04-Layer 2 - LAN Switching
HomeSupportResource CenterSwitchesS12500R SeriesS12500R SeriesTechnical DocumentsReference GuidesMIB CompanionH3C S12500R Switch Router Series MIB Companion(52xx)-6W10004-Layer 2 - LAN Switching
20-EtherLike-MIB
20-EtherLike-MIB 108.61 KB
EtherLike-MIB
About this MIB
Use this MIB to obtain basic Ethernet interface information, collect diagnosis information, and configure the system operating mode.
MIB file name
rfc3635-EtherLike.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).dot3(7).dot3StatsTable(2).dot3StatsEntry(1)
Tabular objects
dot3StatsTable
About this table
This table contains statistics for a collection of Ethernet-like interfaces attached to a particular system.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is dot3StatsIndex.
Object (OID)
Access
Value range
Implementation
dot3StatsIndex (1.3.6.1.2.1.10.7.2.1.1)
read-only
INTEGER
Standard MIB values.
Unique index of the interface attached to an Ethernet-link medium.
As per the MIB.
dot3StatsAlignmentErrors (1.3.6.1.2.1.10.7.2.1.2)
read-only
Counter32
Number of frames that fail to pass FCS check.
As per the MIB.
dot3StatsFCSErrors (1.3.6.1.2.1.10.7.2.1.3)
read-only
Counter32
Number of frames received on a particular interface that are an integral number of octets in length but do not pass the FCS check.
As per the MIB.
dot3StatsSingleCollisionFrames (1.3.6.1.2.1.10.7.2.1.4)
read-only
Counter32
Number of frames that are involved in a single collision  and are subsequently transmitted successfully. This counter does not increment when the interface is operating in full-duplex mode.
As per the MIB.
dot3StatsMultipleCollisionFrames (1.3.6.1.2.1.10.7.2.1.5)
read-only
Counter32
Number of frames that are involved in multiple collisions and are subsequently transmitted successfully. This counter does not increment when the interface is operating in full-duplex mode.
As per the MIB.
dot3StatsSQETestErrors (1.3.6.1.2.1.10.7.2.1.6)
read-only
Counter32
Number of times that the SQE TEST ERROR messages are received on a particular interface.
As per the MIB.
dot3StatsDeferredTransmissions (1.3.6.1.2.1.10.7.2.1.7)
read-only
Counter32
Number of frames for which the first transmission attempt on a particular interface is delayed because the medium is busy.
As per the MIB.
dot3StatsLateCollisions (1.3.6.1.2.1.10.7.2.1.8)
read-only
Counter32
Number of times that a collision is detected on a particular interface later than one slotTime into the transmission of a packet. This counter does not increment when the interface is operating in full-duplex mode.
As per the MIB.
dot3StatsExcessiveCollisions (1.3.6.1.2.1.10.7.2.1.9)
read-only
Counter32
Number of frames for which transmission on a particular interface fails due to excessive collisions.
As per the MIB.
dot3StatsInternalMacTransmitErrors (1.3.6.1.2.1.10.7.2.1.10)
read-only
Counter32
Number of frames for which transmission on a particular interface fails due to an internal MAC sublayer transmit error.
As per the MIB.
dot3StatsCarrierSenseErrors (1.3.6.1.2.1.10.7.2.1.11)
read-only
Counter32
Number of times that the carrier sense condition was lost or never asserted when attempting to transmit a frame on a particular interface.
As per the MIB.
dot3StatsFrameTooLongs (1.3.6.1.2.1.10.7.2.1.13)
read-only
Counter32
Number of frames received on a particular interface that exceed the maximum permitted frame size.
As per the MIB.
dot3StatsInternalMacReceiveErrors (1.3.6.1.2.1.10.7.2.1.16)
read-only
Counter32
Number of frames for which reception on a particular interface fails due to an internal MAC sublayer receive error.
As per the MIB.
dot3StatsEtherChipSet (1.3.6.1.2.1.10.7.2.1.17)
read-only
Object Identifier
This object contains an OBJECT IDENTIFIER.
Not supported
dot3StatsSymbolErrors (1.3.6.1.2.1.10.7.2.1.18)
read-only
Counter
For interfaces operating at 100 Mbps.
As per the MIB.
dot3StatsDuplexStatus (1.3.6.1.2.1.10.7.2.1.19)
read-only
Integer
unknown(1),
halfDuplex(2),
fullDuplex(3)
Current mode of operation of the MAC entity.
As per the MIB.
dot3StatsRateControlAbility
(1.3.6.1.2.1.10.7.2.1.20)
read-only
Integer
For interfaces operating at speeds above 1000 Mbps.
As per the MIB.
dot3StatsRateControlStatus
(1.3.6.1.2.1.10.7.2.1.21)
read-only
OBJECT IDENTIFIER
rateControlOff(1),
rateControlOn(2),
unknown(3)
Current rate control mode of operation of the MAC sublayer of this interface.
As per the MIB.
dot3CollTable
About this table
This table contains a collection of collision histograms for a particular set of interfaces.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ifIndex and dot3CollCount.
Object (OID)
Access
Value range
Implementation
dot3CollCount (1.3.6.1.2.1.10.7.5.1.2)
not-accessible
Integer
Integer (1..16)
Number of per-frame media collisions for which a particular collision histogram cell represents the frequency on a particular interface.
As per the MIB.
dot3CollFrequencies (1.3.6.1.2.1.10.7.5.1.3)
read-only
Counter32
Number of individual MAC frames for which the transmission (successful or otherwise) on a particular interface occurs.
As per the MIB.
dot3ControlTable
About this table
This table contains the descriptive and status information about the MAC Control sublayer on the Ethernet-like interfaces attached to a particular system.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
dot3ControlFunctionsSupported (1.3.6.1.2.1.10.7.9.1.1)
read-only
BITS
pause(0)
List of the possible MAC Control functions implemented for this interface.
As per the MIB.
dot3ControlInUnknownOpcodes (1.3.6.1.2.1.10.7.9.1.2)
read-only
Counter32
Number of MAC Control frames received on this interface that contain an opcode that is not supported by this device.
As per the MIB.
dot3HCControlInUnknownOpcodes(1.3.6.1.2.1.10.7.9.1.3)
read-only
Counter64
64-bit counter of the dot3ControlInUnknownOpcodes object. This object applies to 10-Gbps or faster interfaces.
As per the MIB.
dot3PauseTable
About this table
This table contains the descriptive and status information about the MAC Control PAUSE function on the Ethernet-like interfaces attached to a particular system.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
dot3PauseAdminMode (1.3.6.1.2.1.10.7.10.1.1)
read-write
Integer 32
disabled(1),
enabledXmit(2),
enabledRcv(3),
enabledXmitAndRcv(4)
Configure the default administrative PAUSE mode for this interface.
The object can only be read.
dot3PauseOperMode (1.3.6.1.2.1.10.7.10.1.2)
read-only
Integer32
disabled(1),
enabledXmit(2),
enabledRcv(3),
This object reflects the PAUSE mode currently in use on this interface.
As per the MIB.
dot3InPauseFrames (1.3.6.1.2.1.10.7.10.1.3)
read-only
Counter32
Number of MAC Control frames received on this interface with an opcode indicating the PAUSE operation.
This counter does not increment when the interface is operating in half-duplex mode.
As per the MIB.
dot3OutPauseFrames (1.3.6.1.2.1.10.7.10.1.4)
read-only
Counter32
Number of MAC Control frames transmitted on this interface with an opcode indicating the PAUSE operation.
As per the MIB.
dot3HCInPauseFrames
(1.3.6.1.2.1.10.7.10.1.5)
read-only
Counter64
As per the MIB.
dot3HCOutPauseFrames
(1.3.6.1.2.1.10.7.10.1.6)
read-only
Counter64
As per the MIB.
dot3HCStatsTable
About this table
This table contains 64-bit versions of error counters for a single Ethernet-like interface.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
dot3HCStatsFCSErrors
(1.3.6.1.2.1.10.7.11.1.2)
read-only
Counter64
As per the MIB.
dot3HCStatsInternalMacTransmitErrors
(1.3.6.1.2.1.10.7.11.1.3)
read-only
Counter64
As per the MIB.
dot3HCStatsFrameTooLongs(1.3.6.1.2.1.10.7.11.1.4)
read-only
Counter64
As per the MIB.
dot3HCStatsInternalMacReceiveErrors
(1.3.6.1.2.1.10.7.11.1.5)
read-only
Counter64
As per the MIB.
dot3HCStatsSymbolErrors
(1.3.6.1.2.1.10.7.11.1.6)
read-only
Counter64
Number of invalid data symbols.
As per the MIB.
  • Become a Partner
  • Partner Resources
