H3C S6890 Switch Series Configuration Examples-Release 27xx-6W100
HomeSupportSwitchesS6890 SeriesConfigure & DeployConfiguration ExamplesH3C S6890 Switch Series Configuration Examples-Release 27xx-6W100
Table of Contents
Related Documents
05-Software Patching Examples
Document version: 6W100-20190628
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides software patching examples that use ISSU install commands.
This document assumes that you have basic knowledge of ISSU.
Example: Patching software
As shown in Figure 1, the two-chassis IRF fabric and the TFTP server can reach each other. The IRF members are running CMW710-SYSTEM-R2712, and they have not been patched before.
Use the patch image file CMW710-SYSTEM-R2712H04.bin to fix bugs without rebooting the members.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on S6890-CMW710-R2712.
When you patch software for a centralized IRF device, follow these restrictions and guidelines:
·          The first time you install patch images, you must start with the master. For subsequent patch installations, you must start with the subordinate members.
·          The patch image version must match the device model and Comware version. For example, to fix bugs in CMW710-SYSTEM-R2712, you must use CMW710-SYSTEM-R2712H04.bin.
Procedures
# Download the patch image file CMW710-SYSTEM-R2712H04.bin from the TFTP server to the root directory of the flash memory on the master.
<Sysname> tftp 2.2.2.2 get CMW710-SYSTEM-R2712H04.bin
Press CTRL+C to abort.
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 25.2M    0 25.2M    0     0   210k      0 --:--:--  0:02:02 --:--:--  209k
# Activate the patch images on the master first and then on the subordinate member. This sequence is used because no patch images have been activated on the IRF fabric.
<Sysname> install activate patch flash:/CMW710-SYSTEM-R2712H04.bin slot 1
This operation maybe take several minutes, please wait.............Done.
<Sysname> install activate patch flash:/CMW710-SYSTEM-R2712H04.bin slot 2
The patch images take effect immediately after they are activated.
# For the patch images to take effect after a reboot, commit the software changes.
<Sysname> install commit
# Verify that the patch images have been activated successfully.
<Sysname> display install active
Active packages on slot 1:
  flash:/CMW710-BOOT-R2712.bin
  flash:/CMW710-SYSTEM-R2712.bin
Active packages on slot 2:
# Verify that the patch image file has been added to the main startup software image list so the images can take effect after a reboot.
<Sysname> display install committed
Committed packages on slot 1:
Committed packages on slot 2:
Configuration files
The system does not save the commands used in the configuration procedures to a configuration file.
Related documentation
·          H3C S6890 Switch Series Fundamentals Command Reference (R27xx)
·          H3C S6890 Switch Series Fundamentals Configuration Guide (R27xx)
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
