- 04-Layer 2 - LAN Switching
- 01-HH3C-MAC-INFORMATION-MIB
- 02-HH3C-MLAG-MIB
- 03-HH3C-PVST-MIB
- 04-HH3C-QINQV2-MIB
- 05-HH3C-VLANTERM-MIB
- 06-HH3C-VMAP-MIB
- 07-IEEE8021-CFM-MIB
- 08-IEEE8023-LAG-MIB
- 09-LLDP-EXT-DOT1-MIB
- 10-LLDP-EXT-DOT1-V2-MIB
- 11-LLDP-EXT-DOT3-MIB
- 12-LLDP-EXT-DOT3-V2-MIB
- 13-LLDP-EXT-MED-MIB
- 14-LLDP-MIB
- 15-LLDP-V2-MIB
- 16-MAU-MIB
- 17-P-BRIDGE-MIB
- 18-Q-BRIDGE-MIB
- 19-BRIDGE-MIB
- 20-EtherLike-MIB
- 21-HH3C-LAG-MIB
- 22-HH3C-LLDP-EXT-MIB
- 23-HH3C-LPBKDT-MIB
- 24-HH3C-LswMAM-MIB
- 25-HH3C-LswMSTP-MIB
- 26-HH3C-LswVLAN-MIB
| 22-HH3C-LLDP-EXT-MIB | 62.09 KB |
HH3C-LLDP-EXT-MIB
About this MIB
The Link Layer Discovery Protocol (LLDP) is a Layer 2 industry-standard protocol (IEEE 802.1AB) that allows network devices from different vendors to discover neighbors and exchange system and configuration information.
This MIB defines private MIB objects for the following extended LLDP management features:
· Global LLDP configuration:
¡ Global status of LLDP.
¡ Global status of CDP compatibility.
· LLDP port configuration:
¡ Port-specific packet transmission settings of CDP-compatible LLDP.
¡ Protection action taken on ports whose neighbors fail validation.
¡ Protection action taken on ports whose neighbors age out.
· LLDP neighbor validation criteria:
¡ Chassis ID subtype.
¡ Chassis ID.
¡ Port ID subtype.
¡ Port ID.
· Feature status on LLDP-enabled ports:
¡ Neighbor validation status.
¡ Neighbor aging status.
· Trapping configuration on LLDP-enabled ports:
¡ Trapping for neighbor validation status changes.
¡ Trapping for neighbor aging status changes.
MIB file name
hh3c-lldp-ext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).huawei.h3c(10).h3cCommon(2).h3clldp(100)
Scalar objects
hh3clldpAdminStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3clldpAdminStatus (1.3.6.1.4.1.25506.2.100.1.1.1) |
read-write |
TruthValue |
true(1) false(2) |
Global status of LLDP. |
As per the MIB. |
hh3clldpComplianceCDPStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3clldpComplianceCDPStatus (1.3.6.1.4.1.25506.2.100.1.1.2) |
read-write |
TruthValue |
true(1) false(2) |
Global status of CDP compatibility. |
Not supported. Fixed at 2. |
Tabular objects
hh3clldpPortConfigTable
About this table
Use this table to configure LLDP on ports.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is hh3clldpPortConfigPortNum.
The table OID is 1.3.6.1.4.1.25506.2.100.1.1.3.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3clldpPortConfigPortNum (1.3.6.1.4.1.25506.2.100.1.1.3.1.1) |
not-accessible |
LldpPortNumber |
Standard MIB values. |
Port index. |
As per the MIB. |
hh3clldpPortConfigCDPComplianceStatus (1.3.6.1.4.1.25506.2.100.1.1.3.1.2) |
read-write |
INTEGER |
txAndRx(1) disabled(2) |
Packet transmission capabilities of CDP-compatible LLDP. |
As per the MIB. |
hh3clldpPortConfigValidationAction (1.3.6.1.4.1.25506.2.100.1.1.3.1.3) |
read-write |
Integer32 |
Neighbor validation status. |
As per the MIB. |
h3clldpPortConfigAgingAction (1.3.6.1.4.1.25506.2.100.1.1.3.1.4) |
read-write |
Integer32 |
Neighbor aging status. |
As per the MIB. |
h3clldpNbIdentityTable
About this table
Use this table to configure neighbor validation criteria.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3clldpNbIdentityPortNum.
The table OID is 1.3.6.1.4.1.25506.2.100.1.1.4.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
h3clldpNbIdentityPortNum (1.3.6.1.4.1.25506.2.100.1.1.4.1.1) |
not-accessible |
LldpPortNumber |
Port index. |
As per the MIB. |
h3clldpNbIdentityChassisIDSubtype (1.3.6.1.4.1.25506.2.100.1.1.4.1.2) |
read-write |
INTEGER |
default(0) chassisComponent(1) interfaceAlias(2) portComponent(3) macAddress(4) networkAddress(5) interfaceName(6) local(7) |
Chassis ID subtype. |
As per the MIB. |
h3clldpNbIdentityChassisID (1.3.6.1.4.1.25506.2.100.1.1.4.1.3) |
read-write |
OCTET STRING |
OCTET STRING (0..255) |
Chassis ID. |
As per the MIB. |
h3clldpNbIdentityPortIDSubtype (1.3.6.1.4.1.25506.2.100.1.1.4.1.4) |
read-write |
INTEGER |
default(0) interfaceAlias(1) portComponent(2) macAddress(3) networkAddress(4) interfaceName(5) agentCircuitId(6) local(7) |
Port ID subtype. |
As per the MIB. |
h3clldpNbIdentityPortID (1.3.6.1.4.1.25506.2.100.1.1.4.1.5) |
read-write |
OCTET STRING |
Port ID. |
As per the MIB. |
h3clldpNbIdentityRowStatus (1.3.6.1.4.1.25506.2.100.1.1.4.1.6) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
h3clldpPortStatusTable
About this table
Use this table to obtain status of features on LLDP-enabled ports.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3clldpPortStatusPortNum.
The table OID is 1.3.6.1.4.1.25506.2.100.1.1.5.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
h3clldpPortStatusPortNum (1.3.6.1.4.1.25506.2.100.1.1.5.1.1) |
accessible-for-notify |
LldpPortNumber |
Port index. |
As per the MIB. |
h3clldpPortValidationStatus (1.3.6.1.4.1.25506.2.100.1.1.5.1.2) |
read-only |
Integer32 |
As per the MIB. |
h3clldpPortAgingStatus (1.3.6.1.4.1.25506.2.100.1.1.5.1.3) |
read-only |
Integer32 |
As per the MIB. |
