01-IP路由基础命令
本章节下载: 01-IP路由基础命令 (478.26 KB)
1.1.3 display ip routing-table
1.1.4 display ip routing-table acl
1.1.5 display ip routing-table ip-address
1.1.6 display ip routing-table prefix-list
1.1.7 display ip routing-table protocol
1.1.8 display ip routing-table statistics
1.1.9 display ip routing-table summary
1.1.10 display ipv6 rib attribute
1.1.11 display ipv6 rib graceful-restart
1.1.13 display ipv6 route-direct nib
1.1.14 display ipv6 routing-table
1.1.15 display ipv6 routing-table acl
1.1.16 display ipv6 routing-table ipv6-address
1.1.17 display ipv6 routing-table prefix-list
1.1.18 display ipv6 routing-table protocol
1.1.19 display ipv6 routing-table statistics
1.1.20 display ipv6 routing-table summary
1.1.23 display rib graceful-restart
1.1.25 display route-direct nib
1.1.28 inter-protocol fast-reroute
1.1.29 maintenance-probe enable
1.1.30 nexthop recursive-lookup restrain clear-interval
1.1.31 nexthop recursive-lookup restrain disable
1.1.33 primary-path-detect bfd
1.1.35 protocol nexthop recursive-lookup
1.1.36 reset ip routing-table statistics protocol
1.1.37 reset ipv6 routing-table statistics protocol
address-family ipv4命令用来创建RIB IPv4地址族,并进入RIB IPv4地址族视图。
undo address-family ipv4命令用来删除RIB IPv4地址族和RIB IPv4地址族视图下的所有配置。
address-family ipv4
不存在RIB IPv4地址族。
RIB视图
# 创建RIB IPv4地址族,并进入RIB IPv4地址族视图。
[Sysname] rib
[Sysname-rib] address-family ipv4
[Sysname-rib-ipv4]
address-family ipv6命令用来创建RIB IPv6地址族,并进入RIB IPv6地址族视图。
undo address-family命令用来删除RIB IPv6地址族和RIB IPv6地址族视图下的所有配置。
address-family ipv6
undo address-family ipv6
不存在RIB IPv6地址族。
RIB视图
# 创建RIB IPv6地址族,并进入RIB IPv6地址族视图。
[Sysname] rib
[Sysname-rib] address-family ipv6
[Sysname-rib-ipv6]
display ip routing-table命令用来显示路由表的信息。
display ip routing-table [ verbose ]
display ip routing-table [ all-vpn-instance | vpn-instance vpn-instance-name ] [ verbose ]
display ip routing-table [ all-routes ]
all-vpn-instance:显示所有VPN实例的路由表信息。
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
all-routes:显示公网和所有VPN实例的路由表信息。
verbose:显示全部路由表的详细信息,包括激活路由和未激活路由。如果未指定本参数,将显示激活路由的概要信息。
如果不指定任何参数,将显示公网的信息。
<Sysname> display ip routing-table
Destinations : 8 Routes : 8
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
1.1.1.0/24 Static 60 0 192.168.47.4 GE2/0/0
192.168.47.4 GE2/0/1
1.1.2.0/24 UNR 65 0 0.0.0.0 NULL0
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
192.168.1.40/32 Direct 0 0 127.0.0.1 InLoop0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
# 显示公网和所有VPN实例中当前激活路由的概要信息。
<Sysname> display ip routing-table all-routes
VPN instance: public instance
VPN instance: vpn1
1.1.2.0/24 Static 60 0 2.2.1.1 GE2/0/0
2.2.1.1 GE2/0/2
3.3.1.0/24 BGP 255 0 55.1.1.2 GE2/0/1
# 显示所有VPN实例下的IPv4路由信息。
<Sysname> display ip routing-table all-vpn-instance
VPN instance: vpn1
2.2.1.1 GE2/0/2
1.1.3.0/24 UNR 65 0 0.0.0.0 NULL0
VPN instance: vpn2
Destinations : 7 Routes : 7
1.1.3.0/24 Static 60 0 3.3.1.1 GE2/0/0
表1-1 display ip routing-table命令显示信息描述表
VPN instance |
路由表所属的公网或VPN实例信息,公网路由显示为public instance,私网路由显示为VPN实例名称 |
Destinations |
目的地址个数 |
Routes |
路由条数 |
Destination/Mask |
目的地址/掩码长度 |
Proto |
路由种类或发现该路由的路由协议类型: · Direct:直连路由 · Static:静态路由 · UNR:用户网络路由 · RIP:RIP协议(暂不支持) · O_INTRA:OSPF区域内路由 · O_ASE2:OSPF第二类外部路由 · IS_L1:Level-1的IS-IS IPv4路由 · IS_L2:Level-2的IS-IS IPv4路由 · BGP:BGP协议 · EIGRP:EIGRP协议(暂不支持) · LISP:LISP协议(暂不支持) |
Pre |
路由的优先级 |
Cost |
路由的度量值 |
NextHop |
此路由的下一跳地址 |
出接口,即到该目的网段的数据包将从此接口发出 |
Summary count |
路由数目 |
# 显示路由表的全部详细信息。
<Sysname> display ip routing-table verbose
Destinations : 2 Routes : 2
Destination: 0.0.0.0/32
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 08h34m37s
Cost: 0 Preference: 0
IpPre: N/A QosLocalID: N/A
Tag: 0 State: Active NoAdv
TableID: 0x2 OrigAs: 0
NibID: 0x10000000 LastAs: 0
AttrID: 0xffffffff Neighbor: 0.0.0.0
Flags: 0x1000c OrigNextHop: 127.0.0.1
Label: NULL RealNextHop: 127.0.0.1
BkLabel: NULL BkNextHop: N/A
SRLabel: NULL Interface: InLoopBack0
BkSRLabel: NULL BkInterface: N/A
Tunnel ID: Invalid IPInterface: InLoopBack0
BkTunnel ID: Invalid BkIPInterface: N/A
InLabel: NULL ColorInterface: N/A
SIDIndex: NULL BkColorInterface: N/A
FtnIndex: 0x0 TunnelInterface: N/A
TrafficIndex: N/A BkTunnelInterface: N/A
Connector: N/A PathID: 0x0
UserID: 0x0 SRTunnelID: Invalid
SID Type: N/A NID: Invalid
FlushNID: Invalid BkNID: Invalid
BkFlushNID: Invalid
Destination: 1.1.1.0/24
Protocol: Static
Process ID: 0
SubProtID: 0x0 Age: 04h20m37s
Cost: 0 Preference: 60
Tag: 0 State: Active Adv
NibID: 0x10000003 LastAs: 0
Flags: 0x1008c OrigNextHop: 192.168.47.4
Label: NULL RealNextHop: 192.168.47.4
SRLabel: NULL Interface: GigabitEthernet2/0/0
Tunnel ID: Invalid IPInterface: GigabitEthernet2/0/0
BkFlushNID: Invalid
Protocol: Static
Process ID: 0
Tag: 0 State: Active Adv Derived
Label: NULL RealNextHop: 125.2.1.1
SRLabel: NULL Interface: GigabitEthernet2/0/1
Tunnel ID: Invalid IPInterface: GigabitEthernet2/0/1
BkFlushNID: Invalid
Destination: 22.22.22.0/24
Protocol: UNR
Process ID: 0
SubProtID: 0x1 Age: 00h00m21s
Cost: 0 Preference: 65
NibID: 0x11000000 LastAs: 0
Flags: 0x10000 OrigNextHop: 0.0.0.0
Label: NULL RealNextHop: 0.0.0.0
SRLabel: NULL Interface: NULL0
Tunnel ID: Invalid IPInterface: NULL0
BkFlushNID: Invalid
# 显示所有VPN实例内所有路由的详细信息。
<Sysname> display ip routing-table all-vpn-instance verbose
VPN instance: vpn1
Destinations : 1 Routes : 1
Protocol: Direct
Process ID: 0
OrigTblID: 0x0 OrigVrf: vpn1
BkFlushNID: Invalid
VPN instance: vpn2
Protocol: Static
Process ID: 0
OrigTblID: 0x0 OrigVrf: vpn2
BkFlushNID: Invalid
VPN instance: vpn3
Protocol: UNR
Process ID: 0
BkFlushNID: Invalid
表1-2 display ip routing-table verbose命令显示信息描述表
VPN instance |
Destinations |
目的地址个数 |
Routes |
路由条数 |
Destination |
目的地址/掩码 |
Protocol |
发现该路由的路由协议类型 |
Process ID |
进程号 |
SubProtID |
路由子协议ID |
Age |
此路由在路由表中存在的时间 |
Cost |
路由的度量值 |
Preference |
路由的优先级 |
IpPre |
IP优先级值 |
QosLocalID |
QoS本地ID |
Tag |
路由标记 |
State |
路由状态描述: · Active:有效的单播路由 · Adv:允许对外发送的路由 · Inactive:非激活路由标志 · NoAdv:不允许发布的路由 · Vrrp:VRRP产生的路由 · Nat:NAT产生的路由(暂不支持) · TunE:Tunnel隧道的标志 · Derived:派生路由。路由迭代的出接口不唯一时,第一条迭代路由外的其他迭代路由为派生路由。携带此标记的路由不计入路由条数 · Backup:备份路由的标志 |
OrigTblID |
原始路由表ID |
OrigVrf |
路由所属的原始VPN,显示为default-vrf表示公网 |
TableID |
路由所在路由表的ID |
OrigAs |
初始AS号 |
NibID |
下一跳ID |
LastAs |
最后AS号 |
AttrID |
路由属性ID号 |
Neighbor |
路由协议的邻居地址 |
Flags |
路由标志位 |
OrigNextHop |
此路由的下一跳地址 |
Label |
标签 |
RealNextHop |
路由真实下一跳 |
BkLabel |
备份标签 |
BkNexthop |
备份下一跳地址 |
SRLabel |
SR(Segment Routing)标签 |
BkSRLabel |
SR(Segment Routing)备份标签 |
BkInterface |
备份出接口 |
Tunnel ID |
隧道ID |
IPInterface |
IP出接口 |
BkTunnel ID |
备份隧道ID |
BkIPInterface |
备份IP出接口 |
InLabel |
路由入标签 |
ColorInterface |
(暂不支持)Color出接口,即通过SR Policy迭代的出接口 |
SIDIndex |
SID的相对值 |
BkColorInterface |
备份Color出接口 |
FtnIndex |
FTN表项索引 |
TunnelInterface |
Tunnel出接口 |
TrafficIndex |
流量统计索引值,取值范围为1~64,N/A表示无效值 |
BkTunnelInterface |
备份Tunnel出接口 |
Connector |
表示BGP为MD VPN特性所携带的Connector属性,具体取值为BGP对等体在交换VPN-IPv4路由时携带源PE的地址,N/A表示没有该属性 |
Summary count |
路由数目 |
PathID |
路径ID |
UserID |
接入用户ID |
SRTunnelID |
(暂不支持)SR隧道ID |
SID Type |
(暂不支持)SID类型,N/A表示没有该属性 |
NID |
路由协议下刷的NHLFE(Next Hop Label Forwarding Entry,下一跳标签转发项)表项索引 |
FlushNID |
实际向FIB下刷的NHLFE表项索引 |
BkNID |
路由协议下刷的备份NHLFE表项索引 |
BkFlushNID |
实际向FIB下刷的备份NHLFE表项索引 |
display ip routing-table acl命令用来显示通过指定ACL过滤的路由信息。
display ip routing-table acl ipv4-acl-number [ verbose ]
display ip routing-table [ vpn-instance vpn-instance-name ] acl ipv4-acl-number [ verbose ]
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网的信息。
ipv4-acl-number:基本ACL的编号,取值范围为2000~2999。
verbose:显示通过指定ACL过滤的所有路由的详细信息。如果未指定本参数,将只显示通过指定ACL过滤的激活路由的概要信息。
如果用户指定的ACL不存在或者ACL中没有任何规则,将显示所有的路由信息。
# 配置ACL 2000,并设置路由过滤规则。
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 192.168.1.0 0.0.0.255
[Sysname-acl-ipv4-basic-2000] rule deny source any
# 显示通过ACL 2000过滤的激活路由的概要信息。
[Sysname-acl-ipv4-basic-2000] display ip routing-table acl 2000
Summary count : 4
192.168.1.0/24 Direct 0 0 192.168.1.111 GE2/0/0
192.168.1.0/32 Direct 0 0 192.168.1.111 GE2/0/0
192.168.1.111/32 Direct 0 0 127.0.0.1 InLoop0
192.168.1.255/32 Direct 0 0 192.168.1.111 GE2/0/0
以上显示信息解释请参见表1-1。
# 显示通过ACL 2000过滤的所有路由的详细信息。
<Sysname> display ip routing-table acl 2000 verbose
Summary count : 4
Destination: 192.168.1.0/24
Protocol: Direct
Process ID: 0
SubProtID: 0x1 Age: 04h20m37s
Flags: 0x10080 OrigNextHop: 192.168.1.111
Label: NULL RealNextHop: 192.168.1.111
BkFlushNID: Invalid
Destination: 192.168.1.0/32
Protocol: Direct
Process ID: 0
Flags: 0x1008c OrigNextHop: 192.168.1.111
BkFlushNID: Invalid
Destination: 192.168.1.111/32
Protocol: Direct
Process ID: 0
Flags: 0x10004 OrigNextHop: 127.0.0.1
BkFlushNID: Invalid
Destination: 192.168.1.255/32
Protocol: Direct
Process ID: 0
BkFlushNID: Invalid
以上显示信息解释请参见表1-2。
display ip routing-table ip-address命令用来显示指定目的地址的路由信息。
display ip routing-table ip-address1 to ip-address2命令用来显示指定目的地址范围内的路由信息。
display ip routing-table ip-address [ mask-length | mask ] [ longer-match ] [ verbose ]
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address [ mask-length | mask ] [ longer-match ] [ verbose ]
display ip routing-table ip-address1 to ip-address2 [ verbose ]
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address1 to ip-address2 [ verbose ]
ip-address:目的IP地址,点分十进制格式。
mask-length:网络掩码长度,取值范围为0~32。
mask:网络掩码,点分十进制格式。
longer-match:显示与指定目的网络匹配的所有路由信息。关于匹配条件的详细说明,请查看使用指导。
ip-address1 to ip-address2:IP地址范围。ip-address1和ip-address2共同决定一个地址范围,只有地址在此范围内的路由才会被显示。
使用不同的可选参数,命令的输出也不相同,以下是对该命令不同形式的输出说明:
· display ip routing-table ip-address
显示满足如下条件的所有激活路由:
¡ 用户输入的目的IP地址同路由表中各条路由的子网掩码值进行与运算;
¡ 路由表中各条路由的目的IP地址同其自身子网掩码值进行与运算;
¡ 两次运算结果相同的路由条目将被显示出来。
· display ip routing-table ip-address mask
显示满足如下条件的所有激活路由:
¡ 用户输入的目的IP地址同用户输入的子网掩码值进行与运算;
¡ 路由表中各条路由的目的IP地址同用户输入的子网掩码值进行与运算;
¡ 两次运算结果相同,并且掩码小于等于用户输入的子网掩码的路由条目将被显示出来。
· display ip routing-table ip-address longer-match
显示满足如下条件的所有激活路由:
¡ 用户输入的目的IP地址同子网掩码值进行与运算,有以下三种情况:
- 用户输入的目的IP地址得出其所对应的自然网段,取该自然网段对应的子网掩码默认值(A、B、C类IP地址对应的子网掩码默认值分别为255.0.0.0、255.255.0.0和255.255.255.0),再将用户输入的目的IP地址与对应的子网掩码默认值进行与运算。
- 如果用户输入的目的IP地址是0.0.0.0,将使用掩码0.0.0.0与其进行与运算。
- 除上述两种情况外(如组播地址、环回地址),将使用掩码255.255.255.255与用户输入的目的IP地址进行与运算。
¡ 路由表中各条路由的目的IP地址同上一步得到的子网掩码值进行与运算;
¡ 两次运算结果相同的所有路由条目将被显示出来。
· display ip routing-table ip-address mask longer-match
显示满足如下条件的所有激活路由:
· display ip routing-table ip-address1 to ip-address2
显示ip-address1/32到ip-address2/32之间的激活路由,目的地址与掩码(32位)同时在指定范围内才会显示。
# 显示目的地址为11.0.0.1的路由信息。
<Sysname> display ip routing-table 11.0.0.1
Summary count : 3
11.0.0.0/8 Static 60 0 0.0.0.0 NULL0
11.0.0.0/16 Static 60 0 0.0.0.0 NULL0
11.0.0.0/24 Static 60 0 0.0.0.0 NULL0
# 显示目的地址/掩码为11.0.0.1/20的路由信息。
<Sysname> display ip routing-table 11.0.0.1 20
Summary count : 2
# 显示目的地址为11.0.0.1并且满足匹配条件的路由信息。
<Sysname> display ip routing-table 11.0.0.1 longer-match
Summary count : 3
# 显示目的地址/掩码为11.0.0.1/20并且满足匹配条件的路由信息。
<Sysname> display ip routing-table 11.0.0.1 20 longer-match
Summary count : 3
# 显示目的地址从1.1.1.0到5.5.5.0范围内的路由信息。
<Sysname> display ip routing-table 1.1.1.0 to 5.5.5.0
Summary count : 5
1.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
3.3.3.0/24 Direct 0 0 3.3.3.1 GE2/0/1
3.3.3.1/32 Direct 0 0 127.0.0.1 InLoop0
4.4.4.0/24 Direct 0 0 4.4.4.1 GE2/0/0
4.4.4.1/32 Direct 0 0 127.0.0.1 InLoop0
以上显示信息的解释请参见表1-1。
# 显示目的地址为1.2.3.4的路由的详细信息。
<Sysname> display ip routing-table 1.2.3.4 verbose
Summary count : 1
Destination: 1.2.3.4/32
Protocol: BGP instance test
Process ID: 0
SubProtID: 0x1 Age: 00h00m37s
Cost: 0 Preference: 255
TableID: 0x2 OrigAs: 200
NibID: 0x15000000 LastAs: 200
AttrID: 0x0 Neighbor: 192.168.47.2
Flags: 0x10060 OrigNextHop: 192.168.47.2
Label: NULL RealNextHop: 192.168.47.2
BkFlushNID: Invalid
以上显示信息的解释请参见表1-2。
display ip routing-table prefix-list命令用来显示通过指定前缀列表过滤的路由信息。
display ip routing-table prefix-list prefix-list-name [ verbose ]
display ip routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ]
prefix-list-name:前缀列表名称,为1~63个字符的字符串,区分大小写。
verbose:当使用该参数时,显示通过过滤规则的所有路由的详细信息。如果未指定本参数,将只显示通过过滤规则的激活路由的概要信息。
如果指定的前缀列表不存在,将显示所有的路由信息。
# 配置地址前缀列表test允许前缀为1.1.1.0,掩码长度为24的路由通过。
[Sysname] ip prefix-list test permit 1.1.1.0 24
# 显示通过前缀列表test过滤的激活路由的概要信息。
[Sysname] display ip routing-table prefix-list test
Summary count : 1
1.1.1.0/24 Direct 0 0 1.1.1.2 GE2/0/1
以上显示信息的解释请参见表1-1。
# 显示通过前缀列表test过滤的所有路由的详细信息。
[Sysname] display ip routing-table prefix-list test verbose
Summary count : 1
Protocol: Direct
Process ID: 0
Flags: 0x1008c OrigNextHop: 1.1.1.2
Label: NULL RealNextHop: 1.1.1.2
BkFlushNID: Invalid
以上显示信息的解释请参见表1-2。
display ip routing-table protocol命令用来显示指定协议生成或发现的路由信息。
display ip routing-table protocol protocol [ inactive | verbose ]
display ip routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ]
protocol:显示指定路由协议的信息。
inactive:显示未激活路由的信息。如果未指定本参数,则显示激活路由和未激活路由的信息。
verbose:当使用该参数时,显示路由的详细信息。如果未指定本参数,将显示路由的概要信息。
# 显示所有直连路由的概要信息。
<Sysname> display ip routing-table protocol direct
Summary count : 9
Direct Routing table status : <Active>
Summary count : 9
192.168.80.0/24 Direct 0 0 192.168.80.10 GE2/0/0
192.168.80.0/32 Direct 0 0 192.168.80.10 GE2/0/0
192.168.80.10/32 Direct 0 0 127.0.0.1 InLoop0
192.168.80.255/32 Direct 0 0 192.168.80.10 GE2/0/0
Direct Routing table status : <Inactive>
Summary count : 0
以上显示信息的解释请参见表1-1。
# 显示静态路由表。
<Sysname> display ip routing-table protocol static
Summary count : 1
Static Routing table status : <Active>
Summary count : 0
Static Routing table status : <Inactive>
Summary count : 1
3.0.0.0/8 Static 60 0 2.2.2.2 GE2/0/0
以上显示信息的解释请参见表1-1。
# 显示所有BGP路由的详细信息。
<Sysname> display ip routing-table protocol bgp verbose
Summary count : 1
Destination: 1.1.1.2/32
Protocol: BGP instance default
Process ID: 0
SubProtID: 0x6 Age: 00h03m54s
NibID: 0x16000000 LastAs: 200
BkFlushNID: Invalid
以上显示信息的解释请参见表1-2。
display ip routing-table statistics命令用来显示路由表中路由或前缀的统计信息。
display ip routing-table [ prefix ] statistics
display ip routing-table [ all-routes | all-vpn-instance | vpn-instance vpn-instance-name ] [ prefix ] statistics
all-routes:显示公网和所有VPN实例的信息。
all-vpn-instance:显示所有VPN实例的信息。
prefix:显示前缀的统计信息。如果不指定本参数,则显示路由的统计信息。
如果不指定任何参数,将显示公网的信息。
# 显示公网路由表中的路由统计信息。
<Sysname> display ip routing-table statistics
Total prefixes: 15 Active prefixes: 15
Proto Routes Active Added Deleted
DIRECT 12 12 30 18
STATIC 3 3 5 2
RIP 0 0 0 0
OSPF 0 0 0 0
IS-IS 0 0 0 0
LISP 0 0 0 0
EIGRP 0 0 0 0
BGP 0 0 0 0
UNR 0 0 0 0
Total 15 15 35 20
# 显示公网和所有VPN实例路由表中的路由统计信息。
<Sysname> display ip routing-table all-routes statistics
Total prefixes: 11 Active prefixes: 11
DIRECT 8 8 8 0
STATIC 3 3 5 2
RIP 0 0 0 0
OSPF 0 0 0 0
IS-IS 0 0 0 0
LISP 0 0 0 0
EIGRP 0 0 0 0
BGP 0 0 0 0
UNR 0 0 0 0
Total 11 11 13 2
# 显示指定VPN实例路由表中的综合路由统计信息。
<Sysname> display ip routing-table vpn-instance vpn1 statistics
DIRECT 8 8 8 0
STATIC 3 3 5 2
RIP 0 0 0 0
OSPF 0 0 0 0
IS-IS 0 0 0 0
LISP 0 0 0 0
EIGRP 0 0 0 0
BGP 0 0 0 0
UNR 0 0 0 0
Total 11 11 13 2
# 显示所有VPN实例路由表中的路由统计信息。
<Sysname> display ip routing-table all-vpn-instance statistics
DIRECT 8 8 8 0
STATIC 3 3 5 2
RIP 0 0 0 0
OSPF 0 0 0 0
IS-IS 0 0 0 0
LISP 0 0 0 0
EIGRP 0 0 0 0
BGP 0 0 0 0
UNR 0 0 0 0
Total 11 11 13 2
# 显示公网的前缀统计信息。
<Sysname> display ip routing-table prefix statistics
Proto Prefixes Active Added Deleted
DIRECT 7 7 7 0
STATIC 0 0 0 0
UNR 0 0 0 0
RIP 1 0 1 0
OSPF 0 0 0 0
IS-IS 0 0 0 0
LISP 0 0 0 0
EIGRP 0 0 0 0
BGP 0 0 0 0
Total 8 7 8 0
表1-3 display ip routing-table statistics命令显示信息描述表
Total prefixes |
总的前缀数目 |
Active prefixes |
总的激活前缀数目 |
Proto |
路由协议 |
Routes |
路由数目 |
Prefixes |
前缀数目 |
Active |
活跃的、正在使用的路由或前缀数目 |
Added |
路由器启动后或在上一次清除路由表后,路由表中添加的路由或前缀数目 |
Deleted |
标记为删除的路由或前缀数目(此类路由在等待一段时间后会被释放) |
Total |
各种类型路由或前缀数目的总和 |
display ip routing-table summary命令用来显示路由表的概要信息,包括最大等价路由数、最大可激活路由前缀数、剩余可激活路由前缀数等。
display ip routing-table [ vpn-instance vpn-instance-name ] summary
# 显示公网的路由表概要信息。
<Sysname> display ip routing-table summary
Max ECMP: 64
Max Active Route: 262144
Remain Active Route: 262126
# 显示实例vpn1的路由表概要信息。
<Sysname> display ip routing-table vpn-instance vpn1 summary
Max ECMP: 64
Remain Active Route: 262134
Threshold value percentage of max active routes: 100%
表1-4 display ip routing-table summary命令显示信息描述表
Max ECMP |
最大等价路由数 |
Max Active Route |
最多支持激活路由前缀数 |
Remain Active Route |
剩余可激活路由前缀数 |
Threshold value xxx |
显示最多支持激活路由前缀数的告警门限: · 如果在VPN实例中配置了命令routing-table limit number simply-alert,则显示信息字段为Threshold value of active routes alert,取值表示产生告警的门限值。当VPN实例的激活路由前缀数超过该取值时,可以继续激活新的路由前缀,但会产生Trap告警和日志信息 · 若在VPN实例中配置了命令routing-table limit number warn-threshold,则显示信息字段为Threshold value percentage of max active routes,取值表示当(VPN实例中的激活路由前缀数/最多支持激活路由前缀数×100)达到warn-threshold时,产生Trap告警和日志信息,但仍然允许增加激活路由前缀。当VPN实例中的激活路由前缀由数达到最多支持激活路由前缀数目时,不再激活新的路由前缀 |
display ipv6 rib attribute命令用来显示IPv6 RIB的路由属性信息。
attribute-id:路由属性ID值,取值范围为十六进制数0~ffffffff。
# 显示IPv6 RIB的路由属性信息。
<Sysname> display ipv6 rib attribute
Total number of attribute(s): 1
Detailed information of attribute 0x9:
Flag: 0x0
Protocol: BGP4+ instance default
Address family: IPv6
Reference count: 0
Local preference: 0
Ext-communities number: 0
Ext-communities value: N/A
Communities number: 0
Communities value: N/A
AS-path number: 0
AS-path value: N/A
以上显示信息的解释请参见表1-9。
display ipv6 rib graceful-restart命令用来显示IPv6 RIB的GR状态信息。
# 显示IPv6 RIB的GR状态信息。
<Sysname> display ipv6 rib graceful-restart
RIB GR state : Phase2-calculation end
RCOM GR state : Flush end
Protocol GR state:
No. Protocol Lifetime FD State Start/End
1 DIRECT 900 29 End No/No
2 STATIC 900 32 End No/No
3 ISISV6 900 30 End No/No
4 BGP4+ instance default
900 31 End No/No
5 BGP4+ instance ebcdefg
900 32 End No/No
以上显示信息的解释请参见表1-10。
display ipv6 rib nib命令用来显示IPv6 RIB的下一跳信息。
self-originated:路由管理自己生成的下一跳。
nib-id:路由下一跳ID值,取值范围为十六进制数0~ffffffff。
verbose:显示详细信息。如果未指定本参数,则显示概要信息。
protocol protocol:显示指定路由协议的下一跳信息。
# 显示IPv6 RIB的下一跳信息。
<Sysname> display ipv6 rib nib
Total number of nexthop(s): 151
NibID: 0x20000000 Sequence: 0
Type: 0x1 Flushed: Yes
UserKey0: 0x0 VrfNthp: 0
UserKey1: 0x0 Nexthop: ::
IFIndex: 0x111 LocalAddr: ::
NewUK0: 0x0 NewUK1: 0x0
NewUK2: 0x0 NewUK3: 0x0
NewUK4: 0x0 NewUK5: 0x0
NewUK6: 0x0 NewUK7: 0x0
TopoNthp: Invalid ExtType: 0x0
Color: 0 COFlag: 0x0
SIDIndex: 0x0
NibID: 0x20000001 Sequence: 1
UserKey1: 0x0 Nexthop: ::1
IFIndex: 0x112 LocalAddr: ::1
SIDIndex: 0x0
# 显示IPv6 RIB下一跳的详细信息。
<Sysname> display ipv6 rib nib verbose
SIDIndex: 0x0
RefCnt: 4 FlushRefCnt: 1
Flag: 0x84 Version: 1
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: ::
RelyDepth: 0 RealNexthop: ::
Interface: NULL0 LocalAddr: ::
TunnelCnt: 0 Vrf: default-vrf
TunnelID: N/A Topology:
Weight: 0 Flags: 0x0
SRPolicyNID: 4294967295 SRInterface:
ColorWeight: 0
SIDIndex: 0x0
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: ::1
RelyDepth: 0 RealNexthop: ::1
Interface: InLoop0 LocalAddr: ::1
ColorWeight: 0
display ipv6 route-direct nib命令用来显示IPv6直连路由下一跳信息。
nib-id:路由邻居ID值,取值范围为十六进制数0~ffffffff。
# 显示IPv6直连路由下一跳信息。
<Sysname> display ipv6 route-direct nib
Total number of nexthop(s): 115
SIDIndex: 0x0
SIDIndex: 0x0
# 显示IPv6直连路由下一跳详细信息。
<Sysname> display ipv6 route-direct nib verbose
SIDIndex: 0x0
RefCnt: 1 FlushRefCnt: 0
Flag: 0x2 Version: 1
1 nexthop(s):
ColorWeight: 0
SIDIndex: 0x0
1 nexthop(s):
ColorWeight: 0
display ipv6 routing-table命令用来显示IPv6路由表的信息。
display ipv6 routing-table [ all-vpn-instance | vpn-instance vpn-instance-name ] [ verbose ]
display ipv6 routing-table [ all-routes ]
all-vpn-instance:显示所有VPN实例的路由信息。
verbose:显示IPv6路由表的详细信息,包括激活路由和未激活路由。如果未指定本参数,将显示激活路由的概要信息。
如果不指定任何参数,将显示公网的信息。
# 显示当前路由表的概要信息。
<Sysname> display ipv6 routing-table
Destination: ::1/128 Protocol : Direct
NextHop : ::1 Preference: 0
Interface : InLoop0 Cost : 0
Destination: FE80::/10 Protocol : Direct
NextHop : :: Preference: 0
<Sysname> display ipv6 routing-table all-routes
VPN instance: vpn1
Destination: 1:2::3:4/128 Protocol : Static
NextHop : :: Preference: 60
Interface : NULL0 Cost : 0
# 显示所有VPN实例下的IPv6路由信息。
<Sysname> display ipv6 routing-table all-vpn-instance
VPN instance: vpn1
VPN instance: vpn2
表1-5 display ipv6 routing-table命令显示信息描述表
VPN instance |
Destinations |
目的地址个数 |
Routes |
路由条数 |
Destination |
目的网络/主机的IPv6地址和前缀 |
NextHop |
下一跳地址 |
Preference |
路由优先级 |
出接口,即到该目的地址的数据包将从此接口发出 |
Protocol |
发现该路由的路由协议类型 |
Cost |
路由的开销值 |
Summary count |
路由数目 |
# 显示路由表的详细路由信息。
<Sysname> display ipv6 routing-table verbose
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 19h23m02s
TableID: 0xa OrigAs: 0
NibID: 0x20000000 LastAs: 0
AttrID: 0xffffffff Neighbor: ::
Flags: 0x10004 OrigNextHop: ::1
Label: NULL RealNextHop: ::1
BkFlushNID: Invalid
Destination: 12::/96
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 00h01m47s
NibID: 0x20000003 LastAs: 0
Flags: 0x10080 OrigNextHop: ::
BkFlushNID: Invalid
<Sysname> display ipv6 routing-table all-vpn-instance verbose
VPN instance: vpn1
Protocol: Direct
Process ID: 0
BkFlushNID: Invalid
Destination: 12::1/128
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 00h01m45s
BkFlushNID: Invalid
表1-6 display ipv6 routing-table verbose命令显示信息描述表
VPN instance |
路由表所属的公网或VPN实例信息,公网路由显示为public instance实例名称,私网路由显示为VPN实例名称 |
Destination |
目的网络/主机的IPv6地址和前缀 |
Protocol |
发现该路由的路由协议类型 |
Process ID |
进程号 |
SubProtID |
路由子协议ID |
Age |
此路由在路由表中存在的时间 |
Cost |
路由的度量值 |
Preference |
路由的优先级 |
IpPre |
IP优先级值 |
QosLocalID |
QoS本地ID |
Tag |
路由标记 |
State |
路由状态描述: · Active:有效的单播路由 · Adv:允许对外发送的路由 · Inactive:非激活路由标志 · NoAdv:不允许发布的路由 · Vrrp:VRRP产生的路由 · Nat:NAT产生的路由(暂不支持) · TunE:Tunnel隧道的标志 |
OrigTblID |
原始路由表ID |
OrigVrf |
TableID |
路由所在路由表的ID |
OrigAs |
初始AS号 |
NibID |
下一跳ID |
LastAs |
最后AS号 |
AttrID |
路由属性ID号 |
Neighbor |
路由协议的邻居地址 |
Flags |
路由标志位 |
OrigNextHop |
此路由的下一跳地址 |
Label |
标签 |
RealNextHop |
路由真实下一跳 |
BkLabel |
备份标签 |
BkNexthop |
备份下一跳地址 |
SRLabel |
BkSRLabel |
SR(Segment Routing))备份标签 |
BkInterface |
备份出接口 |
Tunnel ID |
隧道ID |
BkTunnel ID |
备份隧道ID |
BkInterface |
备份出接口 |
InLabel |
路由入标签 |
ColorInterface |
SIDIndex |
SID的相对值 |
BkColorInterface |
备份Color出接口 |
FtnIndex |
FTN表项索引 |
TrafficIndex |
Connector |
PathID |
路径ID |
Summary count |
路由数目 |
UserID |
接入用户ID |
SRTunnelID |
(暂不支持)SR隧道ID |
SID Type |
NID |
FlushNID |
BkNID |
BkFlushNID |
display ipv6 routing-table acl命令用来显示通过指定IPv6 ACL过滤的IPv6路由信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] acl ipv6-acl-number [ verbose ]
ipv6-acl-number:基本IPv6 ACL编号,取值范围为2000~2999。
verbose:显示通过指定IPv6 ACL过滤的所有路由的详细信息。如果未指定本参数,只显示通过IPv6 ACL过滤的激活路由的概要信息。
如果指定的IPv6 ACL不存在或者IPv6 ACL中没有任何规则,将显示所有的IPv6路由信息。
# 显示通过IPv6 ACL 2000过滤的激活路由的概要信息。
<Sysname> display ipv6 routing-table acl 2000
Summary count : 5
Destination : ::1/128 Protocol : Direct
Destination: 12::/96 Protocol : Direct
Interface : GE2/0/1 Cost : 0
Destination: 12::1/128 Protocol : Direct
Destination: FF::11/128 Protocol : BGP4+
NextHop : 12::2 Preference: 255
以上显示信息的解释请参见表1-5。
# 显示通过IPv6 ACL 2000过滤的所有路由的详细信息。
<Sysname> display ipv6 routing-table acl 2000 verbose
Summary count : 5
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 19h29m12s
BkFlushNID: Invalid
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 00h07m57s
BkFlushNID: Invalid
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 00h07m55s
BkFlushNID: Invalid
Process ID: 0
SubProtID: 0x6 Age: 00h06m43s
TableID: 0xa OrigAs: 200
NibID: 0x26000000 LastAs: 200
AttrID: 0x1 Neighbor: 12::2
Flags: 0x10060 OrigNextHop: 12::2
Label: NULL RealNextHop: 12::2
BkFlushNID: Invalid
Protocol: Direct
Process ID: 0
NibID: 0x20000002 LastAs: 0
Flags: 0x10084 OrigNextHop: ::
BkFlushNID: Invalid
以上显示信息的解释请参见表1-6。
display ipv6 routing-table ipv6-address命令用来显示指定目的地址的IPv6路由信息。
display ipv6 routing-table ipv6-address1 to ipv6-address2命令用来显示指定目的地址范围内的IPv6路由信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address [ prefix-length ] [ longer-match ] [ verbose ]
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address1 to ipv6-address2 [ verbose ]
ipv6-address:IPv6目的地址。
prefix-length:前缀长度,取值范围为0~128。
longer-match:显示满足匹配条件的所有路由信息。关于匹配条件的详细说明,请查看使用指导。
ipv6-address1 to ipv6-address2:IPv6地址范围。ipv6-address1和ipv6-address2共同决定一个地址范围,只有地址在此范围内的路由才会被显示。
verbose:显示激活和未激活路由的详细信息。如果未指定本参数,将显示激活路由的概要信息。
· display ipv6 routing-table ipv6-address
显示满足如下条件的所有激活路由:
¡ 用户输入的目的IPv6地址同路由表中各条路由的前缀长度值进行与运算;
¡ 路由表中各条路由的目的IPv6地址同其自身前缀长度值进行与运算;
· display ipv6 routing-table ipv6-address prefix-length
显示满足如下条件的所有激活路由:
¡ 用户输入的目的IPv6地址同用户输入的前缀长度值进行与运算;
¡ 路由表中各条路由的目的IPv6地址同用户输入的前缀长度值进行与运算;
¡ 两次运算结果相同,并且路由表中前缀长度小于等于用户输入的前缀长度的路由条目将被显示出来。
· display ipv6 routing-table ipv6-address longer-match
用户未指定前缀长度时,显示结果与display ipv6 routing-table命令的显示结果相同。
· display ipv6 routing-table ipv6-address prefix-length longer-match
显示满足如下条件的所有激活路由:
· display ipv6 routing-table ipv6-address1 to ipv6-address2
显示ipv6-address1/128到ipv6-address2/128之间的路由,目的IPv6地址与前缀长度(128位)同时在指定范围内才会显示。
# 显示目的IPv6地址/前缀为10::1/127的IPv6路由信息。
<Sysname> display ipv6 routing-table 10::1 127
Summary count: 3
Destination: 10::/64 Protocol : Static
Destination: 10::/68 Protocol : Static
Destination: 10::/120 Protocol : Static
# 显示目的IPv6地址/前缀为10::1/127并且满足匹配条件的IPv6路由信息。
<Sysname> display ipv6 routing-table 10::1 127 longer-match
Summary count : 3
# 显示目的IPv6地址从100::到300::范围内的IPv6路由信息。
<Sysname> display ipv6 routing-table 100:: to 300::
Summary count : 3
Destination: 100::/64 Protocol : Static
Destination: 200::/64 Protocol : Static
Destination: 300::/64 Protocol : Static
# 显示目的IPv6地址/前缀为1:2::3:4/128的IPv6路由的详细信息。
<Sysname> display ipv6 routing-table 1:2::3:4 128 verbose
Summary count : 1
Protocol: BGP4+ instance abc
Process ID: 0
SubProtID: 0x1 Age: 00h01m14s
TableID: 0x1 OrigAs: 200
AttrID: 0x0 Neighbor: 2:2::3:4
Flags: 0x10060 OrigNextHop: 2:2::3:4
Label: NULL RealNextHop: 2:2::3:4
BkFlushNID: Invalid
以上显示信息的解释请参见表1-5。
display ipv6 routing-table prefix-list命令用来显示通过指定前缀列表过滤的IPv6路由信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ]
prefix-list-name:IPv6前缀列表的名称,为1~63个字符的字符串,区分大小写。
verbose:显示所有路由的详细信息。如果未指定本参数,只显示激活路由的概要信息。
# 配置地址前缀列表test允许前缀为::1,前缀长度为128的IPv6路由通过。
[Sysname] ipv6 prefix-list test permit ::1 128
# 显示通过前缀列表test过滤的IPv6激活路由的概要信息。
[Sysname] display ipv6 routing-table prefix-list test
Summary count : 1
以上显示信息的解释请参见表1-5。
# 显示通过前缀列表test过滤的所有IPv6路由的详细信息。
[Sysname] display ipv6 routing-table prefix-list test verbose
Summary count : 1
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 08h57m19s
SRLabel: NULL BkSRLabel: NULL
SIDIndex: NULL InLabel: NULL
Tunnel ID: Invalid Interface: InLoopBack0
BkTunnel ID: Invalid BkInterface: N/A
FtnIndex: 0x0 TrafficIndex: N/A
以上显示信息的解释请参见表1-6。
display ipv6 routing-table protocol命令用来显示指定协议生成或发现的IPv6路由信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ]
inactive:如果配置了该参数,此命令只显示未激活路由信息。如果未指定本参数,将显示所有激活和未激活路由信息。
verbose:显示激活和未激活路由的详细信息。如果未指定本参数,将显示路由的概要信息。
# 显示所有IPv6直连路由的概要信息。
<Sysname> display ipv6 routing-table protocol direct
Summary count : 2
Summary count : 2
Summary count : 0
# 显示IPv6静态路由表。
<Sysname> display ipv6 routing-table protocol static
Summary count : 3
Summary count : 3
Destination: 2::2/128 Protocol : Static
NextHop : fe80::2 Preference: 60
NextHop : fe80::3 Preference: 60
Destination: 3::3/128 Protocol : Static
NextHop : 2::2 Preference: 60
Summary count : 0
# 显示所有BGP4+路由的详细信息。
<Sysname> display ipv6 routing-table protocol bgp4+ verbose
Summary count : 1
Destination: 22::22/128
Process ID: 0
SubProtID: 0x6 Age: 00h04m15s
NibID: 0x25000001 LastAs: 200
AttrID: 0x3 Neighbor: 121::2
Flags: 0x10060 OrigNextHop: 121::2
Label: NULL RealNextHop: 121::2
BkFlushNID: Invalid
以上显示信息的解释请参见表1-5。
display ipv6 routing-table statistics命令用来显示IPv6路由表中路由或前缀的统计信息。
display ipv6 routing-table [ all-routes | all-vpn-instance | vpn-instance vpn-instance-name ] [ prefix ] statistics
如果不指定任何参数时,则显示公网的信息。
# 显示路由统计信息。
<Sysname> display ipv6 routing-table statistics
Total prefixes: 8 Active prefixes: 8
DIRECT 5 5 5 0
STATIC 3 3 3 0
RIPng 0 0 0 0
OSPFv3 0 0 0 0
IS-ISv6 0 0 0 0
LISP 0 0 0 0
BGP4+ 0 0 0 0
SRv6 0 0 0 0
Total 8 8 8 0
<Sysname> display ipv6 routing-table all-routes statistics
Total prefixes: 6 Active prefixes: 6
DIRECT 3 3 3 0
STATIC 3 3 5 2
RIPng 0 0 0 0
OSPFv3 0 0 0 0
IS-ISv6 0 0 0 0
LISP 0 0 0 0
BGP4+ 0 0 0 0
SRv6 0 0 0 0
Total 6 6 8 2
<Sysname> display ipv6 routing-table vpn-instance vpn1 statistics
DIRECT 8 8 8 0
STATIC 3 3 5 2
RIPng 0 0 0 0
OSPFv3 0 0 0 0
IS-ISv6 0 0 0 0
LISP 0 0 0 0
BGP4+ 0 0 0 0
Total 11 11 13 2
<Sysname> display ipv6 routing-table all-vpn-instance statistics
DIRECT 8 8 8 0
STATIC 3 3 5 2
RIPng 0 0 0 0
OSPFv3 0 0 0 0
IS-ISv6 0 0 0 0
LISP 0 0 0 0
BGP4+ 0 0 0 0
Total 11 11 13 2
# 显示公网的IPv6前缀统计信息。
<Sysname> display ipv6 routing-table prefix statistics
DIRECT 5 5 5 0
STATIC 1 1 1 0
RIPng 0 0 0 0
OSPFv3 0 0 0 0
IS-ISv6 0 0 0 0
LISP 0 0 0 0
BGP4+ 0 0 0 0
SRv6 0 0 0 0
Total 6 6 6 0
表1-7 display ipv6 routing-table statistics命令显示信息描述表
Total prefixes |
总的前缀数目 |
Active prefixes |
总的激活前缀数目 |
Proto |
路由协议 |
Routes |
路由数目 |
Prefixes |
前缀数目 |
Active |
激活的、正在使用的路由或前缀数目 |
Added |
Deleted |
Total |
各种类型路由或前缀数目的总和 |
display ipv6 routing-table summary命令用来显示IPv6路由表的概要信息,包括最大等价路由数、最大可激活路由前缀数、剩余可激活路由前缀数等。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] summary
# 显示公网的路由表概要信息。
<Sysname> display ipv6 routing-table summary
Max ECMP: 64
以上显示信息的解释请参见表1-4。
# 显示vpn1实例的路由表概要信息。
<Sysname> display ipv6 routing-table vpn-instance vpn1 summary
Max ECMP: 64
Threshold value of active routes alert: 65100
以上显示信息的解释请参见表1-4。
display max-ecmp-num命令用来显示系统支持IPv4最大等价路由的条数。
# 显示系统支持IPv4最大等价路由的条数。
<Sysname> display max-ecmp-num
Max-ECMP-Num in use: 64
Max-ECMP-Num at the next reboot: 64
表1-8 display max-ecmp-num命令显示信息描述表
Max-ECMP-Num in use |
当前使用的最大等价路由的条数 |
Max-ECMP-Num at the next reboot |
下次启动后的最大等价路由的条数 |
display rib attribute命令用来显示RIB的路由属性信息。
# 显示RIB的路由属性信息。
<Sysname> display rib attribute
Total number of attribute(s): 10
Detailed information of attribute 0x0:
Flag: 0x0
Address family: IPv4
Reference count: 0
Act-RT reference count: 0
Flush flag: 0
Local preference: 0
Ext-communities number: 26
Ext-communities value: <RT: 1:1> <RT: 2:2> <RT: 3:3> <RT: 123.123.123.123:65535
> <RT: 1234567890:65535> <RT: 123.123.123.123:65534> <RT
: 4:4> <RT: 5:5> <RT: 6:6> <RT: 7:7> <RT: 8:8> <RT: 9:9>
<RT: 10:10> <RT: 10:1> <RT: 10:11> <RT: 10:12> <RT: 10:
13> <RT: 10:14> <RT: 10:15> <RT: 10:16> ...
AS-path number: 0
AS-path value: N/A
SFlow AS-path length: 0
SFlow AS-path value: N/A
Detailed information of attribute 0x1:
Flag: 0x0
Protocol: BGP
Reference count: 0
Flush flag: 0
Local prefrence: 0
Ext-communities number: 1
Ext-communities value: <RT: 1:2>
AS-path number: 0
AS-path value: N/A
表1-9 display rib attribute命令显示信息描述表
Total number of attribute(s): |
attribute的总个数 |
Flag |
标志位 |
Protocol |
产生该属性的协议 |
Address family |
地址簇类型 |
Reference count |
引用计数 |
Act-RT reference count |
被激活路由引用次数 |
Flush flag |
下刷FIB标记,0表示属性没有下刷FIB,1表示属性已经下刷FIB |
Local prefrence |
本地优先级 |
Ext-communities number |
扩展团体属性个数 |
Ext-communities value |
扩展团体属性值(个数为0显示N/A,最多显示20个,超出部分用…表示) |
Communities number |
团体属性个数 |
Communities value |
AS-path number |
AS-path个数(AS-path个数为所有AS号之和) |
AS-path value |
AS-path值(AS-path值不区分AS-set、AS-sequence、联盟AS-set、联盟AS-sequence;个数为0显示N/A,最多显示20个,超出部分用…表示) |
SFlow AS-path length |
(暂不支持)sFlow AS-path属性长度 |
SFlow AS-path value |
(暂不支持)sFlow AS-path值(长度为0显示N/A,最多显示80个,超出部分用…表示) |
display rib graceful-restart命令用来显示RIB的GR状态信息。
# 显示RIB的GR状态信息。
<Sysname> display rib graceful-restart
Protocol GR state:
1 DIRECT 900 30 End No/No
2 STATIC 900 34 End No/No
3 OSPF 900 36 End No/No
4 ISIS 900 32 End No/No
5 BGP instance abc
900 22 End No/No
6 BGP instance default
900 25 End No/No
7 LDP 900 35 End No/No
8 SLSP 900 29 End No/No
9 UNR instance UCM
900 33 End No/No
表1-10 display rib graceful-restart命令显示信息描述表
RIB GR state |
RIB GR状态: · Start:协议GR开始 · IGP end:所有IGP协议GR结束 · VPN-triggering end:VPN路由触发优选结束 · VPN-calculation end:VPN路由优选结束 · Routing protocol end:所有路由协议GR结束 · NSR-calculation unfinished:NSR优选未完成状态 · Triggering start:所有路由触发优选开始 · Triggering end:所有路由触发优选结束 · Phase1-calculation end:第一阶段优选结束 · All end:所有协议GR结束 · Phase2-calculation end:第二阶段优选结束 |
RCOM GR state |
RCOM GR状态: · Start:协议GR开始 · VPN-calculation end:VPN路由优选结束 · VPN-notification end:VPN路由上报结束 · Routing protocol end:所有路由协议GR结束 · NSR-calculation unfinished:NSR优选未完成状态 · Phase1-calculation end:第一阶段优选结束 · Notification end:所有路由上报结束 · Phase2-calculation end:第二阶段优选结束 · Flush start:开始下刷FIB · Flush end:下刷FIB结束 |
Protocol GR state |
协议GR状态 |
No. |
编号 |
Protocol |
协议名称 |
Lifetime |
倒换过程中协议的路由信息/标签信息在RIB中的存活时间,单位为秒 |
FD |
协议进程与RIB连接的句柄 |
State |
协议GR状态: · Init:协议GR初始化状态 · Listen:协议GR监听状态 · Idle:协议GR空闲状态 · Active:协议GR激活状态 · Start:协议GR开始状态 · End:协议GR结束状态 |
Start/End |
· No:表示该消息未发送 · Yes:表示该消息已发送 |
display rib nib命令用来显示RIB的下一跳信息。
self-originated:路由管理自己生成的下一跳信息。
nib-id:路由下一跳信息的ID值,取值范围为十六进制数0~ffffffff。
protocol protocol:显示指定路由协议生成的下一跳信息。
如果不指定任何参数,将显示RIB中所有下一跳的概要信息。
# 显示RIB的下一跳信息。
<Sysname> display rib nib
Total number of nexthop(s): 176
NibID: 0x10000000 Sequence: 0
UserKey1: 0x0 Nexthop: 0.0.0.0
IFIndex: 0x111 LocalAddr: 0.0.0.0
TopoNthp: 0 ExtType: 0x0
SIDIndex: 0x0
NibID: 0x10000001 Sequence: 1
UserKey1: 0x0 Nexthop: 127.0.0.1
IFIndex: 0x112 LocalAddr: 127.0.0.1
SIDIndex: 0x0
NibID: 0x10000002 Sequence: 2
Type: 0x5 Flushed: Yes
SIDIndex: 0x0
NibID: 0x16000000 Sequence: 3
Type: 0x21 Flushed: No
UserKey1: 0x0 Nexthop: 12.1.1.2
IFIndex: 0x0 LocalAddr: 0.0.0.0
SIDIndex: 0x0
Instance: abc
表1-11 display rib nib命令显示信息描述表
Total number of nexthop(s) |
总的下一跳个数 |
NibID |
下一跳ID |
Sequence |
下一跳序列号 |
Type |
下一跳类型 |
Flushed |
是否下刷 |
UserKey0 |
第一个协议保留数据 |
UserKey1 |
第二个协议保留数据 |
VrfNthp |
下一跳所在VPN索引,显示为0表示公网 |
Nexthop |
下一跳地址 |
IFIndex |
接口索引 |
LocalAddr |
本地接口地址 |
NewUK0 |
第一个新的协议保留数据 |
NewUK1 |
第二个新的协议保留数据 |
NewUK2 |
第三个新的协议保留数据 |
NewUK3 |
第四个新的协议保留数据 |
NewUK4 |
第五个新的协议保留数据 |
NewUK5 |
第六个新的协议保留数据 |
NewUK6 |
第七个新的协议保留数据 |
NewUK7 |
第八个新的协议保留数据 |
TopoNthp |
(暂不支持)下一跳所在拓扑索引,显示为0表示公网拓扑(目前IPv6不支持子拓扑,显示为Invalid) |
ExtType |
下一跳扩展类型 |
Color |
Color扩展团体属性 |
COFlag |
Color属性的标志位 |
SIDIndex |
SID的索引值 |
Instance |
BGP实例名称 |
SubNibID |
子下一跳的ID |
SubSeq |
子下一跳的序列号 |
NthpCnt |
子下一跳的下一跳计数 |
Samed |
子下一跳中相同下一跳计数 |
NthpType |
子下一跳类型: · IP:下一跳是IP转发类型 · MPLS:下一跳是MPLS转发类型 |
# 显示RIB下一跳详细信息。
<Sysname> display rib nib verbose
SIDIndex: 0x0
RefCnt: 6 FlushRefCnt: 2
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 0.0.0.0
RelyDepth: 0 RealNexthop: 0.0.0.0
Interface: NULL0 LocalAddr: 0.0.0.0
TunnelID: N/A Topology: base
ColorWeight: 0
SIDIndex: 0x0
RefCnt: 13 FlushRefCnt: 5
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 127.0.0.1
RelyDepth: 0 RealNexthop: 127.0.0.1
Interface: InLoop0 LocalAddr: 127.0.0.1
ColorWeight: 0
NibID: 0x15000003 Sequence: 3
Type: 0x43 Flushed: Yes
UserKey0: 0x100010000 VrfNthp: 0
UserKey1: 0x0 Nexthop: 22.22.22.22
SIDIndex: 0x0
Instance: default
RefCnt: 9 FlushRefCnt: 3
Policy: tnl-policy1
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 22.22.22.22
RelyDepth: 1 RealNexthop: 13.1.1.2
Interface: GE0/1/3 LocalAddr: 13.1.1.1
TunnelCnt: 1 Vrf: default-vrf
TunnelID: 1025 Topology: base
ColorWeight: 0
表1-12 display rib nib verbose命令显示信息描述表
总的下一跳个数 |
NibID |
下一跳ID |
Sequence |
下一跳序列号 |
Type |
下一跳类型 |
Flushed |
是否下刷 |
UserKey0 |
第一个协议保留数据 |
VrfNthp |
UserKey1 |
第二个协议保留数据 |
Nexthop |
下一跳地址 |
IFIndex |
接口索引 |
LocalAddr |
本地接口地址 |
NewUK0 |
第一个新的协议保留数据 |
NewUK1 |
第二个新的协议保留数据 |
NewUK2 |
第三个新的协议保留数据 |
NewUK3 |
第四个新的协议保留数据 |
NewUK4 |
第五个新的协议保留数据 |
NewUK5 |
第六个新的协议保留数据 |
NewUK6 |
第七个新的协议保留数据 |
NewUK7 |
第八个新的协议保留数据 |
TopoNthp |
ExtType |
下一跳扩展类型 |
Color |
Color扩展团体属性 |
COFlag |
Color属性的标志位 |
SIDIndex |
SID的索引值 |
Instance |
BGP实例名称 |
RefCnt |
下一跳信息的引用计数 |
FlushRefCnt |
下一跳信息的下刷引用计数 |
Flag |
下一跳信息的标志位 |
Version |
下一跳信息的版本号 |
Policy |
隧道策略名 |
x nexthop (s) |
下一跳具体值(前面数值表示下一跳个数) |
PrefixIndex |
等价时下一跳序号 |
OrigNexthop |
原始下一跳 |
RelyDepth |
迭代深度 |
RealNexthop |
真实下一跳 |
出接口 |
LocalAddr |
本地接口地址 |
TunnelCnt |
迭代到隧道的个数 |
Vrf |
VPN实例名,显示为default-vrf表示公网 |
TunnelID |
迭代到隧道的ID |
Topology |
(暂不支持)拓扑名称,显示为base表示公网拓扑(目前IPv6不支持子拓扑,显示为空) |
Weight |
等价路由各路由的权重,取值为0表示不是等价路由 |
Flags |
当前下一跳的标志位 |
SRPolicyNID |
(暂不支持)SR-TE Policy迭代路由的下一跳ID |
SRInterface |
(暂不支持)SR-TE Policy迭代路由的出接口 |
ColorWeight |
(暂不支持)SR-TE Policy中Color属性的权重值 |
display route-direct nib命令用来显示直连路由下一跳信息。
# 显示直连路由下一跳信息。
<Sysname> display route-direct nib
Total number of nexthop(s): 116
SIDIndex: 0x0
SIDIndex: 0x0
表1-13 display route-direct nib命令显示信息描述表
总的下一跳个数 |
NibID |
NIB ID号 |
Sequence |
NIB序列号 |
Type |
NIB类型 |
Flushed |
是否下刷FIB |
UserKey0 |
NIB协议保留数据1 |
UserKey1 |
NIB协议保留数据2 |
VrfNthp |
Nexthop |
下一跳信息 |
IFIndex |
接口索引 |
LocalAddr |
本地接口地址 |
NewUK0 |
第一个新的协议保留数据 |
NewUK1 |
第二个新的协议保留数据 |
NewUK2 |
第三个新的协议保留数据 |
NewUK3 |
第四个新的协议保留数据 |
NewUK4 |
第五个新的协议保留数据 |
NewUK5 |
第六个新的协议保留数据 |
NewUK6 |
第七个新的协议保留数据 |
NewUK7 |
第八个新的协议保留数据 |
TopoNthp |
ExtType |
下一跳扩展类型 |
Color |
Color扩展团体属性 |
COFlag |
Color属性的标志位 |
SIDIndex |
SID的索引值 |
# 显示直连路由下一跳详细信息。
<Sysname> display route-direct nib verbose
SIDIndex: 0x0
RefCnt: 2 FlushRefCnt: 0
1 nexthop(s):
ColorWeight: 0
SIDIndex: 0x0
RefCnt: 5 FlushRefCnt: 0
1 nexthop(s):
ColorWeight: 0
表1-14 display route-direct nib verbose命令显示信息描述表
总的下一跳个数 |
NibID |
下一跳ID |
Sequence |
下一跳序列号 |
Type |
下一跳类型 |
Flushed |
是否下刷 |
UserKey0 |
第一个协议保留数据 |
VrfNthp |
UserKey1 |
第二个协议保留数据 |
Nexthop |
下一跳地址 |
IFIndex |
接口索引 |
LocalAddr |
本地接口地址 |
NewUK0 |
第一个新的协议保留数据 |
NewUK1 |
第二个新的协议保留数据 |
NewUK2 |
第三个新的协议保留数据 |
NewUK3 |
第四个新的协议保留数据 |
NewUK4 |
第五个新的协议保留数据 |
NewUK5 |
第六个新的协议保留数据 |
NewUK6 |
第七个新的协议保留数据 |
NewUK7 |
第八个新的协议保留数据 |
TopoNthp |
ExtType |
下一跳扩展类型 |
Color |
Color扩展团体属性 |
COFlag |
Color属性的标志位 |
SIDIndex |
SID的索引值 |
RefCnt |
RefCnt |
FlushRefCnt |
下一跳信息的下刷引用计数 |
Flag |
下一跳信息的标志位 |
Version |
下一跳信息的版本号 |
x nexthop (s) |
PrefixIndex |
等价时下一跳序号 |
OrigNexthop |
原始下一跳 |
RelyDepth |
迭代深度 |
RealNexthop |
真实下一跳 |
出接口 |
LocalAddr |
本地接口地址 |
TunnelCnt |
迭代到隧道的个数 |
Vrf |
TunnelID |
迭代到隧道的ID |
Topology |
Weight |
Flags |
当前下一跳的标志位 |
SRPolicyNID |
SRInterface |
ColorWeight |
fib lifetime命令用来配置IPv4/IPv6路由在FIB中的最大存活时间。
undo fib lifetime命令用来恢复缺省情况。
fib lifetime seconds
undo fib lifetime
IPv4/IPv6路由在FIB中的最大存活时间为600秒。
RIB IPv4地址族视图
RIB IPv6地址族视图
seconds:路由在FIB中的最大存活时间,取值范围为0~6000,单位为秒。取值为0时表示,协议或RIB进程倒换并重新恢复后,会立即通知FIB老化表项。
配置本命令后,协议在未配置GR或NSR的情况下,协议或RIB倒换重新恢复后,会延迟配置的seconds,再通知FIB老化表项。
# 配置IPv4路由在FIB中的最大存活时间为60秒。
[Sysname] rib
[Sysname-rib-ipv4] fib lifetime 60
flush route-attribute命令用来配置RIB向FIB下发路由时会携带属性消息。
undo flush route-attribute命令用来取消该配置。
flush route-attribute protocol
undo flush route-attribute protocol
RIB向FIB下发路由时不携带属性消息。
RIB IPv4地址族视图
protocol:路由协议,目前只支持bgp。
# 配置RIB向FIB下发BGP路由时会携带属性消息。
[Sysname] rib
[Sysname-rib-ipv4] flush route-attribute bgp
inter-protocol fast-reroute命令用来开启RIB IPv4/IPv6地址族的不同协议间快速重路由功能。
undo inter-protocol fast-reroute命令用来关闭RIB IPv4/IPv6地址族的不同协议间快速重路由功能。
inter-protocol fast-reroute [ vpn-instance vpn-instance-name ]
undo inter-protocol fast-reroute [ vpn-instance vpn-instance-name ]
不同协议间快速重路由功能处于关闭状态。
RIB IPv4地址族视图
RIB IPv6地址族视图
vpn-instance vpn-instance-name:开启指定VPN实例的不同协议间快速重路由功能。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则开启RIB IPv4/IPv6地址族中公网的不同协议间快速重路由功能。
通过配置不同协议间快速重路由功能,可将不同协议的下一跳作为备份下一跳。当路由器检测到网络故障时,将使用备份下一跳替换失效下一跳,通过备份下一跳来指导报文的转发,从而大大缩短了流量中断的时间。
如果RIB表中去往同一目的地的不同路由的下一跳和出接口均相同,使用该命令不会生成备份下一跳。
使用不同协议间的快速重路由功能生成备份下一跳时可能会造成环路。
# 开启RIB IPv4地址族中公网的不同协议间快速重路由功能。
[Sysname] rib
[Sysname-rib-ipv4] inter-protocol fast-reroute
maintenance-probe enable命令用来开启MTP(Maintain Probe,维护探测器)功能。
undo maintenance-probe enable命令用来关闭MTP功能。
MTP功能处于关闭状态。
开启MTP功能后,当与邻居间的路由协议报文超时时,设备会向超时的邻居发起Ping操作和Tracert操作并记录结果。相关信息可以通过display ospf troubleshooting等路由协议模块的显示命令查看,也可以通过display logbuffer命令查看MTP的详细信息。
# 开启MTP功能。
[Sysname] maintenance-probe enable
· display bgp troubleshooting(三层技术-IP路由命令参考/BGP)
· display logbuffer(网络管理和监控命令参考/信息中心)
· display ospf troubleshooting(三层技术-IP路由命令参考/OSPF)
nexthop recursive-lookup restrain clear-interval命令用来配置清除下一跳循环迭代惩罚计数的时间间隔。
undo nexthop recursive-lookup restrain clear-interval命令用来恢复缺省情况。
nexthop recursive-lookup restrain clear-interval interval
清除下一跳循环迭代惩罚计数的时间间隔为600秒。
RIB IPv4地址族视图
RIB IPv6地址族视图
clear-interval interval:清除下一跳循环迭代惩罚计数的时间间隔。interval表示时间间隔,取值范围1~65535,单位为秒。
下一跳循环迭代惩罚计数达到20次后,设备将启动抑制,即停止根据下一跳信息查找直连出接口的操作。interval时间后,设备将停止对下一跳循环迭代进行抑制,并将下一跳循环迭代惩罚计数清零。
# 配置清除下一跳循环迭代计数的时间间隔为100秒。
[Sysname] rib
[Sysname-rib-ipv4] nexthop recursive-lookup restrain clear-interval 100
nexthop recursive-lookup restrain disable命令用来关闭下一跳循环迭代抑制功能。
undo nexthop recursive-lookup restrain disable命令用来开启下一跳循环迭代抑制功能。
下一跳循环迭代抑制功能处于开启状态。
RIB IPv4地址族视图
RIB IPv6地址族视图
在路由迭代过程中,若迭代路径包含该路由本身,则认为发生循环迭代。循环迭代将导致本次迭代失败并触发继续查找其他依赖路由。当大量路由的下一跳相同,且该下一跳因不断进行循环迭代导致路由频繁震荡时,系统会频繁处理大量的路由变化,这样会占用大量系统资源,导致CPU占用率升高,影响设备性能。
不断进行循环迭代时,迭代失败次数(下一跳循环迭代惩罚计数)会累计一次,当惩罚计数达到一定数量时,将不再进行路由迭代,从而解决上述问题。
用户不关心循环迭代造成的CPU占用率升高时,可以关闭下一跳循环迭代抑制功能。
# 关闭下一跳循环迭代抑制功能。
[Sysname] rib
[Sysname-rib-ipv4] nexthop recursive-lookup restrain disable
non-stop-routing命令用来使能路由的NSR功能。
undo non-stop-routing命令用来关闭路由的NSR功能。
non-stop-routing
路由的NSR功能处于关闭状态。
RIB IPv4地址族视图
RIB IPv6地址族视图
# 使能IPv4路由的NSR功能。
[Sysname] rib
[Sysname-rib-ipv4] non-stop-routing
primary-path-detect bfd命令用来开启主用链路的BFD检测功能。
undo primary-path-detect bfd命令用来关闭主用链路的BFD检测功能。
primary-path-detect bfd { ctrl | echo } [ inter-protocol-frr | protocol-ecmp protocol ]
undo primary-path-detect bfd [ inter-protocol-frr | protocol-ecmp protocol ]
主用链路的BFD检测功能处于关闭状态。
RIB IPv4地址族视图
RIB IPv6地址族视图
ctrl:配置通过控制报文方式的BFD会话对主用链路进行检测。
echo:配置通过echo报文方式的BFD会话对主用链路进行检测。
inter-protocol-frr:开启不同协议间快速重路由的主用链路BFD检测功能,即不同协议的路由间形成快速重路由保护后,通过BFD会话检测主路由的下一跳是否可达。
protocol-ecmp protocol:开启指定路由协议等价路由的主用链路BFD检测功能。在RIB IPv4地址族视图中,该参数的取值包括bgp、ospf、isis和static。在RIB IPv6地址族视图中,该参数的取值包括bgp4+、ospfv3、isisv6和static。
开启本功能后,设备将使用BFD会话对主用链路进行检测:
· 对于不同协议间的快速重路由,主用链路指的是去往同一目的地的多条路由中优先级最高的路由。
· 对于指定路由协议的等价路由,主用链路指的是形成等价路由的每一条路由。
通过重复执行本命令,可以修改BFD会话的工作方式(echo报文方式或控制报文方式)。
执行本命令时,如果没有指定inter-protocol-frr和protocol-ecmp参数,表示同时开启或关闭不同协议间快速重路由的主用链路BFD检测功能,和指定路由协议所有等价路由的BFD检测功能。以此种方式进行的配置,优先级高于通过指定inter-protocol-frr或protocol-ecmp参数进行的配置。
# 配置通过控制报文方式的BFD会话检测OSPF协议所有等价路由的下一跳是否可达。
[Sysname] rib
[Sysname-rib-ipv4] primary-path-detect bfd ctrl protocol-ecmp ospf
· fast-reroute(三层技术-IP路由命令参考/IS-IS)
· inter-protocol fast-reroute
protocol lifetime命令用来配置IPv4/IPv6路由和标签在RIB中的最大存活时间。
undo protocol lifetime命令用来恢复缺省情况。
undo protocol protocol [ instance instance-name ] lifetime
IPv4/IPv6路由和标签在RIB中的最大存活时间为900秒。
RIB IPv4地址族视图
RIB IPv6地址族视图
protocol:路由协议。
instance instance-name:BGP实例名称,instance-name为1~31个字符的字符串,区分大小写。如果未指定本参数,将配置所有BGP实例的最大存活时间。只有当protocol是bgp时该参数可选。
seconds:最大存活时间,取值范围为1~6000,单位为秒。
如果配置了该命令,且协议配置GR的情况下,需要注意该时间不要与GR时间冲突,即必须要保证协议能够在该时间内完成GR并将全部表项下发RIB,否则会导致GR失败并断流。
# 配置RIB中BGP路由和标签的最大存活时间为60秒。
[Sysname] rib
[Sysname-rib-ipv4] protocol bgp lifetime 60
protocol nexthop recursive-lookup命令用来配置按照路由策略进行迭代下一跳查找。
undo protocol nexthop recursive-lookup命令用来取消该配置。
protocol protocol nexthop recursive-lookup route-policy route-policy-name
undo protocol protocol nexthop recursive-lookup route-policy
没有配置按路由策略进行下一跳迭代查找。
RIB IPv4地址族视图
RIB IPv6地址族视图
protocol:路由协议,RIB IPv4地址族视图下支持bgp、static,RIB IPv6地址族视图下支持bgp4+。
route-policy-name:指定路由策略名,为1~63个字符的字符串,区分大小写。
通过配置按路由策略迭代下一跳,可以对路由迭代的结果进行控制。例如:当路由发生变化时,路由管理需要对非直连的下一跳重新进行迭代。如果不对迭代的结果路由进行任何限制,则路由管理可能会将下一跳迭代到一个错误的转发路径上,从而造成流量丢失。此时,可以通过配置本功能,将错误的依赖路由过滤掉,使路由迭代到通过路由策略过滤的指定依赖路由上。
配置路由策略时,如果配置了apply子句,apply子句不会生效。
配置路由策略时,请确保至少有一个正确的依赖路由能够通过该策略的过滤,否则可能导致相关路由不可达,无法正确指导转发。
从BGP直连邻居收到的路由不受下一跳迭代路由策略的限制。
# 配置BGP路由按照路由策略policy1进行下一跳迭代查找。
[Sysname] rib
[Sysname-rib-ipv4] protocol bgp nexthop recursive-lookup route-policy policy1
reset ip routing-table statistics protocol命令用来清除路由表中的路由统计信息。
reset ip routing-table statistics protocol { protocol | all }
reset ip routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
reset ip routing-table [ all-routes | all-vpn-instance ] statistics protocol { protocol | all }
vpn-instance vpn-instance-name:清除指定VPN的路由统计信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
all-routes:清除公网和所有VPN实例的路由统计信息。
all-vpn-instance:清除所有VPN实例的路由统计信息。
protocol:清除IPv4路由表中指定路由协议的统计信息。
all:清除IPv4路由表中所有路由协议的统计信息。
如果没有指定all-routes、vpn-instance和all-vpn-instance参数,则清除公网的路由统计信息。
# 清除路由表中的路由统计信息。
<Sysname> reset ip routing-table statistics protocol all
reset ipv6 routing-table statistics protocol命令用来清除IPv6路由表中的综合路由统计信息。
reset ipv6 routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
reset ipv6 routing-table [ all-routes | all-vpn-instance ] statistics protocol { protocol | all }
protocol:清除IPv6路由表中指定路由协议的统计信息。
all:清除IPv6路由表中所有路由协议的统计信息。
# 清除IPv6路由表中所有路由协议的综合路由统计信息。
<Sysname> reset ipv6 routing-table statistics protocol all
rib命令用来进入RIB视图。
undo rib命令用来删除RIB视图下的所有配置。
rib
undo rib
# 进入RIB视图。
[Sysname] rib
route-direct track命令用来配置直连路由与Track项关联。
undo route-direct track命令用来恢复缺省情况。
route-direct track track-entry-number degrade-cost cost-value
未配置直连路由与Track项关联。
track-entry-number:指定Track项序号,取值范围为1~1024。
degrade-cost cost-value:当Track项状态变为Negative后直连路由的开销值,取值范围为1~4294967295。
在采用VRRP备份组作为用户网关的场景中,由于上行流量的路径取决于VRRP状态,而下行流量的路径一般由动态路由协议通过选路决定,因此可能出现上下行流量路径不一致的情况。当需要在主机上设置防火墙以提高安全性时,上下行路径不一致会导致流量被防火墙阻止;另外,在进行流量监控、流量统计等管理工作时,上下行流量路径不一致会增加不必要的难度和成本。为了解决该问题,可以通过Track项在VRRP备份组和直连路由之间建立关联,使设备根据VRRP状态来调整直连路由的开销值,然后配置动态路由协议引入直连路由,从而使VRRP状态影响动态路由协议的选路结果。具体的工作机制如下:
· 如果直连路由关联的Track项不存在,或者关联的Track项的状态为NotReady或Positive时,接口的直连路由的开销值为0,该路由被优选。
· 如果直连路由关联的Track项的状态为Negative时,该接口的直连路由的开销值为用户通过本功能设置的值,该路由不会被优选。
Track项的状态与VRRP备份组中设备状态的对应关系如下:
· 当设备为Master状态时,关联的Track项为Positive状态。
· 当设备为Backup或Initialize状态时,关联的Track项为Negative状态;当设备为Inactive状态或VRRP备份组不存在时,对应的Track项为NotReady状态。
不能通过重复执行本命令修改直连路由关联的Track项。如需修改直连路由关联的Track项,请先通过undo route-direct track命令取消直连路由关联的Track项,再执行route-direct track命令。
# 在接口GigabitEthernet2/0/0上配置直连路由与序号为1的Track项关联,并设置Track项状态变为Negative后直连路由的开销值为200。
[Sysname] interface gigabitethernet 2/0/0
[Sysname-GigabitEthernet2/0/0] route-direct track 1 degrade-cost 200
· track vrrp(可靠性命令参考/Track)
routing-table limit命令用来配置设备支持的最大IPv4/IPv6激活路由前缀数。
undo routing-table limit命令用来恢复缺省情况。
不限制设备支持的最大IPv4/IPv6激活路由前缀数。
RIB IPv4地址族视图
RIB IPv6地址族视图
number:设备支持的最大IPv4/IPv6激活路由前缀数目,取值范围为1~4294967295。
simply-alert:当设备的IPv4/IPv6激活路由前缀数超过最大支持的激活路由前缀数目时,可以继续激活新的路由前缀,但会产生一条日志信息。
RIB IPv4地址族视图下的配置用于控制公网和所有VPN实例内IPv4激活路由的总数。
RIB IPv6地址族视图下的配置用于控制公网和所有VPN实例内IPv6激活路由的总数。
# 配置当前设备上的RIB IPv4地址族视图下公网和所有VPN实例内IPv4激活路由的总数超过1000时,可以继续激活新的路由前缀,但是会产生一条日志信息。
[Sysname] rib
[Sysname-rib-ipv4] routing-table limit 1000 simply-alert
