04-Network Connectivity Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C Wi-Fi 7 Access Points Cloud Mode Configuration Guides(R2610P06)-6W10004-Network Connectivity Configuration Guide
20-Basic IP routing configuration
20-Basic IP routing configuration 98.63 KB
Configuring basic IP routing
This chapter focuses on unicast routing protocols.
About IP routing
IP routing directs IP packet forwarding on routers. Based on the destination IP address in the packet, a router looks up a route for the packet in a routing table and forwards the packet to the next hop. Routes are path information used to direct IP packets.
Routing table
A RIB contains the global routing information and related information, including route recursion, route redistribution, and route extension information. The router selects optimal routes from the routing table and puts them into the FIB table. It uses the FIB table to forward packets.
Route categories
Table 1 categorizes routes by different criteria.
Table 1 Route categories
Criterion
Categories
Origin
·     Direct route—A direct route is discovered by the data link protocol on an interface, and is also called an interface route.
·     Static route—A static route is manually configured by an administrator.
·     Dynamic route—A dynamic route is dynamically discovered by a routing protocol.
Destination
·     Network route—The destination is a network. The subnet mask is less than 32 bits.
·     Host route—The destination is a host. The subnet mask is 32 bits.
Whether the destination is directly connected
·     Direct route—The destination is directly connected.
·     Indirect route—The destination is indirectly connected.
Route preference
Routing protocols, including static and direct routing, each by default have a preference. If they find multiple routes to the same destination, the router selects the route with the highest preference as the optimal route.
The preference of a direct route is always 0 and cannot be changed. You can configure a preference for each static route and each dynamic routing protocol. The following table lists the route types and default preferences. The smaller the value, the higher the preference.
Table 2 Route types and default route preferences
Route type
Preference
Direct route
0
Multicast static route
1
Unicast static route
60
Unknown (route from an untrusted source)
256
Route backup
Route backup can improve network availability. Among multiple routes to the same destination, the route with the highest priority is the primary route and others are secondary routes.
The router forwards matching packets through the primary route. When the primary route fails, the route with the highest preference among the secondary routes is selected to forward packets. When the primary route recovers, the router uses it to forward packets.
Route recursion
To use a staticroute that has an indirectly connected next hop, a router must perform route recursion to find the output interface to reach the next hop.
The RIB records and saves route recursion information, including brief information about related routes, recursive paths, and recursion depth.
Setting the maximum lifetime for routes and labels in the RIB
Perform this task to prevent routes of a certain protocol from being aged out due to slow protocol convergence resulting from a large number of route entries or long GR period.
The configuration takes effect at the next protocol or RIB process switchover.
Procedure (IPv4)
2.     Enter RIB view.
rib
3.     Create the RIB IPv4 address family and enter its view.
address-family ipv4
4.     Set the maximum lifetime for IPv4 routes and labels in the RIB.
protocol protocol lifetime seconds
By default, the maximum lifetime for routes and labels in the RIB is 480 seconds.
Procedure (IPv6)
2.     Enter RIB view.
rib
3.     Create the RIB IPv6 address family and enter its view.
address-family ipv6
4.     Set the maximum lifetime for IPv6 routes and labels in the RIB.
Setting the maximum lifetime for routes in the FIB
When GR is disabled, FIB entries must be retained for some time after a protocol process switchover or RIB process switchover. When GR is enabled, FIB entries must be removed immediately after a protocol or RIB process switchover to avoid routing issues. Perform this task to meet such requirements.
Procedure (IPv4)
2.     Enter RIB view.
rib
address-family ipv4
4.     Set the maximum lifetime for IPv4 routes in the FIB.
fib lifetime seconds
By default, the maximum lifetime for routes in the FIB is 600 seconds.
Procedure (IPv6)
2.     Enter RIB view.
rib
address-family ipv6
4.     Set the maximum lifetime for IPv6 routes in the FIB.
Configuring inter-protocol FRR
This feature is applicable to services that are sensitive to packet loss and latency. Inter-protocol fast reroute (FRR) enables fast rerouting between routes of different protocols. A backup next hop is automatically selected to reduce the service interruption time caused by unreachable next hops. When the next hop of the primary link fails, the traffic is redirected to the backup next hop.
Among the routes to the same destination in the RIB, a router adds the route with the highest preference to the FIB table. After you configure this feature, the device selects a route of another routing protocol as the backup route. When the next hop of the primary route is unreachable, the device forwards packets through the backup route.
This feature uses the next hop of a route from a different protocol as the backup next hop, which might cause loops.
If you configure both inter-protocol FRR and protocol-specific FRR, protocol-specific FRR takes effect.
Procedure (IPv4)
2.     Enter RIB view.
rib
address-family ipv4
4.     Enable IPv4 RIB inter-protocol FRR.
inter-protocol fast-reroute
By default, inter-protocol FRR is disabled.
Procedure (IPv6)
2.     Enter RIB view.
rib
address-family ipv6
4.     Enable IPv6 RIB inter-protocol FRR.
Display and maintenance commands for basic IP routing
Display routing table information.
display ip routing-table [ verbose ]
display ip routing-table [ all-routes ]
Display information about routes permitted by an IPv4 basic ACL.
display ip routing-table acl ipv4-acl-number [ verbose ]
Display information about routes to a specific destination address.
display ip routing-table ip-address [ mask-length | mask ] [ longer-match ] [ verbose ]
Display information about routes to a range of destination addresses.
display ip routing-table ip-address1 to ip-address2 [ verbose ]
Display information about routes permitted by an IP prefix list.
display ip routing-table  prefix-list prefix-list-name [ verbose ]
Display information about routes installed by a protocol.
display ip routing-table protocol protocol [ inactive | verbose ]
Display IPv4 route statistics.
display ip routing-table [ all-routes ] statistics
Display brief IPv4 routing table information.
display ip routing-table summary
display ipv6 routing-table [ all-routes ]
Display IPv6 RIB GR state information.
Display next hop information in the IPv6 RIB.
Display next hop information for IPv6 direct routes.
Display IPv6 routing table information.
display ipv6 routing-table [ verbose ]
Display information about routes permitted by an IPv6 basic ACL.
display ipv6 routing-table acl ipv6-acl-number [ verbose ]
Display information about routes to an IPv6 destination address.
display ipv6 routing-table ipv6-address [ prefix-length ] [ longer-match ] [ verbose ]
Display information about routes to a range of IPv6 destination addresses.
display ipv6 routing-table ipv6-address1 to ipv6-address2 [ verbose ]
Display information about routes permitted by an IPv6 prefix list.
display ipv6 routing-table prefix-list prefix-list-name [ verbose ]
Display information about routes installed by an IPv6 protocol.
display ipv6 routing-table protocol protocol [ inactive | verbose ]
Display IPv6 route statistics.
display ipv6 routing-table [ all-routes ] statistics
Display brief IPv6 routing table information.
display ipv6 routing-table summary
Display RIB GR state information.
display rib graceful-restart
Display next hop information in the RIB.
Display next hop information for direct routes.
Clear IPv4 route statistics.
reset ip routing-table statistics protocol { protocol | all }
reset ip routing-table [ all-routes ] statistics protocol { protocol | all }
Clear IPv6 route statistics.
reset ipv6 routing-table statistics protocol { protocol | all }
reset ipv6 routing-table [ all-routes ] statistics protocol { protocol | all } }
