- H3C CR16000-M Routers Installation Guide-5W102
- 01-Safety precautions
- 02-Preparing for installation
- 03-Installing the router
- 04-Installing removable components
- 05-Connecting cables
- 06-Verifying the installation
- 07-Starting and configuring the router
- 08-Replacement procedures
- 09-Troubleshooting
- 10-Appendix A Engineering labels
- 11-Appendix B Cable assembling and management
- 12-Appendix C Repackaging the Router
| 00-Preface | 110.11 KB |
Preface
This document describes the installation procedure for the CR16000-M routers. It includes safety precautions, preparing for installation, installing the router, installing modules, connecting cables, starting and configuring the router, replacing modules, troubleshooting, engineering labels, cable assembling and management, and repackaging procedures.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the CR16000-M routers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
