- 04-Layer 2 - LAN Switching
- 01-HH3C-MAC-INFORMATION-MIB
- 02-HH3C-MLAG-MIB
- 03-HH3C-PVST-MIB
- 04-HH3C-QINQV2-MIB
- 05-HH3C-VLANTERM-MIB
- 06-HH3C-VMAP-MIB
- 07-IEEE8021-CFM-MIB
- 08-IEEE8023-LAG-MIB
- 09-LLDP-EXT-DOT1-MIB
- 10-LLDP-EXT-DOT1-V2-MIB
- 11-LLDP-EXT-DOT3-MIB
- 12-LLDP-EXT-DOT3-V2-MIB
- 13-LLDP-EXT-MED-MIB
- 14-LLDP-MIB
- 15-LLDP-V2-MIB
- 16-MAU-MIB
- 17-P-BRIDGE-MIB
- 18-Q-BRIDGE-MIB
- 19-BRIDGE-MIB
- 20-EtherLike-MIB
- 21-HH3C-LAG-MIB
- 22-HH3C-LLDP-EXT-MIB
- 23-HH3C-LPBKDT-MIB
- 24-HH3C-LswMAM-MIB
- 25-HH3C-LswMSTP-MIB
- 26-HH3C-LswVLAN-MIB
| 02-HH3C-MLAG-MIB | 144.93 KB |
Table of Contents
hh3cMLagAutoRecoveryReloadDelay
hh3cMLagRoleLocalConfiguredRole
hh3cMLagRolePeerConfiguredRole
hh3cMLagRoleLocalEffectiveRole
HH3C-MLAG-MIB
About this MIB
Multichassis Link Aggregation Group (M-LAG) virtualizes two physical devices into one system through multichassis link aggregation to provide node redundancy in addition to link redundancy.
HH3C-MLAG-MIB is a private MIB for managing M-LAG from an NMS. This MIB offers following functions: 1. Obtain and modify M-LAG system settings such as the M-LAG system MAC address, priority, and number. 2. Obtain and modify M-LAG keepalive settings. 3. Obtain information about and configure peer-link interfaces and M-LAG interfaces.
MIB file name
hh3c-mlag.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).h3cCommon(2).hh3cMLag(176)
Scalar objects
hh3cMLagSystemMac
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagSystemMac (1.3.6.1.4.1.25506.2.176.1.1.1) |
read-write |
MacAddress |
OCTET STRING(6) |
M-LAG system MAC address. |
Default value: 0-0-0-0-0-0. |
hh3cMLagSystemPriority
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagSystemPriority (1.3.6.1.4.1.25506.2.176.1.1.2) |
read-write |
Integer32 |
Integer32 (0..65535) |
M-LAG system priority. |
You must configure the same M-LAG system priority for the M-LAG member devices in an M-LAG system. |
hh3cMLagSystemNumber
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagSystemNumber (1.3.6.1.4.1.25506.2.176.1.1.3) |
read-write |
Integer32 |
Integer32 (0..2) |
M-LAG system number. |
Default value: 0. |
hh3cMLagRestoreDelay
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagRestoreDelay (1.3.6.1.4.1.25506.2.176.1.1.4) |
read-write |
Integer32 |
Integer32 (1..3600) |
Data restoration interval. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagAutoRecoveryReloadDelay (1.3.6.1.4.1.25506.2.176.1.1.5) |
read-write |
Integer32 |
Integer32 (0|240..3600) |
Reload delay for M-LAG system auto-recovery. |
A value of 0 indicates that M-LAG system auto-recovery is disabled. |
hh3cMLagRoleLocalRolePriority
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagRoleLocalRolePriority (1.3.6.1.4.1.25506.2.176.1.2.1) |
read-write |
Integer32 |
The role priority of the local M-LAG member device. |
The smaller the priority value, the higher the priority. |
hh3cMLagRolePeerRolePriority
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagRolePeerRolePriority (1.3.6.1.4.1.25506.2.176.1.2.2) |
read-only |
Integer32 |
Role priority of the peer M-LAG member device. |
hh3cMLagRoleLocalBridgeMac
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagRoleLocalBridgeMac (1.3.6.1.4.1.25506.2.176.1.2.3) |
read-only |
MacAddress |
OCTET STRING(6) |
Bridge MAC address of the local M-LAG member device. |
Default value: 0-0-0-0-0-0 |
hh3cMLagRolePeerBridgeMac
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagRolePeerBridgeMac (1.3.6.1.4.1.25506.2.176.1.2.4) |
read-only |
MacAddress |
OCTET STRING(6) |
Bridge MAC address of the peer M-LAG member device. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagRoleLocalConfiguredRole (1.3.6.1.4.1.25506.2.176.1.2.5) |
read-only |
INTEGER |
none(0), primary(1), secondary(2) |
Specified role for the local M-LAG member device. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagRolePeerConfiguredRole (1.3.6.1.4.1.25506.2.176.1.2.6) |
read-only |
INTEGER |
Specified role for the peer M-LAG member device. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagRoleLocalEffectiveRole (1.3.6.1.4.1.25506.2.176.1.2.7) |
read-only |
INTEGER |
Effective role for the local M-LAG member device. |
As per the MIB. |
hh3cMLagRolePeerEffectiveRole
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagRolePeerEffectiveRole (1.3.6.1.4.1.25506.2.176.1.2.8) |
read-only |
INTEGER |
Effective role for the peer M-LAG member device. |
As per the MIB. |
hh3cMLagKeepaliveDestIpv4
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagKeepaliveDestIpv4 (1.3.6.1.4.1.25506.2.176.1.3.1) |
read-write |
InetAddressIPv4 |
OCTET STRING(4) |
Destination IP address of keepalive packets. |
Default value: 0.0.0.0. |
hh3cMLagKeepaliveSourceIpv4
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagKeepaliveSourceIpv4 (1.3.6.1.4.1.25506.2.176.1.3.2) |
read-write |
InetAddressIPv4 |
OCTET STRING(4) |
Source IP address of keepalive packets. |
Default value: 0.0.0.0. Configured with the destination IP address of keepalive packets. |
hh3cMLagKeepaliveDestIpv6
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagKeepaliveDestIpv6 (1.3.6.1.4.1.25506.2.176.1.3.3) |
read-write |
InetAddressIPv6 |
OCTET STRING(16) |
Destination IPv6 address of keepalive packets. |
Default value: 0:0::0:0. |
hh3cMLagKeepaliveSourceIpv6
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagKeepaliveSourceIpv6 (1.3.6.1.4.1.25506.2.176.1.3.4) |
read-write |
InetAddressIPv6 |
OCTET STRING(16) |
Source IPv6 address of keepalive packets. |
Default value: 0.0:: 0.0. Configured with the destination IPv6 address of keepalive packets. |
hh3cMLagKeepaliveUdpPort
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagKeepaliveUdpPort (1.3.6.1.4.1.25506.2.176.1.3.5) |
read-write |
Integer32 |
Integer32 (1..65535) |
Destination UDP port of keepalive packets. |
The destination UDP port is also deleted when the keepalive source and destination IP addresses are deleted. |
hh3cMLagKeepaliveInterval
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagKeepaliveInterval (1.3.6.1.4.1.25506.2.176.1.3.6) |
read-write |
Integer32 |
Integer32 (100..10000) |
M-LAG keepalive interval. |
As per the MIB. |
hh3cMLagKeepaliveTimeout
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagKeepaliveTimeout (1.3.6.1.4.1.25506.2.176.1.3.7) |
read-write |
Integer32 |
Integer32 (3..20) |
M-LAG keepalive timeout timer. |
The local M-LAG keepalive timeout timer must be at least two times the M-LAG keepalive interval of the peer. |
hh3cMLagKeepaliveHoldTime
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagKeepaliveHoldTime (1.3.6.1.4.1.25506.2.176.1.3.8) |
read-write |
Integer32 |
Integer32 (3..10) |
Keepalive hold timer. |
As per the MIB. |
hh3cMLagKeepaliveLinkStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagKeepaliveLinkStatus (1.3.6.1.4.1.25506.2.176.1.3.9) |
read-only |
INTEGER |
unknown(1), up(2), down(3) |
Keepalive link status. |
As per the MIB. |
hh3cMLagNotSelectedReason
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagNotSelectedReason (1.3.6.1.4.1.25506.2.176.2.1.3) |
accessible-for-notify |
OCTET STRING |
OCTET STRING(0..255) |
Reason why no selected member port exists for the M-LAG interface. |
As per the MIB. |
hh3cMLagKeepAliveDownReason
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagKeepAliveDownReason(1.3.6.1.4.1.25506.2.176.2.1.4 ) |
OCTET STRING |
Reason why the keepalive link goes down. |
As per the MIB. |
hh3cMLagMadDownReason
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagMadDownReason(1.3.6.1.4.1.25506.2.176.2.1.5 ) |
OCTET STRING |
Reason why the device is placed in M-LAG MAD DOWN state. |
As per the MIB. |
hh3cMLagOldRole
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagOldRole(1.3.6.1.4.1.25506.2.176.2.1.6 ) |
INTEGER |
Previous role for the device. |
As per the MIB. |
hh3cMLagNewRole
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagNewRole(1.3.6.1.4.1.25506.2.176.2.1.7 ) |
INTEGER |
New role for the device. |
As per the MIB. |
hh3cMLagRoleChangeReason
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagRoleChangeReason(1.3.6.1.4.1.25506.2.176.2.1.8 ) |
OCTET STRING |
Reason for the device role switching. |
As per the MIB. |
Tabular objects
hh3cMLagPeerLinkTable
About this table
Use this table to obtain and configure parameters for peer-link interfaces.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Supported |
Supported |
Columns
The table index is hh3cMLagPeerLinkNumber.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagPeerLinkNumber (1.3.6.1.4.1.25506.2.176.1.4.1.1.1) |
not-accessible |
Integer32 |
Integer32 (1..2) |
Peer-link interface number. |
The peer-link interface number can only be 1. |
hh3cMLagPeerLinkIfIndex (1.3.6.1.4.1.25506.2.176.1.4.1.1.2) |
read-write |
InterfaceIndex |
Integer32 (1..2147483647) |
Index of the aggregate interface acting as the peer-link interface. |
As per the MIB. |
hh3cMLagPeerLinkRowStatus (1.3.6.1.4.1.25506.2.176.1.4.1.1.3) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
Supports only destroy(6). |
hh3cMLagPortTable
About this table
Use this table to configure and obtain parameters for M-LAG interfaces.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Supported |
Supported |
Columns
The table index is hh3cMLagGroupId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagGroupId (1.3.6.1.4.1.25506.2.176.1.4.2.1.1) |
not-accessible |
Integer32 |
Integer32 (1..1024) |
M-LAG group ID. |
As per the MIB. |
hh3cMLagPortIfIndex (1.3.6.1.4.1.25506.2.176.1.4.2.1.2) |
read-write |
InterfaceIndex |
Index of the aggregate interface acting as the M-LAG interface. |
As per the MIB. |
hh3cMLagPortRowStatus (1.3.6.1.4.1.25506.2.176.1.4.2.1.3) |
read-create |
RowStatus |
Row status. |
hh3cMLagAllPortTable
About this table
Use this table to obtain and configure selected member port information, DRCP state, and the short DRCP timeout timer for peer-link interfaces and M-LAG interfaces.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cMLagAllPortIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagAllPortIfIndex (1.3.6.1.4.1.25506.2.176.1.4.3.1.1) |
not-accessible |
InterfaceIndex |
Interface index |
As per the MIB. |
hh3cMLagPortDrcpIsShortPeriod (1.3.6.1.4.1.25506.2.176.1.4.3.1.2) |
read-write |
TruthValue |
true(1), false(2) |
Whether the short DRCP timeout timer is enabled. |
As per the MIB. |
hh3cMLagPortPortStatus (1.3.6.1.4.1.25506.2.176.1.4.3.1.3) |
read-only |
INTEGER |
up(1), down(2) |
Interface status |
As per the MIB. |
hh3cMLagPortLocalDRCPState (1.3.6.1.4.1.25506.2.176.1.4.3.1.4) |
read-only |
OCTET STRING |
OCTET STRING(1) |
DRCP status on the local end. |
As per the MIB. |
hh3cMLagPortPeerDRCPState (1.3.6.1.4.1.25506.2.176.1.4.3.1.5) |
read-only |
OCTET STRING |
OCTET STRING(1) |
DRCP status on the peer end. |
As per the MIB. |
hh3cMLagPortLocalMemberList (1.3.6.1.4.1.25506.2.176.1.4.3.1.6) |
read-only |
PortList |
Member list of the local aggregate interface. |
As per the MIB. |
hh3cMLagPortPeerMemberList (1.3.6.1.4.1.25506.2.176.1.4.3.1.7) |
read-only |
PortList |
Member list of the peer aggregate interface. |
As per the MIB. |
Notifications
hh3cMLagIfCheckConsistency
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.3 |
Consistency is detected during the consistency check on M-LAG interfaces. |
Informational |
Warning |
OFF |
This notification is generated if the consistency check result for M-LAG interfaces is consistent.
Status control
This notification cannot be disabled.
Objects
OID |
Index |
Type |
Value range |
6.1.4.1.2.1.2.2.1.1 (ifIndex) |
Interface index |
No |
Integer32 |
6.1.4.1.2.1.2.2.1.2 (ifDescr) |
Interface name |
Yes |
OCTET STRING |
Recommended action
No action is required.
hh3cMLagIfCheckInConsistency
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.4 |
Inconsistency is detected during the consistency check on M-LAG interfaces. |
Informational |
Warning |
OFF |
This notification is generated if the consistency check result for M-LAG interfaces is inconsistent.
Status control
Objects
OID |
Index |
Type |
Value range |
Interface index |
No |
Integer32 |
Interface name |
Yes |
OCTET STRING |
Recommended action
To resolve the issue: 1. If the consistency check on M-LAG interfaces for the type 1 configuration is inconsistent, use the display m-lag consistency command to view configuration information on the M-LAG member devices, and modify their configuration to ensure consistency.
2. If the consistency check on M-LAG interfaces for the type 2 configuration is inconsistent, modify the configuration on the M-LAG member devices to ensure consistency.
hh3cMLagKeepaliveDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.13 |
The keepalive link goes down. |
Informational |
Warning |
OFF |
This notification is generated when the keepalive link goes down.
Status control
Objects
OID |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.176.2.1.4 hh3cMLagKeepAliveDownReason |
No |
OCTET STRING |
Recommended action
To resolve the issue: 1. Check the device role.
2. Verify that the source and destination IP addresses of keepalive packets are consistent between the M-LAG member devices.
3. Check the state of the Layer 3 link used for keepalive detection.
hh3cMLagKeepaliveUp
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.14 |
The keepalive link comes up. |
Informational |
Warning |
OFF |
This notification is generated if keepalive packets can be sent and received correctly between the M-LAG member devices.
Status control
Objects
Recommended action
hh3cMLagDeviceMadDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.15 |
The device is placed in M-LAG MAD DOWN state. |
Informational |
Warning |
OFF |
This notification is generated when service interfaces are shut down by M-LAG MAD.
Status control
Objects
OID |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.176.2.1.5 hh3cMLagMadDownReason |
No |
OCTET STRING |
Recommended action
To resolve the issue, check settings on both ends of the peer link.
hh3cMLagDeviceMadRecovery
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.16 |
The device brings up service interfaces that are placed in M-LAG MAD DOWN state. |
Informational |
Warning |
OFF |
This notification is generated when the device brings up service interfaces that are placed in M-LAG MAD DOWN state.
Status control
Objects
Recommended action
hh3cMLagDeviceRoleChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.17 |
The M-LAG member device role is changed. |
Informational |
Warning |
OFF |
This notification is generated when the M-LAG member device role is changed.
Status control
Objects
OID |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.176.2.1.6 hh3cMLagOldRole |
No |
INTEGER |
1.3.6.1.4.1.25506.2.176.2.1.7 hh3cMLagNewRole |
No |
INTEGER |
1.3.6.1.4.1.25506.2.176.2.1.8 hh3cMLagRoleChangeReason |
Reason for the device role change. |
No |
OCTET STRING |
Recommended action
