07-三层技术-IP路由命令参考
13-路由策略命令
本章节下载: 13-路由策略命令  (431.62 KB)
13-路由策略命令
1 路由策略
1.1 路由策略公共配置命令
1.1.1 apply as-path
1.1.2 apply aigp
1.1.3 apply comm-list delete
1.1.4 apply community
1.1.5 apply cost
1.1.6 apply cost-type
1.1.7 apply extcommunity
1.1.8 apply extcommunity color
1.1.9 apply extcommunity soo
1.1.10 apply gateway-ip
1.1.11 apply ip-precedence
1.1.12 apply ipv6 gateway-ip
1.1.13 apply isis
1.1.14 apply label-index
1.1.15 apply label-value
1.1.16 apply large-comm-list delete
1.1.17 apply large-community
1.1.18 apply local-preference
1.1.19 apply mpls-label
1.1.20 apply origin
1.1.21 apply preference
1.1.22 apply preferred-value
1.1.23 apply prefix-priority
1.1.24 apply qos-local-id
1.1.25 apply tag
1.1.26 apply traffic-index
1.1.27 continue
1.1.28 display ip as-path
1.1.29 display ip community-list
1.1.30 display ip extcommunity-list
1.1.31 display ip large-community-list
1.1.32 display ip rd-list
1.1.33 display route-policy
1.1.34 if-match as-path
1.1.35 if-match community
1.1.36 if-match cost
1.1.37 if-match extcommunity
1.1.38 if-match interface
1.1.39 if-match large-community
1.1.40 if-match local-preference
1.1.41 if-match mpls-label
1.1.42 if-match rd-list
1.1.43 if-match route-policy
1.1.44 if-match route-type
1.1.45 if-match rpki
1.1.46 if-match tag
1.1.47 ip as-path
1.1.48 ip community-list
1.1.49 ip extcommunity-list
1.1.50 ip large-community-list
1.1.51 ip rd-list
1.1.52 reset ip as-path
1.1.53 route-policy
1.1.54 route-policy prefix-protocol-check
1.2 IPv4路由策略配置命令
1.2.1 apply fast-reroute
1.2.2 apply ip-address next-hop
1.2.3 display ip prefix-list
1.2.4 if-match ip
1.2.5 ip prefix-list
1.2.6 reset ip prefix-list
1.3 IPv6路由策略配置命令
1.3.1 apply ipv6 fast-reroute
1.3.2 apply ipv6 next-hop
1.3.3 display ipv6 prefix-list
1.3.4 if-match ipv6
1.3.5 ipv6 prefix-list
1.3.6 reset ipv6 prefix-list
1 路由策略
1.1  路由策略公共配置命令
1.1.1  apply as-path
apply as-path命令用来配置BGP路由信息AS_PATH属性。
undo apply as-path命令用来恢复缺省情况。
apply as-path { as-number&<1-32> [ delete | replace ] | clear }
undo apply as-path
未配置BGP路由信息的AS_PATH属性。
路由策略视图
as-number&<1-32>:自治系统号,取值范围为1~4294967295。&<1-32>表示前面的参数可以输入1~32次。
delete:在原有的AS_Path属性中删除指定的AS号。
replace:替换原有AS号。如果未指定本参数,则在原AS路径前加入AS号。
clear:清空原有的AS_Path属性。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。如果路由信息匹配已存在的编号为1的AS路径访问列表,那么在原AS路径前加入AS号200。
[Sysname-route-policy-policy1-10] if-match as-path 1
[Sysname-route-policy-policy1-10] apply as-path 200
·     display ip as-path
·     if-match as-path
·     ip as-path
1.1.2  apply aigp
apply aigp命令用来配置BGP路由的AIGP属性。
undo apply aigp命令用来恢复缺省情况。
apply aigp { cost-value | igp-cost }
undo apply aigp
未配置BGP路由的AIGP属性。
路由策略视图
cost-value:BGP路由的AIGP属性值,取值范围为0~4294967295。
igp-cost:指定BGP路由的AIGP属性值为到达BGP路由下一跳的IGP路由开销值。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。指定BGP路由的AIGP值为10。
[Sysname-route-policy-policy1-10] apply aigp 10
·     peer aigp(三层技术-IP路由命令参考/BGP)
apply comm-list delete命令用来删除BGP路由信息的团体属性。
undo apply comm-list命令用来恢复缺省情况。
没有删除BGP路由信息的团体属性。
路由策略视图
comm-list-number:团体属性列表号。
·     基本团体属性列表号的取值范围为1~99;
·     高级团体属性列表号的取值范围为100~199。
comm-list-name:团体属性列表名,为1~63个不全为数字的字符串,区分大小写。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。删除已存在的团体属性列表1中指定的BGP路由信息的团体属性。
[Sysname-route-policy-policy1-10] apply comm-list 1 delete
·     ip community-list
apply community命令用来配置BGP路由信息的团体属性。
undo apply community命令用来取消BGP路由信息的团体属性配置。
undo apply community [ none | additive | { community-number&<1-32> | aa:nn&<1-32> | internet | no-advertise | no-export | no-export-subconfed } * [ additive ] ]
未配置BGP路由信息的团体属性。
路由策略视图
none:删除路由的团体属性。
aa:nn&<1-32>:团体号,aa和nn的取值范围为0~65535。&<1-32>表示前面的参数可以输入1~32次。
internet:预定义的团体属性。缺省情况下,所有的路由都具有internet团体属性,可以被通告给所有的BGP对等体。
no-advertise:具有此属性的路由在收到后,不能被通告给任何其他的BGP对等体。
no-export:具有此属性的路由在收到后,不能被发布到本地AS之外。如果使用了联盟,则不能被发布到联盟之外,但可以发布给联盟中的其他子AS。
no-export-subconfed:具有此属性的路由在收到后,不能被发布到本地AS之外,也不能发布到联盟中的其他子AS。
additive:附加至原有路由的团体属性。
# 创建一个名为setcommunity的路由策略,其节点序列号为16,匹配模式为permit。配置BGP路由的团体属性为no-export。
[Sysname-route-policy-setcommunity-16] apply community no-export
·     if-match community
·     ip community-list
1.1.5  apply cost
apply cost命令用来配置路由信息的路由开销。
undo apply cost命令用来恢复缺省情况。
undo apply cost
未配置路由信息的路由开销。
路由策略视图
+:增加开销值。
-:减少开销值。
cost-value:指定路由信息的路由开销,取值范围为0~4294967295。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。如果匹配OSPF外部路由,那么设置该路由的路由开销为120。
[Sysname-route-policy-policy1-10] if-match route-type external-type1or2
[Sysname-route-policy-policy1-10] apply cost 120
apply cost-type命令用来配置路由信息的路由开销类型。
undo apply cost-type命令用来恢复缺省情况。
apply cost-type { external | internal | type-1 | type-2 }
未配置路由开销类型。
路由策略视图
external:IS-IS外部路由。
internal:IS-IS内部路由或者设置BGP路由的MED值为下一跳的IGP度量值。
type-1:OSPF的外部Type-1路由。
type-2:OSPF的外部Type-2路由。
apply cost-type internal命令的作用:
·     应用于IS-IS路由:设置路由类型为IS-IS内部路由。
·     应用于BGP路由:路由器从IBGP对等体学到的路由在通告给EBGP对等体时,如果配置apply cost-type internal命令,则路由器会将向EBGP对等体通告的路由的MED值设置为该路由的下一跳的IGP度量值。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。如果匹配标记域为8的路由,那么设置该路由的路由开销类型为OSPF的外部Type-1路由。
[Sysname-route-policy-policy1-10] if-match tag 8
[Sysname-route-policy-policy1-10] apply cost-type type-1
apply extcommunity命令用来配置BGP路由信息的扩展团体属性。
undo apply extcommunity命令用来取消BGP路由信息的扩展团体属性配置。
apply extcommunity { bandwidth link-bandwidth-value | { rt route-target }&<1-32> } [ additive ]
undo apply extcommunity [ bandwidth link-bandwidth-value | { rt route-target }&<1-32> ]
未配置BGP路由信息的扩展团体属性。
路由策略视图
bandwidth link-bandwidth-value:指定链路带宽扩展团体属性,为3~16个字符的字符串。link-bandwidth-value的形式为16位自治系统号:32位用户自定义数,例如:100:3。其中,自治系统号取值范围为0~65535,用户自定义数取值范围为0~4294967295。
{ rt route-target }&<1-32>:指定的RT(Route Target,路由目标)扩展团体属性,为3~24个字符的字符串。&<1-32>表示前面的参数可以输入1~32次。
route-target有五种形式,分别如下:
·     16位自治系统号:32位用户自定义数,例如:101:3。其中,自治系统号取值范围为0~65535,用户自定义数取值范围为0~4294967295。
·     32位IP地址:16位用户自定义数,例如:192.168.122.15:1。其中,用户自定义数取值范围为0~65535。
·     32位自治系统号:16位用户自定义数,例如:70000:3。其中,自治系统号取值范围为65536~4294967295,用户自定义数取值范围为0~65535。
·     32位IPv4地址/IPv4地址掩码:16位用户自定义数。例如:192.168.122.15/24:1。
·     32位自治系统号的点分方式:16位用户自定义数。例如:65535.65535:1。
additive:允许增加到已有的扩展团体中。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。如果匹配已存在的编号为1的AS路径访问列表,那么为BGP指定RT扩展团体属性。
[Sysname-route-policy-policy1-10] apply extcommunity rt 100:2 additive
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。如果匹配已存在的编号为1的AS路径访问列表,那么为BGP指定链路带宽扩展团体属性。
[Sysname-route-policy-policy1-10] apply extcommunity bandwidth 100:2 additive
apply extcommunity color命令用来配置BGP路由的Color扩展团体属性。
undo apply extcommunity color命令用来取消BGP路由的Color扩展团体属性。
apply extcommunity color color [ additive ]
未配置BGP路由的Color扩展团体属性。
路由策略视图
color color:Color扩展团体属性,为4~13个字符的字符串。color形式为CO(Color-Only)标记位:color-value,例如:10:3。其中,CO标记位取值为二进制数00~11,color-value取值范围为0~4294967295。
additive:允许将Color扩展团体属性增加到已有的扩展团体属性中。如果未配置本参数,则表示替换已有的Color扩展团体属性。
为BGP路由添加Color扩展团体属性后,如果设备收到匹配该路由的报文,则会根据该路由Color扩展团体属性和下一跳地址查找具有相同Color值和Endpoint地址的SR-MPLS TE Policy或SRv6 TE Policy。如果BGP路由携带多个Color扩展团体属性,则会使用最大的Color值去查找。在查找时,BGP路由的Color值与SR-MPLS TE Policy或SRv6 TE Policy的Color值必须完全相同,BGP路由下一跳地址与SR-MPLS TE Policy或SRv6 TE Policy的Endpoint地址的匹配方法由CO标记位决定:
·     CO标记位取值为00或11,BGP路由的下一跳地址和Endpoint地址完全相同才能匹配。
·     CO标记位取值为01,按照如下顺序依次查找匹配的SR-MPLS TE Policy或SRv6 TE Policy:
a.     匹配Endpoint地址与BGP路由下一跳地址完全相同的SR-MPLS TE Policy或SRv6 TE Policy。
b.     根据BGP路由下一跳地址的类型,如果为IPv4地址,则匹配Endpoint地址为0.0.0.0的SR-MPLS TE Policy;如果为IPv6地址,则匹配Endpoint地址为::的SRv6 TE Policy。
·     CO标记位取值为10,按照如下顺序依次查找匹配的SR-MPLS TE Policy或SRv6 TE Policy:
c.     匹配Endpoint地址与BGP路由下一跳地址完全相同的SR-MPLS TE Policy或SRv6 TE Policy。
d.     根据BGP路由下一跳地址的类型,如果为IPv4地址,则匹配Endpoint地址为0.0.0.0的SR-MPLS TE Policy;如果为IPv6地址,则匹配Endpoint地址为::的SRv6 TE Policy。
e.     根据BGP路由下一跳地址的类型,如果为IPv4地址,则匹配Endpoint地址最小的SR-MPLS TE Policy;如果为IPv6地址,则匹配Endpoint地址最小的SRv6 TE Policy。
如果匹配条件都不满足,则匹配失败,设备将继续根据该BGP路由转发报文。如果匹配成功,设备会将该BGP路由迭代到SR-MPLS TE Policy或SRv6 TE Policy,当设备收到匹配该BGP路由的报文时,会通过SR-MPLS TE Policy或SRv6 TE Policy转发该报文。
有关SR-MPLS TE Policy或SRv6 TE Policy的详细介绍,请参见“Segment Routing配置指导”中的“SR-MPLS TE Policy或SRv6 TE Policy”。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。指定BGP路由的Color扩展团体属性为10:20,并允许将Color扩展团体属性增加到已有的扩展团体属性中。
[Sysname-route-policy-policy1-10] apply extcommunity color 10:20 additive
apply extcommunity soo命令用来配置BGP路由的SoO(Site of Origin,源站点)扩展团体属性。
undo apply extcommunity soo命令用来取消该配置。
未配置BGP路由的SoO扩展团体属性。
路由策略视图
site-of-origin&<1-32>:SoO扩展团体属性,为3~24个字符的字符串。&<1-32>表示前面的参数可以输入1~32次。site-of-origin有五种形式,分别如下:
·     32位IP地址/IPv4地址掩码:16位用户自定义数,例如:192.168.122.15/24:1。
·     32位自治系统号的点分方式:16位用户自定义数,例如:65535.65535:1。
additive:表示允许将SoO扩展团体属性增加到已有的扩展团体属性列表中。如果未配置本参数,则表示替换已有的SoO扩展团体属性。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。如果匹配已存在的编号为1的AS路径访问列表,那么为BGP指定SoO扩展团体属性为1:100,并允许将SoO扩展团体属性增加到已有的扩展团体属性列表中。
[Sysname-route-policy-policy1-10] apply extcommunity soo 1:100 additive
apply gateway-ip命令用来配置EVPN IP前缀路由的网关IP地址。
undo apply gateway-ip命令用来恢复缺省情况。
apply gateway-ip { ip-address | origin-nexthop }
未配置EVPN IP前缀路由的网关IP地址。
路由策略视图
ip-address:设置网关IP地址,点分十进制形式。
origin-nexthop:设置路由的下一跳地址作为网关IP地址。
本命令应用于EVPN组网,用来修改EVPN IP前缀路由中的Gateway IP地址。
# 设置路由的下一跳地址作为网关IP地址。
[Sysname-route-policy-policy1-10] apply gateway-ip origin-nexthop
·     apply ipv6 gateway-ip
apply ip-precedence命令用来配置路由的IP优先级。
undo apply ip-precedence命令用来恢复缺省情况。
未配置路由的IP优先级。
路由策略视图
value:路由的IP优先级,取值范围是0~7。
clear:清除路由的IP优先级。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。如果匹配扩展团体列表号100的BGP路由,那么配置路由的IP优先级为3。
[Sysname] ip extcommunity-list 100 permit rt 100:100
[Sysname-route-policy-policy1-10] if-match extcommunity 100
[Sysname-route-policy-policy1-10] apply ip-precedence 3
apply ipv6 gateway-ip命令用来配置EVPN IP前缀路由的网关IPv6地址。
undo apply ipv6 gateway-ip命令用来恢复缺省情况。
apply ipv6 gateway-ip { ipv6-address | origin-nexthop }
未配置EVPN IP前缀路由的网关IPv6地址。
路由策略视图
ipv6-address:设置网关IPv6地址。
origin-nexthop:设置路由的下一跳地址作为网关IPv6地址。
本命令应用于EVPN组网,用来修改EVPN IP前缀路由中的Gateway IPv6地址。
# 设置路由的下一跳地址作为网关IPv6地址。
[Sysname-route-policy-policy1-10] apply ipv6 gateway-ip origin-nexthop
·     apply gateway-ip
1.1.13  apply isis
apply isis命令用来配置引入路由到IS-IS某个级别的区域。
undo apply isis命令用来恢复缺省情况。
undo apply isis
未配置引入路由到IS-IS某个级别的区域。
路由策略视图
level-1:引入路由到IS-IS的Level-1区域。
level-1-2:引入路由到IS-IS的Level-1和Level-2区域。
level-2:引入路由到IS-IS的Level-2区域。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。如果匹配标记域为8的路由,那么引入路由到IS-IS的Level-2区域。
[Sysname-route-policy-policy1-10] apply isis level-2
apply label-index命令用来配置路由的标签索引值。
undo apply label-index命令用来恢复缺省情况。
apply label-index index-value
未配置路由的标签索引值。
路由策略视图
index-value:指定标签索引值,取值范围为0~1048575。
BGP、IS-IS或OSPF引入符合指定路由策略的路由且该路由策略中使用了本apply子句时,可以为引入的路由设置Prefix-SID的标签索引值。如果引入的路由自身携带了标签索引值,则路由协议优先使用路由策略配置的标签索引值。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。设置路由的标签索引值为120。
[Sysname-route-policy-policy1-10] apply label-index 120
apply label-value命令用来配置SID值。
undo apply label-value命令用来恢复缺省情况。
apply label-value label-value
未配置SID值。
路由策略视图
label-value:SID值,取值范围为16~1048575。
本命令用于如下场景:
·     开启BGP-EPE功能后,为指定的等体/对等体组应用路由策略且该路由策略中使用了本apply子句时,可以为BGP邻居分配标签,即SID值。关于BGP-EPE功能的详细介绍,请参见“Segment Routing配置指导”中的“SR-MPLS”。
·     ISIS或OSPF引入符合指定路由策略的路由且该路由策略中使用了本apply子句时,可以为引入的路由设置SID值。如果引入的路由自身携带了SID值,则路由协议优先使用路由策略设置的SID值。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。设置路由的标签值120。
[Sysname-route-policy-policy1-10] apply label-value 120
apply large-comm-list delete命令用来删除BGP路由信息的Large团体属性。
undo apply large-comm-list命令用来取消删除BGP路由信息的Large团体属性的配置。
apply large-comm-list { large-comm-list-number | large-comm-list-name } delete
不会删除BGP路由信息的Large团体属性。
路由策略视图
large-comm-list-number:Large团体属性列表号。基本Large团体属性列表号的取值范围为1~99;高级Large团体属性列表号的取值范围为100~199。
large-comm-list-name:Large团体属性列表名,为1~63个不全为数字的字符串,区分大小写。
通过本命令,可以删除BGP路由信息中与指定的Large团体属性列表中相同的Large团体属性。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。删除BGP路由信息中与Large团体属性列表1中相同的Large团体属性。
[Sysname-route-policy-policy1-10] apply large-comm-list 1 delete
·     ip large-community-list
apply large-community命令用来配置BGP路由信息的Large团体属性。
undo apply large-community命令用来取消BGP路由信息的Large团体属性配置。
apply large-community { aa:bb:cc&<1-8> [ additive ] | additive | none }
undo apply large-community [ aa:bb:cc&<1-8> [ additive ] | additive | none ]
未配置BGP路由信息的Large团体属性。
路由策略视图
aa:bb:cc&<1-8>:Large团体号,aa、bb、cc的取值范围为0~4294967295。&<1-8>表示前面的参数可以输入1~8次。
additive:附加至原有路由的Large团体属性。如果未指定本参数,表示覆盖路由中已存在的Large团体属性。
none:删除路由的Large团体属性。
在路由策略中配置本命令,可以对通过路由策略过滤的BGP路由设置Large团体属性。
多次执行本命,最多可以为BGP路由配置32个Large团体号。
# 创建一个名为setlargecommunity的路由策略,其节点序列号10,匹配模式为permit。配置BGP路由的Large团体属性为1:1:1。
[Sysname] route-policy setlargecommunity permit node 10
[Sysname-route-policy-setlargecommunity-10] apply large-community 1:1:1
·     if-match large-community
apply local-preference命令用来配置BGP路由信息的本地优先级。
undo apply local-preference命令用来恢复缺省情况。
未配置BGP路由信息的本地优先级。
路由策略视图
preference:BGP路由信息的本地优先级,取值范围为0~4294967295。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。如果匹配已存在的编号为1的AS路径访问列表,那么配置该BGP路由的本地优先级为130。
[Sysname-route-policy-policy1-10] apply local-preference 130
apply mpls-label命令用来为路由分配MPLS标签。
undo apply mpls-label命令用来恢复缺省情况。
apply mpls-label
没有为路由分配MPLS标签。
路由策略视图
如果MPLS标签分配失败,路由信息将不会被发布。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。为路由分配MPLS标签。
[Sysname-route-policy-policy1-10] apply mpls-label
1.1.20  apply origin
apply origin命令用来配置BGP路由信息的ORIGIN属性。
undo apply origin命令用来恢复缺省情况。
undo apply origin
未配置BGP路由信息的ORIGIN属性。
路由策略视图
egp as-number:设定BGP路由信息的来源为外部路由。as-number表示指定外部路由的自治系统号,取值范围为1~4294967295。
igp:设定BGP路由信息的来源为内部路由。
incomplete:设定BGP路由信息的来源为未知来源。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。如果匹配已存在的编号为1的AS路径访问列表,那么设置该BGP路由的路由源为IGP。
[Sysname-route-policy-policy1-10] apply origin igp
apply preference命令用来配置路由协议的优先级。
undo apply preference命令用来恢复缺省情况。
apply preference preference
未配置路由协议的优先级。
路由策略视图
preference:路由的优先级,取值范围为1~255。
如果路由协议已经用命令preference配置了优先级,再用apply preference命令修改路由协议的优先级,则这些匹配策略的路由采用apply preference命令修改的优先级,其它路由的优先级均采用preference命令所设的值。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。如果匹配OSPF外部路由,那么设置该路由协议的优先级为90。
[Sysname-route-policy-policy1-10] apply preference 90
apply preferred-value命令用来配置BGP路由信息的首选值。
undo apply preferred-value命令恢复缺省情况。
未配置BGP路由信息的首选值。
路由策略视图
preferred-value:首选值,取值范围为0~65535。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。如果匹配已存在的编号为1的AS路径访问列表,那么设置该BGP路由的首选值为66。
[Sysname-route-policy-policy1-10] apply preferred-value 66
apply prefix-priority命令用来配置路由的收敛优先级。
undo apply prefix-priority命令用来恢复缺省情况。
未配置路由的收敛优先级,即路由的收敛优先级为低(Low)。
路由策略视图
critical:路由的收敛优先级为关键。
high:路由的收敛优先级为高。
medium:路由的收敛优先级中。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。如果匹配已存在的地址前缀列表abc,那么设置该路由的收敛优先级为关键。
[Sysname-route-policy-policy1-10] if-match ip address prefix-list abc
[Sysname-route-policy-policy1-10] apply prefix-priority critical
apply qos-local-id命令用来配置路由的QoS本地ID值。
undo apply qos-local-id命令用来恢复缺省情况。
apply qos-local-id { local-id-value | clear }
未配置路由的QoS本地ID值。
路由策略视图
local-id-value:路由的QoS本地ID值,取值范围是1~4095。
clear:清除路由的QoS本地ID值。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。如果匹配扩展团体列表号100的BGP路由,那么配置路由的QoS本地ID值为100。
[Sysname-route-policy-policy1-10] apply qos-local-id 100
1.1.25  apply tag
apply tag命令用来配置IGP路由信息的标记。
undo apply tag命令用来恢复缺省情况。
apply tag tag-value
undo apply tag
未配置IGP路由信息的标记。
路由策略视图
tag-value:指定路由信息的标记值,取值范围为0~4294967295。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。配置IGP路由信息的标记为100。
[Sysname-route-policy-policy1-10] apply tag 100
apply traffic-index命令用来配置BGP路由信息的流量索引。
undo apply traffic-index命令用来恢复缺省情况。
未配置BGP路由信息的流量索引。
路由策略视图
value:流量索引值,取值范围为1~127。
clear:清除路由的流量索引值。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。如果匹配扩展团体列表号100的BGP路由,那么配置路由的流量索引值为6。
[Sysname-route-policy-policy1-10] apply traffic-index 6
1.1.27  continue
continue命令用来配置下一个执行节点。
undo continue命令用来恢复缺省情况。
continue [ node-number ]
undo continue
未配置下一个执行节点。
路由策略视图
node-number:标识本命令会跳转到的节点索引,取值范围为0~65535。
下一个执行节点序列号必须大于当前节点序列号。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。定义continue子句,配置下一个执行节点序列号为20。
[Sysname-route-policy-policy1-10] continue 20
display ip as-path命令用来显示BGP AS路径过滤列表信息。
display ip as-path [ as-path-number ]
as-path-number:AS路径过滤列表号,取值范围为1~256。如果未指定本参数,将显示所有已配置的BGP AS路径过滤列表信息。
# 显示列表号为1的BGP AS路径列表信息。
As-path-number: 1
 Permitted 0
 Denied 0
        Mode: Permit  Regular experssion:10:1
# 显示所有BGP AS路径过滤列表信息。
As-path-number: 12
 Permitted 0
 Denied 0
        Mode: Permit  Regular expression:^10
As-path-name: as1
 Permitted 0
 Denied 0
        Mode: Deny    Regular expression:*200.*300
表1-1 display ip as-path命令显示信息描述表
As-path-number
AS路径列表号
As-path-name
AS路径列表名
Permitted
应用且通过该策略匹配的次数
Denied
应用且未通过该策略匹配的次数
Mode
匹配模式,有两种取值:
·     Permit:表示允许
·     Deny:表示拒绝
Regular expression
匹配的AS路径正则表达式
·     reset ip as-path
display ip community-list命令用来显示BGP团体属性列表信息。
basic-community-list-number:为基本团体属性列表号,取值范围为1~99。
adv-community-list-number:为高级团体属性列表号,取值范围为100~199。
name comm-list-name:团体属性列表名,为1~63个不全为数字的字符串,区分大小写。
如果未指定团体属性列表号或团体属性列表名,将显示所有已配置的BGP团体属性列表信息。
# 显示所有的BGP团体属性列表信息。
<Sysname> display ip community-list
Community List Basic aaa
        Permit
Community List Advanced bbb
        Permit  3333
表1-2 display ip community-list命令显示信息描述表
基本团体属性列表
高级团体属性列表
permit
匹配模式,有两种取值:
·     Permit:表示允许
·     Deny:表示拒绝
display ip extcommunity-list命令用来显示BGP扩展团体属性列表信息。
display ip extcommunity-list [ ext-comm-list-number | ext-comm-list-name ]
ext-comm-list-number:扩展团体属性列表号,取值范围为1~199。如果未指定本参数,将显示所有已配置的BGP扩展团体属性列表信息。
ext-comm-list-name:扩展团体属性列表名,为1~63个不全为数字的字符串,区分大小写。
如果未指定任何参数,将显示所有已配置的BGP扩展团体属性列表信息。
# 显示列表号为1的BGP扩展团体属性列表信息。
        Permit rt: 9:6
        Permit soo: 9:6
        Permit bandwidth: 9:6
Extended Community List Name extlist
        Permit rt: 10:10
        Permit soo: 1:100
表1-3 display ip extcommunity-list命令显示信息描述表
扩展团体属性列表
扩展团体属性列表名
permit
匹配模式,有两种取值:
·     Permit:表示允许
·     Deny:表示拒绝
rt
soo
bandwidth
Bandwidth(link-bandwidth,链路带宽)扩展团体属性
display ip large-community-list命令用来显示BGP Large团体属性列表信息。
display ip large-community-list [ basic-large-comm-list-number | adv-large-comm-list-number | name large-comm-list-name ]
basic-large-comm-list-number:基本Large团体属性列表号,取值范围为1~99。
adv-large-comm-list-number:高级Large团体属性列表号,取值范围为100~199。
name large-comm-list-name:Large团体属性列表名,为1~63个不全为数字的字符串,区分大小写。
如果未指定Large团体属性列表号和Large团体属性列表名,将显示所有已配置的BGP Large团体属性列表信息。
# 显示所有的BGP Large团体属性列表信息。
<Sysname> display ip large-community-list
Large-community List Basic aaa
        Permit  1:1:1
Large-community List Advanced bbb
        Permit  3333:3333:3333
Large-community List Number 20
        Deny    4:4:4
表1-4 display ip large-community-list命令显示信息描述表
Large-community Basic
基本Large团体属性列表名称
高级Large团体属性列表名称
Large团体属性列表号
Permit
Large团体属性列表的匹配模式为允许模式
Deny
Large团体属性列表的匹配模式为拒绝模式
display ip rd-list命令用来显示RD(Route Distinguisher,路由标识符)列表信息。
rd-list-number:显示指定编号的RD列表信息。rd-list-number表示RD列表编号,取值范围为1~65535。如果不指定本参数,则显示所有RD列表的信息。
# 显示所有RD列表的信息。
<Sysname> display ip rd-list
Route Distinguisher List Number 1
        index: 1          Permit 1.1.1.1:1 2.2.2.2:* 100:1 200:*
Route Distinguisher List Number 2
        index: 2          Deny   1:1 2:2
表1-5 display ip rd-list命令显示信息描述表
RD属性列表号
index
RD属性列表的表项编号
Permit
匹配模式,取值包括:
·     Permit:表示允许
·     Deny:表示拒绝
·     ip rd-list
display route-policy命令用来显示配置的路由策略信息。
display route-policy [ name route-policy-name [ node node-number ] ]
name route-policy-name:指定显示的路由策略名,为1~63个字符的字符串,区分大小写。如果未指定本参数,将显示所有已配置的路由策略信息。
node node-number:指定路由策略中的节点索引,取值范围为0~65535。如果未指定本参数,将显示所有已配置的节点信息。
# 显示名为policy1的路由策略信息。
<Sysname> display route-policy name policy1
Route-policy: policy1
  Permit : 1
          if-match cost 10
          continue: next node 11
          apply comm-list a delete
表1-6 display route-policy命令显示信息描述表
Route-policy
路由策略名称
Permit : xx
节点的匹配模式为允许模式,节点编号为xx
Deny   : xx
节点的匹配模式为拒绝模式,节点编号为xx
if-match
if-match子句,配置的匹配条件
continue
continue字句,配置下一个执行节点
apply
apply子句,如满足匹配条件,则要执行的动作
if-match as-path命令用来配置BGP路由信息的AS路径域的匹配条件。
undo if-match as-path命令用来取消BGP路由信息的AS路径域的匹配条件的配置。
if-match as-path { as-path-number&<1-32> | as-path-name }
undo if-match as-path [ as-path-number&<1-32> | as-path-name ]
未配置BGP路由信息的AS路径域的匹配条件。
路由策略视图
as-path-number&<1-32>:为AS路径过滤列表号,取值范围为1~256。&<1-32>表示前面的参数可以输入1~32次。
as-path-name:AS路径过滤列表名,为1~51个字符的字符串,区分大小写,不能全为数字。
# 首先配置一个编号为2的as-path,允许自治系统号包含200和300的路由信息通过。然后创建一个名为test的路由策略,该路由策略编号为10的节点定义了一条if-match子句,它引用的是先前定义的as-path。
[Sysname-route-policy-policy1-10] if-match as-path 2
·     apply as-path
·     ip as-path
if-match community命令用来配置BGP路由信息的团体属性的匹配条件。
undo if-match community命令用来取消BGP路由信息的团体属性的匹配条件的配置。
undo if-match community [ { basic-community-list-number | name comm-list-name } [ whole-match ] | adv-community-list-number ]&<1-32>
未配置BGP路由信息的团体属性的匹配条件。
路由策略视图
whole-match:为确切匹配,即所有团体而且仅有这些团体必须出现。
&<1-32>:表示前面的参数可以输入1~32次。
# 首先配置一个编号为1的community-list,允许包含团体号100和200的路由信息。然后创建一个名为test的路由策略,该路由策略编号为10的节点定义了一条if-match子句,它引用的是先前定义的community-list。
[Sysname-route-policy-test-10] if-match community 1
·     apply community
·     ip community-list
if-match cost命令用来配置路由信息的路由开销的匹配条件。
undo if-match cost命令用来恢复缺省情况。
if-match cost cost-value
undo if-match cost
未配置路由信息的路由开销的匹配条件。
路由策略视图
cost-value:路由开销,取值范围为0~4294967295。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。定义一条if-match子句,允许路由开销为8的路由信息通过。
[Sysname-route-policy-policy1-10] if-match cost 8
if-match extcommunity命令用来配置BGP路由信息的扩展团体属性的匹配条件。
undo if-match extcommunity命令用来取消BGP路由信息的扩展团体属性的匹配条件的配置。
if-match extcommunity { ext-comm-list-number | ext-comm-list-name }&<1-32>
undo if-match extcommunity [ ext-comm-list-number | ext-comm-list-name ]&<1-32>
未配置BGP路由信息的扩展团体属性的匹配条件。
路由策略视图
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。定义一条if-match子句,匹配已存在的扩展团体列表号100和150定义的扩展团体属性的路由。
[Sysname] ip extcommunity-list 150 permit rt 150:150
[Sysname-route-policy-policy1-10] if-match extcommunity 100 150
·     apply extcommunity
·     ip extcommunity-list
if-match interface命令用来配置路由信息的出接口的匹配条件。
undo if-match interface命令用来取消路由信息的出接口的匹配条件的配置。
未配置路由信息的出接口的匹配条件。
路由策略视图
interface-type interface-number:指定接口类型和编号。
&<1-16>:表示前面的参数可以输入1~16次。
将路由策略应用到BGP时,BGP协议不支持配置路由信息的出接口的匹配条件。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。定义一条if-match子句,匹配出接口为GigabitEthernet3/1/1的路由信息。
[Sysname-route-policy-policy1-10] if-match interface gigabitethernet 3/1/1
if-match large-community命令用来配置BGP路由信息的Large团体属性的匹配条件。
undo if-match large-community命令用来取消BGP路由信息的Large团体属性的匹配条件的配置。
if-match large-community { { basic-large-comm-list-number | name large-comm-list-name } [ whole-match ] | adv-large-comm-list-number }&<1-32>
undo if-match large-community [ { basic-large-comm-list-number | name large-comm-list-name } [ whole-match ] | adv-large-comm-list-number ]&<1-32>
未配置BGP路由信息的Large团体属性的匹配条件。
路由策略视图
whole-match:表示完全匹配。如果指定了本参数,则只有路由的Large团体属性列表与指定的Large团体属性列表完全相同时,才满足匹配条件;如果未指定本参数,则只要路由的Large团体属性列表中包含指定Large团体属性列表里的所有属性,就满足匹配条件。
如果本命令中指定的Large团体属性列表尚未创建,则需要通过ip large-community-list命令创建对应的Large团体属性列表。
本命令与ip large-community-list命令配合使用,可以作为路由策略的匹配条件,通过匹配条件可以筛选出存在指定Large团体属性的BGP路由。
# 首先配置一个编号为1的large团体属性列表,允许包含Large团体号1:0:1和2:0:1的路由信息通过。然后创建一个名为test的路由策略,该路由策略编号为10的节点定义了一条if-match子句,它引用的是先前定义的large团体属性列表。
[Sysname] ip large-community-list 1 permit 1:0:1 2:0:1
[Sysname-route-policy-test-10] if-match large-community 1
·     apply large-community
·     apply large-comm-list delete
if-match local-preference命令用来配置BGP路由信息的本地优先级的匹配条件。
undo if-match local-preference命令用来恢复缺省情况。
未配置BGP路由信息的本地优先级的匹配条件。
路由策略视图
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。定义一条if-match子句,允许BGP路由信息的本地优先级为2的路由信息通过。
[Sysname-route-policy-policy1-10] if-match local-preference 2
if-match mpls-label命令用来配置路由信息的MPLS标签的匹配条件。
undo if-match mpls-label命令用来恢复缺省情况。
if-match mpls-label
未配置路由信息的MPLS标签的匹配条件。
路由策略视图
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。定义一条if-match子句,匹配路由信息的MPLS标签。
[Sysname-route-policy-policy1-10] if-match mpls-label
if-match rd-list命令用来配置VPN路由RD(Route Distinguisher,路由标识符)属性的匹配条件。
undo if-match rd-list命令用来取消VPN路由RD属性匹配条件的配置。
未配置VPN路由RD属性的匹配条件。
路由策略视图
rd-list-number:指定RD属性列表号,取值范围为1~65535。
# 配置一个编号为1的RD属性列表,允许包含RD号为1:1的路由信息通过,创建一个名为rp1的路由策略,该路由策略中编号为10的节点定义了一条if-match子句,引用编号为1的RD属性列表。
[Sysname] ip rd-list 1 permit 1:1
[Sysname] route-policy rp1 permit node 10
[Sysname-route-policy-rp1-10] if-match rd-list 1
·     ip rd-list
if-match route-policy命令用来将子路由策略作为路由策略的匹配条件。
undo if-match route-policy命令用来恢复缺省情况。
if-match route-policy route-policy-name
未将子路由策略作为路由策略的匹配条件。
路由策略视图
route-policy-name:指定子路由策略名,为1~63个字符的字符串,区分大小写。
使用子路由策略作为父路由策略的匹配条件时,对于子路由策略中不同的节点匹配模式,匹配机制如下:
·     如果节点的匹配模式为deny,则当路由项满足该节点的所有if-match子句时被拒绝通过该节点的过滤,并且不会进行下一个节点的匹配;如果路由项不满足该节点的if-match子句,将进入下一个节点继续匹配。匹配完成时,父路由策略将继承该匹配结果。
·     如果节点的匹配模式为permit,则当路由项满足该节点的所有if-match子句时被允许通过该节点的过滤并执行该节点的apply子句,父路由策略将继承apply结果。如路由项不满足该节点的if-match子句,将继续匹配该路由策略的下一个节点。
将子路由策略作为路由策略的匹配条件时,需要注意的是:
·     如果指定的子路由策略不存在,则默认满足该匹配条件。
·     最多只能嵌套一层,即不支持子路由策略再嵌套子路由策略。例如路由策略a使用路由策略b作为匹配条件,则路由策略b不能再使用其他路由策略作为匹配条件,路由策略a也不能作为其他路由策略的匹配条件。
·     不能形成循环,例如路由策略a使用路由策略b作为匹配条件,则路由策略b不能使用路由策略a作为匹配条件。
同一路由策略视图下,多次执行本命令时,最后一次执行的命令生效。
# 创建一个名为parent的路由策略,其节点序列号为10,匹配模式为permit。定义一条if-match子句,允许满足子路由策略child的路由信息通过。
[Sysname] route-policy parent permit node 10
[Sysname-route-policy-policy1-10] if-match route-policy child
if-match route-type命令用来配置路由信息类型的匹配条件。
undo if-match route-type命令用来取消路由信息类型的匹配条件的配置。
if-match route-type { bgp-evpn-ad | bgp-evpn-imet | bgp-evpn-ip-prefix | bgp-evpn-mac-ip | eigrp-external | eigrp-internal | external-type1 | external-type1or2 | external-type2 | internal | is-is-level-1 | is-is-level-2 | nssa-external-type1 | nssa-external-type1or2 | nssa-external-type2 } *
undo if-match route-type [ bgp-evpn-ad | bgp-evpn-imet | bgp-evpn-ip-prefix | bgp-evpn-mac-ip | eigrp-external | eigrp-internal | external-type1 | external-type1or2 | external-type2 | internal | is-is-level-1 | is-is-level-2 | nssa-external-type1 | nssa-external-type1or2 | nssa-external-type2 ] *
未配置路由信息的类型的匹配条件。
路由策略视图
bgp-evpn-ad:BGP EVPN的以太网自动发现路由。
bgp-evpn-imet:BGP EVPN的IMET(Inclusive Multicast Ethernet Tag Route,包含性组播以太网标签路由)路由。
bgp-evpn-ip-prefix:BGP EVPN的IP前缀路由。
bgp-evpn-mac-ip:BGP EVPN的MAC/IP发布路由。
eigrp-external:EIGRP外部路由。
eigrp-internal:EIGRP内部路由。
external-type1:OSPF Type1的外部路由。
external-type1or2:OSPF外部路由。
external-type2:OSPF Type2的外部路由。
internal:内部路由(包括OSPF区域间和区域内路由)。
is-is-level-1:IS-IS的Level-1路由。
is-is-level-2:IS-IS的Level-2路由。
nssa-external-type1:OSPF NSSA Type1的外部路由。
nssa-external-type1or2:OSPF NSSA的外部路由。
nssa-external-type2:OSPF NSSA Type2的外部路由。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。定义一条if-match子句,匹配internal类型的路由。
[Sysname-route-policy-policy1-10] if-match route-type internal
if-match rpki命令用来配置BGP RPKI验证结果的匹配条件。
undo if-match rpki命令用来恢复缺省情况。
undo if-match rpki
未配置BGP RPKI验证结果的匹配条件。
路由策略视图
invalid:匹配BGP RPKI验证结果为Invalid的路由。
not-found:匹配BGP RPKI验证结果为Not-found的路由。
valid:匹配BGP RPKI验证结果为Valid的路由。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。定义一条if-match子句,允许BGP RPKI验证结果为Valid的路由信息通过。
[Sysname-route-policy-policy1-10] if-match rpki valid
1.1.46  if-match tag
if-match tag命令用来配置IGP路由信息标记的匹配条件。
undo if-match tag命令用来恢复缺省情况。
if-match tag tag-value
undo if-match tag
未配置IGP路由信息标记的匹配条件。
路由策略视图
tag-value:指定要求的标记值,取值范围为0~4294967295。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。定义一条if-match子句,匹配标记为8的IGP路由信息。
1.1.47  ip as-path
ip as-path命令用来配置一个AS路径过滤列表。
undo ip as-path命令用来删除指定的AS路径过滤列表。
ip as-path { as-path-number | as-path-name } { deny | permit } regular-expression
undo ip as-path { as-path-number | as-path-name } [ regular-expression | deny | permit ]
不存在AS路径过滤列表。
as-path-number:指定的AS路径过滤列表号,取值范围为1~256。
as-path-name:指定的AS路径过滤列表名,为1~51个字符的字符串,区分大小写,不能全为数字。
deny:指定AS路径过滤列表的匹配模式为拒绝模式。
permit:指定AS路径过滤列表的匹配模式为允许模式。
regular-expression:AS路径正则表达式,为1~256个字符的字符串。
BGP协议的路由信息中,包含一个AS路径域,在BGP协议交换路由信息的过程中,该路由所经过的所有AS都会记录在这个域中。例如^200.*100$,表示匹配所有AS 200开始、以AS 100结束的AS路径域。AS路径正则表达式所用到的特殊字符及其含义,请参见“三层技术-IP路由配置指导”中的“路由策略”。
# 配置序号为1的AS路径过滤列表,允许AS_PATH以10开头的路由信息通过。
·     apply as-path
·     if-match as-path
ip community-list命令用来配置一个团体属性列表。
undo ip community-list命令用来删除指定的团体属性列表。
undo ip community-list { basic-comm-list-num | basic basic-comm-list-name } [ deny | permit ] [ community-number&<1-32> | aa:nn&<1-32> ] [ internet | no-advertise | no-export | no-export-subconfed ] *
undo ip community-list { adv-comm-list-num | advanced adv-comm-list-name } [ deny | permit ] [ regular-expression ]
不存在团体属性列表。
basic-comm-list-num:基本团体属性列表号,取值范围为1~99。
basic basic-comm-list-name:标识基本团体属性名称。basic-comm-list-name为1~63个不全为数字的字符串,区分大小写。
advanced adv-comm-list-name:标识高级团体属性名称。adv-comm-list-name为1~63个不全为数字的字符串,区分大小写。
adv-comm-list-num:高级团体属性列表号,取值范围为100~199。
regular-expression:指定高级团体属性的正则表达式,为1~63个字符的字符串。有关正则表达式的详细介绍,请参见“三层技术-IP路由配置指导”中的“路由策略”。
deny:指定团体属性列表的匹配模式为拒绝模式。
permit:指定团体属性列表的匹配模式为允许模式。
# 配置序号为1的基本团体属性列表,允许internet团体属性的路由信息通过。
# 配置序号为100的高级团体属性列表,允许团体属性内容以“10”开头的路由信息通过。
·     apply comm-list delete
·     apply community
·     display ip community-list
ip extcommunity-list命令用来配置一个扩展团体属性列表。
undo ip extcommunity-list命令用来删除指定的扩展团体属性列表。
ip extcommunity-list { ext-comm-list-number | ext-comm-list-name } { deny | permit } { bandwidth link-bandwidth-value | rt route-target | soo site-of-origin }&<1-32>
undo ip extcommunity-list { ext-comm-list-number | ext-comm-list-name } [ { deny | permit } [ bandwidth link-bandwidth-value | rt route-target | soo site-of-origin ]&<1-32> ]
不存在扩展团体属性列表。
deny:指定扩展团体属性列表的匹配模式为拒绝模式。
permit:指定扩展团体属性列表的匹配模式为允许模式。
bandwidth link-bandwidth-value:指定的链路带宽扩展团体属性,为3~16个字符的字符串。&<1-32>表示前面的参数可以输入1~32次。link-bandwidth-value的形式为16位自治系统号:32位用户自定义数,例如:100:3。其中,自治系统号取值范围为0~65535,用户自定义数取值范围为0~4294967295。
rt route-target:指定的RT(Route Target,路由目标)扩展团体属性,为3~24个字符的字符串。&<1-32>表示前面的参数可以输入1~32次。
soo site-of-origin:指定的SoO(Site of Origin,源站点)扩展团体属性,为3~24个字符的字符串。&<1-32>表示前面的参数可以输入1~32次。
route-target和site-of-origin有五种形式,分别如下:
·     32位IP地址/IPv4地址掩码:16位用户自定义数。例如:192.168.122.15/24:1。
# 配置序号为1的扩展团体属性列表,允许RT为200:200的路由信息通过。
# 配置序号为2的扩展团体属性列表,允许SoO为100:100的路由信息通过。
# 配置序号为3的扩展团体属性列表,允许链路带宽扩展团体属性为100:100的路由信息通过。
[Sysname] ip extcommunity-list 3 permit bandwidth 100:100
·     display ip extcommunity-list
·     if-match extcommunity
ip large-community-list命令用来配置一个Large团体属性列表。
undo ip large-community-list命令用来删除指定的Large团体属性列表或删除列表中的指定Large团体属性。
ip large-community-list { basic-large-comm-list-num | basic basic-large-comm-list-name } { deny | permit } aa:bb:cc&<1-32>
undo ip large-community-list { basic-large-com-list-num | basic basic-large-comm-list-name } [ deny | permit ] [ aa:bb:cc&<1-32> ]
ip large-community-list { adv-large-comm-list-num | advanced adv-large-comm-list-name } { deny | permit } regular-expression
undo ip large-community-list { adv-large-comm-list-num | advanced adv-large-comm-list-name } [ deny | permit ] [ regular-expression ]
不存在Large团体属性列表。
basic-large-comm-list-num:基本Large团体属性列表号,取值范围为1~99。
basic basic-large-comm-list-name:基本Large团体属性列表名称。basic-large-comm-list-name为1~63个不全为数字的字符串,区分大小写。
adv-large-comm-list-num:高级Large团体属性列表号,取值范围为100~199。
advanced adv-comm-list-name:高级Large团体属性列表名称。adv-large-comm-list-name为1~63个不全为数字的字符串,区分大小写。
deny:指定Large团体属性列表的匹配模式为拒绝模式。
permit:指定Large团体属性列表的匹配模式为允许模式。
aa:bb:cc&<1-32>:Large团体号,aa、bb和cc的取值范围为0~4294967295。&<1-32>表示前面的参数可以输入1~32次。
regular-expression:指定高级Large团体属性的正则表达式,为1~63个字符的字符串。有关正则表达式的详细介绍,请参见“三层技术-IP路由配置指导”中的“路由策略”。
本命令与if-match large-community命令配合使用,可以作为路由策略的匹配条件,通过匹配条件可以筛选出存在指定Large团体属性的BGP路由。
在执行undo命令时,如果未指定deny和permit参数,则表示指定匹配模式为deny和permit的Large团体属性。
# 配置序号为100的高级Large团体属性列表,允许包含以“10”开头的Large团体属性的路由通过。
[Sysname] ip large-community-list 100 permit ^10
# 配置序号为1的基本Large团体属性列表,允许包含Large团体属性1:1:1的路由信息通过。
[Sysname] ip large-community-list 1 permit 1:1:1
·     display ip large-community-list
1.1.51  ip rd-list
ip rd-list命令用来配置一个RD(Route Distinguisher,路由标识符)属性列表。
undo ip rd-list命令用来删除指定RD属性列表或其某个表项。
undo ip rd-list rd-list-number [ index index-number ] [ { deny | permit } route-distinguisher&<1-10> ]
不存在RD属性列表。
rd-list-number:RD属性列表编号,取值范围为为1~65535。
index index-number:指定RD属性列表中的表项编号,index-number取值范围为1~4294967295。表项编号值小的表项先被匹配。如果未指定本参数,该表项编号按照配置先后顺序依次递增,每次加10,第一个序号值为10;若当前表项编号已为最大值,则从未使用的表项编号中从小到大分配。
deny:指定所定义的RD属性列表的匹配模式为拒绝模式。
permit:指定所定义的RD属性列表的匹配模式为允许模式。
route-distinguisher&<1-10>:路由标识符,为3~21个字符的字符串。&<1-10>表示前面的参数最多可以输入10次。路由标识符有以下几种配置格式:
·     16位自治系统号:32位用户自定义数。例如:101:3。
·     16位自治系统号:*,*表示任意值。例如:101:*表示匹配RD号为101:xxx(xxx表示取值范围内的任意值)的VPN路由。
·     32位IP地址:16位用户自定义数。例如:192.168.122.15:1。
·     32位IP地址:*,*表示任意值。例如:192.168.122.15:*表示匹配RD号为192.168.122.15:xxx(xxx表示取值范围内的任意值)的VPN路由。
·     32位自治系统号:16位用户自定义数字,其中的自治系统号最小值为65536。例如:65536:1。
·     32位自治系统号:*,*表示任意值,其中的自治系统号最小值为65536。例如:65536:*表示匹配RD号为65536:xxx(xxx表示取值范围内的任意值)的VPN路由。
RD属性列表用于过滤VPN路由信息,一个RD属性列表可以有若干条表项,每一表项可指定一个或多个路由标识符。RD属性列表中各个表项之间的过滤关系是“或”的关系,其使用规则如下:
·     引用不存在的RD属性列表进行过滤时,认为通过该RD属性列表的过滤。
·     引用已经存在的RD属性列表进行过滤时,如果路由信息的RD通过一条表项的过滤,则认为通过该RD属性列表的过滤;如果路由信息的RD没有通过RD属性列表中任何一条表项的过滤,则认为未通过该RD属性列表的过滤。
# 配置一个编号为1的RD属性列表,允许包含RD号100:1的路由信息通过。
[Sysname] ip rd-list 1 permit 100:1
·     display ip rd-list
·     if-match rd-list
reset ip as-path命令用来清除BGP AS路径过滤列表统计信息。
reset ip as-path [ as-path-number | as-path-name ]
as-path-name:指定AS路径过滤列表名,为1~51个字符的字符串,区分大小写,不能全为数字。
如果未指定任何参数,将清除所有的BGP AS路径过滤列表统计信息。
# 清除名称为abc的BGP AS路径过滤列表的统计信息。
<Sysname> reset ip as-path abc
1.1.53  route-policy
route-policy命令用来创建路由策略,并进入该路由策略视图。如果指定的路由策略已经存在,则直接进入该路由策略视图。
undo route-policy命令用来删除指定的路由策略。
不存在路由策略。
route-policy-name:指定路由策略名,为1~63个字符的字符串,区分大小写。
deny:指定所定义的路由策略节点的匹配模式为拒绝模式。当路由项满足该节点的所有if-match子句时被拒绝通过该节点的过滤,并且不会进行下一个节点的匹配;如果路由项不满足该节点的if-match子句,将进入下一个节点继续匹配。
permit:指定所定义的路由策略节点的匹配模式为允许模式。当路由项满足该节点的所有if-match子句时被允许通过该节点的过滤并执行该节点的apply子句,如路由项不满足该节点的if-match子句,将继续匹配该路由策略的下一个节点。
node node-number:标识路由策略中的一个节点索引,当该路由策略用于路由信息过滤时,node-number小的节点先被匹配,取值范围为0~65535。
路由策略用于路由信息过滤。一个路由策略由若干节点组成,每一节点由一些if-match子句和apply子句组成。if-match子句定义该节点的匹配规则,apply子句定义通过该节点过滤后进行的动作。节点中不同类型的if-match子句之间的过滤关系是“与”的关系,相同类型的if-match子句是“或”的关系,即必须满足该节点所有类型的if-match子句。路由策略节点之间的过滤关系是“或”的关系,即通过一个节点的过滤就意味着通过该路由策略的过滤。若没有通过任一节点的过滤,则表示没有通过该路由策略的过滤。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit,并进入路由策略视图。
·     display route-policy
route-policy prefix-protocol-check命令用来配置路由策略对路由信息的协议类型(IPv4或IPv6)和通过if-match子句指定的地址前缀列表的协议类型进行匹配检查,协议类型不一致的路由信息无法通过该if-match子句的过滤。
undo route-policy prefix-protocol-check命令用来恢复缺省情况。
路由策略不会对路由信息的协议类型(IPv4或IPv6)和通过if-match子句指定的地址前缀列表的协议类型进行匹配检查。如果if-match子句指定了IPv6地址前缀列表,则所有的IPv4路由信息都会匹配该子句;如果if-match子句指定了IPv4地址前缀列表,则所有的IPv6路由信息都会匹配该子句。
配置本命令后,如果路由策略的if-match子句指定了IPv6地址前缀列表,则所有的IPv4路由信息都无法通过该子句的匹配;如果if-match子句指定了IPv4地址前缀列表,则所有的IPv6路由信息都无法通过该子句的匹配。
# 配置路由策略对路由信息的协议类型(IPv4或IPv6)和通过if-match子句指定的地址前缀列表的协议类型进行匹配检查,协议类型不一致的路由信息无法通过该if-match子句的过滤。
[Sysname] route-policy prefix-protocol-check
·     if-match ip
·     if-match ipv6
1.2  IPv4路由策略配置命令
apply fast-reroute命令用来配置快速重路由备份。
undo apply fast-reroute命令用来恢复缺省情况。
未配置快速重路由备份。
路由策略视图
backup-interface interface-type interface-number:备份出接口。对于备份出接口为非P2P类型的接口时(包括NBMA类型接口或广播类型接口),必须同时指定其对应的备份下一跳地址。interface-type interface-number为指定的接口类型和编号。
backup-nexthop ip-address:备份下一跳地址。
# 创建一个名为policy1的路由策略,为到达目的地100.1.1.0/24的路由配置备份出接口为GigabitEthernet3/1/1,备份下一跳地址为193.1.1.8。
[Sysname-route-policy-policy1-10] apply fast-reroute backup-interface gigabitethernet 3/1/1 backup-nexthop 193.1.1.8
apply ip-address next-hop命令用来配置IPv4路由信息的下一跳地址。
undo apply ip-address next-hop命令用来恢复缺省情况。
未配置IPv4路由信息的下一跳地址。
路由策略视图
ip-address:下一跳IP地址。
public:指定公网。
vpn-instance vpn-instance-name:指定VPN实例的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
当引入路由时,使用本命令设置下一跳地址无效。
如果未指定参数public或vpn-instance vpn-instance-name,则表示下一跳地址为公网地址。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。如果匹配已存在的编号为1的AS路径访问列表,那么设置路由信息的下一跳地址为193.1.1.8。
[Sysname-route-policy-policy1-10] apply ip-address next-hop 193.1.1.8
display ip prefix-list命令用来显示IPv4地址前缀列表的统计信息。
name prefix-list-name:指定显示的地址前缀列表名,为1~63个字符的字符串,区分大小写。如果未指定本参数,将显示所有已配置的地址前缀列表的统计信息。
# 显示名为abc的地址前缀列表的统计信息。
<Sysname> display ip prefix-list name abc
Prefix-list: abc
 Permitted 0
 Denied 0
         index: 10        Deny   6.6.6.0/24              ge  26  le  28
表1-7 display ip prefix-list命令显示信息描述表
Prefix-list
地址前缀列表的名称
Permitted
符合匹配条件的路由个数
Denied
不符合匹配条件的路由个数
index
地址前缀列表的内部序列号
deny
匹配模式,有两种取值:
·     Permit:表示允许
·     Deny:表示拒绝
6.6.6.0/24
匹配的IP地址和掩码长度
ge
即greater-equal,匹配的IP地址掩码长度的下限值
le
即less-equal,匹配的IP地址掩码长度的上限值
·     ip prefix-list
·     reset ip prefix-list
1.2.4  if-match ip
if-match ip命令用来配置IPv4的路由信息的匹配条件。
undo if-match ip命令用来取消IPv4的路由信息的匹配条件的配置。
if-match ip { address | next-hop | route-source } { acl { ipv4-acl-number | name ipv4-acl-name } | prefix-list prefix-list-name }
undo if-match ip { address | next-hop | route-source } [ acl | prefix-list ]
未配置IPv4的路由信息的匹配条件。
路由策略视图
address:匹配IPv4路由信息的目的地址。
next-hop:匹配下一跳地址。
route-source:匹配路由发布的源地址。仅对BGP路由有效,对IGP路由无效,其识别匹配的是IP路由表详细信息中的"Neighbor"字段。
acl ipv4-acl-number:指定用于过滤的ACL号。对于address,ipv4-acl-number的取值范围为2000~3999;对于next-hop和route-source,ipv4-acl-number的取值范围为2000~2999。
acl name ipv4-acl-name:指定用于过滤的ACL名称,ipv4-acl-name表示ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。
prefix-list prefix-list-name:指定用于过滤的地址前缀列表名称,为1~63个字符的字符串,区分大小写。
引用ACL时,需要注意的是:
·     若引用的ACL不存在,或者引用的ACL中没有配置规则,则匹配所有的IPv4路由信息。
·     在引用的ACL中,若某规则指定了vpn-instance参数,则该规则将不生效。
当配置的是高级ACL时,其使用规则如下:
·     使用命令rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard来过滤指定IPv4地址的路由信息。
·     使用命令rule [ rule-id ] { deny | permit } ip destination dest-addr dest-wildcard来过滤指定掩码的路由信息,配置的掩码应该是连续的(当配置的掩码不连续时该过滤掩码的条件不生效)。当指定next-hop或route-source参数时,不能使用本规则,否则,所有的报文都可与指定ACL中的规则相匹配,导致路由信息匹配结果异常。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。定义一个if-match子句,允许下一跳地址匹配已存在的地址前缀列表p1的路由信息通过。
[Sysname-route-policy-policy1-10] if-match ip next-hop prefix-list p1
ip prefix-list命令用来配置一个IPv4地址前缀列表或表项。
undo ip prefix-list命令用来删除指定的IPv4地址前缀列表或其某个表项。
undo ip prefix-list prefix-list-name [ index index-number ]
不存在IPv4地址前缀列表。
prefix-list-name:指定IPv4地址前缀列表名,为1~63个字符的字符串,区分大小写。
index-number:标识IPv4地址前缀列表中的一条表项,index-number小的表项先被匹配,取值范围为1~65535。如果未指定本参数,该序号值按照配置先后顺序依次递增,每次加10,第一个序号值为10。对设备进行目标配置时,本参数为必选参数。关于目标配置的详细介绍请参见“基础配置指导”中的“目标配置管理”。
deny:指定所定义的IPv4地址前缀列表表项的匹配模式为拒绝模式。在该模式下,如果过滤的IPv4地址在定义的范围内,则不能通过过滤,并且不进行下一节点的匹配;否则,进行下一节点的匹配。
permit:指定所定义的IPv4地址前缀列表表项的匹配模式为允许模式。在该模式下,如果过滤的IPv4地址在定义的范围内,则通过过滤,不进行下一个节点的匹配;否则,进行下一节点的匹配。
ip-address mask-length:指定IPv4地址前缀和前缀长度,mask-length的取值范围为0~32。
greater-equal min-mask-length、less-equal max-mask-length:如果IPv4地址和前缀长度都已匹配,则使用该参数来指定地址前缀长度范围。greater-equal表示大于等于,less-equal表示小于等于。前缀长度范围可以表达为mask-length <= min-mask-length <= max-mask-length <= 32。如果只指定min-mask-length时,则前缀长度范围为[ min-mask-length,32 ];如果只指定max-mask-length时,则前缀长度范围为[ mask-length,max-mask-length ];如果二者都指定,则前缀长度范围为[ min-mask-length,max-mask-length ]。
IPv4地址前缀列表用于IPv4地址的过滤。一个IPv4地址前缀列表可以有若干条表项,每一表项指定一个地址前缀范围。表项之间的过滤关系是“或”的关系,即通过一条表项的过滤就意味着通过该IPv4地址前缀列表的过滤。若没有通过任一表项的过滤,则不能通过该IPv4地址前缀列表的过滤。
如果将ip-address mask-length指定为0.0.0.0 0,则只匹配缺省路由。如果需要匹配所有路由,则应配置为0.0.0.0 0 less-equal 32。
# 定义一条名为p1的IPv4地址前缀列表,只允许10.0.0.0/8网段的,掩码长度为17或18的路由通过。
[Sysname] ip prefix-list p1 permit 10.0.0.0 8 greater-equal 17 less-equal 18
·     display ip prefix-list
reset ip prefix-list命令用来清除IPv4地址前缀列表的统计信息。
prefix-list-name:指定地址前缀列表的名称,为1~63个字符的字符串,区分大小写。如果未指定本参数,将清除所有的IPv4地址前缀列表的统计信息。
# 清除IPv4地址前缀列表abc的统计信息。
<Sysname> reset ip prefix-list abc
·     ip prefix-list
1.3  IPv6路由策略配置命令
apply ipv6 fast-reroute命令用来配置快速重路由备份。
undo apply ipv6 fast-reroute命令用来恢复缺省情况。
未配置快速重路由备份。
路由策略视图
backup-nexthop ipv6-address:备份下一跳IPv6地址。
# 创建一个名为policy1的路由策略,为到达目的地100::1/64的路由配置备份下一跳地址为1::1/64。
[Sysname] ipv6 prefix-list abc index 10 permit 100::1 64
[Sysname-route-policy-policy1-10] if-match ipv6 address prefix-list abc
[Sysname-route-policy-policy1-10] apply ipv6 fast-reroute backup-nexthop 1::1
apply ipv6 next-hop命令用来配置IPv6路由信息的下一跳地址。
undo apply ipv6 next-hop命令用来恢复缺省情况。
未配置IPv6路由信息的下一跳地址。
路由策略视图
ipv6-address:指定下一跳IPv6地址。
引入路由时,使用apply ipv6 next-hop命令设置下一跳地址无效。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。如果匹配已存在的编号为1的as-path,那么配置路由的下一跳地址为3ffe:506::1。
[Sysname-route-policy-policy1-10] apply ipv6 next-hop 3ffe:506::1
display ipv6 prefix-list命令用来显示IPv6地址前缀列表的统计信息。
name prefix-list-name:指定IPv6地址前缀列表的名称,为1~63个字符的字符串,区分大小写。如果未指定本参数,将显示所有配置的IPv6地址前缀列表的统计信息。
# 显示所有IPv6地址前缀列表的统计信息。
<Sysname> display ipv6 prefix-list
Prefix-list6: 666
 Permitted 0
 Denied 0
         index: 10        Permit 6::/64                  ge  66  le  88
表1-8 display ipv6 prefix-list命令显示信息描述表
Prefix-list6
IPv6地址前缀列表的名称
Permitted
符合匹配条件的路由个数
Denied
不符合匹配条件的路由个数
index
地址前缀列表的内部序列号
permit
匹配模式,有两种取值:
·     Permit:表示允许
·     Deny:表示拒绝
6::/64
匹配的IPv6地址和前缀长度
ge
即greater-equal,匹配的IPv6前缀长度的下限值
le
即less-equal,匹配的IPv6前缀长度的上限值
·     ipv6 prefix-list
·     reset ipv6 prefix-list
1.3.4  if-match ipv6
if-match ipv6命令用来配置IPv6的路由信息的匹配条件。
undo if-match ipv6命令用来取消IPv6的路由信息的匹配条件的配置。
if-match ipv6 { address | next-hop | route-source } { acl { ipv6-acl-number | name ipv6-acl-name } | prefix-list prefix-list-name }
undo if-match ipv6 { address | next-hop | route-source } [ acl | prefix-list ]
未配置IPv6的路由信息的匹配条件。
路由策略视图
address:匹配IPv6路由信息的目的地址。
next-hop:匹配IPv6路由信息的下一跳。
route-source:匹配IPv6路由信息的源地址。
acl ipv6-acl-number:指定用于过滤的IPv6 ACL号。对于address,ipv6-acl-number的取值范围为2000~3999;对于next-hop和route-source,ipv6-acl-number的取值范围为2000~2999。
acl name ipv6-acl-name:指定用于过滤的IPv6 ACL名称,ipv6-acl-name表示ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。
prefix-list prefix-list-name:指定用于过滤的IPv6地址前缀列表的名称,为1~63个字符的字符串,区分大小写。
引用IPv6 ACL时,需要注意的是:
·     若引用的IPv6 ACL不存在,或者引用的IPv6 ACL中没有配置规则,则匹配所有的IPv6路由信息。
·     在引用的IPv6 ACL中,若某规则指定了vpn-instance参数,则该规则将不生效。
·     使用命令rule [ rule-id ] { deny | permit } ipv6 source source-address source-prefix来过滤指定IPv6地址的路由信息。
·     使用命令rule [ rule-id ] { deny | permit } ipv6 destination dest-address dest-prefix来过滤指定IPv6地址前缀的路由信息。当指定next-hop或route-source参数时,不能使用本规则,否则,所有的报文都可与指定ACL中的规则相匹配,导致路由信息匹配结果异常。
# 创建一个名为policy1的路由策略,其节点序列号为10,匹配模式为permit。定义一条if-match子句,允许下一跳地址匹配已存在的IPv6地址前缀列表p1的路由信息通过。
[Sysname-route-policy-policy1-10] if-match ipv6 next-hop prefix-list p1
ipv6 prefix-list命令用来配置IPv6地址前缀列表或表项。
undo ipv6 prefix-list命令用来删除指定的IPv6地址前缀列表或其中某个表项。
ipv6 prefix-list prefix-list-name [ index index-number ] { deny | permit } ipv6-address { prefix-length [ greater-equal min-prefix-length ] [ less-equal max-prefix-length ] | inverse inverse-prefix-length }
undo ipv6 prefix-list prefix-list-name [ index index-number ]
不存在IPv6地址前缀列表。
prefix-list-name:指定IPv6地址前缀列表名,为1~63个字符的字符串,区分大小写。
index-number:标识IPv6地址前缀列表中的一条表项,index-number小的表项先被匹配,取值范围为1~65535。如果未指定本参数,该序号值按照配置先后顺序依次递增,每次加10,第一个序号值为10。对设备进行目标配置时,本参数为必选参数。关于目标配置的详细介绍请参见“基础配置指导”中的“目标配置管理”。
deny:指定所定义的IPv6地址前缀列表表项的匹配模式为拒绝模式。在该模式下,如果过滤的IPv6地址在定义的范围内,则不能通过过滤,并且不进行下一节点的匹配;否则,进行下一节点的匹配。
permit:指定所定义的IPv6地址前缀列表表项的匹配模式为允许模式。在该模式下,如果过滤的IPv6地址在定义的范围内,则通过过滤,不进行下一个节点的匹配;否则,进行下一节点的匹配。
ipv6-address:指定IPv6地址。
prefix-length:指定前缀长度,取值范围为0~128。
greater-equal min-prefix-length、less-equal max-prefix-length:如果IPv6地址和前缀长度都已匹配,则使用该参数来指定地址前缀长度范围。greater-equal表示大于等于,less-equal表示小于等于。前缀长度范围可以表达为prefix-length <= min-prefix-length <= max-prefix-length <= 128。如果只指定了min-prefix-length,则前缀范围为[ min-prefix-length,128 ];如果只指定了max-prefix-length,则前缀范围为[ prefix-length,max-prefix-length ];如果二者都指定,则前缀范围为[ min-prefix-length,max-prefix-length ]。
inverse inverse-prefix-length:指定反向前缀长度,即与指定的IPv6地址前缀从最低位开始需要匹配的位数。inverse-prefix-length的取值范围为1~128。
IPv6地址前缀列表用于IPv6地址过滤。一个IPv6地址前缀列表可包含多个表项,一个表项指定一个地址前缀范围。表项之间的过滤关系是“或”,即通过一个表项就可通过该IPv6地址前缀列表的过滤。没有通过任何一个表项的过滤就意味着没有通过该IPv6地址前缀列表的过滤。
如果将ipv6-address prefix-length指定为:: 0,则只匹配缺省路由。如果需要匹配所有路由,则应配置为:: 0 less-equal 128。
# 配置一条IPv6地址前缀列表,允许前缀长度在32位到64位之间的IPv6地址通过。
[Sysname] ipv6 prefix-list abc permit :: 0 greater-equal 32 less-equal 64
# 配置一条IPv6地址前缀列表,拒绝地址前缀为3FFE:D00::/32,前缀长度大于等于32位的IPv6地址通过。
[Sysname] ipv6 prefix-list abc deny 3FFE:D00:: 32 less-equal 128
·     display ipv6 prefix-list
reset ipv6 prefix-list命令用来清除IPv6地址前缀列表的统计信息。
prefix-list-name:指定地址前缀列表的名称,为1~63个字符的字符串,区分大小写。如果未指定本参数,将清除所有的IPv6地址前缀列表的统计信息。
# 清除指定IPv6地址前缀列表的统计信息。
<Sysname> reset ipv6 prefix-list abc
·     ipv6 prefix-list
