H3C S6890 Switch Series Configuration Examples-Release 27xx-6W100
HomeSupportSwitchesS6890 SeriesConfigure & DeployConfiguration ExamplesH3C S6890 Switch Series Configuration Examples-Release 27xx-6W100
Table of Contents
Related Documents
65-VCF Fabric Configuration Examples
65-VCF Fabric Configuration Examples 110.39 KB
Document version: 6W100-20190628
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides VCF fabric configuration examples.
This document assumes that you have basic knowledge of VCF fabric.
Example: Configuring automated VCF fabric deployment
As shown in Figure 1, on a VXLAN network with distributed IP gateways, Device A and Device B are spine nodes, Device C and Device D are leaf nodes that act as the distributed IP gateways, and Device E is the border device that connects to the Internet. Device A through Device E communicate with the director server, the DHCP server, and the NTP server in the management network through their management Ethernet interfaces. VM 1-1 and VM 1-2 belong to Tenant network A, and VM 2-1 and VM 2-2 belong to Tenant network B.
Configure automated VCF fabric deployment to meet the following requirements:
·          The DHCP server assigns IP addresses on subnet 10.11.113.0/24 to the devices.
·          Device A through Device E download a template file issued by the director server to complete automated underlay network deployment after the first power-up.
·          VMs that belong to the same VXLAN can communicate with each other. VMs that belong to different VXLANs can communicate with each other and can access the Internet through the distributed IP gateways.
In this configuration example, Device A and Device B are S6890 series switches, and Device C, Device D, and Device E are S6800 series switches.
Figure 1 Network diagram
Analysis
·          Connect the devices and the servers with cables and make sure they can reach each other.
·          Configure the DHCP server, the TFTP server, and the NTP server so they can provide services correctly.
·          Automated underlay network deployment is implemented on the director server. In this example, H3C DR1000 server is used. With the DR1000 server, the deployment process is visible and network devices are automatically managed after the deployment. For more information about the DR1000 server, see the related user guide.
·          To implement automated overlay network deployment, you can use OpenStack controller system or the Cloud OS+VCF controller solution. In this example, OpenStack controller system is used. For more information about the Cloud OS+VCF controller solution, see the related guide.
Software versions used
This configuration example was created and verified on S6890-CMW710-R2712.
To make sure VMs use the same IP gateway before and after migration, specify the same MAC address for the same VSI interface on each leaf node.
Spine nodes in a VXLAN network with distributed IP gateways are used as the core forwarder on the underlay network. No overlay network configuration is needed on the spine nodes.
By default, interfaces on S6890 switches are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
Configuring the DHCP server
1.        Configure a DHCP address pool to dynamically assign IP addresses on subnet 10.11.113.0/24 to the devices.
2.        Specify 10.11.113.19/24 as the IP address of the TFTP server.
3.        Specify template file aaa.template as the boot file.
The name of the template file that a device obtains varies by device role in the VCF fabric. In this example, a leaf node will obtain boot file name aaa_leaf.template while a spine node will obtain boot file name aaa_spine.template.
Configuring the director server
1.        Install ADDC Director and then install UBA and NTA components.
2.        Install a DHCP plug-in to assign a fixed IP address to ADDC Director.
3.        Configure basic auto configuration parameters, including the network topology type, the network scale, and the address subnets provided by the DHCP server.
4.        Configure network automation parameters:
¡  MAC address of the master spine node.
¡  IP address subnets provided by the master spine node.
¡  Username and password for the master spine node to communicate with other devices.
¡  User role of the master spine node.
¡  Neutron server parameters.
Deploying the controller
Deploy an OpenStack controller node as needed. The following steps are for illustration only.
1.        Install a MySQL database.
2.        Install RabbitMQ.
3.        Add and verify the OpenStack identity service.
4.        Create an OpenStack client.
5.        Add and verify the following services: OpenStack image service, OpenStack Nova service, and OpenStack Neutron service.
Deploying compute nodes
Deploy OpenStack compute nodes as needed. The following steps are for illustration only.
1.        Install the OpenStack Nova related components, openvswitch, and neutron-ovs-agent.
2.        Configure management component related parameters, including the IP address and the username and password to communicate with RabbitMQ.
3.        Restart the services on the compute nodes.
4.        Install OpenStack Dashboard on the controller and then verify that Compute node 1 and Compute node 2 are installed on the dashboard.
Deploying the underlay network
1.        Power up zero-configuration devices Device A through Device E after the network planning is finished and the servers are correctly configured.
Each device performs the following steps to complete automated underlay network deployment after powering up:
a.    Starts up without loading configuration.
b.    Obtains the IP address of the management Ethernet interface, the IP address of the TFTP server, and the name of the boot file from the DHCP server.
c.    Downloads a template file corresponding to its default role in the VCF fabric from the TFTP server.
d.    Compares the version of the template file downloaded from the TFTP server and the version of the current template file. If the two versions are inconsistent, downloads the newer version.
e.    Parses the template file and deploys static configuration in the template file.
Master spine node Device A also assigns an IP address to the loopback interface on Device B through Device E through NETCONF.
f.     Assigns an IP address to the interfaces connected to upstream spine nodes or downstream leaf nodes and runs a routing protocol to implement Layer 3 interconnectivity.
2.        (Optional.) Save the running configuration on the master spine node Device A by using the save command after the automated underlay network deployment finishes. This step prevents Device A from reallocating IP addresses to the loopback interface on Device B through Device E after restart.
Deploying the overlay network
Perform the following tasks on OpenStack Dashboard to complete the automated overlay network deployment:
1.        Create a network named Network.
2.        Create subnets subnet-1 and subnet-2 and then assign network address range 10.10.1.0/24 to subnet-1 and 10.1.1.0/24 to subnet-2.
3.        Create a router named router on the dashboard and then bind a port on the router to subnet subnet-1 and another port to subnet subnet-2.
4.        Create VM 1-1 and VM 2-1 on Compute node 1 and VM 1-2 and VM 2-2 on Compute node 2.
1.        Verify the underlay network topology.
# Display VCF fabric topology information on Device A.
[DeviceA] display vcf-fabric topology
                                  Topology Information
* indicates the master spine role among all spines
SpineIP           Interface                   Link LeafIP           Status
*10.11.113.51     FortyGigE1/0/1              Up   10.11.113.61     Deploying
                  FortyGigE1/0/2              Down --               --
                  FortyGigE1/0/3              Up   10.11.113.62     Deploying
                  FortyGigE1/0/4              Down --               --
                  FortyGigE1/0/5              Up   10.11.113.63     Deploying
                  FortyGigE1/0/6              Down --               --
10.11.113.52      FortyGigE1/0/1              Up   10.11.113.61     Deploying
                  FortyGiE1/0/6               Down --               --
2.        Verify the automated underlay network deployment. In this example, the underlay network configuration on Device C is verified.
# Display information about automated underlay network deployment on Device C.
[DeviceC] display vcf-fabric underlay autoconfigure
success command:
           system
           clock timezone beijing add 08:00:00
           system
           lldp global enable
           lldp compliance cdp
           system
           ospf 1
           non-stop-routing
           area 0.0.0.0
           system
           interface LoopBack0
           system
           l2vpn enable
           system
           vxlan tunnel arp-learning disable
           system
           stp global enable
           system
           ntp-service enable
           ntp-service unicast-server 10.11.113.136 vpn-instance mgmt
           system
           netconf soap https enable
           netconf ssh server enable
           restful https enable
           system
           info-center loghost vpn-instance mgmt 10.11.113.136
           system
           local-user admin
           password ******
           service-type https
           system
           line vty 0 63
           authentication-mode scheme
           system
           vcf-fabric topology enable
           system
           neutron
           rabbit user openstack
           rabbit password ******
           rabbit host ip 10.11.113.136 vpn-instance mgmt
           restful user admin password ******
           vpn-target 1:1 export-extcommunity
           vsi-mac 789c-2f5f-0200
           network-type distributed-vxlan
           l2agent enable
           l3agent enable
           system
           snmp-agent
           snmp-agent community read public
           snmp-agent community write private
           snmp-agent sys-info version all
           snmp-agent packet max-size 4096
           snmp-agent target-host trap address udp-domain 192.181.1.30 vpn-insta
nce mgmt params securityname public v2c
           system
           telnet server enable
           local-user admin
           password ******
           service-type telnet http https
           system
           netconf soap http enable
           local-user admin
           password ******
           service-type http https
           system
           bgp 100
           non-stop-routing
           address-family l2vpn evpn
Uplink interface:
         FortyGigE1/0/1
         FortyGigE1/0/2
IRF allocation:
         Self Bridge Mac: 00e0-fc00-5100
         IRF Status: No
         Member List: [1]
BGP peer configuration:
         10.100.16.17
         10.100.16.16
3.        Verify the automated overlay network deployment. In this example, the overlay network configuration on Device C is verified.
# Display VSI configuration on Device C.
[DeviceC] display current-configuration configuration vsi
vsi vxlan10071
 gateway vsi-interface 8190
 vxlan 10071
 evpn encapsulation vxlan
  route-distinguisher auto
  vpn-target auto export-extcommunity
  vpn-target auto import-extcommunity
return
# Display VSI interface configuration on Device C.
[DeviceC] display current-configuration interface Vsi-interface
interface Vsi-interface4091
ip binding vpn-instance neutron-1015
ip address 108.1.0.1 255.255.0.0 sub
mac-address 789c-2f5f-0200
arp mode uni
distributed-gateway local
# Display information about all VPN instances on Device C.
[DeviceC] display ip vpn-instance
  Total VPN-Instances configured : 6
  VPN-Instance Name               RD                     Create time
  mgmt                                                   2018/04/17 08:49:59
  neutron-1016                    4227879168:1016        2018/04/17 08:50:59
  neutron-1015                    4227879168:1015        2018/04/17 08:51:01
  neutron-1018                    4227879168:1018        2018/04/17 08:51:03
  neutron-1017                    4227879168:1017        2018/04/17 08:51:07
  neutron-1021                    4227879168:1021        2018/04/17 08:51:08
4.        Verify the connectivity between VMs. In this example, the connectivity between VM 1-1 and VM 2-2 is verified.
# Ping VM 2-2 on Compute node 2 from VM 1-1 on Compute node 1.
$ ping 10.1.1.3
Ping 10.1.1.3 (10.1.1.3): 56 data bytes, press CTRL_C to break
56 bytes from 10.1.1.3: icmp_seq=0 ttl=254 time=10.000 ms
56 bytes from 10.1.1.3: icmp_seq=1 ttl=254 time=4.000 ms
56 bytes from 10.1.1.3: icmp_seq=2 ttl=254 time=4.000 ms
56 bytes from 10.1.1.3: icmp_seq=3 ttl=254 time=3.000 ms
56 bytes from 10.1.1.3: icmp_seq=4 ttl=254 time=3.000 ms
 --- Ping statistics for 10.1.1.3 ---
Configuration files
·          Underlay network configuration on Device C:
irf mac-address persistent always
 irf auto-update enable
 undo irf link-delay
 irf member 1 priority 1
ospf 1
 non-stop-routing
 area 0.0.0.0
 lldp compliance cdp
 lldp global enable
interface LoopBack0
 ip address 19.1.1.254 255.255.255.255
interface FortyGigE1/0/1
 port link-mode route
 ip address unnumbered interface LoopBack0
 ospf network-type p2p
 ospf 1 area 0.0.0.0
 lldp compliance admin-status cdp txrx
 lldp management-address arp-learning
 lldp tlv-enable basic-tlv management-address-tlv interface LoopBack0
interface FortyGigE1/0/2
 ospf 1 area 0.0.0.0
bgp 100
 non-stop-routing
 peer 200.1.15.152 as-number 100
 peer 200.1.15.152 connect-interface LoopBack0
 peer 200.1.15.152 password cipher $c$3$CRkr6IFvbGrUgoWHuUCYfSf3XLYWbQ==
 peer 200.1.15.153 as-number 100
 peer 200.1.15.153 connect-interface LoopBack0
 peer 200.1.15.153 password cipher $c$3$NzsdiaPMbqkfL5DJsga/5QHtP+w5tg==
  peer 200.1.15.152 enable
  peer 200.1.15.153 enable
·          Overlay network configuration on Device C:
ip vpn-instance neutron-1017
 route-distinguisher 4227879168:1017
 description d3ca707e-ce59-4682-b2d8-7151744993a2
 vpn-target 1017:1017 import-extcommunity
 vpn-target 1017:1017 1:1 export-extcommunity
ip vpn-instance neutron-1018
 route-distinguisher 4227879168:1018
 description a9c509ca-8ec3-4860-bb03-4a6c9eae2698
 vpn-target 1018:1018 import-extcommunity
 vpn-target 1018:1018 1:1 export-extcommunity
interface vsi-interface4088
ip binding vpn-instance neutron-1018
arp mode uni
interface vsi-interface4089
ip address 10.1.11.1 255.255.255.0
arp mode uni
vsi vxlan10081
arp supprerssion enable
folding disable all
vxlan 10081
evpn encapsulation vlan
vsi vxlan10018
folding disable all
vxlan 10018
interface Ten-GigabieEthernet1/0/5
port link-mode bridge
service-instance 100
encapsulation s-vid 4088
xconnect vsi vxlan10018
service-instance 101
encapsulation s-vid 4089
xconnect vsi vxlan10081
Related documentation
·          H3C S6890 Switch Series Network Management and Monitoring Command Reference (R27xx)
·          H3C S6890 Switch Series Network Management and Monitoring Configuration Guide (R27xx)
