- H3C S6850&S9850&S9820-64H Config Examples-Release 655x-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 14-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 15-GRE Tunnel Configuration Examples
- 16-GRE with OSPF Configuration Examples
- 17-OSPF Configuration Examples
- 18-IS-IS Configuration Examples
- 19-BGP Configuration Examples
- 20-Policy-Based Routing Configuration Examples
- 21-OSPFv3 Configuration Examples
- 22-IPv6 IS-IS Configuration Examples
- 23-Routing Policy Configuration Examples
- 24-IGMP Snooping Configuration Examples
- 25-IGMP Configuration Examples
- 26-BIDIR-PIM Configuration Examples
- 27-MLD Snooping Configuration Examples
- 28-IPv6 Multicast VLAN Configuration Examples
- 29-Basic MPLS Configuration Examples
- 30-MPLS L3VPN Configuration Examples
- 31-ACL Configuration Examples
- 32-Control Plane-Based QoS Policy Configuration Examples
- 33-Traffic Policing Configuration Examples
- 34-GTS and Rate Limiting Configuration Examples
- 35-Priority Mapping and Queue Scheduling Configuration Examples
- 36-Traffic Filtering Configuration Examples
- 37-AAA Configuration Examples
- 38-Port Security Configuration Examples
- 39-Portal Configuration Examples
- 40-SSH Configuration Examples
- 41-IP Source Guard Configuration Examples
- 42-Ethernet OAM Configuration Examples
- 43-CFD Configuration Examples
- 44-DLDP Configuration Examples
- 45-VRRP Configuration Examples
- 46-BFD Configuration Examples
- 47-NTP Configuration Examples
- 48-SNMP Configuration Examples
- 49-NQA Configuration Examples
- 50-Mirroring Configuration Examples
- 51-sFlow Configuration Examples
- 52-FCoE Configuration Examples
- 53-OpenFlow Configuration Examples
- 54-MAC Address Table Configuration Examples
- 55-Static Multicast MAC Address Entry Configuration Examples
- 56-IP Unnumbered Configuration Examples
- 57-MVRP Configuration Examples
- 58-MCE Configuration Examples
- 59-Congestion Avoidance and Queue Scheduling Configuration Examples
- 60-Attack Protection Configuration Examples
- 61-Smart Link Configuration Examples
- 62-RRPP Configuration Examples
- 63-BGP Route Selection Configuration Examples
- 64-IS-IS Route Summarization Configuration Examples
- 65-IRF Configuration Examples
- 66-MPLS OAM Configuration Examples
- 67-MPLS TE Configuration Examples
- 68-VXLAN Configuration Examples
- 69-NetStream Configuration Examples
- 70-DRNI Configuration Examples
- 71-DRNI and EVPN Configuration Examples
- 72-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 73-VCF Fabric Configuration Examples
- 74-PTP Configuration Examples
- 75-S-MLAG Configuration Examples
- 76-Puppet Configuration Examples
| 55-Static Multicast MAC Address Entry Configuration Examples | 68.59 KB |
H3C S6850 & S9850 & S9820-64H |
Static Multicast MAC Address Entry |
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring static multicast MAC address entries
Introduction
This document provides configuration examples of static multicast MAC address entries.
This document assumes that you have basic knowledge of multicast MAC addresses.
As shown in Figure 1, Router A runs IGMP and acts as the IGMP querier. Switch A does not run a Layer 2 multicast protocol.
Configure a static multicast MAC address entry on Switch A so that only Host A and Host C can receive multicast data for multicast group 224.1.1.1.
Analysis
Multicast MAC address entries guide Layer 2 multicast forwarding. They can be dynamically created through Layer 2 multicast protocols or manually configured by binding multicast MAC addresses and ports.
In this example, Switch A does not run a Layer 2 multicast protocol. To control destination ports of Layer 2 multicast data, configure a static multicast MAC address entry on Switch A.
Hardware |
Software version |
S6850 switch series S9850 switch series |
Release 6555P01 |
S9820-64H switch |
Release 6555P01 |
When you configure multicast MAC address entries, follow these guidelines:
· You must specify an unused multicast MAC address in a manually configured multicast MAC address entry.
· By default, Ethernet interfaces, VLAN interfaces, and aggregate interfaces are shut down. You must first use the undo shutdown command to bring them up. This example assumes that all these interfaces are already up.
Procedures
# On Switch A, create VLAN 100.
[SwitchA] vlan 100
[SwitchA-vlan100] quit
# Configure HundredGigE 1/0/1 through HundredGigE 1/0/4 to operate in Layer 2 mode, and assign the ports to VLAN 100.
[SwitchA] interface range hundredgige 1/0/1 to hundredgige 1/0/4
[SwitchA-if-range] port access vlan 100
[SwitchA-if-range] quit
# Translate the multicast IP address 224.1.1.1 to a multicast MAC address (0100-5e01-0101). (Details not shown.)
# Create a static entry for the multicast MAC address 0100-5e01-0101 with HundredGigE 1/0/2 and HundredGigE 1/0/4 in VLAN 100 as outgoing ports.
[SwitchA] mac-address multicast 0100-5e01-0101 interface hundredgige 1/0/2 hundredgige 1/0/4 vlan 100
# Display static multicast MAC address entries for VLAN 100 on Switch A.
[SwitchA] display mac-address multicast vlan 100
MAC Address VLAN ID State Port/NickName Aging
0100-5e01-0101 100 Multicast HGE1/0/2 N
HGE1/0/4
The output shows that HundredGigE 1/0/2 and HundredGigE 1/0/4 have become outgoing ports of the multicast MAC group 0100-5e01-0101.
Configuration files
vlan 100
interface HundredGigE1/0/1
port link-mode bridge
interface HundredGigE1/0/2
interface HundredGigE1/0/3
interface HundredGigE1/0/4
mac-address multicast 0100-5e01-0101 interface HundredGigE1/0/2 HundredGigE1/0/4 vlan 100
Related documentation
· H3C S6850 & S9850 Switch Series IP Multicast Configuration Guide-Release 655x
· H3C S6850 & S9850 Switch Series IP Multicast Command Reference-Release 655x
· H3C S9820-64H Switch IP Multicast Configuration Guide-Release 655x
· H3C S9820-64H Switch IP Multicast Command Reference-Release 655x
