H3C S6890 Switch Series Configuration Examples-Release 27xx-6W100
HomeSupportSwitchesS6890 SeriesConfigure & DeployConfiguration ExamplesH3C S6890 Switch Series Configuration Examples-Release 27xx-6W100
Table of Contents
Related Documents
14-GRE with OSPF Configuration Examples
Document version: 6W100-20190628
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides GRE with OSPF configuration examples.
This document assumes that you have basic knowledge of GRE and OSPF.
Example: Configuring GRE with OSPF
As shown in Figure 1, Device A is the gateway of the headquarters. Device B and Device C are the gateways of Branch 1 and Branch 2, respectively. The gateways have obtained public IP addresses from an ISP and can communicate with one another. Configure GRE with OSPF to meet the following requirements:
·          The headquarters and the branches communicate with one another through the GRE tunnels established between the headquarters and the branches.
·          The gateways learn the routes reaching the destination networks through the tunnel interfaces.
Figure 1 Network diagram
Device
IP address
Device
IP address
Device A
Vlan-int10
191.2.1.1/24
Device B
Vlan-int10
191.3.1.1/24
Vlan-int20
10.1.1.1/24
Vlan-int20
10.7.1.1/24
Tunnel1
10.5.1.1/24
Tunnel1
10.5.1.2/24
Tunnel2
10.6.1.1/24
Device C
Vlan-int10
191.4.1.1/24
Vlan-int20
10.8.1.1/24
Tunnel2
10.6.1.2/24
Software versions used
This configuration example was created and verified on S6890-CMW710-R2712.
Encapsulated packets cannot be forwarded on Layer 3 according to the destination IP addresses and routing tables. You must create a service loopback group of the tunnel service type to loop encapsulated packets back to the forwarding module for Layer 3 forwarding.
By default, interfaces on the devices are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
Before configuring GRE and OSPF, configure an IPv4 routing protocol on the gateways so that they can reach one another. (Details not shown.)
Configuring Device A
# Configure VLAN-interface 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port Ten-GigabitEthernet 1/0/1
[DeviceA-vlan10] quit
[DeviceA-vlan-interface10] ip address 191.2.1.1 255.255.255.0
[DeviceA-vlan-interface10] quit
# Configure other interfaces in the same way VLAN-interface 10 is configured. (Details not shown.)
# Create service loopback group 1, and specify its service type as Tunnel.
[DeviceA] service-loopback group 1 type tunnel
# Add Ten-GigabitEthernet 1/0/3 to service loopback group 1.
[DeviceA] interface Ten-GigabitEthernet 1/0/3
[DeviceA-Ten-GigabitEthernet1/0/3] port service-loopback group 1
[DeviceA-Ten-GigabitEthernet1/0/3] quit
# Create a tunnel interface Tunnel 1, and specify the tunnel mode as GRE/IPv4.
[DeviceA] interface tunnel 1 mode gre
# Configure an IP address for the tunnel interface Tunnel 1.
[DeviceA-Tunnel1] ip address 10.5.1.1 24
# Configure the source interface of the tunnel interface Tunnel 1 as VLAN-interface 10.
[DeviceA-Tunnel1] source vlan-interface 10
# Configure the destination address of the tunnel interface Tunnel 1 as the IP address of VLAN-interface 10 on Device B.
[DeviceA-Tunnel1] destination 191.3.1.1
[DeviceA-Tunnel1] quit
# Create a tunnel interface Tunnel 2, and specify the tunnel mode as GRE/IPv4.
[DeviceA] interface tunnel 2 mode gre
# Configure an IP address for the tunnel interface Tunnel 2.
[DeviceA-Tunnel2] ip address 10.6.1.1 24
# Configure the source interface of the tunnel interface Tunnel 2 as VLAN-interface 10.
[DeviceA-Tunnel2] source vlan-interface 10
# Configure the destination address of the tunnel interface Tunnel 2 as the IP address of VLAN-interface 10 on Device C.
[DeviceA-Tunnel2] destination 191.4.1.1
[DeviceA-Tunnel2] quit
# Configure the OSPF router ID as 10.6.1.1.
[DeviceA] router-id 10.6.1.1
# Enable OSPF process 1.
[DeviceA] ospf 1
# Create OSPF area 0.
[DeviceA-ospf-1] area 0
# Enable OSPF on interfaces whose primary IP addresses are on network 10.1.1.0/24, 10.5.1.0/24, or 10.6.1.0/24 in area 0.
[DeviceA-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] network 10.5.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] network 10.6.1.0 0.0.0.255
Configuring Device B
[DeviceB] vlan 10
[DeviceB-vlan10] port Ten-GigabitEthernet 1/0/1
[DeviceB-vlan10] quit
[DeviceB] interface vlan-interface 10
[DeviceB-vlan-interface10] ip address 191.3.1.1 255.255.255.0
[DeviceB-vlan-interface10] quit
[DeviceB] service-loopback group 1 type tunnel
[DeviceB] interface Ten-GigabitEthernet 1/0/3
[DeviceB-Ten-GigabitEthernet1/0/3] port service-loopback group 1
[DeviceB-Ten-GigabitEthernet1/0/3] quit
[DeviceB] interface tunnel 1 mode gre
[DeviceB-Tunnel1] ip address 10.5.1.2 24
[DeviceB-Tunnel1] source Vlan-interface 10
# Configure the destination address of the tunnel interface Tunnel 1 as the IP address of VLAN-interface 10 on Device A.
[DeviceB-Tunnel1] destination 191.2.1.1
[DeviceB-Tunnel1] quit
# Configure the OSPF router ID as 10.7.1.1.
[DeviceB] router-id 10.7.1.1
[DeviceB] ospf 1
[DeviceB-ospf-1] area 0
# Enable OSPF on interfaces whose primary IP addresses are on network 10.7.1.0/24 or 10.5.1.0/24 in area 0.
[DeviceB-ospf-1-area-0.0.0.0] network 10.7.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] network 10.5.1.0 0.0.0.255
Configuring Device C
<DeviceC> system-view
[DeviceC] vlan 10
[DeviceC-vlan10] port Ten-GigabitEthernet 1/0/1
[DeviceC-vlan10] quit
[DeviceC] interface Vlan-interface 10
[DeviceC-Vlan-interface10] ip address 191.4.1.1 255.255.255.0
[DeviceC-Vlan-interface10] quit
[DeviceC] service-loopback group 1 type tunnel
[DeviceC] interface Ten-GigabitEthernet 1/0/3
[DeviceC-Ten-GigabitEthernet1/0/3] port service-loopback group 1
[DeviceC-Ten-GigabitEthernet1/0/3] quit
[DeviceC] interface tunnel 2 mode gre
[DeviceC-Tunnel2] ip address 10.6.1.2 24
[DeviceC-Tunnel2] source Vlan-interface 10
# Configure the destination address of the tunnel interface Tunnel 2 as the IP address of VLAN-interface 10 on Device A.
[DeviceC-Tunnel2] destination 191.2.1.1
[DeviceC-Tunnel2] quit
# Configure the OSPF router ID as 10.8.1.1.
[DeviceC] router-id 10.8.1.1
[DeviceC] ospf 1
[DeviceC-ospf-1] area 0
# Enable OSPF on interfaces whose primary IP addresses are on network 10.8.1.0/24 or 10.6.1.0/24 in area 0.
[DeviceC-ospf-1-area-0.0.0.0] network 10.8.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] network 10.6.1.0 0.0.0.255
# Verify that Host A can ping Host B successfully.
C:\> ping 10.7.1.2
Pinging 10.7.1.2 with 32 bytes of data:
Reply from 10.7.1.2: bytes=32 time=19ms TTL=253
Reply from 10.7.1.2: bytes=32 time<1ms TTL=253
Ping statistics for 10.7.1.2:
    Minimum = 0ms, Maximum = 19ms, Average = 4ms
# Verify that Host A can ping Host C successfully.
C:\> ping 10.8.1.2
Pinging 10.8.1.2 with 32 bytes of data:
Reply from 10.8.1.2: bytes=32 time=18ms TTL=253
Reply from 10.8.1.2: bytes=32 time<1ms TTL=253
Ping statistics for 10.8.1.2:
# Verify that Host B can ping Host C successfully.
C:\> ping 10.8.1.2
Reply from 10.8.1.2: bytes=32 time=20ms TTL=251
Reply from 10.8.1.2: bytes=32 time<1ms TTL=251
Configuration files
·          Device A
vlan 10
vlan 20
interface Vlan-interface10
interface Vlan-interface20
 port link-mode bridge
 port access vlan 10
 port access vlan 20
interface Tunnel1 mode gre
 source vlan-interface10
 ip address 10.5.1.1 255.255.255.0
interface Tunnel2 mode gre
 ip address 10.6.1.1 255.255.255.0
ospf 1
 area 0.0.0.0
·          Device B
vlan 10
vlan 20
 ip address 10.7.1.1 255.255.255.0
 port access vlan 10
 port access vlan 20
 source Vlan-interface10
 ip address 10.5.1.2 255.255.255.0
ospf 1
 area 0.0.0.0
·          Device C
vlan 10
vlan 20
 ip address 10.8.1.1 255.255.255.0
 port access vlan 10
 port access vlan 20
 ip address 10.6.1.2 255.255.255.0
ospf 1
 area 0.0.0.0
Related documentation
·          H3C S6890 Switch Series Layer 3—IP Routing Command Reference (R27xx)
·          H3C S6890 Switch Series Layer 3—IP Routing Configuration Guide (R27xx)
·          H3C S6890 Switch Series Layer 3—IP Services Command Reference (R27xx)
·          H3C S6890 Switch Series Layer 3—IP Services Configuration Guide (R27xx)
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
