- 09-WLAN Advanced Features
- 01-Wireless Spectrum Analysis Configuration Example
- 02-Auto DFS Configuration Examples
- 03-Auto TPC Configuration Examples
- 04-Whitelist-Based Client Access Control Configuration Example
- 05-Blacklist-Based Client Access Control Configuration Example
- 06-CAC Configuration Example
- 07-WLAN Probe Configuration Example
- 08-Intra-AC Roaming Configuration Example
- 09-Bonjour Gateway Configuration Example
- 10-IPv4 Multicast Optimization Configuration Examples
- 11-IPv6 Multicast Optimization Configuration Examples
| 06-CAC Configuration Example | 131.63 KB |
H3C Access Controllers |
Comware 7 CAC Configuration Example |
Overview
The following information provides an example for configuring Connect Admission Control (CAC) to limit the number of clients that can use high-priority AC queues.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of CAC.
Example: Configuring CAC
As shown in Figure 1, configure CAC to allow only one client to use the AC-VO and AC-VI queues at one time to guarantee bandwidth for high-priority traffic.
Procedures
1. Click the Network View tab at the bottom of the page.
2. From the navigation pane, select Wireless Configuration > Wireless QoS.
3. On the Wi-Fi Multimedia tab, click the More icon
from the EDCA parameters for clients area.
4. Click the Edit icon
for the target
radio and configure EDCA parameters as follows:
¡ Select Based on number of clients from the CAC policy field.
¡ Set the maximum number of clients to 1.
¡ Select Enable for AC-VI and AC-VO.
Figure 2 Configuring EDCA parameters
# Verify that the other clients cannot use a high-priority AC queue (AC-VO or AC-VI) when an online client already uses a high-priority AC queue.
Related documentation
H3C Access Controllers Web-Based Configuration Guide
