04-Layer 2 - LAN Switching
HomeSupportResource CenterSwitchesS12500R SeriesS12500R SeriesTechnical DocumentsReference GuidesMIB CompanionH3C S12500R Switch Router Series MIB Companion(52xx)-6W10004-Layer 2 - LAN Switching
04-HH3C-QINQV2-MIB
04-HH3C-QINQV2-MIB 35.86 KB
HH3C-QINQV2-MIB
About this MIB
Use this MIB to manage, configure, and obtain 802.1Q in 802.1Q (QinQ) information.
MIB file name
hh3c-qinqv2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cQinQv2(137)
Tabular objects
hh3cQinQv2IfConfigTable
About this table
Use this table to enable QinQ, set the CVLAN TPID and SVLAN TPID, and configure VLAN transparent transmission on a port.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
hh3cQinQv2IfState (1.3.6.1.4.1.25506.2.137.1.2.1.1)
read-write
TruthValue
true(1),
false(2)
This variable is used to enable or disable QinQ on the port.
Implementation varies by product
  • Become a Partner
  • Partner Resources
