01-命令总索引
本章节下载: 01-命令总索引 (155.91 KB)
本命令索引包括手册中所出现的全部命令,按字母序排列,左边为命令行,右边为该命令所在的功能模块和页码。
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
abr-summary (OSPF area view) |
IP路由分册-04-OSPF |
1-1 |
abr-summary (OSPFv3 area view) |
IP路由分册-09-OSPFv3 |
1-1 |
access-limit |
安全分册-01-AAA |
1-1 |
access-limit enable |
安全分册-01-AAA |
1-1 |
accounting |
QoS分册-01-QoS |
1-5 |
accounting default |
安全分册-01-AAA |
1-2 |
accounting lan-access |
安全分册-01-AAA |
1-3 |
accounting login |
安全分册-01-AAA |
1-4 |
accounting optional |
安全分册-01-AAA |
1-5 |
accounting-on enable |
安全分册-01-AAA |
2-1 |
accounting-on enable interval |
安全分册-01-AAA |
2-1 |
accounting-on enable send |
安全分册-01-AAA |
2-2 |
acl |
安全分册-11-ACL |
1-3 |
acl |
系统分册-01-登录以太网交换机 |
2-1 |
acl copy |
安全分册-11-ACL |
1-5 |
acl ipv6 |
安全分册-11-ACL |
1-20 |
acl ipv6 copy |
安全分册-11-ACL |
1-21 |
acl ipv6 name |
安全分册-11-ACL |
1-22 |
acl name |
安全分册-11-ACL |
1-6 |
activation-key |
系统分册-01-登录以太网交换机 |
1-1 |
active region-configuration |
接入分册-16-MSTP |
1-1 |
add-member |
系统分册-15-集群管理 |
1-14 |
administrator-address |
系统分册-15-集群管理 |
1-15 |
aggregate |
IP路由分册-06-BGP |
1-1 |
apply as-path |
IP路由分册-12-路由策略 |
1-1 |
apply comm-list delete |
IP路由分册-12-路由策略 |
1-2 |
apply community |
IP路由分册-12-路由策略 |
1-2 |
apply cost |
IP路由分册-12-路由策略 |
1-3 |
apply cost-type |
IP路由分册-12-路由策略 |
1-4 |
apply extcommunity |
IP路由分册-12-路由策略 |
1-5 |
apply ip-address next-hop |
IP路由分册-12-路由策略 |
1-21 |
apply ipv6 next-hop |
IP路由分册-12-路由策略 |
1-26 |
apply isis |
IP路由分册-12-路由策略 |
1-5 |
apply local-preference |
IP路由分册-12-路由策略 |
1-6 |
apply origin |
IP路由分册-12-路由策略 |
1-7 |
apply preference |
IP路由分册-12-路由策略 |
1-7 |
apply preferred-value |
IP路由分册-12-路由策略 |
1-8 |
apply tag |
IP路由分册-12-路由策略 |
1-9 |
area (OSPF view) |
IP路由分册-04-OSPF |
1-2 |
area (OSPFv3 view) |
IP路由分册-09-OSPFv3 |
1-2 |
area-authentication-mode |
IP路由分册-05-IS-IS |
1-1 |
arp check enable |
IP业务分册-02-ARP |
1-1 |
arp detection enable |
IP业务分册-02-ARP |
4-3 |
arp detection mode |
IP业务分册-02-ARP |
4-4 |
arp detection static-bind |
IP业务分册-02-ARP |
4-5 |
arp detection trust |
IP业务分册-02-ARP |
4-5 |
arp detection validate |
IP业务分册-02-ARP |
4-6 |
arp max-learning-num |
IP业务分册-02-ARP |
1-2 |
arp rate-limit |
IP业务分册-02-ARP |
4-3 |
arp source-suppression enable |
IP业务分册-02-ARP |
4-1 |
arp source-suppression limit |
IP业务分册-02-ARP |
4-1 |
arp static |
IP业务分册-02-ARP |
1-2 |
arp timer aging |
IP业务分册-02-ARP |
1-3 |
arp-snooping enable |
IP业务分册-02-ARP |
3-1 |
asbr-summary |
IP路由分册-04-OSPF |
1-2 |
ascii |
系统分册-04-文件系统管理 |
2-5 |
attribute |
安全分册-09-PKI |
1-1 |
authentication default |
安全分册-01-AAA |
1-6 |
authentication lan-access |
安全分册-01-AAA |
1-7 |
authentication login |
安全分册-01-AAA |
1-7 |
authentication super |
安全分册-01-AAA |
1-8 |
IP路由分册-04-OSPF |
1-3 |
系统分册-01-登录以太网交换机 |
1-2 |
authorization command |
安全分册-01-AAA |
1-9 |
authorization default |
安全分册-01-AAA |
1-10 |
authorization lan-access |
安全分册-01-AAA |
1-11 |
authorization login |
安全分册-01-AAA |
1-12 |
authorization-attribute |
安全分册-01-AAA |
1-13 |
auto-build |
系统分册-15-集群管理 |
1-16 |
auto-cost enable |
IP路由分册-05-IS-IS |
1-2 |
auto-execute command |
系统分册-01-登录以太网交换机 |
1-3 |
auto-rp enable |
组播分册-03-PIM |
1-1 |
backup startup-configuration |
系统分册-04-文件系统管理 |
1-13 |
balance (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-2 |
balance (IPv6 address family view) |
IP路由分册-11-IPv6 BGP |
1-1 |
bandwidth-reference |
IP路由分册-09-OSPFv3 |
1-2 |
bandwidth-reference (IS-IS view) |
IP路由分册-05-IS-IS |
1-3 |
bandwidth-reference (OSPF view) |
IP路由分册-04-OSPF |
1-4 |
bestroute as-path-neglect (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-3 |
bestroute as-path-neglect (IPv6 address family view) |
1-2 |
bestroute compare-med (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-4 |
bestroute compare-med (IPv6 address family view) |
1-2 |
bestroute med-confederation (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-4 |
bestroute med-confederation (IPv6 address family view) |
1-3 |
bfd authentication-mode |
IP路由分册-13-BFD |
1-1 |
bfd detect-multiplier |
IP路由分册-13-BFD |
1-2 |
bfd echo-source-ip |
IP路由分册-13-BFD |
1-2 |
bfd min-echo-receive-interval |
IP路由分册-13-BFD |
1-3 |
bfd min-receive-interval |
IP路由分册-13-BFD |
1-4 |
bfd min-transmit-interval |
IP路由分册-13-BFD |
1-4 |
bfd session init-mode |
IP路由分册-13-BFD |
1-5 |
bgp |
IP路由分册-06-BGP |
1-5 |
bims-server |
IP业务分册-03-DHCP |
1-1 |
binary |
系统分册-04-文件系统管理 |
2-6 |
bind-attribute |
安全分册-01-AAA |
1-14 |
black-list add-mac |
系统分册-15-集群管理 |
1-17 |
black-list delete-mac |
系统分册-15-集群管理 |
1-17 |
bootfile-name |
IP业务分册-03-DHCP |
1-2 |
boot-loader |
系统分册-03-设备管理 |
1-1 |
bootrom |
系统分册-03-设备管理 |
1-1 |
bpdu-tunnel dot1q stp |
接入分册-12-BPDU Tunnel |
1-1 |
bpdu-tunnel tunnel-dmac |
1-2 |
broadcast-suppression |
接入分册-01-以太网端口 |
1-14 |
bsr-policy (PIM view) |
组播分册-03-PIM |
1-1 |
build |
系统分册-15-集群管理 |
1-18 |
burst-mode enable |
QoS分册-01-QoS |
8-1 |
burst-traffic |
QoS分册-01-QoS |
6-1 |
bye |
安全分册-08-SSH2.0 |
1-27 |
bye |
系统分册-04-文件系统管理 |
2-6 |
ca identifier |
安全分册-09-PKI |
1-2 |
cache-sa-enable |
组播分册-04-MSDP |
1-1 |
car |
QoS分册-01-QoS |
1-6 |
car name |
QoS分册-01-QoS |
4-1 |
c-bsr (PIM view) |
组播分册-03-PIM |
1-2 |
c-bsr admin-scope |
组播分册-03-PIM |
1-3 |
c-bsr global |
组播分册-03-PIM |
1-3 |
c-bsr group |
组播分册-03-PIM |
1-4 |
c-bsr hash-length (PIM view) |
组播分册-03-PIM |
1-5 |
c-bsr holdtime (PIM view) |
组播分册-03-PIM |
1-5 |
c-bsr interval (PIM view) |
组播分册-03-PIM |
1-6 |
c-bsr priority (PIM view) |
组播分册-03-PIM |
1-7 |
cd |
安全分册-08-SSH2.0 |
1-28 |
cd |
系统分册-04-文件系统管理 |
1-1 |
cd |
系统分册-04-文件系统管理 |
2-7 |
cdup |
安全分册-08-SSH2.0 |
1-28 |
cdup |
系统分册-04-文件系统管理 |
2-8 |
certificate request entity |
安全分册-09-PKI |
1-2 |
certificate request from |
安全分册-09-PKI |
1-3 |
certificate request mode |
安全分册-09-PKI |
1-4 |
certificate request polling |
安全分册-09-PKI |
1-4 |
certificate request url |
安全分册-09-PKI |
1-5 |
cfd cc enable |
接入分册-15-连通错误检测 |
1-1 |
cfd cc interval |
接入分册-15-连通错误检测 |
1-1 |
cfd enable |
接入分册-15-连通错误检测 |
1-2 |
cfd linktrace |
接入分册-15-连通错误检测 |
1-3 |
cfd linktrace auto-detection |
接入分册-15-连通错误检测 |
1-4 |
cfd loopback |
接入分册-15-连通错误检测 |
1-5 |
cfd ma |
接入分册-15-连通错误检测 |
1-6 |
cfd md |
接入分册-15-连通错误检测 |
1-6 |
cfd mep |
接入分册-15-连通错误检测 |
1-7 |
cfd mep enable |
接入分册-15-连通错误检测 |
1-8 |
cfd mip-rule |
接入分册-15-连通错误检测 |
1-9 |
cfd remote-mep |
接入分册-15-连通错误检测 |
1-10 |
cfd service-instance |
接入分册-15-连通错误检测 |
1-10 |
check region-configuration |
接入分册-16-MSTP |
1-1 |
checkzero |
IP路由分册-03-RIP |
1-1 |
checkzero |
IP路由分册-08-RIPng |
1-1 |
ciphersuite |
安全分册-10-SSL |
1-1 |
circuit-cost |
IP路由分册-05-IS-IS |
1-3 |
classifier behavior |
QoS分册-01-QoS |
1-15 |
client-verify enable |
安全分册-10-SSL |
1-1 |
clock datetime |
系统分册-02-系统基本配置 |
1-1 |
clock summer-time one-off |
系统分册-02-系统基本配置 |
1-1 |
clock summer-time repeating |
系统分册-02-系统基本配置 |
1-2 |
clock timezone |
系统分册-02-系统基本配置 |
1-4 |
close |
系统分册-04-文件系统管理 |
2-8 |
close-mode wait |
安全分册-10-SSL |
1-2 |
cluster |
系统分册-15-集群管理 |
1-19 |
cluster enable |
系统分册-15-集群管理 |
1-20 |
cluster switch-to |
系统分册-15-集群管理 |
1-20 |
cluster-local-user |
系统分册-15-集群管理 |
1-21 |
cluster-mac |
系统分册-15-集群管理 |
1-22 |
cluster-mac syn-interval |
系统分册-15-集群管理 |
1-22 |
cluster-snmp-agent community |
系统分册-15-集群管理 |
1-23 |
cluster-snmp-agent group v3 |
系统分册-15-集群管理 |
1-24 |
cluster-snmp-agent mib-view |
系统分册-15-集群管理 |
1-25 |
cluster-snmp-agent usm-user v3 |
系统分册-15-集群管理 |
1-26 |
command-privilege level |
系统分册-02-系统基本配置 |
1-5 |
common-name |
安全分册-09-PKI |
1-6 |
compare-different-as-med (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-6 |
compare-different-as-med (IPv6 address family view) |
1-4 |
confederation id |
IP路由分册-06-BGP |
1-7 |
confederation nonstandard |
IP路由分册-06-BGP |
1-7 |
confederation peer-as |
IP路由分册-06-BGP |
1-8 |
control-vlan |
接入分册-17-RRPP |
1-1 |
copy |
系统分册-04-文件系统管理 |
1-2 |
cost-style |
IP路由分册-05-IS-IS |
1-4 |
country |
安全分册-09-PKI |
1-6 |
crl check |
安全分册-09-PKI |
1-7 |
crl update-period |
安全分册-09-PKI |
1-7 |
crl url |
安全分册-09-PKI |
1-8 |
c-rp (PIM view) |
组播分册-03-PIM |
1-7 |
c-rp advertisement-interval (PIM view) |
组播分册-03-PIM |
1-8 |
c-rp holdtime (PIM view) |
组播分册-03-PIM |
1-9 |
crp-policy (PIM view) |
组播分册-03-PIM |
1-10 |
cut connection |
安全分册-01-AAA |
1-15 |
dampening (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-9 |
dampening (IPv6 address family view) |
1-4 |
databits |
系统分册-01-登录以太网交换机 |
1-4 |
data-fill |
系统分册-12-NQA |
1-1 |
data-flow-format (HWTACACS scheme view) |
安全分册-01-AAA |
3-1 |
data-flow-format (RADIUS scheme view) |
安全分册-01-AAA |
2-3 |
data-size |
系统分册-12-NQA |
1-2 |
debugging |
系统分册-04-文件系统管理 |
2-9 |
debugging |
系统分册-09-系统维护与调试 |
1-8 |
default |
IP路由分册-04-OSPF |
1-5 |
default cost |
IP路由分册-09-OSPFv3 |
1-3 |
default cost (RIP view) |
IP路由分册-03-RIP |
1-2 |
default cost (RIPng view) |
IP路由分册-08-RIPng |
1-2 |
default ipv4-unicast |
IP路由分册-06-BGP |
1-10 |
default local-preference (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-11 |
default local-preference (IPv6 address family view) |
1-5 |
default med (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-11 |
default med (IPv6 address family view) |
1-6 |
default-cost (OSPF area view) |
IP路由分册-04-OSPF |
1-5 |
default-cost (OSPFv3 area view) |
IP路由分册-09-OSPFv3 |
1-4 |
default-route |
IP路由分册-03-RIP |
1-2 |
default-route imported (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-12 |
default-route imported (IPv6 address family view) |
1-6 |
default-route-advertise |
IP路由分册-09-OSPFv3 |
1-4 |
default-route-advertise (IS-IS view) |
IP路由分册-05-IS-IS |
1-5 |
default-route-advertise (OSPF view) |
IP路由分册-04-OSPF |
1-6 |
delete |
安全分册-08-SSH2.0 |
1-29 |
delete |
系统分册-04-文件系统管理 |
1-2 |
delete |
系统分册-04-文件系统管理 |
2-10 |
delete ipv6 static-routes all |
IP路由分册-07-IPv6 静态路由 |
1-1 |
delete static-routes all |
IP路由分册-02-静态路由 |
1-1 |
delete-member |
系统分册-15-集群管理 |
1-27 |
description |
接入分册-01-以太网端口 |
1-1 |
description |
接入分册-02-链路聚合 |
1-1 |
description |
接入分册-09-VLAN |
1-1 |
description |
IP路由分册-14-MCE |
1-1 |
description (any NQA test type view) |
系统分册-12-NQA |
1-2 |
description (for IPv4) |
安全分册-11-ACL |
1-6 |
description (for IPv6) |
安全分册-11-ACL |
1-23 |
description (OSPF/OSPF area view) |
IP路由分册-04-OSPF |
1-7 |
destination |
IP业务分册-09-隧道技术 |
1-1 |
destination ip |
系统分册-12-NQA |
1-3 |
destination port |
系统分册-12-NQA |
1-3 |
dhcp enable |
IP业务分册-03-DHCP |
1-2 |
dhcp relay address-check |
IP业务分册-03-DHCP |
2-1 |
dhcp relay information circuit-id format-type |
IP业务分册-03-DHCP |
2-1 |
dhcp relay information circuit-id string |
IP业务分册-03-DHCP |
2-2 |
dhcp relay information enable |
IP业务分册-03-DHCP |
2-3 |
dhcp relay information format |
IP业务分册-03-DHCP |
2-3 |
dhcp relay information remote-id format-type |
IP业务分册-03-DHCP |
2-4 |
dhcp relay information remote-id string |
IP业务分册-03-DHCP |
2-5 |
dhcp relay information strategy |
IP业务分册-03-DHCP |
2-6 |
dhcp relay release ip |
IP业务分册-03-DHCP |
2-7 |
dhcp relay security static |
IP业务分册-03-DHCP |
2-7 |
dhcp relay security tracker |
IP业务分册-03-DHCP |
2-8 |
dhcp relay server-detect |
IP业务分册-03-DHCP |
2-9 |
dhcp relay server-group |
IP业务分册-03-DHCP |
2-9 |
dhcp relay server-select |
IP业务分册-03-DHCP |
2-10 |
dhcp select relay |
IP业务分册-03-DHCP |
2-11 |
dhcp select server global-pool |
IP业务分册-03-DHCP |
1-3 |
dhcp server detect |
IP业务分册-03-DHCP |
1-3 |
dhcp server forbidden-ip |
IP业务分册-03-DHCP |
1-4 |
dhcp server ip-pool |
IP业务分册-03-DHCP |
1-5 |
dhcp server ping packets |
IP业务分册-03-DHCP |
1-5 |
dhcp server ping timeout |
IP业务分册-03-DHCP |
1-6 |
dhcp server relay information enable |
IP业务分册-03-DHCP |
1-6 |
dhcp-snooping |
IP业务分册-03-DHCP |
4-1 |
dhcp-snooping information circuit-id format-type |
IP业务分册-03-DHCP |
4-2 |
dhcp-snooping information circuit-id string |
IP业务分册-03-DHCP |
4-2 |
dhcp-snooping information enable |
IP业务分册-03-DHCP |
4-3 |
dhcp-snooping information format |
IP业务分册-03-DHCP |
4-4 |
dhcp-snooping information remote-id format-type |
IP业务分册-03-DHCP |
4-4 |
dhcp-snooping information remote-id string |
IP业务分册-03-DHCP |
4-5 |
dhcp-snooping information strategy |
IP业务分册-03-DHCP |
4-6 |
dhcp-snooping trust |
IP业务分册-03-DHCP |
4-7 |
dir |
安全分册-08-SSH2.0 |
1-29 |
dir |
系统分册-04-文件系统管理 |
1-3 |
dir |
系统分册-04-文件系统管理 |
2-10 |
disconnect |
系统分册-04-文件系统管理 |
2-11 |
display acl |
安全分册-11-ACL |
1-7 |
display acl ipv6 |
安全分册-11-ACL |
1-23 |
display arp |
IP业务分册-02-ARP |
1-4 |
display arp detection |
IP业务分册-02-ARP |
4-7 |
display arp detection statistics |
IP业务分册-02-ARP |
4-7 |
display arp ip-address |
IP业务分册-02-ARP |
1-5 |
display arp source-suppression |
IP业务分册-02-ARP |
4-2 |
display arp timer aging |
IP业务分册-02-ARP |
1-6 |
display arp vpn-instance |
IP业务分册-02-ARP |
1-6 |
display arp-snooping |
IP业务分册-02-ARP |
3-1 |
display bfd debugging-switches |
IP路由分册-13-BFD |
1-5 |
display bfd interface |
IP路由分册-13-BFD |
1-6 |
display bfd session |
IP路由分册-13-BFD |
1-7 |
display bgp group |
IP路由分册-06-BGP |
1-13 |
display bgp ipv6 group |
1-7 |
display bgp ipv6 network |
1-8 |
display bgp ipv6 paths |
1-9 |
display bgp ipv6 peer |
1-10 |
display bgp ipv6 routing-table |
1-12 |
display bgp ipv6 routing-table as-path-acl |
1-14 |
display bgp ipv6 routing-table community |
1-14 |
display bgp ipv6 routing-table community-list |
1-15 |
display bgp ipv6 routing-table dampened |
1-16 |
display bgp ipv6 routing-table dampening parameter |
1-17 |
display bgp ipv6 routing-table different-origin-as |
1-18 |
display bgp ipv6 routing-table flap-info |
1-19 |
display bgp ipv6 routing-table peer |
1-20 |
display bgp ipv6 routing-table regular-expression |
1-21 |
display bgp ipv6 routing-table statistic |
1-21 |
display bgp network |
IP路由分册-06-BGP |
1-14 |
display bgp paths |
IP路由分册-06-BGP |
1-15 |
display bgp peer |
IP路由分册-06-BGP |
1-16 |
display bgp routing-table |
IP路由分册-06-BGP |
1-19 |
display bgp routing-table as-path-acl |
IP路由分册-06-BGP |
1-20 |
display bgp routing-table cidr |
IP路由分册-06-BGP |
1-21 |
display bgp routing-table community |
IP路由分册-06-BGP |
1-21 |
display bgp routing-table community-list |
IP路由分册-06-BGP |
1-22 |
display bgp routing-table dampened |
IP路由分册-06-BGP |
1-23 |
display bgp routing-table dampening parameter |
IP路由分册-06-BGP |
1-24 |
display bgp routing-table different-origin-as |
IP路由分册-06-BGP |
1-25 |
display bgp routing-table flap-info |
IP路由分册-06-BGP |
1-25 |
display bgp routing-table label |
IP路由分册-06-BGP |
1-26 |
display bgp routing-table peer |
IP路由分册-06-BGP |
1-27 |
display bgp routing-table regular-expression |
IP路由分册-06-BGP |
1-28 |
display bgp routing-table statistic |
IP路由分册-06-BGP |
1-29 |
display bgp vpnv4 route-distinguisher routing-table |
IP路由分册-14-MCE |
1-10 |
display bgp vpnv4 vpn-instance group |
IP路由分册-14-MCE |
1-2 |
display bgp vpnv4 vpn-instance network |
IP路由分册-14-MCE |
1-3 |
display bgp vpnv4 vpn-instance paths |
IP路由分册-14-MCE |
1-4 |
display bgp vpnv4 vpn-instance peer |
IP路由分册-14-MCE |
1-5 |
display bgp vpnv4 vpn-instance routing-table |
IP路由分册-14-MCE |
1-8 |
display bgp vpnv4 vpn-instance routing-table label |
IP路由分册-14-MCE |
1-10 |
display boot-loader |
系统分册-03-设备管理 |
1-2 |
display bootp client |
IP业务分册-03-DHCP |
5-1 |
display brief interface |
接入分册-01-以太网端口 |
1-2 |
display burst-traffic interface |
QoS分册-01-QoS |
6-2 |
display cfd linktrace-reply |
接入分册-15-连通错误检测 |
1-11 |
display cfd linktrace-reply auto-detection |
接入分册-15-连通错误检测 |
1-12 |
display cfd ma |
接入分册-15-连通错误检测 |
1-13 |
display cfd md |
接入分册-15-连通错误检测 |
1-14 |
display cfd mep |
接入分册-15-连通错误检测 |
1-15 |
display cfd mp |
接入分册-15-连通错误检测 |
1-18 |
display cfd remote-mep |
接入分册-15-连通错误检测 |
1-19 |
display cfd service-instance |
接入分册-15-连通错误检测 |
1-20 |
display cfd status |
接入分册-15-连通错误检测 |
1-21 |
display channel |
系统分册-10-信息中心 |
1-1 |
display clipboard |
系统分册-02-系统基本配置 |
1-6 |
display clock |
系统分册-02-系统基本配置 |
1-7 |
display cluster |
系统分册-15-集群管理 |
1-27 |
display cluster base-topology |
系统分册-15-集群管理 |
1-29 |
display cluster black-list |
系统分册-15-集群管理 |
1-31 |
display cluster candidates |
系统分册-15-集群管理 |
1-31 |
display cluster current-topology |
系统分册-15-集群管理 |
1-32 |
display cluster members |
系统分册-15-集群管理 |
1-34 |
display configure-user |
系统分册-02-系统基本配置 |
1-7 |
display connection |
安全分册-01-AAA |
1-16 |
display cpu-usage |
系统分册-03-设备管理 |
1-3 |
display cpu-usage history |
系统分册-03-设备管理 |
1-4 |
display current-configuration |
系统分册-02-系统基本配置 |
1-8 |
display debugging |
系统分册-09-系统维护与调试 |
1-9 |
display device |
系统分册-03-设备管理 |
1-6 |
display device manuinfo |
系统分册-03-设备管理 |
1-7 |
display dhcp client |
IP业务分册-03-DHCP |
3-1 |
display dhcp relay |
IP业务分册-03-DHCP |
2-11 |
display dhcp relay information |
IP业务分册-03-DHCP |
2-12 |
display dhcp relay security |
IP业务分册-03-DHCP |
2-13 |
display dhcp relay security statistics |
IP业务分册-03-DHCP |
2-14 |
display dhcp relay security tracker |
IP业务分册-03-DHCP |
2-15 |
display dhcp relay server-group |
IP业务分册-03-DHCP |
2-15 |
display dhcp relay statistics |
IP业务分册-03-DHCP |
2-16 |
display dhcp server conflict |
IP业务分册-03-DHCP |
1-7 |
display dhcp server expired |
IP业务分册-03-DHCP |
1-8 |
display dhcp server forbidden-ip |
IP业务分册-03-DHCP |
1-9 |
display dhcp server free-ip |
IP业务分册-03-DHCP |
1-9 |
display dhcp server ip-in-use |
IP业务分册-03-DHCP |
1-10 |
display dhcp server statistics |
IP业务分册-03-DHCP |
1-11 |
display dhcp server tree |
IP业务分册-03-DHCP |
1-12 |
display dhcp-snooping |
IP业务分册-03-DHCP |
4-7 |
display dhcp-snooping information |
IP业务分册-03-DHCP |
4-8 |
display dhcp-snooping packet statistics |
IP业务分册-03-DHCP |
4-10 |
display dhcp-snooping trust |
IP业务分册-03-DHCP |
4-11 |
display diagnostic-information |
系统分册-02-系统基本配置 |
1-9 |
display dldp |
接入分册-05-DLDP |
1-1 |
display dldp statistics |
接入分册-05-DLDP |
1-2 |
display dns domain |
IP业务分册-04-域名解析 |
1-1 |
display dns dynamic-host |
IP业务分册-04-域名解析 |
1-2 |
display dns ipv6 dynamic-host |
IP业务分册-07-IPv6基础 |
1-1 |
display dns ipv6 server |
IP业务分册-07-IPv6基础 |
1-2 |
display dns proxy table |
IP业务分册-04-域名解析 |
1-2 |
display dns server |
IP业务分册-04-域名解析 |
1-3 |
display domain |
安全分册-01-AAA |
1-17 |
display dot1x |
安全分册-02-802.1X |
1-1 |
display fan |
系统分册-03-设备管理 |
1-8 |
display fib |
IP业务分册-05-IP性能优化 |
1-1 |
display fib ip-address |
IP业务分册-05-IP性能优化 |
1-3 |
display flow-template interface |
安全分册-11-ACL |
1-32 |
display flow-template user-defined |
安全分册-11-ACL |
1-32 |
display ftp client configuration |
系统分册-04-文件系统管理 |
2-12 |
display ftp-server |
系统分册-04-文件系统管理 |
2-1 |
display ftp-user |
系统分册-04-文件系统管理 |
2-1 |
display garp statistics |
接入分册-10-GVRP |
1-1 |
display garp timer |
接入分册-10-GVRP |
1-2 |
display gvrp local-vlan interface |
接入分册-10-GVRP |
1-5 |
display gvrp state |
接入分册-10-GVRP |
1-6 |
display gvrp statistics |
接入分册-10-GVRP |
1-7 |
display gvrp status |
接入分册-10-GVRP |
1-8 |
display gvrp vlan-operation interface |
接入分册-10-GVRP |
1-8 |
display habp |
安全分册-03-HABP |
1-1 |
display habp table |
安全分册-03-HABP |
1-1 |
display habp traffic |
安全分册-03-HABP |
1-2 |
display history-command |
系统分册-02-系统基本配置 |
1-10 |
display hotkey |
系统分册-02-系统基本配置 |
1-11 |
display hwtacacs |
安全分册-01-AAA |
3-2 |
display icmp statistics |
IP业务分册-05-IP性能优化 |
1-4 |
display igmp group |
组播分册-02-IGMP |
1-1 |
display igmp group port-info |
组播分册-02-IGMP |
1-2 |
display igmp interface |
组播分册-02-IGMP |
1-3 |
display igmp routing-table |
组播分册-02-IGMP |
1-5 |
display igmp ssm-mapping |
组播分册-02-IGMP |
1-6 |
display igmp ssm-mapping group |
组播分册-02-IGMP |
1-7 |
display igmp-snooping group |
组播分册-05-IGMP Snooping |
1-1 |
display igmp-snooping statistics |
1-2 |
display info-center |
系统分册-10-信息中心 |
1-2 |
display interface |
接入分册-01-以太网端口 |
1-4 |
display interface tunnel |
IP业务分册-09-隧道技术 |
1-2 |
display interface vlan-interface |
接入分册-09-VLAN |
1-2 |
display ip as-path |
IP路由分册-12-路由策略 |
1-9 |
display ip check source |
安全分册-07-IP Source Guard |
1-1 |
display ip community-list |
IP路由分册-12-路由策略 |
1-10 |
display ip extcommunity-list |
IP路由分册-12-路由策略 |
1-11 |
display ip host |
IP业务分册-04-域名解析 |
1-4 |
display ip http |
系统分册-05-HTTP |
1-1 |
display ip https |
系统分册-05-HTTP |
2-1 |
display ip interface |
IP业务分册-01-IP地址 |
1-1 |
display ip interface brief |
IP业务分册-01-IP地址 |
1-3 |
display ip ip-prefix |
IP路由分册-12-路由策略 |
1-21 |
display ip ipv6-prefix |
IP路由分册-12-路由策略 |
1-27 |
display ip routing-table |
IP路由分册-01-IP路由表显示 |
1-1 |
display ip routing-table acl |
IP路由分册-01-IP路由表显示 |
1-5 |
display ip routing-table ip-address |
IP路由分册-01-IP路由表显示 |
1-7 |
display ip routing-table ip-prefix |
IP路由分册-01-IP路由表显示 |
1-9 |
display ip routing-table protocol |
IP路由分册-01-IP路由表显示 |
1-11 |
display ip routing-table statistics |
IP路由分册-01-IP路由表显示 |
1-12 |
display ip routing-table vpn-instance |
IP路由分册-14-MCE |
1-11 |
display ip socket |
IP业务分册-05-IP性能优化 |
1-5 |
display ip statistics |
IP业务分册-05-IP性能优化 |
1-8 |
display ip vpn-instance |
IP路由分册-14-MCE |
1-12 |
display ip-subnet-vlan interface |
接入分册-09-VLAN |
1-23 |
display ip-subnet-vlan vlan |
接入分册-09-VLAN |
1-24 |
display ipv6 fib |
IP业务分册-07-IPv6基础 |
1-3 |
display ipv6 fibcache |
IP业务分册-07-IPv6基础 |
1-4 |
display ipv6 host |
IP业务分册-07-IPv6基础 |
1-4 |
display ipv6 interface |
IP业务分册-07-IPv6基础 |
1-5 |
display ipv6 interface tunnel |
IP业务分册-09-隧道技术 |
1-3 |
display ipv6 neighbors |
IP业务分册-07-IPv6基础 |
1-8 |
display ipv6 neighbors count |
IP业务分册-07-IPv6基础 |
1-10 |
display ipv6 pathmtu |
IP业务分册-07-IPv6基础 |
1-10 |
display ipv6 routing-table |
IP路由分册-01-IP路由表显示 |
1-13 |
display ipv6 routing-table acl |
IP路由分册-01-IP路由表显示 |
1-14 |
display ipv6 routing-table ipv6-address |
IP路由分册-01-IP路由表显示 |
1-14 |
display ipv6 routing-table ipv6-address1 ipv6-address2 |
IP路由分册-01-IP路由表显示 |
1-16 |
display ipv6 routing-table ipv6-prefix |
IP路由分册-01-IP路由表显示 |
1-17 |
display ipv6 routing-table protocol |
IP路由分册-01-IP路由表显示 |
1-17 |
display ipv6 routing-table statistics |
IP路由分册-01-IP路由表显示 |
1-18 |
display ipv6 routing-table verbose |
IP路由分册-01-IP路由表显示 |
1-19 |
display ipv6 socket |
IP业务分册-07-IPv6基础 |
1-11 |
display ipv6 statistics |
IP业务分册-07-IPv6基础 |
1-13 |
display isis brief |
IP路由分册-05-IS-IS |
1-6 |
display isis debug-switches |
IP路由分册-05-IS-IS |
1-7 |
display isis graceful-restart status |
IP路由分册-05-IS-IS |
1-8 |
display isis interface |
IP路由分册-05-IS-IS |
1-9 |
display isis lsdb |
IP路由分册-05-IS-IS |
1-11 |
display isis mesh-group |
IP路由分册-05-IS-IS |
1-13 |
display isis name-table |
IP路由分册-05-IS-IS |
1-14 |
display isis peer |
IP路由分册-05-IS-IS |
1-15 |
display isis route |
IP路由分册-05-IS-IS |
1-18 |
display isis route ipv6 |
IP路由分册-10-IPv6 IS-IS |
1-1 |
display isis spf-log |
IP路由分册-05-IS-IS |
1-20 |
display isis statistics |
IP路由分册-05-IS-IS |
1-22 |
display lacp system-id |
接入分册-02-链路聚合 |
1-2 |
display link-aggregation member-port |
接入分册-02-链路聚合 |
1-2 |
display link-aggregation summary |
接入分册-02-链路聚合 |
1-4 |
display link-aggregation verbose |
接入分册-02-链路聚合 |
1-5 |
display lldp local-information |
接入分册-06-LLDP |
1-1 |
display lldp neighbor-information |
接入分册-06-LLDP |
1-4 |
display lldp statistics |
接入分册-06-LLDP |
1-9 |
display lldp status |
接入分册-06-LLDP |
1-10 |
display lldp tlv-config |
接入分册-06-LLDP |
1-12 |
display local-proxy-arp |
IP业务分册-02-ARP |
2-1 |
display local-user |
安全分册-01-AAA |
1-19 |
display logbuffer |
系统分册-10-信息中心 |
1-4 |
display logbuffer summary |
系统分册-10-信息中心 |
1-5 |
display loopback-detection |
接入分册-01-以太网端口 |
1-15 |
display mac-address |
系统分册-08-MAC地址表管理 |
1-1 |
display mac-address aging-time |
系统分册-08-MAC地址表管理 |
1-2 |
display mac-authentication |
安全分册-04-MAC地址认证 |
1-1 |
display mac-forced-forwarding interface |
IP业务分册-02-ARP |
5-1 |
display mac-forced-forwarding vlan |
IP业务分册-02-ARP |
5-1 |
display memory |
系统分册-03-设备管理 |
1-8 |
display mib-style |
系统分册-06-SNMP |
2-1 |
display mirroring-group |
接入分册-18-端口镜像 |
1-1 |
display mld-snooping group |
组播分册-07-MLD Snooping |
1-1 |
display mld-snooping statistics |
1-2 |
display monitor-link group |
接入分册-08-Monitor Link |
1-1 |
display msdp brief |
组播分册-04-MSDP |
1-1 |
display msdp peer-status |
组播分册-04-MSDP |
1-3 |
display msdp sa-cache |
组播分册-04-MSDP |
1-5 |
display msdp sa-count |
组播分册-04-MSDP |
1-6 |
display multicast boundary |
组播分册-01-组播路由与转发 |
1-1 |
display multicast forwarding-table |
组播分册-01-组播路由与转发 |
1-2 |
display multicast routing-table |
组播分册-01-组播路由与转发 |
1-4 |
display multicast routing-table static |
组播分册-01-组播路由与转发 |
1-5 |
display multicast rpf-info |
组播分册-01-组播路由与转发 |
1-6 |
display multicast-vlan |
组播分册-06-组播VLAN |
1-1 |
display ndp |
系统分册-15-集群管理 |
1-1 |
display nqa |
系统分册-12-NQA |
1-4 |
display nqa server status |
系统分册-12-NQA |
1-27 |
display ntdp |
系统分册-15-集群管理 |
1-7 |
display ntdp device-list |
系统分册-15-集群管理 |
1-8 |
display ntdp single-device |
系统分册-15-集群管理 |
1-9 |
display ntp-service sessions |
系统分册-13-NTP |
1-1 |
display ntp-service status |
系统分册-13-NTP |
1-2 |
display ntp-service trace |
系统分册-13-NTP |
1-3 |
display oam |
接入分册-14-以太网OAM |
1-1 |
display oam configuration |
接入分册-14-以太网OAM |
1-5 |
display oam critical-event |
接入分册-14-以太网OAM |
1-6 |
display oam link-event |
接入分册-14-以太网OAM |
1-7 |
display ospf abr-asbr |
IP路由分册-04-OSPF |
1-8 |
display ospf asbr-summary |
IP路由分册-04-OSPF |
1-9 |
display ospf brief |
IP路由分册-04-OSPF |
1-10 |
display ospf cumulative |
IP路由分册-04-OSPF |
1-13 |
display ospf error |
IP路由分册-04-OSPF |
1-14 |
display ospf interface |
IP路由分册-04-OSPF |
1-16 |
display ospf lsdb |
IP路由分册-04-OSPF |
1-17 |
display ospf nexthop |
IP路由分册-04-OSPF |
1-20 |
display ospf peer |
IP路由分册-04-OSPF |
1-21 |
display ospf peer statistics |
IP路由分册-04-OSPF |
1-23 |
display ospf request-queue |
IP路由分册-04-OSPF |
1-24 |
display ospf retrans-queue |
IP路由分册-04-OSPF |
1-25 |
display ospf routing |
IP路由分册-04-OSPF |
1-26 |
display ospf vlink |
IP路由分册-04-OSPF |
1-27 |
display ospfv3 |
IP路由分册-09-OSPFv3 |
1-6 |
display ospfv3 interface |
IP路由分册-09-OSPFv3 |
1-7 |
display ospfv3 lsdb |
IP路由分册-09-OSPFv3 |
1-9 |
display ospfv3 lsdb statistic |
IP路由分册-09-OSPFv3 |
1-12 |
display ospfv3 next-hop |
IP路由分册-09-OSPFv3 |
1-13 |
display ospfv3 peer |
IP路由分册-09-OSPFv3 |
1-13 |
display ospfv3 peer statistic |
IP路由分册-09-OSPFv3 |
1-15 |
display ospfv3 request-list |
IP路由分册-09-OSPFv3 |
1-16 |
display ospfv3 retrans-list |
IP路由分册-09-OSPFv3 |
1-18 |
display ospfv3 routing |
IP路由分册-09-OSPFv3 |
1-19 |
display ospfv3 statistic |
IP路由分册-09-OSPFv3 |
1-21 |
display ospfv3 topology |
IP路由分册-09-OSPFv3 |
1-22 |
display ospfv3 vlink |
IP路由分册-09-OSPFv3 |
1-23 |
display pim bsr-info |
组播分册-03-PIM |
1-10 |
display pim claimed-route |
组播分册-03-PIM |
1-12 |
display pim control-message counters |
组播分册-03-PIM |
1-13 |
display pim grafts |
组播分册-03-PIM |
1-15 |
display pim interface |
组播分册-03-PIM |
1-15 |
display pim join-prune |
组播分册-03-PIM |
1-17 |
display pim neighbor |
组播分册-03-PIM |
1-18 |
display pim routing-table |
组播分册-03-PIM |
1-20 |
display pim rp-info |
组播分册-03-PIM |
1-22 |
display pki certificate |
安全分册-09-PKI |
1-9 |
display pki certificate access-control-policy |
安全分册-09-PKI |
1-10 |
display pki certificate attribute-group |
安全分册-09-PKI |
1-11 |
display pki crl domain |
安全分册-09-PKI |
1-12 |
display port |
接入分册-09-VLAN |
1-8 |
display port combo |
接入分册-01-以太网端口 |
1-7 |
display port-group manual |
接入分册-01-以太网端口 |
1-16 |
display port-isolate group |
接入分册-03-端口隔离 |
1-1 |
display port-security |
安全分册-06-端口安全 |
1-1 |
display port-security mac-address block |
安全分册-06-端口安全 |
1-3 |
display port-security mac-address security |
安全分册-06-端口安全 |
1-4 |
display power |
系统分册-03-设备管理 |
1-9 |
display protocol-vlan interface |
接入分册-09-VLAN |
1-18 |
display protocol-vlan vlan |
接入分册-09-VLAN |
1-19 |
display proxy-arp |
IP业务分册-02-ARP |
2-1 |
display public-key local |
安全分册-08-SSH2.0 |
1-1 |
display public-key peer |
安全分册-08-SSH2.0 |
1-2 |
display qos car interface |
QoS分册-01-QoS |
3-1 |
display qos car name |
QoS分册-01-QoS |
4-1 |
display qos gts interface |
QoS分册-01-QoS |
3-3 |
display qos map-table |
QoS分册-01-QoS |
2-1 |
display qos policy |
QoS分册-01-QoS |
1-16 |
display qos policy global |
QoS分册-01-QoS |
1-17 |
display qos policy interface |
QoS分册-01-QoS |
1-18 |
display qos trust interface |
QoS分册-01-QoS |
2-4 |
display qos vlan-policy |
QoS分册-01-QoS |
1-19 |
display qos wred interface |
QoS分册-01-QoS |
6-2 |
display qos wrr interface |
QoS分册-01-QoS |
5-1 |
display radius scheme |
安全分册-01-AAA |
2-4 |
display radius statistics |
安全分册-01-AAA |
2-6 |
display reboot-type |
系统分册-03-设备管理 |
1-10 |
display rip |
IP路由分册-03-RIP |
1-3 |
display rip database |
IP路由分册-03-RIP |
1-5 |
display rip interface |
IP路由分册-03-RIP |
1-6 |
display rip route |
IP路由分册-03-RIP |
1-7 |
display ripng |
IP路由分册-08-RIPng |
1-2 |
display ripng database |
IP路由分册-08-RIPng |
1-3 |
display ripng interface |
IP路由分册-08-RIPng |
1-4 |
display ripng route |
IP路由分册-08-RIPng |
1-6 |
display rmon alarm |
系统分册-07-RMON |
1-1 |
display rmon event |
系统分册-07-RMON |
1-2 |
display rmon eventlog |
系统分册-07-RMON |
1-3 |
display rmon history |
系统分册-07-RMON |
1-4 |
display rmon prialarm |
系统分册-07-RMON |
1-6 |
display rmon statistics |
系统分册-07-RMON |
1-7 |
display route-policy |
IP路由分册-12-路由策略 |
1-11 |
display router id |
IP路由分册-01-IP路由表显示 |
1-20 |
display rrpp brief |
接入分册-17-RRPP |
1-2 |
display rrpp ring-group |
接入分册-17-RRPP |
1-3 |
display rrpp statistics |
接入分册-17-RRPP |
1-4 |
display rrpp verbose |
接入分册-17-RRPP |
1-6 |
display saved-configuration |
系统分册-04-文件系统管理 |
1-14 |
display schedule job |
系统分册-03-设备管理 |
1-10 |
display schedule reboot |
系统分册-03-设备管理 |
1-11 |
display service-loopback group |
接入分册-04-业务环回组 |
1-1 |
display sflow |
IP业务分册-10-sFlow |
1-1 |
display sftp client source |
安全分册-08-SSH2.0 |
1-3 |
display smart-link flush |
接入分册-07-Smart Link |
1-1 |
display smart-link group |
1-1 |
display snmp-agent community |
系统分册-06-SNMP |
1-1 |
display snmp-agent group |
系统分册-06-SNMP |
1-2 |
display snmp-agent local-engineid |
系统分册-06-SNMP |
1-3 |
display snmp-agent mib-view |
系统分册-06-SNMP |
1-3 |
display snmp-agent statistics |
系统分册-06-SNMP |
1-5 |
display snmp-agent sys-info |
系统分册-06-SNMP |
1-6 |
display snmp-agent trap queue |
系统分册-06-SNMP |
1-7 |
display snmp-agent trap-list |
系统分册-06-SNMP |
1-8 |
display snmp-agent usm-user |
系统分册-06-SNMP |
1-9 |
display ssh client source |
安全分册-08-SSH2.0 |
1-4 |
display ssh server |
安全分册-08-SSH2.0 |
1-4 |
display ssh server-info |
安全分册-08-SSH2.0 |
1-6 |
display ssh user-information |
安全分册-08-SSH2.0 |
1-7 |
display ssl client-policy |
安全分册-10-SSL |
1-3 |
display ssl server-policy |
安全分册-10-SSL |
1-3 |
display stack |
堆叠管理命令 |
1-1 |
display startup |
系统分册-04-文件系统管理 |
1-16 |
display stop-accounting-buffer |
安全分册-01-AAA |
2-9 |
安全分册-01-AAA |
3-3 |
display storm-constrain |
接入分册-01-以太网端口 |
1-17 |
display stp |
接入分册-16-MSTP |
1-2 |
display stp abnormal-port |
接入分册-16-MSTP |
1-5 |
display stp down-port |
接入分册-16-MSTP |
1-6 |
display stp history |
接入分册-16-MSTP |
1-7 |
display stp ignored-vlan |
接入分册-16-MSTP |
1-8 |
display stp region-configuration |
接入分册-16-MSTP |
1-8 |
display stp root |
接入分册-16-MSTP |
1-9 |
display stp tc |
接入分册-16-MSTP |
1-10 |
display switch-mode |
IP业务分册-08-双协议栈 |
1-1 |
display system-guard |
安全分册-05-System-Guard |
1-1 |
display tcp ipv6 statistics |
IP业务分册-07-IPv6基础 |
1-16 |
display tcp ipv6 status |
IP业务分册-07-IPv6基础 |
1-18 |
display tcp statistics |
IP业务分册-05-IP性能优化 |
1-9 |
display tcp status |
IP业务分册-05-IP性能优化 |
1-12 |
display telnet client configuration |
系统分册-01-登录以太网交换机 |
1-4 |
display tftp client configuration |
系统分册-04-文件系统管理 |
3-1 |
display this |
系统分册-02-系统基本配置 |
1-12 |
display time-range |
安全分册-11-ACL |
1-1 |
display track |
系统分册-11-Track |
1-1 |
display traffic behavior |
QoS分册-01-QoS |
1-7 |
display traffic classifier |
QoS分册-01-QoS |
1-1 |
display transceiver |
系统分册-03-设备管理 |
1-15 |
display transceiver alarm |
系统分册-03-设备管理 |
1-11 |
display transceiver diagnosis |
系统分册-03-设备管理 |
1-14 |
display transceiver manuinfo |
系统分册-03-设备管理 |
1-16 |
display trapbuffer |
系统分册-10-信息中心 |
1-6 |
display udp ipv6 statistics |
IP业务分册-07-IPv6基础 |
1-19 |
display udp statistics |
IP业务分册-05-IP性能优化 |
1-12 |
display udp-helper server |
IP业务分册-06-UDP Helper |
1-1 |
display user-bind |
1-2 |
display user-group |
安全分册-01-AAA |
1-21 |
display user-interface |
系统分册-01-登录以太网交换机 |
1-5 |
display users |
系统分册-01-登录以太网交换机 |
1-6 |
display version |
系统分册-02-系统基本配置 |
1-13 |
display vlan |
接入分册-09-VLAN |
1-3 |
display voice vlan oui |
接入分册-09-VLAN |
2-1 |
display voice vlan state |
接入分册-09-VLAN |
2-2 |
display vrrp |
系统分册-14-VRRP |
1-1 |
display vrrp ipv6 |
系统分册-14-VRRP |
1-12 |
display vrrp ipv6 statistics |
系统分册-14-VRRP |
1-14 |
display vrrp statistics |
系统分册-14-VRRP |
1-3 |
display web users |
系统分册-01-登录以太网交换机 |
1-8 |
dldp authentication-mode |
接入分册-05-DLDP |
1-4 |
dldp delaydown-timer |
接入分册-05-DLDP |
1-5 |
dldp enable |
接入分册-05-DLDP |
1-5 |
dldp interval |
接入分册-05-DLDP |
1-6 |
dldp reset |
接入分册-05-DLDP |
1-7 |
dldp unidirectional-shutdown |
接入分册-05-DLDP |
1-8 |
dldp work-mode |
接入分册-05-DLDP |
1-8 |
dns domain |
IP业务分册-04-域名解析 |
1-5 |
dns proxy enable |
IP业务分册-04-域名解析 |
1-5 |
dns resolve |
IP业务分册-04-域名解析 |
1-6 |
dns server |
IP业务分册-04-域名解析 |
1-6 |
dns server ipv6 |
IP业务分册-07-IPv6基础 |
1-20 |
dns-list |
IP业务分册-03-DHCP |
1-13 |
domain |
安全分册-01-AAA |
1-22 |
domain default enable |
安全分册-01-AAA |
1-22 |
domain ring |
接入分册-17-RRPP |
1-8 |
domain-authentication-mode |
IP路由分册-05-IS-IS |
1-24 |
domain-id |
IP路由分册-14-MCE |
1-13 |
domain-name |
IP业务分册-03-DHCP |
1-14 |
dot1x |
安全分册-02-802.1X |
1-4 |
dot1x authentication-method |
安全分册-02-802.1X |
1-5 |
dot1x free-ip |
安全分册-02-802.1X |
2-1 |
dot1x guest-vlan |
安全分册-02-802.1X |
1-6 |
dot1x handshake |
安全分册-02-802.1X |
1-7 |
dot1x mandatory-domain |
安全分册-02-802.1X |
1-8 |
dot1x max-user |
安全分册-02-802.1X |
1-9 |
dot1x multicast-trigger |
安全分册-02-802.1X |
1-10 |
dot1x port-control |
安全分册-02-802.1X |
1-11 |
dot1x port-method |
安全分册-02-802.1X |
1-12 |
dot1x quiet-period |
安全分册-02-802.1X |
1-13 |
dot1x retry |
安全分册-02-802.1X |
1-13 |
dot1x supp-proxy-check |
安全分册-02-802.1X |
1-14 |
dot1x timer |
安全分册-02-802.1X |
1-15 |
dot1x timer ead-timeout |
安全分册-02-802.1X |
2-1 |
dot1x url |
安全分册-02-802.1X |
2-2 |
duplex |
接入分册-01-以太网端口 |
1-8 |
ebgp-interface-sensitive |
IP路由分册-06-BGP |
1-29 |
enable link-local-signaling |
IP路由分册-04-OSPF |
1-29 |
enable log |
IP路由分册-04-OSPF |
1-29 |
enable log updown |
系统分册-10-信息中心 |
1-7 |
enable out-of-band-resynchronization |
IP路由分册-04-OSPF |
1-30 |
enable snmp trap updown |
接入分册-02-链路聚合 |
1-7 |
系统分册-06-SNMP |
1-10 |
encap-data-enable |
组播分册-04-MSDP |
1-7 |
escape-key |
系统分册-01-登录以太网交换机 |
1-8 |
execute |
系统分册-04-文件系统管理 |
1-4 |
exit |
安全分册-08-SSH2.0 |
1-30 |
expediting enable |
IP业务分册-09-隧道技术 |
1-6 |
expediting subnet |
IP业务分册-09-隧道技术 |
1-7 |
expired |
IP业务分册-03-DHCP |
1-14 |
export route-policy |
IP路由分册-14-MCE |
1-14 |
ext-community-type |
IP路由分册-14-MCE |
1-15 |
fast-leave (IGMP-Snooping view) |
1-3 |
fast-leave (MLD-Snooping view) |
1-3 |
file prompt |
系统分册-04-文件系统管理 |
1-5 |
filename |
系统分册-12-NQA |
1-7 |
filter |
IP路由分册-04-OSPF |
1-30 |
filter |
QoS分册-01-QoS |
1-8 |
filter-policy export |
IP路由分册-08-RIPng |
1-7 |
IP路由分册-14-MCE |
1-16 |
filter-policy export (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-30 |
filter-policy export (IPv6 address family view) |
1-22 |
filter-policy export (IS-IS view) |
IP路由分册-05-IS-IS |
1-25 |
filter-policy export (OSPF view) |
IP路由分册-04-OSPF |
1-31 |
filter-policy export (OSPFv3 view) |
IP路由分册-09-OSPFv3 |
1-24 |
filter-policy export (RIP view) |
IP路由分册-03-RIP |
1-9 |
filter-policy import |
IP路由分册-14-MCE |
1-16 |
filter-policy import (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-31 |
filter-policy import (IPv6 address family view) |
1-23 |
filter-policy import (IS-IS view) |
IP路由分册-05-IS-IS |
1-26 |
filter-policy import (OSPF view) |
IP路由分册-04-OSPF |
1-32 |
filter-policy import (OSPFv3 view) |
IP路由分册-09-OSPFv3 |
1-25 |
filter-policy import (RIP view) |
IP路由分册-03-RIP |
1-10 |
filter-policy import (RIPng view) |
IP路由分册-08-RIPng |
1-8 |
fixdisk |
系统分册-04-文件系统管理 |
1-6 |
flash-flood |
IP路由分册-05-IS-IS |
1-27 |
flow-control |
接入分册-01-以太网端口 |
1-9 |
flow-control |
系统分册-01-登录以太网交换机 |
1-9 |
flow-interval |
接入分册-01-以太网端口 |
1-18 |
flow-template |
安全分册-11-ACL |
1-33 |
flow-template basic |
安全分册-11-ACL |
1-34 |
flow-template extend |
安全分册-11-ACL |
1-37 |
flush enable |
1-3 |
format |
系统分册-04-文件系统管理 |
1-6 |
fqdn |
安全分册-09-PKI |
1-13 |
free ftp user |
系统分册-04-文件系统管理 |
2-2 |
free user-interface |
系统分册-01-登录以太网交换机 |
1-10 |
free web-users |
系统分册-01-登录以太网交换机 |
2-2 |
frequency |
系统分册-12-NQA |
1-8 |
ftp |
系统分册-04-文件系统管理 |
2-12 |
ftp client source |
系统分册-04-文件系统管理 |
2-13 |
ftp ipv6 |
系统分册-04-文件系统管理 |
2-14 |
ftp server acl |
系统分册-04-文件系统管理 |
2-3 |
ftp server enable |
系统分册-04-文件系统管理 |
2-3 |
ftp timeout |
系统分册-04-文件系统管理 |
2-4 |
ftp update |
系统分册-04-文件系统管理 |
2-4 |
ftp-server |
系统分册-15-集群管理 |
1-36 |
garp timer |
接入分册-10-GVRP |
1-3 |
garp timer leaveall |
接入分册-10-GVRP |
1-4 |
gateway-list |
IP业务分册-03-DHCP |
1-15 |
get |
安全分册-08-SSH2.0 |
1-31 |
get |
系统分册-04-文件系统管理 |
2-15 |
graceful-restart (BGP view) |
IP路由分册-06-BGP |
1-32 |
graceful-restart (IS-IS view) |
IP路由分册-05-IS-IS |
1-27 |
graceful-restart (OSPF view) |
IP路由分册-04-OSPF |
1-33 |
graceful-restart help |
IP路由分册-04-OSPF |
1-34 |
graceful-restart interval (IS-IS view) |
IP路由分册-05-IS-IS |
1-28 |
graceful-restart interval (OSPF view) |
IP路由分册-04-OSPF |
1-35 |
graceful-restart suppress-sa |
IP路由分册-05-IS-IS |
1-28 |
graceful-restart timer restart |
IP路由分册-06-BGP |
1-32 |
graceful-restart timer wait-for-rib |
IP路由分册-06-BGP |
1-33 |
gratuitous-arp-learning enable |
IP业务分册-02-ARP |
1-8 |
gratuitous-arp-sending enable |
IP业务分册-02-ARP |
1-8 |
group |
安全分册-01-AAA |
1-23 |
group (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-34 |
group (IPv6 address family view) |
1-23 |
group-member |
接入分册-01-以太网端口 |
1-18 |
group-policy (IGMP-Snooping view) |
1-4 |
group-policy (MLD-Snooping view) |
1-4 |
gvrp |
接入分册-10-GVRP |
1-9 |
gvrp registration |
接入分册-10-GVRP |
1-10 |
habp enable |
安全分册-03-HABP |
1-3 |
habp server vlan |
安全分册-03-HABP |
1-3 |
habp timer |
安全分册-03-HABP |
1-4 |
handshake timeout |
安全分册-10-SSL |
1-5 |
header |
系统分册-02-系统基本配置 |
1-13 |
hello-option dr-priority (PIM view) |
组播分册-03-PIM |
1-23 |
hello-option holdtime (PIM view) |
组播分册-03-PIM |
1-24 |
hello-option lan-delay (PIM view) |
组播分册-03-PIM |
1-24 |
hello-option neighbor-tracking (PIM view) |
组播分册-03-PIM |
1-25 |
hello-option override-interval (PIM view) |
组播分册-03-PIM |
1-26 |
help |
安全分册-08-SSH2.0 |
1-31 |
history-command max-size |
系统分册-01-登录以太网交换机 |
1-11 |
history-records |
系统分册-12-NQA |
1-9 |
holdtime |
系统分册-15-集群管理 |
1-37 |
holdtime assert (PIM view) |
组播分册-03-PIM |
1-26 |
holdtime join-prune (PIM view) |
组播分册-03-PIM |
1-27 |
host-advertise |
IP路由分册-04-OSPF |
1-35 |
host-aging-time (IGMP-Snooping view) |
1-5 |
host-aging-time (MLD-Snooping view) |
1-5 |
host-route |
IP路由分册-03-RIP |
1-11 |
hotkey |
系统分册-02-系统基本配置 |
1-15 |
http-version |
系统分册-12-NQA |
1-9 |
hwtacacs nas-ip |
安全分册-01-AAA |
3-4 |
hwtacacs scheme |
安全分册-01-AAA |
3-5 |
idle-cut enable |
安全分册-01-AAA |
1-24 |
idle-timeout |
系统分册-01-登录以太网交换机 |
1-11 |
if-match |
QoS分册-01-QoS |
1-2 |
if-match acl |
IP路由分册-12-路由策略 |
1-22 |
if-match as-path |
IP路由分册-12-路由策略 |
1-12 |
if-match community |
IP路由分册-12-路由策略 |
1-13 |
if-match cost |
IP路由分册-12-路由策略 |
1-13 |
if-match extcommunity |
IP路由分册-12-路由策略 |
1-14 |
if-match interface |
IP路由分册-12-路由策略 |
1-15 |
if-match ip |
IP路由分册-12-路由策略 |
1-23 |
if-match ip-prefix |
IP路由分册-12-路由策略 |
1-24 |
if-match ipv6 |
IP路由分册-12-路由策略 |
1-27 |
if-match route-type |
IP路由分册-12-路由策略 |
1-15 |
if-match tag |
IP路由分册-12-路由策略 |
1-16 |
igmp |
组播分册-02-IGMP |
1-8 |
igmp enable |
组播分册-02-IGMP |
1-9 |
igmp group-policy |
组播分册-02-IGMP |
1-9 |
igmp last-member-query-interval |
组播分册-02-IGMP |
1-10 |
igmp max-response-time |
组播分册-02-IGMP |
1-11 |
igmp require-router-alert |
组播分册-02-IGMP |
1-11 |
igmp robust-count |
组播分册-02-IGMP |
1-12 |
igmp send-router-alert |
组播分册-02-IGMP |
1-13 |
igmp ssm-mapping enable |
组播分册-02-IGMP |
1-13 |
igmp startup-query-count |
组播分册-02-IGMP |
1-14 |
igmp startup-query-interval |
组播分册-02-IGMP |
1-14 |
igmp static-group |
组播分册-02-IGMP |
1-15 |
igmp timer other-querier-present |
组播分册-02-IGMP |
1-16 |
igmp timer query |
组播分册-02-IGMP |
1-17 |
igmp version |
组播分册-02-IGMP |
1-17 |
igmp-snooping |
1-6 |
igmp-snooping drop-unknown |
1-6 |
igmp-snooping enable |
1-7 |
igmp-snooping fast-leave |
1-8 |
igmp-snooping general-query source-ip |
1-9 |
igmp-snooping group-limit |
1-9 |
igmp-snooping group-policy |
1-10 |
igmp-snooping host-aging-time |
1-11 |
igmp-snooping host-join |
1-12 |
igmp-snooping last-member-query-interval |
1-13 |
igmp-snooping max-response-time |
1-14 |
igmp-snooping overflow-replace |
1-14 |
igmp-snooping querier |
1-15 |
igmp-snooping query-interval |
1-16 |
igmp-snooping router-aging-time |
1-17 |
igmp-snooping special-query source-ip |
1-17 |
igmp-snooping static-group |
1-18 |
igmp-snooping static-router-port |
1-19 |
igmp-snooping version |
1-20 |
import |
QoS分册-01-QoS |
2-2 |
import route-policy |
IP路由分册-14-MCE |
1-17 |
import-route |
IP路由分册-08-RIPng |
1-8 |
import-route (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-34 |
import-route (IPv6 address family view) |
1-24 |
import-route (IS-IS view) |
IP路由分册-05-IS-IS |
1-29 |
import-route (OSPF view) |
IP路由分册-04-OSPF |
1-36 |
import-route (OSPFv3 view) |
IP路由分册-09-OSPFv3 |
1-26 |
import-route (RIP view) |
IP路由分册-03-RIP |
1-11 |
import-route isis level-2 into level-1 |
IP路由分册-05-IS-IS |
1-30 |
import-route limit (IS-IS view) |
IP路由分册-05-IS-IS |
1-31 |
import-source |
组播分册-04-MSDP |
1-8 |
info-center channel name |
系统分册-10-信息中心 |
1-8 |
info-center console channel |
系统分册-10-信息中心 |
1-8 |
info-center enable |
系统分册-10-信息中心 |
1-9 |
info-center logbuffer |
系统分册-10-信息中心 |
1-10 |
info-center loghost |
系统分册-10-信息中心 |
1-10 |
info-center loghost source |
系统分册-10-信息中心 |
1-11 |
info-center monitor channel |
系统分册-10-信息中心 |
1-12 |
info-center snmp channel |
系统分册-10-信息中心 |
1-13 |
info-center source |
系统分册-10-信息中心 |
1-14 |
info-center synchronous |
系统分册-10-信息中心 |
1-16 |
info-center timestamp |
系统分册-10-信息中心 |
1-17 |
info-center timestamp loghost |
系统分册-10-信息中心 |
1-18 |
info-center trapbuffer |
系统分册-10-信息中心 |
1-19 |
instance |
接入分册-16-MSTP |
1-11 |
interface |
接入分册-01-以太网端口 |
1-10 |
interface bridge-aggregation |
接入分册-02-链路聚合 |
1-8 |
interface tunnel |
IP业务分册-09-隧道技术 |
1-8 |
接入分册-09-VLAN |
1-4 |
ip (Pki Entity view) |
安全分册-09-PKI |
1-14 |
ip address |
接入分册-09-VLAN |
1-5 |
ip address |
IP业务分册-01-IP地址 |
1-4 |
ip address bootp-alloc |
IP业务分册-03-DHCP |
5-2 |
ip address dhcp-alloc |
IP业务分册-03-DHCP |
3-3 |
ip as-path |
IP路由分册-12-路由策略 |
1-17 |
ip binding vpn-instance |
IP路由分册-14-MCE |
1-18 |
ip check source |
1-3 |
ip community-list |
IP路由分册-12-路由策略 |
1-18 |
IP路由分册-12-路由策略 |
1-19 |
ip forward-broadcast (Interface view) |
IP业务分册-05-IP性能优化 |
1-13 |
ip forward-broadcast (System view) |
IP业务分册-05-IP性能优化 |
1-14 |
ip host |
IP业务分册-04-域名解析 |
1-7 |
ip http acl |
系统分册-01-登录以太网交换机 |
2-2 |
ip http acl |
系统分册-05-HTTP |
1-1 |
ip http enable |
系统分册-01-登录以太网交换机 |
1-12 |
ip http enable |
系统分册-05-HTTP |
1-2 |
ip https acl |
系统分册-05-HTTP |
2-1 |
ip https certificate access-control-policy |
系统分册-05-HTTP |
2-2 |
ip https enable |
系统分册-05-HTTP |
2-3 |
ip https ssl-server-policy |
系统分册-05-HTTP |
2-3 |
ip ip-prefix |
IP路由分册-12-路由策略 |
1-24 |
ip ipv6-prefix |
IP路由分册-12-路由策略 |
1-28 |
ip redirects enable |
IP业务分册-05-IP性能优化 |
1-15 |
ip route-static |
IP路由分册-02-静态路由 |
1-2 |
ip route-static default-preference |
IP路由分册-02-静态路由 |
1-4 |
ip rpf-route-static |
组播分册-01-组播路由与转发 |
1-7 |
ip ttl-expires enable |
IP业务分册-05-IP性能优化 |
1-15 |
ip unreachables enable |
IP业务分册-05-IP性能优化 |
1-16 |
ip vpn-instance |
IP路由分册-14-MCE |
1-18 |
ip-pool |
系统分册-15-集群管理 |
1-38 |
ip-subnet-vlan |
接入分册-09-VLAN |
1-25 |
ipv4-family vpn-instance |
IP路由分册-14-MCE |
1-19 |
ipv6 |
IP业务分册-07-IPv6基础 |
1-20 |
ipv6 address |
IP业务分册-07-IPv6基础 |
1-21 |
ipv6 address auto link-local |
IP业务分册-07-IPv6基础 |
1-22 |
ipv6 address eui-64 |
IP业务分册-07-IPv6基础 |
1-23 |
ipv6 address link-local |
IP业务分册-07-IPv6基础 |
1-23 |
ipv6 default-route-advertise |
1-4 |
ipv6 enable |
1-5 |
ipv6 fibcache |
IP业务分册-07-IPv6基础 |
1-24 |
ipv6 fib-loadbalance-type hash-based |
IP业务分册-07-IPv6基础 |
1-24 |
ipv6 filter-policy export |
1-5 |
ipv6 filter-policy import |
1-6 |
ipv6 hoplimit-expires enable |
IP业务分册-07-IPv6基础 |
1-25 |
ipv6 host |
IP业务分册-07-IPv6基础 |
1-26 |
ipv6 icmp-error |
IP业务分册-07-IPv6基础 |
1-26 |
ipv6 icmpv6 multicast-echo-reply enable |
IP业务分册-07-IPv6基础 |
1-27 |
ipv6 import-route |
1-7 |
ipv6 import-route isisv6 level-2 into level-1 |
1-8 |
ipv6 import-route limit |
1-9 |
ipv6 maximum load-balancing |
1-9 |
ipv6 nd autoconfig managed-address-flag |
IP业务分册-07-IPv6基础 |
1-27 |
ipv6 nd autoconfig other-flag |
IP业务分册-07-IPv6基础 |
1-28 |
ipv6 nd dad attempts |
IP业务分册-07-IPv6基础 |
1-29 |
ipv6 nd hop-limit |
IP业务分册-07-IPv6基础 |
1-29 |
ipv6 nd ns retrans-timer |
IP业务分册-07-IPv6基础 |
1-30 |
ipv6 nd nud reachable-time |
IP业务分册-07-IPv6基础 |
1-30 |
ipv6 nd ra halt |
IP业务分册-07-IPv6基础 |
1-31 |
ipv6 nd ra interval |
IP业务分册-07-IPv6基础 |
1-32 |
ipv6 nd ra prefix |
IP业务分册-07-IPv6基础 |
1-32 |
ipv6 nd ra router-lifetime |
IP业务分册-07-IPv6基础 |
1-33 |
ipv6 neighbor |
IP业务分册-07-IPv6基础 |
1-34 |
ipv6 neighbors max-learning-num |
IP业务分册-07-IPv6基础 |
1-35 |
ipv6 pathmtu |
IP业务分册-07-IPv6基础 |
1-35 |
ipv6 pathmtu age |
IP业务分册-07-IPv6基础 |
1-36 |
ipv6 preference |
1-10 |
ipv6 route-static |
1-1 |
ipv6 summary |
1-11 |
ipv6-family |
1-25 |
isis |
IP路由分册-05-IS-IS |
1-32 |
isis authentication-mode |
IP路由分册-05-IS-IS |
1-33 |
isis circuit-level |
IP路由分册-05-IS-IS |
1-34 |
isis circuit-type p2p |
IP路由分册-05-IS-IS |
1-35 |
isis cost |
IP路由分册-05-IS-IS |
1-35 |
isis dis-name |
IP路由分册-05-IS-IS |
1-36 |
isis dis-priority |
IP路由分册-05-IS-IS |
1-37 |
isis enable |
IP路由分册-05-IS-IS |
1-38 |
isis ipv6 enable |
1-11 |
isis mesh-group |
IP路由分册-05-IS-IS |
1-38 |
isis mib-binding |
IP路由分册-05-IS-IS |
1-39 |
isis silent |
IP路由分册-05-IS-IS |
1-40 |
isis small-hello |
IP路由分册-05-IS-IS |
1-41 |
isis timer csnp |
IP路由分册-05-IS-IS |
1-41 |
isis timer hello |
IP路由分册-05-IS-IS |
1-42 |
isis timer holding-multiplier |
IP路由分册-05-IS-IS |
1-43 |
isis timer lsp |
IP路由分册-05-IS-IS |
1-44 |
isis timer retransmit |
IP路由分册-05-IS-IS |
1-45 |
is-level |
IP路由分册-05-IS-IS |
1-45 |
is-name |
IP路由分册-05-IS-IS |
1-46 |
is-name map |
IP路由分册-05-IS-IS |
1-47 |
is-snmp-traps enable |
IP路由分册-05-IS-IS |
1-47 |
jp-pkt-size (PIM view) |
组播分册-03-PIM |
1-27 |
jp-queue-size (PIM view) |
组播分册-03-PIM |
1-28 |
jumboframe enable |
接入分册-01-以太网端口 |
1-19 |
key (HWTACACS scheme view) |
安全分册-01-AAA |
3-5 |
key (RADIUS scheme view) |
安全分册-01-AAA |
2-10 |
lacp port-priority |
接入分册-02-链路聚合 |
1-8 |
lacp system-priority |
接入分册-02-链路聚合 |
1-9 |
last-listener-query-interval (MLD-Snooping view) |
1-5 |
last-member-query-interval (IGMP view) |
组播分册-02-IGMP |
1-18 |
last-member-query-interval (IGMP-Snooping view) |
1-21 |
lcd |
系统分册-04-文件系统管理 |
2-16 |
ldap-server |
安全分册-09-PKI |
1-14 |
link-aggregation mode |
接入分册-02-链路聚合 |
1-10 |
link-delay |
接入分册-01-以太网端口 |
1-10 |
lldp admin-status |
接入分册-06-LLDP |
1-14 |
lldp check-change-interval |
接入分册-06-LLDP |
1-14 |
lldp compliance admin-status cdp |
接入分册-06-LLDP |
1-15 |
lldp compliance cdp |
接入分册-06-LLDP |
1-16 |
lldp enable |
接入分册-06-LLDP |
1-16 |
lldp encapsulation snap |
接入分册-06-LLDP |
1-17 |
lldp fast-count |
接入分册-06-LLDP |
1-17 |
lldp hold-multiplier |
接入分册-06-LLDP |
1-18 |
lldp management-address-format string |
接入分册-06-LLDP |
1-19 |
lldp management-address-tlv |
接入分册-06-LLDP |
1-19 |
lldp notification remote-change enable |
接入分册-06-LLDP |
1-20 |
lldp timer notification-interval |
接入分册-06-LLDP |
1-20 |
lldp timer reinit-delay |
接入分册-06-LLDP |
1-21 |
lldp timer tx-delay |
接入分册-06-LLDP |
1-21 |
lldp timer tx-interval |
接入分册-06-LLDP |
1-22 |
lldp tlv-enable |
接入分册-06-LLDP |
1-23 |
locality |
安全分册-09-PKI |
1-15 |
local-proxy-arp enable |
IP业务分册-02-ARP |
2-2 |
local-user |
安全分册-01-AAA |
1-24 |
local-user password-display-mode |
安全分册-01-AAA |
1-25 |
lock |
系统分册-01-登录以太网交换机 |
1-13 |
logging-host |
系统分册-15-集群管理 |
1-39 |
log-peer-change |
IP路由分册-04-OSPF |
1-37 |
log-peer-change |
IP路由分册-06-BGP |
1-35 |
log-peer-change |
IP路由分册-09-OSPFv3 |
1-27 |
log-peer-change (IS-IS view) |
IP路由分册-05-IS-IS |
1-48 |
loopback |
接入分册-01-以太网端口 |
1-20 |
loopback-detection control enable |
接入分册-01-以太网端口 |
1-20 |
loopback-detection enable |
接入分册-01-以太网端口 |
1-21 |
loopback-detection interval-time |
接入分册-01-以太网端口 |
1-22 |
loopback-detection per-vlan enable |
接入分册-01-以太网端口 |
1-23 |
ls |
安全分册-08-SSH2.0 |
1-32 |
ls |
系统分册-04-文件系统管理 |
2-16 |
lsa-arrival-interval |
IP路由分册-04-OSPF |
1-38 |
lsa-generation-interval |
IP路由分册-04-OSPF |
1-39 |
lsdb-overflow-limit |
IP路由分册-04-OSPF |
1-39 |
lsp-fragments-extend |
IP路由分册-05-IS-IS |
1-48 |
lsp-length originate |
IP路由分册-05-IS-IS |
1-49 |
lsp-length receive |
IP路由分册-05-IS-IS |
1-50 |
mac-address |
接入分册-01-以太网端口 |
1-23 |
mac-address (Interface view) |
系统分册-08-MAC地址表管理 |
1-2 |
mac-address (system view) |
系统分册-08-MAC地址表管理 |
1-3 |
mac-address max-mac-count (Interface view) |
系统分册-08-MAC地址表管理 |
1-4 |
mac-address timer |
系统分册-08-MAC地址表管理 |
1-5 |
安全分册-04-MAC地址认证 |
1-2 |
mac-authentication domain |
安全分册-04-MAC地址认证 |
1-4 |
mac-authentication timer |
安全分册-04-MAC地址认证 |
1-4 |
mac-authentication user-name-format |
安全分册-04-MAC地址认证 |
1-5 |
mac-forced-forwarding |
IP业务分册-02-ARP |
5-2 |
mac-forced-forwarding gateway probe |
IP业务分册-02-ARP |
5-3 |
mac-forced-forwarding network-port |
IP业务分册-02-ARP |
5-4 |
mac-forced-forwarding server |
IP业务分册-02-ARP |
5-4 |
mac-mirroring |
接入分册-11-QinQ |
1-1 |
mac-mirroring src-vlan dest-vlan |
系统分册-08-MAC地址表管理 |
1-6 |
management-vlan |
系统分册-15-集群管理 |
1-39 |
management-vlan synchronization enable |
系统分册-15-集群管理 |
1-40 |
maximum load-balancing (IS-IS view) |
IP路由分册-05-IS-IS |
1-51 |
maximum load-balancing (OSPF view) |
IP路由分册-04-OSPF |
1-40 |
maximum load-balancing (OSPFv3 view) |
IP路由分册-09-OSPFv3 |
1-27 |
maximum load-balancing (RIP view) |
IP路由分册-03-RIP |
1-13 |
maximum load-balancing (RIPng view) |
IP路由分册-08-RIPng |
1-9 |
maximum-routes |
IP路由分册-04-OSPF |
1-41 |
max-response-time (IGMP view) |
组播分册-02-IGMP |
1-18 |
max-response-time (IGMP-Snooping view) |
1-21 |
max-response-time (MLD-Snooping view) |
1-6 |
mdi |
接入分册-01-以太网端口 |
1-24 |
mib-style |
系统分册-06-SNMP |
2-1 |
mirroring-group |
接入分册-18-端口镜像 |
1-2 |
mirroring-group mirroring-port |
接入分册-18-端口镜像 |
1-3 |
mirroring-group monitor-port |
接入分册-18-端口镜像 |
1-4 |
mirroring-group reflector-port |
接入分册-18-端口镜像 |
1-5 |
mirroring-group remote-probe vlan |
接入分册-18-端口镜像 |
1-6 |
mirroring-port |
接入分册-18-端口镜像 |
1-7 |
mirror-to cpu |
QoS分册-01-QoS |
7-1 |
mirror-to interface |
QoS分册-01-QoS |
7-1 |
mkdir |
安全分册-08-SSH2.0 |
1-32 |
mkdir |
系统分册-04-文件系统管理 |
1-7 |
mkdir |
系统分册-04-文件系统管理 |
2-18 |
mld-snooping |
1-7 |
mld-snooping drop-unknown |
1-7 |
mld-snooping enable |
1-8 |
mld-snooping fast-leave |
1-9 |
mld-snooping general-query source-ip |
1-9 |
mld-snooping group-limit |
1-10 |
mld-snooping group-policy |
1-11 |
mld-snooping host-aging-time |
1-12 |
mld-snooping host-join |
1-13 |
mld-snooping last-listener-query-interval |
1-14 |
mld-snooping max-response-time |
1-14 |
mld-snooping overflow-replace |
1-15 |
mld-snooping querier |
1-16 |
mld-snooping query-interval |
1-17 |
mld-snooping router-aging-time |
1-17 |
mld-snooping special-query source-ip |
1-18 |
mld-snooping static-group |
1-19 |
mld-snooping static-router-port |
1-20 |
mld-snooping version |
1-20 |
1-2 |
monitor-port |
接入分册-18-端口镜像 |
1-8 |
more |
系统分册-04-文件系统管理 |
1-7 |
move |
系统分册-04-文件系统管理 |
1-8 |
msdp |
组播分册-04-MSDP |
1-9 |
mtracert |
组播分册-01-组播路由与转发 |
1-9 |
mtu |
接入分册-01-以太网端口 |
1-33 |
组播分册-01-组播路由与转发 |
1-10 |
multicast forwarding-table downstream-limit |
组播分册-01-组播路由与转发 |
1-11 |
multicast forwarding-table route-limit |
组播分册-01-组播路由与转发 |
1-11 |
multicast load-splitting |
组播分册-01-组播路由与转发 |
1-12 |
multicast longest-match |
组播分册-01-组播路由与转发 |
1-13 |
multicast routing-enable |
组播分册-01-组播路由与转发 |
1-13 |
multicast-suppression |
接入分册-01-以太网端口 |
1-25 |
multicast-vlan |
组播分册-06-组播VLAN |
1-2 |
name |
接入分册-09-VLAN |
1-6 |
nas-ip (HWTACACS scheme view) |
安全分册-01-AAA |
3-6 |
nas-ip (RADIUS scheme view) |
安全分册-01-AAA |
2-11 |
nbns-list |
IP业务分册-03-DHCP |
1-16 |
ndp enable |
系统分册-15-集群管理 |
1-4 |
ndp timer aging |
系统分册-15-集群管理 |
1-5 |
ndp timer hello |
系统分册-15-集群管理 |
1-6 |
nest |
QoS分册-01-QoS |
1-8 |
netbios-type |
IP业务分册-03-DHCP |
1-17 |
network |
IP业务分册-03-DHCP |
1-17 |
network |
IP路由分册-03-RIP |
1-13 |
network (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-36 |
network (IPv6 address family view) |
1-25 |
network (OSPF area view) |
IP路由分册-04-OSPF |
1-41 |
network short-cut(BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-37 |
network-entity |
IP路由分册-05-IS-IS |
1-51 |
next-hop |
系统分册-12-NQA |
1-10 |
nm-interface vlan-interface |
系统分册-15-集群管理 |
1-41 |
nqa |
系统分册-12-NQA |
1-10 |
nqa agent enable |
系统分册-12-NQA |
1-11 |
nqa agent max-concurrent |
系统分册-12-NQA |
1-12 |
nqa schedule |
系统分册-12-NQA |
1-12 |
nqa server enable |
系统分册-12-NQA |
1-28 |
nqa server tcp-connect |
系统分册-12-NQA |
1-29 |
nqa server udp-echo |
系统分册-12-NQA |
1-29 |
nssa |
IP路由分册-04-OSPF |
1-42 |
ntdp enable |
系统分册-15-集群管理 |
1-11 |
ntdp explore |
系统分册-15-集群管理 |
1-12 |
ntdp hop |
系统分册-15-集群管理 |
1-12 |
ntdp timer |
系统分册-15-集群管理 |
1-13 |
ntdp timer hop-delay |
系统分册-15-集群管理 |
1-13 |
ntdp timer port-delay |
系统分册-15-集群管理 |
1-14 |
ntp-service access |
系统分册-13-NTP |
1-4 |
ntp-service authentication enable |
系统分册-13-NTP |
1-5 |
ntp-service authentication-keyid |
系统分册-13-NTP |
1-6 |
ntp-service broadcast-client |
系统分册-13-NTP |
1-7 |
ntp-service broadcast-server |
系统分册-13-NTP |
1-7 |
ntp-service in-interface disable |
系统分册-13-NTP |
1-8 |
ntp-service max-dynamic-sessions |
系统分册-13-NTP |
1-8 |
ntp-service multicast-client |
系统分册-13-NTP |
1-9 |
ntp-service multicast-server |
系统分册-13-NTP |
1-10 |
ntp-service reliable authentication-keyid |
系统分册-13-NTP |
1-10 |
ntp-service source-interface |
系统分册-13-NTP |
1-11 |
ntp-service unicast-peer |
系统分册-13-NTP |
1-12 |
ntp-service unicast-server |
系统分册-13-NTP |
1-13 |
oam enable |
接入分册-14-以太网OAM |
1-9 |
oam errored-frame period |
接入分册-14-以太网OAM |
1-9 |
oam errored-frame threshold |
接入分册-14-以太网OAM |
1-10 |
oam errored-frame-period period |
接入分册-14-以太网OAM |
1-11 |
oam errored-frame-period threshold |
接入分册-14-以太网OAM |
1-11 |
oam errored-frame-seconds period |
接入分册-14-以太网OAM |
1-12 |
oam errored-frame-seconds threshold |
接入分册-14-以太网OAM |
1-13 |
oam errored-symbol period |
接入分册-14-以太网OAM |
1-13 |
oam errored-symbol threshold |
接入分册-14-以太网OAM |
1-14 |
oam loopback |
接入分册-14-以太网OAM |
1-15 |
oam mode |
接入分册-14-以太网OAM |
1-16 |
opaque-capability enable |
IP路由分册-04-OSPF |
1-43 |
open |
系统分册-04-文件系统管理 |
2-18 |
open ipv6 |
系统分册-04-文件系统管理 |
2-19 |
operation (FTP test type view) |
系统分册-12-NQA |
1-13 |
operation (HTTP test type view) |
系统分册-12-NQA |
1-13 |
系统分册-12-NQA |
1-14 |
option |
IP业务分册-03-DHCP |
1-18 |
organization |
安全分册-09-PKI |
1-15 |
organization-unit |
安全分册-09-PKI |
1-16 |
originating-rp |
组播分册-04-MSDP |
1-9 |
ospf |
IP路由分册-04-OSPF |
1-43 |
ospf authentication-mode |
IP路由分册-04-OSPF |
1-44 |
ospf bfd enable |
IP路由分册-13-BFD |
1-9 |
ospf cost |
IP路由分册-04-OSPF |
1-46 |
ospf dr-priority |
IP路由分册-04-OSPF |
1-46 |
ospf mib-binding |
IP路由分册-04-OSPF |
1-47 |
ospf mtu-enable |
IP路由分册-04-OSPF |
1-48 |
ospf network-type |
IP路由分册-04-OSPF |
1-48 |
ospf packet-process prioritized-treatment |
IP路由分册-04-OSPF |
1-50 |
ospf timer dead |
IP路由分册-04-OSPF |
1-50 |
ospf timer hello |
IP路由分册-04-OSPF |
1-51 |
ospf timer poll |
IP路由分册-04-OSPF |
1-52 |
ospf timer retransmit |
IP路由分册-04-OSPF |
1-52 |
ospf trans-delay |
IP路由分册-04-OSPF |
1-53 |
ospfv3 |
IP路由分册-09-OSPFv3 |
1-28 |
ospfv3 area |
IP路由分册-09-OSPFv3 |
1-29 |
ospfv3 cost |
IP路由分册-09-OSPFv3 |
1-29 |
ospfv3 dr-priority |
IP路由分册-09-OSPFv3 |
1-30 |
ospfv3 mtu-ignore |
IP路由分册-09-OSPFv3 |
1-30 |
ospfv3 network-type |
IP路由分册-09-OSPFv3 |
1-31 |
ospfv3 peer |
IP路由分册-09-OSPFv3 |
1-32 |
ospfv3 timer dead |
IP路由分册-09-OSPFv3 |
1-33 |
ospfv3 timer hello |
IP路由分册-09-OSPFv3 |
1-33 |
ospfv3 timer poll |
IP路由分册-09-OSPFv3 |
1-35 |
ospfv3 timer retransmit |
IP路由分册-09-OSPFv3 |
1-34 |
ospfv3 trans-delay |
IP路由分册-09-OSPFv3 |
1-35 |
output-delay |
IP路由分册-03-RIP |
1-14 |
overflow-replace (IGMP-Snooping view) |
1-22 |
overflow-replace (MLD-Snooping view) |
1-21 |
parity |
系统分册-01-登录以太网交换机 |
1-13 |
passive |
系统分册-04-文件系统管理 |
2-20 |
password |
安全分册-01-AAA |
1-26 |
password (FTP test type view) |
系统分册-12-NQA |
1-15 |
peer |
IP路由分册-03-RIP |
1-14 |
peer |
IP路由分册-04-OSPF |
1-54 |
peer advertise-community (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-38 |
peer advertise-community (IPv6 address family view) |
1-26 |
peer advertise-ext-community (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-38 |
peer advertise-ext-community (IPv6 address family view) |
1-27 |
peer allow-as-loop |
IP路由分册-14-MCE |
1-19 |
peer allow-as-loop (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-39 |
peer allow-as-loop (IPv6 address family view) |
1-27 |
peer as-number (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-40 |
peer as-number (IPv6 address family view) |
1-28 |
peer as-path-acl (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-41 |
peer as-path-acl (IPv6 address family view) |
1-29 |
peer capability-advertise conventional |
IP路由分册-06-BGP |
1-42 |
peer capability-advertise route-refresh |
IP路由分册-06-BGP |
1-42 |
1-29 |
peer connect-interface |
组播分册-04-MSDP |
1-10 |
peer connect-interface (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-43 |
peer connect-interface (IPv6 address family view) |
1-30 |
peer default-route-advertise |
1-31 |
peer default-route-advertise (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-44 |
peer description |
组播分册-04-MSDP |
1-11 |
peer description (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-45 |
peer description (IPv6 address family view) |
1-31 |
peer ebgp-max-hop (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-46 |
peer ebgp-max-hop (IPv6 address family view) |
1-32 |
peer enable (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-46 |
peer enable (IPv6 address family view) |
1-33 |
peer fake-as (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-47 |
peer fake-as (IPv6 address family view) |
1-34 |
peer filter-policy (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-48 |
peer filter-policy (IPv6 address family view) |
1-34 |
peer group |
IP路由分册-14-MCE |
1-20 |
peer group (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-49 |
peer group (IPv6 address family view) |
1-35 |
peer ignore (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-50 |
peer ignore (IPv6 address family view) |
1-36 |
peer ip-prefix |
IP路由分册-06-BGP |
1-50 |
peer ipv6-prefix |
1-36 |
peer keep-all-routes (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-51 |
peer keep-all-routes (IPv6 address family view) |
1-37 |
peer log-change (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-52 |
peer log-change (IPv6 address family view) |
1-38 |
peer mesh-group |
组播分册-04-MSDP |
1-11 |
peer minimum-ttl |
组播分册-04-MSDP |
1-12 |
peer next-hop-local (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-53 |
peer next-hop-local (IPv6 address family view) |
1-38 |
peer password |
IP路由分册-06-BGP |
1-53 |
peer preferred-value (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-54 |
peer preferred-value (IPv6 address family view) |
1-39 |
peer public-as-only (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-56 |
peer public-as-only (IPv6 address family view) |
1-40 |
peer reflect-client (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-56 |
peer reflect-client (IPv6 address family view) |
1-41 |
peer request-sa-enable |
组播分册-04-MSDP |
1-12 |
peer route-limit (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-57 |
peer route-limit (IPv6 address family view) |
1-41 |
peer route-policy (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-58 |
peer route-policy (IPv6 address family view) |
1-42 |
peer route-update-interval (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-59 |
peer route-update-interval (IPv6 address family view) |
1-43 |
peer sa-cache-maximum |
组播分册-04-MSDP |
1-13 |
peer sa-policy |
组播分册-04-MSDP |
1-14 |
peer sa-request-policy |
组播分册-04-MSDP |
1-15 |
peer substitute-as (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-60 |
peer substitute-as (IPv6 address family view) |
1-44 |
peer timer (BGP/BGP-VPN instance view) |
IP路由分册-06-BGP |
1-60 |
peer timer (IPv6 address family view) |
1-44 |
peer-public-key end |
安全分册-08-SSH2.0 |
1-8 |
pim |
组播分册-03-PIM |
1-29 |
pim bsr-boundary |
组播分册-03-PIM |
1-29 |
pim dm |
组播分册-03-PIM |
1-30 |
pim hello-option dr-priority |
组播分册-03-PIM |
1-31 |
pim hello-option holdtime |
组播分册-03-PIM |
1-31 |
pim hello-option lan-delay |
组播分册-03-PIM |
1-32 |
pim hello-option neighbor-tracking |
组播分册-03-PIM |
1-32 |
pim hello-option override-interval |
组播分册-03-PIM |
1-33 |
pim holdtime assert |
组播分册-03-PIM |
1-34 |
pim holdtime join-prune |
组播分册-03-PIM |
1-34 |
pim require-genid |
组播分册-03-PIM |
1-35 |
pim sm |
组播分册-03-PIM |
1-35 |
pim state-refresh-capable |
组播分册-03-PIM |
1-36 |
pim timer graft-retry |
组播分册-03-PIM |
1-37 |
pim timer hello |
组播分册-03-PIM |
1-37 |
pim timer join-prune |
组播分册-03-PIM |
1-38 |
pim triggered-hello-delay |
组播分册-03-PIM |
1-38 |
ping |
系统分册-09-系统维护与调试 |
1-1 |
ping ipv6 |
系统分册-09-系统维护与调试 |
1-4 |
安全分册-09-PKI |
1-17 |
安全分册-09-PKI |
1-17 |
pki delete-certificate |
安全分册-09-PKI |
1-18 |
pki domain |
安全分册-09-PKI |
1-18 |
pki entity |
安全分册-09-PKI |
1-19 |
pki import-certificate |
安全分册-09-PKI |
1-19 |
pki request-certificate domain |
安全分册-09-PKI |
1-20 |
pki retrieval-certificate |
安全分册-09-PKI |
1-21 |
pki retrieval-crl domain |
安全分册-09-PKI |
1-22 |
pki validate-certificate |
安全分册-09-PKI |
1-22 |
pki-domain |
安全分册-10-SSL |
1-5 |
port |
1-3 |
port |
1-2 |
port |
接入分册-09-VLAN |
1-9 |
port access vlan |
接入分册-09-VLAN |
1-10 |
port hybrid ip-subnet-vlan vlan |
接入分册-09-VLAN |
1-26 |
port hybrid protocol-vlan |
接入分册-09-VLAN |
1-20 |
port hybrid pvid vlan |
接入分册-09-VLAN |
1-11 |
port hybrid vlan |
接入分册-09-VLAN |
1-12 |
port link-aggregation group |
接入分册-02-链路聚合 |
1-10 |
port link-mode |
接入分册-01-以太网端口 |
1-11 |
port link-type |
接入分册-09-VLAN |
1-14 |
port monitor-link group |
1-3 |
port service-loopback group |
接入分册-04-业务环回组 |
1-2 |
port smart-link group |
1-4 |
port trunk permit vlan |
接入分册-09-VLAN |
1-15 |
port trunk pvid vlan |
接入分册-09-VLAN |
1-17 |
port-group manual |
接入分册-01-以太网端口 |
1-26 |
port-isolate enable |
接入分册-03-端口隔离 |
1-1 |
port-isolate uplink-port |
接入分册-03-端口隔离 |
1-3 |
port-security authorization ignore |
安全分册-06-端口安全 |
1-6 |
port-security enable |
安全分册-06-端口安全 |
1-7 |
port-security intrusion-mode |
安全分册-06-端口安全 |
1-8 |
安全分册-06-端口安全 |
1-8 |
port-security max-mac-count |
安全分册-06-端口安全 |
1-10 |
port-security ntk-mode |
安全分册-06-端口安全 |
1-11 |
port-security oui |
安全分册-06-端口安全 |
1-12 |
port-security port-mode |
安全分册-06-端口安全 |
1-12 |
port-security timer disableport |
安全分册-06-端口安全 |
1-14 |
port-security trap |
安全分册-06-端口安全 |
1-14 |
preemption mode |
1-5 |
prefer-cipher |
安全分册-10-SSL |
1-6 |
preference |
IP路由分册-03-RIP |
1-15 |
preference |
IP路由分册-04-OSPF |
1-55 |
preference |
IP路由分册-08-RIPng |
1-10 |
preference |
IP路由分册-09-OSPFv3 |
1-36 |
IP路由分册-06-BGP |
1-62 |
1-46 |
preference (IS-IS view) |
IP路由分册-05-IS-IS |
1-52 |
primap |
QoS分册-01-QoS |
1-9 |
primary accounting (HWTACACS scheme view) |
安全分册-01-AAA |
3-7 |
primary accounting (RADIUS scheme view) |
安全分册-01-AAA |
2-11 |
primary authentication (HWTACACS scheme view) |
安全分册-01-AAA |
3-7 |
primary authentication (RADIUS scheme view) |
安全分册-01-AAA |
2-12 |
primary authorization |
安全分册-01-AAA |
3-8 |
probe count |
系统分册-12-NQA |
1-15 |
probe packet-interval |
系统分册-12-NQA |
1-16 |
probe packet-number |
系统分册-12-NQA |
1-17 |
probe packet-timeout |
系统分册-12-NQA |
1-17 |
probe timeout |
系统分册-12-NQA |
1-18 |
probe-interval (PIM view) |
组播分册-03-PIM |
1-39 |
protected-vlan |
1-6 |
protected-vlan |
接入分册-17-RRPP |
1-9 |
protocol inbound |
系统分册-01-登录以太网交换机 |
1-14 |
protocol-vlan |
接入分册-09-VLAN |
1-21 |
proxy-arp enable |
IP业务分册-02-ARP |
2-3 |
public-key local create |
安全分册-08-SSH2.0 |
1-10 |
public-key local destroy |
安全分册-08-SSH2.0 |
1-11 |
public-key local export rsa |
安全分册-08-SSH2.0 |
1-11 |
public-key peer |
安全分册-08-SSH2.0 |
1-12 |
public-key peer import sshkey |
安全分册-08-SSH2.0 |
1-13 |
public-key-code begin |
安全分册-08-SSH2.0 |
1-8 |
public-key-code end |
安全分册-08-SSH2.0 |
1-9 |
put |
安全分册-08-SSH2.0 |
1-33 |
put |
系统分册-04-文件系统管理 |
2-20 |
pwd |
安全分册-08-SSH2.0 |
1-33 |
pwd |
系统分册-04-文件系统管理 |
1-9 |
pwd |
系统分册-04-文件系统管理 |
2-21 |
qinq enable |
接入分册-11-QinQ |
1-2 |
qinq ethernet-type |
接入分册-11-QinQ |
1-3 |
qinq vid |
接入分册-11-QinQ |
1-4 |
qos apply policy |
QoS分册-01-QoS |
1-20 |
qos apply policy global |
QoS分册-01-QoS |
1-21 |
qos car |
QoS分册-01-QoS |
3-2 |
qos car aggregative |
QoS分册-01-QoS |
4-2 |
qos car name |
QoS分册-01-QoS |
4-3 |
qos gts |
QoS分册-01-QoS |
3-4 |
qos map-table |
QoS分册-01-QoS |
2-2 |
qos policy |
QoS分册-01-QoS |
1-21 |
qos priority |
QoS分册-01-QoS |
2-3 |
qos trust |
QoS分册-01-QoS |
2-4 |
qos vlan-policy |
QoS分册-01-QoS |
1-22 |
qos wred enable |
QoS分册-01-QoS |
6-3 |
qos wrr |
QoS分册-01-QoS |
5-2 |
quit |
安全分册-08-SSH2.0 |
1-34 |
quit |
系统分册-02-系统基本配置 |
1-17 |
quit |
系统分册-04-文件系统管理 |
2-21 |
radius client |
安全分册-01-AAA |
2-13 |
radius nas-ip |
安全分册-01-AAA |
2-14 |
radius scheme |
安全分册-01-AAA |
2-15 |
radius trap |
安全分册-01-AAA |
2-15 |
raw-vlan-id inbound |
接入分册-11-QinQ |
1-5 |
reaction |
系统分册-12-NQA |
1-19 |
reaction trap |
系统分册-12-NQA |
1-20 |
reboot |
系统分册-03-设备管理 |
1-17 |
reboot member |
系统分册-15-集群管理 |
1-41 |
redirect |
QoS分册-01-QoS |
1-10 |
reflect between-clients (BGP view) |
IP路由分册-06-BGP |
1-63 |
reflect between-clients (IPv6 address family view) |
IP路由分册-11-IPv6 BGP |
1-46 |
reflector cluster-id (BGP view) |
IP路由分册-06-BGP |
1-63 |
reflector cluster-id (IPv6 address family view) |
1-47 |
refresh bgp |
IP路由分册-06-BGP |
1-64 |
refresh bgp ipv6 |
1-48 |
refresh bgp vpn-instance |
IP路由分册-14-MCE |
1-21 |
region-name |
接入分册-16-MSTP |
1-12 |
register-policy (PIM view) |
组播分册-03-PIM |
1-39 |
register-suppression-timeout (PIM view) |
组播分册-03-PIM |
1-40 |
register-whole-checksum (PIM view) |
组播分册-03-PIM |
1-41 |
remark dot1p |
QoS分册-01-QoS |
1-10 |
remark drop-precedence |
QoS分册-01-QoS |
1-11 |
remark dscp |
QoS分册-01-QoS |
1-12 |
remark ip-precedence |
QoS分册-01-QoS |
1-13 |
remark local-precedence |
QoS分册-01-QoS |
1-13 |
remark service-vlan-id |
QoS分册-01-QoS |
1-14 |
remotehelp |
系统分册-04-文件系统管理 |
2-22 |
remove |
安全分册-08-SSH2.0 |
1-34 |
rename |
安全分册-08-SSH2.0 |
1-35 |
rename |
系统分册-04-文件系统管理 |
1-9 |
report-aggregation (IGMP-Snooping view) |
1-23 |
report-aggregation (MLD-Snooping view) |
1-22 |
require-router-alert (IGMP view) |
组播分册-02-IGMP |
1-19 |
reset acl counter |
安全分册-11-ACL |
1-8 |
reset acl ipv6 counter |
安全分册-11-ACL |
1-24 |
reset arp |
IP业务分册-02-ARP |
1-7 |
reset arp detection statistics |
IP业务分册-02-ARP |
4-8 |
reset arp-snooping |
IP业务分册-02-ARP |
3-2 |
reset bfd session statistics |
IP路由分册-13-BFD |
1-10 |
reset bgp |
IP路由分册-06-BGP |
1-65 |
reset bgp dampening |
IP路由分册-06-BGP |
1-65 |
reset bgp flap-info |
IP路由分册-06-BGP |
1-66 |
reset bgp ipv4 all |
IP路由分册-06-BGP |
1-66 |
reset bgp ipv6 |
1-49 |
reset bgp ipv6 dampening |
1-49 |
reset bgp ipv6 flap-info |
1-50 |
reset bgp vpn-instance |
IP路由分册-14-MCE |
1-21 |
reset bgp vpn-instance dampening |
IP路由分册-14-MCE |
1-22 |
reset bgp vpn-instance flap-info |
IP路由分册-14-MCE |
1-23 |
reset counters interface |
接入分册-01-以太网端口 |
1-12 |
reset dhcp relay statistics |
IP业务分册-03-DHCP |
2-18 |
reset dhcp server conflict |
IP业务分册-03-DHCP |
1-19 |
reset dhcp server ip-in-use |
IP业务分册-03-DHCP |
1-19 |
reset dhcp server statistics |
IP业务分册-03-DHCP |
1-20 |
reset dhcp-snooping |
IP业务分册-03-DHCP |
4-11 |
reset dhcp-snooping packet statistics |
IP业务分册-03-DHCP |
4-12 |
reset dldp statistics |
接入分册-05-DLDP |
1-9 |
reset dns dynamic-host |
IP业务分册-04-域名解析 |
1-8 |
reset dns ipv6 dynamic-host |
IP业务分册-07-IPv6基础 |
1-36 |
reset dot1x statistics |
安全分册-02-802.1X |
1-17 |
reset garp statistics |
接入分册-10-GVRP |
1-5 |
reset hwtacacs statistics |
安全分册-01-AAA |
3-9 |
reset igmp group |
组播分册-02-IGMP |
1-20 |
reset igmp group port-info |
组播分册-02-IGMP |
1-20 |
reset igmp ssm-mapping group |
组播分册-02-IGMP |
1-21 |
reset igmp-snooping group |
1-23 |
reset igmp-snooping statistics |
1-24 |
reset ip ip-prefix |
IP路由分册-12-路由策略 |
1-25 |
reset ip ipv6-prefix |
IP路由分册-12-路由策略 |
1-29 |
reset ip routing-table statistics protocol |
IP路由分册-01-IP路由表显示 |
1-22 |
reset ip statistics |
IP业务分册-05-IP性能优化 |
1-16 |
reset ipv6 fibcache |
IP业务分册-07-IPv6基础 |
1-37 |
reset ipv6 neighbors |
IP业务分册-07-IPv6基础 |
1-37 |
reset ipv6 pathmtu |
IP业务分册-07-IPv6基础 |
1-38 |
reset ipv6 routing-table statistics |
IP路由分册-01-IP路由表显示 |
1-23 |
reset ipv6 statistics |
IP业务分册-07-IPv6基础 |
1-38 |
reset isis all |
IP路由分册-05-IS-IS |
1-53 |
reset isis peer |
IP路由分册-05-IS-IS |
1-53 |
reset lacp statistics |
接入分册-02-链路聚合 |
1-11 |
reset logbuffer |
系统分册-10-信息中心 |
1-20 |
reset mac-authentication statistics |
安全分册-04-MAC地址认证 |
1-6 |
reset mld-snooping group |
1-22 |
reset mld-snooping statistics |
1-23 |
reset msdp peer |
组播分册-04-MSDP |
1-15 |
reset msdp sa-cache |
组播分册-04-MSDP |
1-16 |
reset msdp statistics |
组播分册-04-MSDP |
1-16 |
reset multicast forwarding-table |
组播分册-01-组播路由与转发 |
1-14 |
reset multicast routing-table |
组播分册-01-组播路由与转发 |
1-15 |
reset ndp statistics |
系统分册-15-集群管理 |
1-6 |
reset oam |
接入分册-14-以太网OAM |
1-16 |
reset ospf counters |
IP路由分册-04-OSPF |
1-56 |
reset ospf process |
IP路由分册-04-OSPF |
1-56 |
reset ospf redistribution |
IP路由分册-04-OSPF |
1-57 |
reset pim control-message counters |
组播分册-03-PIM |
1-41 |
reset qos car name |
QoS分册-01-QoS |
4-4 |
reset qos policy global |
QoS分册-01-QoS |
1-23 |
reset qos vlan-policy |
QoS分册-01-QoS |
1-23 |
reset radius statistics |
安全分册-01-AAA |
2-16 |
reset recycle-bin |
系统分册-04-文件系统管理 |
1-10 |
reset rip statistics |
IP路由分册-03-RIP |
1-16 |
reset rrpp statistics |
接入分册-17-RRPP |
1-10 |
reset saved-configuration |
系统分册-04-文件系统管理 |
1-16 |
reset smart-link statistics |
1-7 |
reset stop-accounting-buffer |
安全分册-01-AAA |
2-17 |
安全分册-01-AAA |
3-10 |
reset stp |
接入分册-16-MSTP |
1-12 |
reset tcp ipv6 statistics |
IP业务分册-07-IPv6基础 |
1-39 |
reset tcp statistics |
IP业务分册-05-IP性能优化 |
1-17 |
reset trapbuffer |
系统分册-10-信息中心 |
1-20 |
reset udp ipv6 statistics |
IP业务分册-07-IPv6基础 |
1-39 |
reset udp statistics |
IP业务分册-05-IP性能优化 |
1-17 |
reset udp-helper packet |
1-1 |
reset unused porttag |
系统分册-03-设备管理 |
1-18 |
reset vrrp ipv6 statistics |
系统分册-14-VRRP |
1-16 |
reset vrrp statistics |
系统分册-14-VRRP |
1-4 |
restore startup-configuration |
系统分册-04-文件系统管理 |
1-17 |
retry |
安全分册-01-AAA |
2-17 |
retry realtime-accounting |
安全分册-01-AAA |
2-18 |
retry stop-accounting (HWTACACS scheme view) |
安全分册-01-AAA |
3-10 |
retry stop-accounting (RADIUS scheme view) |
安全分册-01-AAA |
2-19 |
return |
系统分册-02-系统基本配置 |
1-17 |
revision-level |
接入分册-16-MSTP |
1-13 |
rfc1583 compatible |
IP路由分册-04-OSPF |
1-57 |
ring |
接入分册-17-RRPP |
1-11 |
ring enable |
接入分册-17-RRPP |
1-13 |
rip |
IP路由分册-03-RIP |
1-16 |
rip authentication-mode |
IP路由分册-03-RIP |
1-17 |
rip default-route |
IP路由分册-03-RIP |
1-18 |
rip input |
IP路由分册-03-RIP |
1-19 |
rip metricin |
IP路由分册-03-RIP |
1-19 |
rip metricout |
IP路由分册-03-RIP |
1-20 |
rip mib-binding |
IP路由分册-03-RIP |
1-21 |
rip output |
IP路由分册-03-RIP |
1-22 |
rip poison-reverse |
IP路由分册-03-RIP |
1-23 |
rip split-horizon |
IP路由分册-03-RIP |
1-23 |
rip summary-address |
IP路由分册-03-RIP |
1-24 |
rip version |
IP路由分册-03-RIP |
1-25 |
ripng |
IP路由分册-08-RIPng |
1-11 |
ripng default-route |
IP路由分册-08-RIPng |
1-11 |
ripng enable |
IP路由分册-08-RIPng |
1-12 |
ripng metricin |
IP路由分册-08-RIPng |
1-13 |
ripng metricout |
IP路由分册-08-RIPng |
1-13 |
ripng poison-reverse |
IP路由分册-08-RIPng |
1-14 |
ripng split-horizon |
IP路由分册-08-RIPng |
1-14 |
ripng summary-address |
IP路由分册-08-RIPng |
1-15 |
rmdir |
安全分册-08-SSH2.0 |
1-35 |
rmdir |
系统分册-04-文件系统管理 |
1-12 |
rmdir |
系统分册-04-文件系统管理 |
2-24 |
rmon alarm |
系统分册-07-RMON |
1-9 |
rmon event |
系统分册-07-RMON |
1-11 |
rmon history |
系统分册-07-RMON |
1-12 |
rmon prialarm |
系统分册-07-RMON |
1-13 |
rmon statistics |
系统分册-07-RMON |
1-15 |
robust-count (IGMP view) |
组播分册-02-IGMP |
1-22 |
root-certificate fingerprint |
安全分册-09-PKI |
1-23 |
route-distinguisher |
IP路由分册-14-MCE |
1-23 |
route-option bypass-route |
系统分册-12-NQA |
1-20 |
route-policy |
IP路由分册-12-路由策略 |
1-20 |
router id |
IP路由分册-01-IP路由表显示 |
1-21 |
router-aging-time (IGMP-Snooping view) |
1-24 |
router-aging-time (MLD-Snooping view) |
1-23 |
router-id |
IP路由分册-06-BGP |
1-67 |
router-id |
IP路由分册-09-OSPFv3 |
1-37 |
router-id |
1-50 |
routing-table limit |
IP路由分册-14-MCE |
1-24 |
rrpp domain |
接入分册-17-RRPP |
1-14 |
rrpp enable |
接入分册-17-RRPP |
1-15 |
rrpp ring-group |
接入分册-17-RRPP |
1-15 |
rule (advanced IPv4 ACL view) |
安全分册-11-ACL |
1-11 |
rule (advanced IPv6 ACL view) |
安全分册-11-ACL |
1-26 |
rule (basic IPv4 ACL view) |
安全分册-11-ACL |
1-9 |
rule (basic IPv6 ACL view) |
安全分册-11-ACL |
1-25 |
rule (Ethernet frame header ACL view) |
安全分册-11-ACL |
1-15 |
rule (Pki Cert Acp view) |
安全分册-09-PKI |
1-23 |
rule (user-defined ACL view) |
安全分册-11-ACL |
1-17 |
rule comment (for IPv4) |
安全分册-11-ACL |
1-18 |
rule comment (for IPv6) |
安全分册-11-ACL |
1-30 |
save |
系统分册-04-文件系统管理 |
1-17 |
schedule job |
系统分册-03-设备管理 |
1-18 |
schedule reboot at |
系统分册-03-设备管理 |
1-20 |
schedule reboot delay |
系统分册-03-设备管理 |
1-21 |
screen-length |
系统分册-01-登录以太网交换机 |
1-15 |
screen-length disable |
系统分册-02-系统基本配置 |
1-18 |
secondary accounting (HWTACACS scheme view) |
安全分册-01-AAA |
3-11 |
secondary accounting (RADIUS scheme view) |
安全分册-01-AAA |
2-20 |
secondary authentication (HWTACACS scheme view) |
安全分册-01-AAA |
3-11 |
secondary authentication (RADIUS scheme view) |
安全分册-01-AAA |
2-21 |
secondary authorization |
安全分册-01-AAA |
3-12 |
security-policy-server |
安全分册-01-AAA |
2-22 |
self-service-url enable |
安全分册-01-AAA |
1-27 |
send |
系统分册-01-登录以太网交换机 |
1-15 |
send-router-alert (IGMP view) |
组播分册-02-IGMP |
1-22 |
server-type |
安全分册-01-AAA |
2-22 |
接入分册-04-业务环回组 |
1-2 |
service-loopback-group |
IP业务分册-09-隧道技术 |
1-8 |
service-type |
安全分册-01-AAA |
1-28 |
session |
安全分册-10-SSL |
1-7 |
set authentication password |
系统分册-01-登录以太网交换机 |
1-16 |
set-overload |
IP路由分册-05-IS-IS |
1-54 |
sflow agent ip |
IP业务分册-10-sFlow |
1-2 |
sflow collector ip |
IP业务分册-10-sFlow |
1-3 |
sflow enable |
IP业务分册-10-sFlow |
1-3 |
sflow interval |
IP业务分册-10-sFlow |
1-4 |
sflow sampling-mode |
IP业务分册-10-sFlow |
1-5 |
sflow sampling-rate |
IP业务分册-10-sFlow |
1-5 |
sflow version |
IP业务分册-10-sFlow |
1-6 |
sftp |
安全分册-08-SSH2.0 |
1-14 |
sftp client ipv6 source |
安全分册-08-SSH2.0 |
1-15 |
安全分册-08-SSH2.0 |
1-15 |
sftp ipv6 |
安全分册-08-SSH2.0 |
1-16 |
sftp server enable |
安全分册-08-SSH2.0 |
1-17 |
sftp server idle-timeout |
安全分册-08-SSH2.0 |
1-17 |
shell |
系统分册-01-登录以太网交换机 |
1-17 |
shutdown |
接入分册-01-以太网端口 |
1-12 |
shutdown |
接入分册-02-链路聚合 |
1-11 |
shutdown |
接入分册-09-VLAN |
1-7 |
shutdown (MSDP view) |
组播分册-04-MSDP |
1-17 |
shutdown-interval |
系统分册-03-设备管理 |
1-22 |
silent-interface (OSPF view) |
IP路由分册-04-OSPF |
1-58 |
silent-interface (RIP view) |
IP路由分册-03-RIP |
1-26 |
silent-interface(OSPFv3 view) |
IP路由分册-09-OSPFv3 |
1-37 |
smart-link flush enable |
1-7 |
smart-link group |
1-8 |
snmp-agent |
系统分册-06-SNMP |
1-10 |
snmp-agent calculate-password |
系统分册-06-SNMP |
1-11 |
系统分册-06-SNMP |
1-12 |
snmp-agent group |
系统分册-06-SNMP |
1-13 |
系统分册-06-SNMP |
1-15 |
snmp-agent log |
系统分册-06-SNMP |
1-15 |
系统分册-06-SNMP |
1-16 |
snmp-agent packet max-size |
系统分册-06-SNMP |
1-17 |
系统分册-06-SNMP |
1-18 |
snmp-agent target-host |
系统分册-06-SNMP |
1-19 |
snmp-agent trap enable |
系统分册-06-SNMP |
1-20 |
snmp-agent trap enable bfd |
IP路由分册-13-BFD |
1-10 |
snmp-agent trap enable ospf |
IP路由分册-04-OSPF |
1-59 |
snmp-agent trap if-mib link extended |
系统分册-06-SNMP |
1-22 |
snmp-agent trap life |
系统分册-06-SNMP |
1-23 |
snmp-agent trap queue-size |
系统分册-06-SNMP |
1-23 |
snmp-agent trap source |
系统分册-06-SNMP |
1-24 |
snmp-agent usm-user { v1 | v2c } |
系统分册-06-SNMP |
1-25 |
snmp-agent usm-user v3 |
系统分册-06-SNMP |
1-26 |
snmp-host |
系统分册-15-集群管理 |
1-42 |
source |
IP业务分册-09-隧道技术 |
1-9 |
source interface |
系统分册-12-NQA |
1-21 |
source ip |
系统分册-12-NQA |
1-22 |
source port |
系统分册-12-NQA |
1-23 |
source-lifetime (PIM view) |
组播分册-03-PIM |
1-42 |
source-policy (PIM view) |
组播分册-03-PIM |
1-42 |
speed |
接入分册-01-以太网端口 |
1-13 |
speed |
系统分册-01-登录以太网交换机 |
1-18 |
spf timers |
IP路由分册-09-OSPFv3 |
1-38 |
spf-schedule-interval |
IP路由分册-04-OSPF |
1-60 |
spt-switch-threshold infinity (PIM view) |
组播分册-03-PIM |
1-43 |
ssh client authentication server |
安全分册-08-SSH2.0 |
1-18 |
ssh client first-time enable |
安全分册-08-SSH2.0 |
1-19 |
ssh client ipv6 source |
安全分册-08-SSH2.0 |
1-19 |
ssh client source |
安全分册-08-SSH2.0 |
1-20 |
ssh server authentication-retries |
安全分册-08-SSH2.0 |
1-20 |
ssh server authentication-timeout |
安全分册-08-SSH2.0 |
1-21 |
ssh server compatible-ssh1x enable |
安全分册-08-SSH2.0 |
1-22 |
ssh server enable |
安全分册-08-SSH2.0 |
1-22 |
ssh server rekey-interval |
安全分册-08-SSH2.0 |
1-23 |
ssh user |
安全分册-08-SSH2.0 |
1-23 |
ssh2 |
安全分册-08-SSH2.0 |
1-25 |
ssh2 ipv6 |
安全分册-08-SSH2.0 |
1-26 |
ssl client-policy |
安全分册-10-SSL |
1-7 |
ssl server-policy |
安全分册-10-SSL |
1-8 |
ssm-mapping (IGMP view) |
组播分册-02-IGMP |
1-23 |
ssm-policy (PIM view) |
组播分册-03-PIM |
1-44 |
stack ip-pool |
堆叠管理命令 |
1-2 |
stack role master |
堆叠管理命令 |
1-3 |
stack stack-port |
堆叠管理命令 |
1-4 |
stack switch-to |
堆叠管理命令 |
1-4 |
startup saved-configuration |
系统分册-04-文件系统管理 |
1-18 |
startup-query-count (IGMP view) |
组播分册-02-IGMP |
1-24 |
startup-query-interval (IGMP view) |
组播分册-02-IGMP |
1-24 |
state |
安全分册-01-AAA |
1-28 |
state |
安全分册-01-AAA |
2-23 |
state |
安全分册-09-PKI |
1-24 |
state-refresh-interval (PIM view) |
组播分册-03-PIM |
1-45 |
state-refresh-rate-limit (PIM view) |
组播分册-03-PIM |
1-45 |
state-refresh-ttl |
组播分册-03-PIM |
1-46 |
static-bind client-identifier |
IP业务分册-03-DHCP |
1-20 |
static-bind ip-address |
IP业务分册-03-DHCP |
1-21 |
static-bind mac-address |
IP业务分册-03-DHCP |
1-22 |
static-rp (PIM view) |
组播分册-03-PIM |
1-47 |
static-rpf-peer |
组播分册-04-MSDP |
1-17 |
step (for IPv4) |
安全分册-11-ACL |
1-19 |
step (for IPv6) |
安全分册-11-ACL |
1-31 |
stop-accounting-buffer enable (HWTACACS scheme view) |
安全分册-01-AAA |
3-13 |
stop-accounting-buffer enable (RADIUS scheme view) |
安全分册-01-AAA |
2-24 |
stopbits |
系统分册-01-登录以太网交换机 |
1-18 |
storm-constrain |
接入分册-01-以太网端口 |
1-26 |
storm-constrain control |
接入分册-01-以太网端口 |
1-28 |
storm-constrain enable log |
接入分册-01-以太网端口 |
1-28 |
storm-constrain enable trap |
接入分册-01-以太网端口 |
1-29 |
storm-constrain interval |
接入分册-01-以太网端口 |
1-30 |
stp |
接入分册-16-MSTP |
1-14 |
stp bpdu-protection |
接入分册-16-MSTP |
1-15 |
stp bridge-diameter |
接入分册-16-MSTP |
1-15 |
stp compliance |
接入分册-16-MSTP |
1-16 |
stp config-digest-snooping |
接入分册-16-MSTP |
1-17 |
stp cost |
接入分册-16-MSTP |
1-18 |
stp edged-port |
接入分册-16-MSTP |
1-19 |
stp ignored vlan |
接入分册-16-MSTP |
1-20 |
stp loop-protection |
接入分册-16-MSTP |
1-20 |
stp max-hops |
接入分册-16-MSTP |
1-21 |
stp mcheck |
接入分册-16-MSTP |
1-22 |
stp mode |
接入分册-16-MSTP |
1-23 |
stp no-agreement-check |
接入分册-16-MSTP |
1-23 |
stp pathcost-standard |
接入分册-16-MSTP |
1-24 |
stp point-to-point |
接入分册-16-MSTP |
1-25 |
stp port priority |
接入分册-16-MSTP |
1-26 |
stp port-log |
接入分册-16-MSTP |
1-27 |
stp priority |
接入分册-16-MSTP |
1-28 |
接入分册-16-MSTP |
1-29 |
stp root primary |
接入分册-16-MSTP |
1-29 |
stp root secondary |
接入分册-16-MSTP |
1-30 |
stp root-protection |
接入分册-16-MSTP |
1-31 |
stp tc-protection |
接入分册-16-MSTP |
1-31 |
stp tc-protection threshold |
接入分册-16-MSTP |
1-32 |
stp timer forward-delay |
接入分册-16-MSTP |
1-33 |
stp timer hello |
接入分册-16-MSTP |
1-33 |
stp timer max-age |
接入分册-16-MSTP |
1-34 |
stp timer-factor |
接入分册-16-MSTP |
1-35 |
stp transmit-limit |
接入分册-16-MSTP |
1-36 |
stub (OSPF area view) |
IP路由分册-04-OSPF |
1-61 |
stub (OSPFv3 area view) |
IP路由分册-09-OSPFv3 |
1-39 |
stub-router |
IP路由分册-04-OSPF |
1-61 |
subvlan (Multicast-VLAN view) |
组播分册-06-组播VLAN |
1-2 |
summary |
IP路由分册-03-RIP |
1-26 |
summary (IS-IS view) |
IP路由分册-05-IS-IS |
1-55 |
summary automatic |
IP路由分册-06-BGP |
1-68 |
super |
系统分册-02-系统基本配置 |
1-18 |
super authentication-mode |
系统分册-02-系统基本配置 |
1-19 |
super password |
系统分册-02-系统基本配置 |
1-20 |
switch-mode |
IP业务分册-08-双协议栈 |
1-1 |
switch-mode mce |
IP路由分册-14-MCE |
1-25 |
synchronization (BGP view) |
IP路由分册-06-BGP |
1-68 |
synchronization (IPv6 address family view) |
1-51 |
sysname |
系统分册-01-登录以太网交换机 |
1-19 |
sysname |
系统分册-02-系统基本配置 |
1-21 |
system-guard aging-time |
1-1 |
system-guard control |
1-2 |
system-guard detect-threshold |
1-3 |
system-guard enable |
1-3 |
system-guard rate-limit |
1-4 |
system-view |
系统分册-02-系统基本配置 |
1-22 |
tcp anti-naptha enable |
IP业务分册-05-IP性能优化 |
1-18 |
tcp ipv6 timer fin-timeout |
IP业务分册-07-IPv6基础 |
1-40 |
tcp ipv6 timer syn-timeout |
IP业务分册-07-IPv6基础 |
1-40 |
tcp ipv6 window |
IP业务分册-07-IPv6基础 |
1-41 |
tcp mss |
IP业务分册-05-IP性能优化 |
1-18 |
tcp state |
IP业务分册-05-IP性能优化 |
1-19 |
tcp syn-cookie enable |
IP业务分册-05-IP性能优化 |
1-20 |
tcp timer check-state |
IP业务分册-05-IP性能优化 |
1-20 |
tcp timer fin-timeout |
IP业务分册-05-IP性能优化 |
1-21 |
tcp timer syn-timeout |
IP业务分册-05-IP性能优化 |
1-22 |
tcp window |
IP业务分册-05-IP性能优化 |
1-22 |
telnet |
系统分册-01-登录以太网交换机 |
1-20 |
telnet client source |
系统分册-01-登录以太网交换机 |
1-21 |
telnet ipv6 |
系统分册-01-登录以太网交换机 |
1-21 |
telnet server enable |
系统分册-01-登录以太网交换机 |
1-22 |
terminal debugging |
系统分册-10-信息中心 |
1-20 |
terminal logging |
系统分册-10-信息中心 |
1-21 |
terminal monitor |
系统分册-10-信息中心 |
1-22 |
terminal trapping |
系统分册-10-信息中心 |
1-23 |
terminal type |
系统分册-01-登录以太网交换机 |
1-23 |
tftp |
系统分册-04-文件系统管理 |
3-2 |
tftp client source |
系统分册-04-文件系统管理 |
3-3 |
tftp ipv6 |
系统分册-04-文件系统管理 |
3-4 |
tftp-server |
系统分册-15-集群管理 |
1-42 |
tftp-server acl |
系统分册-04-文件系统管理 |
3-1 |
tftp-server domain-name |
IP业务分册-03-DHCP |
1-23 |
tftp-server ip-address |
IP业务分册-03-DHCP |
1-23 |
timer |
接入分册-17-RRPP |
1-16 |
timer |
系统分册-15-集群管理 |
1-43 |
IP路由分册-06-BGP |
1-69 |
1-52 |
timer hello (PIM view) |
组播分册-03-PIM |
1-47 |
timer hold |
接入分册-01-以太网端口 |
1-33 |
timer join-prune (PIM view) |
组播分册-03-PIM |
1-48 |
timer lsp-generation |
IP路由分册-05-IS-IS |
1-56 |
timer lsp-max-age |
IP路由分册-05-IS-IS |
1-57 |
timer lsp-refresh |
IP路由分册-05-IS-IS |
1-58 |
timer other-querier-present (IGMP view) |
组播分册-02-IGMP |
1-25 |
timer query (IGMP view) |
组播分册-02-IGMP |
1-26 |
timer quiet (HWTACACS scheme view) |
安全分册-01-AAA |
3-14 |
timer quiet (RADIUS scheme view) |
安全分册-01-AAA |
2-25 |
timer realtime-accounting (HWTACACS scheme view) |
安全分册-01-AAA |
3-14 |
timer realtime-accounting (RADIUS scheme view) |
安全分册-01-AAA |
2-25 |
timer response-timeout (HWTACACS scheme view) |
安全分册-01-AAA |
3-15 |
timer response-timeout (RADIUS scheme view) |
安全分册-01-AAA |
2-26 |
timer retry |
组播分册-04-MSDP |
1-18 |
timer spf |
IP路由分册-05-IS-IS |
1-58 |
time-range |
安全分册-11-ACL |
1-1 |
timers |
IP路由分册-03-RIP |
1-27 |
timers |
IP路由分册-08-RIPng |
1-16 |
topology accept |
系统分册-15-集群管理 |
1-44 |
topology restore-from |
系统分册-15-集群管理 |
1-45 |
topology save-to |
系统分册-15-集群管理 |
1-45 |
tos |
系统分册-12-NQA |
1-24 |
tracert |
系统分册-09-系统维护与调试 |
1-6 |
tracert ipv6 |
系统分册-09-系统维护与调试 |
1-7 |
track bfd echo |
系统分册-11-Track |
1-2 |
track nqa |
系统分册-11-Track |
1-3 |
traffic behavior |
QoS分册-01-QoS |
1-15 |
QoS分册-01-QoS |
1-4 |
transmit-pacing |
IP路由分册-04-OSPF |
1-62 |
ttl |
系统分册-12-NQA |
1-25 |
tunnel-protocol |
IP业务分册-09-隧道技术 |
1-10 |
type |
系统分册-12-NQA |
1-23 |
udp-helper enable |
1-2 |
udp-helper port |
1-3 |
udp-helper server |
1-3 |
undelete |
系统分册-04-文件系统管理 |
1-12 |
unicast-suppression |
接入分册-01-以太网端口 |
1-30 |
url |
系统分册-12-NQA |
1-25 |
user |
系统分册-04-文件系统管理 |
2-24 |
user privilege level |
系统分册-01-登录以太网交换机 |
1-24 |
user-bind |
安全分册-07-IP Source Guard |
1-3 |
user-group |
安全分册-01-AAA |
1-29 |
user-interface |
系统分册-01-登录以太网交换机 |
1-23 |
username (FTP test type view) |
系统分册-12-NQA |
1-26 |
user-name-format (HWTACACS scheme view) |
安全分册-01-AAA |
3-16 |
user-name-format (RADIUS scheme view) |
安全分册-01-AAA |
2-27 |
validate-source-address |
IP路由分册-03-RIP |
1-28 |
verbose |
系统分册-04-文件系统管理 |
2-25 |
version |
IP路由分册-03-RIP |
1-29 |
version |
安全分册-10-SSL |
1-8 |
version (IGMP view) |
组播分册-02-IGMP |
1-26 |
virtual-cable-test |
接入分册-01-以太网端口 |
1-31 |
virtual-system |
IP路由分册-05-IS-IS |
1-60 |
vlan |
接入分册-09-VLAN |
1-7 |
vlan-check disable |
接入分册-11-QinQ |
1-6 |
vlan-mapping modulo |
接入分册-16-MSTP |
1-37 |
vlink-peer (OSPF area view) |
IP路由分册-04-OSPF |
1-63 |
vlink-peer (OSPFv3 area view) |
IP路由分册-09-OSPFv3 |
1-39 |
voice vlan aging |
接入分册-09-VLAN |
2-3 |
voice vlan enable |
接入分册-09-VLAN |
2-3 |
voice vlan mac-address |
接入分册-09-VLAN |
2-4 |
voice vlan mode auto |
接入分册-09-VLAN |
2-5 |
voice vlan security enable |
接入分册-09-VLAN |
2-6 |
voice-config |
IP业务分册-03-DHCP |
1-24 |
vpn-instance (ICMP-echo test type view) |
系统分册-12-NQA |
1-26 |
vpn-instance-capability simple |
IP路由分册-14-MCE |
1-25 |
vpn-target |
IP路由分册-14-MCE |
1-26 |
vrrp ipv6 method |
系统分册-14-VRRP |
1-17 |
vrrp ipv6 vrid authentication-mode |
系统分册-14-VRRP |
1-17 |
vrrp ipv6 vrid preempt-mode |
系统分册-14-VRRP |
1-18 |
vrrp ipv6 vrid priority |
系统分册-14-VRRP |
1-19 |
vrrp ipv6 vrid timer advertise |
系统分册-14-VRRP |
1-20 |
vrrp ipv6 vrid track |
系统分册-14-VRRP |
1-20 |
vrrp ipv6 vrid virtual-ip |
系统分册-14-VRRP |
1-21 |
vrrp method |
系统分册-14-VRRP |
1-5 |
vrrp un-check ttl |
系统分册-14-VRRP |
1-6 |
vrrp vrid authentication-mode |
系统分册-14-VRRP |
1-6 |
vrrp vrid preempt-mode |
系统分册-14-VRRP |
1-7 |
vrrp vrid priority |
系统分册-14-VRRP |
1-8 |
vrrp vrid timer advertise |
系统分册-14-VRRP |
1-9 |
vrrp vrid track |
系统分册-14-VRRP |
1-10 |
vrrp vrid track interface |
系统分册-14-VRRP |
1-11 |
vrrp vrid virtual-ip |
系统分册-14-VRRP |
1-11 |
