- 04-Comware 7 CLI-based configuration examples (AC+fit AP deployment)
- 01-HTTPS Login Configuration Examples
- 02-SSH Configuration Examples
- 03-License Management Configuration Examples
- 04-AP Association with the AC at Layer 2 Configuration Examples
- 05-AP Association with the AC at Layer 2 (IPv6) Configuration Examples
- 06-Auto AP Configuration Examples
- 07-AP Association with the AC at Layer 3 Configuration Examples
- 08-AP Association with the AC at Layer 3 (IPv6) Configuration Examples
- 09-WEP Encryption Configuration Examples
- 100-Static Blacklist Configuration Examples
- 101-Client Quantity Control Configuration Examples
- 102-AP License Synchronization Configuration Examples
- 103-BLE Module iBeacon Transmission Configuration Examples
- 104-Medical RFID Tag Management Configuration Examples
- 105-iBeacon Management Configuration Examples
- 106-Mesh Link Establishment Between Fit APs Configuration Examples
- 107-Mesh Link Establishment Between a Fit AP and a Fat AP Configuration Examples
- 108-Auto-DFS and Auto-TPC Configuration Examples
- 109-AP Image Downloading Configuration Examples
- 10-PSK Encryption Configuration Examples
- 110-Dual-Uplink Interfaces Configuration Guide
- 111-H3C Comware AC Cloud-Managed AP Centralized Management Configuration Examples
- 112-Internal-to-External Access Through NAT Configuration Examples
- 113-Layer 2 Static Aggregation Configuration Examples
- 114-Layer 2 Multicast Configuration Examples
- 115-Static VLAN Allocation Configuration Examples
- 116-URL Redirection Configuration Examples
- 117-IPv6 URL Redirection Configuration Examples
- 11-WPA3-SAE PSK Encryption Configuration Examples
- 12-WLAN Access (IPv6) Configuration Examples
- 13-Policy-Based Forwarding with Dual Gateways Configuration Examples
- 14-Scheduled Configuration Deployment by AP Group Configuration Examples
- 15-Inter-AC Roaming with Static Client VLAN Allocation Configuration Examples
- 16-Service Template and Radio Binding Configuration Examples
- 17-Scheduled WLAN Access Services Configuration Examples
- 18-HTTPS-Based Local Portal Authentication Configuration Examples
- 19-Remote Portal Authentication Configuration Examples
- 20-Local Portal Authentication through LDAP Server Configuration Examples
- 21-Local Portal Auth and SSID-based Auth Page Pushing Configuration Examples
- 22-Local Portal MAC-Trigger Authentication Configuration Examples
- 23-Portal MAC-Trigger Authentication Configuration Examples
- 24-Local Forwarding Mode and Local Portal MAC-Trigger Auth Configuration Examples
- 25-Local Portal Authentication (IPv6) Configuration Examples
- 26-Local Portal Authentication through LDAP Server (IPv6) Configuration Examples
- 27-Remote Portal Authentication (IPv6) Configuration Examples
- 28-Portal MAC-Trigger Authentication (IPv6) Configuration Example
- 29-Remote Portal Authentication with User Profile Authorization Configuration Examples
- 30-WiFiDog Portal Authentication Configuration Examples
- 31-Portal Fail-Permit Configuration Examples
- 32-Local MAC Authentication Configuration Examples
- 33-Remote MAC Authentication Configuration Examples
- 34-Local Portal Authentication Configuration Examples
- 35-Transparent Auth Through Remote MAC and Portal Auth Configuration Examples
- 36-Remote AP, Remote Portal, and MAC-Trigger Authentication Configuration Examples
- 37-MAC Authentication with Guest VLAN Assignment Configuration Examples
- 38-MAC Authentication with Guest VLAN Assignment (IPv6) Configuration Examples
- 39-Local MAC-And-802.1X Authentication Configuration Examples
- 40-Local 802.1X Authentication Configuration Examples
- 41-Local RADIUS-Based 802.1X Authentication in EAP Relay Mode Configuration Examples
- 42-Remote 802.1X Authentication Configuration Examples
- 43-Remote 802.1X Authentication (IPv6) Configuration Examples
- 44-Remote 802.1X Authentication in WPA3-Enterprise Mode Configuration Examples
- 45-802.1X Auth with ACL Assignment Through IMC Server Configuration Examples
- 46-802.1X Auth with User Profile Assignment Through IMC Server Configuration Examples
- 47-EAD Authentication Configuration Examples
- 48-EAD Authentication (IPv6) Configuration Examples
- 49-Local Forwarding Mode and Local Portal Authentication Configuration Examples
- 50-Local Forwarding Mode Direct Portal Authentication Configuration Examples
- 51-Local Forwarding Mode Direct Portal Authentication (IPv6) Configuration Examples
- 52-Local Forwarding Configuration Examples
- 53-Wired Port Local Forwarding through Wireless Terminator Configuration Examples
- 54-Remote AP Configuration Examples
- 55-Downlink VLAN Management for Fit-Mode APs Configuration Examples
- 56-Downlink VLAN Management for Fit APs and Cloud APs Configuration Examples
- 57-WIPS Configuration Examples
- 58-WIPS Countermeasures Against All SSIDs Configuration Examples
- 59-IP Source Guard (IPv4) Configuration Examples
- 60-IP Source Guard (IPv6) Configuration Examples
- 61-IPS Configuration Examples
- 62-URL Filtering Configuration Examples
- 63-Anti-Virus Configuration Examples
- 64-Data Filtering Configuration Examples
- 65-File Filtering Configuration Examples
- 66-Application Audit and Management Configuration Examples
- 67-Application Rate Limiting Configuration Examples
- 68-IRF Setup with LACP MAD Configuration Examples
- 69-IRF Setup with ARP MAD Configuration Examples
- 70-IRF Setup with Members Not Directly Connected Configuration Examples
- 71-IRF Setup with Members in One Chassis Configuration Examples
- 72-IRF Setup with Members in Different Chassis Configuration Examples
- 73-Dual-Link Backup Configuration Examples
- 74-Remote 802.1X Auth on an AC Hierarchy Network with Dual-Link Backup Configuration Examples
- 75-Remote Portal Auth on an AC Hierarchy Network with Dual-Link Backup Configuration Examples
- 76-OAuth-Based Portal MAC-Trigger Auth on a Local-Forwarding Dual-Link Backup Configuration Examples
- 77-Dual-Link Backup OAuth-Based Portal Authentication in Local Forwarding Configuration Examples
- 78-Dual-Link Backup Remote Portal MAC-Trigger Authentication in Local Forwarding Configuration Examples
- 79-Dual-Link Backup Remote Portal and Transparent MAC Auth in Local Forwarding Configuration Examples
- 80-Dual-Link Backup Remote Portal Authentication in Local Forwarding Configuration Examples
- 81-Dual-Link Backup Remote Portal and Transparent MAC Auth in Centralized Forwarding Configuration Examples
- 82-Dual-Link Backup Remote Portal Authentication in Centralized Forwarding Configuration Examples
- 83-Dual-Link Backup Lightweight Portal Authentication in Centralized Forwarding Configuration Examples
- 84-Dual-Link Backup OAuth-Based Portal Authentication in Centralized Forwarding Configuration Examples
- 85-Dual-Link Backup Remote Portal MAC-Trigger Auth in Centralized Forwarding Configuration Examples
- 86-Remote 802.1X Authentication on a Dual-Link AC Backup Network Configuration Examples
- 87-Remote MAC Authentication on a Dual-Link AC Backup Network Configuration Examples
- 88-AC Hierarchy Configuration Examples
- 89-Remote 802.1X Auth (Local AC Auth+AC Forwardering) Configuration Examples
- 90-Remote 802.1X Auth (Central AC Auth+AP Forwarding) Configuration Examples
- 91-AC Hierarchy (IPv6) Configuration Examples
- 92-WLAN Probe Configuration Examples
- 93-Multicast Optimization Configuration Examples
- 94-Client Rate Limiting Configuration Examples
- 95-Inter-AC Roaming Configuration Examples
- 96-Inter-AC Roaming (IPv6) Configuration Examples
- 97-Inter-AC Roaming in Local Forwarding Mode Configuration Examples
- 98-H3C Access Controllers Cooperative Roaming for 802.11v Clients Configuration Examples
| 108-Auto-DFS and Auto-TPC Configuration Examples | 408.10 KB |
H3C Access Controllers |
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example for configuring auto dynamic frequency selection (DFS) and auto transmit power control (TPC).
The following information applies to Comware-based access controllers and access points with a software version of 5439 or later (5411 or later for the WA6600 series access points). Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of WLAN RRM.
· Auto-DFS and auto-TPC are not supported in the following scenarios or devices:
¡ Scenarios where the working channels and powers are not allowed to change.
¡ Scenarios where WLAN location are not compatible with auto-DFS and auto-TPC.
¡ Unified wired and wireless access controller.
¡ WTU420, WTU420H, and X-share series access points.
· Use the serial ID labeled on the AP's rear panel to specify an AP.
· Do not manually specify a working channel, because it has a higher priority than the automatically selected channel.
· Make sure power lock is disabled.
· As a best practice, set the bandwidth mode for the 5 GHz radio to 40 MHz or 20 MHz.
· To enable auto-DFS or auto-TPC only for an AP or AP group, use the following commands:
¡ calibrate-channel self-decisive enable
¡ calibrate-power self-decisive enable
Example: Configuring auto-DFS and auto-TPC
As shown in Figure 1, in centralized forwarding mode, the AC is connected to the switch, and the switch assigns an IP address to the AP and clients as a DHCP server. Configure auto-DFS and auto-TPC for the AP to change the working channel and transmit power automatically based on the wireless environment.
Procedures
Configuring the AC
1. Configure interfaces on the AC:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish a CAPWAP tunnel with the AP.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.1.0.1 16
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. VLAN 200 will be used for client access.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 192.2.0.1 24
[AC-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the switch to the AC as a trunk port, and assign the trunk port to VLAN1, VLAN 100, and VLAN 200.
[AC-GigabitEthernet1/0/1] port trunk permit vlan 1 100 200
2. Configure a wireless service:
# Create a service template named service and enter its view.
[AC] wlan service-template service
# Configure the SSID as service.
[AC-wlan-st-service] ssid service
Specify VLAN 200 in the service template.
[AC-wlan-st-service] vlan 200
# Set the AKM mode to PSK and specify plaintext string 12345678 as the preshared key.
[AC-wlan-st-service] akm mode psk
[AC-wlan-st-service] preshared-key pass-phrase simple 12345678
# Specify the cipher suite as CCMP and the security IE as RSN.
[AC-wlan-st-service] cipher-suite ccmp
[AC-wlan-st-service] security-ie rsn
# Configure the AC to forward client data traffic. You can skip this step if the AC is the client traffic forwarder by default.
[AC-wlan-st-service] client forwarding-location ap
# Enable the service template.
[AC-wlan-st-service] service-template enable
[AC-wlan-st-service] quit
3. Configure an AP:
# Create a manual AP named ap1, and specify the AP model and serial ID.
[AC] wlan ap ap1 model WA6330
[AC-wlan-ap-ap1] serial-id 219801A23V8192E00021
# Create AP group group1, add the AP to the AP group, and specify the AP model.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap ap1
[AC-wlan-ap-group-group1] ap-model WA6330
# Enter the view of radio 1.
[AC-wlan-ap-group-group1-ap-model-WA6330] radio 1
# Set the bandwidth mode to 40 MHz.
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1]channel band-width 40
# Bind WLAN service template service to radio 1 and enable the radio.
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] service-template service
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] quit
[AC-wlan-ap-group-group1-ap-model-WA6330] quit
[AC-wlan-ap-group-group1] quit
# Configure AP 2, AP 3, and AP 4 in the same way AP 1 is configured.
4. Configure auto-DFS and auto-TPC:
# Enter global configuration view.
[AC] wlan global-configuration
# Enable auto-TPC.
[AC-wlan-global-configuration] calibrate-power self-decisive enable all
# Enable auto-DFS.
[AC-wlan-global-configuration] calibrate-channel self-decisive enable all
[AC-wlan-global-configuration] quit
[AC] quit
Configure the switch
# Create VLAN 100. The switch will use this VLAN to forward the traffic on the CAPWAP tunnels between the AC and AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
# Create VLAN 200. The switch will use this VLAN to forward packets for wireless clients.
[Switch] vlan 200
[Switch-vlan200] quit
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 1 100 200
# Configure GigabitEthernet 1/0/2 that connects the switch to the APs as an access port, and assign the access port to VLAN 100.
[Switch] interface range gigabitethernet 1/0/2 to gigabitethernet 1/0/5
[Switch-if-range] port link-type access
[Switch-if-range] port access vlan 100
# Enable the PoE feature.
[Switch-if-range] poe enable
[Switch-if-range] quit
# Specify an IP address for VLAN-interface 100.
[Switch-Vlan-interface100] ip address 192.1.0.2 16
# Specify an IP address for VLAN-interface 200.
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 192.2.0.2 24
[Switch-Vlan-interface200] quit
# Enable DHCP.
[Switch] dhcp enable
# Create DHCP address pool 100. Specify the 192.1.0.0/16 subnet and the 192.1.0.1 gateway for the pool.
[Switch] dhcp server ip-pool 100
[Switch-dhcp-pool-100] network 192.1.0.0 mask 255.255.0.0
[Switch-dhcp-pool-100] gateway-list 192.1.0.1
[Switch-dhcp-pool-100] quit
# Create DHCP address pool 200. Specify the 192.2.0.0/16 subnet and the 192.2.0.1 gateway for the pool.
[Switch] dhcp server ip-pool 200
[Switch-dhcp-pool-200] network 192.2.0.0 mask 255.255.255.0
[Switch-dhcp-pool-200] gateway-list 192.2.0.1
[Switch-dhcp-pool-200] quit
1. View AP registration information on the AC:
# Verify that the APs have been associated with the AC. If the APs are in R/M state, the APs have been associated with the AC.
<AC> display wlan ap all
AP information
State : I = Idle, J = Join, JA = JoinAck, IL = ImageLoad
C = Config, DC = DataCheck, R = Run, M = Master, B = Backup
AP name APID State Model Serial ID
ap1 1 R/M WA6330 219801A23V8192E00021
ap2 2 R/M WA6330 219801A23V8192E00022
ap3 3 R/M WA6330 219801A23V8192E00023
ap4 4 R/M WA6330 219801A23V8192E00024
2. View history and detailed RRM information on the AC.
# Display DFS and TPC information for radio 1 of AP 1 on the AC to verify that the channel and power have been changed.
<AC> display wlan rrm-history ap name ap1
AP RRM History
Flags : I - Interference, P - Packets discarded, F - Retransmission,
R - Radar, C - Coverage, B - Channelbusy,
M - Manual O - Others
AP RRM History : ap1
Radio : 1 Basic BSSID : 7848-59f3-df80
Ch Power Load Util Intf PER Retry Reason Date Time
(dBm) (%) (%) (%) (%) (%) (yyyy-mm-dd) (hh:mm:ss)
Before 36 20 21 0 11 0 1 ----C--- 2021-02-25 15:12:56
After 36 17 21 0 11 0 1 - - -
Before 36 17 21 0 12 0 0 ----C--- 2021-02-25 15:15:56
After 36 14 21 0 12 0 0 - - -
Before 36 14 21 0 12 0 0 ----C--- 2021-02-25 15:18:56
After 36 11 21 0 12 0 0 - - -
Before 36 11 18 0 11 0 10 -----B-- 2021-02-25 15:25:21
After 40 11 16 0 10 0 8 - - -
# Display detailed DFS and TPC information for radio 1 of AP 1 on the AC.
<AC> display wlan rrm-status ap name ap1
AP RRM Profile : ap1
Channel : 40 Tx Power (dBm) : 14
Ch Nbrs Load Util Intf PER Retry Radar Last Detected At
36 44 23 0 16 0 0 - 2021-02-26 15:30:32
40 3 9 - 1 0 - - 2021-02-26 15:30:32
44 11 18 - 6 0 - - 2021-02-26 15:30:32
48 8 30 - 10 0 - - 2021-02-26 15:30:32
52 25 17 - 12 0 - - 2021-02-26 15:30:32
56 0 7 - 0 0 - - 2021-02-26 15:30:32
60 4 8 - 1 0 - - 2021-02-26 15:30:32
64 7 7 - 0 0 - - 2021-02-26 15:30:32
149 30 32 - 24 0 - - 2021-02-26 15:30:32
153 12 10 - 3 0 - - 2021-02-26 15:30:32
157 12 14 - 4 0 - - 2021-02-26 15:30:32
161 5 8 - 2 0 - - 2021-02-26 15:30:32
165 5 7 - 1 0 - - 2021-02-26 15:30:32
Nbr-MACAddress Ch Intf SignalStrength Type Last Detected At
(%) (dBm)
0023-89e2-ed80 36 0 -29 Unmanaged 2021-02-26 15:30:40
0023-ee00-1168 52 0 -88 Unmanaged 2021-02-26 15:30:40
04d7-a537-8540 149 0 -68 Unmanaged 2021-02-26 15:30:40
1019-651b-d682 36 0 -7 Unmanaged 2021-02-26 15:30:40
1019-651b-d691 149 2 -52 Unmanaged 2021-02-26 15:30:40
346b-5b6c-1e00 36 0 -47 Unmanaged 2021-02-26 15:30:40
346b-5b6c-1e01 36 0 -53 Unmanaged 2021-02-26 15:30:40
346b-5b76-1d20 36 0 -35 Managed 2021-02-26 15:30:40
346b-5b76-1d22 36 0 -23 Managed 2021-02-26 15:30:40
346b-5b76-1d23 36 0 -17 Managed 2021-02-26 15:30:40
346b-5b76-1d24 36 0 -20 Managed 2021-02-26 15:30:40
3891-d502-be60 52 0 -60 Managed 2021-02-26 15:30:40
3891-d502-be61 52 0 -61 Managed 2021-02-26 15:30:40
3891-d58a-8f80 44 0 -75 Unmanaged 2021-02-26 15:30:40
3891-d58a-8f81 44 0 -76 Unmanaged 2021-02-26 15:30:40
3891-d58a-8f82 44 0 -75 Unmanaged 2021-02-26 15:30:40
3891-d58a-8f90 161 0 -94 Unmanaged 2021-02-26 15:30:40
3891-d58d-6d41 52 0 -45 Unmanaged 2021-02-26 15:30:40
3897-d618-90e0 36 0 -32 Unmanaged 2021-02-26 15:30:40
3897-d6e0-e860 36 0 -38 Unmanaged 2021-02-26 15:30:40
3. (Optional.) Connect the AC to the Cloudnet platform to view AP and client statistics.
# View the health status of clients to identify whether the number of clients with a health score of excellent and good has increased.
Figure 2 Client health status
# View the health status of APs to identify whether the number of APs with a health score of excellent and good has increased.
Figure 3 AP health status
Configuration files
· Switch:
dhcp enable
vlan 100
vlan 200
interface Vlan-interface100
ip address 192.1.0.2 255.255.0.0
interface Vlan-interface200
ip address 192.2.0.2 255.255.255.0
poe enable
poe enable
interface GigabitEthernet1/0/4
poe enable
interface GigabitEthernet1/0/5
poe enable
· AC:
vlan 100
vlan 200
ssid service
vlan 200
akm mode psk
preshared-key pass-phrase cipher $c$3$HOaHaYA7Aazh6+V0xH8AvnFdV1xTZEw0uBZs
cipher-suite ccmp
security-ie rsn
ip address 192.1.0.1 255.255.0.0
ip address 192.2.0.1 255.255.255.0
vlan 1
ap ap1
ap-model WA6330
radio 1
radio enable
wlan ap ap2 model WA6330
serial-id 219801A23V8192E00022
wlan ap ap3 model WA6330
serial-id 219801A23V8192E00023
wlan ap ap4 model WA6330
serial-id 219801A23V8192E00024
Related documentation
· AP Management Configuration Guide in H3C Access Controllers Configuration Guides
· AP Management Command Reference in H3C Access Controllers Command References
· WLAN RRM Configuration Guide in H3C Access Controllers Configuration Guides
· WLAN RRM Command Reference in H3C Access Controllers Command References
