- H3C SecPath M9000-X Multiservice Security Gateway Series Installation Guide-6W100
- 01-Chapter 1 Chassis views
- 02-Chapter 2 Preparing for Installation
- 03-Chapter 3 Installing the Gateway
- 04-Chapter 4 Accessing the Gateway and Configuring Basic Settings
- 05-Chapter 5 Troubleshooting
- 06-Chapter 6 Replacing Removable Components
- 07-Appendix A FRUs and Compatibility Matrixes
- 08-Appendix B Technical Specifications
- 09-Appendix C LEDs
- 10-Appendix D Cables
- 11-Appendix E Slot arrangement and interface numbering
- 12-Appendix F Engineering labels
- 13-Appendix G Cabling Recommendations
- 14-Appendix H Repackaging the Gateway
00-Preface | 106.62 KB |
Preface
This installation guide describes the installation procedure for the H3C SecPath M9000-X multiservice security gateway series. It includes the following topics:
· Chassis views.
· Preparing for installation.
· Installing the gateway.
· Accessing the gateway and configuring basic settings.
· Troubleshooting.
· Replacing removable components.
· FRUs and compatibility matrixes.
· Technical specifications.
· LEDs.
· Cables.
· Slot arrangement and interface numbering.
· Engineering labels.
· Cabling recommendations.
· Repackaging the gateway.
This preface includes:
· Audience
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the M9000-X security gateway series
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
NOTE |
Network topology icons
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Documentation feedback
We appreciate your comments.
