- 04-Layer 2 - LAN Switching
- 01-HH3C-MAC-INFORMATION-MIB
- 02-HH3C-MLAG-MIB
- 03-HH3C-PVST-MIB
- 04-HH3C-QINQV2-MIB
- 05-HH3C-VLANTERM-MIB
- 06-HH3C-VMAP-MIB
- 07-IEEE8021-CFM-MIB
- 08-IEEE8023-LAG-MIB
- 09-LLDP-EXT-DOT1-MIB
- 10-LLDP-EXT-DOT1-V2-MIB
- 11-LLDP-EXT-DOT3-MIB
- 12-LLDP-EXT-DOT3-V2-MIB
- 13-LLDP-EXT-MED-MIB
- 14-LLDP-MIB
- 15-LLDP-V2-MIB
- 16-MAU-MIB
- 17-P-BRIDGE-MIB
- 18-Q-BRIDGE-MIB
- 19-BRIDGE-MIB
- 20-EtherLike-MIB
- 21-HH3C-LAG-MIB
- 22-HH3C-LLDP-EXT-MIB
- 23-HH3C-LPBKDT-MIB
- 24-HH3C-LswMAM-MIB
- 25-HH3C-LswMSTP-MIB
- 26-HH3C-LswVLAN-MIB
| 01-HH3C-MAC-INFORMATION-MIB | 85.56 KB |
hh3cMACInformationcSendInterval
hh3cMACInformationLearntMACNum
hh3cMACInformationRemovedMACNum
hh3cMACInformationSyslogSendNum
hh3cMACInformationChangedTrapExt
About this MIB
Use this MIB to configure MAC Information.
MIB file name
hh3c-mac-information.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMACInformation(87)
Scalar objects
hh3cMACInformationEnabled
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInformationEnabled (1.3.6.1.4.1.25506.2.87.1.1.1) |
read-write |
INTEGER |
enabled(1) disabled(2) |
Status of the MAC Information feature. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInformationcSendInterval(1.3.6.1.4.1.25506.2.87.1.1.2) |
read-write |
Integer32 |
Integer32 (1..20000) |
MAC change notification interval. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInformationLearntMACNum(1.3.6.1.4.1.25506.2.87.1.1.3) |
read-only |
Counter32 |
Standard MIB values. |
Total number of the MAC addresses learned since MAC information is enabled. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInformationRemovedMACNum (1.3.6.1.4.1.25506.2.87.1.1.4) |
read-only |
Counter32 |
Total number of the MAC addresses deleted or aged since MAC information is enabled. |
As per the MIB. |
hh3cMACInformationTrapSendNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInformationTrapSendNum (1.3.6.1.4.1.25506.2.87.1.1.5) |
read-only |
Counter32 |
Number of sent SNMP notifications. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInformationSyslogSendNum (1.3.6.1.4.1.25506.2.87.1.1.6) |
read-write |
Counter32 |
Number of sent syslog messages. |
As per the MIB. |
hh3cMACInformationCacheLen
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInformationCacheLen (1.3.6.1.4.1.25506.2.87.1.1.7) |
read-write |
Integer32 |
Integer32 (0..1000) |
MAC Information queue length. |
As per the MIB. |
hh3cMACInfomationWorkMode
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfomationWorkMode (1.3.6.1.4.1.25506.2.87.1.1.8) |
read-write |
Hh3cMACInfoWorkMode |
trap(1) syslog(2) |
MAC Information mode |
As per the MIB. |
hh3cMACInfoTrapVerExt
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfoTrapVerExt (1.3.6.1.4.1.25506.2.87.1.4.2.1) |
accessible-for-notify |
Integer32 |
SNMP version. |
As per the MIB. |
hh3cMACInfoTrapIndexExt
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfoTrapIndexExt (1.3.6.1.4.1.25506.2.87.1.4.2.2) |
Integer32 |
Integer32 (0..4294967295) |
Notification index. |
As per the MIB. |
hh3cMACInfoTrapCountExt
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfoTrapCountExt (1.3.6.1.4.1.25506.2.87.1.4.2.3) |
Integer32 |
Notification count. |
As per the MIB. |
hh3cMACInfoTrapMsgExt
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfoTrapMsgExt (1.3.6.1.4.1.25506.2.87.1.4.2.4) |
OCTET STRING |
OCTET STRING (0..255) |
Notification contents. |
As per the MIB. |
Tabular objects
hh3cMACInfomationIfTable
About this table
Use this table to configure MAC Information on ports.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is ifIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACLearntEnable (1.3.6.1.4.1.25506.2.87.1.2.1.1.1) |
read-write |
INTEGER |
MAC learning event reporting. |
As per the MIB. |
hh3cMACRemovedEnable (1.3.6.1.4.1.25506.2.87.1.2.1.1.2) |
read-write |
INTEGER |
MAC aging or deletion event reporting. |
As per the MIB. |
Notifications
This table contains notifications output by HH3C-MAC-INFORMATION-MIB.
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.87.1.4.0.1 |
MAC changes. |
Informational |
Warning |
ON |
This notification is generated when MAC addresses change.
If the number of cached MAC notifications reaches the limit set with hh3cMACInformationCacheLen while the amount of time that has elapsed since last notification transmission is shorter than the interval set with hh3cMACInformationcSendInterval, the device uses a new MAC notification to overwrite the oldest one. If the elapsed time is longer than the interval and at least one cached MAC address has been learned or deleted, the device sends notifications.
Status control
This notification cannot be disabled.
Objects
OID (Object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.87.1.4.2.1 (hh3cMACInfoTrapVerExt) |
SNMP version. |
N |
Unsigned32 |
1.3.6.1.4.1.25506.2.87.1.4.2.2 (hh3cMACInfoTrapIndexExt) |
N |
Unsigned32 |
Unsigned32 (1..2147483647) |
1.3.6.1.4.1.25506.2.87.1.4.2.3 (hh3cMACInfoTrapCountExt) |
N |
Unsigned32 |
1.3.6.1.4.1.25506.2.87.1.4.2.4 (hh3cMACInfoTrapMsgExt) |
N |
OCTET STRING |
OCTET STRING (1..254) |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
hh3cMACInformationMovedTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.87.1.4.0.2 |
A MAC address moves. |
Informational |
Warning |
OFF |
This notification is generated when a MAC address moves.
After you enable notifications for the MAC address table, the MAC address table module generates notifications for important events and sends the notifications to the SNMP module. You can configure SNMP to output those notifications. When notifications are disabled for the MAC address table, the device sends the generated logs to the information center. To display the logs, configure the log destination and output rules in the information center.
Status control
This notification can be disabled.
Objects
OID (Object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.87.1.4.2.5.0 (hh3cMACInfoTrapMsgMovedAddress) |
MAC address. |
N |
OCTET STRING |
1.3.6.1.4.1.25506.2.87.1.4.2.6.0 (hh3cMACInfoTrapMsgMovedVlan) |
VLAN ID. |
N |
Unsigned32 |
Unsigned32 (1..4094) |
1.3.6.1.4.1.25506.2.87.1.4.2.7.0 (hh3cMACInfoTrapMsgMovedFromIf) |
Source port for the MAC address move. |
N |
Unsigned32 |
Unsigned32(1..2147483647) |
1.3.6.1.4.1.25506.2.87.1.4.2.8.0 (hh3cMACInfoTrapMsgMovedToIf) |
Destination port for the MAC address move. |
N |
Unsigned32 |
1.3.6.1.4.1.25506.2.87.1.4.2.9.0 (hh3cMACInfoTrapMsgMovedCount) |
MAC address move count. |
N |
Counter32 |
This table does not contain indexes. For information about the index or indexes of a MIB object instance, see the section for that MIB object.
Recommended action
