04-Layer 2 - LAN Switching
HomeSupportResource CenterSwitchesS12500R SeriesS12500R SeriesTechnical DocumentsReference GuidesMIB CompanionH3C S12500R Switch Router Series MIB Companion(52xx)-6W10004-Layer 2 - LAN Switching
17-P-BRIDGE-MIB
17-P-BRIDGE-MIB 38.65 KB
P-BRIDGE-MIB
About this MIB
Use this table to manage the priorities and multicast filtering defined in IEEE 802.1D-1998.
MIB file name
Rfc4363-pbridge.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2().dod1dBridge(17).pBridgeMIB(6)
Scalar objects
OID of this table is: 1.3.6.1.2.1.17.6.1.1
Object (OID)
Access
Value range
Implementation
dot1dDeviceCapabilities (1.3.6.1.2.1.17.6.1.1.1)
read-only
BITS
dot1dExtendedFilteringServices(0),
dot1dTrafficClasses(1),
dot1qStaticEntryIndividualPort(2),
dot1qIVLCapable(3),
dot1qSVLCapable(4),
dot1qHybridCapable(5),
dot1qConfigurablePvidTagging(6),
dot1dLocalVlanCapable(7)
Device capabilities.
As per the MIB.
dot1dTrafficClassesEnabled (1.3.6.1.2.1.17.6.1.1.2)
read-write
TruthValue
true(1),
false(2)
Whether traffic classification is supported.
Read-only.
dot1dGmrpStatus (1.3.6.1.2.1.17.6.1.1.3)
read-write
EnabledStatus
enabled(1),
disabled(2)
GMRP enabling state.
Not supported
Tabular objects
dot1dPortCapabilitiesTable
OID of this table is: 1.3.6.1.2.1.17.6.1.1.4
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.17.6.1.1.4.1.1)
read-only
BITS
dot1qDot1qTagging(0) ,
dot1qConfigurableAcceptableFrameTypes(1) ,
dot1qIngressFiltering(2)
Port capabilities.
As per the MIB.
  • Become a Partner
  • Partner Resources
