- H3C Servers UniSystem Configuration Examples-6W102
- 01-UniSystem Bulk HDM&BIOS Import Configuration Examples
- 02-H3C UniSystem Cloning Installation Configuration Examples
- 03-UniSystem SMTP Configuration Examples
- 04-H3C UniSystem Cluster Creation Configuration Examples
- 05-H3C UniSystem SNMP Configuration Examples
- 06-H3C UniSystem RAID Configuration Examples
- 07-H3C UniSystem Rack Server Deployment Configuration Examples
- 08-UniSystem Bulk Component Update Configuration Examples
- 09-H3C UniSystem Server Inspection Configuration Example
- 10-H3C Unisystem REPO Acquisition and Use Configuration Examples
- 11-H3C UniSystem LDAP Management Configuration Example
- 12-H3C UniSystem Secure Erase Configuration Examples
- 13-H3C UniSystem Intelligent Version Management Configuration Examples
- 14-H3C UniSystem Bulk IP Settings Configuration Examples
| 14-H3C UniSystem Bulk IP Settings Configuration Examples | 823.21 KB |
H3C UniSystem
Copyright © 2025 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
NOTE: Starting from version 2.59, FIST software has been renamed as UniSystem. |
UniSystem supports multiple methods to bulk edit HDM management IP addresses of servers. The servers can be those managed by UniSystem or those not managed. The following editing methods apply to different scenarios as follows:
· IP Address—Applies to scenarios where the default HDM management IP address (192.168.1.2/24) for servers has changed.
· Port MAC and Serial Number—Applies to scenarios where the default HDM management IP address (192.168.1.2/24) for servers has not changed.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of bulk IP management.
· IP address modification method
¡ The current IP address of the HDM management port (shared or dedicated) is required. Both IPv4 and IPv6 addresses are supported.
¡ Make sure UniSystem can reach the above IP address.
· Port MAC modification method
¡ The current MAC address of the HDM management port (shared or dedicated) is required.
¡ Make sure the corresponding HDM management port (shared or dedicated) is on the same Layer 2 network as UniSystem and the IPv6 feature is enabled.
· Serial number modification method
¡ For G6 servers:
- The serial numbers of servers are required.
- Make sure the HDM management port (shared or dedicated) is on the same Layer 2 network as UniSystem and the IPv6 feature is enabled.
- Make sure SSDP is enabled on HDM and the port number is 1900, which are the default settings.
¡ For G3 and G5 servers:
- The address of the dedicated HDM port must be the default IP (192.168.1.2/24). Make sure UniSystem can communicate with the default IP address.
- Make sure the dedicated HDM management port is on the same Layer 2 network as UniSystem and the IPv6 feature is enabled.
- Obtain serial numbers of the servers where the default IP address is configured for the dedicated network port on the above Layer 2 network. Input the product serial numbers of the above servers and the corresponding IP modification information to the template.
· To edit the IP addresses of both the dedicated and shared HDM management ports, make sure the IP addresses of these two ports reside on different subnets to avoid potential network faults.
Example: Configuring bulk IP settings
As shown in Figure 1, connect the Ethernet port on the UniSystem server and the six servers to a switch on the same LAN, and configure IP addresses to ensure communication between UniSystem and the servers. Bulk edit the HDM management IP addresses of servers with the bulk IP setting feature of UniSystem. The network configuration is as shown in Table 1.
Table 1 Network configuration information
Device role |
Device configuration item |
HDM management IP after modification |
UniSystem |
UniSystem IP |
· 192.168.0.190/16 · 172.16.20.34/16 |
N/A |
Username of the default UniSystem administrator |
admin |
N/A |
Password of the default FIST administrator |
Password@_ |
N/A |
Server A |
Server model |
H3C UniServer B5800 G3 |
N/A |
HDM management IP |
192.168.1.152/16 |
172.16.1.152/16 |
Server B |
Server model |
N/A |
HDM management IP |
192.168.0.183/16 |
172.16.0.183/16 |
Server C |
Server model |
H3C UniServer R6900 G3 |
N/A |
HDM management port MAC |
38:AD:8E:E4:F7:24 |
172.16.31.69/16 |
Server D |
Server model |
H3C UniServer R4900 G3 |
N/A |
20:22:01:13:19:18 |
172.16.50.65/16 |
Server E |
Server model |
H3C UniServer R4900 G6 |
N/A |
Serial number |
210235A4HE5239C0005A |
172.16.49.62/16 |
Server F |
Server model |
H3C UniServer R4950 G6 |
N/A |
Serial number |
210235A4HE5239C0000Z |
172.16.20.175/16 |
Analysis
1. Log in to UniSystem, and then access the Network page to configure network settings.
2. Access the Server List > Bulk IP Settings page, select a method to bulk configure IP settings, and download a bulk IP setting template.
3. Input information in the template, and then upload the template.
4. Complete bulk IP settings.
Software versions used
This configuration example was created and verified on UniSystem-2.64.
Procedures
Logging in to UniSystem
1. Open a browser on the UniSystem client and enter the address of the UniSystem server.
2. As shown in Figure 2, enter the default username admin and password Password@_ on the login page.
3. Click Log In to access the UniSystem dashboard.
Configuring network settings
NOTE: If the HDM management IP address after modification and the UniSystem server IP address cannot communicate correctly, first configure a new IP address for UniSystem that can communicate with the HDM management IP address after modification. · The information in this section is applicable to only UniSystem running in AE modules and VMs. · If UniSystem is running on the PC, configure the IP address for the PC from Network and Sharing Center. |
To configure network settings:
1. Select Menu > System > Network.
2. Click Add IP Address. In the dialog box that opens, enter an IP address. Make sure the specified IP address can communicate with the HDM management IP address after modification.
3. Click OK.
Bulk editing IP addresses
Bulk editing IP addresses with the IP address modification method
1. Select Menu > Devices > Server List.
2. Click Bulk IP Settings.
Figure 7 Bulk editing IP settings
3. (Optional.) Click Usage Guidelines for more information about how to use this feature.
4. Select IP Address and click Download Template to obtain the template.
5. Input the current HDM management IP addresses, modified HDM management IP addresses, subnet masks, and gateways for servers A and B.
Figure 9 Template for bulk editing IP addresses with the IP address modification method
6. Click the … icon and select the device list file.
7. Click Upload. After the upload, you can view the uploaded device information from the device list.
Figure 10 Uploading the template
8. (Optional.) Configure the Auto Add After Modification field. This example selects True for this field for UniSystem to automatically manage the servers after modification.
9. (Optional.) Select a static group. This example selects No Static Group.
10. In the Username and Password fields, enter the HDM username and password, respectively.
11. Click OK. The system starts editing HDM management IP addresses of the servers in bulk.
Figure 11 Completed editing HDM management IP addresses successfully
Bulk editing IP addresses with the port MAC modification method
1. Select Port MAC and click Download Template to obtain the template.
2. Input the port MAC addresses of the HDM management ports, and modified IPv4 addresses, subnet masks, and gateways of the HDM management ports for servers C and D.
Figure 12 Template for editing IP addresses with the port MAC modification method
3. Click the … icon and select the device list file.
4. Click Upload. After the upload, you can view the uploaded device information from the device list.
Figure 13 Uploading the template
5. (Optional.) Configure the Auto Add After Modification field. This example selects True for this field for UniSystem to automatically manage the servers after modification.
6. (Optional.) Select a static group. This example selects No Static Group.
7. In the Username and Password fields, enter the HDM username and password, respectively.
8. Click OK. The system starts editing HDM management IP addresses of the servers in bulk.
Figure 14 Completed editing HDM management IP addresses successfully
Bulk editing IP addresses with the serial number modification method
1. Select Serial Number and click Download Template to obtain the template.
2. Input the serial numbers of servers E and F, and modified IPv4 addresses, subnet masks, and gateways of the HDM management ports for servers E and F.
Figure 15 Template for editing IP addresses with the serial number modification method
Figure 16 Uploading the template
Figure 17 Completed editing HDM management IP addresses successfully
2. Verify that the target servers have been added to the server list and the modified HDM management IP addresses of the servers have been edited successfully.
Related documentation
H3C Servers UniSystem User Guide
