10-ACL和QoS命令参考
02-QoS命令
本章节下载: 02-QoS命令  (442.69 KB)
02-QoS命令
1 QoS策略
1.1 定义类的命令
1.1.1 display traffic classifier user-defined
1.1.2 if-match
1.1.3 traffic classifier
1.2 定义流行为的命令
1.2.1 accounting
1.2.2 car
1.2.3 display traffic behavior user-defined
1.2.4 filter
1.2.5 packet-rate
1.2.6 primap pre-defined color
1.2.7 redirect
1.2.8 remark dot1p
1.2.9 remark drop-precedence
1.2.10 remark dscp
1.2.11 remark local-precedence
1.2.12 remark mpls-exp
1.2.13 traffic behavior
1.3 定义策略和应用策略的命令
1.3.1 classifier behavior
1.3.2 control-plane
1.3.3 display qos policy user-defined
1.3.4 display qos policy global
1.3.5 display qos policy interface
1.3.6 display qos vlan-policy
1.3.7 display qos policy control-plane
1.3.8 display qos policy control-plane pre-defined
1.3.9 qos apply policy
1.3.10 qos apply policy global
1.3.11 qos policy
1.3.12 qos vlan-policy
1.3.13 reset qos policy control-plane
1.3.14 reset qos policy global
1.3.15 reset qos vlan-policy
2 优先级映射配置命令
2.1 优先级映射表配置命令
2.1.1 display qos map-table
2.1.2 display qos map-table color
2.1.3 import
2.1.4 qos map-table
2.1.5 qos map-table color
2.2 端口优先级配置命令
2.2.1 qos priority
2.3 端口优先级信任模式配置命令
2.3.1 display qos trust interface
2.3.2 qos trust
3 流量监管/流量整形
3.1 流量监管配置命令
3.1.1 display car resource
3.2 流量整形配置命令
3.2.1 display qos gts interface
3.2.2 qos gts
4 硬件实现拥塞管理
4.1 严格优先级队列配置命令
4.1.1 display qos sp
4.1.2 qos sp
4.2 加权公平队列配置命令
4.2.1 display qos wfq interface
4.2.2 qos bandwidth queue
4.2.3 qos wfq
4.2.4 qos wfq weight
4.3 队列调度策略配置命令
4.3.1 display qos qmprofile configuration
4.3.2 display qos qmprofile interface
4.3.3 qos apply qmprofile
4.3.4 qos qmprofile
4.3.5 queue
5 拥塞避免配置命令
5.1 WRED配置命令
5.1.1 display qos wred interface
5.1.2 qos wred enable
6 全局CAR
6.1 全局CAR配置命令
6.1.1 car name
6.1.2 display qos car name
6.1.3 qos car aggregative
6.1.4 reset qos car name
7 报文统计
7.1 报文统计配置命令
7.1.1 display qos traffic-counter
7.1.2 qos traffic-counter
7.1.3 reset qos traffic-counter
8 QoS调度精度增强模式配置命令
8.1.1 enhanced-qos
9 QoS管道模式配置命令
9.1.1 qos pipe-mode
1 QoS策略
·     设备支持两种运行模式:独立运行模式和IRF模式,缺省情况为独立运行模式。有关IRF模式的介绍,请参见“IRF配置指导”中的“IRF”。
·     本文中提到的EB类单板和EC2类单板指的是丝印后缀分别为EB、EC2的单板。
·     本文中提到的ACL标准模式指的是EB/EC2类单板的一种ACL工作模式,关于ACL标准模式的详细介绍,请参见“ACL和QoS配置指导”中的“ACL”。
1.1  定义类的命令
display traffic classifier user-defined [ tcl-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
tcl-name:类名。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display traffic classifier user-defined命令用来显示配置的用户自定义类信息。
如果未指定类名,本命令将显示所有用户自定义类的信息。
# 显示配置的用户自定义的类信息。
  User Defined Classifier Information:
   Classifier: tc1
    Operator: AND
    Rule(s) : If-match acl 2000
表1-1 display traffic classifier user-defined命令显示信息描述表
用户自定义类的信息
Classifier
类的名字及其内容,内容可以有多种类型
Operator
分类规则之间的逻辑关系
Rule
分类规则
1.1.2  if-match
if-match match-criteria
undo if-match match-criteria
类视图
【缺省级别】
2:系统级
match-criteria:类的匹配规则,取值范围如下表所示。
表1-2 类的匹配规则取值
取值
acl [ ipv6 ] { acl-number | name acl-name }
定义匹配ACL的规则
acl-number是ACL的序号,IPv4 ACL序号的取值范围是2000~5999,IPv6 ACL序号的取值范围是2000~3999
acl-name是ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头,为避免混淆,ACL的名称不可以使用英文单词all
如果QoS策略引用了匹配规则是用户自定义ACL的类,仅当该QoS策略应用在入方向时,用户自定义ACL才生效
当EB/EC2类单板工作在ACL标准模式时,该类单板上应用的QoS策略不支持引用匹配规则为IPv6 ACL和用户自定义ACL的类
customer-dot1p 8021p-list
定义匹配用户网络802.1p优先级的规则,8021p-list为802.1p优先级值的列表,最多可以输入8个802.1p优先级值,802.1p优先级取值范围为0~7
在全局QoS策略和VLAN策略中,不支持配置本参数
当EB/EC2类单板工作在ACL标准模式时,该类单板上应用的QoS策略不支持引用匹配规则中带有本参数的类
customer-vlan-id { vlan-id-list | vlan-id1 to vlan-id2 }
定义匹配用户网络VLAN ID的规则,vlan-id-list为VLAN ID的列表,最多可以输入8个VLAN ID,vlan-id1 to vlan-id2表示一个VLAN ID的范围,vlan-id1的值必须小于vlan-id2的值,VLAN ID取值范围为1~4094
destination-mac mac-address
定义匹配目的MAC地址的规则
当EB/EC2类单板工作在ACL标准模式时,该类单板入方向应用的QoS策略引用匹配规则中带有本参数的类,对IPv4报文不生效;该类单板出方向应用的QoS策略引用匹配规则中带有本参数的类,对IPv4报文和IPv6报文不生效
dscp dscp-list
定义匹配DSCP的规则,dscp-list为DSCP取值的列表,最多可以输入8个DSCP取值,DSCP取值范围为0~63
inbound-interface interface-type interface-number
定义匹配入接口的规则,interface-type interface-number为接口类型和接口编号
·     该关键字仅能基于控制平面应用QoS策略
·     inbound-interface所指定的接口必须与qos apply policy所应用的控制平面所在的槽位一致,否则功能应用失败
·     需要注意的是,当使用本字段时,此流分类对应的流行为下只能配置流量过滤动作或流量监管动作,即只能配置filter或car命令
forwarding-layer { bridge | route }
定义匹配2层或者3层转发报文的规则:bridge表示匹配2层转发报文;route表示匹配3层转发报文
ip-precedence ip-precedence-list
定义匹配IP优先级的规则,ip-precedencee-list为ip-precedence的列表,最多可以输入8个ip-precedence,ip-precedence取值范围为0~7
mpls-exp exp-list
定义匹配外层MPLS EXP优先级的规则,exp-list为EXP的列表,最多可以输入8个EXP,EXP取值范围为0~7
当EB/EC2类单板工作在ACL标准模式时,该类单板出方向应用的QoS策略不支持引用匹配规则中带有本参数的类
mpls-label { label-id-list | label-id1 to label-id2 }
定义匹配外层MPLS Label值的规则,label-id-list为MPLS Label值的列表,最多可以输入8个Label值;label-id1 to label-id2表示一个Label ID的范围,label-id1的值必须小于label-id2的值,Label ID取值范围为0~1048575
protocol protocol-name
定义匹配协议的规则,protocol-name取值为arp、ip、ipv6
当EB/EC2类单板工作在ACL标准模式时,该类单板上应用的QoS策略不支持引用匹配规则为ipv6协议的类
second-mpls-exp exp-list
定义匹配内层MPLS EXP优先级的规则,exp-list为EXP的列表,最多可以输入8个EXP,EXP取值范围为0~7
second-mpls-label { label-id-list | label-id1 to label-id2 }
定义匹配内层MPLS Label值的规则,label-id-list为MPLS Label值的列表,最多可以输入8个Label值;label-id1 to label-id2表示一个Label ID的范围,label-id1的值必须小于label-id2的值,Label ID取值范围为0~1048575
service-dot1p 8021p-list
定义匹配运营商网络802.1p优先级的规则,8021p-list为802.1p优先级值的列表,最多可以输入8个802.1p优先级值,802.1p优先级取值范围为0~7
service-vlan-id { vlan-id-list | vlan-id1 to vlan-id2 }
定义匹配运营商网络VLAN ID的规则,vlan-id-list为VLAN ID的列表,最多可以输入8个VLAN ID,vlan-id1 to vlan-id2表示一个VLAN ID的范围,vlan-id1的值必须小于vlan-id2的值,VLAN ID取值范围为1~4094
system-index index-value-list
定义规则来匹配预定义的上送控制平面报文类型,index-value-list为系统预定义匹配字段索引号(system-index)的列表,最多可以输入8个system-index值,system-index值的取值范围为1~28,每个取值的具体含义可以通过display qos policy control-plane pre-defined命令来查看
需要注意的是,当使用本字段时,此流分类中不能再定义其它匹配规则,并且此流分类对应的流行为下只能配置限速动作,即只能配置packet-rate命令
source-mac mac-address
定义匹配源MAC地址的规则
当EB/EC2类单板工作在ACL标准模式时,该类单板入方向应用的QoS策略引用匹配规则中带有本参数的类,对IPv4报文不生效;在该类单板出方向应用的QoS策略引用匹配规则中带有本参数的类,对IPv4报文和IPv6报文不生效
undo if-match命令还有一个特殊的形式,用来更改流分类规则中引用的ACL,将源ACL变更为新的ACL:undo if-match acl [ ipv6 ] { acl-number | name acl-name } [ update acl [ ipv6 ] { acl-number | name acl-name } ]。
【描述】
if-match命令用来定义匹配指定匹配规则的所有报文的规则。undo if-match命令用来删除匹配指定匹配规则的所有报文的规则。
在定义各个规则的时候,注意事项如下:
(1)     定义匹配ACL的规则
·     如果类中引用的ACL不存在,则不能在硬件中下发。
·     如果类下的规则之间是逻辑或的关系,则该类允许通过ACL名称和序号的方式分别引用一次同一个ACL;如果类下的规则之间是逻辑与的关系,则该类允许通过ACL名称或序号的方式仅引用一次同一个ACL。
(2)     定义匹配目的MAC地址规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。
(3)     定义匹配源MAC地址规则
(4)     定义匹配DSCP的规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,dscp值将自动按照配置先后的顺序排序。
·     一条命令可以配置多个DSCP值,最多可指定8个;如果指定了多个相同的DSCP值,系统默认为一个;多个不同的DSCP值是或的关系。
·     删除某条匹配DSCP的规则时,指定的所有DSCP值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(5)     定义匹配入接口的规则
·     定义该匹配规则时,指定接口必须存在。如果接口为动态接口,在该接口删除后,该规则被删除。
·     支持接口类型:以太网接口。
(6)     定义匹配用户网络或运营商网络的802.1p优先级的规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,8021p值将自动按照从小到大的顺序排序。
·     一条命令可以配置多个802.1p优先级值,最多可指定8个;如果指定了多个相同的802.1p优先级值,系统默认为一个;多个不同的802.1p优先级值是或的关系。
·     删除某条匹配802.1p优先级的规则时,指定的所有802.1p优先级值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(7)     定义匹配IP优先级的规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,IP优先级的值将自动按照配置先后的顺序排序。
·     一条命令可以配置多个IP优先级值,最多可指定8个;如果指定了多个相同的IP优先级值,系统默认为一个;多个不同的IP优先级值是或的关系。
·     删除某条匹配IP优先级的规则时,指定的所有IP优先级值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(8)     定义匹配MPLS EXP优先级的规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,MPLS EXP优先级的值将自动按照小到大的顺序排序。
·     一条命令可以配置多个MPLS EXP优先级值,最多可指定8个;如果指定了多个相同的MPLS EXP优先级值,系统默认为一个;多个不同的MPLS EXP优先级值是或的关系。
·     删除某条匹配MPLS EXP优先级的规则时,指定的所有MPLS EXP优先级值必须与该规则中定义的完全相同才会删除,顺序可不一样。
·     MPLS EXP为MPLS报文特有的参数,该匹配规则仅对MPLS报文生效。
·     MPLS报文不支持匹配IP相关匹配规则。
(9)     定义匹配MPLS Label值的规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,MPLS Label值将自动按照小到大的顺序排序。
·     一条命令可以配置多个MPLS Label值,最多可指定8个;如果指定了多个相同的MPLS Label值,系统默认为一个;多个不同的MPLS Label值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配MPLS Label值的规则时,指定的所有MPLS Label值必须与该规则中定义的完全相同才会删除,顺序可不一样。
·     MPLS Label为MPLS报文特有的参数,该匹配规则仅对MPLS报文生效。
(10)     定义匹配用户网络和运营商网络VLAN ID的规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,vlan-id值将自动按照配置先后的顺序排序。
·     一条命令可以配置多个VLAN ID值,如果指定了多个相同的VLAN ID值,系统默认为一个;多个不同的VLAN ID值是或的关系。
·     删除某条匹配VLAN ID的规则时,指定的所有VLAN ID值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(11)     定义匹配预定义的上送控制平面报文类型的规则
·     一条命令可以配置多个system-index值,如果指定了多个相同的system-index值,系统默认为一个;多个不同的system-index值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配system-index的规则时,指定的所有system-index值必须与该规则中定义的完全相同才会删除,顺序可不一样。
·     系统预定义的报文类型信息可以通过display qos policy control-plane pre-defined命令查看。
(12)     定义匹配2层转发或者3层转发报文的规则
·     if-match forwarding-layer bridge和 if-match forwarding-layer route 不能同时配置。
·     forwarding-layer参数不能在类中单独配置,即在配置该参数的类中必须配置有其它参数;且不论类操作符是and或or,同时配置的其它参数都不允许和forwarding-layer参数冲突。
相关配置可参考命令traffic classifier。
# 定义类class1的匹配规则为:匹配目的MAC地址为0050-BA27-BE88的报文。
[Sysname-classifier-class1] if-match destination-mac 0050-ba27-be88
# 定义类class1的匹配规则为:匹配用户网络802.1p优先级为3。
# 定义类class1的匹配规则为:匹配运营商网络802.1p优先级为5。
[Sysname-classifier-class1] if-match service-dot1p 5
# 定义类class1的匹配规则为:匹配用户网络VLAN ID值为1的报文。
[Sysname-classifier-class1] if-match customer-vlan-id 1
# 定义类class1的匹配规则为:匹配运营商网络VLAN ID值为2的报文。
[Sysname-classifier-class1] if-match service-vlan-id 2
traffic classifier tcl-name [ operator { and | or } ]
undo traffic classifier tcl-name
【缺省级别】
2:系统级
tcl-name:类名,为1~31个字符的字符串。
operator:指定各规则之间的逻辑运算符。
【描述】
traffic classifier命令用来定义一个类并进入类视图。undo traffic classifier命令用来删除一个类。
缺省情况下为operator and。
相关配置可参考命令qos policy、qos apply policy和classifier behavior。
# 定义一个名为class1的类。
1.2  定义流行为的命令
1.2.1  accounting
accounting { byte | packet }
undo accounting
流行为视图
【缺省级别】
2:系统级
byte:表示报文以字节为单位进行统计。
packet:表示报文以包数为单位进行统计。此参数的配置,同时会影响CAR的统计单位。
【描述】
accounting命令用来为流行为配置流量统计动作。undo accounting命令用来取消流量统计动作配置。
相关配置可参考命令qos policy、traffic behavior和classifier behavior。
# 在流行为中配置以字节数为单位的流量统计动作。
[Sysname-behavior-database] accounting byte
1.2.2  car
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ pir peak-information-rate ] [ red action ]
undo car
流行为视图
【缺省级别】
2:系统级
cir committed-information-rate:承诺信息速率。流量的平均速率,取值范围为:1~20000000,单位为kbps。
cbs committed-burst-size:承诺突发尺寸,取值范围为:1553~2147450880,单位为byte。设置的突发尺寸必须大于最大报文长度。缺省取值为500毫秒以CIR速率通过的流量,若该数值小于1553,则缺省值为1553。
ebs excess-burst-size:超出突发尺寸,单位为byte,取值范围为:0~2147450880,缺省值为0。
pir peak information rate:峰值速率,取值范围为:1~20000000,单位为kbps。
red action:数据包的流量既不符合承诺速率也不符合峰值速率时对数据包采取的动作,缺省动作为discard。action:对数据包采取的动作,有以下几种:
·     discard:丢弃数据包。
·     pass:允许数据包通过。
【描述】
car命令用来为流行为配置流量监管动作。undo car命令用来取消流量监管动作配置。
如果多次使用该命令在同一个流行为上配置,最后一次配置生效。
# 为流行为配置流量监管。报文正常流速为200kbps,承诺突发尺寸为50000byte,不符合承诺速率时对数据包采取丢弃动作。
[Sysname-behavior-database] car cir 200 cbs 50000 red discard
display traffic behavior user-defined [ behavior-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
behavior-name:行为名,为1~31个字符的字符串。如果未指定行为名,则显示所有系统预定义行为或所有用户定义行为的信息。
【描述】
display traffic behavior user-defined命令用来显示用户自定义的流行为信息。
# 显示配置的用户自定义的流行为信息。
  User Defined Behavior Information:
    Behavior: tb1
      Committed Access Rate:
        CIR 1000 (kbps), CBS 100000 (byte), EBS 0 (byte)
        Red Action: discard
      Marking:
        Remark dot1p COS 5
表1-3 display traffic behavior user-defined命令显示信息描述表
用户自定义流行为的信息
Behavior
行为的名字及其内容,内容可以有多种类型
流量限速的相关信息
Marking
重标记的相关信息
1.2.4  filter
filter { deny | permit }
undo filter
流行为视图
【缺省级别】
2:系统级
deny:丢弃数据包。
permit:允许数据包通过。
【描述】
filter命令用来为流行为配置流量过滤动作。undo filter命令用来取消过滤动作配置。
# 为流行为配置丢弃数据包的过滤动作。
1.2.5  packet-rate
packet-rate value
undo packet-rate
流行为视图
【缺省级别】
2:系统级
value:协议报文速率,单位为包每秒(pps)。取值范围为1~1048575。
【描述】
packet-rate命令用来为流行为配置限速动作。undo packet-rate命令用来取消配置。
通过限速可以对进入CPU的协议报文速率进行限制,保证CPU的正常运转, 防止遭受协议报文攻击。
# 为流行为copp配置CPU报文限速动作。
[Sysname] traffic behavior copp
[Sysname-behavior-copp] packet-rate 1600
primap pre-defined color { dot1p-dot1p | dot1p-exp | dot1p-dp | dot1p-dscp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp | up-dscp }
undo primap pre-defined color { dot1p-dot1p | dot1p-exp | dot1p-dp | dot1p-dscp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp | up-dscp }
流行为视图
【缺省级别】
2:系统级
pre-defined:预先定义的优先级映射表。
color:使用带颜色优先级映射表做映射。
dot1p-dot1p:802.1p优先级到802.1p优先级映射表。
dot1p-exp:802.1p优先级到EXP映射表。
dot1p-dp:802.1p优先级到丢弃优先级映射表。
dot1p-dscp:802.1p优先级到DSCP映射表。
dot1p-lp:802.1p优先级到本地优先级映射表。
dscp-dot1p:DSCP到802.1p优先级映射表。
dscp-dp:DSCP到丢弃优先级映射表。
dscp-dscp:DSCP到DSCP映射表。
dscp-exp:DSCP到EXP映射表。
dscp-lp:DSCP到本地优先级映射表。
exp-dot1p:EXP到802.1p优先级映射表。
exp-dp:EXP到丢弃优先级映射表。
exp-dscp:EXP到DSCP映射表。
exp-exp:EXP到EXP映射表。
exp-lp:EXP到本地优先级映射表。
up-dscp:用户优先级到DSCP映射表。
【描述】
primap pre-defined color命令用来配置流行为中的动作为使用相应的带颜色优先级映射表为报文获取其他的优先级参数。undo primap pre-defined color命令用来取消流行为中的使用相应的带颜色优先级映射表为报文映射优先级的动作。
需要注意的是,本命令需要和car结合在一起使用。
相关配置可参考命令display qos map-table color。
# 使用带颜色的DSCP到丢弃优先级映射表为报文获取丢弃优先级参数。
[Sysname-behavior-behavior1] car cir 1600
[Sysname-behavior-behavior1] primap pre-defined color dscp-dp
1.2.7  redirect
redirect { cpu | interface interface-type interface-number [ vlan vlan-id ] | next-hop { ipv4-add1 [ ipv4-add2 ] | ipv6-add1 [ interface-type interface-number ] [ ipv6-add2 [ interface-type interface-number ] ] } [ fail-action { discard | forward } ] }
undo redirect { cpu | interface interface-type interface-number | next-hop }
流行为视图
【缺省级别】
2:系统级
cpu:重定向到CPU。
interface:重定向到指定的接口。interface-type interface-number:指定接口类型和接口号,支持重定向到普通以太网接口或二层聚合接口。
vlan vlan-id:指定重定向报文封装的VLAN Tag,vlan-id为VLAN编号,取值范围1~4094。
next-hop:重定向到指定的下一跳。
ipv4-add:下一跳IPv4地址。ipv4-add2是ipv4-add1的备份下一跳地址,如果重定向到ipv4-add1失败,则会选择重定向到ipv4-add2。
ipv6-add:下一跳IPv6地址。IPv6地址为链路本地地址时,下一跳IPv6地址需要配置接口(该接口只能是VLAN接口);IPv6地址为非链路本地地址时,下一跳IPv6地址不需要配置接口。ipv6-add2是ipv6-add1的备份下一跳地址,如果重定向到ipv6-add1失败,则会选择重定向到ipv6-add2。
fail-action { discard | forward }:当下一跳的地址不存在的时候,对报文采取的动作。
·     discard:丢弃报文。
·     forward:根据普通路由转发报文。默认的动作为forward。
【描述】
redirect命令用来为流行为配置流量重定向动作。undo redirect命令用来取消流量重定向动作配置。
·     在IRF模式下,设备不支持将流量重定向到聚合接口。
·     与单纯依照IP报文的目的地址查找路由表进行转发不同,策略路由(即重定向到下一跳)可基于到达报文的源地址等信息,灵活地进行路由选择。策略路由的优先级要高于普通路由,即报文先按照策略路由进行转发,如果无法匹配所有的策略路由条件,再按照普通路由进行转发。
·     在独立运行模式下,设备不支持将流量重定向到LST1IPS2A1单板的聚合接口。
·     在IRF模式下,设备不支持跨框(即流量的出接口和入接口位于两台不同的成员设备上)将流量重定向到LST1IPS2A1单板的第二个内联接口。
·     通过QoS策略将流量重定向到LST1IPS2A1单板的内联接口时,需要配置两个内联接口聚合,同时配置聚合组中的最小选中端口数为2,并且不允许其他端口加入该聚合组。
# 为流行为配置流量重定向动作,重定向到GigabitEthernet3/0/1。
[Sysname-behavior-database] redirect interface gigabitethernet3/0/1
1.2.8  remark dot1p
remark dot1p 8021p
undo remark dot1p
流行为视图
【缺省级别】
2:系统级
8021p:标记的802.1p优先级,取值范围为0~7。
【描述】
remark dot1p命令用来配置标记报文的802.1p优先级。undo remark dot1p命令用来取消标记报文的802.1p优先级。
# 配置标记报文的802.1p优先级值为2。
[Sysname-behavior-database] remark dot1p 2
remark drop-precedence drop-precedence-value
undo remark drop-precedence
流行为视图
【缺省级别】
2:系统级
drop-precedence-value:标记的丢弃优先级,取值范围为0~2,值越小优先级越大。
【描述】
remark drop-precedence命令用来配置标记报文的丢弃优先级。undo remark drop-precedence命令用来取消标记报文的丢弃优先级。
# 配置标记报文的丢弃优先级值为2。
[Sysname-behavior-database] remark drop-precedence 2
1.2.10  remark dscp
remark dscp dscp-value
undo remark dscp
流行为视图
【缺省级别】
2:系统级
dscp-value:DSCP值,取值范围为0~63,也可以是关键字,如表1-4所示。
表1-4 DSCP关键字与值的对应表
关键字
DSCP值(二进制)
DSCP值(十进制)
default
000000
0
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
ef
101110
46
【描述】
remark dscp命令用来为类配置标记报文的DSCP值。undo remark dscp命令用来取消标记报文的DSCP值。
# 配置标记报文的DSCP值为6。
remark local-precedence local-precedence
undo remark local-precedence
流行为视图
【缺省级别】
2:系统级
local-precedence:标记的本地优先级,取值范围为0~7。
【描述】
remark local-precedence命令用来配置标记报文的本地优先级。undo remark local-precedence命令用来取消标记报文的本地优先级。
# 配置标记报文的本地优先级值为2。
remark mpls-exp exp-value
undo remark mpls-exp
流行为视图
【缺省级别】
2:系统级
exp-value:标记的MPLS报文的EXP域的值,取值范围为0~7。
【描述】
remark mpls-exp命令用来配置标记MPLS报文的EXP域的值。undo remark mpls-exp命令用来取消标记MPLS报文的EXP域的值。
# 配置标记MPLS报文的EXP域的值为2。
[Sysname-behavior-database] remark mpls-exp 2
【缺省级别】
2:系统级
behavior-name:流行为名,为1~31个字符的字符串。
【描述】
traffic behavior命令用来定义一个流行为并进入流行为视图。undo traffic behavior命令用来删除一个流行为。
# 定义一个名为behavior1的流行为。
1.3  定义策略和应用策略的命令
classifier tcl-name behavior behavior-name
undo classifier tcl-name
策略视图
【缺省级别】
2:系统级
tcl-name:类名。
behavior-name:流行为名。
【描述】
classifier behavior命令用来在策略中为类指定采用的流行为。undo classifier命令用来取消指定类在策略中的使用。
·     策略下每个类只能与一个动作关联。
·     如果配置本命令时指定的类和流行为不存在,系统将创建一个空的类和空的流行为。
相关配置可参考命令qos policy。
# 在策略user1中为类database指定采用流行为test。
[Sysname] qos policy user1
1.3.2  control-plane
独立运行模式:
IRF模式:
control-plane chassis chassis-number slot slot-number
【缺省级别】
2:系统级
slot slot-number:指定单板。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:指定成员设备上指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号,可使用display device查看。(IRF模式)
【描述】
control-plane slot命令用来进入指定单板的控制平面视图。
# 进入3号槽位的单板控制平面视图。(独立运行模式)
[Sysname] control-plane slot 3
[Sysname-cp-slot3]
# 进入1号成员设备3号槽位的单板控制平面视图。(IRF模式)
[Sysname] control-plane chassis 1 slot 3
[Sysname-cp-chassis1-slot3]
display qos policy user-defined [ policy-name [ classifier tcl-name ] ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
policy-name:策略名,如果未指定,则显示所有用户自定义策略的配置信息。
tcl-name:策略中的类名。
【描述】
display qos policy user-defined命令用来显示指定策略或所有策略中指定类或所有类及与类关联的行为的配置信息。
# 显示用户自定义策略中指定类或所有类及与类关联的行为的配置信息。
  User Defined QoS Policy Information:
  Policy: qpolicy
   Classifier: tc1
     Behavior: tb1
        Red Action: discard
      Marking:
        Remark dot1p COS 5
表1-5 display qos policy user-defined命令显示信息描述表
Policy
策略名
Classifier
类名,一个策略中可以存在多个类,每个类有对应的行为,每个类的匹配规则又可以有多条,参见traffic classifier命令
Behavior
策略中一个类对应的行为,每个行为可以有多条规则,参见traffic behavior命令
流量限速的相关信息
CIR
承诺信息速率,单位为kbps
CBS
承诺突发尺寸,也就是容纳突发流量的令牌桶深度,单位为Bytes
EBS
超出突发尺寸,在双令牌桶算法中超出突发流量超过承诺突发流量的部分,单位为Bytes
Red Action
对红色报文的动作
Marking
标记相关信息
独立运行模式:
display qos policy global [ slot slot-number ] [ inbound | outbound ] [ | { begin | exclude | include } regular-expression ]
IRF模式:
display qos policy global [ chassis chassis-number slot slot-number ] [ inbound | outbound ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
inbound:显示设备所有接口入方向应用的QoS策略信息。
outbound:显示设备所有接口出方向应用的QoS策略信息。
slot slot-number:显示指定单板上的基于全局应用QoS策略的信息,slot-number表示单板槽位号(独立运行模式)。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的基于全局应用QoS策略的信息。chassis-number表示设备在IRF中的成员编号(IRF模式)。
【描述】
display qos policy global命令用来显示全局QoS策略信息。
·     如果不指定显示方向,则同时显示出入两个方向基于全局应用QoS策略的信息。
·     如果不指定槽位号,则显示主控板上基于全局应用QoS策略的信息,不显示各单板的信息。
# 显示全局入方向上的QoS策略信息。
<Sysname> display qos policy global inbound
  Direction: Inbound
  Policy: qpolicy
   Classifier: tc1
     Operator: AND
     Behavior: tb1
        Red Action: discard
        Green : 0(Packets) 0(Bytes)
        Yellow: 0(Packets) 0(Bytes)
        Red   : 0(Packets) 0(Bytes)
      Marking:
        Remark dot1p COS 5
表1-6 display qos policy global命令显示信息描述表
Direction
策略应用的方向
Policy
策略名称及其内容
Classifier
类的名称及其内容,内容可以有多种类型
Operator
分类规则之间的逻辑关系
Rule(s)
分类规则
Behavior
流行为的名称及其内容,内容可以有多种类型
流量限速的相关信息
CIR
承诺信息速率,单位为kbps
CBS
EBS
Red Action
对红色报文的动作
Green
绿色报文的流量统计
Yellow
黄色报文的流量统计
Red
红色报文的流量统计
Marking
重标记相关信息
display qos policy interface [ interface-type interface-number ] [ inbound | outbound ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-type:接口类型。
interface-number:接口编号。
inbound:显示设备入方向的QoS策略的配置信息和运行情况。
outbound:显示设备出方向的QoS策略的配置信息和运行情况。
【描述】
display qos policy interface命令用来显示指定接口上QoS策略的配置信息和运行情况。
# 显示GigabitEthernet3/0/1接口入方向上QoS策略的配置信息和运行情况。
<Sysname> display qos policy interface gigabitethernet 3/0/1 inbound
  Interface: GigabitEthernet3/0/1
  Direction: Inbound
  Policy: qpolicy
   Classifier: tc1
     Operator: AND
     Behavior: tb1
        Red Action: discard
      Marking:
        Remark dot1p COS 5
表1-7 display qos policy interface命令显示信息描述表
接口名,由接口类型和接口编号结合在一起组成。
Direction
Policy应用在接口的方向
Policy
应用到接口上的策略的名字
Classifier
策略里分类规则以及对应的配置信息
Operator
同一个类中多条分类规则的逻辑关系
Rule(s)
类的分类规则
Behavior
策略里行为的名字及配置信息,参见behavior的相关命令
Marking
重标记相关信息
独立运行模式:
display qos vlan-policy { name policy-name | vlan [ vlan-id ] } [ slot slot-number ] [ inbound | outbound ] [ | { begin | exclude | include } regular-expression ]
IRF模式:
display qos vlan-policy { name policy-name | vlan [ vlan-id ] } [ chassis chassis-number slot slot-number ] [ inbound | outbound ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
name policy-name:显示指定策略名称的基于VLAN应用QoS策略的信息。policy-name表示策略名称。
vlan vlan-id:显示指定VLAN上应用的基于VLAN应用QoS策略的信息。vlan-id表示应用策略的VLAN ID。
slot slot-id:显示指定单板上基于VLAN应用QoS策略的信息,slot-number表示槽位号(独立运行模式)。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的基于VLAN应用QoS策略的信息。chassis-number表示设备在IRF中的成员编号(IRF模式)。
inbound:显示对VLAN接收到的报文应用的QoS策略信息。
outbound:显示对VLAN发送的报文应用的QoS策略信息。
【描述】
display qos vlan-policy命令用来显示基于VLAN应用QoS策略的信息。
·     如果不指定显示方向,则同时显示出入两个方向的基于VLAN应用QoS策略的信息。
·     如果不指定槽位号,则表示显示设备上所有的基于VLAN应用QoS策略的信息。
·     如果不指定成员编号和槽位号,则表示显示IRF系统上所有的基于VLAN应用QoS策略的信息。
# 显示入方向VLAN 2的策略信息。
<Sysname> display qos vlan-policy vlan 2 inbound
  Vlan 2
  Direction: Inbound
  Policy: qpolicy
   Classifier: tc1
     Operator: AND
     Behavior: tb1
        Red Action: discard
      Marking:
        Remark dot1p COS 5
表1-8 display qos vlan-policy命令输出信息描述
Vlan
引用QoS策略的VLAN ID
Direction
对VLAN接收到(Inbound)/发送(Outbound)的报文应用QoS策略
Policy
策略名称
Classifier
类的名称
Operator
分类规则之间的逻辑关系
Rule(s)
分类规则
Behavior
流行为的名称
流量限速的相关信息
CIR
承诺信息速率,单位为kbps
CBS
承诺突发尺寸,也就是容纳突发流量的令牌桶深度,单位为byte
EBS
超出突发尺寸,在双令牌桶算法中超出突发流量超过承诺突发流量的部分,单位为byte
Red Action
对红色报文的动作
Green
绿色报文的流量统计
Yellow
黄色报文的流量统计
Red
红色报文的流量统计
Marking
重标记相关信息
独立运行模式:
display qos policy control-plane slot slot-number [ inbound ] [ | { begin | exclude | include } regular-expression ]
IRF模式:
display qos policy control-plane chassis chassis-number slot slot-number [ inbound ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
slot slot-number:显示指定单板的控制平面应用QoS策略的信息,slot-number表示单板所在的槽位号。(独立运行模式)
inbound:显示对进入控制平面的报文应用的QoS策略信息。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的控制平面应用QoS策略的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号,可使用display device查看。(IRF模式)
【描述】
display qos policy control-plane命令用来显示指定槽位控制平面应用QoS策略的信息。
# 显示3号板控制平面入方向上应用的QoS策略信息。(独立运行模式)
<Sysname> display qos policy control-plane slot 3 inbound
Control-plane slot 3
  Direction: Inbound
  Policy: 1
    Classifier: 2
      Operator: AND
      Behavior: 2
          CIR 128 (kbps), CBS 8000 (byte), EBS 0 (byte)
          Red Action: discard
          Green : 12928(Bytes)
          Yellow: 7936(Bytes)
          Red   : 43904(Bytes)
# 显示1号成员设备3号板控制平面入方向上应用的QoS策略信息。(IRF模式)
<Sysname> display qos policy control-plane chassis 1 slot 3 inbound
Control-plane chassis 1 slot 3
  Direction: Inbound
  Policy: 1
   Classifier: default-class
     Matched : 0(Packets)
     Rule(s) : If-match any
     Behavior: be
表1-9 display qos policy control-plane命令显示信息描述表
Control-plane
控制平面
Direction
对进控制平面(Inbound)/出控制平面(Outbound)的报文应用QoS策略
Policy
策略名称及其内容
Classifier
类的名称及其内容,内容可以有多种类型
Matched
符合分类规则的数据包数目
Operator
分类规则之间的逻辑关系
Rule(s)
分类规则
Behavior
流量限速的相关信息
CIR
承诺信息速率,单位为kbps
CBS
EBS
Red Action
对红色报文的动作
Green
绿色报文的流量统计
Yellow
黄色报文的流量统计
Red
红色报文的流量统计
none
表示没有配置其他流行为
独立运行模式:
display qos policy control-plane pre-defined [slot slot-number ] [ | { begin | exclude | include } regular-expression ]
IRF模式:
display qos policy control-plane pre-defined [chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
slot slot-number:显示指定单板的系统预定义的控制平面策略信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number:显示指定成员设备上指定单板的系统预定义的控制平面策略信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号,可使用display device查看。(IRF模式)
【描述】
display qos policy control-plane pre-defined命令用来显示控制平面应用的系统预定义的QoS策略信息。
·     在独立运行模式下,如果不指定槽位号,则显示所有在位单板的系统预定义的控制平面应用QoS策略的信息。
·     在IRF模式下,如果不指定成员编号和槽位号,则显示所有成员设备上在位单板的系统预定义的控制平面应用QoS策略的信息。
# 在设备上显示3号板系统预定义的控制平面应用QoS策略的信息。
<Sysname> display qos policy control-plane pre-defined slot 3
  Slot: 3
  Pre-defined Control-plane Policy Slot: 3
  Index  |  PacketType  |  BandWidth(pps)  |  Priority
  1          STP             200               7
  2          ARP-BC          600               2
  3          IGMP            2048              3
  4          GVRP            100               7
  5          MLD             500               3
  6          PIM-MC          2000              4
  7          DHCP            400               2
  8          802.3ah         100               7
  9          TTL(1)          20                3
  10         HopLimit(1)     20                3
  11         ARP-UC          600               3
  12         LACP            100               7
  13         CFD             20000             7
  14         802.1X          4096              1
  15         RRPP            300               3
  16         DLDP            100               7
  17         LLDP            200               7
  18         Loopback        100               7
  19         DHCP Snooping   600               0
  20         Portal          400               1
  21         VRRP/VRRP3      2000              5
  22         RSVP            2000              4
  23         UDP Helper      500               3
  24         DHCPv6          400               2
  25         ICMP ping       1000              6
  26         PIM-UC          2000              4
  27         SNMP            200               1
  28         ISIS            1500              5
# 显示1号成员设备3号单板系统预定义的控制平面应用QoS策略的信息。(IRF模式)
<Sysname> display qos policy control-plane pre-defined chassis 1 slot 5
Chassis 1 slot 5
  Pre-defined Control-plane Policy Chassis 1 slot 5
  1          STP             200               7
  2          ARP-BC          600               2
  3          IGMP            2048              3
  4          GVRP            100               7
  5          MLD             500               3
  6          PIM-MC          2000              4
  7          DHCP            400               2
  8          802.3ah         100               7
  9          TTL(1)          20                3
  10         HopLimit(1)     20                3
  11         ARP-UC          600               3
  12         LACP            100               7
  13         CFD             20000             7
  14         802.1X          4096              1
  15         RRPP            300               3
  16         DLDP            100               7
  17         LLDP            200               7
  18         Loopback        100               7
  20         Portal          400               1
  21         VRRP/VRRP3      4000              5
  22         RSVP            2000              4
  23         UDP Helper      500               3
  24         DHCPv6          400               2
  25         ICMP ping       1000              6
  26         PIM-UC          2000              4
  27         SNMP            200               1
  28         ISIS            1500              5
表1-10 display qos policy control-plane pre-defined命令显示信息描述表
预定义控制平面策略内容
Index
系统预定义匹配字段索引号
Packet-type
匹配字段内容
BandWidth
带宽
Priority
优先级
undo qos apply policy [ policy-name ] { inbound | outbound }
接口视图/端口组视图/控制平面视图
【缺省级别】
2:系统级
policy policy-name:策略名。为1~31个字符的字符串。
inbound:入方向。
outbound:出方向。在控制平面视图下设备不支持此关键字。
【描述】
qos apply policy命令用来应用关联的策略。undo qos apply policy命令用来删除关联的策略。
在接口视图下执行该命令,则该配置只在当前接口生效;在端口组视图下执行该命令,则该配置将在端口组中的所有端口生效。
·     在将QoS策略应用在IRF端口所在槽位单板控制平面时,如果在此QoS策略对应的流分类包含的二层ACL中定义了匹配所有的报文的规则(即配置rule permit命令),那么请不要在对应的流行下配置流量监管(即car cir命令)或配置丢弃数据包(即filter deny命令)功能,否则可能导致IRF分裂,影响设备正常使用。
·     在接口视图/端口组视图/控制平面视图下应用QoS策略后,如果该QoS策略的名称为inbound、outbound、inbound的前几个字符或outbound的前几个字符(不区分大小写),取消应用该QoS策略时,无法通过带策略名方式取消,只能通过不带策略名方式取消。
# 将策略USER1应用到接口GigabitEthernet3/0/1的出方向上。
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] qos apply policy USER1 outbound
# 对进入3号槽控制平面的报文应用策略aaa。
[Sysname-cp-slot3] qos apply policy aaa inbound
undo qos apply policy  [ policy-name ] global { inbound | outbound }
【缺省级别】
2:系统级
policy-name:策略名,为1~31个字符的字符串。
inbound:对设备所有端口接收到的报文应用QoS策略。
outbound:对设备所有端口发送的报文应用QoS策略。
【描述】
qos apply policy global命令用来全局应用QoS策略,全局应用的QoS策略对全部流量生效。undo qos apply policy global命令用来取消全局应用的QoS策略。
·     基于全局应用的QoS策略需要下发到所有接口板,如果遇到某个接口板硬件资源不足等情况,会导致策略在该接口板下发失败。此时主控板及其它接口不回退该策略的配置,需要用户手工将该策略的相关配置清除。类似地,动态修改过程中,如果基于全局应用的QoS策略在某个接口板刷新时遇到硬件资源不足等情况,下发失败,也需要用户手工将该策略的配置清除。
·     当全局应用QoS策略后,如果该QoS策略的名称为global或global的前几个字符(不区分大小写),取消应用该QoS策略时,无法通过带策略名方式取消,只能通过不带策略名方式取消。
# 将名为user1的策略应用到全局的入方向上。
[Sysname] qos apply policy user1 global inbound
1.3.11  qos policy
qos policy policy-name
undo qos policy policy-name
【缺省级别】
2:系统级
【描述】
qos policy命令用来定义一个策略并进入策略视图。undo qos policy命令用来删除一个策略。
如果该策略已经被应用,则不允许删除该策略,需要先在应用的位置上取消对该策略的应用,然后再使用undo qos policy命令删除该策略。
相关配置可参考命令classifier behavior、qos apply policy、qos vlan-policy和qos apply policy global。
# 定义一个名为user1的策略。
undo qos vlan-policy [ policy-name ] vlan vlan-id-list { inbound | outbound }
【缺省级别】
2:系统级
policy-name:策略名称,为1~31个字符的字符串。
vlan-id-list:VLAN ID列表,形式可以是vlan-id to vlan-id,其中,vlan-id为指定VLAN的ID号,取值范围为1~4094。可以输入多个不连续的VLAN ID,中间以空格隔开。设备最多允许用户同时指定8个VLAN ID。该VLAN必须已经手工创建。
inbound:对VLAN接收到的报文应用QoS策略。
outbound:对VLAN发送的报文应用QoS策略。
【描述】
qos vlan-policy命令用来在指定VLAN上应用QoS策略。undo qos vlan-policy命令用来取消指定VLAN上应用的QoS策略。
·     基于VLAN的QoS策略需要下发到所有接口板,如果遇到某个接口板硬件资源不足等情况,会导致策略在该接口板下发失败。此时主控板及其它接口不回退该策略的配置,需要用户手工将该策略的相关配置清除。类似地,动态修改过程中,如果基于VLAN的QoS策略在某个接口板刷新时遇到硬件资源不足等情况,下发失败,也需要用户手工将该策略的配置清除。
·     在指定VLAN应用QoS策略后,如果该QoS策略的名称为VLAN或VLAN的前几个字符(不区分大小写),取消应用该QoS策略时,无法通过带策略名方式取消,只能通过不带策略名方式取消。
# 在VLAN 200、300、400、500的入方向上应用VLAN策略test。
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound
独立运行模式:
reset qos policy control-plane slot slot-number  [ inbound ]
IRF模式:
reset qos policy control-plane chassis chassis-number slot slot-number [ inbound ]
【缺省级别】
1:监控级
slot slot-number:清除指定单板的基于控制平面应用QoS策略的统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
inbound:清除进入控制平面的方向的基于控制平面应用QoS策略的统计信息。
chassis chassis-number:清除指定成员设备上指定单板的基于控制平面应用QoS策略的统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号,可使用display device查看。(IRF模式)
【描述】
reset qos policy control-plane命令用来清除控制平面应用QoS策略的统计信息。
# 清除应用到3号板进入控制平面方向的QoS策略统计信息。(独立运行模式)
<Sysname> reset qos policy control-plane slot 3 inbound
# 清除应用到1号成员设备3号板进入控制平面的QoS策略统计信息。(IRF模式)
<Sysname> reset qos policy control-plane chassis 1 slot 3
【缺省级别】
1:监控级
inbound:入方向。
outbound:出方向。
【描述】
reset qos policy global命令用来清除全局应用的QoS策略的统计信息。
# 清除全局入方向应用的QoS策略的统计信息。
<Sysname> reset qos policy global inbound
【缺省级别】
1:监控级
vlan-id:VLAN的ID号,取值范围为1~4094。
inbound:表示清除VLAN入方向策略的统计信息。
outbound:表示清除VLAN出方向策略的统计信息。
【描述】
reset qos vlan-policy命令用来清除VLAN应用QoS策略的统计信息。
# 清除VLAN 2应用的QoS策略的统计信息。
<Sysname> reset qos vlan-policy vlan 2
2 优先级映射配置命令
2.1  优先级映射表配置命令
display qos map-table [ inbound { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-lp | up-lp | up-up } | outbound { up-dp | up-fc | up-lp | up-rpr } ] [ dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-lp | up-dp | up-fc | up-lp | up-rpr | up-up ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
inbound:接收报文方向优先级映射表。
outbound:发送报文方向优先级映射表。
up-dp:用户优先级到丢弃优先级映射表。
up-fc:用户优先级到转发类映射表。
up-lp:用户优先级到本地优先级映射表。
up-rpr:用户优先级到RPR优先级映射表。
up-up:用户优先级到用户优先级映射表。
【描述】
display qos map-table命令用来显示指定优先级映射表配置情况。
如不指定表的类型,本命令将显示所有映射表的配置情况。
相关配置可参考命令qos map-table。
# 显示802.1p优先级到本地优先级映射表的配置信息。
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
# 显示802.1p优先级到丢弃优先级映射表的配置信息。
<Sysname> display qos map-table dot1p-dp
MAP-TABLE NAME: dot1p-dp   TYPE: pre-define   DIRECTION: inbound
IMPORT  :  EXPORT
   0    :    0
   1    :    0
   2    :    0
   3    :    0
   4    :    0
   5    :    0
   6    :    0
   7    :    0
表2-1 display qos map-table命令显示信息描述表
MAP-TABLE NAME
映射表的名字
TYPE
映射表的类型
DIRECTION
优先级映射表的方向
IMPORT
映射表的输入项
EXPORT
映射表的输出项
display qos map-table color [ [ green | yellow | red ] [ inbound [ dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp ] | outbound [ dot1p-dot1p | dot1p-dscp | dot1p-exp | dscp-dot1p | dscp-dscp | dscp-exp | exp-dot1p | exp-dscp | exp-exp ] ] | up-dscp ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
green:绿色报文。
yellow:黄色报文。
red:红色报文。
dot1p-dp:802.1p优先级到丢弃优先级映射表。该参数仅在inbound方向有效。
dot1p-lp:802.1p优先级到本地优先级映射表。该参数仅在inbound方向有效。
dscp-dp:DSCP到丢弃优先级映射表。该参数仅在inbound方向有效。
dscp-lp:DSCP到本地优先级映射表。该参数仅在inbound方向有效。
exp-dp:EXP到丢弃优先级映射表。该参数仅在inbound方向有效。
exp-exp:EXP到EXP映射表。
exp-lp:EXP到本地优先级映射表。该参数仅在inbound方向有效。
【描述】
display qos map-table color命令用来显示指定带颜色优先级映射表配置情况。
如不指定表的类型,本命令将显示所有带颜色映射表的配置情况。如不指定颜色,本命令将显示所有颜色的带颜色映射表的配置情况。
相关配置可参考命令qos map-table color。
目前,up相关的映射表虽然能配置,但实际上配置没有生效。
# 显示绿色报文的EXP到本地优先级映射表的配置信息。
<Sysname> display qos map-table color green exp-lp
MAP-TABLE NAME: exp-lp   TYPE: pre-define   COLOR: green   DIRECTION: inbound
IMPORT  :  EXPORT
   0    :    0
   1    :    1
   2    :    2
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
表2-2 display qos map-table color命令显示信息描述表
MAP-TABLE NAME
映射表的名字
TYPE
映射表的类型
COLOR
映射表的颜色
DIRECTION
优先级映射表的方向
IMPORT
映射表的输入项
EXPORT
映射表的输出项
2.1.3  import
优先级映射表视图
【缺省级别】
2:系统级
import-value-list:映射输入参数列表。
export-value:映射输出参数。
all:删除该映射表所有参数。
【描述】
import命令用来配置指定优先级映射表参数,定义一条或一组映射规则。undo import命令用来删除指定映射索引所对应的映射项,被删除的映射条目恢复为系统缺省值。
相关配置可参考命令display qos map-table和display qos map-table color。
# Inbound方向上,配置802.1p优先级到丢弃优先级映射表参数,与802.1p优先级4、5相对应的丢弃优先级为1。
[Sysname] qos map-table inbound dot1p-dp
[Sysname-maptbl-in-dot1p-dp] import 4 5 export 1
2.1.4  qos map-table
qos map-table { { inbound { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-lp | up-lp | up-up } } | { outbound { up-lp | up-dp | up-fc | up-rpr } } }
【缺省级别】
2:系统级
up-fc:用户优先级到转发类映射表;
up-rpr:用户优先级到RPR优先级映射表;
【描述】
相关配置可参考命令display qos map-table。
# 进入接收报文方向的802.1p优先级到丢弃优先级映射表视图。
qos map-table color { green | yellow | red } { inbound { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp } | outbound  { dot1p-dot1p | dot1p-dscp | dot1p-exp | dscp-dot1p | dscp-dscp | dscp-exp | exp-dot1p | exp-dscp | exp-exp } | up-dscp }
【缺省级别】
2:系统级
green:绿色报文。
yellow:黄色报文。
red:红色报文。
exp-exp:EXP到EXP映射表。
【描述】
qos map-table color命令用来进入指定方向的带颜色优先级映射表视图。
# 进入绿色报文(接收方向)的EXP到本地优先级映射表视图。
[Sysname] qos map-table color green inbound exp-lp
[Sysname-maptbl-green-in-exp-lp]
2.2  端口优先级配置命令
2.2.1  qos priority
qos priority { dot1p | dp | dscp | exp | lp } priority-value
undo qos priority { dot1p | dp | dscp | exp | lp }
以太网接口视图/端口组视图
【缺省级别】
2:系统级
dot1p:表示802.1p优先级,取值范围为0~7。
dp:表示丢弃优先级,取值范围为0~2,缺省值为0。
dscp:表示DSCP优先级,取值范围为0~63。
exp:表示EXP优先级,取值范围为0~7。
lp:表示本地优先级,取值范围为0~7,缺省值为2。
priority-value:优先级值。
【描述】
qos priority命令用来配置当前端口的优先级。undo qos priority命令用来恢复优先级为缺省值。
端口优先级可以通过命令display qos trust interface来查看。
# 配置以太网端口GigabitEthernet3/0/3的802.1p优先级为2。
[Sysname] interface GigabitEthernet 3/0/3
[Sysname-GigabitEthernet3/0/3] qos priority dot1p 2
2.3  端口优先级信任模式配置命令
display qos trust interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display qos trust interface命令用来显示当前配置的端口优先级信任模式信息和端口优先级的信息。
如果不指定接口,本命令将显示所有接口的端口优先级信任模式信息和端口优先级的信息。
# 显示当前配置的端口优先级信任模式信息和端口优先级的信息。
<Sysname> display qos trust interface gigabitethernet 3/0/3
Interface: GigabitEthernet3/0/3
Port priority information
  Port dot1p priority: -
  Port dp priority: 0
  Port dscp priority: -
  Port exp priority: -
  Port lp priority: 2
  Port priority trust type: untrust,  Override: disable
表2-3 display qos trust interface命令显示信息描述表
接口名,由接口类型和接口编号构成
Port priority
端口优先级
端口优先级信任类型
Override
是否覆盖报文本身的优先级
如果端口没有配置过qos priority,且端口信任模式是untrust,当执行display qos trust interface命令时,端口的本地优先级lp priority值为2,dp priority为0,其余类型优先级没有缺省值。
2.3.2  qos trust
qos trust { auto | dot1p | dscp | exp } [ override ]
undo qos trust
以太网接口视图/端口组视图
【缺省级别】
2:系统级
auto:表示根据报文的类型,自动提取报文中的优先级字段进行优先级映射。对于二层报文,采用802.1p优先级;对于三层报文,优先采用IP优先级;对于MPLS报文,优先采用EXP。
exp:信任MPLS报文自带的EXP,以此优先级进行优先级映射,本参数不支持override。
override:表示通过优先级映射表取得的优先级将覆盖报文本身的优先级。缺省为不覆盖,本参数不支持exp。
【描述】
qos trust命令用来配置端口优先级信任模式。undo qos trust命令用来恢复端口优先级信任模式为缺省情况。
缺省情况下,端口信任模式为untrust,信任端口的默认优先级。
# 在以太网端口GigabitEthernet3/0/3上配置优先级信任模式为信任报文自带的802.1p优先级。
[Sysname] interface gigabitethernet 3/0/3
[Sysname-GigabitEthernet3/0/3] qos trust dot1p
3 流量监管/流量整形
3.1  流量监管配置命令
独立运行模式:
display car resource [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
IRF模式:
display car resource [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
slot slot-number:显示指定单板的CAR资源使用信息,slot-number表示单板槽位号(独立运行模式)。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的CAR资源使用信息。chassis-number表示设备在IRF中的成员编号(IRF模式)。
【描述】
display car resource命令用来显示设备的CAR资源使用信息。
如果不指定单板槽位号,则显示设备上所有在位单板的CAR资源使用信息。
# 显示所有在位单板的CAR资源使用信息。
<Sysname> display car resource
  Slot: 3
  Resource Type   Total   Reserved  Configured  Remaining  Start      End
                  Number  Number    Number      Number     Port Name  Port Name
  INBOUND-CAR     4096    0         0           4096       GE3/0/1    GE3/0/24
  INBOUND-COUNT   4096    0         0           4096       GE3/0/1    GE3/0/24
  OUTBOUND-CAR    2048    0         0           2048       GE3/0/1    GE3/0/24
  OUTBOUND-COUNT  2048    0         0           2048       GE3/0/1    GE3/0/24
表3-1 display car resource命令显示信息描述表
Slot
单板槽位号
Resource Type
资源类型:INBOUND-CAR表示上行方向流量监管资源;OUTBOUND-CAR表示下行方向流量监管资源
Total Number
支持的指定方向的流量监管表项总数
Reserved Number
预留的指定方向的流量监管表项总数
Configured Number
已经配置的指定方向的流量监管表项总数
Remaining Number
剩余的指定方向的流量监管表项总数
Start Port Name
起始端口名称
End Port Name
结束端口名称
·     上行Counter、下行Counter二者是资源共享的。
·     系统每下发一条CAR表项,会同时占用一个CAR资源和一个Counter资源。
3.2  流量整形配置命令
display qos gts interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display qos gts interface命令用来显示某个接口或所有接口的GTS配置情况。
如不指定接口,本命令将显示所有接口的GTS配置情况。
# 显示所有接口的GTS配置情况。
 Rule(s): If-match any
表3-2 display qos gts命令显示信息描述表
Rule(s)
匹配规则
CIR
承诺信息速率,单位为kbps
CBS
3.2.2  qos gts
qos gts { any | queue queue-number } cir committed-information-rate [ cbs committed-burst-size ]
undo qos gts { any | queue queue-number }
以太网接口视图/端口组视图
【缺省级别】
2:系统级
any:对所有的数据包进行流量整形。
queue queue-number:对队列queue上的数据包进行流量整形,queue-number为匹配的队列号,取值范围0~7。
cir committed-information-rate:承诺信息速率,单位是kbps。对于GE接口,取值范围1000~1000000;对于10GE接口,取值范围2500~10000000。
cbs committed-burst-size:承诺突发尺寸,取值范围16384~16777215,单位是byte。cbs缺省取值为500毫秒以CIR速率通过的流量。
【描述】
qos gts命令用来为所有流或者队列中的数据包设置流量整形。undo qos gts命令用来取消流量整形。
缺省情况下,接口上没有配置流量整形。
# 在接口GigabitEthernet3/0/6上对所有数据包进行流量整形。
[Sysname] interface gigabitethernet 3/0/6
[Sysname-GigabitEthernet3/0/6] qos gts any cir 1200
4 硬件实现拥塞管理
4.1  严格优先级队列配置命令
display qos sp interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-type interface-number:指定的接口类型和接口编号。
【描述】
display qos sp interface命令用来显示接口的SP(Strict Priority,严格优先级)队列配置情况。
如不指定接口,本命令将显示所有已经使能SP队列接口的SP队列配置情况。
相关配置可参考命令qos sp。
# 显示GigabitEthernet4/0/7的严格优先级队列配置情况。
<Sysname> display qos sp interface GigabitEthernet4/0/7
Interface: GigabitEthernet4/0/7
Output queue: Strict-priority queue
表4-1 display qos sp interface命令显示信息描述表
Output queue
当前出队列类型
采用SP队列进行队列调度
4.1.2  qos sp
qos sp
undo qos sp
接口视图/端口组视图
【缺省级别】
2:系统级
无
【描述】
qos sp命令用来在接口上配置严格优先队列。undo qos sp命令用来恢复接口上缺省的队列算法。
缺省情况下,接口采用严格优先队列调度。
相关配置可参考命令display qos sp interface。
# 在接口GigabitEthernet4/0/7上配置严格优先队列。
[Sysname] interface GigabitEthernet 4/0/7
[Sysname-GigabitEthernet4/0/7] qos sp
4.2  加权公平队列配置命令
display qos wfq interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display qos wfq interface命令用来显示接口的WFQ(Weighted Fair Queuing,加权公平队列)队列配置情况。
如不指定接口,本命令将显示所有已经使能WFQ队列接口的WFQ队列配置情况。
相关配置可参考命令qos wfq。
# 显示接口GigabitEthernet2/0/1的WFQ队列配置情况。
<Sysname> display qos wfq interface GigabitEthernet 2/0/1
Interface: GigabitEthernet2/0/1
Output queue: Hardware weighted fair queue
Queue ID    Weight            Min-Bandwidth
   0         1                 40
   1         1                 200
   2         1                 40
   3         1                 40
   4         1                 40
   5         1                 40
   6         1                 40
   7         1                 40
表4-2 display qos wfq interface命令显示信息描述表
Output queue
当前出队列类型
Queue ID
队列号
Weight
调度时各个队列的权重
Min-Bandwidth
队列的最小保证带宽值,单位是kbps
undo qos bandwidth queue queue-id [ min bandwidth-value ]
【缺省级别】
2:系统级
queue-id:指定的队列,取值范围0~7。
min bandwidth-value:端口流量拥塞时能够保证的最小队列带宽值。
·     在千兆以太网接口上(即GE接口),取值范围为40~1000000kbps;
·     在万兆以太网接口上(即10GE接口),取值范围为40~2500000kbps;
【描述】
qos bandwidth queue命令用来配置端口队列的最小带宽保证。undo qos bandwidth queue命令用来将端口队列的最小带宽保证值恢复为缺省情况。
缺省情况下,队列的最小带宽保证值为40kbps。
# 在GigabitEthernet2/0/1上配置队列1的最小保证带宽值为100kbps。
[Sysname] interface GigabitEthernet 2/0/1
[Sysname-GigabitEthernet2/0/1] qos wfq
[Sysname-GigabitEthernet2/0/1] qos bandwidth queue 1 min 100
4.2.3  qos wfq
qos wfq
undo qos wfq
接口视图/端口组视图
【缺省级别】
2:系统级
无
【描述】
qos wfq命令用来在接口上使能WFQ队列。undo qos wfq命令用来恢复接口上缺省的队列算法。
缺省情况下,接口采用严格优先队列调度。
需要注意的是,如果用户使能了WFQ队列,那么当前接口的所有队列调度模式将改变为WFQ,调度权重缺省值为1,最小保证带宽缺省值为40kbps。
# 在GigabitEthernet2/0/1上使能WFQ队列。
qos wfq queue-id weight schedule-value
undo qos wfq queue-id weight
【缺省级别】
2:系统级
weight schedule-value:配置队列的调度权重。schedule-value的取值范围为1~63。
【描述】
qos wfq weight命令用来在接口上配置硬件WFQ队列的队列调度权重值。undo qos wfq weight命令用来将队列调度权重值恢复为缺省情况。
缺省情况下,调度权重值为1。
相关配置可参考命令display qos wfq interface。
# 在GigabitEthernet2/0/1上配置队列3和队列4的调度权重分别为20、30。
[Sysname-GigabitEthernet2/0/1] qos wfq 3 weight 20
[Sysname-GigabitEthernet2/0/1] qos wfq 4 weight 30
4.3  队列调度策略配置命令
display qos qmprofile configuration [ profile-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
profile-name:队列调度策略名称,为1~31个字符的字符串,区分大小写。
【描述】
display qos qmprofile configuration命令用来显示队列调度策略的配置情况。
如果不指定队列调度策略的名称,将显示所有队列调度策略的配置情况。
# 显示队列调度策略myprofile的配置情况。
<Sysname> display qos qmprofile configuration myprofile
Queue management profile: myprofile
 Queue ID    Type    Group    Weight
 0           SP      N/A      N/A
 1           SP      N/A      N/A
 2           SP      N/A      N/A
 3           SP      N/A      N/A
 4           SP      N/A      N/A
 5           SP      N/A      N/A
 6           WRR     1        200
 7           SP      N/A      N/A
表4-3 display qos qmprofile configuration命令显示信息描述表
队列调度策略名称
Queue ID
队列号
队列调度类型,包括SP(严格优先级)、WRR(加权轮询调度)
Group
WRR优先组,N/A表示无效
Weight
调度权重,N/A表示无效
display qos qmprofile interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display qos qmprofile interface命令用来显示接口的队列调度策略的配置情况。
如果不指定接口,将显示所有接口的队列调度策略的配置情况。
# 显示指定接口的队列调度策略的配置情况。
<Sysname> display qos qmprofile interface gigabitethernet 3/0/1
表4-4 display qos qmprofile interface命令显示信息描述表
接口名称
队列调度策略名称
undo qos apply qmprofile
以太网接口视图/端口组视图
【缺省级别】
2:系统级
【描述】
qos apply qmprofile命令用来在接口上应用队列调度策略。undo qos apply qmprofile命令用来恢复接口缺省的队列调度策略。
缺省情况下,各队列使用严格优先级调度策略。
每个接口只能应用一个队列调度策略。
# 在GigabitEthernet3/0/1接口上应用队列调度策略myprofile。
[Sysname] interface gigabitethernet 3/0/1
[Sysname-GigabitEthernet3/0/1] qos apply qmprofile myprofile
4.3.4  qos qmprofile
qos qmprofile profile-name
undo qos qmprofile profile-name
【缺省级别】
2:系统级
【描述】
qos qmprofile命令用来创建用户自定义的队列调度策略,并进入队列调度策略视图。undo qos qmprofile命令用来删除用户自定义的队列调度策略。
需要注意的是,不能删除已经应用到接口的队列调度策略,必须先在应用的接口上取消对该队列调度策略的应用,然后再删除该队列调度策略。
# 创建自定义的队列调度策略myprofile,并进入队列调度策略视图。
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile]
4.3.5  queue
queue queue-id { sp | wrr group group-id weight weight-value }
undo queue queue-id
队列调度策略视图
【缺省级别】
2:系统级
queue-id:队列号,取值范围0~7。
sp:配置队列为严格优先级调度。
wrr:配置队列为加权轮询调度。
group-id:WRR优先组号,取值范围1~2。
weight-value:调度权重,取值范围1~250。
【描述】
queue命令用来配置指定队列的调度策略。undo queue命令用来删除指定队列的调度策略。
需要注意的是:每个WRR组内的队列号应该连续,否则可能出现调度不准确。
# 创建自定义的队列调度策略myprofile,并配置队列0为严格优先级调度。
[Sysname-qmprofile-myprofile] queue 0 sp
# 创建自定义的队列调度策略myprofile,并配置队列1为加权轮询调度,权重为100,分组为1。
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 weight 100
5 拥塞避免配置命令
5.1  WRED配置命令
display qos wred interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display qos wred interface命令用来显示指定接口上的WRED配置信息。
如果不指定接口,本命令将显示所有接口上的WRED配置信息。
# 显示所有接口的WRED配置信息。
<Sysname> display qos wred interface
Interface: GigabitEthernet3/0/6
 Current WRED configuration:
 WRED: Enable
表5-1 display qos wred interface命令显示信息描述表
当前WRED的配置信息
qos wred enable
undo qos wred enable
以太网接口视图/端口组视图
【缺省级别】
2:系统级
无
【描述】
qos wred enable命令用来在接口上使能WRED。undo qos wred enable命令用来恢复缺省的队列丢弃方法。
缺省情况下,队列丢弃方法为尾丢弃。
# 在GigabitEthernet3/0/6接口上使能WRED。
[Sysname] interface GigabitEthernet 3/0/6
[Sysname-GigabitEthernet3/0/6] qos wred enable
6 全局CAR
6.1  全局CAR配置命令
6.1.1  car name
car name car-name
undo car
流行为视图
【缺省级别】
2:系统级
car-name:聚合CAR的名称。该聚合CAR必须已经存在。
【描述】
car name命令用来配置流行为的聚合CAR动作。undo car用来删除流行为的流量监管动作。
# 配置流行为be1的聚合CAR动作为aggcar-1。
display qos car name [ car-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
car-name:聚合CAR的名称。
【描述】
display qos car name命令用来显示聚合CAR的CAR配置和统计信息。
·     如果输入car-name参数,将显示指定聚合CAR的CAR配置和统计信息。
·     如果不输入car-name参数,将显示所有聚合CAR的CAR配置和统计信息。
# 显示所有聚合CAR的配置信息。
<Sysname> display qos car name
  Mode: aggregative
  CIR 100(kbps)  CBS: 2000(byte)  EBS: 0(byte)
  Red Action: discard
  Green packet 0(Bytes), 0(Pkts)
  Yellow packet 0(Bytes), 0(Pkts)
  Red packet 0(Bytes), 0(Pkts)
表6-1 display qos car name命令显示信息描述表
Name
聚合CAR的名称
Mode
流量监管的类型
CIR  CBS  EBS
流量监管流量的参数配置
Red Action
对红色报文的动作
Green packet
绿色报文的流量统计
Yellow packet
黄色报文的流量统计
Red packet
红色报文的流量统计
目前,设备只支持按照字节数(Bytes)来统计,不支持按照报文数(Pkts)来统计,即Pkts计数都为0。
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ pir peek-information-rate ] [ red action ]
undo qos car car-name
【缺省级别】
2:系统级
car-name:聚合CAR的名称。
aggregative:标明该全局CAR为聚合模式,目前只支持聚合CAR。
cir committed-information-rate:承诺信息速率,取值范围为1~20000000,单位为kbps。
cbs committed-burst-size:承诺突发尺寸,即实际平均速率在承诺速率以内时的突发流量,取值范围为1553~2147450880,单位为byte。缺省值为500ms内承诺信息速率的流量,若该数值小于1553,则缺省值为1553。设置的突发尺寸同时必须大于最大报文长度。
ebs excess-burst-size:过度突发尺寸,取值范围为0~2147450880,单位为byte。
pir peak-information-rate:峰值速率,取值范围为1~20000000,单位为kbps。不配置峰值速率表示所配置的是单速桶流量监管,否则表示双速桶流量监管。
red action:对红色报文采取的动作。红色报文为流量不符合承诺速率的报文。action的取值有以下几种:
·     discard:丢弃数据包。
·     pass:允许数据包通过。
【描述】
qos car aggregative命令用来配置聚合CAR。undo qos car命令用来取消聚合CAR的配置。
聚合CAR配置需要在策略中引用后才能生效。
# 配置聚合CAR采取的CAR参数取值,cir取值为200,cbs取值为2000,对于红色报文采取丢弃的动作。
[Sysname] qos car aggcar-1 aggregative cir 200 cbs 2000 red discard
【缺省级别】
2:系统级
car-name:聚合CAR的名称。
【描述】
reset qos car name命令用来清除聚合CAR的统计信息。
·     如果输入car-name参数,将清除指定聚合CAR的统计信息。
·     如果不输入car-name参数,将清除所有聚合CAR的统计信息。
# 清除聚合CAR aggcar-1的配置信息。
<Sysname> reset qos car name aggcar-1
7 报文统计
7.1  报文统计配置命令
独立运行模式:
display qos traffic-counter { inbound | outbound } { counter0 | counter1 } slot slot-number [ | { begin | exclude | include } regular-expression ]
IRF模式:
display qos traffic-counter { inbound | outbound } { counter0 | counter1 } chassis chassis-number slot slot-number [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
inbound:入方向的报文统计计数器。
outbound:出方向的报文统计计数器。
counter0:计数器0。
counter1:计数器1。
slot-number:显示指定单板计数器统计的流量信息,slot-number表示单板槽位号(独立运行模式)。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板计数器统计的流量信息。chassis-number表示设备在IRF中的成员编号(IRF模式)。
【描述】
display qos tranffic-counter命令用来显示计数器统计的流量信息,同时显示该组计数器的配置信息。
# 显示4号槽位单板出方向上的报文统计信息。
<Sysname> display qos traffic-counter outbound counter0 slot 4
Slot 4 outbound counter0 mode:
 Interface: all
 VLAN: all
Traffic-counter summary:
 Unicast: 0 packets
 Multicast: 0 packets
 Broadcast: 0 packets
 Control packets: 2 packets
 Bridge egress filtered packets: 0 packets
 Tail drop packets: 0 packets
 Multicast Tail drop packets: 6 packets
 Forward restrictions packets: 0 packets
表7-1 display qos traffic-counter outbound命令显示信息描述表
4槽位单板上计数器0统计出方向流量的监控对象
本计数器所统计的接口
VLAN
本计数器所统计的VLAN
Local precedence
本计数器所统计的本地优先级
Drop priority
本计数器所统计的丢弃优先级
本计数器统计信息汇总
Unicast
单播报文数
Multicast
多播报文数
Broadcast
广播报文数
Control packets
控制报文和镜像报文统计
出方向桥(二层)过滤报文统计(包括VLAN过滤和STP Block报文)
Tail drop packets
单播报文拥塞尾丢弃统计
组播、广播报文拥塞尾丢弃统计
转发的限制报文数(目前,该项暂不支持)
# 显示1号槽位单板入方向上的报文统计信息。
<Sysname> display qos traffic-counter inbound counter0 slot 1
Slot 1 inbound counter0 mode:
 Interface: all
 VLAN: all
 Bridge in frames: 5490000 packets
 Bridge local discarded: 0 packets
 Bridge vlan ingress filter discarded: 0 packets
 Bridge security filter discarded: 0 packets
表7-2 display qos traffic-counter inbound命令显示信息描述表
1槽位单板上计数器0统计入方向流量的监控对象
本计数器所统计的接口
VLAN
本计数器所统计的VLAN
本计数器统计信息汇总
Bridge in frames
桥(二层)接收到的报文个数
桥(二层)丢弃报文个数(除了桥安全过滤和VLAN入方向过滤外的其他原因丢弃的报文数)
VLAN入方向过滤报文数
桥(二层)安全过滤报文数
独立运行模式:
qos traffic-counter { inbound | outbound } { counter0 | counter1 } slot slot-number [ interface interface-type interface-number | vlan vlan-id | drop-priority dp-value ] *
undo qos traffic-counter { inbound | outbound } { counter0 | counter1 } slot slot-number
IRF模式:
qos traffic-counter { inbound | outbound } { counter0 | counter1 } chassis chassis-number slot slot-number [ interface interface-type interface-number | vlan vlan-id | drop-priority dp-value ] *
undo qos traffic-counter { inbound | outbound } { counter0 | counter1 } chassis chassis-number slot slot-number
【缺省级别】
2:系统级
counter0:计数器0。
counter1:计数器1。
slot-number:单板槽位号(独立运行模式)。
chassis chassis-number:表示设备在IRF中的成员编号(IRF模式)。
interface-type interface-number:指定绑定的接口类型和接口编号。
vlan-id:VLAN的编号,取值范围为1~4094。
drop-priority:丢弃优先级,取值范围为0~2。
【描述】
qos traffic-counter命令用来使能报文统计功能。undo qos traffic-counter命令用来关闭报文统计功能。
缺省情况下,报文统计功能处于关闭状态。
一块单板提供两个计数器用于统计单板流量,监控的对象可以是指定端口、VLAN、本地优先级和丢弃优先级的报文。
·     当不指定端口时,则监控单板上所有端口的流量。
·     当不指定VLAN时,则监控单板上所有VLAN的流量。
·     当不指定丢弃优先级时,则监控单板上所有丢弃优先级的流量。
·     drop-priority只支持outbound方向上的应用。
·     使用qos traffic-counter命令重新设置某单板的监控对象后,计数器的值会自动清零。
# 使能4号槽位的计数器0的报文统计功能,统计GigabitEthernet4/0/1端口的出方向流量。
[Sysname] qos traffic-counter outbound counter0 slot 4 interface gigabitethernet 4/0/1
独立运行模式:
reset qos traffic-counter { inbound | outbound } { counter0 | counter1 } slot slot-number
IRF模式:
reset qos traffic-counter { inbound | outbound } { counter0 | counter1 } chassis chassis-number slot slot-number
【缺省级别】
2:系统级
counter0:计数器0。
counter1:计数器1。
【描述】
reset qos traffic-counter命令用来清除报文统计计数器的统计值。
# 清除4号槽位的出方向报文统计计数器的统计值。
<Sysname> reset qos traffic-counter outbound counter0 slot 4
8 QoS调度精度增强模式配置命令
8.1.1  enhanced-qos
enhanced-qos enable
undo enhanced-qos enable
【缺省级别】
2:系统级
无
【描述】
enhanced-qos enable命令用来设置QoS的调度精度增强模式。undo enhanced-qos enable 命令用来取消QoS调度精度增强模式。
缺省情况下,系统处于QoS调度精度增强模式。
在对转发时延性能要求较高的场景下,可取消系统的QoS调度精度增强模式,使得系统获得更高的转发时延性能。
# 取消系统的QoS调度精度增强模式。
[Sysname] undo enhanced-qos enable
9 QoS管道模式配置命令
9.1.1  qos pipe-mode
qos pipe-mode
undo qos pipe-mode
【缺省级别】
2:系统级
无
【描述】
qos pipe-mode命令用来配置QoS管道模式。undo qos pipe-mode命令用来取消QoS管道模式。
缺省情况下,设备未配置QoS管道模式。
配置QoS管道模式后,可以确保报文在经过以下任意一种网络后:
·     在MAC-in-MAC网络;
·     在MPLS L2VPN网络;
·     在MPLS L3VPN网络;
·     在VPLS网络;
所携带的DSCP优先级字段不会被改变,从而不影响下游设备对该IP报文的转发调度。关于此功能的详细介绍请参见配置指导中的“QoS”。
# 配置QoS管道模式。
[Sysname] qos pipe-mode
