接口
display segment-routing ipv6 te policy statistics命令用来显示SRv6 TE Policy的统计信息。
# 显示SRv6 TE Policy的统计信息。
<Sysname> display segment-routing ipv6 te policy statistics
         IPv6 TE Policy Database Statistics
Total policies: 1 (1 up 0 down)
    Configured: 1 (1 up 0 down)
    From BGP: 0 (Added 0 deleted 0   0 up 0 down)
    From ODN: 0 (Added 0 deleted 0   0 up 0 down)
From PCE: 0 (Added 0 deleted 0   0 up 0 down)
Total candidate paths: 1
    Configured: 1
    From BGP: 0 (Added 0 deleted 0)
    From ODN: 0 (Added 0 deleted 0)
    From PCE: 0 (Added 0 deleted 0)
Total SID lists: 1 (1 up 0 down)
    From BGP: 0 (0 up 0 down)
SRv6-TE policy group resource information:
  Max resources: 1024
  Used resources: 0
  Upper threshold: 717 (70%)
  Lower threshold: 102 (10%)
SRv6-TE policy resource information:
  Max resources: 1024
  Used resources: 1
  Upper threshold: 512 (50%)
SID list resource information:
  Max resources: 4096
  Used resources: 1
  Upper threshold: 3277 (80%)
  Lower threshold: 1638 (40%)
Forwarding path resource information:
  Max resources: 65535
  Used resources: 1
  Upper threshold: 26214 (40%)
  Lower threshold: 13107 (20%)
表1-20 display segment-routing ipv6 te policy statistics命令显示信息描述表
SRv6 TE Policy的统计信息
Total policies
SRv6 TE Policy总个数:
·     up:处于up状态的SRv6 TE Policy的个数
·     down:处于down状态的SRv6 TE Policy的个数
Configured
手工配置的个数:
From BGP
通过BGP路由学习的个数
·     Added:BGP添加个数
·     deleted:BGP删除个数
From ODN
通过ODN生成的个数
·     Added:ODN添加个数
·     deleted:ODN删除个数
From PCE
通过PCE生成的个数
·     Added:PCE添加个数
·     deleted:PCE删除个数
SRv6 TE Policy候选路径总个数
Total SID lists
SID列表总个数
SRv6 TE Policy组的资源信息
Max resources
资源总数
Used resources
当前占用数量
Upper threshold
资源阈值上限
Lower threshold
资源阈值下限
SRv6 TE Policy的资源信息
SID列表的资源信息
转发路径的资源信息
display segment-routing ipv6 te policy status命令用来显示SRv6 TE Policy的状态。
display segment-routing ipv6 te policy status [ policy-name policy-name ]
policy-name policy-name:指定SRv6 TE Policy名称,为1~59个字符的字符串,区分大小写。如果未指定本参数,则显示所有SRv6 TE Policy的状态。
当上一个检查项状态为Failed时,其他检查项显示为“-”,表示不检查。
# 显示所有SRv6 TE Policy的状态。
<Sysname> display segment-routing ipv6 te policy status
Name/ID: p1/0
Status: Up
  Check admin status                  : Passed
  Check for endpoint & color          : Passed
  Check for segment list              : Passed
  Check valid candidate paths         : Passed
  Check for BSIDs                     : Passed
表1-21 display segment-routing ipv6 te policy status命令显示信息描述表
Name/ID
Status
SRv6 TE Policy的状态:
·     Up
·     Down
Check admin status
检查SRv6 TE Policy下是否配置了shutdown:
·     Passed:检查结果为通过,即未配置
·     Failed:检查结果为失败,即已配置
检查SRv6 TE Policy下是否存在目的地址和Color:
·     Passed:检查结果为通过,即存在
·     Failed:检查结果为失败,即不存在
Check for segment lists
检查SRv6 TE Policy的候选路径下是否存在有效的SID列表:
检查SRv6 TE Policy是否存在UP状态的候选路径:
Check for BSIDs
检查SRv6 TE Policy下是否存在Binding SID:
display segment-routing ipv6 te policy-group命令用来显示SRv6 TE Policy组的信息。
display segment-routing ipv6 te policy-group [ group-id ] [ verbose ]
group-id:显示指定SRv6 TE Policy组的信息。group-id为SRv6 TE Policy组ID,取值范围为1~4294967295。如果未指定本参数,则显示所有SRv6 TE Policy组的信息。
verbose:显示SRv6 TE Policy组的详细信息。如果未指定本参数,则显示SRv6 TE Policy组的简要信息。
# 显示所有SRv6 TE Policy组的简要信息。
<Sysname> display segment-routing ipv6 te policy-group
Total number of policy groups: 1
GroupID      GroupState    UPMappings     TotalMappings
10           Up            26             26
# 显示所有SRv6 TE Policy组的详细信息。
<Sysname> display segment-routing ipv6 te policy-group verbose
GroupID: 10                         GroupState: Up
GroupNID: 2151677953                Referenced: 1
Flags:  A                           Group type: Dynamic
Group color: 100
StateChangeTime: 2021-03-18 09:57:43
Endpoint: 4::4
UP/Total Mappings: 26/26
  Color       Type       DSCP
  10          IPv4       10, 12, 14, 16, 18, 20
表1-22 display segment-routing ipv6 te policy-group命令显示信息描述表
SRv6 TE Policy组的总个数
GroupID
SRv6 TE Policy组ID
GroupState
SRv6 TE Policy组状态:
·     Down
·     Up
UPMappings
SRv6 TE Policy组中Color和DSCP映射关系生效数量
TotalMappings
SRv6 TE Policy组中Color和DSCP映射关系总数量
GroupNID
SRv6 TE Policy组的转发表项索引
Referenced
SRv6 TE Policy组被引用的次数
Flags
SRv6 TE Policy组的标志位:
·     A:分配SRv6 TE Policy组的转发表项索引
·     F:下发SRv6 TE Policy组的转发表项
·     W:等待分配SRv6 TE Policy组的转发表项索引
·     D:删除SRv6 TE Policy组
·     None:SRv6 TE Policy组处于初始状态或者稳定状态
Group type
SRv6 TE Policy组的类型,取值包括:
·     Static:静态创建
·     Dynamic:动态创建
Group color
SRv6 TE Policy组的Color值
StateChangeTime
SRv6 TE Policy组状态变化的时间
Endpoint
SRv6 TE Policy组的目的节点地址,None表示未配置
UP/Total Mappings
SRv6 TE Policy组中有效的Color和DSCP映射关系数量和配置的Color和DSCP映射关系总数量
Color
Color值
报文类型:
·     IPv4
·     IPv6
DSCP
DSCP优先级
display segment-routing ipv6 te policy-group last-down-reason命令用来显示SRv6 TE Policy组最近一次down的原因。
display segment-routing ipv6 te policy-group last-down-reason [ endpoint ipv6-address color color-value | group-id ]
endpoint ipv6-address color color-value:显示指定Color属性和目的节点的SRv6 TE Policy信息。color-value取值范围为0~4294967295,ipv6-address表示目的节点的IPv6地址。
group-id:显示指定SRv6 TE Policy组最近一次down的原因。group-id为SRv6 TE Policy组ID,取值范围为1~4294967295。如果未指定本参数,则显示所有SRv6 TE Policy组最近一次down的原因。
# 显示SRv6 TE Policy组1最近一次down的原因。
<Sysname> display segment-routing ipv6 te policy-group last-down-reason 10
Group ID   : 10                        Group type : Static
Group color: 100                       Endpoint   : 4::4
Group NID  : 2151677956
Create time: 2021-03-18 09:57:43
Up time    : -
Down time  : 2021-03-18 09:57:43
Down reason: No active SRv6-TE Policies
  Color: 20                     Address family: IPv4
    Up time    : 2021-03-18 01:52:20.785
    Down time  : 2021-03-18 09:59:23
    Down reason: No endpoint
表1-23 display segment-routing ipv6 te policy-group last-down-reason命令显示信息描述表
Group ID
SRv6 TE Policy组的ID
Group type
SRv6 TE Polic组的类型:
·     Static:静态创建
·     Dynamic:动态创建
Group color
Endpoint
Group NID
Create time
SRv6 TE Policy组创建的时间
Up time
SRv6 TE Policy组UP的时间
Down time
SRv6 TE Policy组DOWN的时间
Down reason
SRv6 TE Policy组DOWN的原因:
·     No endpoint:没有配置SRv6 TE Policy组的目的节点地址
·     No color-DSCP mappings:没有配置Color和DSCP映射关系
·     No active SRv6-TE policies:SRv6 TE Policy组中不存在有效的SRv6 TE Policy
Color
与DSCP进行映射的Color值
Address family type
地址族:
·     IPv4
·     IPv6
Up time
Color和DSCP映射关系生效的时间
Down time
Color和DSCP映射关系失效的时间
Down reason
Color和DSCP映射关系失效的原因:
·     No endpoint:没有配置SRv6 TE Policy的目的节点地址
·     The SRv6-TE policy is used by another group:Color对应的SRv6 TE Policy已经被其他SRv6 TE Policy组使用
·     SRv6-TE policy does't exist:SRv6 TE Policy不存在
·     SRv6-TE policy down:Color对应的SRv6 TE Policy处于down状态
display segment-routing ipv6 te policy-group statistics命令用来显示SRv6 TE Policy组的统计信息。
# 显示SRv6 TE Policy组的统计信息。
<Sysname> display segment-routing ipv6 te policy-group statistics
Statistics type          Total                Up
Dynamic groups           3                    1
Static groups            2                    1
Color-DSCP mappings      2                    2
表1-24 display segment-routing ipv6 te policy-group statistics命令显示信息描述表
Statistics type
统计对象:
·     Dynamic groups:动态创建的SRv6 TE Policy组
·     Static groups:静态创建的SRv6 TE Policy组
·     Color-DSCP mappings:所有SRv6 TE Policy组中的Color和DSCP映射关系
Total
总数量
UP
生效的数量
display segment-routing ipv6 te sbfd命令用来显示SRv6 TE Policy的SBFD信息。
display segment-routing ipv6 te sbfd [ down | policy { { color color-value | end-point ipv6 ipv6-address } * | name policy-name } | up ]
down:显示状态为down的SRv6 TE Policy的SBFD信息。
policy:显示指定SRv6 TE Policy的SBFD信息。
up:显示状态为up的SRv6 TE Policy的SBFD信息。
如果未指定down、policy和up参数,则显示所有SRv6 TE Policy的SBFD信息。
# 显示所有SRv6 TE Policy的SBFD信息。
<Sysname> display segment-routing ipv6 te sbfd
 Color: 10
 Endpoint: 4::4
 Policy name: p1
 State: Down
   Nid: 2149580801
   BFD type: SBFD
   Remote Discr: 100
   State: Down
   Timer: 30
   VPN index: 0
   Template name: abc
表1-25 display segment-routing ipv6 te sbfd命令显示信息描述表
Color
Endpoint
Policy name
SRv6 TE Policy的名称
SBFD会话状态:
·     Up
·     Down
·     Delete
Nid
SID列表的转发表项索引
BFD type
BFD类型,目前仅支持SBFD
Encapsulation mode
SBFD报文封装模式:
·     Encaps:普通封装模式
·     Insert:插入封装模式
·     -:未配置SBFD封装模式
Remote Discr
远端标识符
Timer
SBFD会话定时器,单位为秒
VPN index
VPN实例索引
Template name
SBFD的模板名
display segment-routing ipv6 te segment-list命令用来显示SRv6 TE的SID列表信息。
display segment-routing ipv6 te segment-list [ name seglist-name | id id-value ]
name segment-list-name:显示指定名称的SID列表信息。segment-list-name表示SID列表名称,为1~128个字符的字符串,区分大小写。
id id-value:显示指定ID的SID列表信息。id-value为SID列表的ID,取值范围为1~4294967295。
如果未指定name和id参数,则显示SRv6 TE的所有SID列表信息。
SID列表的ID可以通过display segment-routing ipv6 te policy命令查看。
# 显示SRv6 TE的所有SID列表信息。
<Sysname> display segment-routing ipv6 te segment-list
Total Segment lists: 1
Name/ID: A/1
 Origin: CLI
 Status: Up
 Verification State: Down
 Nodes: 1
  Index    : 1                            SID: 1::2
  Status   : Up                    TopoStatus: Nonexistent
  Type     : Type 2                     Flags: None
  Coc Type : -           Common prefix length: 0
表1-26 display segment-routing ipv6 te segment-list命令显示信息描述表
Total Segment lists
SID列表个数
Name/ID
SID列表名称/ID
Origin
SID列表的配置来源:
·     CLI:手工配置
·     BGP:BGP配置下发
·     PCE:PCE配置下发
·     -:无有效来源
Status
SID列表的状态:
·     Down:SID列表处于down状态
·     Up:SID列表处于up状态
Verification State
SID列表的故障感知校验结果:
·     Down:校验未通过
·     Up:校验通过
TopoStatus
SID在IGP拓扑中的存在情况:
·     Existent:IGP拓扑中存在该SID
·     Nonexistent:IGP拓扑中不存在该SID
Nodes
SID列表中节点数量
Index
节点索引值
SID
节点的SID,即IPv6地址
节点的SID类型:
·     None:未配置
·     Type 2:IPv6地址
Flags
节点的标志位,当前未定义,显示为None
COC type
SID的压缩类型,目前仅支持COC32,表示32位压缩
SID未压缩时,显示为“-”
G-SID的公共前缀长度
display segment-routing ipv6 te source-sid命令用来显示从LS数据库中收集到的SRv6 SID的信息。
display segment-routing ipv6 te source-sid [ end | end-x | sid ]
end:显示End SID信息。
end-x:显示End.X SID信息。
sid:显示指定的SRv6 SID信息。
如果未指定任何参数,则显示从LS数据库中收集到的所有SRv6 SID的信息。
# 显示从LS数据库中收集到的所有SRv6 SID的信息。
<Sysname> display segment-routing ipv6 te source-sid
  SID         : 11::1:0:8, Count: 1
   Type       : End.X(LAN), Topology ID: 0
   Instance ID: 0
    Source    : IS-IS, ProcID 100, IS-Level-1
    Node      : 0000.0000.0019.00
    Local     : 0000.0000.0019.00
    Peer      : 0000.0000.0022.01
  SID         : 12:1:2:3:0:1::, Count: 2
   Type       : End, Topology ID: 0
   Instance ID: 0
   Type       : End, Topology ID: 2
   Instance ID: 0
  SID         : 12:1:2:3:0:6::, Count: 2
   Type       : End.X, Topology ID: 0
   Instance ID: 0
    Local     : 2001:1::2
    Peer      : 2001:1::16
   Type       : End.X, Topology ID: 2
   Instance ID: 0
    Local     : 2001:1::2
    Peer      : 2001:1::16
表1-27 display segment-routing ipv6 te source-sid命令显示信息描述表
SID
SRv6 SID值
Count
本SID的发布源的个数
SID类型:
·     End
·     End.X
·     End.X(LAN)
Topology ID
拓扑ID
Instance ID
实例ID
Source
SID来源:
·     ISIS
·     OSPFV3
·     BGP
·     SRPOLICY
ProcID
进程ID
IS-Level-X
节点的level级别:
·     IS-Level-1
·     IS-Level-2
Node
SID发布源所在节点
Local
当SID的类型是End.X时,显示该SID所绑定本端接口所属的IS-IS进程的System ID;当链路类型是P2P类型,且使能IS-IS进程的IPv6链路属性的时候,显示该SID所绑定本端接口下的IPv6地址
Peer
当SID的类型是End.X时,显示该SID所绑定邻居接口所属的IS-IS进程的System ID;当链路类型是P2P类型,且使能IS-IS进程的IPv6链路属性的时候,显示该SID所绑定邻居接口下的IPv6地址
1.1.38  distribute bgp-ls
distribute bgp-ls命令用来配置设备允许将SRv6 TE Policy的候选路径信息上报BGP-LS。
undo distribute bgp-ls命令用来恢复缺省情况。
distribute bgp-ls
不允许将SRv6 TE Policy的候选路径信息上报BGP-LS。
SRv6 TE视图
配置本命令后,设备会将SRv6 TE Policy的候选路径信息上报给BGP-LS,通过BGP-LS路由对外发布,以满足需要知道SRv6 TE Policy路径信息的应用的需求。
# 配置设备允许将SRv6 TE Policy的候选路径信息上报BGP-LS。
[Sysname] segment-routing-ipv6
[Sysname-srv6-te] distribute bgp-ls
1.1.39  drop-upon-invalid enable
drop-upon-invalid enable命令用来开启SRv6 TE Policy在Policy失效时丢弃流量的功能。
undo drop-upon-invalid enable命令用来关闭SRv6 TE Policy在Policy失效时丢弃流量的功能。
SRv6 TE Policy在Policy失效时丢弃流量功能处于关闭状态。
SRv6 TE Policy视图
如果希望限定流量仅通过SRv6 TE Policy隧道转发,可以开启本功能。
缺省情况下,转发报文的SRv6 TE Policy的所有候选路径都失效时,设备会通过传统IPv6转发方式转发报文,即根据目的IPv6地址查找IPv6路由表转发报文。
当配置drop-upon-invalid enable命令后,如果用于转发报文的SRv6 TE Policy的所有候选路径都失效,设备会丢弃该报文,不会通过传统IPv6转发方式转发报文。
当display segment-routing ipv6 te policy命令中Request state字段显示为Falied(即BSID申请失败)、Conflicted(BSID冲突)或者Forwarding index字段显示为0(即SRv6 TE Policy无效)时,drop-upon-invalid enable命令不生效。
# 配置SRv6 TE Policy a1在失效时丢弃流量。
[Sysname-srv6-te-policy-a1] drop-upon-invalid enable
1.1.40  dynamic (SRv6 TE Policy Path Preference view)
dynamic命令用来创建并进入SRv6 TE Policy Path Preference动态配置视图。如果已经存在SRv6 TE Policy Path Preference动态配置视图,则直接进入SRv6 TE Policy Path Preference 动态配置视图。
undo dynamic命令用来删除SRv6 TE Policy Path Preference动态配置视图及该视图下的所有配置。
dynamic
undo dynamic
不存在SRv6 TE Policy Path Preference动态配置视图。
SRv6 TE Policy Path Preference视图
在SRv6 TE Policy Path Preference动态配置视图下可以配置动态生成SRv6 TE Policy候选路径的SID列表。
# 创建并进入SRv6 TE Policy Path Preference动态配置视图。
[Sysname-srv6-te-policy-1] candidate-paths
[Sysname-srv6-te-policy-1-path] preference 20
[Sysname-srv6-te-policy-1-path-pref-20] dynamic
[Sysname-srv6-te-policy-1-path-pref-20-dyna]
1.1.41  dynamic (SRv6 TE-ODN view)
dynamic命令用来创建并进入SRv6 TE-ODN动态配置视图。如果SRv6 TE-ODN动态配置视图已经存在,则直接进入SRv6 TE-ODN动态配置视图。
undo dynamic命令用来删除SRv6 TE-ODN动态配置视图及该视图下的所有配置。
dynamic
undo dynamic
不存在SRv6 TE-ODN动态配置视图。
SRv6 TE-ODN视图
在SRv6 TE-ODN动态配置视图下可以配置SRv6 TE Policy的生成策略和SRv6 TE Policy候选路径SID列表的动态生成。
# 创建并进入SRv6 TE-ODN动态配置视图。
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] traffic-engineering
[Sysname-srv6-te-odn-1] dynamic
[Sysname-srv6-te-odn-1-dynamic]
1.1.42  encapsulation-mode encaps include local-end.x
encapsulation-mode encaps include local-end.x命令用来配置通过SRv6 TE Policy转发报文时封装的SRH中是否包含本地End.X SID。
undo encapsulation-mode encaps include local-end.x命令用来恢复缺省情况。
encapsulation-mode encaps include local-end.x [ disable ]
未配置通过SRv6 TE Policy转发报文时封装的SRH中是否包含本地End.X SID,以SRv6 TE视图下的配置为准。
SRv6 TE Policy视图
disable:配置通过SRv6 TE Policy转发报文时封装的SRH中不包含本地End.X SID。如果未指定本参数,则通过SRv6 TE Policy转发报文时封装的SRH中包含本地End.X SID。
通过BSID方式引流到SRv6 TE Policy时,缺省情况下,如果头节点的SRv6 SID是End.X SID,则不会将该SID封装到SRH中。配置本命令后,封装SRH时可以添加本地的End.X SID。
在SRH中添加本地的End.X SID后,可以通过报文中的SRH获取完整的路径信息,即获取到SRv6转发路径上所有SRv6节点的信息。
SRv6 TE视图和SRv6 TE Policy视图下均可以配置通过SRv6 TE Policy转发报文时封装的SRH中是否包含本地End.X SID。SRv6 TE视图的配置对所有SRv6 TE Policy都有效,而SRv6 TE Policy视图的配置只对当前SRv6 TE Policy有效。对于一个SRv6 TE Policy来说,优先采用该SRv6 TE Policy内的配置,只有该SRv6 TE Policy内未进行配置时,才采用SRv6 TE视图的配置。
配置了本功能的同时,在SRv6 TE Policy视图下配置encapsulation-mode encaps reduced命令指定SRv6 TE Policy的封装模式为普通封装的简化模式时,本功能优先生效。
# 配置通过SRv6 TE Policy转发报文时封装的SRH中包含本地End.X SID。
[Sysname-srv6-te-policy-1] encapsulation-mode encaps include local-end.x
·     srv6-policy encapsulation-mode encaps include local-end.x
1.1.43  encapsulation-mode encaps reduced
encapsulation-mode encaps reduced命令用来配置SRv6 TE Policy的封装模式。
undo encapsulation-mode encaps reduced命令用来恢复缺省情况。
encapsulation-mode encaps reduced [ disable ]
未配置SRv6 TE Policy的封装模式,以SRv6 TE视图下的配置为准。
SRv6 TE Policy视图
disable:配置SRv6 TE Policy采用Encaps封装模式。如果未指定本参数,则SRv6 TE Policy采用Encaps.Red封装模式。
通过BSID引流时,如果报文的目的IPv6地址和BSID相同,则报文通过对应的SRv6 TE Policy转发。此时,需要为报文封装SRv6 TE Policy的SID列表,封装模式包括:
·     Encaps方式:普通封装模式。在原始报文的基础上封装IPv6头和SRH时,SRv6 TE Policy的SID列表中的所有SID均封装在SRH中。
¡     IPv6头的目的IPv6地址为SRv6 TE Policy的SID列表中的第一个IPv6地址,源IPv6地址为encapsulation source-address命令指定的IPv6地址。
·     Encaps.Red方式:简化封装模式。在原始报文的基础上封装IPv6头和SRH时,SRv6 TE Policy的SID列表中的第一个SID不封装在SRH中,其他SID封装到SRH中,以便减少SRH的长度。
¡     IPv6头的目的IPv6地址为SRv6 TE Policy的SID列表中的第一个SID,源IPv6地址为encapsulation source-address命令指定的IPv6地址。
¡     SRH包含SRv6 TE Policy的SID列表中除第一个SID外所有SID信息。
SRv6 TE视图和SRv6 TE Policy视图下均可以配置SRv6 TE Policy的封装模式。SRv6 TE视图的配置对所有SRv6 TE Policy都有效,而SRv6 TE Policy视图的配置只对当前SRv6 TE Policy有效。对于一个SRv6 TE Policy来说,优先采用该SRv6 TE Policy内的配置,只有该SRv6 TE Policy内未进行配置时,才采用SRv6 TE视图的配置。
配置本功能并指定封装模式为普通封装的简化模式,同时,在SRv6 TE Policy视图下又配置了encapsulation-mode encaps include local-end.x命令,则encapsulation-mode encaps include local-end.x命令生效。
# 配置SRv6 TE Policy 1采用Encaps.Red封装模式。
[Sysname-srv6-te] policy 1
[Sysname-srv6-te-policy-1] encapsulation-mode encaps reduced
·     encapsulation source-address(Segment Routing命令参考/SRv6 VPN)
·     srv6-policy encapsulation-mode encaps reduced
1.1.44  end-point
end-point命令用来配置SRv6 TE Policy组的目的节点地址。
undo end-point命令用来恢复缺省情况。
undo end-point ipv6
未配置SRv6 TE Policy组的目的节点地址。
SRv6 TE Policy组视图
ipv6 ipv6-address:指定SRv6 TE Policy组的目的节点地址。
SRv6 TE Policy组中所有SRv6 TE Policy的目的节点地址必须与该SRv6 TE Policy组的目的节点地址相同。
多次执行本命令,最后一次执行的命令生效。
# 配置SRv6 TE Policy组的目的节点地址为100::2。
[Sysname-srv6-te-policy-group-10] end-point ipv6 100::2
1.1.45  explicit segment-list
explicit segment-list命令用来为指定优先级的SRv6 TE Policy候选路径配置SID列表。
undo explicit segment-list命令用来删除SRv6 TE Policy候选路径的SID列表或恢复SID列表的缺省权重值、恢复SID列表的Path MTU为全局值。
explicit segment-list segment-list-name [ path-mtu mtu-value | weight weight-value ] *
undo explicit segment-list segment-list-name [ path-mtu | weight ]
指定优先级的SR-MPLS TE Policy候选路径下不存在SID列表。
SRv6 Policy Path Preference视图
segment-list-name:SID列表名称,为1~128个字符的字符串,区分大小写。
path-mtu mtu-value:SID列表的Path MTU,单位为字节。取值范围为1280~9600。如果未指定本参数,则以SRv6视图下配置的全局Path MTU值为准。
weight weight-value:SID列表的权重值,取值范围为1~4294967295,缺省值为1。
当通过指定SRv6 TE Policy转发流量时,会选取优先级最高的有效候选路径下配置的SID列表作为该流量的转发路径。
同一SRv6 TE Policy Path Preference视图下可以配置多个SID列表。多个SID列表均可以转发流量,实现负载分担。通过为SID列表指定不同的权重,可以按照比例对流量进行转发。例如,创建SID列表a、b、c,配置其权重分别为x、y、z,此时SID列表a转发流量的比例为x/(x+y+z)。
对于同一SID列表,多次指定其权重值,最后一次指定的权重值生效。
SRv6视图和SRv6 TE Policy Path Preference视图下均可以配置SR-MPLS TE Policy的Path MTU值。SRv6视图的配置对所有SR-MPLS TE Policy的候选路径都有效,而SRv6 TE Policy Path Preference视图的配置只对当前SRv6 TE Policy候选路径的SID列表标识的路径有效。对于一个SRv6 TE Policy SID列表标识的路径来说,优先采用该SRv6 TE Policy Path Preference视图内的配置,只有该SRv6 TE Policy Path Preference视图内未进行配置时,才采用SRv6视图的配置。
SID列表的Path MTU减去全局配置的Path MTU预留值,就是SID列表的Active MTU。Active MTU再和物理接口的IPv6 MTU比较,二者中的较小者为源节点发送报文时实际采用的MTU。Active Path MTU必须大于等于1280字节。
# 为SRv6 TE Policy中优先级为20的候选路径配置SID列表为abc,其权重为20。
[Sysname-srv6-te-policy-a1] candidate-paths
[Sysname-srv6-te-policy-a1-path] preference 20
[Sysname-srv6-te-policy-a1-path-pref-20] explicit segment-list abc weight 20
·     path-mtu(Segment Routing命令参考/SRv6)
·     segment-list
1.1.46  fast-reroute mirror delete-delay
fast-reroute mirror delete-delay命令用来配置Mirror FRR的延迟删除时间。
undo fast-reroute mirror delete-delay命令用来恢复缺省情况。
fast-reroute mirror delete-delay delete-delay-time
Mirror FRR延迟删除时间为60秒。
IS-IS IPv6单播地址族视图
OSPFv3视图
delete-delay-time:延迟删除时间,取值范围为1~21845,单位为秒。
在尾节点保护场景中,切换到Mirror FRR路径后,流量沿着Mirror FRR路径转发。当中间节点完成路由收敛后,会删除Mirror FRR路径。如果此时头节点未完成路径切换,仍将流量转发给中间节点,由于中间节点上不存在Mirror FRR路径,流量会被丢弃。
为了避免上述情况,可以在中间节点上配置Mirror FRR的延迟删除时间,延迟删除Mirror FRR路由,使流量沿着Mirror FRR路径转发,避免丢包。
# IS-SI进程1下配置Mirror FRR的延迟删除时间为100秒。
[Sysname] isis 1
[Sysname-isis-1] address-family ipv6
[Sysname-isis-1-ipv6] fast-reroute mirror delete-delay 100
# 在OSPFv3进程1下配置Mirror FRR的延迟删除时间为100秒。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] fast-reroute mirror delete-delay 100
·     fast-reroute mirror enable
1.1.47  fast-reroute mirror enable
fast-reroute mirror enable命令用来开启尾节点保护功能。
undo fast-reroute mirror enable命令用来关闭尾节点保护功能。
尾节点保护功能处于关闭状态。
IS-IS IPv6单播地址族视图
OSPFv3视图
在某个SRv6节点上开启尾节点保护功能后,该节点可以根据收到的IS-ISv6路由中携带的End.M SID,计算到达尾节点的备份路径信息,即Mirror FRR路径信息。当尾节点故障后,中间节点可以根据End.M SID,将流量转发到对尾节点进行保护的节点处理,避免流量丢失。
# 开启IS-IS尾节点保护功能。
[Sysname] isis 1
[Sysname-isis-1-ipv6] fast-reroute mirror enable
# 开启OSPFv3尾节点保护功能。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] fast-reroute mirror enable
1.1.48  forwarding statistics
forwarding statistics命令用来配置SRv6 TE Policy的流量转发统计功能。
undo forwarding statistics命令用来恢复缺省情况。
forwarding statistics { disable | [ service-class ] enable }
未配置SRv6 TE Policy的流量转发统计功能,以SRv6 TE视图下的配置为准。
SRv6 TE Policy视图
disable:关闭SRv6 TE Policy的流量转发统计功能。
enable:开启SRv6 TE Policy的流量转发统计功能。
service-class:开启基于隧道转发类的SRv6 TE Policy流量统计功能,即不仅对SRv6 TE Policy隧道转发的总流量进行统计,还会对隧道转发的每个隧道转发类的流量分别进行统计。如果不指定本参数,则只对SRv6 TE Policy隧道转发的总流量进行统计。
SRv6 TE视图和SRv6 TE Policy视图下均可以配置SRv6 TE Policy的流量转发统计功能。SRv6 TE视图的配置对所有SRv6 TE Policy都有效,而SRv6 TE Policy视图的配置只对当前SRv6 TE Policy有效。对于一个SRv6 TE Policy来说,优先采用该SRv6 TE Policy内的配置,只有该SRv6 TE Policy内未进行配置时,才采用SRv6 TE视图的配置。
配置了本命令对SRv6 TE Policy隧道转发类的流量进行统计后,再切换到仅对SRv6 TE Policy隧道转发的总流量进行统计,需要执行reset segment-routing ipv6 te forwarding statistics命令清除流量转发统计信息,否则字节数统计不准确。
# 开启SRv6 TE Policy 1的流量转发统计功能。
[Sysname-srv6-te-policy-1] forwarding statistics enable
·     display segment-routing ipv6 te forwarding
·     reset segment-routing ipv6 te forwarding statistics
·     srv6-policy forwarding statistic enable
·     srv6-policy forwarding statistic interval
1.1.49  forward-type
forward-type命令用来创建转发类型,并进入对应的转发类型视图。如果指定的转发类型已经存在,则直接进入该转发类型视图。
undo forward-type命令用来恢复缺省情况。
forward-type dscp
undo forward-type dscp
不存在转发类型,由ODN自动创建的SRv6 TE Policy组无法引流。
dscp:配置转发类型为DSCP,即根据DSCP引流。
通过本命令可以指定由ODN自动创建的SRv6 TE Policy组的引流方式。目前SRv6 TE Policy组仅支持基于DSCP引流,即引流过程为:
(1)     根据报文的DSCP值查找与其关联的Color属性;
(2)     通过Color属性匹配到SRv6 TE Policy组中的某个SRv6 TE Policy;
(3)     携带指定DSCP的报文通过指定SRv6 TE Policy转发。
# 创建转发类型DSCP,并进入DSCP转发类型视图。
1.1.50  group-color
group-color命令用来配置SRv6 TE Policy组的Color值。
undo group-color命令用来恢复缺省情况。
group-color color-value
undo group-color
未配置SRv6 TE Policy组的Color值。
SRv6 TE Policy组视图
color-value:Color值,取值范围为0~4294967295。
通过本命令指定SRv6 TE Policy组的Color值后,可以通过Color引流方式将流量引入指定SRv6 TE Policy组。
SRv6 TE Policy组的Color值和SRv6 TE Policy组中SRv6 TE Policy的Color值可以相同,也可以不同,二者互不影响。
# 配置SRv6 TE Policy组的Color值为1。
[Sysname-srv6-te-policy-group-1] group-color 1
1.1.51  import-route sr-policy
import-route sr-policy命令用来将BGP IPv6 SR Policy路由引入到BGP路由表中,以便通过BGP发布引入的路由。
undo import-route sr-policy命令用来恢复缺省情况。
BGP不会引入BGP IPv6 SR Policy路由。
BGP IPv6 SR Policy地址族视图
配置本命令后,设备将本地的BGP IPv6 SR Policy路由引入到BGP路由表中,并将该路由发布给IBGP对等体,以便对等体根据BGP IPv6 SR Policy转发流量。
# 在BGP IPv6 SR Policy地址族视图下,引入BGP IPv6 SR Policy路由。
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv6 sr-policy
[Sysname-bgp-default-srpolicy-ipv6] import-route sr-policy
1.1.52  index
index命令用来在SID列表中添加节点。
undo index命令用来删除SID列表中指定节点。
index index-number ipv6 ipv6-address
index index-number coc32 ipv6 ipv6-address common-prefix-length
undo index index-number
SID列表中不存在任何节点。
SID列表视图
index-number:SID列表的节点索引值,取值范围为1~65535。
ipv6 ipv6-address:SID列表中指定节点对应的IPv6地址。
coc32:添加COC标识,表示当前节点的下一节点为32bits G-SID。
common-prefix-length:下一个G-SID的公共前缀长度,取值范围为1~94。
在SID列表中添加G-SID时,本命令common-prefix-length参数配置值必须与下一节点所属的Locator段中的公共前缀长度一致。
在SID列表中添加G-SID时,需要保证:
·     G-SID的前一对应的SRv6 SID必须是End(COC32) SID或End.X(COC32) SID。
·     最后一个节点对应的SRv6 SID不能携带COC标识,即倒数第二个节点不能通过index index-number coc32 ipv6命令指定SRv6 SID。
# 在SID列表abc中添加节点,其节点索引为1,IPv6地址为1000::1。
[Sysname-srv6-te] segment-list abc
[Sysname-srv6-te-sl-abc] index 1 ipv6 1000::1
# 在SID列表text中添加节点,其中:
·     节点索引为10,IPv6地址为100::1,下一节点为32bits G-SID,G-SID的公共前缀长度为64。
·     节点索引为20,IPv6地址为200::1:0:0,下一节点为32bits G-SID,G-SID的公共前缀长度为64。
·     节点索引为30,IPv6地址为200::2:0:0,下一节点为32bits G-SID,G-SID的公共前缀长度为64。
·     节点索引为40,IPv6地址为200::3:0:0,下一节点为32bits G-SID,G-SID的公共前缀长度为64。
·     节点索引为50,IPv6地址为200::4:0:0。
·     节点索引为60,IPv6地址为300::3。
[Sysname-srv6-te] segment-list text
[Sysname-srv6-te-sl-abc] index 10 coc32 ipv6 100::1 64
[Sysname-srv6-te-sl-abc] index 20 coc32 ipv6 200::1:0:0 64
[Sysname-srv6-te-sl-abc] index 30 coc32 ipv6 200::2:0:0 64
[Sysname-srv6-te-sl-abc] index 40 coc32 ipv6 200::3:0:0:0 64
[Sysname-srv6-te-sl-abc] index 50 ipv6 200::4:0:0
[Sysname-srv6-te-sl-abc] index 60 ipv6 300::3
·     locator(Segment Routing命令参考/SRv6)
·     srv6 compress enable(Segment Routing命令参考/SRv6)
1.1.53  mirror remote-sid delete-delay
mirror remote-sid delete-delay命令用来配置远端SRv6 SID与VPN实例/交叉连接/VSI映射表的延迟删除时间。
undo mirror remote-sid delete-delay命令用来恢复缺省情况。
mirror remote-sid delete-delay delete-delay-time
远端SRv6 SID与VPN实例/交叉连接/VSI映射表的延迟删除时间为60秒。
SRv6视图
在尾节点保护场景中,当尾节点故障时,保护节点与尾节点之间邻居中断,会导致保护节点从尾节点收到的BGP路由删除,进而导致远端SRv6 SID与VPN实例/交叉连接/VSI映射表被删除,造成丢包。为了避免上述情况,可以在对尾节点进行保护的节点上延迟删除远端SRv6 SID与VPN实例/交叉连接/VSI映射表,在头节点感知到尾节点故障计算出新的转发路径前,保证流量通过保护节点转发,避免丢包。
# 配置远端SRv6 SID与VPN实例/交叉连接/VSI映射表的延迟删除时间为100秒。
[Sysname-segment-routing-ipv6] mirror remote-sid delete-delay 100
1.1.54  on-demand
on-demand 命令用来创建SRv6 TE Policy的ODN(On-Demand Next-Hop,按需下一跳)模板,并进入SRv6 TE-ODN视图。如果指定的ODN模板已经存在,则直接进入该SRv6 TE-ODN视图。
undo on-demand命令用来删除指定的ODN模板及SRv6 TE-ODN视图下的所有配置。
on-demand color color-value
undo on-demand color color-value
不存在SRv6 TE Policy的ODN模板。
SRv6 TE视图
color color-value:指定ODN模板的Color值,取值范围为0~4294967295。
配置ODN模板后,当设备收到BGP路由时,如果该BGP路由携带的Color扩展团体属性与ODN模板的Color值相同,则以该BGP路由的下一跳地址作为SRv6 TE Policy的目的节点地址,以ODN模板的Color值作为SRv6 TE Policy的Color属性,生成一个SRv6 TE Policy。同时,ODN会为该SRv6 TE Policy自动生成两条候选路径:
·     Preference为200的候选路径,该候选路径下的SID列表需要用户手工指定。
·     Preference为100的候选路径,该候选路径下的SID列表需要由PCE计算。
由ODN功能创建的SRv6 TE Policy下还可以手工创建候选路径。
# 创建SRv6 TE Policy的ODN模板,配置ODN模板的Color值为1,并进入SRv6 TE-ODN视图。
1.1.55  on-demand-group
on-demand-group命令用来创建SRv6 TE Policy组的ODN模板,并进入SRv6 TE-ODN Policy组视图。如果指定的ODN模板已经存在,则直接进入该SRv6 TE-ODN Policy组视图。
undo on-demand-group命令用来删除指定的ODN模板及SRv6 TE-ODN Policy组视图下的所有配置。
on-demand-group color color-value
undo on-demand-group color color-value
不存在SRv6 TE Policy组的ODN模板。
SRv6 TE视图
配置SRv6 TE Policy组的ODN模板后,当设备收到BGP路由时,如果该BGP路由携带的Color扩展团体属性与ODN模板的Color值相同,则以该BGP路由的下一跳地址作为SRv6 TE Policy组的目的节点地址,以ODN模板的Color值作为SRv6 TE Policy组的Color属性,生成一个SRv6 TE Policy组。设备将在未分配的组ID中,选择最小的组ID分配给该SRv6 TE Policy组。
自动创建SRv6 TE Policy组后,在ODN模板下需要配置Color和DSCP的映射关系,以便实现基于DSCP引流。
# 创建SRv6 TE Policy组的ODN模板,配置ODN模板的Color值为1,并进入SRv6 TE-ODN Policy组视图。
[Sysname-srv6-te] on-demand-group color 1
1.1.56  path verification
path verification命令用来配置SRv6 TE Policy路径连通性检查功能。
undo path verification命令用来恢复缺省情况。
path verification { enable | disable }
未配置SRv6 TE Policy路径连通性检查功能,以SRv6 TE视图下的配置为准。
SRv6 TE Policy视图
enable:开启SRv6 TE Policy路径连通性检查功能。
disable:关闭SRv6 TE Policy路径连通性检查功能。
需要在SRv6 TE Policy的头节点配置本功能。
通常情况下,管理员通过控制器向设备下发SRv6 TE Policy的SID列表。如果头节点上未配置BFD检测SRv6 TE Policy,则当SID列表指示的路径故障时,头节点不能快速感知该故障,只能等待控制器感知拓扑变化并重新计算路径后通知头节点切换SRv6 TE Policy的SID列表。如果控制器故障或设备与控制器间链路故障,则头节点无法及时感知故障、切换SID列表,导致流量丢失。
为了提升故障时流量切换的速度、提高可靠性,可以在头节点开启SRv6 TE Policy路径连通性检查功能。开启该功能后,头节点收集网络的拓扑信息,根据如下信息校验SRv6 TE Policy中所有SID列表的有效性:
·     如果SID列表中所有SRv6 SID在拓扑中均存在,且其对应的Locator前缀均路由可达,则SID列表有效。
·     如果SID列表中任一SRv6 SID在拓扑中不存在,或者任一SRv6 SID对应的Locator前缀路由不可达,则SID列表无效。
头节点感知到SID列表无效,即SID列表故障时,根据不同的配置情况,触发不同路径切换方式:
(1)     当SRv6 TE Policy优选的有效候选路径下存在多个SID列表,如果某一SID列表故障,则不再使用该SID列表转发流量,流量在其他有效SID列表间负载分担。
(2)     当SRv6 TE Policy下存在有效的主备候选路径,如果主候选路径的所有SID列表均故障,则将流量切换到备候选路径转发。
(3)     当SRv6 TE Policy下所有有效候选路径均故障,则该SRv6 TE Policy故障,触发其他保护措施(如MPLS L3VPN快速重路由)。
SRv6 TE视图和SRv6 TE Policy视图下均可以配置SRv6 TE Policy路径连通性检查功能。SRv6 TE视图的配置对所有SRv6 TE Policy都有效,而SRv6 TE Policy视图的配置只对当前SRv6 TE Policy有效。对于一个SRv6 TE Policy来说,优先采用该SRv6 TE Policy内的配置,只有该SRv6 TE Policy内未进行配置时,才采用SRv6 TE视图的配置。
由于SRv6 SID状态和路由状态感知都是在头节点进行的,所以头节点需要IGP域的所有SRv6 SID和路由。需要通过以下配置实现:
·     IGP域使用IS-ISv6传递路由信息。
·     在头节点的IS-IS视图下配置distribute link-state命令,上报链路状态信息。
当Segment List路径中存在Binding SID时,由于Binding SID不在IGP拓扑中泛洪,所以路径校验会失败,因此,在部署Binding SID场景,不能配置头节点故障感知功能。
# 开启SRv6 TE Policy 1的路径连通性检查功能。
[Sysname-srv6-te-policy-1] path verification enable
·     distribute(三层技术-IP路由命令参考/IS-IS)
·     srv6-policy path verification enable
1.1.57  pce capability segment-routing ipv6
pce capability segment-routing ipv6命令用来开启PCC设备的SRv6能力。
undo pce capability segment-routing ipv6命令用来关闭PCC设备的SRv6能力。
PCC设备的SRv6能力处于关闭状态。
PCC视图
当需要建立支持SRv6能力的PCEP会话时,需要在会话两端的设备上开启本功能。开启本功能后,可以通过建立的PCEP会话对SRv6 TE Policy的候选路径进行计算、上报、托管和更新等操作。
目前,设备作为PCE时不具备SRv6能力。
# 开启PCC设备的SRv6能力。
[Sysname] pce-client
[Sysname-pcc] pce capability segment-routing ipv6
1.1.58  pce delegation
pce delegation命令用来配置SRv6 TE Policy的PCE托管功能。
undo pce delegation命令用来恢复缺省情况。
pce delegation { enable | disable }
undo pce delegation
未配置SRv6 TE Policy的PCE托管功能,以SRv6 TE视图下的配置为准。
SRv6 TE Policy视图
enable:开启SRv6 TE Policy的PCE托管功能。
disable:关闭SRv6 TE Policy的PCE托管功能
开启PCE托管后,SRv6 TE Policy将候选路径托管给PCE,PCC接受来自PCE的候选路径的创建或更新请求,来创建或更新候选路径信息。
SRv6 TE视图和SRv6 TE Policy视图下均可以配置PCE托管功能。SRv6 TE视图的配置对所有SRv6 TE Policy都有效,而SRv6 TE Policy视图的配置只对当前SRv6 TE Policy有效。对于一个SRv6 TE Policy来说,优先采用该SRv6 TE Policy内的配置,只有该SRv6 TE Policy内未进行配置时,才采用SRv6 TE视图的配置。
如果同一SRv6 TE Policy下同时配置pce delegation命令和pce passive-delegate report-only命令,则pce passive-delegate report-only命令优先生效。
# 开启SRv6 TE Policy的PCE托管功能。
[Sysname-srv6-te-policy-1] pce delegation enable
·     pce passive-delegate report-only
·     srv6-policy pce delegation enable
1.1.59  pce passive-delegate report-only
pce passive-delegate report-only命令用来配置将SRv6 TE Policy的候选路径信息上报给PCE,但候选路径不由PCE进行托管。
undo pce passive-delegate report-only命令用来恢复缺省情况。
pce passive-delegate report-only { enable | disable }
未配置SRv6 TE Policy的仅上报不托管功能,以SRv6 TE视图下的配置为准。
SRv6 TE Policy视图
enable:开启SRv6 TE Policy的信息上报功能。
disable:关闭SRv6 TE Policy的信息上报功能。
如果设备上存在的多个SRv6 TE Policy中仅一部分由PCE托管,为了保证PCE准确计算全局的带宽信息,未托管的SRv6 TE Policy候选路径的信息也需要通过PCEP Report message消息上报给PCE。此时可以配置将无需托管的SRv6 TE Policy的候选路径信息上报给PCE,但不由PCE计算候选路径。
SRv6 TE视图和SRv6 TE Policy视图下均可以配置上报但不由PCE托管功能。SRv6 TE视图的配置对所有SRv6 TE Policy都有效,而SRv6 TE Policy视图的配置只对当前SRv6 TE Policy有效。对于一个SRv6 TE Policy来说,优先采用该SRv6 TE Policy内的配置,只有该SRv6 TE Policy内未进行配置时,才采用SRv6 TE视图的配置。
# 开启SRv6 TE Policy的候选路径信息上报给PCE、但候选路径不由PCE进行托管功能。
[Sysname-srv6-te-policy-1] pce passive-delegate report-only enable
·     pce delegation
·     srv6-policy pce passive-delegate report-only enable
1.1.60  pcep (SRv6 TE Policy Path Preference dynamic view)
pcep命令用来配置SRv6 TE Policy使用PCE计算当前候选路径的SID列表。
undo pcep命令用来恢复缺省情况。
pcep
undo pcep
SRv6 TE Policy候选路径的SID列表不使用PCE计算,需要手工配置。
配置本命令后,设备将通过PCE为手工创建的SRv6 TE Policy的候选路径计算SID列表。SID列表计算过程为:
(1)     本端设备作为PCC,向PCE发起路径计算请求。
(2)     PCE收到该请求后,为PCC计算路径。
(3)     PCE完成路径计算后,对PCC的路径请求进行应答,要求PCC创建路径信息。
(4)     PCC根据PCE计算的路径信息在SRv6 TE Policy的候选路径下创建SID列表信息。
# 配置SRv6 TE Policy使用PCE计算当前候选路径的SID列表。
[Sysname-srv6-te-policy-1-path-pref-20-dyna] pcep
1.1.61  pcep (SRv6 TE-ODN dynamic view)
pcep命令用来开启使用PCE计算路径功能。
undo pcep命令用来关闭使用PCE计算路径功能。
pcep
undo pcep
使用PCE计算路径功能处于关闭状态。
SRv6 TE-ODN动态配置视图
根据ODN模板生成的SRv6 TE Policy候选路径100的SID列表只能通过PCE计算,不能手工指定。在该候选路径下,需要配置本命令开启使用PCE计算路径功能。路径计算过程为:
(3)     PCE完成路径计算后,对PCC的路径请求进行应答,要求PCC创建路径。
(4)     PCC根据PCE计算的路径信息在SRv6 TE Policy候选路径100下创建SID列表信息。
# 开启使用PCE计算路径功能。
[Sysname-srv6-te] on-demand color 1
[Sysname-srv6-te-odn-1-dynamic] pcep
1.1.62  policy
policy命令用来创建SRv6 TE Policy,并进入SRv6 TE Policy视图。如果SRv6 TE Policy已经存在,则直接进入SRv6 TE Policy视图。
undo policy命令用来删除指定SRv6 TE Policy,及该SRv6 TE Policy视图下的所有配置。
policy policy-name
undo policy policy-name
不存在SRv6 TE Policy。
SRv6 TE视图
policy-name:SRv6 TE Policy名称,为1~59个字符的字符串,区分大小写。
# 创建名称为srv6policy的SRv6 TE Policy,并进入SRv6 TE Policy视图。
[Sysname-srv6-te] policy p1
[Sysname-srv6-te-policy-p1]
1.1.63  policy-group
policy-group命令用来创建SRv6 TE Policy组,并进入SRv6 TE Policy组视图。如果SRv6 TE Policy组已经存在,则直接进入SRv6 TE Policy组视图。
undo policy-group命令用来删除指定SRv6 TE Policy组,及该SRv6 TE Policy组视图下的所有配置。
policy-group group-id
undo policy-group group-id
不存在SRv6 TE Policy组。
SRv6 TE视图
group-id:SRv6 TE Policy组ID,取值范围为1~4294967295。
将SRv6 TE Policy加入到SRv6 TE Policy组后,可以实现根据报文的DSCP(Differentiated Services Code Point,区分服务编码点)分组引流。
# 创建SRv6 TE Policy组1,并进入SRv6 TE Policy组视图。
[Sysname-srv6-te] policy-group 1
1.1.64  preference
preference命令用来配置SRv6 TE Policy候选路径的优先级,并进入SRv6 TE Policy Path Preference视图。如果SRv6 TE Policy候选路径的优先级已经存在,则直接进入SRv6 TE Policy Path Preference视图。
undo preference命令用来删除SRv6 TE Policy候选路径的优先级,及SRv6 TE Policy Path Preference视图下的所有配置。
preference preference-value
undo preference preference-value
未配置SRv6 TE Policy候选路径的优先级。
SRv6 TE Policy候选路径视图
preferenc-value:SRv6 TE Policy候选路径的优先级,取值范围为1~65535。数值越大,优先级越高。
# 配置SRv6 TE Policy候选路径的优先级为20,并进入该SRv6 TE Policy Path Preference视图。
[Sysname-srv6-te] policy a1
1.1.65  rate-limit
rate-limit命令用来配置SRv6 TE Policy的限速值。
undo rate-limit命令用来恢复缺省情况。
rate-limit kbps
undo rate-limit
不对SRv6 TE Policy的流量速率进行限制。
SRv6 TE Policy视图
kbps:限速值,取值范围为1~4294967295,单位为kbps。
配置本命令后,通过SRv6 TE Policy转发的报文速率超过限速值时,超过速率限制的报文会被丢弃。
# 配置SRv6 TE Policy aaa的限速值为15000kbps。
[Sysname-srv6-te] policy aaa
[Sysname-srv6-te-policy-aaa] rate-limit 15000
1.1.66  reset segment-routing ipv6 te forwarding statistics
reset segment-routing ipv6 te forwarding statistics命令用来清除SRv6 TE Policy流量转发统计信息。
配置本命令后将清除所有SRv6 TE Policy流量转发统计信息。
# 清除SRv6 TE Policy流量转发统计信息。
<Sysname> reset segment-routing ipv6 te forwarding statistics
·     forwarding statistics
·     srv6-policy forwarding statistics enable
·     srv6-policy forwarding statistics interval
1.1.67  restrict
restrict命令用来配置ODN生成SRv6 TE Policy的触发策略。
undo restrict命令用来恢复缺省情况。
restrict prefix-list-name
undo restrict
携带的Color扩展团体属性与ODN模板的Color值相同的BGP路由均会触发ODN功能生成SRv6 TE Policy。
SRv6 TE-ODN视图
prefix-list-name:IPv6地址前缀列表名,为1~63个字符的字符串,区分大小写。
根据ODN模板生成SRv6 TE Policy时,可以利用IPv6地址前缀列表对BGP路由进行过滤。通过IPv6地址前缀列表过滤的BGP路由可以触发生成SRv6 TE Policy,被IPv6地址前缀列表拒绝的BGP路由不能触发建立SRv6 TE Policy。
# 配置允许1000::/96网段的BGP路由触发ODN功能生成SRv6 TE Policy。
[Sysname] ipv6 prefix-list policy permit 1000:: 96
[Sysname-srv6-te-odn-1] restrict policy
·     ipv6 prefix-list(三层技术-IP路由命令参考/路由策略)
1.1.68  router-id filter
router-id filter命令用来开启Router ID过滤功能。
undo router-id filter命令用来关闭Router ID过滤功能。
router-id filter [ bgp-rib-only ]
Router ID过滤功能处于关闭状态。
bgp-rib-only:当设备收到BGP IPv6 SR Policy路由,且该路由携带的Route Target属性中不包含本地设备的Router ID时,仅接收该路由,不生成对应的SRv6 TE Policy。
当网络中存在大量的BGP IPv6 SR Policy路由,而设备仅希望处理部分路由时,可以通过本命令过滤接收到的BGP IPv6 SR Policy路由。
开启Router ID过滤功能后,设备将检查接收到的BGP IPv6 SR Policy路由中携带的Route Target属性。如果该属性中包含本地设备的Router ID,则接收该路由,并生成对应的SRv6 TE Policy;否则:
·     执行本命令时,如果未指定bgp-rib-only参数,则丢弃该路由。
·     执行本命令时,如果指定bgp-rib-only参数,则仅接收该路由,不生成对应的SRv6 TE Policy。
当控制器需要通过多台中间设备将BGP IPv6 SR Policy路由发布到源节点时,控制器与源节点之间的中间设备仅需要转发BGP IPv6 SR Policy路由,不需要生成SRv6 TE Policy,以节省中间设备的资源。这种情况下,可以在中间设备上配置router-id filter bgp-rib-only命令,当中间设备收到BGP IPv6 SR Policy路由后,即使该路由携带的Route Target属性中不包含本地设备的Router ID,也不会丢弃该路由,仍对该路由进行转发。同时,也不会在中间设备上生成SRv6 TE Policy,避免影响报文转发。
为了正确使用Router ID过滤功能,需要通过路由策略等方式为BGP IPv6 SR Policy路由合理添加Route Target属性。否则,可能会导致错误地学习或丢弃BGP IPv6 SR Policy路由。
# 开启Router ID过滤功能。
[Sysname] bgp 100
[Sysname-bgp-default-srpolicy-ipv6] router-id filter
1.1.69  sbfd
sbfd命令用来配置SRv6 TE Policy的SBFD功能。
undo sbfd命令用来恢复缺省情况。
sbfd { disable | enable [ remote remote-id ] [ template template-name ] [ backup-template backup-template-name ] [ oam-sid sid ] [ encaps | insert ] }
undo sbfd
未配置SRv6 TE Policy的SBFD功能,以SRv6 TE视图下的配置为准。
SRv6 TE Policy视图
disable:关闭SRv6 TE Policy的SBFD功能。
enable:开启SRv6 TE Policy的SBFD功能。
remote remote-id:指定SBFD会话的远端标识符,取值范围为1~4294967295。如果未指定本参数,则以SRv6 TE视图下的配置为准。
template template-name:指定引用的BFD模板。template-name为BFD会话参数模板的名称,为1~63个字符的字符串,区分大小写。如果未指定本参数,则以SRv6 TE视图下配置的BFD模板为准。
backup-template backup-template-name:指定备份SID列表引用的BFD模板。backup-template-name为BFD会话参数模板的名称,为1~63个字符的字符串,区分大小写。如果未指定本参数,则以SRv6 TE视图下配置的备份BFD模板为准。
oam-sid sid:为SBFD报文添加OAM SID,用于定位目的节点。sid为目的节点的SRv6 SID。如果未指定本参数,则不为SBFD报文添加OAM SID。目前OAM SID需要配置为目的节点上的End.OP SID。
encaps:配置SBFD报文采用普通封装模式。
insert:配置SBFD报文采用插入封装模式。
通过SBFD检测SRv6 TE Policy时,需要为SBFD报文封装SRv6 TE Policy的SID列表,封装模式包括:
·     Encaps方式:普通封装模式。在原始报文的基础上封装新的IPv6头和SRH,且SRv6 TE Policy的SID列表中的所有SID均封装在SRH中。
¡     新IPv6头的目的IPv6地址为SRv6 TE Policy的SID列表中的第一个IPv6地址,源IPv6地址为encapsulation source-address命令指定的IPv6地址。
¡     SRH包含SRv6 TE Policy的SID列表中所有SID信息。
·     Insert方式:插入封装模式。在原始IPv6报文头后插入SRH,且SRv6 TE Policy的SID列表中的所有SID均封装在SRH中。
¡     IPv6头的目的IPv6地址改为SRv6 TE Policy的SID列表中的第一个IPv6地址,源IPv6地址为encapsulation source-address命令指定的IPv6地址。
如果未指定encaps和insert参数,则采用bfd srv6-encapsulation-mode encap命令配置的封装模式。
通过SBFD检测SRv6 TE Policy,为SBFD报文封装SRv6 TE Policy的SID列表时,不受SRv6 TE视图和SRv6 TE Policy视图下SRv6 TE Policy的封装模式命令的控制。
SRv6 TE视图和SRv6 TE Policy视图下均可以配置SRv6 TE Policy的SBFD功能。SRv6 TE视图的配置对所有SRv6 TE Policy都有效,而SRv6 TE Policy视图的配置只对当前SRv6 TE Policy有效。对于一个SRv6 TE Policy来说,优先采用该SRv6 TE Policy内的配置,只有该SRv6 TE Policy内未进行配置时,才采用SRv6 TE视图的配置。
本命令指定的远端标识符必须与Reflector端sbfd local-discriminator命令指定的标识符一致,否则Reflector端不会发送应答报文给Initiator端。
目前,支持通过BFD echo报文和SBFD两种方式检测SRv6 TE Policy。在同一SRv6 TE Policy下同时配置以上两种检测方式时,SBFD检测生效。
# 开启SRv6 TE Policy 1的SBFD功能。
[Sysname-srv6-te-policy-1] sbfd enable
·     bfd srv6-encapsulation-mode encap
·     display segment-routing ipv6 te sbfd
·     sbfd local-discriminator(可靠性命令参考/BFD)
·     srv6-policy sbfd
1.1.70  segment-list
segment-list命令用来创建SID列表,并进入SID列表视图。如果SID列表已经存在,则直接进入SID列表视图。
undo segment-list命令用来删除指定的SID列表,及该SID列表视图下的所有配置。
undo segment-list segment-list-name
不存在SID列表。
SRv6 TE视图
segment-list-name:SID列表名称,取值范围为1~128个字符的字符串,区分大小写。
# 创建名称为abc的SID列表,并进入SID列表视图。
1.1.71  service-class
service-class命令用来配置SRv6 TE Policy的转发类。
undo service-class命令用来恢复缺省情况。
service-class service-class-value
undo service-class
未配置SRv6 TE Policy的转发类,该SRv6 TE Policy的转发类值为255,转发优先级最低。
SRv6 TE Policy视图
service-class-value:SRv6 TE Policy转发类的值,取值范围为1~15。SRv6 TE Policy转发类的取值越小,SRv6 TE Policy转发的优先级越低,没有配置转发类的SRv6 TE Policy优先级最低。
配置本功能后:
·     设备会优先选择与流量的转发类值相同的SRv6 TE Policy转发该流量。
·     如果存在多条与流量的转发类值相同的SRv6 TE Policy,只有一条流且为逐流负载分担则随机选择一条SRv6 TE Policy转发流量;有一条流但是为逐包负载分担或有多条流,则流量在相同转发类的SRv6 TE Policy间进行负载分担。通过ip load-sharing mode可以配置流区分和负载分担方式
·     如果没有与流量的转发类值相同的SRv6 TE Policy,则选择转发类值最小的SRv6 TE Policy转发流量。
流行为视图下可以通过remark service-class命令重新标记报文的隧道转发类的值。
# 配置SRv6 TE Policy 1的转发类值为5。
[Sysname-srv6-te-policy-1] service-class 5
·     ip load-sharing mode(三层技术-IP业务命令参考/IP转发基础)
·     remark service-class(ACL和QoS命令参考/QoS)
1.1.72  shutdown
shutdown命令用来关闭SRv6 TE Policy。
undo shutdown命令用来开启SRv6 TE Policy。
shutdown
SRv6 TE Policy处于开启状态。
SRv6 TE Policy视图
通过本命令控制SRv6 TE Policy的开启和关闭状态,从而控制该SRv6 TE Policy是否可以转发流量。
当设备存在多个SRv6 TE Policy时,可以配置本命令,关闭一些不需要的SRv6 TE Policy,避免影响流量转发。
# 关闭SRv6 TE Policy 1。
[Sysname-srv6-te-policy-1] shutdown
1.1.73  snmp-agent trap enable srv6-policy
snmp-agent trap enable srv6-policy命令用来开启SRv6 TE Policy的告警功能。
undo snmp-agent trap enable srv6-policy命令用来关闭SRv6 TE Policy的告警功能。
SRv6 TE Policy的告警功能处于关闭状态。
开启SRv6 TE Policy的告警功能后,当SRv6 TE Policy的状态发生变化和SRv6 TE Policy的资源使用数量超限时,将生成告警信息并发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
SRv6 TE Policy的资源包括:
·     SRv6 TE Policy转发路径数目
·     SRv6 TE Policy组的转发表项ID数目
·     SRv6 TE Policy的转发表项ID数目
·     SID列表的转发表项ID数目
# 开启SRv6 TE Policy的告警功能。
[Sysname] snmp-agent trap enable srv6-policy
1.1.74  sr-policy steering
sr-policy steering命令用来配置SRv6 TE Policy的引流方式。
undo sr-policy steering命令用来恢复缺省情况。
sr-policy steering { disable | policy-based }
基于Color将数据报文引流到SRv6 TE Policy。
BGP实例视图
disable:不使用基于Color引流,可以基于隧道策略将数据报文引流到SRv6 TE Policy 。
policy-based:如果BGP路由中未携带Color扩展团体属性,则基于隧道策略将数据报文引流到SRv6 TE Policy。指定本参数后,按照基于隧道绑定策略进行引流->基于Color引流->基于隧道负载分担策略进行引流的优先级顺序引流方式。
可以通过如下方式将数据报文引流到SRv6 TE Policy:
·     基于Color引流:查找是否存在Color和Endpoint地址与BGP路由的Color扩展团体属性和下一跳地址完全相同的SRv6 TE policy。若存在,则将该BGP路由迭代到SRv6 TE Policy。当设备收到匹配该BGP路由的报文时,会通过SRv6 TE Policy转发该报文。
·     基于隧道策略引流:IP L3VPN over SRv6、EVPN L3VPN over SRv6组网中,通过部署隧道策略,将SRv6 TE Policy作为公网隧道来转发私网报文。隧道策略的详细介绍请参见“MPLS配置指导”中的“隧道策略”。
在L2VPN组网环境中,本命令不生效。
# 配置基于隧道策略将数据报文引流到SRv6 TE Policy。
[Sysname] bgp 100
[Sysname-bgp-default] sr-policy steering policy-based
1.1.75  sr-te frr enable
sr-te frr enable命令用来开启SRv6 TE FRR功能。
undo sr-te frr enable命令用来关闭SRv6 TE FRR功能。
sr-te frr enable
SRv6 TE FRR功能处于关闭状态。
Segment Routing IPv6视图
开启SRv6 TE FRR功能后,当SRv6 TE Policy的中间节点发生故障时,故障节点的上游节点可以代替故障节点完成报文转发,这个上游节点称之为代理转发(Proxy Forwarding)节点。
在节点开启SRv6 TE FRR功能后,当报文中存在SRH,且SRH中SL>1时,在如下任一场景下,该节点将作为代理转发节点转发报文:
·     查询IPv6 FIB表,没有找到对应的转发表项。
·     报文的下一跳是报文目的地址,该目的地址对应的出接口状态为DOWN;
·     查询Local SID表匹配SRv6 SID为End.X SID,且End.X SID对应的出接口状态为DOWN。
·     从路由表中查到的路由为NULL0路由。
代理转发节点代替故障节点进行报文转发时,需要进行以下操作:
·     代理转发节点将报文中SRH的SL减1;
·     将下层要处理的SID更新到外层IPv6报文头,使其作为报文的目的地址;
·     根据目的地址查表转发。
代理转发节点通过执行以上操作使报文绕过故障节点,实现中间节点故障的保护。这种保护技术也称为SRv6 TE FRR。
组网环境复杂时,中间节点并不固定,所以,为了提供整网可靠性,建议在所有节点上开启SRv6 TE FRR功能。
在中间节点保护组网环境中,不能配置srv6 compress enable命令,否则会导致中间节点保护失效。
# 开启SRv6 TE FRR功能。
[Sysname-segment-routing-ipv6] sr-te frr enable
1.1.76  srv6-policy alarm-threshold
srv6-policy alarm-threshold命令用来配置SRv6 TE Policy资源数量的告警阈值。
undo srv6-policy alarm-threshold命令用来恢复缺省情况。
srv6-policy { forwarding-path | policy | policy-group | segment-list } alarm-threshold upper-limit upper-limit-value lower-limit lower-limit-value
undo srv6-policy { forwarding-path | policy | policy-group | segment-list } alarm-threshold
SRv6 TE Policy所有资源告警的上限阈值均为80%,下限阈值均为75%。
SRv6 TE视图
forwarding-path:SRv6 TE Policy转发路径数目。
policy:为SRv6 TE Policy分配的转发表项ID数目。
policy-group:为SRv6 TE Policy组分配的转发表项ID数目。
segment-list:为SID列表分配的转发表项ID数目。
upper-limit upper-limit-value:以百分比的形式配置SRv6 TE Policy资源上限阈值,取值范围为1~100。
lower-limit lower-limit-value:以百分比的形式配置SRv6 TE Policy资源下限阈值,取值范围为1~100。
可通过本命令配置SRv6 TE Policy资源数量的告警阈值。当SRv6 TE Policy资源占用数目大于等于上限阈值或从超上限回落到小于等于下限阈值时会产生日志信息和告警信息,以便于管理员及时了解SRv6 TE Policy资源的使用情况。
配置本命令前,需要先开启SRv6 TE Policy的日志功能和告警功能。
可通过display segment-routing ipv6 te policy statistics命令查看当前SRv6 TE Policy资源的使用信息。
# 配置SRv6 TE Policy为SID列表分配的转发表项ID数目阈值,阈值上限为90%,阈值下限为60%。
[Sysname-srv6-te] srv6-policy segment-list alarm-threshold upper-limit 90 lower-limit 60
·     display segment-routing ipv6 te policy statistics
·     srv6-policy log enable
1.1.77  srv6-policy autoroute enable
srv6-policy autoroute enable命令用来开启SRv6 TE Policy的自动引流功能。
undo srv6-policy autoroute enable命令用来关闭SRv6 TE Policy的自动引流功能。
ISIS IPv6地址族视图:
srv6-policy autoroute enable [ level-1 | level-2 ]
OSPFv3视图:
SRv6 TE Policy的自动引流功能处于关闭状态。
ISIS IPv6地址族视图
OSPFv3视图
level-1:开启Level-1的SRv6 TE Policy的自动引流功能。
level-2:开启Level-2的SRv6 TE Policy的自动引流功能。
配置本功能后可以将SRv6 TE Policy隧道发布到IGP(OSPFv3或IS-IS)路由中,让SRv6 TE Policy参与IGP路由的计算,使得流量可以通过SRv6 TE Policy转发。
如果不指定level-1和level-2参数,则开启所有Level的SRv6 TE Policy的自动引流功能。
配置本命令前,需要在SRv6 TE Policy视图下配置autoroute enable命令,允许SRv6 TE Policy隧道参与路由计算。
# 开启IS-IS进程1的SRv6 TE Policy自动引流功能。
[Sysname] isis 1
[Sysname-isis-1-ipv6] srv6-policy autoroute enable
# 开启OSPFv3进程1的SRv6 TE Policy自动引流功能。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] srv6-policy autoroute enable
·     autoroute enable
1.1.78  srv6-policy backup hot-standby enable
srv6-policy backup hot-standby enable命令用来全局开启SRv6 TE Policy的热备份功能。
undo srv6-policy backup hot-standby enable命令用来全局关闭SRv6 TE Policy的热备份功能。
SRv6 TE Policy的热备份功能处于关闭状态。
SRv6 TE视图
开启SRv6 TE Policy的热备份功能后,如果一个SRv6 TE Policy下面存在多条候选路径,则优先级最高的有效路径是主路径,优先级次高的有效路径是备份路径。如果主路径下所有Segment List都发生故障,则将流量切换到备路径转发,以减少对业务的影响。
SRv6 TE视图和SRv6 TE Policy视图下均可以配置SRv6 TE Policy的热备份功能。SRv6 TE视图的配置对所有SRv6 TE Policy都有效,而SRv6 TE Policy视图的配置只对当前SRv6 TE Policy有效。对于一个SRv6 TE Policy来说,优先采用该SRv6 TE Policy内的配置,只有该SRv6 TE Policy内未进行配置时,才采用SRv6 TE视图的配置。
# 开启SRv6 TE Policy的热备份功能。
[Sysname-srv6-te] srv6-policy backup hot-standby enable
·     backup hot-standby
1.1.79  srv6-policy bfd echo
srv6-policy bfd echo命令用来全局开启SRv6 TE Policy的echo报文方式的BFD检测功能。
undo srv6-policy bfd echo命令用来全局关闭SRv6 TE Policy的echo报文方式的BFD检测功能。
srv6-policy bfd echo source-ipv6 ipv6-address [ template template-name ] [ backup-template backup-template-name ]
SRv6 TE Policy的echo报文方式的BFD检测功能处于关闭状态。
SRv6 TE视图
source-ipv6 ipv6-address:指定BFD会话的源IPv6地址。
template template-name:指定引用的BFD模板。template-name为BFD会话参数模板的名称,为1~63个字符的字符串,区分大小写。如果未指定本参数,则BFD会话使用系统视图下配置的多跳BFD会话参数。
backup-template backup-template-name:指定备份SID列表引用的BFD模板。backup-template-name为BFD会话参数模板的名称,为1~63个字符的字符串,区分大小写。如果未指定本参数,则BFD会话使用系统视图下配置的多跳BFD会话参数。
SRv6 TE视图和SRv6 TE Policy视图下均可以配置SRv6 TE Policy的echo报文方式的BFD功能。SRv6 TE视图的配置对所有SRv6 TE Policy都有效,而SRv6 TE Policy视图的配置只对当前SRv6 TE Policy有效。对于一个SRv6 TE Policy来说,优先采用该SRv6 TE Policy内的配置,只有该SRv6 TE Policy内未进行配置时,才采用SRv6 TE视图的配置。
# 全局开启SRv6 TE Policy的echo报文方式的BFD检测功能,并指定BFD会话的源IPv6地址为11::11。
[Sysname-srv6-te] srv6-policy bfd echo source-ipv6 11::11
·     bfd echo
·     display segment-routing ipv6 te bfd
1.1.80  srv6-policy encapsulation-mode encaps include local-end.x
srv6-policy encapsulation-mode encaps include local-end.x命令用来全局配置通过SRv6 TE Policy转发报文时封装的SRH中包含本地End.X SID。
undo srv6-policy encapsulation-mode encaps include local-end.x命令用来恢缺省情况。
SRv6 TE视图
配置了本功能的同时,在SRv6 TE视图下配置srv6-policy encapsulation-mode encaps reduced命令指定SRv6 TE Policy的封装模式为普通封装的简化模式时,本功能优先生效。
# 全局配置通过SRv6 TE Policy转发报文时封装的SRH中包含本地End.X SID。
[Sysname-srv6-te] srv6-policy encapsulation-mode encaps include local-end.x
·     encapsulation-mode encaps include local-end.x
1.1.81  srv6-policy encapsulation-mode encaps reduced
srv6-policy encapsulation-mode encaps reduced命令用来全局配置SRv6 TE Policy的封装模式为Encaps.Red模式。
undo srv6-policy encapsulation-mode encaps reduced命令用来恢复缺省情况。
SRv6 TE Policy的封装模式为Encaps模式。
SRv6 TE视图
报文通过SRv6 TE Policy转发时,需要为报文封装SRv6 TE Policy的SID列表,封装模式包括:
配置本功能并指定封装模式为普通封装的简化模式,同时,在SRv6 TE视图下又配置了srv6-policy encapsulation-mode encaps include local-end.x命令,则srv6-policy encapsulation-mode encaps include local-end.x命令生效。
# 全局配置SRv6 TE Policy的封装模式为Encaps.Red模式。
[Sysname-srv6-te] srv6-policy encapsulation-mode encaps reduced
·     encapsulation-mode encaps reduced
1.1.82  srv6-policy forwarding statistics enable
srv6-policy forwarding statistics enable命令用来全局开启SRv6 TE Policy的流量转发统计功能。
undo srv6-policy forwarding statistics enable命令用来全局关闭SRv6 TE Policy的流量转发统计功能。
srv6-policy forwarding statistics [ service-class ] enable
SRv6 TE Policy的流量转发统计功能处于关闭状态。
SRv6 TE视图
# 开启SRv6 TE Policy的流量转发统计功能。
[Sysname-srv6-te] srv6-policy forwarding statistics enable
1.1.83  srv6-policy forwarding statistics interval
srv6-policy forwarding statistics interval命令用来全局配置SRv6 TE Policy流量转发统计信息收集的时间间隔。
undo srv6-policy forwarding statistics interval命令用来恢复缺省情况。
srv6-policy forwarding statistics interval interval
SRv6 TE Policy流量转发统计信息收集的时间间隔为30秒。
SRv6 TE视图
interval:SRv6 TE Policy流量转发统计信息收集的时间间隔,取值范围为5~65535,单位为秒。
本命令对所有SRv6 TE Policy生效。
# 配置SRv6 TE Policy流量转发统计信息收集的时间间隔为90秒。
[Sysname-srv6-te] srv6-policy forwarding statistics interval 90
1.1.84  srv6-policy locator
srv6-policy locator命令用来引用Locator段。
undo srv6-policy locator命令用来取消引用Locator段。
srv6-policy locator locator-name
未引用Locator段。
SRv6 TE视图
locator-name:Locator段名称,为1~31个字符的字符串,区分大小写。
在SRv6 TE视图下引用Locator段用来限定BSID的范围。只有在Locator段范围内的BSID才能生效。
不能通过重复执行srv6-policy locator命令修改引用的Locator段。如需修改引用的Locator段,请先通过undo srv6-policy locator命令删除已引用的Locator段,再执行srv6-policy locator命令引用新的Locator段。
# 在SRv6 TE视图下引用Locator段test1。
[Sysname-srv6-te] srv6-policy locator test1
1.1.85  srv6-policy log enable
srv6-policy log enable命令用来开启SRv6 TE Policy的日志功能。
undo srv6-policy log enable命令用来关闭SRv6 TE Policy的日志功能。
SRv6 TE Policy的日志功能处于关闭状态。
SRv6 TE视图
开启SRv6 TE Policy的日志功能后,设备将记录SRv6 TE Policy的状态变化和资源使用情况,以便管理员对SRv6 TE Policy运行情况进行审计。设备生成的SRv6 TE Policy日志信息将被发送到设备的信息中心,通过设置信息中心的参数,决定日志信息的输出规则(即是否允许输出以及输出方向)。有关信息中心参数的配置请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启SRv6 TE Policy的日志功能。
[Sysname-srv6-te] srv6-policy log enable
1.1.86  srv6-policy path verification enable
srv6-policy path verification enable命令用来全局开启SRv6 TE Policy路径连通性检查功能。
undo srv6-policy path verification enable命令全局关闭SRv6 TE Policy路径连通性检查功能。
SRv6 TE Policy路径连通性检查功能处于关闭状态。
SRv6 TE视图
# 全局开启SRv6 TE Policy的路径连通性检查功能。
[Sysname-srv6-te] srv6-policy path verification enable
·     path verification
1.1.87  srv6-policy pce delegation enable
srv6-policy pce delegation enable命令用来全局开启SRv6 TE Policy的PCE托管功能。
undo srv6-policy pce delegation enable命令用来全局关闭SRv6 TE Policy的PCE托管功能。
SRv6 TE Policy的PCE托管功能处于关闭状态。
SRv6 TE视图
如果SRv6 TE视图下同时配置srv6-policy pce delegation enable命令和srv6-policy pce passive-delegate report-only enable命令,则srv6-policy pce passive-delegate report-only enable命令优先生效。
# 全局开启SRv6 TE Policy的PCE托管功能。
[Sysname-srv6-te] srv6-policy pce delegation enable
·     pce delegation
1.1.88  srv6-policy pce passive-delegate report-only enable
srv6-policy pce passive-delegate report-only enable命令用来全局开启将SRv6 TE Policy的候选路径信息上报给PCE,但候选路径不由PCE进行托管功能。
undo srv6-policy pce passive-delegate report-only enable命令用来全局关闭将SRv6 TE Policy的候选路径信息上报给PCE,但候选路径不由PCE进行托管功能。
将SRv6 TE Policy的候选路径信息上报给PCE,但候选路径不由PCE进行托管功能处于关闭状态。
SRv6 TE视图
# 全局开启将SRv6 TE Policy的候选路径信息上报给PCE,但候选路径不由PCE进行托管功能。
[Sysname-srv6-te] srv6-policy pce passive-delegate report-only enable
1.1.89  srv6-policy sbfd
srv6-policy sbfd命令用来全局开启SRv6 TE Policy的SBFD功能并配置相关参数。
undo srv6-policy sbfd命令用来全局关闭SRv6 TE Policy的SBFD功能。
srv6-policy sbfd [ remote remote-id  ] [ template template-name ] [ backup-template backup-template-name ]
SRv6 TE Policy的SBFD功能处于关闭状态。
SRv6 TE视图
remote remote-id:指定SBFD会话的远端标识符,取值范围为1~4294967295。如果未指定本参数,则使用sbfd destination ipv6 remote-discriminator命令配置的远端标识符。
template template-name:指定引用的BFD模板。template-name为BFD会话参数模板的名称,为1~63个字符的字符串,区分大小写。如果未指定本参数,则SBFD会话使用系统视图下配置的多跳BFD会话参数。
backup-template backup-template-name:指定备份SID列表引用的BFD模板。backup-template-name为BFD会话参数模板的名称,为1~63个字符的字符串,区分大小写。如果未指定本参数,则SBFD会话使用系统视图下配置的多跳BFD会话参数。
# 全局开启SRv6 TE Policy的SBFD功能,并指定SBFD会话的远端标识符为1000001。
[Sysname-srv6-te] srv6-policy sbfd remote 1000001
·     sbfd
·     sbfd destination ipv6 remote-discriminator(可靠性命令参考/BFD)
1.1.90  srv6-policy switch-delay delete-delay
srv6-policy switch-delay delete-delay命令用来配置SRv6 TE Policy中转发路径的切换延迟时间和删除延迟时间。
undo srv6-policy switch-delay命令用来恢复缺省情况。
srv6-policy switch-delay switch-delay-time delete-delay delete-delay-time
SRv6 TE Policy中转发路径的切换延迟时间为5000毫秒,删除延迟时间为20000毫秒。
SRv6 TE视图
switch-delay-time:SRv6 TE Policy中转发路径的切换延迟时间,取值范围为0~600000,单位为毫秒。
delete-delay-time:SRv6 TE Policy中转发路径的删除延迟时间,取值范围为0~600000,单位为毫秒。
在SRv6 TE Policy的转发路径更新过程中,设备在删除老的转发路径之前先把新的转发路径建立起来,建立新的转发路径期间流量先保持按照老的转发路径转发,切换延迟时间超时后再按照新的转发路径转发流量,并在删除延迟时间超时后将旧转发路径删除,防止转发路径切换导致流量不通。
# 配置SRv6 TE Policy中转发路径的切换延迟时间为8000毫秒,删除延迟时间为15000毫秒。
[Sysname-srv6-te] srv6-policy switch-delay 8000 delete-delay 15000
1.1.91  te ipv6-router-id
te ipv6-router-id命令用来配置TE IPv6 Router ID地址。
undo te ipv6-router-id命令用来恢复缺省情况。
te ipv6-router-id router-id
未配置TE IPv6 Router ID。
router-id:TE IPv6 Router ID,为IPv6地址形式,取值为除::和FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF外的IPv6地址。
TE IPv6 Router ID用于标识PCE请求的源节点,可以为任意取值,但是要求在IPv6网络中必须唯一。
# 配置TE IPv6 Router ID为1::1。
[Sysname] te ipv6-router-id 1::1
1.1.92  traffic-engineering
traffic-engineering命令用来创建SRv6 TE,并进入SRv6 TE视图。如果SRv6 TE已经存在,则直接进入SRv6 TE视图。
undo traffic-engineering命令用来删除SRv6 TE,及SRv6 TE视图下的所有配置。
traffic-engineering
不存在SRv6 TE。
SRv6视图
# 创建SRv6 TE,并进入SRv6 TE视图。
[Sysname-srv6-te]
1.1.93  ttl-mode
ttl-mode命令用来配置SRv6 TE Policy对TTL的处理模式。
undo ttl-mode命令用来恢复缺省情况。
ttl-mode { pipe | uniform }
undo ttl-mode
SRv6 TE Policy对TTL的处理模式为Pipe模式。
SRv6视图
pipe:TTL的处理模式为Pipe模式。
uniform:TTL的处理模式为Uniform模式。
使用SRv6 TE Policy作为公网隧道的场景下,SRv6 TE Policy对TTL的处理有两种模式:
·     Uniform模式:入节点为IP报文添加新的IPv6头时,将原IP报文中的TTL值复制到新IPv6头的IPv6 Hop Limit字段。使用SRv6 TE Policy转发报文时,对新IPv6头的Hop Limit值逐跳减一。设备解封装报文时,将新IPv6头的Hop Limit值复制回IP报文。使用这种方式时,公网中的节点对用户网络的报文可见。报文沿着SRv6 TE Policy传输的过程中,TTL逐跳递减,Tracert的结果将反映报文实际经过的路径。
·     Pipe模式:入节点为IP报文添加新的IPv6头时,不会将原IP报文中的TTL值复制到新IPv6头的IPv6 Hop Limit字段,新IPv6头的TTL取值为255。使用SRv6 TE Policy转发报文时,对新IPv6头的Hop Limit值逐跳减一。设备解封装报文时,不修改IPv6 Hop Limit的值。使用这种方式时,公网中的节点对用户网络的报文不可见。Tracert的结果不包括公网中的每一跳,从而隐藏公网的结构。
# 配置SRv6 TE Policy 1对TTL的处理模式为Uniform模式。
[Sysname-segment-routing-ipv6] ttl-mode uniform
1.1.94  validation-check enable
validation-check enable命令用来开启BGP IPv6 SR Policy路由有效性检查功能。
undo validation-check enable命令用来关闭BGP IPv6 SR Policy路由有效性检查功能。
BGP IPv6 SR Policy路由有效性检查功能处于关闭状态,即设备不会检查对等体/对等体组接收到的BGP IPv6 SR Policy路由的有效性。
可以通过以下方式对控制器下发的BGP IPv6 SR Policy路由的发布范围进行控制:
·     通过RT扩展团体属性控制路由的发布范围:控制器为BGP IPv6 SR Policy路由添加IPv4地址格式的RT属性,IPv4地址与指定源节点的BGP Router ID相同。源节点接收到携带该属性的路由后,会将本地的Router ID与RT属性中的IPv4地址进行对比。如果相同,则接收该路由,否则,丢弃该路由。
·     通过NO_ADVERTISE团体属性控制路由的发布范围:控制器为BGP IPv6 SR Policy路由添加NO_ADVERTISE团体属性。源节点接收携带该属性的路由后,不能将该路由通告给任何其他的BGP对等体,从而实现仅源节点可以接收BGP IPv6 SR Policy路由。
开启本功能后,设备会对BGP IPv6 SR Policy路由进行检查。如果BGP IPv6 SR Policy路由中既没有IPv4地址格式的RT扩展团体属性,又没有NO_ADVERTISE团体属性,则该路由无效,将该路由丢弃。
# 开启BGP IPv6 SR Policy路由有效性检查功能。
[Sysname] bgp 100
[Sysname-bgp-default] address ipv6 sr-policy
[Sysname-bgp-default-srpolicy-ipv6] validation-check enable
