- 04-Comware 7 CLI-based configuration examples (AC+fit AP deployment)
- 01-HTTPS Login Configuration Examples
- 02-SSH Configuration Examples
- 03-License Management Configuration Examples
- 04-AP Association with the AC at Layer 2 Configuration Examples
- 05-AP Association with the AC at Layer 2 (IPv6) Configuration Examples
- 06-Auto AP Configuration Examples
- 07-AP Association with the AC at Layer 3 Configuration Examples
- 08-AP Association with the AC at Layer 3 (IPv6) Configuration Examples
- 09-WEP Encryption Configuration Examples
- 100-Static Blacklist Configuration Examples
- 101-Client Quantity Control Configuration Examples
- 102-AP License Synchronization Configuration Examples
- 103-BLE Module iBeacon Transmission Configuration Examples
- 104-Medical RFID Tag Management Configuration Examples
- 105-iBeacon Management Configuration Examples
- 106-Mesh Link Establishment Between Fit APs Configuration Examples
- 107-Mesh Link Establishment Between a Fit AP and a Fat AP Configuration Examples
- 108-Auto-DFS and Auto-TPC Configuration Examples
- 109-AP Image Downloading Configuration Examples
- 10-PSK Encryption Configuration Examples
- 110-Dual-Uplink Interfaces Configuration Guide
- 111-H3C Comware AC Cloud-Managed AP Centralized Management Configuration Examples
- 112-Internal-to-External Access Through NAT Configuration Examples
- 113-Layer 2 Static Aggregation Configuration Examples
- 114-Layer 2 Multicast Configuration Examples
- 115-Static VLAN Allocation Configuration Examples
- 116-URL Redirection Configuration Examples
- 117-IPv6 URL Redirection Configuration Examples
- 11-WPA3-SAE PSK Encryption Configuration Examples
- 12-WLAN Access (IPv6) Configuration Examples
- 13-Policy-Based Forwarding with Dual Gateways Configuration Examples
- 14-Scheduled Configuration Deployment by AP Group Configuration Examples
- 15-Inter-AC Roaming with Static Client VLAN Allocation Configuration Examples
- 16-Service Template and Radio Binding Configuration Examples
- 17-Scheduled WLAN Access Services Configuration Examples
- 18-HTTPS-Based Local Portal Authentication Configuration Examples
- 19-Remote Portal Authentication Configuration Examples
- 20-Local Portal Authentication through LDAP Server Configuration Examples
- 21-Local Portal Auth and SSID-based Auth Page Pushing Configuration Examples
- 22-Local Portal MAC-Trigger Authentication Configuration Examples
- 23-Portal MAC-Trigger Authentication Configuration Examples
- 24-Local Forwarding Mode and Local Portal MAC-Trigger Auth Configuration Examples
- 25-Local Portal Authentication (IPv6) Configuration Examples
- 26-Local Portal Authentication through LDAP Server (IPv6) Configuration Examples
- 27-Remote Portal Authentication (IPv6) Configuration Examples
- 28-Portal MAC-Trigger Authentication (IPv6) Configuration Example
- 29-Remote Portal Authentication with User Profile Authorization Configuration Examples
- 30-WiFiDog Portal Authentication Configuration Examples
- 31-Portal Fail-Permit Configuration Examples
- 32-Local MAC Authentication Configuration Examples
- 33-Remote MAC Authentication Configuration Examples
- 34-Local Portal Authentication Configuration Examples
- 35-Transparent Auth Through Remote MAC and Portal Auth Configuration Examples
- 36-Remote AP, Remote Portal, and MAC-Trigger Authentication Configuration Examples
- 37-MAC Authentication with Guest VLAN Assignment Configuration Examples
- 38-MAC Authentication with Guest VLAN Assignment (IPv6) Configuration Examples
- 39-Local MAC-And-802.1X Authentication Configuration Examples
- 40-Local 802.1X Authentication Configuration Examples
- 41-Local RADIUS-Based 802.1X Authentication in EAP Relay Mode Configuration Examples
- 42-Remote 802.1X Authentication Configuration Examples
- 43-Remote 802.1X Authentication (IPv6) Configuration Examples
- 44-Remote 802.1X Authentication in WPA3-Enterprise Mode Configuration Examples
- 45-802.1X Auth with ACL Assignment Through IMC Server Configuration Examples
- 46-802.1X Auth with User Profile Assignment Through IMC Server Configuration Examples
- 47-EAD Authentication Configuration Examples
- 48-EAD Authentication (IPv6) Configuration Examples
- 49-Local Forwarding Mode and Local Portal Authentication Configuration Examples
- 50-Local Forwarding Mode Direct Portal Authentication Configuration Examples
- 51-Local Forwarding Mode Direct Portal Authentication (IPv6) Configuration Examples
- 52-Local Forwarding Configuration Examples
- 53-Wired Port Local Forwarding through Wireless Terminator Configuration Examples
- 54-Remote AP Configuration Examples
- 55-Downlink VLAN Management for Fit-Mode APs Configuration Examples
- 56-Downlink VLAN Management for Fit APs and Cloud APs Configuration Examples
- 57-WIPS Configuration Examples
- 58-WIPS Countermeasures Against All SSIDs Configuration Examples
- 59-IP Source Guard (IPv4) Configuration Examples
- 60-IP Source Guard (IPv6) Configuration Examples
- 61-IPS Configuration Examples
- 62-URL Filtering Configuration Examples
- 63-Anti-Virus Configuration Examples
- 64-Data Filtering Configuration Examples
- 65-File Filtering Configuration Examples
- 66-Application Audit and Management Configuration Examples
- 67-Application Rate Limiting Configuration Examples
- 68-IRF Setup with LACP MAD Configuration Examples
- 69-IRF Setup with ARP MAD Configuration Examples
- 70-IRF Setup with Members Not Directly Connected Configuration Examples
- 71-IRF Setup with Members in One Chassis Configuration Examples
- 72-IRF Setup with Members in Different Chassis Configuration Examples
- 73-Dual-Link Backup Configuration Examples
- 74-Remote 802.1X Auth on an AC Hierarchy Network with Dual-Link Backup Configuration Examples
- 75-Remote Portal Auth on an AC Hierarchy Network with Dual-Link Backup Configuration Examples
- 76-OAuth-Based Portal MAC-Trigger Auth on a Local-Forwarding Dual-Link Backup Configuration Examples
- 77-Dual-Link Backup OAuth-Based Portal Authentication in Local Forwarding Configuration Examples
- 78-Dual-Link Backup Remote Portal MAC-Trigger Authentication in Local Forwarding Configuration Examples
- 79-Dual-Link Backup Remote Portal and Transparent MAC Auth in Local Forwarding Configuration Examples
- 80-Dual-Link Backup Remote Portal Authentication in Local Forwarding Configuration Examples
- 81-Dual-Link Backup Remote Portal and Transparent MAC Auth in Centralized Forwarding Configuration Examples
- 82-Dual-Link Backup Remote Portal Authentication in Centralized Forwarding Configuration Examples
- 83-Dual-Link Backup Lightweight Portal Authentication in Centralized Forwarding Configuration Examples
- 84-Dual-Link Backup OAuth-Based Portal Authentication in Centralized Forwarding Configuration Examples
- 85-Dual-Link Backup Remote Portal MAC-Trigger Auth in Centralized Forwarding Configuration Examples
- 86-Remote 802.1X Authentication on a Dual-Link AC Backup Network Configuration Examples
- 87-Remote MAC Authentication on a Dual-Link AC Backup Network Configuration Examples
- 88-AC Hierarchy Configuration Examples
- 89-Remote 802.1X Auth (Local AC Auth+AC Forwardering) Configuration Examples
- 90-Remote 802.1X Auth (Central AC Auth+AP Forwarding) Configuration Examples
- 91-AC Hierarchy (IPv6) Configuration Examples
- 92-WLAN Probe Configuration Examples
- 93-Multicast Optimization Configuration Examples
- 94-Client Rate Limiting Configuration Examples
- 95-Inter-AC Roaming Configuration Examples
- 96-Inter-AC Roaming (IPv6) Configuration Examples
- 97-Inter-AC Roaming in Local Forwarding Mode Configuration Examples
- 98-H3C Access Controllers Cooperative Roaming for 802.11v Clients Configuration Examples
| 97-Inter-AC Roaming in Local Forwarding Mode Configuration Examples | 300.48 KB |
H3C Access Controllers |
Inter-AC Roaming in Local Forwarding Mode |
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring inter-AC roaming in local forwarding mode
Configuring the configuration files
Introduction
The following information provides an example for configuring inter-AC roaming in local forwarding mode.
The following information applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of WLAN access and WLAN roaming.
As shown in Figure 1, AP 1 and AP 2 are managed by AC 1 and AC 2, respectively. Clients associated with AC 1 belong to VLAN 200. Clients associated with AC 2 belong to VLAN 400.
Complete the following tasks:
· Configure inter-AC roaming to enable clients to roam between AP 1 and AP 2.
· Enable local forwarding of client traffic.
· Configure VLAN-based user isolation to improve user security and reduce radio resource consumption caused by multicast and broadcast packets.
Device |
IP address |
AC 1 |
VLAN-interface 100 |
192.1.0.2/16 |
AC 2 |
192.1.0.3/16 |
Switch 3 |
192.1.0.1/16 |
VLAN-interface 200 |
192.2.0.1/16 |
VLAN-interface 300 |
192.3.0.1/16 |
VLAN-interface 400 |
192.4.0.1/16 |
Analysis
· To implement inter-AC roaming, add the two ACs to the same mobility group.
· To implement fast roaming, configure RSN + 802.1X authentication for clients.
· A client will inherit the roaming VLAN when it roams between ACs, so you must assign the data forwarding links of the APs to all service VLANs.
· To assign the interfaces on the APs to the local forwarding service VLANs and configure VLAN-based isolation, execute the map-configuration command on the AC to deploy a configuration file to each AP.
When you configure inter-AC roaming in local forwarding mode, follow these restrictions and guidelines:
· Make sure the configured SSID, authentication and key management (AKM) mode, and cipher suite are the same on APs for wireless roaming.
· Make sure no Tab or space exists at the end of each command line in the configuration file to be deployed by using the map-configuration command.
· Use the serial ID labeled on the AP's rear panel to specify an AP.
Procedures
IMPORTANT: The configuration files are in .txt format and contain commands to be deployed to specific APs. To configure an AP, upload the AP configuration file to the AC and execute the map-configuration command after the AP establishes CAPWAP tunnels with the AC. The system then executes commands in the configuration file on the AP in sequence. |
Assign the uplink interfaces on the APs to all service VLANs (VLAN 200 and VLAN 400), and specify the MAC address of the gateway as the permitted MAC address for the service VLANs.
# Configure the configuration file of AP 1 as follows:
vlan 200
vlan 400
interface GigabitEthernet 1/0/1
port link-type trunk
port trunk permit vlan 200 400
user-isolation vlan 200 permit-mac 000f-e212-7788
user-isolation vlan 200 enable
# Configure the configuration file of AP 2 as follows:
vlan 200
vlan 400
user-isolation vlan 400 permit-mac 000f-e212-7788
user-isolation vlan 400 enable
Configuring AC 1
1. Configure interfaces on AC 1:
# Create VLAN 100 and VLAN-interface 100, and assign IP address 192.1.0.2/16 to the interface. The AC will use this IP address to establish CAPWAP tunnels with APs.
<AC1> system-view
[AC1] vlan 100
[AC1-vlan100] quit
[AC1] interface vlan-interface 100
[AC1-Vlan-interface100] ip address 192.1.0.2 16
[AC1-Vlan-interface100] quit
# Configure interface GigabitEthernet 1/0/1 that connects AC 1 to Switch 3 as an access port, and assign the port to VLAN 100.
[AC1] interface gigabitethernet 1/0/1
[AC1-GigabitEthernet1/0/1] port link-type access
[AC1-GigabitEthernet1/0/1] port access vlan 100
[AC1-GigabitEthernet1/0/1] quit
2. Configure 802.1X authentication:
# Set the 802.1X authentication method to EAP.
[AC1] dot1x authentication-method eap
# Create RADIUS scheme office and enter its view.
[AC1] radius scheme office
# Specify the IP address of the primary RADIUS authentication server as 192.3.0.2.
[AC1-radius-office] primary authentication 192.3.0.2
# Specify the IP address of the primary RADIUS accounting server as 192.3.0.2.
[AC1-radius-office] primary accounting 192.3.0.2
# Set the shared key to 12345678 in plaintext form for communication with the authentication server.
[AC1-radius-office] key authentication simple 12345678
# Set the shared key to 12345678 in plaintext form for communication with the accounting server.
[AC1-radius-office] key accounting simple 12345678
# Specify 192.1.0.2 as the NAS IPv4 address of RADIUS packets.
[AC1-radius-office] nas-ip 192.1.0.2
[AC1-radius-office] quit
# Create ISP domain office and enter its view.
[AC1] domain office
# Perform RADIUS authentication for LAN users based on scheme office.
[AC1-isp-office] authentication lan-access radius-scheme office
# Perform RADIUS authorization for LAN users based on scheme office.
[AC1-isp-office] authorization lan-access radius-scheme office
# Perform RADIUS accounting for LAN users based on scheme office.
[AC1-isp-office] accounting lan-access radius-scheme office
[AC1-isp-office] quit
3. Configure wireless access services:
# Create wireless service template 1 and enter its view.
[AC1] wlan service-template 1
# Set the SSID of the service template to service.
[AC1-wlan-st-1] ssid service
# Assign the service template to VLAN 200.
[AC1-wlan-st-1] vlan 200
# Configure APs to forward client data traffic.
[AC1-wlan-st-1] client forwarding-location ap
# Set the authentication and key management mode to 802.1X.
[AC1-wlan-st-1] akm mode dot1x
# Set the user access authentication mode to 802.1X authentication.
[AC1-wlan-st-1] client-security authentication-mode dot1x
# Specify ISP domain office as the authentication domain for 802.1X clients in service template 1.
[AC1-wlan-st-1] dot1x domain office
# Set the cipher suite to AES-CCMP.
[AC1-wlan-st-1] cipher-suite ccmp
# Enable the RSN IE in beacon and probe responses.
[AC1-wlan-st-1] security-ie rsn
# Enable the service template.
[AC1-wlan-st-1] service-template enable
[AC1-wlan-st-1] quit
4. Configure APs:
IMPORTANT: In a large-scale network, configure AP groups as a best practice. |
# Create AP ap1, and specify its model and serial number.
[AC1] wlan ap ap1 model WA6320
[AC1-wlan-ap-ap1] serial-id 219801A28N819CE0002T
# Create AP group group1, create an AP grouping rule by AP names and an AP grouping rule by AP models, bind wireless service template 1 to radio 1, and enable radio 1.
[AC1] wlan ap-group group1
[AC1-wlan-ap-group-group1] ap ap1
[AC1-wlan-ap-group-group1] ap-model WA6320
[AC1-wlan-ap-group-group1-ap-model-WA6320] radio 1
[AC1-wlan-ap-group-group1-ap-model-WA6320-radio-1] radio enable
[AC1-wlan-ap-group-group1-ap-model-WA6320-radio-1] service-template 1
[AC1-wlan-ap-group-group1-ap-model-WA6320-radio-1] quit
[AC1-wlan-ap-group-group1-ap-model-WA6320] quit
5. Configuring roaming:
# Create mobility group 1 and enter its view.
[AC1] wlan mobility group 1
# Specify 192.1.0.2 as the source IP address for establishing IACTP tunnels.
[AC1-wlan-mg-1] source ip 192.1.0.2
# Configure AC 1 as a member of mobility group 1, and specify 192.1.0.3 as the source IP address for establishing IACTP tunnels.
[AC1-wlan-mg-1] member ip 192.1.0.3
# Enable mobility group 1.
[AC1-wlan-mg-1] group enable
[AC1-wlan-mg-1] quit
6. Configure the default route:
# Configure the next hop of the default route to AC 1 as 192.1.0.1. The default route is used for the communication between AC 1 and the RADIUS server.
[AC1] ip route-static 0.0.0.0 0.0.0.0 192.1.0.1
Configuring AC 2
1. Configure interfaces on AC 2:
# Create VLAN 100 and VLAN-interface 100, and assign IP address 192.1.0.3/16 to the interface. The AC will use this IP address to establish CAPWAP tunnels with APs.
<AC2> system-view
[AC2] vlan 100
[AC2-vlan100] quit
[AC2] interface vlan-interface 100
[AC2-Vlan-interface100] ip address 192.1.0.3 16
[AC2-Vlan-interface100] quit
# Configure interface GigabitEthernet 1/0/1 that connects AC 2 to Switch 3 as an access port, and assign the port to VLAN 100.
[AC2] interface gigabitethernet 1/0/1
[AC2-GigabitEthernet1/0/1] port link-type access
[AC2-GigabitEthernet1/0/1] port access vlan 100
[AC2-GigabitEthernet1/0/1] quit
[AC2] dot1x authentication-method eap
[AC2] radius scheme office
[AC2-radius-office] primary authentication 192.3.0.2
[AC2-radius-office] primary accounting 192.3.0.2
[AC2-radius-office] key authentication simple 12345678
[AC2-radius-office] key accounting simple 12345678
# Specify 192.1.0.3 as the NAS IPv4 address of RADIUS packets.
[AC2-radius-office] nas-ip 192.1.0.3
[AC2-radius-office] quit
[AC2] domain office
[AC2-isp-office] authentication lan-access radius-scheme office
[AC2-isp-office] authorization lan-access radius-scheme office
[AC2-isp-office] accounting lan-access radius-scheme office
[AC2-isp-office] quit
[AC2] wlan service-template 1
[AC2-wlan-st-1] ssid service
# Assign the service template to VLAN 400.
[AC2-wlan-st-1] vlan 400
[AC2-wlan-st-1] client forwarding-location ap
[AC2-wlan-st-1] akm mode dot1x
[AC2-wlan-st-1] client-security authentication-mode dot1x
[AC2-wlan-st-1] dot1x domain office
[AC2-wlan-st-1] cipher-suite ccmp
[AC2-wlan-st-1] security-ie rsn
[AC2-wlan-st-1] service-template enable
[AC2-wlan-st-1] quit
4. Configure APs:
# Create AP ap2, and specify its model and serial number.
[AC2] wlan ap ap2 model WA6320
[AC2-wlan-ap-ap2] serial-id 219801A28N819CE0002U
# Create AP group group2, create an AP grouping rule by AP names and an AP grouping rule by AP models, bind wireless service template 1 to radio 1, and enable radio 1.
[AC2] wlan ap-group group2
[AC2-wlan-ap-group-group2] ap ap2
[AC2-wlan-ap-group-group2] ap-model WA6320
[AC2-wlan-ap-group-group2-ap-model-WA6320] radio 1
[AC2-wlan-ap-group-group2-ap-model-WA6320-radio-1] radio enable
[AC2-wlan-ap-group-group2-ap-model-WA6320-radio-1] service-template 1
[AC2-wlan-ap-group-group2-ap-model-WA6320-radio-1] quit
[AC2-wlan-ap-group-group2-ap-model-WA6320] quit
[AC2] wlan mobility group 1
# Specify 192.1.0.3 as the source IP address for establishing IACTP tunnels.
[AC2-wlan-mg-1] source ip 192.1.0.3
# Configure AC 2 as a member of mobility group 1, and specify 192.1.0.2 as the source IP address for establishing IACTP tunnels.
[AC2-wlan-mg-1] member ip 192.1.0.2
[AC2-wlan-mg-1] group enable
[AC2-wlan-mg-1] quit
# Configure the next hop of the default route to AC 2 as 192.1.0.1. The default route is used for the communication between AC 2 and the RADIUS server.
[AC2] ip route-static 0.0.0.0 0.0.0.0 192.1.0.1
Configuring switch 1
# Create VLAN 100. The switch will use VLAN 100 to forward packets between AC 1 and AP 1.
<Switch1> system-view
[Switch1] vlan 100
[Switch1-vlan100] quit
# Create VLAN 200. The switch will use VLAN 200 to communicate with wireless clients on AC 1.
[Switch1] vlan 200
[Switch1-vlan200] quit
# Create VLAN 400. The switch will use VLAN 400 to forward wireless client traffic when the client roams from AC 2 to AC 1.
[Switch1] vlan 400
[Switch1-vlan400] quit
# Configure GigabitEthernet1/0/1 that connects switch 1 to switch 3 as a trunk port, and assign the port to VLANs 100, 200, and 400.
[Switch1] interface gigabitethernet 1/0/1
[Switch1-GigabitEthernet1/0/1] port link-type trunk
[Switch1-GigabitEthernet1/0/1] port trunk permit vlan 100 200 400
[Switch1-GigabitEthernet1/0/1] quit
# Configure GigabitEthernet1/0/2 that connects switch 1 to AP 1 as a trunk port, and assign the port to VLANs 100, 200, and 400.
[Switch1] interface gigabitethernet 1/0/2
[Switch1-GigabitEthernet1/0/2] port link-type trunk
[Switch1-GigabitEthernet1/0/2] port trunk permit vlan 100 200 400
[Switch1-GigabitEthernet1/0/2] port trunk pvid 100
[Switch1-GigabitEthernet1/0/2] quit
Configuring switch 2
# Create VLAN 100. The switch will use VLAN 100 to forward packets between AC 2 and AP 2.
<Switch2> system-view
[Switch2] vlan 100
[Switch2-vlan100] quit
# Create VLAN 200. The switch will use VLAN 200 to forward wireless client traffic when the client roams from AC 1 to AC 2.
[Switch2] vlan 200
[Switch2-vlan200] quit
# Create VLAN 400. The switch will use VLAN 400 to communicate with wireless clients on AC 2.
[Switch2] vlan 400
[Switch2-vlan400] quit
# Configure GigabitEthernet1/0/1 that connects switch 2 to switch 3 as a trunk port, and assign the port to VLANs 100, 200, and 400.
[Switch2] interface gigabitethernet 1/0/1
[Switch2-GigabitEthernet1/0/1] port link-type trunk
[Switch2-GigabitEthernet1/0/1] port trunk permit vlan 100 200 400
[Switch2-GigabitEthernet1/0/1] quit
# Configure GigabitEthernet1/0/2 that connects switch 2 to AP 2 as a trunk port, assign the port to VLANs 100, 200, and 400, and set the PVID to 100.
[Switch2] interface gigabitethernet 1/0/2
[Switch2-GigabitEthernet1/0/2] port link-type trunk
[Switch2-GigabitEthernet1/0/2] port trunk permit vlan 100 200 400
[Switch2-GigabitEthernet1/0/2] quit
Configuring switch 3
1. Configure interfaces on switch 3:
# Create VLAN 100 and VLAN-interface 100, and assign IP address 192.1.0.1/16 to the interface. Switch 3 will use this IP address to communicate with AC 1 and AC 2.
<Switch3> system-view
[Switch3] vlan 100
[Switch3-vlan100] quit
[Switch3] interface vlan-interface 100
[Switch3-Vlan-interface100] ip address 192.1.0.1 16
[Switch3-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign IP address 192.2.0.1/16 to the interface. Switch 3 will use this IP address to communicate with wireless clients on AC 1.
[Switch3] vlan 200
[Switch3-vlan200] quit
[Switch3] interface vlan-interface 200
[Switch3-Vlan-interface200] ip address 192.2.0.1 16
[Switch3-Vlan-interface200] quit
# Create VLAN 400 and VLAN-interface 400, and assign IP address 192.4.0.1/16 to the interface. Switch 3 will use this IP address to communicate with wireless clients on AC 2.
[Switch3] vlan 400
[Switch3-vlan400] quit
[Switch3] interface vlan-interface 400
[Switch3-Vlan-interface400] ip address 192.4.0.1 16
[Switch3-Vlan-interface400] quit
# Create VLAN 300 and VLAN-interface 300, and assign IP address 192.3.0.1/16 to the interface. Switch 3 will use this IP address to communicate with the RADIUS server.
[Switch3] vlan 300
[Switch3-vlan300] quit
[Switch3] interface vlan-interface 300
[Switch3-Vlan-interface300] ip address 192.3.0.1 16
[Switch3-Vlan-interface300] quit
# Configure interface GigabitEthernet 1/0/1 that connects Switch 3 to AC 1 as an access port, and assign the port to VLAN 100.
[Switch3] interface gigabitethernet 1/0/1
[Switch3-GigabitEthernet1/0/1] port link-type access
[Switch3-GigabitEthernet1/0/1] port access vlan 100
[Switch3-GigabitEthernet1/0/1] quit
# Configure interface GigabitEthernet 1/0/2 that connects Switch 3 to AC 2 as an access port, and assign the port to VLAN 100.
[Switch3] interface gigabitethernet 1/0/2
[Switch3-GigabitEthernet1/0/2] port link-type access
[Switch3-GigabitEthernet1/0/2] port access vlan 100
[Switch3-GigabitEthernet1/0/2] quit
# Configure interface GigabitEthernet 1/0/3 that connects Switch 3 to Switch 1 as a trunk port, and assign the port to VLANs 100, 200, and 400.
[Switch3] interface gigabitethernet 1/0/3
[Switch3-GigabitEthernet1/0/3] port link-type trunk
[Switch3-GigabitEthernet1/0/3] port trunk permit vlan 100 200 400
[Switch3-GigabitEthernet1/0/3] quit
# Configure interface GigabitEthernet 1/0/4 that connects Switch 3 to Switch 2 as a trunk port, and assign the port to VLANs 100, 200, and 400.
[Switch3] interface gigabitethernet 1/0/4
[Switch3-GigabitEthernet1/0/4] port link-type trunk
[Switch3-GigabitEthernet1/0/4] port trunk permit vlan 100 200 400
[Switch3-GigabitEthernet1/0/4] quit
# Configure interface GigabitEthernet 1/0/5 that connects Switch 3 to the RADIUS server as an access port, and assign the port to VLAN 300.
[Switch3] interface gigabitethernet 1/0/5
[Switch3-GigabitEthernet1/0/5] port link-type access
[Switch3-GigabitEthernet1/0/5] port access vlan 300
[Switch3-GigabitEthernet1/0/5] quit
2. Configure the DHCP server:
# Enable DHCP.
[Switch3] dhcp enable
# Create a DHCP address pool named vlan100 for the APs. Specify the 192.1.0.0/16 subnet for the pool and exclude IP addresses 192.1.0.2 and 192.1.0.3 from dynamic allocation. Set the gateway IP address to 192.1.0.1.
[Switch3] dhcp server ip-pool vlan100
[Switch3-dhcp-pool-vlan100] network 192.1.0.0 mask 255.255.0.0
[Switch3-dhcp-pool-vlan100] forbidden-ip 192.1.0.2 192.1.0.3
[Switch3-dhcp-pool-vlan100] gateway-list 192.1.0.1
[Switch3-dhcp-pool-vlan100] quit
# Create a DHCP address pool named vlan200 for the clients. Specify the 192.2.0.0/16 subnet for the pool. Set the gateway IP address to 192.2.0.1 and specify the DNS server address. In this example, the gateway also acts as a DNS server.
[Switch3] dhcp server ip-pool vlan200
[Switch3-dhcp-pool-vlan200] network 192.2.0.0 mask 255.255.0.0
[Switch3-dhcp-pool-vlan200] gateway-list 192.2.0.1
[Switch3-dhcp-pool-vlan200] dns-list 192.2.0.1
[Switch3-dhcp-pool-vlan200] quit
# Create a DHCP address pool named vlan400 for the clients. Specify the 192.4.0.0/16 subnet for the pool. Set the gateway IP address to 192.4.0.1 and specify the DNS server address. In this example, the gateway also acts as a DNS server.
[Switch3] dhcp server ip-pool vlan400
[Switch3-dhcp-pool-vlan400] network 192.4.0.0 mask 255.255.0.0
[Switch3-dhcp-pool-vlan400] gateway-list 192.4.0.1
[Switch3-dhcp-pool-vlan400] dns-list 192.4.0.1
[Switch3-dhcp-pool-vlan400] quit
Configuring the RADIUS server
In this example, the RADIUS server runs on iMC PLAT 7.2(E0403) and iMC EIA 7.2(E0403).
To configure the RADIUS server:
1. Add the ACs to the IMC Platform as access devices:
a. Log in to IMC.
b. Click the User tab.
c. From the navigation tree, select User Access Policy > Access Device Management > Access Device.
d. Click Add to add AC 1 and AC 2 as access devices.
e. Configure the following parameters:
- Enter 192.1.0.2 for AC 1 and 192.1.0.3 for AC 2 in the Device IP field.
- Enter 12345678 in the Shared Key field.
- Use the default settings for other parameters.
f. Click OK.
Figure 2 Adding access devices
2. Add an access policy:
a. Click the User tab.
b. From the navigation tree, select User Access Policy > Access Policy.
c. Click Add to add an access policy that uses the following settings:
- Access Policy Name—dot1x.
- Preferred EAP Type—EAP-PEAP.
- Subtype—MS-CHAPV2. The subtype must match the client authentication method.
Figure 3 Adding an access policy
3. Add an access service:
b. From the navigation tree, select User Access Policy > Access Service.
c. Click Add to add an access service that uses the following settings:
- Service Name—dot1x.
- Default Access Policy—dot1x.
Figure 4 Adding an access service
4. Add an access user:
b. From the navigation tree, select All Access Users.
c. Click Add to add an access user that uses the following settings:
- User Name—user.
- Account Name—dot1x.
- Password—dot1x.
d. Select the dot1x service for the user.
Figure 5 Adding an access user
# Make the client come online from AP 1. (Details not shown.)
# On AC 1, verify that the client is associated with AP 1.
<AC1> display wlan client verbose
Total number of clients: 1
MAC address : 0015-00ba-0428
IPv4 address : 192.2.0.16
IPv6 address : N/A
Username : N/A
AID : 1
AP ID : 1
AP name : ap1
Radio ID : 1
SSID : service
BSSID : 5866-ba71-3960
VLAN ID : 200
Sleep count : 0
Wireless mode : 802.11ac
Channel bandwidth : 40MHz
SM power save : Disabled
Short GI for 20MHz : Supported
Short GI for 40MHz : Supported
STBC RX capability : Supported
STBC TX capability : Not supported
LDPC RX capability : Not supported
Block Ack : N/A
Supported HT MCS set : 0, 1, 2, 3, 4, 5, 6, 7,
8, 9, 10, 11, 12, 13, 14,
15
Supported rates : 6, 9, 12, 18, 24, 36,
48, 54 Mbps
QoS mode : WMM
Listen interval : 250
RSSI : 0
Rx/Tx rate : 0/0
Authentication method : Open system
Security mode : RSN
AKM mode : 802.1X
Cipher suite : CCMP
User authentication mode : 802.1X
Authorization ACL ID : N/A
Authorization user profile : N/A
Roam status : N/A
Key derivation : SHA1
PMF status : N/A
Forwarding policy name : N/A
Online time : 0days 0hours 0minutes 17seconds
FT status : Inactive
# Make the client roam to AP 2.
# On AC 2, verify that the client is associated with AP 2.
<AC2> display wlan client verbose
IPv6 address : N/A
Username : N/A
AID : 1
AP ID : 1
AP name : ap2
Radio ID : 1
SSID : service
BSSID : 5860-ba71-3960
VLAN ID : 200
Sleep count : 0
Block Ack : N/A
15
48, 54 Mbps
QoS mode : WMM
RSSI : 0
Rx/Tx rate : 0/0
Security mode : RSN
AKM mode : 802.1X
Cipher suite : CCMP
Roam status : Inter-AC roam
PMF status : N/A
# Verify that clients in VLAN 200 and VLAN 400 can access the Internet but cannot access a client in the same VLAN. (Details not shown.)
Configuration files
· Switch 1:
vlan 100
vlan 200
vlan 400
port trunk pvid 100
· Switch 2:
vlan 100
vlan 200
vlan 400
port trunk pvid 100
· Switch 3:
dhcp enable
vlan 100
vlan 200
vlan 300
vlan 400
forbidden-ip 192.1.0.3
dns-list 192.2.0.1
dns-list 192.4.0.1
interface Vlan-interface100
ip address 192.1.0.1 255.255.0.0
interface Vlan-interface200
ip address 192.2.0.1 255.255.0.0
interface Vlan-interface300
ip address 192.3.0.1 255.255.0.0
interface Vlan-interface400
ip address 192.4.0.1 255.255.0.0
port trunk access 100
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
· AC 1:
vlan 100
ssid service
vlan 200
akm mode dot1x
cipher-suite ccmp
security-ie rsn
dot1x domain office
ip address 192.1.0.2 255.255.0.0
nas-ip 192.1.0.2
domain office
ap ap1
ap-model WA6320
radio 1
radio enable
service-template 1
source ip 192.1.0.2
member ip 192.1.0.3
group enable
· AC 2:
vlan 100
ssid service
vlan 400
akm mode dot1x
cipher-suite ccmp
security-ie rsn
dot1x domain office
ip address 192.1.0.3 255.255.0.0
nas-ip 192.1.0.3
domain office
ap ap2
ap-model WA6320
radio 1
radio enable
service-template 1
source ip 192.1.0.3
member ip 192.1.0.2
group enable
Related documentation
· AP Management Command Reference in H3C Access Controllers Command References
· AP Management Configuration Guide in H3C Access Controllers Configuration Guides
· User Access and Authentication Command Reference in H3C Access Controllers Command References
· User Access and Authentication Configuration Guide in H3C Access Controllers Configuration Guides
· WLAN Access Command Reference in H3C Access Controllers Command References
· WLAN Access Configuration Guide in H3C Access Controllers Configuration Guides
· WLAN Roaming Command Reference in H3C Access Controllers Command References
· WLAN Roaming Configuration Guide in H3C Access Controllers Configuration Guides
