02-802.1X命令
本章节下载: 02-802.1X命令 (174.84 KB)
display dot1x [ sessions | statistics ] [ interface interface-list ]
【缺省级别】
1:监控级
sessions:显示802.1X的会话连接信息。
statistics:显示802.1X的相关统计信息。
interface interface-list:以太网端口列表,表示多个以太网端口,表示方式为interface-list = { interface-type interface-number [ to interface-type interface-number ] }&<1-10>。其中,interface-type为端口类型,interface-number为端口号。&<1-10>表示前面的参数最多可以输入10次。起始端口类型必须和终止端口类型一致,并且终止端口号必须大于起始端口号。
【描述】
display dot1x命令用来显示802.1X的相关信息,包括会话连接信息、相关统计信息或配置信息等。
需要注意的是,如果不指定参数sessions或者statistics,则显示802.1X的所有信息,包括会话连接信息、相关统计信息和配置信息等。
相关配置可参考命令reset dot1x statistics、dot1x、dot1x retry、dot1x max-user、dot1x port-control、dot1x port-method和dot1x timer。
# 显示802.1X的所有信息。
<Sysname> display dot1x
Equipment 802.1X protocol is enabled
CHAP authentication is enabled
Proxy trap checker is disabled
Proxy logoff checker is disabled
EAD quick deploy is enabled
Configuration: Transmit Period 30 s, Handshake Period 15 s
Quiet Period 60 s, Quiet Period Timer is disabled
Supp Timeout 30 s, Server Timeout 100 s
The maximal retransmitting times 3
EAD quick deploy configuration:
EAD timeout: 30m
The maximum 802.1X user resource number is 1024 per slot
Total current used 802.1X resource number is 1
Ethernet1/0/1 is link-up
Handshake is disabled
The port is an authenticator
Authenticate Mode is Auto
Port Control Type is Mac-based
802.1X Multicast-trigger is enabled
Mandatory authentication domain: NOT configured
Guest VLAN: 4
Max number of on-line users is 256
EAPOL Packet: Tx 1087, Rx 986
Sent EAP Request/Identity Packets : 943
EAP Request/Challenge Packets: 60
EAP Success Packets: 29, Fail Packets: 55
Received EAPOL Start Packets : 60
EAPOL LogOff Packets: 24
EAP Response/Identity Packets : 724
EAP Response/Challenge Packets: 54
Error Packets: 0
1. Authenticated user : MAC address: 0015-e9a6-7cfe
Controlled User(s) amount to 1
表1-1 display dot1x命令显示信息描述表
Equipment 802.1X protocol is enabled |
全局的802.1X特性已经开启 |
CHAP authentication is enabled |
使能CHAP认证 |
Proxy trap checker is disabled |
是否检测通过代理登录用户的接入 l disable表示不检测; l enable表示检测到用户使用代理后,发送Trap报文 |
Proxy logoff checker is disabled |
是否检测通过代理登录用户的接入 l disable表示不检测; l enable表示检测到用户使用代理后,切断用户连接 |
EAD quick deploy is enabled |
使能EAD快速部署功能 |
Transmit Period |
发送间隔定时器的时长 |
Handshake Period |
设备向客户端发送握手报文的时间间隔 |
Quiet Period |
静默定时器的时长 |
Quiet Period Timer is disabled |
静默定时器处于关闭状态 |
Supp Timeout |
客户端认证超时定时器的时长 |
Server Timeout |
认证服务器超时定时器的时长 |
The maximal retransmitting times |
设备向接入用户发送认证请求报文的最大次数 |
EAD quick deploy configuration |
EAD快速部署功能的具体配置 |
URL |
用户IE访问重定向的URL |
Free IP |
用户可访问的免认证网段 |
EAD timeout |
ACL老化定时器超时时间 |
The maximum 802.1X user resource number per slot |
每板最大支持的接入用户数 |
Total current used 802.1X resource number |
当前在线接入用户数 |
Ethernet1/0/1 is link-up |
端口Ethernet1/0/1的状态为up |
802.1X protocol is disabled |
该端口未使能802.1X协议 |
该端口是否检测通过代理登录用户的接入 l disable表示不检测; l enable表示检测用户使用代理后,发送Trap报文 |
该端口是否检测通过代理登录用户的接入 l disable表示不检测; l enable表示检测用户使用代理后,切断用户连接 |
Handshake is disabled |
握手功能是禁止的 |
The port is an authenticator |
该端口担当设备端作用 |
Authenticate Mode is Auto |
端口接入控制的模式为auto |
802.1X Multicast-trigger is enabled |
802.1X的组播触发功能已开启 |
Mandatory authentication domain |
端口接入用户的强制认证域 |
Port Control Type is Mac-based |
端口接入控制方式为mac-based,即基于MAC地址对接入用户进行认证 |
Guest VLAN |
端口配置的Guest VLAN,没有配置Guest VLAN显示NOT configured |
Max number of on-line users |
本端口最多可容纳的接入用户数 |
EAPOL Packet |
EAPOL报文数目:Tx表示发送的报文数目;Rx表示接受的报文数目 |
Sent EAP Request/Identity Packets |
发送的EAP Request/Identity报文数 |
EAP Request/Challenge Packets |
发送的EAP Request/Challenge报文数 |
EAP Success Packets |
发送的EAP Success报文数 |
Received EAPOL Start Packets |
接收的EAPOL Start报文数 |
EAPOL LogOff Packets |
接收的EAPOL LogOff报文数 |
EAP Response/Identity Packets |
接收的EAP Response/Identity报文数 |
EAP Response/Challenge Packets |
接收的EAP Response/Challenge报文数 |
Error Packets |
接收的错误报文数 |
Authenticated user |
认证通过的用户 |
Controlled User(s) amount |
该端口受控用户数目 |
在系统视图下:
dot1x [ interface interface-list ]
undo dot1x [ interface interface-list ]
在二层以太网端口视图下:
dot1x
undo dot1x
系统视图/二层以太网端口视图
【缺省级别】
2:系统级
interface interface-list:端口列表,表示多个端口,表示方式为interface-list = { interface-type interface-number [ to interface-type interface-number ] }&<1-10>。其中,interface-type为端口类型,interface-number为端口号。&<1-10>表示前面的参数最多可以输入10次。起始端口类型必须和终止端口类型一致,并且终止端口号必须大于起始端口号。
【描述】
dot1x命令用来开启指定端口上或全局的802.1X特性。undo dot1x命令用来关闭指定端口上或全局的802.1X特性。
缺省情况下,所有端口及全局的802.1X特性都处于关闭状态。
l 在系统视图下,如果不指定参数interface interface-list,则表示开启全局的802.1X特性;如果指定参数interface interface-list,则表示开启指定端口的802.1X特性。
l 在二层以太网端口视图下,不能指定参数interface interface-list,只能打开当前端口的802.1X特性。
l 802.1X特性启动前后,均可以使用配置命令来配置全局或端口的802.1X特性参数。如果在开启全局802.1X特性前没有配置全局或端口的其它802.1X特性参数,则这些参数在运行时均为缺省值。
l 只有同时开启全局和端口的802.1X特性后,802.1X的配置才能在端口上生效。
相关配置可参考命令display dot1x。
# 开启以太网端口Ethernet1/0/1和Ethernet1/0/5到Ethernet1/0/7上的802.1X特性。
[Sysname] dot1x interface ethernet 1/0/1 ethernet 1/0/5 to ethernet 1/0/7
或者
[Sysname-Ethernet1/0/1] dot1x
[Sysname-Ethernet1/0/1] quit
[Sysname] interface ethernet 1/0/5
[Sysname-Ethernet1/0/5] dot1x
[Sysname-Ethernet1/0/5] quit
[Sysname] interface ethernet 1/0/6
[Sysname-Ethernet1/0/6] dot1x
[Sysname-Ethernet1/0/6] quit
[Sysname] interface ethernet 1/0/7
[Sysname-Ethernet1/0/7] dot1x
# 开启全局的802.1X特性。
[Sysname] dot1x
undo dot1x authentication-method
【缺省级别】
2:系统级
chap:采用CHAP认证方式。
eap:采用EAP认证方式。
pap:采用PAP认证方式。
【描述】
dot1x authentication-method命令用来设置802.1X用户的认证方式。undo dot1x authentication-method命令用来恢复802.1X用户的缺省认证方式。
缺省情况下,802.1X用户认证方法为CHAP认证。
l PAP(Password Authentication Protocol,密码验证协议),它采用明文方式传送口令。
l CHAP(Challenge Handshake Authentication Protocol,质询握手验证协议),它只在网络上传输用户名,而并不传输口令。相比之下,CHAP认证保密性较好,更为安全可靠。
l EAP认证功能,意味着设备直接把802.1X用户的认证信息以EAP报文直接封装到RADIUS报文的属性字段中,发送给RADIUS服务器完成认证,而无须将EAP报文转换成标准的RADIUS报文后再发给RADIUS服务器来完成认证。这种情况下,user-name-format命令的设置无效,user-name-format的介绍请参见“安全分册”中的“AAA命令”。
l 本地认证支持PAP和CHAP。
l 采用RADIUS认证方法时,PAP、CHAP、EAP认证功能的最终实现,需要RADIUS服务器支持相应的PAP、CHAP、EAP认证。
# 设置设备对802.1X用户采用PAP认证。
[Sysname] dot1x authentication-method pap
在系统视图下:
dot1x guest-vlan guest-vlan-id [ interface interface-list ]
undo dot1x guest-vlan [ interface interface-list ]
在二层以太网端口视图下:
系统视图/二层以太网端口视图
【缺省级别】
2:系统级
【描述】
dot1x guest-vlan命令用来配置指定端口的Guest VLAN。undo dot1x guest-vlan命令用来取消指定端口的Guest VLAN。
缺省情况下,端口没有配置Guest VLAN。
根据端口的接入控制方式可以将Guest VLAN划分为两类:MAC-based Guest VLAN(简称MGV)和Port-based Guest VLAN(简称PGV)。
l 在系统视图下,如果不指定参数interface-list,则表示配置所有(二层以太网和二层WLAN)端口的Guest VLAN;如果指定参数interface-list,则表示配置指定端口的Guest VLAN。
l 在二层以太网端口视图下,不能指定参数interface-list,只能配置当前端口的Guest VLAN。
l 只有开启802.1X特性的情况下,Guest VLAN才能生效。
l 只有802.1X组播触发功能开启的情况下,PGV才生效。
l 当端口的接入控制方式为portbased时,Guest VLAN才能生效;若端口的接入控制为macbased,Guest VLAN能够配置成功,但不生效。若PGV生效后,将端口的接入控制方式由portbased修改为macbased,则端口会离开Guest VLAN。
l 当接入控制的方式为portbased时,可以指定携带Tag方式的VLAN为Hybrid端口的Guest VLAN,但该Guest VLAN不会生效。同样当Hybrid端口的Guest VLAN生效后,则不能再配置该Guest VLAN为携带Tag方式的VLAN。
l 禁止删除已被配置为Guest VLAN的VLAN,若要删除该VLAN,请先通过命令undo dot1x guest-vlan取消802.1X的Guest VLAN配置。
l Guest VLAN配置与EAD快速部署的Free IP配置dot1x free-ip在端口上互斥。
相关配置可参考命令dot1x、dot1x port-method、dot1x multicast-trigger。
# 配置端口Ethernet1/0/1的Guest VLAN为已经创建的VLAN 999。
[Sysname] dot1x guest-vlan 999 interface ethernet 1/0/1
# 配置端口Ethernet1/0/2~Ethernet1/0/5的Guest VLAN为已经创建的VLAN 10。
[Sysname] dot1x guest-vlan 10 interface ethernet 1/0/2 to ethernet 1/0/5
# 配置所有端口的Guest VLAN为已经创建的VLAN 7。
[Sysname] dot1x guest-vlan 7
# 配置端口Ethernet1/0/7的Guest VLAN为已经创建的VLAN 3。
[Sysname-Ethernet1/0/7] dot1x guest-vlan 3
dot1x handshake
undo dot1x handshake
二层以太网端口视图
【缺省级别】
2:系统级
无
【描述】
dot1x handshake命令用于开启在线用户握手功能,通过设备端定期向客户端发送握手报文来探测用户是否在线。undo dot1x handshake命令用于关闭在线用户握手功能。
缺省情况下,开启在线用户握手功能。
l 802.1X的代理检测功能依赖于在线用户握手功能。在配置代理检测功能之前,必须先开启在线用户握手功能。关闭在线用户握手功能之前,必须先关闭配置代理检测功能。
l 建议在线用户握手功能与H3C 802.1X客户端配合使用,以保证该功能可以正常运行。
# 开启在线用户握手功能。
[Sysname] interface ethernet 1/0/4
[Sysname-Ethernet1/0/4] dot1x handshake
undo dot1x mandatory-domain
二层以太网端口视图
【缺省级别】
2:系统级
domain-name:ISP认证域名,为1~24个字符的字符串,不分区大小写。
【描述】
dot1x mandatory-domain命令用来配置端口上802.1X用户的强制认证域。undo dot1x mandatory-domain命令用来删除该端口上802.1X用户的认证域。
缺省情况下,未定义强制认证域。
l 从指定端口上接入的802.1X用户将按照如下先后顺序选择认证域:端口上配置的强制ISP域-->用户名中指定的ISP域-->系统缺省的ISP域。
l 端口上配置的强制认证域必须已经存在。
l 端口上配置了强制认证域之后,使用display connection命令显示该端口下的用户连接信息时,所显示的用户域名为强制认证域名。关于命令display connection的介绍请参见“安全分册”中的“AAA命令”。
# 在端口Ethernet1/0/1上配置802.1X用户使用强制认证域my-domain。
[Sysname-Ethernet1/0/1] dot1x mandatory-domain my-domain
# 802.1X用户usera通过认证后,查看端口Ethernet1/0/1上的用户连接信息。
[Sysname-Ethernet1/0/1] display connection interface ethernet 1/0/1
Index=68 ,Username=usera@my-domian
MAC=0015-e9a6-7cfe ,IP=3.3.3.3
Total 1 connection(s) matched.
在系统视图下:
dot1x max-user user-number [ interface interface-list ]
undo dot1x max-user [ interface interface-list ]
在二层以太网端口视图下:
undo dot1x max-user
系统视图/二层以太网端口视图
【缺省级别】
2:系统级
user-number:端口同时可容纳接入用户数量的最大值,取值范围为1~256。
【描述】
dot1x max-user命令用来设置802.1X在指定端口上可容纳接入用户数量的最大值。undo dot1x max-user命令用来恢复该值的缺省值。
缺省情况下,端口同时接入用户数量最大值为256。
l 在系统视图下执行该命令可以作用于参数interface-list所指定的端口,如果不指定任何端口则将作用于所有端口。
l 在以太网端口视图下执行该命令时,不能指定参数interface-list,只能作用于当前端口。
# 设置端口Ethernet1/0/1最多可容纳32个接入用户。
[Sysname] dot1x max-user 32 interface ethernet 1/0/1
或者
[Sysname-Ethernet1/0/1] dot1x max-user 32
undo dot1x multicast-trigger
二层以太网端口视图
【缺省级别】
2:系统级
无
【描述】
dot1x multicast-trigger命令用来使能802.1X的组播触发功能,即周期性地向客户端发送组播触发报文。undo dot1x multicast-trigger命令用来关闭802.1X的组播触发功能。
缺省情况下,802.1X的组播触发功能处于开启状态。
# 在端口Ethernet1/0/1下关闭802.1X的组播触发功能。
[Sysname] interface ethernet 1/01
[Sysname-Ethernet1/0/1] undo dot1x multicast-trigger
在系统视图下:
dot1x port-control { authorized-force | auto | unauthorized-force } [ interface interface-list ]
undo dot1x port-control [ interface interface-list ]
在二层以太网端口视图下:
系统视图/二层以太网端口视图
【缺省级别】
2:系统级
authorized-force:强制授权模式。指示端口始终处于授权状态,允许用户不经认证授权即可访问网络资源。
auto:自动识别模式。指示端口初始状态为非授权状态,仅允许EAPOL报文收发,不允许用户访问网络资源;如果认证通过,则端口切换到授权状态,允许用户访问网络资源。这也是最常见的情况。
unauthorized-force:强制非授权模式。指示端口始终处于非授权状态,不允许用户访问网络资源。
【描述】
dot1x port-control命令用来设置802.1X在指定端口上进行接入控制的模式。undo dot1x port-control命令用来恢复缺省的接入控制模式。
缺省情况下,接入控制模式为auto。
# 指定端口Ethernet1/0/1处于强制非授权状态。
[Sysname] dot1x port-control unauthorized-force interface ethernet 1/0/1
或者
[Sysname-Ethernet1/0/1] dot1x port-control unauthorized-force
在系统视图下:
dot1x port-method { macbased | portbased } [ interface interface-list ]
undo dot1x port-method [ interface interface-list ]
在二层以太网端口视图下:
系统视图/二层以太网端口视图
【缺省级别】
2:系统级
macbased:表示基于MAC地址对接入用户进行认证,即该端口下的所有接入用户均需要单独认证,当某个用户下线时,也只有该用户无法使用网络。
portbased:表示基于端口对接入用户进行认证,即只要该端口下的第一个用户认证成功后,其他接入用户无须认证就可使用网络资源,但是当第一个用户下线后,其他用户也会被拒绝使用网络。
【描述】
dot1x port-method命令用来设置802.1X在指定端口上进行接入控制的方式。undo dot1x port-method命令用来恢复缺省的接入控制方式。
缺省情况下,接入控制方式为macbased。
l 在系统视图下执行该命令可以作用于interface-list参数所指定的端口,如果不指定任何端口则将作用于所有端口。
# 在端口Ethernet1/0/1上配置对接入用户进行基于端口的802.1X认证。
[Sysname] dot1x port-method portbased interface ethernet 1/0/1
或者
[Sysname-Ethernet1/0/1] dot1x port-method portbased
dot1x quiet-period
undo dot1x quiet-period
【缺省级别】
2:系统级
无
【描述】
dot1x quiet-period命令用来开启静默定时器功能。undo dot1x quiet-period命令用来关闭该定时器功能。
缺省情况下,静默定时器功能处于关闭状态。
当802.1X用户认证失败以后,设备需要静默一段时间(该时间由静默定时器设置)。在静默期间,设备对该用户不进行802.1X认证的相关处理。
相关配置可参考命令display dot1x和dot1x timer。
# 开启静默定时器。
[Sysname] dot1x quiet-period
dot1x retry max-retry-value
undo dot1x retry
【缺省级别】
2:系统级
max-retry-value:向接入用户发送认证请求报文的最大次数,取值范围为1~10。
【描述】
dot1x retry命令用来设置设备向接入用户发送认证请求报文的最大次数。undo dot1x retry命令用来将该最大发送次数恢复为缺省情况。
缺省情况下,向接入用户发送认证请求报文的最大次数为2。
l 如果设备向用户发送认证请求报文后,在规定的时间里(可通过dot1x timer tx-period tx-period-value或者dot1x timer supp-timeout supp-timeout-value设定)没有收到用户的响应,则设备将根据max-retry-value值决定是否再次向用户发送该认证请求报文。
l 此命令参数max-retry-value取值为1时表示只允许向用户发送一次认证请求报文,如果没有收到响应,不再重复发送;取值为2时表示在首次向用户发送请求又没有收到响应后将重复发送1次;……依次类推。
l 本命令设置后将作用于所有端口。
# 配置设备最多向接入用户发送9次认证请求报文。
[Sysname] dot1x retry 9
在系统视图下:
dot1x supp-proxy-check { logoff | trap } [ interface interface-list ]
undo dot1x supp-proxy-check { logoff | trap } [ interface interface-list ]
在二层以太网端口视图下:
系统视图/二层以太网端口视图
【缺省级别】
2:系统级
logoff:检测到用户使用代理后,切断用户连接。
trap:检测到用户使用代理后,向网管系统发送Trap报文。
【描述】
dot1x supp-proxy-check命令用来设置设备对通过代理登录的用户的检测及接入控制。undo dot1x supp-proxy-check命令用来取消设备对通过代理登录的用户的检测及相关控制的设置。
缺省情况下,设备不对通过代理登录的用户进行检测及接入控制。
l 该功能的实现需要H3C 802.1X客户端程序的配合。
l 在系统视图下执行该命令时,如果不指定参数interface interface-list,则表示开启全局的用户的检测及接入控制;如果指定参数interface interface-list,则表示开启指定端口的用户的检测及接入控制。
l 在以太网端口视图下执行该命令时,不能指定参数interface interface-list,只能打开当前端口的用户的检测及接入控制。
l 必须同时开启全局和指定端口的代理用户检测与控制,此特性的配置才能在该端口上生效。
# 设置端口Ethernet1/0/1~Ethernet1/0/8检测到用户使用代理后,切断该用户的连接。
[Sysname] dot1x supp-proxy-check logoff
[Sysname] dot1x supp-proxy-check logoff interface ethernet 1/0/1 to ethernet 1/0/8
# 设置端口Ethernet1/0/9检测到登录的用户使用代理后,设备发送Trap报文。
[Sysname] dot1x supp-proxy-check trap
[Sysname] dot1x supp-proxy-check trap interface ethernet 1/0/9
或者
[Sysname] interface ethernet 1/0/9
[Sysname-Ethernet1/0/9] dot1x supp-proxy-check trap
dot1x timer { handshake-period handshake-period-value | quiet-period quiet-period-value | server-timeout server-timeout-value | supp-timeout supp-timeout-value | tx-period tx-period-value }
undo dot1x timer { handshake-period | quiet-period | server-timeout | supp-timeout | tx-period }
【缺省级别】
2:系统级
handshake-period-value:握手定时器的值,取值范围为5~1024,单位为秒。
quiet-period-value:静默定时器的值,取值范围为10~120,单位为秒。
server-timeout-value:认证服务器超时定时器的值,取值范围为100~300,单位为秒。
supp-timeout-value:客户端认证超时定时器的值,取值范围为10~120,单位为秒。
tx-period-value:用户名请求超时定时器的值,取值范围为10~120,单位为秒。
【描述】
dot1x timer命令用来配置802.1X的各项定时器参数。undo dot1x timer命令用来将指定的定时器恢复为缺省情况。
缺省情况下,握手定时器的值为15秒,静默定时器的值为60秒,认证服务器超时定时器的值为100秒,客户端认证超时定时器的值为30秒,用户名请求超时定时器的值为30秒。
802.1X认证过程受以下定时器的控制:
l 握手定时器(handshake-period):此定时器是在用户认证成功后启动的,设备端以此间隔为周期发送握手请求报文,以定期检测用户的在线情况。如果配置发送次数为N,则当设备端连续N次没有收到客户端的响应报文,就认为用户已经下线。
l 静默定时器(quiet-period):对用户认证失败以后,设备端需要静默一段时间(该时间由静默定时器设置),在静默期间,设备端不处理该用户的认证功能。
l 认证服务器超时定时器(server-timeout):当设备端向认证服务器发送了RADIUS Access-Request请求报文后,设备端启动server-timeout定时器,若在该定时器设置的时长内,设备端没有收到认证服务器的响应,设备端将重发认证请求报文。
l 客户端认证超时定时器(supp-timeout):当设备端向客户端发送了EAP-Request/MD5 Challenge请求报文后,设备端启动此定时器,若在该定时器设置的时长内,设备端没有收到客户端的响应,设备端将重发该报文。
l 用户名请求超时定时器(tx-period):当设备端向客户端发送EAP-Request/Identity请求报文后,设备端启动该定时器,若在该定时器设置的时长内,设备端没有收到客户端的响应,则设备端将重发认证请求报文。另外,为了兼容不主动发送EAPOL-Start连接请求报文的客户端,设备会定期组播EAP-Request/Identity请求报文来检测客户端。tx-period定义了该组播报文的发送时间间隔。
需要注意的是,一般情况下,用户无需修改定时器的值,除非在一些特殊或恶劣的网络环境下,可以使用该命令调节交互进程。修改后的定时器值,可立即生效。
# 设置认证服务器的超时定时器时长为150秒。
[Sysname] dot1x timer server-timeout 150
reset dot1x statistics [ interface interface-list ]
【缺省级别】
2:系统级
【描述】
reset dot1x statistics命令用来清除802.1X的统计信息。
l 如果不指定端口类型和端口号,则清除设备上的全局及所有端口的802.1X统计信息;
l 如果指定端口类型和端口号,则清除指定端口上的802.1X统计信息。
# 清除以太网端口Ethernet1/0/1上的802.1X统计信息。
<Sysname> reset dot1x statistics interface ethernet 1/0/1
dot1x free-ip ip-address { mask-address | mask-length }
undo dot1x free-ip { ip-address { mask | mask-length } | all }
【缺省级别】
2:系统级
ip-address:免认证网段IP地址。
mask:免认证网段IP地址的掩码。
mask-length:免认证网段IP地址的掩码长度。
all:所有免认证网段。
【描述】
dot1x free-ip命令用来配置Free IP,即用户在802.1X认证成功之前可访问的免认证网段。undo dot1x free-ip命令用来删除配置的Free IP。
缺省情况下,未定义Free IP。
l Free IP功能与全局使能MAC认证或端口安全功能及端口上的Guest VLAN功能互斥;
l Free IP功能只在端口接入控制的模式为auto的情况下生效;
l 目前,免认证网段最多可配置4条。
# 配置终端用户在802.1X认证之前可访问的免认证网段为192.168.0.0/24。
[Sysname] dot1x free-ip 192.168.0.0 24
dot1x timer ead-timeout ead-timeout-value
undo dot1x timer ead-timeout
【缺省级别】
2:系统级
ead-timeout-value:EAD规则的老化超时时间,取值范围为1~1440,单位为分钟。
【描述】
dot1x timer ead-timeout命令用来配置EAD规则的老化超时时间。undo dot1x timer ead-timeout命令用来恢复缺省配置。
缺省情况下,EAD规则的老化超时时间为30分钟。
# 配置EAD规则的老化超时时间为5分钟。
[Sysname] dot1x timer ead-timeout 5
dot1x url url-string
undo dot1x [ url-string ]
【缺省级别】
2:系统级
url-string:重定向URL地址,为1~64个字符的字符串,区分大小写,格式为“http://string”。
【描述】
dot1x url命令用来配置用户HTTP访问的重定向URL,即用户在802.1X认证成功之前,如果使用浏览器访问非Free IP网段的其它网络,设备会将用户访问的URL重定向到已配置的HTTP访问的重定向地址。undo dot1x url命令用来删除用户HTTP访问的重定向URL。
缺省情况下,未定义重定向URL。
l 重定向的URL和Free IP必须在同一个网段内,否则无法访问指定的重定向URL;
l 用户HTTP访问的重定向URL可多次配置,但仅最后配置的一条有效。
相关配置可参考命令display dot1x和dot1x free-ip。
# 配置用户HTTP访问的重定向URL为http://192.168.0.1。
[Sysname] dot1x url http://192.168.0.1
