H3C SecPath M9000-X Multiservice Security Gateway Series Installation Guide-6W100
HomeSupportSecurityH3C SecPath M9000-XH3C SecPath M9000-XTechnical DocumentsInstall & UpgradeInstallation GuidesH3C SecPath M9000-X Multiservice Security Gateway Series Installation Guide-6W100
09-Appendix C LEDs
09-Appendix C LEDs 824.47 KB
Appendix C LEDs
The M9000-X gateway series provides a lot of LEDs. You can determine the gateway operating status by examining the LEDs.
Supervisor engine module (SEM) LEDs
Figure 1 NSQM7SUPA0 SEM LEDs
(1) Fan tray status LED (FAN)
(2) Card status LEDs
(3) SEM active/standby status LED
(4) Power status LED (PWR)
(5) Fiber management Ethernet port LED
(6) Copper management Ethernet port LED
Figure 2 NSQM7SUPB0 SEM LEDs
(1) Fiber management Ethernet port LEDs
(2) Coper management Ethernet port LEDs
(3) Fan tray status LEDs
(4) Card status LEDs
(5) SEM active/standby status LED
(6) Power status LEDs
Figure 3 NSQM7SUPA0-CN SEM LEDs
(6) Coper management Ethernet port LED
Figure 4 NSQM7SUPB0-CN SEM LEDs
Fiber/copper management Ethernet port LEDs
Each SEM has management Ethernet fiber/copper port LEDs to indicate the link status and data forwarding status of the management Ethernet port.
Table 1 Description for the fiber/copper management Ethernet port LED on the NSQM7SUPA0/NSQM7SUPB0 SEM
LINK
Flashing
A link is present on the port, and the port is receiving or sending data.
Steady on
A link is present.
Off
No link is present.
Table 2 Description for the copper management Ethernet port LED on the NSQM7SUPA0-CN/NSQM7SUPB0-CN SEM
LINK
ACT
Steady on
Flashing
Steady on
Off
A link is present.
Off
Off
No link is present.
Table 3 Description for the fiber management Ethernet port LED on the NSQM7SUPA0-CN/NSQM7SUPB0-CN SEM
LINK
Flashing
Steady on
A link is present.
Off
No link is present.
Power status LED
Each SEM provides power status LEDs to indicate the operating status of power supplies.
Table 4 Description for the power status LED on the NSQM7SUPB0 SEM
OK
FAIL
On
Off
The power supplies are operating correctly.
Off
On
One or multiple power supplies are faulty.
Off
Off
The gateway is not powered on.
Table 5 Description for the power status LED on the NSQM7SUPA0/NSQM7SUPA0-CN/NSQM7SUPB0-CN
Status
Steady green
Steady red
Off
Each SEM provides fan tray status LEDs to indicate the operating status of fan trays.
Table 6 Description for the fan tray status LEDs on NSQM7SUPB0
OK
FAIL
Steady on
Off
All fan trays are operating correctly.
Off
Steady on
A fan tray has failed, or no fan tray is present.
Off
Off
Table 7 Description for the fan tray status LED on the NSQM7SUPA0/NSQM7SUPA0-CN/NSQM7SUPB0-CN
Status
Steady green
Steady red
A fan tray has failed or no fan tray is present.
Off
Each SEM has one ACTIVE LED to indicate the active or standby status of the SEM.
Table 8 SEM ACTIVE LED description
LED status
Steady on
The SEM is active.
Off
·     The SEM is in standby status.
·     The SEM has failed. Examine the card LED for an SEM problem.
Card LEDs
Each SEM has the LEDs numbered the same as card slots to indicate the status of the active SEM, standby SEM, interface switch modules, service modules, and switching fabric modules in the slots. Table 9 and Table 10 show the LED descriptions.
Table 9 Description for the card LEDs on the NSQM7SUPB0
RUN
ALM
Flashing at 4 Hz
Steady on
The card is loading software. If the LEDs keep in this state, the card software version is not compatible with the gateway software version.
Flashing at 0.5 Hz
Off
The card is operating correctly.
Flashing at 0.25 Hz
The card temperature has exceeded the upper warning threshold or dropped below the lower warning threshold.
Steady on
Steady on
The card is in boot state or has failed.
Off
Off
The card is not present.
Table 10 Description for the card status LEDs on the NSQM7SUPA0/NSQM7SUPA0-CN/NSQM7SUPB0-CN SEM
LED status
Flashing green (0.5 Hz)
Flashing green (4 Hz)
The card is loading software. If the LED remain in this state, the software of the card does not match that of the device.
Steady green
The card is starting up.
Steady red
A major alarm or fault is present on the card.
Flashing red (0.25 Hz)
Off
The card is not present or is faulty.
Firewall module LEDs
The NS-FWFFGA0, NS-FWFFGB0, NS-FWFFGC0, NS-FWFFGD0, and NS-FWFAMA1 firewall modules provide multiple LEDs to indicate the firewall module operating status.
Table 11 Description for the LEDs on the NS-FWFFGA0/NS-FWFFGB0/NS-FWFFGC0/NS-FWFFGD0 firewall module
LED
Mark
Status
Module status LED
Steady green
The card is operating correctly, or a minor alarm is present.
HDM is initializing.
Flashing orange (1 Hz)
A major alarm is present.
Flashing red (1 Hz)
A critical alarm is present.
System power/standby LED
Steady green
The system has powered up.
Flashing green
The system is powering up.
Steady orange
The system is in standby state.
Off
The system is powered off.
CPU status LED
RUN
Fast flashing green
The CPU is loading software.
Slow flashing green
The CPU is operating correctly.
Steady red
A fault is present on the CPU.
Off
The CPU is not running.
Steady green
A 1 Gbps link is present on the port.
Flashing green
The port is sending or receiving data at 1 Gbps.
Steady yellow
A 10/100 Mbps link is present on the port.
Flashing yellow
The port is sending or receiving data at 10/100 Mbps.
Off
The port is not connected.
100GBSAE-R fiber port LED
Off
No link is present on the port.
Steady green
A link is present on the port.
Flashing green
The port is sending or receiving data.
Table 12 Description for the LEDs on the NS-FWFAMA1 firewall module
LED
Mark
Status
CPU status LED
RUN
Fast flashing green
Slow flashing green
Steady red
Off
Steady green
A Gigabit link is present on the port.
Flashing green
Off
Off
Steady green
Flashing green
Switching fabric module LEDs
NSQM5FAB08A1 switching fabric module LEDs
The NSQM7FAB06A0 and NSQM7FAB10A0 switching fabric modules and the fan tray that convers the switching fabric modules each provide a status LED to indicate the operation status for the switching fabric modules.
Table 13 Switching fabric module LED description
LED
Mark
Status
Status LED
RUN/ALM
Steady green
The switching fabric module is operating correctly.
Steady red
The switching fabric module is faulty, or is loading software.
Off
The switching fabric module is not present.
Table 14 Description for the switching fabric module LED on the fan tray
RUN LED
ALM LED
Flashing (1 Hz)
Off
Off
On
The switching fabric module is faulty.
Flashing (1 Hz)
On
The switching fabric module is loading software or is operating incorrectly, for example, the temperature of the switching fabric module has exceeded the upper or lower limit.
Off
Off
The switching fabric module has not started or is not powered on.
On
On
The switching fabric module is in boot state.
Interface module LEDs
The interface modules provide port LEDs to indicate the link status and data receiving/forwarding status of the ports.
10GE fiber port LED
Table 15 10GE fiber port LED description
LED status
Flashing
The port is receiving or sending data at 10 Gbps.
On
A 10 Gbps link is present.
Off
No link is present.
40GE fiber port LED
Table 16 40GE fiber port LED description
LED status
Flashing
The port is receiving or sending data at 40 Gbps.
On
A 40 Gbps link is present.
Off
No link is present.
100GE fiber port LEDs
Table 17 100GE fiber port LED description
LED status
Flashing
The port is receiving or sending data at 100 Gbps.
On
A link is present.
Off
No link is present.
The fan trays for the M9000-X gateways provide LEDs to indicate their operating status.
Table 18 M9000-X06 fan tray LED description
OK
FAIL
On
Off
The fan tray is operating correctly.
Off
On
The fan tray is faulty.
Off
Off
The fan tray is not powered on.
Table 19 M9000-X10 fan tray LED description
OK/FAIL LED status
Off
The fan tray is faulty or not powered on.
Steady green
Steady red
Power supply LEDs
The PSR2400-54A, PSR2400-54D, and PSR3000-54A power supplies each have one AC OK LED and one DC OK LED to indicate its operating status. The PSR3000-54AHD power supply has one IN OK LED and one OUT OK LED to indicate its operating status.
Table 20 PSR2400-54A/PSR2400-54D/PSR3000-54A power supply LED description
LED
Status
AC OK
Off
·     The power supply does not have power input.
·     The input voltage is too low, and the power supply is in self protection state.
Green
DC OK
Green
The power supply is outputting power correctly.
Orange
The power supply is in an over-temperature condition.
Red
The power supply is experiencing an output problem, including output short-circuit, output overcurrent, output overvoltage, input under-voltage, or remote power off, and has entered self protection state.
Table 21 PSR3000-54AHD power supply LED description
LED
Status
IN OK
Off
Green
OUT OK
Green
Orange
Red
