- 09-WLAN Advanced Features
- 01-Wireless Spectrum Analysis Configuration Example
- 02-Auto DFS Configuration Examples
- 03-Auto TPC Configuration Examples
- 04-Whitelist-Based Client Access Control Configuration Example
- 05-Blacklist-Based Client Access Control Configuration Example
- 06-CAC Configuration Example
- 07-WLAN Probe Configuration Example
- 08-Intra-AC Roaming Configuration Example
- 09-Bonjour Gateway Configuration Example
- 10-IPv4 Multicast Optimization Configuration Examples
- 11-IPv6 Multicast Optimization Configuration Examples
| 05-Blacklist-Based Client Access Control Configuration Example | 90.25 KB |
H3C Access Controllers |
Comware 7 Static Blacklist-Based Client Access Control Configuration Example |
Overview
The following information provides an example for configuring static blacklist-based client access control.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of the static client blacklist.
Example: Configuring static blacklist-based client access control
As shown in Figure 1, configure the static blacklist to forbid the client whose MAC address is 4c-c0-0a-df-f6-4f to access the WLAN.
Procedures
1. Click the Network View tab at the bottom of the page.
2. From the navigation pane, select Wireless Configuration > Wireless Security.
3. On the Whitelist and blacklist tab, click
the More icon
from
the Static Blacklist area.
4. Click the Add button
to
add MAC address 4c-c0-0a-df-f6-4f to the static blacklist.
Figure 2 Adding a MAC address to the static blacklist
3. On the Whitelist and blacklist tab, verify that MAC address 4c-c0-0a-df-f6-4f has been added to the static blacklist.
Figure 3 Verifying static blacklist configuration
4. Verify that the client whose MAC address is 4c-c0-0a-df-f6-4f cannot access the WLAN and the other clients can access the WLAN.
Related documentation
H3C Access Controllers Web-Based Configuration Guide
