H3C S6850&S9850&S9820-64H Config Examples-Release 655x-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C S6850&S9850&S9820-64H Config Examples-Release 655x-6W100
Table of Contents
Related Documents
04-ISSU Configuration Examples
04-ISSU Configuration Examples 99.79 KB
H3C S6850 & S9850 & S9820-64H
ISSU Examples
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides compatible and incompatible ISSU configuration examples.
Before performing an ISSU, use the display version comp-matrix file command to view the recommended ISSU method in the Upgrade Way field. Table 1 shows a matrix of ISSU types and ISSU methods.
Table 1 Matrix of ISSU types and ISSU methods
ISSU type
ISSU methods
Compatible
The ISSU methods are displayed in the Upgrade Way field.
·          Service Upgrade
·          File Upgrade
·          ISSU Reboot
·          Reboot
Incompatible
Only one upgrade method (Incompatible upgrade) is available, which is displayed at the end of command output.
This document assumes that you have basic knowledge of ISSU.
General restrictions and guidelines
Before performing an ISSU, you must complete the following preparation tasks:
·           Read the software release notes to identify support of the device for ISSU.
·           Use the display device command to verify that no member devices are in Fault state.
·           Use the dir command to verify that each member device has sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files.
·           For service continuity during an ISSU, verify that the following feature settings are configured:
Feature
Setting requirements
GR/NSR
Enable GR or NSR for protocols including LDP, RSVP, OSPF, ISIS, BGP, and FSPF.
BFD
Disable BFD for protocols including LDP, RSVP, OSPF, ISIS, RIP, BGP, VRRP, and NQA.
Ethernet link aggregation
Use the long LACP timeout interval (the lacp period short command is not configured) on all member ports in dynamic aggregation groups.
IRF
Configure IRF bridge MAC persistence as follows:
·          Compatible upgrade—Configure the irf mac-address persistent timer or irf mac-address persistent always command.
·          Incompatible upgrade
¡  Configure the irf mac-address persistent always command if the bridge MAC address is the MAC address of the device for which you want to execute the issu load command.
¡  Disable IRF MAD before the ISSU and enable IRF MAD again after the ISSU.
·           Log in to the device through the console port. If you use Telnet or SSH, you might be disconnected from the device before the ISSU is completed.
During an ISSU, use the following guidelines:
·           In a multiuser environment, make sure no other administrators access the device while you are performing the ISSU.
·           Do not perform any of the following tasks during an ISSU:
¡  Reboot, add, or remove member device.
¡  Execute commands that are not for ISSU.
¡  Modify, delete, or rename image files.
The following describes restrictions and guidelines for an ISSU.
Hardware requirements
·           Do not perform an ISSU during hardware upgrade or failure. Otherwise, upgrade failure or system exceptions might occur.
Upgrade restrictions
·           Use the dir command to verify that the device has sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files by using the delete command.
Feature restrictions
For service continuity during ISSU, configure the following feature settings:
Feature
GR or NSR
BFD
IRF
·          Compatible upgrade—Enable the IRF bridge MAC address to be permanent or remain unchanged for 12 minutes after the address owner leaves .
·          Incompatible upgrade—Enable the IRF bridge MAC address to be permanent if the bridge MAC address is the MAC address of the device for which you want to execute the issu load command.
Operation restrictions
¡  Execute commands that are irrelevant to the ISSU.
Example: Performing a compatible ISSU
As shown in Figure 1, the two-chassis IRF fabric and the TFTP server can reach each other. Perform a compatible ISSU on the IRF to upgrade startup images from T0001015 to T0001016.
Figure 1 Network diagram
Hardware
Software version
S6850 switch series
S9850 switch series
Release 6555P01
S9820-64H switch
Release 6555P01
When you perform the compatible ISSU, follow these restrictions and guidelines:
·           The available storage space on each member device must be at least two times the size of the new image.
·           Do not execute commands that are irrelevant to the ISSU.
·           The automatic rollback timer starts after you execute the issu run switchover command. If no exceptions occur, execute the issu accept or issu commit command to complete the upgrade before this timer expires. If an exception occurs, manually roll back or wait for the system to automatically roll back to the original software images, and then perform a new upgrade.
·           After you execute the issu accept or issu commit command, the system automatically deletes the rollback timer.
Procedures
# Download the new image file T0001016.ipe from the TFTP server to the root directory of a file system on the master. The .ipe file includes the boot-t0001016.bin image file and the system-t0001016.bin image file.
<Sysname> tftp 2.2.2.2 get T0001016.ipe
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 52.2M  100 42.8M    0     0   159k      0  0:04:34  0:04:34 --:--:--  165
# Display current software images.
<Sysname> display install active
Active packages on slot 1:
  flash:/boot-t0001015.bin
  flash:/system-t0001015.bin
Active packages on slot 2:
# Display the recommended ISSU methods.
<Sysname> display version comp-matrix file ipe flash:/T0001016.ipe
Verifying the file flash:/T0001016.ipe on slot 1..................................Done.
Identifying the upgrade methods...........Done.
  Slot                        Upgrade Way
  1                           Reboot
  2                           Reboot
The output shows the two versions are compatible and a reboot is needed to complete upgrade.
# Set the rollback timer to 120 minutes (the default is 45 minutes).
[Sysname] issu rollback-timer 120
<Sysname> quit
# Upgrade the subordinate member.
<Sysname> issu load file ipe flash:/T0001016.ipe slot 2
This operation will delete the rollback point information for the previous upgrade
 and maybe get unsaved configuration lost. Continue? [Y/N]:y
Successfully copied flash:/boot-t0001016.bin to slot2#flash:/boot-t0001016.bin.
Successfully copied flash:/system-t0001016.bin to slot2#flash:/system-t0001016.bin.
  Running Version             New Version
  Test 0001015                Test 0001016
  Slot                        Upgrade Way
  2                           Reboot
# After the subordinate member starts up, verify that the ISSU is finished on the subordinate member.
<Sysname> display issu state
ISSU state: Loaded
Compatibility: Incompatible
Work state: Normal
Upgrade method: Card by card
Upgraded slot: None
Current upgrading slot:
  slot 2
Previous version list:
  boot: 7.1.070 Test 0001015
  system: 7.1.070 Test 0001015
Upgrade version list:
  boot: 7.1.070, Test 0001016
  system: 7.1.070, Test 0001016
# Perform a master/subordinate switchover.
<Sysname> issu run switchover
  Slot                        Switchover Way
  1                           Master subordinate switchover
# Verify that the switchover has completed.
ISSU state: switchover
Compatibility: Unknown
Work state: Normal
Upgrade method: card by card
Upgraded chassis: None
Current upgrading chassis: None
Current version list:
  boot: 7.1.070, Test 0001015
  system: 7.1.070, Test 0001015
Current software images:
// The ISSU state Switchover indicates the switchover has completed.
# Upgrade the original master.
<Sysname> issu commit slot 1
flash: /boot-t0001016.bin
flash: /system-t0001016.bin
  Slot                        Upgrade Way
  1                           Reboot
# View ISSU state.
ISSU state: Init
Work state: Normal
// The Init state indicates that the ISSU has completed.
# Verify that startup images have been upgraded to T0001016.
Configuration files
The system does not save the commands used in the configuration procedures to a configuration file.
Example: Performing an incompatible ISSU
As shown in Figure 2, the two-chassis IRF fabric and the TFTP server can reach each other. Perform an incompatible ISSU on the IRF to upgrade startup images from T0001015 to T0001017.
Figure 2 Network diagram
Hardware
Software version
S6850 switch series
S9850 switch series
Release 6555P01
S9820-64H switch
Release 6555P01
When you perform the incompatible ISSU, follow these restrictions and guidelines:
Procedures
# Download the new image file T0001017.ipe from the TFTP server to the root directory of a file system on the master. The .ipe file includes the boot-t0001017.bin image file and the system-t0001017.bin image file.
<Sysname> tftp 2.2.2.2 get T0001017.ipe
100 50.1M  100 42.8M    0     0   159k      0  0:04:34  0:04:34 --:--:--  165k
# Display the ISSU method.
<Sysname> display version comp-matrix file ipe flash:/T0001017.ipe
Verifying the file flash:/T0001017.ipe on slot 1..................................Done.
Incompatible upgrade.
The output shows the two versions are incompatible and a reboot is needed to complete upgrade.
<Sysname> issu load file ipe flash:/T0001017.ipe slot 2
Successfully copied flash:/boot-t0001017.bin to slot2#flash:/boot-t0001017.bin.
Successfully copied flash:/system-t0001017.bin to slot2#flash:/system-t0001017.bin.
  Test 0001015                Test 0001017
  Slot                        Upgrade Way
  2                           Reboot
Upgrading software images to incompatible versions. Continue? [Y/N]: y
# Verify that the ISSU is finished on the subordinate member.
ISSU state: Loaded
Work state: Normal
Upgraded slot: None
  slot 2
  boot: 7.1.070, Test 0001017
  system: 7.1.070, Test 0001017
# Perform a master/subordinate switchover to complete upgrade.
  Slot                        Upgrade Way
  2                           Reboot
  1                           Reboot
Upgrading software images to incompatible versions. Continue? [Y/N]:y
# View ISSU state.
ISSU state: Init
Work state: Normal
# Verify that startup images have been upgraded to T0001017.
Configuration files
Related documentation
·           H3C S6850 & S9850 Switch Series Fundamentals Configuration Guide-Release 655x
·           H3C S6850 & S9850 Switch Series Fundamentals Command Reference-Release 655x
·           H3C S9820-64H Switch Fundamentals Configuration Guide-Release 655x
·           H3C S9820-64H Switch Fundamentals Command Reference-Release 655x
