09-WLAN Advanced Features
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers Web-Based Configuration Examples-6W10009-WLAN Advanced Features
10-IPv4 Multicast Optimization Configuration Examples
Comware 7 IPv4 Multicast Optimization Configuration Examples
Introduction
The following information provides an example for configuring IPv4 multicast optimization.
This example is applicable to the scenario where high quality and efficiency are required for IPv4 multicast data transmission.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of IPv4 multicast optimization and WLAN access.
Example: Configuring IPv4 multicast optimization
As shown in Figure 1, the source connected to the AC provides the IPv4 multicast service, and the AP provides wireless services to the clients through SSID service. Configure IPv4 multicast optimization to manage multicast packet forwarding.
Figure 1 Network diagram
Procedures
Configuring basic AC settings
Configure wireless service, IPv4 address, AP access, and radio settings on the AC. (Details not shown.)
1.     Click the Network View tab at the bottom of the page.
2.     From the navigation pane, select Wireless Configuration > Applications.
3.     Click the Multicast Optimization tab and then click the More icon  in the upper right corner of the IPv4 Multicast Optimization area.
Figure 2 Multicast Optimization page
4.     On the page that opens, select the WLAN service with SSID service.
5.     Click On.
Figure 3 Enabling multicast optimization
6.     Click the Advanced Configuration tab and perform the following actions:
¡     Set the entry aging time to 300 seconds.
¡     Set the entry limit to 100 and set the entry limit per client to 10.
¡     Set the client limit per group to 2 and set the action to drop multicast packets.
¡     Use the default settings for the other parameters.
¡     Click Apply.
Figure 4 Configuring the advanced configuration
# Connect Client 1, Client 2, and Client 3 to the WLAN service with SSID service.
# Send IGMP reports from Client 1 and Client 2 to join the IPv4 multicast group that the source uses to forward IPv4 multicast data. Both Client 1 and Client 2 can receive the IPv4 multicast data.
# Send an IGMP report from Client 3 to join the IPv4 multicast group. None of the clients can receive the IPv4 multicast data.
Related documentation
H3C Access Controllers Web-Based Configuration Guide
