04-Layer 2 - LAN Switching
HomeSupportResource CenterSwitchesS12500R SeriesS12500R SeriesTechnical DocumentsReference GuidesMIB CompanionH3C S12500R Switch Router Series MIB Companion(52xx)-6W10004-Layer 2 - LAN Switching
21-HH3C-LAG-MIB
21-HH3C-LAG-MIB 73.62 KB
HH3C-LAG-MIB
About this MIB
This MIB contains information in ieee8023-lag.mib and hh3c-lag.mib.
MIB file name
hh3c-lag.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3cLAG(25)
Scalar objects
hh3cAggResourceAllocationValue
Object (OID)
Access
Value range
Implementation
hh3cAggResourceAllocationValue (1.3.6.1.4.1.25506.8.25.1.3)
read-only
Octets
OCTET STRING (1)
Whether link aggregation is implemented by Huawei or H3C.
As per the MIB.
Tabular objects
hh3cAggLinkTable
About this table
This table contains aggregation group information.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cAggLinkNumber.
Object (OID)
Access
Value range
Implementation
hh3cAggLinkNumber (1.3.6.1.4.1.25506.8.25.1.1.1.1)
not-accessible
Integer32
Standard MIB values.
Aggregation group ID.
As per the MIB.
hh3cAggLinkName (1.3.6.1.4.1.25506.8.25.1.1.1.2)
read-create
DisplayString
SIZE (0..32)
Aggregation group name.
Not supported
hh3cAggLinkMode (1.3.6.1.4.1.25506.8.25.1.1.1.3)
read-create
INTEGER
manual(1)
static(2)
dynamic(3)
Aggregation mode.
Supports only 2 and 3.
hh3cAggLinkPortList (1.3.6.1.4.1.25506.8.25.1.1.1.4)
read-create
PortList
OCTET STRING (0..255)
Aggregation member ports.
As per the MIB.
hh3cAggLinkState (1.3.6.1.4.1.25506.8.25.1.1.1.5)
read-create
RowStatus
Row status.
Supports only active(1), createAndGo(4), and destroy(6).
hh3cAggPortListSelectedPorts (1.3.6.1.4.1.25506.8.25.1.1.1.6)
read-only
PortList
Selected member ports.
As per the MIB.
hh3cAggPortListSamePartnerPorts (1.3.6.1.4.1.25506.8.25.1.1.1.7)
read-only
PortList
Member ports attached to the same peer.
As per the MIB.
A value of the PortList type specifies a list of ports in the format of an octet string. Each octet specifies eight ports. Within each octet, the most significant bit represents the lowest-numbered port, and the least significate bit represents the highest-numbered port. Thus, each port of the device is represented by a single bit within the value of this object. If that bit has a value of 1, then that port is included in the set of ports. The port is not included if its bit has a value of 0.
Example:
hh3cAggLinkPortList.1 (PortList) 00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.34 (hex)
Hexadecimal string 00 indicates that no ports are included in an octet. The last octet is 34 in hexadecimal format and 00110100 in binary format. Therefore, the following ports are included in the list:
Port 307 (38 × 8 + 3 = 307, where 38 is the number of times that hexadecimal string 00 appears.)
Port 308 (38 × 8 + 4 = 308)
Port 310 (38 × 8 + 6 = 310)
To view the member ports of an aggregate interface:
1.     Check the hh3cAggLinkPortList object in the hh3cAggLinkTable table to obtain the member port list.
¡     For a Layer 2 aggregate interface, this object is suffixed with the aggregate interface ID. For example, hh3cAggLinkPortList.3 lists the member ports of Bridge-Aggregation 3.
¡     For a Layer 3 aggregate interface, this object is suffixed with the sum of the aggregate interface ID and 16384. For example, hh3cAggLinkPortList.16387 lists the member ports of Route-Aggregation 3.
2.     Calculate the logical ID of each member port based on the value of the hh3cAggLinkPortList object.
3.     Check the dot1dBasePortIfIndex object in the dot1dBasePortTable table for the ifindex value mapped to the logical ID of each member port.
4.     Check the ifXTable table for the interface name mapped to each ifindex value.
Example:
The value of the hh3cAggLinkTable object is as follows:
11:hh3cAggLinkPortList.16387(PortList)00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.80.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.40 (hex)
The following member ports are included in the list:
Port 409 (51 × 8 + 1= 409, where 51 is the number of times that hexadecimal string 00 appears.)
Port 2690 (336 × 8 + 2= 2690)
The value of the dot1dBasePortIfIndex object is as follows:
127:dot1dBasePortIfIndex.409(INTEGER) 385
234:dot1dBasePortIfIndex.2690 (INTEGER) 2690
The ifindex value of port 409 is 385, and the ifindex value of port 2690 is 2690.
The value of the ifXTable table is as follows:
177:ifName.9173 (DisplayString) Route-Aggregation3[52.6F.75.74.65.2D.41.67.67.72.65.67.61.74.69.6F.6E.33 (hex)]
5:ifName.385(DisplayString) GigabitEthernet1/4/2/1[47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.34.2F.32.2F.31 (hex)]
112:ifName.2690(DisplayString) GigabitEthernet2/5/1/2[47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.32.2F.35.2F.31.2F.32 (hex)]
Therefore, the interface name is GigabitEthernet 1/4/2/1 for port 409 and GigabitEthernet 2/5/1/2 for port 2690.
On the device, the ports are as follows:
[H3C]dislink-aggregation verbose Route-Aggregation 3
AggregateInterface: Route-Aggregation3
AggregationMode: Static
LoadsharingType: Shar
  Port             Status  Priority Oper-Key
  GE1/4/2/1        S       32768    2
  GE2/5/1/2        S       32768    2
[H3C]
hh3cAggPortTable
About this table
This table contains aggregation member port information.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is hh3cAggPortIndex.
Object (OID)
Access
Value range
Implementation
hh3cAggPortIndex (1.3.6.1.4.1.25506.8.25.1.2.1.1)
not-accessible
Gauge32
Member port index.
As per the MIB.
hh3cAggPortNotAttachedReason (1.3.6.1.4.1.25506.8.25.1.2.1.2)
read-write
Integer32
0..10
Why the port is unselected.
Read-only.
hh3cAggPortLacpState (1.3.6.1.4.1.25506.8.25.1.2.1.3)
read-write
TruthValue
true(1)
false(2)
Status of LACP.
Read-only.
hh3cAggPortNotAttachedString (1.3.6.1.4.1.25506.8.25.1.2.1.4)
read-write
DisplayString
SIZE (0..255)
Detailed cause for the unselected state of the member port.
Read-only.
Notifications
hh3cAggPortInactiveNotification
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.8.25.2.2
An aggregation member port becomes unselected.
Informational
Warning
ON
This notification is generated when an aggregation member port becomes unselected.
Status control
This notification cannot be disabled.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.8.25.1.1.1.1 (hh3cAggLinkNumber)
Yes
Integer32
1..40960
Recommended action
1.     Verify that the aggregation member port is physically up.
2.     Verify that the attribute configuration of the aggregation member port is the same as that of the aggregate interface.
3.     Repeat step 1 and step 2 on the peer port if the aggregate interface operates in dynamic mode.
4.     If the issue persists, contact H3C Support.
hh3cAggPortInactiveNotification2
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.25.2.2.3
Informational
Warning
ON
Status control
Objects
OID (object name)
Index
Value range
Yes
Integer32
1..40960
1.3.6.1.4.1.25506.8.25.1.2.1.1 (hh3cAggPortIndex)
Aggregation member port index.
No
Integer32
As per the MIB.
Recommended action
hh3cAggPortActiveNotification
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.25.2.2.4
An aggregation member port becomes selected.
Informational
Warning
ON
This notification is generated when an aggregation member port becomes selected.
Status control
Objects
OID (object name)
Index
Value range
Yes
Integer32
1..40960
No
Integer32
As per the MIB.
Recommended action
No action is required.
  • Become a Partner
  • Partner Resources
