- H3C S6850&S9850&S9820-64H Config Examples-Release 655x-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 14-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 15-GRE Tunnel Configuration Examples
- 16-GRE with OSPF Configuration Examples
- 17-OSPF Configuration Examples
- 18-IS-IS Configuration Examples
- 19-BGP Configuration Examples
- 20-Policy-Based Routing Configuration Examples
- 21-OSPFv3 Configuration Examples
- 22-IPv6 IS-IS Configuration Examples
- 23-Routing Policy Configuration Examples
- 24-IGMP Snooping Configuration Examples
- 25-IGMP Configuration Examples
- 26-BIDIR-PIM Configuration Examples
- 27-MLD Snooping Configuration Examples
- 28-IPv6 Multicast VLAN Configuration Examples
- 29-Basic MPLS Configuration Examples
- 30-MPLS L3VPN Configuration Examples
- 31-ACL Configuration Examples
- 32-Control Plane-Based QoS Policy Configuration Examples
- 33-Traffic Policing Configuration Examples
- 34-GTS and Rate Limiting Configuration Examples
- 35-Priority Mapping and Queue Scheduling Configuration Examples
- 36-Traffic Filtering Configuration Examples
- 37-AAA Configuration Examples
- 38-Port Security Configuration Examples
- 39-Portal Configuration Examples
- 40-SSH Configuration Examples
- 41-IP Source Guard Configuration Examples
- 42-Ethernet OAM Configuration Examples
- 43-CFD Configuration Examples
- 44-DLDP Configuration Examples
- 45-VRRP Configuration Examples
- 46-BFD Configuration Examples
- 47-NTP Configuration Examples
- 48-SNMP Configuration Examples
- 49-NQA Configuration Examples
- 50-Mirroring Configuration Examples
- 51-sFlow Configuration Examples
- 52-FCoE Configuration Examples
- 53-OpenFlow Configuration Examples
- 54-MAC Address Table Configuration Examples
- 55-Static Multicast MAC Address Entry Configuration Examples
- 56-IP Unnumbered Configuration Examples
- 57-MVRP Configuration Examples
- 58-MCE Configuration Examples
- 59-Congestion Avoidance and Queue Scheduling Configuration Examples
- 60-Attack Protection Configuration Examples
- 61-Smart Link Configuration Examples
- 62-RRPP Configuration Examples
- 63-BGP Route Selection Configuration Examples
- 64-IS-IS Route Summarization Configuration Examples
- 65-IRF Configuration Examples
- 66-MPLS OAM Configuration Examples
- 67-MPLS TE Configuration Examples
- 68-VXLAN Configuration Examples
- 69-NetStream Configuration Examples
- 70-DRNI Configuration Examples
- 71-DRNI and EVPN Configuration Examples
- 72-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 73-VCF Fabric Configuration Examples
- 74-PTP Configuration Examples
- 75-S-MLAG Configuration Examples
- 76-Puppet Configuration Examples
| 67-MPLS TE Configuration Examples | 140.10 KB |
H3C S6850 & S9850 & S9820-64H |
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Example: Establishing MPLS TE tunnels with RSVP-TE
Example: Configuring MPLS TE forwarding adjacency
Introduction
This document provides MPLS TE configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of MPLS TE.
As shown in Figure 1, use RSVP-TE to establish two MPLS TE tunnels between Switch A and Switch D. The MPLS TE tunnel for Enterprise A requires a bandwidth of 20000 kbps. The MPLS TE tunnel for Enterprise B requires a bandwidth of 30000 kbps.
The maximum bandwidth of the link that each tunnel traverses is 50000 kbps and the maximum reservable bandwidth is 40000 kbps.
Analysis
To establish MPLS TE tunnels through RSVP-TE, you must perform the following tasks:
· Enable MPLS, MPLS TE, and RSVP-TE on nodes that the MPLS TE tunnels traverse.
· On each interface that the MPLS TE tunnels traverse, configure link TE attributes, including the maximum link bandwidth and the maximum reservable bandwidth.
· On each node that the MPLS TE tunnels traverse, configure the IGP TE extension to advertise the link TE attributes, which generates a TEDB on each node.
Based on the TEDB, CSPF calculates the shortest, TE constraints-compliant path to the tunnel destination. If you do not configure the IGP TE extension, the path is created based on IGP routing. The supported IGP TE extensions are OSPF TE and ISIS TE. This example uses OSPF TE.
· Create a tunnel interface on the ingress node of each MPLS TE tunnel, and perform the following tasks on the tunnel interface:
¡ Specify the tunnel destination address.
¡ Specify the tunnel bandwidth as required (20000 kbps for Enterprise A and 30000 kbps for Enterprise B).
¡ Specify the MPLS TE signaling protocol as RSVP-TE.
RSVP-TE advertises labels to establish CRLSPs and reserves bandwidth resources on each node along the calculated path.
· On the ingress node of each MPLS TE tunnel, configure static routing to direct traffic to the MPLS TE tunnel.
Hardware |
Software version |
S6850 switch series S9850 switch series |
Release 6555P01 |
S9820-64H switch |
Release 6555P01 |
Before configuration, disable the spanning tree feature globally or map each VLAN to an MSTI.
Procedures
1. Configure IP addresses for interfaces:
# Configure IP addresses and masks for interfaces on Switch A, including the loopback interface, as shown in Figure 1.
[SwitchA] vlan 10
[SwitchA-vlan10] port hundredgige 1/0/1
[SwitchA-vlan10] quit
[SwitchA-Vlan-interface10] ip address 10.1.1.1 24
[SwitchA] vlan 30
[SwitchA-vlan30] port hundredgige 1/0/2
[SwitchA-vlan30] quit
[SwitchA] interface vlan-interface 30
[SwitchA-Vlan-interface30] ip address 30.1.1.1 24
[SwitchA-Vlan-interface30] quit
[SwitchA] vlan 70
[SwitchA-vlan70] port hundredgige 1/0/3
[SwitchA-vlan70] quit
[SwitchA] interface vlan-interface 70
[SwitchA-Vlan-interface70] ip address 70.1.1.1 24
[SwitchA-Vlan-interface70] quit
[SwitchA] vlan 80
[SwitchA-vlan80] port hundredgige 1/0/4
[SwitchA-vlan80] quit
[SwitchA] interface vlan-interface 80
[SwitchA-Vlan-interface80] ip address 80.1.1.1 24
[SwitchA-Vlan-interface80] quit
[SwitchA-LoopBack0] ip address 1.1.1.1 32
[SwitchA-LoopBack0] quit
# Configure other devices in the same way that Switch A is configured. (Details not shown.)
2. Configure OSPF to ensure IP connectivity among the switches:
# Configure Switch A.
[SwitchA] ospf
[SwitchA-ospf-1] area 0
[SwitchA-ospf-1-area-0.0.0.0] network 1.1.1.1 0.0.0.0
[SwitchA-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[SwitchA-ospf-1] quit
# Configure Switch B.
[SwitchB] ospf
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[SwitchB-ospf-1] quit
# Configure Switch C.
[SwitchC] ospf
[SwitchC-ospf-1] area 0
[SwitchC-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[SwitchC-ospf-1] quit
# Configure Switch D.
[SwitchD] ospf
[SwitchD-ospf-1] area 0
[SwitchD-ospf-1-area-0.0.0.0] network 4.4.4.4 0.0.0.0
[SwitchD-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[SwitchD-ospf-1] quit
# Execute the display ip routing-table command on each switch to verify that the switches have learned the routes to one another, including the routes to the loopback interfaces. The following shows the output on Switch A.
Destinations : 26 Routes : 26
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
1.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
2.2.2.2/32 O_INTRA 10 1 10.1.1.2 Vlan10
3.3.3.3/32 O_INTRA 10 1 30.1.1.3 Vlan30
4.4.4.4/32 O_INTRA 10 2 10.1.1.2 Vlan10
8.1.1.0/24 Direct 0 0 8.1.1.1 Tun2
8.1.1.0/32 Direct 0 0 8.1.1.1 Tun2
8.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
8.1.1.255/32 Direct 0 0 8.1.1.1 Tun2
10.1.1.0/24 Direct 0 0 10.1.1.1 Vlan10
10.1.1.0/32 Direct 0 0 10.1.1.1 Vlan10
10.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
10.1.1.255/32 Direct 0 0 10.1.1.1 Vlan10
20.1.1.0/24 O_INTRA 10 2 10.1.1.2 Vlan10
30.1.1.0/24 Direct 0 0 30.1.1.1 Vlan30
30.1.1.0/32 Direct 0 0 30.1.1.1 Vlan30
30.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
30.1.1.255/32 Direct 0 0 30.1.1.1 Vlan30
40.1.1.0/24 Static 1 0 0.0.0.0 Tun2
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
224.0.0.0/4 Direct 0 0 0.0.0.0 NULL0
224.0.0.0/24 Direct 0 0 0.0.0.0 NULL0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
3. Configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE:
[SwitchA] mpls lsr-id 1.1.1.1
[SwitchA] mpls te
[SwitchA-te] quit
[SwitchA] rsvp
[SwitchA-rsvp] quit
[SwitchA-Vlan-interface10] mpls enable
[SwitchA-Vlan-interface10] mpls te enable
[SwitchA-Vlan-interface10] rsvp enable
[SwitchA-Vlan-interface30] mpls enable
[SwitchA-Vlan-interface30] mpls te enable
[SwitchA-Vlan-interface30] rsvp enable
[SwitchB] mpls lsr-id 2.2.2.2
[SwitchB] mpls te
[SwitchB-te] quit
[SwitchB] rsvp
[SwitchB-rsvp] quit
[SwitchB-Vlan-interface10] mpls enable
[SwitchB-Vlan-interface10] mpls te enable
[SwitchB-Vlan-interface10] rsvp enable
[SwitchB] interface vlan-interface 20
[SwitchB-Vlan-interface20] mpls enable
[SwitchB-Vlan-interface20] mpls te enable
[SwitchB-Vlan-interface20] rsvp enable
[SwitchB-Vlan-interface20] quit
[SwitchC] mpls lsr-id 3.3.3.3
[SwitchC] mpls te
[SwitchC-te] quit
[SwitchC] rsvp
[SwitchC-rsvp] quit
[SwitchC] interface vlan-interface 30
[SwitchC-Vlan-interface30] mpls enable
[SwitchC-Vlan-interface30] mpls te enable
[SwitchC-Vlan-interface30] rsvp enable
[SwitchC-Vlan-interface30] quit
[SwitchC] interface vlan-interface 40
[SwitchC-Vlan-interface40] mpls enable
[SwitchC-Vlan-interface40] mpls te enable
[SwitchC-Vlan-interface40] rsvp enable
[SwitchC-Vlan-interface40] quit
[SwitchD] mpls lsr-id 4.4.4.4
[SwitchD] mpls te
[SwitchD-te] quit
[SwitchD] rsvp
[SwitchD-rsvp] quit
[SwitchD] interface vlan-interface 20
[SwitchD-Vlan-interface20] mpls enable
[SwitchD-Vlan-interface20] mpls te enable
[SwitchD-Vlan-interface20] rsvp enable
[SwitchD-Vlan-interface20] quit
[SwitchD] interface vlan-interface 40
[SwitchD-Vlan-interface40] mpls enable
[SwitchD-Vlan-interface40] mpls te enable
[SwitchD-Vlan-interface40] rsvp enable
[SwitchD-Vlan-interface40] quit
4. Configure MPLS TE attributes of links:
# Configure the maximum link bandwidth and maximum reservable bandwidth on Switch A.
[SwitchA-Vlan-interface10] mpls te max-link-bandwidth 50000
[SwitchA-Vlan-interface10] mpls te max-reservable-bandwidth 40000
[SwitchA-Vlan-interface30] mpls te max-link-bandwidth 50000
[SwitchA-Vlan-interface30] mpls te max-reservable-bandwidth 40000
# Configure the maximum link bandwidth and maximum reservable bandwidth on Switch B.
[SwitchB-Vlan-interface10] mpls te max-link-bandwidth 50000
[SwitchB-Vlan-interface10] mpls te max-reservable-bandwidth 40000
[SwitchB-Vlan-interface20] mpls te max-link-bandwidth 50000
[SwitchB-Vlan-interface20] mpls te max-reservable-bandwidth 40000
# Configure the maximum link bandwidth and maximum reservable bandwidth on Switch C.
[SwitchC-Vlan-interface30] mpls te max-link-bandwidth 50000
[SwitchC-Vlan-interface30] mpls te max-reservable-bandwidth 40000
[SwitchC-Vlan-interface40] mpls te max-link-bandwidth 50000
[SwitchC-Vlan-interface40] mpls te max-reservable-bandwidth 40000
# Configure the maximum link bandwidth and maximum reservable bandwidth on Switch D.
[SwitchD-Vlan-interface20] mpls te max-link-bandwidth 50000
[SwitchD-Vlan-interface20] mpls te max-reservable-bandwidth 40000
[SwitchD-Vlan-interface40] mpls te max-link-bandwidth 50000
[SwitchD-Vlan-interface40] mpls te max-reservable-bandwidth 40000
5. Configure OSPF TE to advertise link TE attributes:
# Enable opaque LSA advertisement and reception on Switch A. By default, the opaque LSA advertisement and reception capability is enabled.
[SwitchA] ospf
[SwitchA-ospf-1] opaque-capability enable
# Enable MPLS TE for OSPF area 0 on Switch A.
[SwitchA-ospf-1-area-0.0.0.0] mpls te enable
# Enable opaque LSA advertisement and reception on Switch B. By default, the opaque LSA advertisement and reception capability is enabled.
[SwitchB] ospf
[SwitchB-ospf-1] opaque-capability enable
# Enable MPLS TE for OSPF area 0 on Switch B.
[SwitchB-ospf-1-area-0.0.0.0] mpls te enable
# Enable opaque LSA advertisement and reception on Switch C. By default, the opaque LSA advertisement and reception capability is enabled.
[SwitchC] ospf
[SwitchC-ospf-1] opaque-capability enable
# Enable MPLS TE for OSPF area 0 on Switch C.
[SwitchC-ospf-1-area-0.0.0.0] mpls te enable
# Enable opaque LSA advertisement and reception on Switch D. By default, the opaque LSA advertisement and reception capability is enabled.
[SwitchD] ospf
[SwitchD-ospf-1] opaque-capability enable
# Enable MPLS TE for OSPF area 0 on Switch D.
[SwitchD-ospf-1-area-0.0.0.0] mpls te enable
6. Configure MPLS TE tunnels on Switch A:
# Configure MPLS TE tunnel interface Tunnel 1 to forward traffic of Enterprise A.
[SwitchA] interface tunnel 1 mode mpls-te
[SwitchA-Tunnel1] ip address 7.1.1.1 255.255.255.0
# Specify the tunnel destination address as the LSR ID of Switch D, use RSVP-TE to establish the tunnel, and assign 20000 kbps bandwidth to the tunnel.
[SwitchA-Tunnel1] destination 4.4.4.4
[SwitchA-Tunnel1] mpls te signaling rsvp-te
[SwitchA-Tunnel1] mpls te bandwidth 20000
# Enable route recording for MPLS TE tunnel 1.
[SwitchA-Tunnel1] mpls te record-route
[SwitchA-Tunnel1] quit
# Configure MPLS TE tunnel interface Tunnel 2 to forward traffic of Enterprise B.
[SwitchA] interface tunnel 2 mode mpls-te
[SwitchA-Tunnel2] ip address 8.1.1.1 255.255.255.0
# Specify the tunnel destination address as the LSR ID of Switch D, use RSVP-TE to establish the tunnel, and assign 30000 kbps bandwidth to the tunnel.
[SwitchA-Tunnel2] destination 4.4.4.4
[SwitchA-Tunnel2] mpls te signaling rsvp-te
[SwitchA-Tunnel2] mpls te bandwidth 30000
# Enable route recording for MPLS TE tunnel 2.
[SwitchA-Tunnel2] mpls te record-route
[SwitchA-Tunnel2] quit
7. Configure static routing on Switch A to direct traffic to the MPLS TE tunnels:
# Configure a static route to direct traffic destined for 50.1.1.0/24 to MPLS TE tunnel interface Tunnel 1.
[SwitchA] ip route-static 50.1.1.0 24 tunnel 1 preference 1
# Configure a static route to direct traffic destined for 60.1.1.0/24 to MPLS TE tunnel interface Tunnel 2.
[SwitchA] ip route-static 60.1.1.0 24 tunnel 2 preference 1
# Execute the display interface tunnel brief command on Switch A. The output shows that the two tunnel interfaces are up.
[SwitchA] display interface tunnel brief
Protocol: (s) - spoofing
Tun1 UP UP 7.1.1.1
Tun2 UP UP 8.1.1.1
# Execute the display mpls te tunnel-interface command on Switch A to display detailed information about the MPLS TE tunnels.
[SwitchA] display mpls te tunnel-interface
Tunnel Name : Tunnel 1
Tunnel State : Up (Main CRLSP up, Shared-resource CRLSP down)
Tunnel Attributes :
LSP ID : 27415 Tunnel ID : 1
Admin State : Normal
Ingress LSR ID : 1.1.1.1 Egress LSR ID : 4.4.4.4
Signaling : RSVP-TE Static CRLSP Name : -
Resv Style : SE
Tunnel mode : -
Reverse-LSP name : -
Class Type : CT0 Tunnel Bandwidth : 20000 kbps
Reserved Bandwidth : 20000 kbps
Setup Priority : 7 Holding Priority : 7
Affinity Attr/Mask : 0/0
Explicit Path : -
Backup Explicit Path : -
Metric Type : TE
Record Route : Enabled Record Label : Disabled
FRR Flag : Disabled Bandwidth Protection : Disabled
Backup Bandwidth Flag: Disabled Backup Bandwidth Type: -
Backup Bandwidth : -
Bypass Tunnel : No Auto Created : No
Route Pinning : Disabled
Retry Limit : 3 Retry Interval : 2 sec
Reoptimization : Disabled Reoptimization Freq : -
Backup Type : None Backup LSP ID : -
Auto Bandwidth : Disabled Auto Bandwidth Freq : -
Collected Bandwidth : -
Tunnel Name : Tunnel 2
Tunnel Attributes :
LSP ID : 27302 Tunnel ID : 2
Resv Style : SE
Tunnel mode : -
Class Type : CT0 Tunnel Bandwidth : 30000 kbps
Reserved Bandwidth : 30000 kbps
Explicit Path : -
Metric Type : TE
# Execute the display ip routing-table command on Switch A. The output shows two static route entries with output interfaces of Tunnel 1 and Tunnel 2.
Destinations : 30 Routes : 31
30.1.1.3 Vlan30
7.1.1.0/24 Direct 0 0 7.1.1.1 Tun1
7.1.1.0/32 Direct 0 0 7.1.1.1 Tun1
7.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
7.1.1.255/32 Direct 0 0 7.1.1.1 Tun1
50.1.1.0/24 Static 1 0 0.0.0.0 Tun1
60.1.1.0/24 Static 1 0 0.0.0.0 Tun2
# Execute the display rsvp lsp verbose command on Switch A to verify the following information:
· Tunnel 1 uses path Switch A—Switch B—Switch D, and has a bandwidth of 20000 kbps.
· Tunnel 2 uses path Switch A—Switch C—Switch D, and has a bandwidth of 30000 kbps.
[SwitchA] display rsvp lsp verbose
Tunnel name: SwitchA_t1
Destination: 4.4.4.4 Source: 1.1.1.1
Tunnel ID: 1 LSP ID: 27415
LSR type: Ingress Direction: Unidirectional
Setup priority: 7 Holding priority: 7
In-Label: - Out-Label: 1146
In-Interface: - Out-Interface: Vlan10
Nexthop: 10.1.1.2 Exclude-any: 0
Include-Any: 0 Include-all: 0
Mean rate (CIR): 20000 kbps Mean burst size (CBS): 1000.00 bytes
Path MTU: 1500 Class type: CT0
RRO number: 6
10.1.1.1/32 Flag: 0x00 (No FRR)
10.1.1.2/32 Flag: 0x00 (No FRR)
2.2.2.2/32 Flag: 0x20 (No FRR/Node-ID)
20.1.1.2/32 Flag: 0x00 (No FRR)
20.1.1.4/32 Flag: 0x00 (No FRR)
4.4.4.4/32 Flag: 0x20 (No FRR/Node-ID)
Fast Reroute protection: None
Tunnel name: SwitchA_t2
Tunnel ID: 2 LSP ID: 27302
In-Label: - Out-Label: 1150
In-Interface: - Out-Interface: Vlan30
Nexthop: 30.1.1.3 Exclude-any: 0
Mean rate (CIR): 30000 kbps Mean burst size (CBS): 1000.00 bytes
RRO number: 6
30.1.1.1/32 Flag: 0x00 (No FRR)
30.1.1.3/32 Flag: 0x00 (No FRR)
3.3.3.3/32 Flag: 0x20 (No FRR/Node-ID)
40.1.1.3/32 Flag: 0x00 (No FRR)
40.1.1.4/32 Flag: 0x00 (No FRR)
Configuration files
· Switch A:
ospf 1
area 0.0.0.0
mpls te enable
mpls lsr-id 1.1.1.1
vlan 10
vlan 30
vlan 70
vlan 80
mpls te
rsvp
interface LoopBack0
ip address 1.1.1.1 255.255.255.255
interface Vlan-interface10
mpls enable
mpls te enable
rsvp enable
interface Vlan-interface30
ip address 30.1.1.1 255.255.255.0
mpls enable
mpls te enable
rsvp enable
interface Vlan-interface70
ip address 70.1.1.1 255.255.255.0
interface Vlan-interface80
ip address 80.1.1.1 255.255.255.0
interface HundredGigE1/0/1
port link-mode bridge
port access vlan 10
interface HundredGigE1/0/2
port access vlan 30
interface HundredGigE1/0/3
port access vlan 70
interface HundredGigE1/0/4
port access vlan 80
interface Tunnel1 mode mpls-te
mpls te bandwidth ct0 20000
destination 4.4.4.4
interface Tunnel2 mode mpls-te
mpls te bandwidth ct0 30000
destination 4.4.4.4
ip route-static 50.1.1.0 24 Tunnel1 preference 1
ip route-static 60.1.1.0 24 Tunnel2 preference 1
· Switch B:
ospf 1
area 0.0.0.0
mpls te enable
mpls lsr-id 2.2.2.2
vlan 10
vlan 20
mpls te
rsvp
interface LoopBack0
ip address 2.2.2.2 255.255.255.255
mpls enable
mpls te enable
rsvp enable
interface Vlan-interface20
ip address 20.1.1.2 255.255.255.0
mpls enable
mpls te enable
rsvp enable
port access vlan 10
port access vlan 20
· Switch C:
ospf 1
area 0.0.0.0
mpls te enable
mpls lsr-id 3.3.3.3
vlan 30
vlan 40
mpls te
rsvp
interface LoopBack0
ip address 3.3.3.3 255.255.255.0
ip address 30.1.1.3 255.255.255.0
mpls enable
mpls te enable
rsvp enable
interface Vlan-interface40
ip address 40.1.1.3 255.255.255.0
mpls enable
mpls te enable
rsvp enable
port access vlan 40
port access vlan 30
· Switch D:
ospf 1
area 0.0.0.0
mpls te enable
mpls lsr-id 4.4.4.4
vlan 20
vlan 40
vlan 50
vlan 60
mpls te
rsvp
interface LoopBack0
ip address 4.4.4.4 255.255.255.255
ip address 20.1.1.4 255.255.255.0
mpls enable
mpls te enable
rsvp enable
ip address 40.1.1.4 255.255.255.0
mpls enable
mpls te enable
rsvp enable
interface Vlan-interface50
ip address 50.1.1.4 255.255.255.0
interface Vlan-interface60
ip address 60.1.1.4 255.255.255.0
port access vlan 40
port access vlan 20
port access vlan 50
port access vlan 60
As shown in Figure 2, Device A, Device B, Device C, and Device D run OSPF.
Establish an MPLS TE tunnel from Device B to Device D that uses the path Device B—Device C—Device D, and configure MPLS TE forwarding adjacency for the tunnel.
Before the tunnel is established, traffic from Device A to Device D is forwarded through the direct link Device A—Device D. After the tunnel is established, the traffic is forwarded through the MPLS TE tunnel.
Analysis
· Enable MPLS TE on nodes and interfaces that the MPLS TE tunnels traverse.
· To make forwarding adjacency take effect, you must establish two MPLS TE tunnels in opposite directions between Device B and Device D, and enable forwarding adjacency on both devices.
· For the MPLS TE tunnel to use the path Device B—Device C—Device D, configure the path as the explicit path for the tunnel.
· For traffic from Device A to Device D to be forwarded through the MPLS TE tunnel, make sure the tunnel's metric is less than 15 (metric 25 minus 10). This example uses 12.
Hardware |
Software version |
Release 6555P01 |
S9820-64H switch |
Release 6555P01 |
Procedures
1. Configure IP addresses for interfaces, configure basic OSPF, and set OSPF costs. (Details not shown.) For the configuration, see "Configuration files."
2. Enable MPLS TE on each node and interface that the MPLS TE tunnel traverses:
# On Device B, configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE.
[DeviceB] mpls lsr-id 2.2.2.2
[DeviceB] mpls te
[DeviceB-te] quit
[DeviceB] rsvp
[DeviceB-rsvp] quit
[DeviceB] interface vlan-interface 23
[DeviceB-Vlan-interface23] mpls enable
[DeviceB-Vlan-interface23] mpls te enable
[DeviceB-Vlan-interface23] rsvp enable
[DeviceB-Vlan-interface23] quit
# On Device C, configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE.
<DeviceC> system-view
[DeviceC] mpls lsr-id 3.3.3.3
[DeviceC] mpls te
[DeviceC-te] quit
[DeviceC] rsvp
[DeviceC-rsvp] quit
[DeviceC] interface vlan-interface 23
[DeviceC-Vlan-interface23] mpls enable
[DeviceC-Vlan-interface23] mpls te enable
[DeviceC-Vlan-interface23] rsvp enable
[DeviceC-Vlan-interface23] quit
[DeviceC] interface vlan-interface 34
[DeviceC-Vlan-interface34] mpls enable
[DeviceC-Vlan-interface34] mpls te enable
[DeviceC-Vlan-interface34] rsvp enable
[DeviceC-Vlan-interface34] quit
# On Device D, configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE.
<DeviceD> system-view
[DeviceD] mpls lsr-id 4.4.4.4
[DeviceD] mpls te
[DeviceD-te] quit
[DeviceD] rsvp
[DeviceD-rsvp] quit
[DeviceD] interface vlan-interface 34
[DeviceD-Vlan-interface34] mpls enable
[DeviceD-Vlan-interface34] mpls te enable
[DeviceD-Vlan-interface34] rsvp enable
[DeviceD-Vlan-interface34] quit
3. Configure OSPF TE to advertise link TE attributes:
# On Device B, enable opaque LSA advertisement and reception, and enable MPLS TE for OSPF area 0. By default, opaque LSA advertisement and reception are enabled.
[DeviceB] ospf
[DeviceB-ospf-1] opaque-capability enable
[DeviceB-ospf-1] area 0
[DeviceB-ospf-1-area-0.0.0.0] mpls te enable
[DeviceB-ospf-1-area-0.0.0.0] quit
[DeviceB-ospf-1] quit
# On Device C, enable opaque LSA advertisement and reception, and enable MPLS TE for OSPF area 0. By default, opaque LSA advertisement and reception are enabled.
[DeviceC] ospf
[DeviceC-ospf-1] opaque-capability enable
[DeviceC-ospf-1] area 0
[DeviceC-ospf-1-area-0.0.0.0] mpls te enable
[DeviceC-ospf-1-area-0.0.0.0] quit
[DeviceC-ospf-1] quit
# On Device D, enable opaque LSA advertisement and reception, and enable MPLS TE for OSPF area 0. By default, opaque LSA advertisement and reception are enabled.
[DeviceD] ospf
[DeviceD-ospf-1] opaque-capability enable
[DeviceD-ospf-1] area 0
[DeviceD-ospf-1-area-0.0.0.0] mpls te enable
[DeviceD-ospf-1-area-0.0.0.0] quit
[DeviceD-ospf-1] quit
4. Configure MPLS TE tunnels:
# On Device B, configure MPLS TE tunnel interface Tunnel 1, and specify the tunnel destination address as the LSR ID of Device D.
[DeviceB] interface tunnel 1 mode mpls-te
[DeviceB-Tunnel1] ip address 9.2.2.2 255.255.255.0
[DeviceB-Tunnel1] destination 4.4.4.4
# Configure MPLS TE to use RSVP-TE to establish the tunnel.
[DeviceB-Tunnel1] mpls te signaling rsvp-te
[DeviceB-Tunnel1] quit
# Configure an explicit path named tun1.
[DeviceB] explicit-path tun1
[DeviceB-explicit-path-tun1] nexthop 23.23.23.3
[DeviceB-explicit-path-tun1] nexthop 34.34.34.4
[DeviceB-explicit-path-tun1]quit
# Specify explicit path tun1 for the tunnel.
[DeviceB–Tunnel1] mpls te path preference 1 explicit-path tun1
# Enable forwarding adjacency for the tunnel.
[DeviceB-Tunnel1] mpls te igp advertise
# Enable OSPF on tunnel interface Tunnel 1 and set the OSPF cost to 12 for the tunnel interface.
[DeviceB-Tunnel1] ospf 1 area 0
[DeviceB-Tunnel1] ospf cost 12
# On Device D, configure MPLS TE tunnel interface Tunnel 1, and specify the tunnel destination address as the LSR ID of Device B.
[DeviceD] interface tunnel 1 mode mpls-te
[DeviceD-Tunnel1] ip address 9.2.2.4 255.255.255.0
[DeviceD-Tunnel1] destination 2.2.2.2
[DeviceD-Tunnel1] mpls te signaling rsvp-te
[DeviceD-Tunnel1] quit
[DeviceD] explicit-path tun1
[DeviceD-explicit-path-tun1] nexthop 34.34.34.3
[DeviceD-explicit-path-tun1] nexthop 23.23.23.2
[DeviceD-explicit-path-tun1]quit
[DeviceD–Tunnel1] mpls te path preference 1 explicit-path tun1
[DeviceD-Tunnel1] mpls te igp advertise
[DeviceD-Tunnel1] ospf 1 area 0
[DeviceD-Tunnel1] ospf cost 12
# Execute the display interface tunnel brief command on Device B and Device D. This example uses Device B. The output shows that Tunnel 1 is up.
[DeviceB] display interface tunnel brief
Tun1 UP UP 9.2.2.2
# Display routing table information on Device A. The output shows that the next hop of the route to Device D is Device B, and the cost is 22 (10 plus 12). The MPLS TE tunnel has been used during IGP route calculation.
[Device A] display ip routing-table
Destinations : 24 Routes : 24
2.2.2.2/32 O_INTRA 10 10 12.12.12.2 Vlan12
3.3.3.3/32 O_INTRA 10 20 12.12.12.2 Vlan12
4.4.4.4/32 O_INTRA 10 22 12.12.12.2 Vlan12
9.2.2.0/24 O_INTRA 10 22 12.12.12.2 Vlan12
10.1.0.3/32 Direct 0 0 127.0.0.1 InLoop0
12.12.12.0/24 Direct 0 0 12.12.12.1 Vlan12
12.12.12.0/32 Direct 0 0 12.12.12.1 Vlan12
12.12.12.1/32 Direct 0 0 127.0.0.1 InLoop0
12.12.12.255/32 Direct 0 0 12.12.12.1 Vlan12
14.14.14.0/24 Direct 0 0 14.14.14.1 Vlan14
14.14.14.0/32 Direct 0 0 14.14.14.1 Vlan14
14.14.14.1/32 Direct 0 0 127.0.0.1 InLoop0
14.14.14.255/32 Direct 0 0 14.14.14.1 Vlan14
23.23.23.0/24 O_INTRA 10 20 12.12.12.2 Vlan12
34.34.34.0/24 O_INTRA 10 30 12.12.12.2 Vlan12
Configuration files
· Device A:
ospf 1
area 0.0.0.0
network 12.12.12.0 0.0.0.255
network 14.14.14.0 0.0.0.255
vlan 12
vlan 14
interface LoopBack0
interface Vlan-interface12
ip address 12.12.12.1 255.255.255.0
ospf cost 10
interface Vlan-interface14
ip address 14.14.14.1 255.255.255.0
ospf cost 25
port access vlan 12
port access vlan 14
· Device B:
ospf 1
area 0.0.0.0
network 23.23.23.0 0.0.0.255
mpls te enable
mpls lsr-id 2.2.2.2
vlan 12
vlan 23
mpls te
explicit-path tun1
nexthop index 1 23.23.23.3 include strict
nexthop index 101 34.34.34.4 include strict
rsvp
interface LoopBack0
ip address 12.12.12.2 255.255.255.0
ospf cost 10
interface Vlan-interface23
ip address 23.23.23.2 255.255.255.0
ospf cost 10
mpls enable
mpls te enable
rsvp enable
port access vlan 12
port access vlan 23
ospf cost 12
ospf 1 area 0.0.0.0
destination 4.4.4.4
· Device C:
ospf 1
area 0.0.0.0
network 34.34.34.0 0.0.0.255
mpls te enable
mpls lsr-id 3.3.3.3
vlan 23
vlan 34
mpls te
rsvp
interface LoopBack0
ip address 3.3.3.3 255.255.255.255
ip address 23.23.23.3 255.255.255.0
ospf cost 10
mpls enable
mpls te enable
rsvp enable
interface Vlan-interface34
ip address 34.34.34.3 255.255.255.0
ospf cost 10
mpls enable
mpls te enable
rsvp enable
port access vlan 34
port access vlan 23
· Device D:
ospf 1
area 0.0.0.0
mpls te enable
mpls lsr-id 4.4.4.4
vlan 14
vlan 34
mpls te
explicit-path tun1
nexthop index 1 34.34.34.3 include strict
nexthop index 101 23.23.23.2 include strict
rsvp
interface LoopBack0
ip address 14.14.14.4 255.255.255.0
ospf cost 25
ip address 34.34.34.4 255.255.255.0
ospf cost 10
mpls enable
mpls te enable
rsvp enable
port access vlan 34
port access vlan 14
ospf cost 12
ospf 1 area 0.0.0.0
destination 2.2.2.2
Related documentation
· H3C S6850 & S9850 Switch Series MPLS Configuration Guide-Release 655x
· H3C S6850 & S9850 Switch Series MPLS Command Reference-Release 655x
· H3C S9820-64H Switch MPLS Configuration Guide-Release 655x
· H3C S9820-64H Switch MPLS Command Reference-Release 655x
