H3C S6890 Switch Series Configuration Examples-Release 27xx-6W100
HomeSupportSwitchesS6890 SeriesConfigure & DeployConfiguration ExamplesH3C S6890 Switch Series Configuration Examples-Release 27xx-6W100
Table of Contents
Related Documents
06-Ethernet Link Aggregation Configuration Examples
Document version: 6W100-20190628
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides Ethernet link aggregation configuration examples.
This document assumes that you have basic knowledge of Ethernet link aggregation.
Example: Configuring Layer 2 link aggregation
As shown in Figure 1, both Device A and Device B forward traffic from VLAN 10 and VLAN 20.
Configure link aggregation on Device A and Device B to meet the following requirements:
·          VLAN 10 on Device A can communicate with VLAN 10 on Device B.
·          VLAN 20 on Device A can communicate with VLAN 20 on Device B.
Figure 1 Network diagram
Analysis
To enable traffic from VLAN 10 and VLAN 20 to pass through Layer 2 aggregate interface Bridge-aggregation 1, perform the following tasks:
·          Configure Layer 2 aggregate interface Bridge-aggregation 1 as a trunk port.
·          Assign the aggregate interface to VLAN 10 and VLAN 20.
Software versions used
This configuration example was created and verified on S6890-CMW710-R2712.
When you configure Layer 2 link aggregation, follow these restrictions and guidelines:
·          When you assign a port to an aggregation group, the recommended configuration procedure is as follows:
a.    Use the display this command in interface view to check the following attribute configurations of the port:
-      Port isolation.
-      VLAN.
-      VLAN mapping.
b.    If any of the above configurations exist, use the undo forms of the corresponding commands to remove these configurations. This enables the port to use the default attribute configurations.
c.    Assign the port to the aggregation group.
·          In a static aggregation group, the Selected state of a port is not affected by whether the peer port is added to an aggregation group and is Selected. As a result, the Selected state of a port might be different from the Selected state of the peer port. When both ends support static aggregation and dynamic aggregation, please use dynamic aggregation.
·          By default, interfaces on S6890 switches are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
1.        Configure Device A:
# Create VLAN 10, and assign port Ten-GigabitEthernet 1/0/4 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port ten-gigabitethernet 1/0/4
[DeviceA-vlan10] quit
# Create VLAN 20, and assign port Ten-GigabitEthernet 1/0/5 to VLAN 20.
[DeviceA] vlan 20
[DeviceA-vlan20] port ten-gigabitethernet 1/0/5
[DeviceA-vlan20] quit
# Create Layer 2 aggregate interface Bridge-aggregation 1. Use one of the following methods as needed.
¡  Use the static aggregation mode to create Layer 2 aggregate interface Bridge-aggregation 1.
[DeviceA] interface bridge-aggregation 1
[DeviceA-Bridge-Aggregation1] undo shutdown
[DeviceA-Bridge-Aggregation1] quit
¡  Use the dynamic aggregation mode to create Layer 2 aggregate interface Bridge-aggregation 1.
[DeviceA-Bridge-Aggregation1] link-aggregation mode dynamic
# Assign ports Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/3 to aggregation group 1.
[DeviceA] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/3
[DeviceA-if-range] port link-aggregation group 1
[DeviceA-if-range] undo shutdown
[DeviceA-if-range] quit
# Configure Layer 2 aggregate interface Bridge-aggregation 1 as a trunk port.
[DeviceA-Bridge-Aggregation1] port link-type trunk
Configuring Ten-GigabitEthernet1/0/1 done.
 Configuring Ten-GigabitEthernet1/0/2 done.
 Configuring Ten-GigabitEthernet1/0/3 done.
# Assign the aggregate interface to VLANs 10 and 20.
[DeviceA-Bridge-Aggregation1] port trunk permit vlan 10 20
2.        Configure Device B in the same way Device A is configured. (Details not shown.)
# Display detailed information about the link aggregation groups on Device A.
·          Link aggregation configuration information when the static aggregation mode is used:
[DeviceA] display link-aggregation verbose
Port: A -- Auto port, M -- Management port, R -- Reference port
Flags:  A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
        G -- Defaulted, H -- Expired
Aggregation Interface: Bridge-Aggregation1
Aggregation Mode: Static
Management VLANs: None
  Port             Status  Priority  Oper-Key
  XGE1/0/1(R)      S       32768     1
  XGE1/0/2         S       32768     1
  XGE1/0/3         S       32768     1
The output shows that all member ports in the local aggregation group are in the Selected state. The Selected states of the local member ports are not affected by the Selected states of the peer member ports.
·          Link aggregation configuration information when the dynamic aggregation mode is used:
Aggregation Mode: Dynamic
System ID: 0x8000, 000f-e234-5678
Local:
  Port                Status   Priority Index    Oper-Key               Flag
  XGE1/0/1            S        32768    2        1                      {ACDEF}
  XGE1/0/2            S        32768    3        1                      {ACDEF}
  XGE1/0/3            S        32768    4        1                      {ACDEF}
Remote:
  Actor               Priority Index    Oper-Key SystemID               Flag
  XGE1/0/1(R)         32768    2        1        0x8000, a4e5-c316-0100 {ACDEF}
  XGE1/0/2            32768    3        1        0x8000, a4e5-c316-0100 {ACDEF}
  XGE1/0/3            32768    4        1        0x8000, a4e5-c316-0100 {ACDEF}
The output shows that the local member ports and the corresponding peer member ports are all Selected. In the dynamic link aggregation mode, each local member port and its peer member port have the same Selected state through exchanging LACPDUs. The user data traffic can be forwarded correctly.
Configuration files
·          Device A:
vlan 10
interface Ten-GigabitEthernet1/0/4
 port link-mode bridge
 port access vlan 10
vlan 20
interface Ten-GigabitEthernet1/0/5
 port access vlan 20
¡  In the static aggregation mode:
interface Bridge-Aggregation1
¡  In the dynamic aggregation mode:
·          Device B:
The configuration file on Device B is the same as the configuration file on Device A.
Example: Configuring Layer 2 link aggregation load sharing
As shown in Figure 2, both Device A and Device B forward traffic from VLAN 10 and VLAN 20.
·          VLAN 10 on Device A can communicate with VLAN 10 on Device B. VLAN 20 on Device A can communicate with VLAN 20 on Device B.
·          The packets from VLAN 10 are load shared across the Selected ports of link aggregation group 1 by source MAC addresses. The packets from VLAN 20 are load shared across the Selected ports of link aggregation group 2 based on packet types.
Figure 2 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·          To configure different load sharing modes for packets in different link aggregation groups, configure link aggregation load sharing modes in system view and Layer 2 aggregate interface view.
·          To enable packets from VLAN 10 to pass through aggregate interface Bridge-aggregation 1, assign the aggregate interface to VLAN 10. To enable packets from VLAN 20 to pass through aggregate interface Bridge-aggregation 2, assign the aggregate interface to VLAN 20.
1.        Use the display this command in interface view to check the following attribute configurations of the port:
¡  Port isolation.
¡  VLAN.
¡  VLAN mapping.
2.        If any of the above configurations exist, use the undo forms of the corresponding commands to remove these configurations. This enables the port to use the default attribute configurations.
3.        Assign the port to the aggregation group.
Procedures
# Create VLAN 10, and assign port Ten-GigabitEthernet 1/0/5 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port ten-gigabitethernet 1/0/5
# Create VLAN 20, and assign port Ten-GigabitEthernet 1/0/6 to VLAN 20.
[DeviceA] vlan 20
[DeviceA-vlan20] port ten-gigabitethernet 1/0/6
# Bring up Ten-GigabitEthernet 1/0/5.
[DeviceA] interface ten-gigabitethernet 1/0/5
[DeviceA-Ten-GigabitEthernet1/0/5] undo shutdown
[DeviceA-Ten-GigabitEthernet1/0/5] quit
# Bring up Ten-GigabitEthernet 1/0/6.
[DeviceA] interface ten-gigabitethernet 1/0/6
[DeviceA-Ten-GigabitEthernet1/0/6] undo shutdown
[DeviceA-Ten-GigabitEthernet1/0/6] quit
# Set the global load sharing mode to load share packets based on source MAC addresses.
[DeviceA] link-aggregation global load-sharing mode source-mac
# Assign ports Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 to aggregation group 1.
[DeviceA-Ten-GigabitEthernet1/0/1] undo shutdown
[DeviceA-Ten-GigabitEthernet1/0/1] port link-aggregation group 1
[DeviceA] interface ten-gigabitethernet 1/0/2
[DeviceA-Ten-GigabitEthernet1/0/2] undo shutdown
[DeviceA-Ten-GigabitEthernet1/0/2] port link-aggregation group 1
[DeviceA-Ten-GigabitEthernet1/0/2] quit
# Assign Layer 2 aggregate interface Bridge-aggregation 1 to VLAN 10.
[DeviceA-Bridge-Aggregation1] port access vlan 10
# Create Layer 2 aggregate interface Bridge-aggregation 2.
[DeviceA] interface bridge-aggregation 2
[DeviceA-Bridge-Aggregation2] undo shutdown
# Configure Layer 2 aggregation group 2 to load share packets based on packet types.
[DeviceA-Bridge-Aggregation2] link-aggregation load-sharing mode flexible
[DeviceA-Bridge-Aggregation2] quit
# Assign ports Ten-GigabitEthernet 1/0/3 and Ten-GigabitEthernet 1/0/4 to aggregation group 2.
[DeviceA] interface ten-gigabitethernet 1/0/3
[DeviceA-Ten-GigabitEthernet1/0/3] undo shutdown
[DeviceA-Ten-GigabitEthernet1/0/3] port link-aggregation group 2
[DeviceA-Ten-GigabitEthernet1/0/3] quit
[DeviceA] interface ten-gigabitethernet 1/0/4
[DeviceA-Ten-GigabitEthernet1/0/4] undo shutdown
[DeviceA-Ten-GigabitEthernet1/0/4] port link-aggregation group 2
[DeviceA-Ten-GigabitEthernet1/0/4] quit
# Assign Layer 2 aggregate interface Bridge-aggregation 2 to VLAN 20.
[DeviceA-Bridge-Aggregation2] port access vlan 20
Configuring Ten-GigabitEthernet1/0/4 done.
# Display the information about Selected ports in link aggregation groups on Device A.
Port Status: S -- Selected, U -- Unselected , I -- Individual
  XGE1/0/2         S       32768     1
Aggregation Interface: Bridge-Aggregation2
  XGE1/0/3(R)      S       32768     2
  XGE1/0/4         S       32768     2
·          Link aggregation groups 1 and 2 are both Layer 2 static aggregation groups.
·          Each aggregation group has two Selected ports for forwarding traffic.
# Display the link aggregation load sharing mode of Bridge-aggregation 1.
[DeviceA]display link-aggregation load-sharing mode interface Bridge-Aggregation 1
Bridge-Aggregation1 load-sharing mode:
source-mac address
The output shows that link aggregation group 1 load shares packets based on source MAC addresses.
# Display the link aggregation load sharing mode of Bridge-aggregation 2.
[DeviceA]display link-aggregation load-sharing mode interface Bridge-Aggregation 2
Bridge-Aggregation2 load-sharing mode:
packet type-based sharing
The output shows that link aggregation group 2 load shares packets based on packet types.
Configuration files
·          Device A:
vlan 10
 port access vlan 10
vlan 20
interface Ten-GigabitEthernet1/0/6
 port access vlan 10
 port access vlan 10
 port access vlan 10
 port access vlan 10
interface Bridge-Aggregation2
 port access vlan 20
 port access vlan 20
 port access vlan 20
·          Device B:
Example: Configuring Layer 2 link aggregation in an IRF fabric
On the network as shown in Figure 3, perform the following tasks:
·          Set up a two-chassis IRF fabric at the access layer and a two-chassis IRF fabric at the distribution layer of the enterprise network.
·          Configure link aggregation to improve the reliability of the links between the access-layer and distribution-layer IRF fabrics and implement load sharing.
·          Run LACP MAD on the two IRF fabrics to detect IRF split.
Figure 3 Network diagram
When you configure Layer 2 link aggregation in an IRF fabric, follow these restrictions and guidelines:
·          IRF physical ports must be set to the bridge mode.
·          When you bind physical ports to an IRF port, you must set all the physical ports to operate in either normal or enhanced mode.
·          The physical ports of two connected IRF ports must operate in the same mode: normal or enhanced. For more information about the binding mode of the IRF physical ports, see IRF Configuration Guide.
-      Port isolation.
-      VLAN.
-      VLAN mapping.
Procedures
1.        Configure IRF on Device A:
# Shut down Ten-GigabitEthernet 1/0/1.
[DeviceA-Ten-GigabitEthernet1/0/1] shutdown
# Bind Ten-GigabitEthernet 1/0/1 to IRF port 1/1.
[DeviceA] irf-port 1/1
[DeviceA-irf-port1/1] port group interface ten-gigabitethernet 1/0/1
You must perform the following tasks for a successful IRF setup:
Save the configuration after completing IRF configuration.
Execute the "irf-port-configuration active" command to activate the IRF ports.
[DeviceA-irf-port1/1] quit
# Bring up Ten-GigabitEthernet1/0/1, and save the configuration.
[DeviceA] save
# Activate the IRF port configuration.
[DeviceA] irf-port-configuration active
2.        Configure IRF on Device B:
# Change the member ID of Device B to 2, and reboot the device to validate the change.
[DeviceB] irf member 1 renumber 2
Renumbering the member ID may result in configuration change or loss. Continue? [Y/N]:y
[DeviceB] quit
<DeviceB> reboot
# Shut down Ten-Gigabitethernet 2/0/1.
[DeviceB] interface ten-gigabitethernet 2/0/1
[DeviceB-Ten-GigabitEthernet2/0/1] shutdown
[DeviceB-Ten-GigabitEthernet2/0/1] quit
# Bind Ten-GigabitEthernet 2/0/1 to IRF port 2/2.
[DeviceB] irf-port 2/2
[DeviceB-irf-port2/2] port group interface ten-gigabitethernet 2/0/1
[DeviceB-irf-port2/2] quit
# Bring up Ten-GigabitEthernet 2/0/1, and save the configuration.
[DeviceB-Ten-GigabitEthernet2/0/1] undo shutdown
[DeviceB] save
[DeviceB] irf-port-configuration active
Device A and Device B perform master election, and the one that has lost the election reboots to form an IRF fabric with the master. In this example, Device B reboots.
# Use the display irf command to verify that Device A has become the Master device.
[DeviceA] display irf
MemberID    Role    Priority  CPU-Mac         Description
 *+1        Master   1        00a0-fc00-5801  ---
   2        Standby  1        00e0-fc58-1235  ---
 The bridge MAC of the IRF is: 00a0-fc00-5800
 Auto upgrade                : yes
 Mac persistent              : 6 min
 Domain ID                   : 0
 Auto merge                  : yes
3.        Configure a Layer 2 aggregation group on Device A:
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and configure the link aggregation mode as dynamic.
# Configure Layer 2 aggregation group 1 to load share packets based on packet types.
[DeviceA-Bridge-Aggregation1] link-aggregation load-sharing mode flexible
# Assign ports Ten-GigabitEthernet 1/0/9, Ten-GigabitEthernet1/0/10, Ten-GigabitEthernet 2/0/9, and Ten-GigabitEthernet 2/0/10 to link aggregation group 1.
[DeviceA] interface range ten-gigabitethernet 1/0/9 to ten-gigabitethernet 1/0/10
ten-gigabitethernet 2/0/9 to ten-gigabitethernet 2/0/10
[DeviceA]
Configure LACP MAD on the IRF fabric:
# Set the domain ID of the IRF fabric to 1.
[DeviceA] irf domain 1
# Enable LACP MAD on Bridge-Aggregation 1.
[DeviceA] interface Bridge-Aggregation 1
[DeviceA-Bridge-Aggregation1] mad enable
[Current domain is: 1]:
The assigned domain ID is: 1
MAD LACP only enable on dynamic aggregation interface.
4.        Configure IRF on Device C in the same way IRF is configured on Device A. (Details not shown.)
5.        Configure IRF on Device D in the same way IRF is configured on Device B. (Details not shown.)
Device C and Device D perform master election, and the one that has lost the election reboots to form an IRF fabric with the master. In this example, Device C reboots.
6.        Configure a Layer 2 dynamic aggregation group Bridge-Aggregation 1 on Device C in the same way Bridge-Aggregation 1 is configured on Device A. (Details not shown.)
7.        Configure LACP MAD on the IRF fabric:
# Set the domain ID of the IRF fabric to 2.
<DeviceC> system-view
[DeviceC] irf domain 2
[DeviceC] interface Bridge-Aggregation 1
[DeviceC-Bridge-Aggregation1] mad enable
[Current domain is: 2]:
The assigned domain ID is: 2
# Display the information about the link aggregation groups on Device A.
System ID: 0x8000, 00a0-fc00-5800
Local:
  XGE1/0/9(R)         S        32768    10       1                      {ACG}
  XGE1/0/10           S        32768    11       1                      {ACG}
  XGE2/0/9            S        32768    138      1                      {ACG}
  XGE2/0/10           S        32768    139      1                      {ACG}
Remote:
  XGE1/0/9            32768    0        0        0x8000, 0000-0000-0000 {EF}
  XGE1/0/10           32768    0        0        0x8000, 0000-0000-0000 {EF}
  XGE2/0/9            32768    0        0        0x8000, 0000-0000-0000 {EF}
  XGE2/0/10           32768    0        0        0x8000, 0000-0000-0000 {EF}
# Display the load sharing mode of Layer 2 aggregation group 1 on Device A.
[DeviceA] display link-aggregation load-sharing mode interface Bridge-Aggregation 1
The output shows that Layer 2 aggregation group 1 load shares packets based on packet types.
# Shut down physical IRF port Ten-GigabitEthernet 2/0/1 on Device B.
A log message appears on Device A.
[DeviceA]%Jul  9 16:52:41:734 2016 DeviceA STM/3/STM_LINK_DOWN: -MDC=1; IRF port 1 went down.
%Jul  9 16:52:41:800 2016 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Ten-GigabitEthernet1/0/1 changed to down.
%Jul  9 16:52:41:854 2016 DeviceA IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Ten-GigabitEthernet1/0/1 changed to down.
%Jul  9 16:52:41:867 2016 DeviceA DEV/3/BOARD_REMOVED: -MDC=1; Board was removed from slot 2, type is Simware.
The output shows that IRF split occurs on the distribution layer because Ten-GigabitEthernet 2/0/1 that is bound to IRF port 2/2 is physically down.
Configuration files
·          Device A:
 irf domain 1
 irf mac-address persistent timer
 irf auto-update enable
 irf auto-merge enable
 undo irf link-delay
 irf member 1 priority 1
 irf member 2 priority 1
irf-port 1/1
 port group interface Ten-GigabitEthernet1/0/1 mode enhanced
irf-port 2/2
interface Ten-GigabitEthernet1/0/9
interface Ten-GigabitEthernet1/0/10
interface Ten-GigabitEthernet2/0/9
interface Ten-GigabitEthernet2/0/10
·          Device C:
The configuration file on Device C is similar as the configuration file on Device A.
Example: Configuring Layer 3 link aggregation
On the network as shown in Figure 4, perform the following tasks:
·          Configure a Layer 3 dynamic aggregation group on both Device A and Device B.
·          Configure IP addresses and subnet masks for the corresponding Layer 3 aggregate interfaces.
Figure 4 Network diagram
Procedures
# Create Layer 3 aggregate interface Route-Aggregation 1. Use one of the following methods as needed.
¡  Use the static aggregation mode to create Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA] interface route-aggregation 1
¡  Use the dynamic aggregation mode to create Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA-Route-Aggregation1] link-aggregation mode dynamic
# Configure an IP address and subnet mask for Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA-Route-Aggregation1] ip address 192.168.1.1 24
[DeviceA-Route-Aggregation1] undo shutdown
[DeviceA-Route-Aggregation1] quit
[DeviceA-if-range] port link-mode route
  XGE1/0/1         S       32768    1
  XGE1/0/2         S       32768    1
  XGE1/0/3         S       32768    1
The output shows that all member ports in the local aggregation group are in Selected state. The Selected states of the local member ports are not affected by the Selected states of the peer member ports.
Local:
  XGE1/0/1(R)         S        32768    2        1                      {ACDEF}
Remote:
  XGE1/0/1            32768    2        1        0x8000, 68fa-34f2-0200 {ACDEF}
  XGE1/0/2            32768    3        1        0x8000, 68fa-34f2-0200 {ACDEF}
  XGE1/0/3            32768    4        1        0x8000, 68fa-34f2-0200 {ACDEF}
Configuration files
·          Device A:
interface route-aggregation1
 Device B:
The configuration file on Device B is similar as the configuration file on Device A.
Example: Configuring Layer 3 link aggregation load sharing
On the network as shown in Figure 5, perform the following tasks:
·          Configure Layer 3 static aggregation groups 1 and 2 on Device A and Device B.
·          Configure link aggregation group 1 to load share packets based on source IP addresses.
·          Configure link aggregation group 2 to load share packets based on packet types.
Figure 5 Network diagram
You can configure global or group-specific link aggregation load sharing mode. A link aggregation group preferentially uses the group-specific load sharing mode.
Procedures
# Configure the global load sharing mode to load share packets based on source IP addresses.
[DeviceA] link-aggregation global load-sharing mode source-ip
# Create Layer 3 aggregate interface Route-Aggregation 2.
[DeviceA] interface route-aggregation 2
# Configure Layer 3 aggregation group 2 to load share packets based on packet types.
[DeviceA-Route-Aggregation2] link-aggregation load-sharing mode flexible
# Configure an IP address and subnet mask for Layer 3 aggregate interface Route-Aggregation 2.
[DeviceA-Route-Aggregation2] ip address 192.168.2.1 24
[DeviceA-Route-Aggregation2] undo shutdown
[DeviceA-Route-Aggregation2] quit
# Assign Layer 3 Ethernet interfaces Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 to aggregation group 1.
[DeviceA] interface range ten-gigabitethernet 1/0/1 ten-gigabitethernet 1/0/2
# Assign Layer 3 Ethernet interfaces Ten-GigabitEthernet 1/0/3 and Ten-GigabitEthernet 1/0/4 to aggregation group 2.
[DeviceA] interface range ten-gigabitethernet 1/0/3 ten-gigabitethernet 1/0/4
[DeviceA-if-range] port link-aggregation group 2
# Display detailed information about all aggregation groups on Device A.
  XGE1/0/2         S       32768    1
Aggregate Interface: Route-Aggregation2
  XGE1/0/4         S       32768    2
The output shows that:
·          Link aggregation groups 1 and 2 are both load-shared Layer 3 static aggregation groups.
·          Each aggregation group contains two Selected ports.
# Display the group-specific load sharing modes of all aggregation groups on Device A.
Route-Aggregation1 load-sharing mode:
source-ip address
Route-Aggregation2 load-sharing mode:
·          Link aggregation group 1 load shares packets based on source IP addresses.
·          Link aggregation group 2 load shares packets based on packet types.
Configuration files
·          Device A:
interface Route-Aggregation1
interface Route-Aggregation2
 ip address 192.168.2.1 255.255.255.0
 link-aggregation load-sharing mode destination-ip
·          Device B:
Related documentation
·          H3C S6890 Switch Series Layer 2—LAN Switching Configuration Guide (R27xx)
·          H3C S6890 Switch Series Layer 2—LAN Switching Command Reference (R27xx)
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
